[U-Boot] [PATCH] riscv: add Kconfig entries for the F and D ISA extensions support
This patch add Kconfig entries for the F (Single-Precision) and D (Double-Precision) floating point instruction-set extensions.
Signed-off-by: Eric Lin tesheng@andestech.com --- arch/riscv/Kconfig | 8 ++++++++ arch/riscv/Makefile | 12 ++++++++---- 2 files changed, 16 insertions(+), 4 deletions(-)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 362f3cdc65..a8031fa230 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -91,6 +91,14 @@ config RISCV_ISA_C when building U-Boot, which results in compressed instructions in the U-Boot binary.
+config RISCV_ISA_F + bool "Emit Floating-point instructions" + default n + help + Adds "F" to the ISA subsets that the toolchain is allowed to emit + when building U-Boot, which results in Single and Double-precision instructions + in the U-Boot binary. + config RISCV_ISA_A def_bool y
diff --git a/arch/riscv/Makefile b/arch/riscv/Makefile index 0b80eb8d86..87ec0ea4b5 100644 --- a/arch/riscv/Makefile +++ b/arch/riscv/Makefile @@ -5,15 +5,19 @@
ifeq ($(CONFIG_ARCH_RV64I),y) ARCH_BASE = rv64im - ABI = lp64 + ABI := lp64 endif ifeq ($(CONFIG_ARCH_RV32I),y) ARCH_BASE = rv32im - ABI = ilp32 + ABI := ilp32 endif ifeq ($(CONFIG_RISCV_ISA_A),y) ARCH_A = a endif +ifeq ($(CONFIG_RISCV_ISA_F),y) + ARCH_F = fd + ABI := $(ABI)d +endif ifeq ($(CONFIG_RISCV_ISA_C),y) ARCH_C = c endif @@ -24,8 +28,8 @@ ifeq ($(CONFIG_CMODEL_MEDANY),y) CMODEL = medany endif
-ARCH_FLAGS = -march=$(ARCH_BASE)$(ARCH_A)$(ARCH_C) -mabi=$(ABI) \ - -mcmodel=$(CMODEL) +ARCH_FLAGS = -march=$(ARCH_BASE)$(ARCH_A)$(ARCH_F)$(ARCH_C) -mabi=$(ABI) \ + -mcmodel=$(CMODEL)
PLATFORM_CPPFLAGS += $(ARCH_FLAGS) CFLAGS_EFI += $(ARCH_FLAGS)
Hi Eric,
adds
Could you please provide reason that why U-Boot has to be compiled using F/D extension?
+config RISCV_ISA_F
default n
this can be dropped as default is n
help
This does not match what the config name says. The config name is for F and it cannot indicate both F and D here.
ABI = lp64
ABI := lp64
ABI = ilp32
ABI := ilp32
ARCH_F = fd
ABI := $(ABI)d
-mcmodel=$(CMODEL)
-mcmodel=$(CMODEL)
PLATFORM_CPPFLAGS += $(ARCH_FLAGS) CFLAGS_EFI += $(ARCH_FLAGS) --
Regards, Bin
Hi Bin,
-----Original Message----- From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Tuesday, May 21, 2019 3:56 PM To: Eric Te-Sheng Lin(林德晟) Cc: U-Boot Mailing List; Lukas Auer; Anup Patel; Rick Jian-Zhi Chen(陳建志); Greentime Ying-Han Hu(胡英漢); dslin1010@gmail.com Subject: Re: [PATCH] riscv: add Kconfig entries for the F and D ISA extensions support
Hi Eric,
adds
OK I'll correct it as adds
Cause on AE350 platform, we have two different kinds of toolchain v5d (support I/M/A/C/F/D ISA) and v5 (support I/M/A/C ISA). If we use the v5d toolchain to build U-Boot it will build fail, so we would like to add F/D extension on U-Boot.
in the
U-Boot binary.
+config RISCV_ISA_F
default n
OK, I'll drop it
help
- Double-precision instructions
OK, I'll correct it as follows to cover F and D: config RISCV_ISA_FD bool "Emit Floating-point instructions" help Adds "F" and "D" to the ISA subsets that the toolchain is allowed to emit when building U-Boot, which results in Single and Double-precision instructions in the U-Boot binary.
ABI = lp64
ABI := lp64
ABI = ilp32
ABI := ilp32
ARCH_F = fd
ifeq ($(CONFIG_RISCV_ISA_FD),y) ARCH_FD = fd
ABI := $(ABI)d
-mcmodel=$(CMODEL)
ARCH_FLAGS = -march=$(ARCH_BASE)$(ARCH_A)$(ARCH_FD)$(ARCH_C)
-mabi=$(ABI) \
-mcmodel=$(CMODEL)
Regards, Bin
Thanks for your review.
Regards, Eric CONFIDENTIALITY NOTICE:
This e-mail (and its attachments) may contain confidential and legally privileged information or information protected from disclosure. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution, or use of the information contained herein is strictly prohibited. In this case, please immediately notify the sender by return e-mail, delete the message (and any accompanying documents) and destroy all printed hard copies. Thank you for your cooperation.
Copyright ANDES TECHNOLOGY CORPORATION - All Rights Reserved.
Hi Eric,
On Wed, May 22, 2019 at 4:23 PM tesheng@andestech.com wrote:
Hi Bin,
Hi Eric,
adds
I don't understand. What difference do these two toochains have? Isn't the v5d toolchain's default -march string be pre-configured to imafd? But even if the toolchain is pre-configured to generate fd instruction, I think it can be override by the compiler flags. Can you please share the details of the toolchain you used? I suspect you have to fix your toolchain, not U-Boot.
in the
U-Boot binary.
+config RISCV_ISA_F
default n
OK, I'll drop it
help
ABI = lp64
ABI := lp64
ABI = ilp32
ABI := ilp32
ARCH_F = fd
ABI := $(ABI)d
-mcmodel=$(CMODEL)
-mabi=$(ABI) \
-mcmodel=$(CMODEL)
Regards, Bin
Hi Bin
Bin Meng bmeng.cn@gmail.com 於 2019年5月22日 週三 下午5:25寫道:
Hi Eric,
Hi Bin,
Hi Eric,
adds
It's seems the ABI issue. Because our toolchain don't support multilib, the v5d toolchain libraries ABI is ilp64d. If I use the v5d toolchain to build U-Boot with -mabi=lp64, it will get link error as below: ... riscv64-linux-ld.bfd: /nds64le-linux-glibc-v5d/bin/../lib/gcc/riscv64-linux/7.3.0/libgcc.a(save-restore.o): can't link double-float modules with soft-float modules riscv64-linux-ld.bfd: failed to merge target specific data of file /nds64le-linux-glibc-v5d/bin/../lib/gcc/riscv64-linux/7.3.0/libgcc.a(save-restore.o) examples/standalone/Makefile:62: recipe for target 'examples/standalone/hello_world' failed ...
so we would like to override the compiler flag mabi to lp64d.
in the
U-Boot binary.
+config RISCV_ISA_F
default n
OK, I'll drop it
help
ABI = lp64
ABI := lp64
ABI = ilp32
ABI := ilp32
ARCH_F = fd
ABI := $(ABI)d
-mcmodel=$(CMODEL)
-mabi=$(ABI) \
-mcmodel=$(CMODEL)
Regards, Bin
Thanks for your review Eric
Hi Bin
Hi Eric,
Hi Bin,
Hi Eric,
adds
in the
U-Boot binary.
+config RISCV_ISA_F
default n
OK, I'll drop it
help
ABI = lp64
ABI := lp64
ABI = ilp32
ABI := ilp32
ARCH_F = fd
ABI := $(ABI)d
-mcmodel=$(CMODEL)
-mabi=$(ABI) \
-mcmodel=$(CMODEL)
Regards, Bin
Hi Bin
Hi Eric,
Hi Bin,
Hi Eric,
adds
in the
U-Boot binary.
+config RISCV_ISA_F
default n
OK, I'll drop it
help
ABI = lp64
ABI := lp64
ABI = ilp32
ABI := ilp32
ARCH_F = fd
ABI := $(ABI)d
-mcmodel=$(CMODEL)
-mabi=$(ABI) \
-mcmodel=$(CMODEL)
Regards, Bin
Hi Eric,
On Fri, May 24, 2019 at 4:04 PM Eric Lin dslin1010@gmail.com wrote:
Hi Bin
Hi Eric,
Hi Bin,
Hi Eric,
adds
Then please fix your compiler. Passing -mabi=lp64 to compiler is definitely correct.
No, adding this to U-Boot is a workaround to your compiler.
Regards, Bin
Hi Bin, On Fri, May 24, 2019 at 05:40:08PM +0800, Bin Meng wrote:
Hi Eric,
Hi Bin
Bin Meng bmeng.cn@gmail.com ??? 2019???5???22??? ?????? ??????5:25?????????
Hi Eric,
Hi Bin,
-----Original Message----- From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Tuesday, May 21, 2019 3:56 PM To: Eric Te-Sheng Lin(?????????) Cc: U-Boot Mailing List; Lukas Auer; Anup Patel; Rick Jian-Zhi Chen(?????????); Greentime Ying-Han Hu(?????????); dslin1010@gmail.com Subject: Re: [PATCH] riscv: add Kconfig entries for the F and D ISA extensions support
Hi Eric,
adds
One of our customer ever used floating point in their project. They want to calculate something with floating point instructions in u-Boot before entering kernel.
IMHO, we may consider this case for user to use -mabi=ilp64d. This CONFIG will be useful for them to compile their codes and linking together with u-Boot.
Hi Greentime,
Hi Eric,
Hi Bin
Hi Eric,
Hi Bin,
Hi Eric,
On Tue, May 21, 2019 at 3:18 PM Eric Lin tesheng@andestech.com wrote: > > This patch add Kconfig entries for the F (Single-Precision)
adds
> and D (Double-Precision) floating point instruction-set extensions. >
This is a new use case. For other architectures like x86, we don't allow U-Boot to be compiled using hardware float ABI. Why can't they use software floating point instead?
Regards, Bin
Hi Bin, On Tue, May 28, 2019 at 05:58:47PM +0800, Bin Meng wrote:
Hi Greentime,
Hi Eric,
Hi Bin
Hi Eric,
Hi Bin,
> -----Original Message----- > From: Bin Meng [mailto:bmeng.cn@gmail.com] > Sent: Tuesday, May 21, 2019 3:56 PM > To: Eric Te-Sheng Lin(?????????) > Cc: U-Boot Mailing List; Lukas Auer; Anup Patel; Rick Jian-Zhi Chen(?????????); > Greentime Ying-Han Hu(?????????); dslin1010@gmail.com > Subject: Re: [PATCH] riscv: add Kconfig entries for the F and D ISA extensions > support > > Hi Eric, > > On Tue, May 21, 2019 at 3:18 PM Eric Lin tesheng@andestech.com wrote: > > > > This patch add Kconfig entries for the F (Single-Precision) > > adds >
> > and D (Double-Precision) floating point instruction-set extensions. > > > > Could you please provide reason that why U-Boot has to be compiled using F/D > extension? >
It's because they'd like to calculate something very quickly. It may just be done in few cycles with floating point instructions and it will be very useful for their usages instead of using soft-float.
That's the reason they ask us to provide such kind of CONFIG and we think it might also be helpful for users who are trying to do some mathematics with floating point instructions in u-Boot.
Thanks. :)
Regards, Bin
Hi Greentime,
Hi Eric,
Hi Bin
Hi Eric,
On Wed, May 22, 2019 at 4:23 PM tesheng@andestech.com wrote: > > Hi Bin, > > > -----Original Message----- > > From: Bin Meng [mailto:bmeng.cn@gmail.com] > > Sent: Tuesday, May 21, 2019 3:56 PM > > To: Eric Te-Sheng Lin(?????????) > > Cc: U-Boot Mailing List; Lukas Auer; Anup Patel; Rick Jian-Zhi Chen(?????????); > > Greentime Ying-Han Hu(?????????); dslin1010@gmail.com > > Subject: Re: [PATCH] riscv: add Kconfig entries for the F and D ISA extensions > > support > > > > Hi Eric, > > > > On Tue, May 21, 2019 at 3:18 PM Eric Lin tesheng@andestech.com wrote: > > > > > > This patch add Kconfig entries for the F (Single-Precision) > > > > adds > > > > OK I'll correct it as adds > > > > and D (Double-Precision) floating point instruction-set extensions. > > > > > > > Could you please provide reason that why U-Boot has to be compiled using F/D > > extension? > > > > Cause on AE350 platform, we have two different kinds of toolchain v5d (support I/M/A/C/F/D ISA) and > v5 (support I/M/A/C ISA). If we use the v5d toolchain to build U-Boot it will build fail, so we would like to add F/D extension on U-Boot.
I will have to leave this to other people to comment. I personally do not like this to be supported in the upstream U-Boot. However if others do not object, I am OK too.
Regards, Bin
participants (5)
Bin Meng
Eric Lin
Eric Lin
Greentime Hu
