[U-Boot] [PATCH V2] Add Boundary Devices Nitrogen6X boards
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- Changes for V2: - Update tXS, tXPR as noted by Benoît Thébaudeau - Use struct hdmi_regs and readb()/writeb() as noted by Wolfgang Denk - Use get_ram_size() instead of imx_ddr_size() - Remote unneeded CONFIG_ARP_TIMEOUT
MAINTAINERS | 8 + board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg | 58 ++ board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg | 58 ++ board/boundary/nitrogen6x/6x_bootscript.txt | 63 ++ .../boundary/nitrogen6x/6x_bootscript_android.txt | 64 ++ .../nitrogen6x/6x_bootscript_android_recovery.txt | 64 ++ board/boundary/nitrogen6x/6x_upgrade.txt | 45 + board/boundary/nitrogen6x/800mhz_2x128mx16.cfg | 58 ++ board/boundary/nitrogen6x/800mhz_2x256mx16.cfg | 58 ++ board/boundary/nitrogen6x/800mhz_4x128mx16.cfg | 57 ++ board/boundary/nitrogen6x/800mhz_4x256mx16.cfg | 58 ++ board/boundary/nitrogen6x/Makefile | 41 + board/boundary/nitrogen6x/README | 92 ++ board/boundary/nitrogen6x/clocks.cfg | 46 + board/boundary/nitrogen6x/ddr-setup.cfg | 112 +++ board/boundary/nitrogen6x/nitrogen6dl.cfg | 45 + board/boundary/nitrogen6x/nitrogen6dl2g.cfg | 45 + board/boundary/nitrogen6x/nitrogen6q.cfg | 45 + board/boundary/nitrogen6x/nitrogen6q2g.cfg | 45 + board/boundary/nitrogen6x/nitrogen6s.cfg | 45 + board/boundary/nitrogen6x/nitrogen6s1g.cfg | 45 + board/boundary/nitrogen6x/nitrogen6x.c | 895 ++++++++++++++++++++ boards.cfg | 6 + include/configs/nitrogen6x.h | 286 +++++++ 24 files changed, 2339 insertions(+) create mode 100644 board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/6x_bootscript.txt create mode 100644 board/boundary/nitrogen6x/6x_bootscript_android.txt create mode 100644 board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt create mode 100644 board/boundary/nitrogen6x/6x_upgrade.txt create mode 100644 board/boundary/nitrogen6x/800mhz_2x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_2x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_4x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_4x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/Makefile create mode 100644 board/boundary/nitrogen6x/README create mode 100644 board/boundary/nitrogen6x/clocks.cfg create mode 100644 board/boundary/nitrogen6x/ddr-setup.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6dl.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6dl2g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6q.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6q2g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6s.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6s1g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6x.c create mode 100644 include/configs/nitrogen6x.h
diff --git a/MAINTAINERS b/MAINTAINERS index 175bbe2..f490d62 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1037,6 +1037,14 @@ Pali Rohár pali.rohar@gmail.com
nokia_rx51 ARM ARMV7 (OMAP34xx SoC)
+Eric Nelson eric.nelson@boundarydevices.com + nitrogen6dl i.MX6DL 1GB + nitrogen6dl2g i.MX6DL 2GB + nitrogen6q i.MX6Q/6D 1GB + nitrogen6q2g i.MX6Q/6D 2GB + nitrogen6s i.MX6S 512MB + nitrogen6s1g i.MX6S 1GB + -------------------------------------------------------------------------
Unknown / orphaned boards: diff --git a/board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg b/board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg new file mode 100644 index 0000000..16a37d0 --- /dev/null +++ b/board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x00020036 +DATA 4, MX6_MMDC_P0_MDCFG0, 0x555A7974 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xDB538F64 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MX6_MMDC_P0_MDOR, 0x005A1023 +DATA 4, MX6_MMDC_P0_MDOTC, 0x09444040 +DATA 4, MX6_MMDC_P0_MDPDC, 0x00025576 +DATA 4, MX6_MMDC_P0_MDASP, 0x00000027 +DATA 4, MX6_MMDC_P0_MDCTL, 0x831A0000 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04088032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00428031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x19308030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P0_MDREF, 0x00005800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x42720306 +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x026F0266 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x4273030A +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x02740240 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x45393B3E +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x403A3747 +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x40434541 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x473E4A3B +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x0011000E +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x000E001B +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x00190015 +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x00070018 +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg b/board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg new file mode 100644 index 0000000..0607703 --- /dev/null +++ b/board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x00020036 +DATA 4, MX6_MMDC_P0_MDCFG0, 0x898E7974 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xDB538F64 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MX6_MMDC_P0_MDOR, 0x008E1023 +DATA 4, MX6_MMDC_P0_MDOTC, 0x09444040 +DATA 4, MX6_MMDC_P0_MDPDC, 0x00025576 +DATA 4, MX6_MMDC_P0_MDASP, 0x00000047 +DATA 4, MX6_MMDC_P0_MDCTL, 0x841A0000 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04088032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00428031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x19308030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P0_MDREF, 0x00007800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x43040319 +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x03040279 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x43040321 +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x03030251 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x4d434248 +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x42413c4d +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x34424543 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x49324933 +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x001a0017 +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x001F001F +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x00170027 +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x000a001f +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/boundary/nitrogen6x/6x_bootscript.txt b/board/boundary/nitrogen6x/6x_bootscript.txt new file mode 100644 index 0000000..061b3a4 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_bootscript.txt @@ -0,0 +1,63 @@ +setenv bootargs enable_wait_mode=off +setenv nextcon 0; + +if hdmidet ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=hdmi,1280x720M@60,if=RGB24 + setenv fbmem "fbmem=28M"; + setexpr nextcon $nextcon + 1 +else + echo "------ no HDMI monitor"; +fi + +i2c dev 2 +if i2c probe 0x04 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,LDB-XGA,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbmem "fbmem=10M"; + else + setenv fbmem ${fbmem},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no Freescale display"; +fi + +if i2c probe 0x38 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,1024x600M@60,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbmem "fbmem=10M"; + else + setenv fbmem ${fbmem},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 1024x600 display"; +fi + +if i2c probe 0x48 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=lcd,CLAA-WVGA,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbmem "fbmem=10M"; + else + setenv fbmem ${fbmem},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 800x480 display"; +fi + +while test "3" -ne $nextcon ; do + setenv bootargs $bootargs video=mxcfb${nextcon}:off ; + setexpr nextcon $nextcon + 1 ; +done + +setenv bootargs $bootargs $fbmem +setenv bootargs "$bootargs console=ttymxc1,115200 vmalloc=400M consoleblank=0 rootwait" + +if test "sata" = "${dtype}" ; then + setenv bootargs "$bootargs root=/dev/sda1" ; +else + setenv "bootargs $bootargs root=/dev/mmcblk0p1" ; +fi +${fs}load ${dtype} ${disk}:1 10800000 /boot/uImage && bootm 10800000 ; +echo "Error loading kernel image" diff --git a/board/boundary/nitrogen6x/6x_bootscript_android.txt b/board/boundary/nitrogen6x/6x_bootscript_android.txt new file mode 100644 index 0000000..0982cf8 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_bootscript_android.txt @@ -0,0 +1,64 @@ +${dtype} dev ${disk} + +setenv bootargs enable_wait_mode=off +setenv nextcon 0; +setenv bootargs $bootargs console=ttymxc1,115200 vmalloc=400M consoleblank=0 ; + +i2c dev 2 + +if i2c probe 0x04 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,LDB-XGA,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no Freescale display"; +fi + +if i2c probe 0x38 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,1024x600M@60,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 1024x600 display"; +fi + +if i2c probe 0x48 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=lcd,CLAA-WVGA,if=RGB666 tsdev=tsc2004 calibration + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 800x480 display"; +fi + +if hdmidet ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=hdmi,1280x720M@60,if=RGB24 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=28M"; + else + setenv fbcon ${fbcon},28M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no HDMI monitor"; +fi + +while test "3" -ne $nextcon ; do + setenv bootargs $bootargs video=mxcfb${nextcon}:off ; + setexpr nextcon $nextcon + 1 ; +done + +setenv bootargs $bootargs fbcon=$fbcon +${fs}load ${dtype} ${disk}:1 10800000 uImage && ${fs}load ${dtype} ${disk}:1 12800000 uramdisk.img && bootm 10800000 12800000 +echo "Error loading kernel image" diff --git a/board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt b/board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt new file mode 100644 index 0000000..0982cf8 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt @@ -0,0 +1,64 @@ +${dtype} dev ${disk} + +setenv bootargs enable_wait_mode=off +setenv nextcon 0; +setenv bootargs $bootargs console=ttymxc1,115200 vmalloc=400M consoleblank=0 ; + +i2c dev 2 + +if i2c probe 0x04 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,LDB-XGA,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no Freescale display"; +fi + +if i2c probe 0x38 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,1024x600M@60,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 1024x600 display"; +fi + +if i2c probe 0x48 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=lcd,CLAA-WVGA,if=RGB666 tsdev=tsc2004 calibration + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 800x480 display"; +fi + +if hdmidet ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=hdmi,1280x720M@60,if=RGB24 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=28M"; + else + setenv fbcon ${fbcon},28M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no HDMI monitor"; +fi + +while test "3" -ne $nextcon ; do + setenv bootargs $bootargs video=mxcfb${nextcon}:off ; + setexpr nextcon $nextcon + 1 ; +done + +setenv bootargs $bootargs fbcon=$fbcon +${fs}load ${dtype} ${disk}:1 10800000 uImage && ${fs}load ${dtype} ${disk}:1 12800000 uramdisk.img && bootm 10800000 12800000 +echo "Error loading kernel image" diff --git a/board/boundary/nitrogen6x/6x_upgrade.txt b/board/boundary/nitrogen6x/6x_upgrade.txt new file mode 100644 index 0000000..0d8e8e5 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_upgrade.txt @@ -0,0 +1,45 @@ +setenv stdout serial,vga +echo "check U-Boot" ; +setenv offset 0x400 +if ${fs}load ${dtype} ${disk}:1 12000000 u-boot.imx || ${fs}load ${dtype} ${disk}:1 12000000 u-boot.nopadding ; then + echo "read $filesize bytes from SD card" ; + if sf probe || sf probe || \ + sf probe 1 27000000 || sf probe 1 27000000 ; then + echo "probed SPI ROM" ; + if sf read 0x12400000 $offset $filesize ; then + if cmp.b 0x12000000 0x12400000 $filesize ; then + echo "------- U-Boot versions match" ; + else + echo "Need U-Boot upgrade" ; + echo "Program in 5 seconds" ; + for n in 5 4 3 2 1 ; do + echo $n ; + sleep 1 ; + done + echo "erasing" ; + sf erase 0 0x50000 ; + # two steps to prevent bricking + echo "programming" ; + sf write 0x12000000 $offset $filesize ; + echo "verifying" ; + if sf read 0x12400000 $offset $filesize ; then + if cmp.b 0x12000000 0x12400000 $filesize ; then + while echo "---- U-Boot upgraded. reset" ; do + sleep 120 + done + else + echo "Read verification error" ; + fi + else + echo "Error re-reading EEPROM" ; + fi + fi + else + echo "Error reading boot loader from EEPROM" ; + fi + else + echo "Error initializing EEPROM" ; + fi ; +else + echo "No U-Boot image found on SD card" ; +fi diff --git a/board/boundary/nitrogen6x/800mhz_2x128mx16.cfg b/board/boundary/nitrogen6x/800mhz_2x128mx16.cfg new file mode 100644 index 0000000..de33e65 --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_2x128mx16.cfg @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002002D +DATA 4, MX6_MMDC_P0_MDCFG0, 0x40435323 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xB66E8D63 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MX6_MMDC_P0_MDOR, 0x00431023 +DATA 4, MX6_MMDC_P0_MDOTC, 0x00333030 +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002556D +DATA 4, MX6_MMDC_P0_MDASP, 0x00000017 +DATA 4, MX6_MMDC_P0_MDCTL, 0x83190000 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00048031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x13208030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P0_MDREF, 0x00005800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/boundary/nitrogen6x/800mhz_2x256mx16.cfg b/board/boundary/nitrogen6x/800mhz_2x256mx16.cfg new file mode 100644 index 0000000..19707cf --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_2x256mx16.cfg @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002002D +DATA 4, MX6_MMDC_P0_MDCFG0, 0x696C5323 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xB66E8D63 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MX6_MMDC_P0_MDOR, 0x006C1023 +DATA 4, MX6_MMDC_P0_MDOTC, 0x00333030 +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002556D +DATA 4, MX6_MMDC_P0_MDASP, 0x00000027 +DATA 4, MX6_MMDC_P0_MDCTL, 0x84190000 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00048031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x13208030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P0_MDREF, 0x00007800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/boundary/nitrogen6x/800mhz_4x128mx16.cfg b/board/boundary/nitrogen6x/800mhz_4x128mx16.cfg new file mode 100644 index 0000000..dd6a423 --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_4x128mx16.cfg @@ -0,0 +1,57 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002002D +DATA 4, MX6_MMDC_P0_MDCFG0, 0x40435323 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xB66E8D63 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MX6_MMDC_P0_MDOR, 0x00431023 +DATA 4, MX6_MMDC_P0_MDOTC, 0x00333030 +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002556D +DATA 4, MX6_MMDC_P0_MDASP, 0x00000027 +DATA 4, MX6_MMDC_P0_MDCTL, 0x831A0000 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00048031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x13208030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P0_MDREF, 0x00005800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x420F020F +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x01760175 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x41640171 +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x015E0160 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x45464B4A +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x49484A46 +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x40402E32 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x3A3A3231 +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x003A003A +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x0030002F +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x002F0038 +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x00270039 +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/boundary/nitrogen6x/800mhz_4x256mx16.cfg b/board/boundary/nitrogen6x/800mhz_4x256mx16.cfg new file mode 100644 index 0000000..d5d06e2 --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_4x256mx16.cfg @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002002D +DATA 4, MX6_MMDC_P0_MDCFG0, 0x696C5323 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xB66E8D63 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MX6_MMDC_P0_MDOR, 0x006C1023 +DATA 4, MX6_MMDC_P0_MDOTC, 0x00333030 +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002556D +DATA 4, MX6_MMDC_P0_MDASP, 0x00000047 +DATA 4, MX6_MMDC_P0_MDCTL, 0x841A0000 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00048031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x13208030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MX6_MMDC_P0_MDREF, 0x00007800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/boundary/nitrogen6x/Makefile b/board/boundary/nitrogen6x/Makefile new file mode 100644 index 0000000..fe1e5e0 --- /dev/null +++ b/board/boundary/nitrogen6x/Makefile @@ -0,0 +1,41 @@ +# +# Copyright (C) 2012-2013, Guennadi Liakhovetski lg@denx.de +# (C) Copyright 2012-2013 Freescale Semiconductor, Inc. +# Copyright (C) 2013, Boundary Devices info@boundarydevices.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := nitrogen6x.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/boundary/nitrogen6x/README b/board/boundary/nitrogen6x/README new file mode 100644 index 0000000..5049093 --- /dev/null +++ b/board/boundary/nitrogen6x/README @@ -0,0 +1,92 @@ +U-Boot for the Boundary Devices Nitrogen6X and +Freescale i.MX6Q SabreLite boards + +This file contains information for the port of +U-Boot to the Boundary Devices Nitrogen6X and +Freescale i.MX6Q SabreLite boards. + +1. Boot source, boot from SPI NOR +--------------------------------- +The configuration in this directory supports both the +Nitrogen6X and Freescale SabreLite board, but in a +different fashion from Freescale's implementation in +board/freescale/mx6qsabrelite. + +In particular, this image supports booting from SPI NOR +and saving the environment to SPI NOR. + +It does not support 'boot from SD' at offset 0x400 +except through the 'bmode' command. + http://lists.denx.de/pipermail/u-boot/2012-August/131151.html + +2. Boots using 6x_bootscript on SATA or SD card +----------------------------------------------- +The default bootcmd for these boards is configured +to look for and source a boot script named '6x_bootscript' +in the root of the first partition of the following +devices: + + sata 0 + mmc 0 + mmc 1 + +They're searched in the order listed above, trying both the +ext2 and fat filesystems. + +2. Maintaining the SPI NOR +-------------------------- +A couple of convenience commands + + clearenv - clear environment to factory default + upgradeu - look and source a boot script named + '6x_upgrade' to upgrade the U-Boot version + in SPI NOR. The search is the same as for + 6x_bootscript described above. + +3. Display support +------------------ +U-Boot support for the following displays is configured by +default: + + HDMI - 1024 x 768 for maximum compatibility + Hannstar-XGA - 1024 x 768 LVDS (Freescale part number MCIMX-LVDS1) + wsvga-lvds - 1024 x 600 LVDS (Boundary p/n Nit6X_1024x600) + wvga-rgb - 800 x 480 RGB (Boundary p/n Nit6X_800x480) + +Since the ipuv3_fb display driver currently supports only a single display, +this code auto-detects panel by probing the HDMI Phy for Hot Plug Detect +or the I2C touch controller of the LVDS and RGB displays in the priority +listed above. + +Setting 'panel' environment variable to one of the names above will +override auto-detection and force activation of the specified panel. + +4. Building +------------ + +To build U-Boot for one of the Nitrogen6x or SabreLite board: + + make nitrogen6x_config + make u-boot.imx + +Note that 'nitrogen6x' is a placeholder. The complete list of supported +board configurations is shown in tha MAINTAINERS file: + nitrogen6q i.MX6Q/6D 1GB + nitrogen6dl i.MX6DL 1GB + nitrogen6s i.MX6S 512MB + nitrogen6q2g i.MX6Q/6D 2GB + nitrogen6dl2g i.MX6DL 2GB + nitrogen6s1g i.MX6S 1GB + +The -6q variants support either the i.MX6Quad or i.MX6Dual processors +and are configured for a 64-bit memory bus at 1066 MHz. + +The -6dl variants also use a 64-bit memory bus, operated at 800MHz. + +The -6s variants use a 32-bit memory bus at 800MHz. + +If you place the u-boot.imx into a single-partition SD card +along with a binary version of the boot script 6x_upgrade.txt, +you can program it using 'upgradeu': + + U-Boot> run upgradeu diff --git a/board/boundary/nitrogen6x/clocks.cfg b/board/boundary/nitrogen6x/clocks.cfg new file mode 100644 index 0000000..e7d1f86 --- /dev/null +++ b/board/boundary/nitrogen6x/clocks.cfg @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* set the default clock gate to save power */ +DATA 4, CCM_CCGR0, 0x00C03F3F +DATA 4, CCM_CCGR1, 0x0030FC03 +DATA 4, CCM_CCGR2, 0x0FFFC000 +DATA 4, CCM_CCGR3, 0x3FF00000 +DATA 4, CCM_CCGR4, 0x00FFF300 +DATA 4, CCM_CCGR5, 0x0F0000C3 +DATA 4, CCM_CCGR6, 0x000003FF + +/* enable AXI cache for VDOA/VPU/IPU */ +DATA 4, MX6_IOMUXC_GPR4, 0xF00000CF +/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ +DATA 4, MX6_IOMUXC_GPR6, 0x007F007F +DATA 4, MX6_IOMUXC_GPR7, 0x007F007F diff --git a/board/boundary/nitrogen6x/ddr-setup.cfg b/board/boundary/nitrogen6x/ddr-setup.cfg new file mode 100644 index 0000000..c315812 --- /dev/null +++ b/board/boundary/nitrogen6x/ddr-setup.cfg @@ -0,0 +1,112 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* + * DDR3 settings + * MX6Q ddr is limited to 1066 Mhz currently 1056 MHz(528 MHz clock), + * memory bus width: 64 bits x16/x32/x64 + * MX6DL ddr is limited to 800 MHz(400 MHz clock) + * memory bus width: 64 bits x16/x32/x64 + * MX6SOLO ddr is limited to 800 MHz(400 MHz clock) + * memory bus width: 32 bits x16/x32 + */ +DATA 4, MX6_IOM_DRAM_SDQS0, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS1, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS2, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS3, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS4, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS5, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS6, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS7, 0x00000030 + +DATA 4, MX6_IOM_GRP_B0DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B1DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B2DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B3DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B4DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B5DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B6DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B7DS, 0x00000030 +DATA 4, MX6_IOM_GRP_ADDDS, 0x00000030 +/* 40 Ohm drive strength for cs0/1,sdba2,cke0/1,sdwe */ +DATA 4, MX6_IOM_GRP_CTLDS, 0x00000030 + +DATA 4, MX6_IOM_DRAM_DQM0, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM1, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM2, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM3, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM4, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM5, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM6, 0x00020030 +DATA 4, MX6_IOM_DRAM_DQM7, 0x00020030 + +DATA 4, MX6_IOM_DRAM_CAS, 0x00020030 +DATA 4, MX6_IOM_DRAM_RAS, 0x00020030 +DATA 4, MX6_IOM_DRAM_SDCLK_0, 0x00020030 +DATA 4, MX6_IOM_DRAM_SDCLK_1, 0x00020030 + +DATA 4, MX6_IOM_DRAM_RESET, 0x000e0030 +DATA 4, MX6_IOM_DRAM_SDCKE0, 0x00003000 +DATA 4, MX6_IOM_DRAM_SDCKE1, 0x00003000 + +DATA 4, MX6_IOM_DRAM_SDODT0, 0x00003030 +DATA 4, MX6_IOM_DRAM_SDODT1, 0x00003030 + +/* (differential input) */ +DATA 4, MX6_IOM_DDRMODE_CTL, 0x00020000 +/* (differential input) */ +DATA 4, MX6_IOM_GRP_DDRMODE, 0x00020000 +/* disable ddr pullups */ +DATA 4, MX6_IOM_GRP_DDRPKE, 0x00000000 +DATA 4, MX6_IOM_DRAM_SDBA2, 0x00000000 +/* 40 Ohm drive strength for cs0/1,sdba2,cke0/1,sdwe */ +DATA 4, MX6_IOM_GRP_DDR_TYPE, 0x000C0000 + +/* Read data DQ Byte0-3 delay */ +DATA 4, MX6_MMDC_P0_MPRDDQBY0DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY1DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY2DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY3DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY0DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY1DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY2DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY3DL, 0x33333333 + +/* + * MDMISC mirroring interleaved (row/bank/col) + */ +DATA 4, MX6_MMDC_P0_MDMISC, 0x00081740 + +/* + * MDSCR con_req + */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008000 diff --git a/board/boundary/nitrogen6x/nitrogen6dl.cfg b/board/boundary/nitrogen6x/nitrogen6dl.cfg new file mode 100644 index 0000000..d6da96c --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6dl.cfg @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "800mhz_4x128mx16.cfg" +#include "clocks.cfg" diff --git a/board/boundary/nitrogen6x/nitrogen6dl2g.cfg b/board/boundary/nitrogen6x/nitrogen6dl2g.cfg new file mode 100644 index 0000000..0b1c35c --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6dl2g.cfg @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "800mhz_4x256mx16.cfg" +#include "clocks.cfg" diff --git a/board/boundary/nitrogen6x/nitrogen6q.cfg b/board/boundary/nitrogen6x/nitrogen6q.cfg new file mode 100644 index 0000000..680a853 --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6q.cfg @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "1066mhz_4x128mx16.cfg" +#include "clocks.cfg" diff --git a/board/boundary/nitrogen6x/nitrogen6q2g.cfg b/board/boundary/nitrogen6x/nitrogen6q2g.cfg new file mode 100644 index 0000000..f57ab0e --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6q2g.cfg @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "1066mhz_4x256mx16.cfg" +#include "clocks.cfg" diff --git a/board/boundary/nitrogen6x/nitrogen6s.cfg b/board/boundary/nitrogen6x/nitrogen6s.cfg new file mode 100644 index 0000000..b5af5cc --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6s.cfg @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "800mhz_2x128mx16.cfg" +#include "clocks.cfg" diff --git a/board/boundary/nitrogen6x/nitrogen6s1g.cfg b/board/boundary/nitrogen6x/nitrogen6s1g.cfg new file mode 100644 index 0000000..5aeefc8 --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6s1g.cfg @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "800mhz_2x256mx16.cfg" +#include "clocks.cfg" diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c new file mode 100644 index 0000000..147bd91 --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -0,0 +1,895 @@ +/* + * Copyright (C) 2010-2013 Freescale Semiconductor, Inc. + * Copyright (C) 2013, Boundary Devices info@boundarydevices.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/sys_proto.h> +#include <malloc.h> +#include <asm/arch/mx6-pins.h> +#include <asm/errno.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/imx-common/boot_mode.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <micrel.h> +#include <miiphy.h> +#include <netdev.h> +#include <linux/fb.h> +#include <ipu_pixfmt.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mxc_hdmi.h> +#include <i2c.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define SPI_PAD_CTRL (PAD_CTL_HYS | \ + PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define BUTTON_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define I2C_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE | PAD_CTL_SRE_FAST) + +#define WEAK_PULLUP (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_SRE_SLOW) + +#define WEAK_PULLDOWN (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_SRE_SLOW) + +#define OUTPUT_40OHM (PAD_CTL_SPEED_MED|PAD_CTL_DSE_40ohm) + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + + return 0; +} + +iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_SD3_DAT6__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_SD3_DAT7__UART1_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const uart2_pads[] = { + MX6_PAD_EIM_D26__UART2_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D27__UART2_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) + +/* I2C1, SGTL5000 */ +struct i2c_pads_info i2c_pad_info0 = { + .scl = { + .i2c_mode = MX6_PAD_EIM_D21__I2C1_SCL | PC, + .gpio_mode = MX6_PAD_EIM_D21__GPIO_3_21 | PC, + .gp = IMX_GPIO_NR(3, 21) + }, + .sda = { + .i2c_mode = MX6_PAD_EIM_D28__I2C1_SDA | PC, + .gpio_mode = MX6_PAD_EIM_D28__GPIO_3_28 | PC, + .gp = IMX_GPIO_NR(3, 28) + } +}; + +/* I2C2 Camera, MIPI */ +struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX6_PAD_KEY_COL3__I2C2_SCL | PC, + .gpio_mode = MX6_PAD_KEY_COL3__GPIO_4_12 | PC, + .gp = IMX_GPIO_NR(4, 12) + }, + .sda = { + .i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA | PC, + .gpio_mode = MX6_PAD_KEY_ROW3__GPIO_4_13 | PC, + .gp = IMX_GPIO_NR(4, 13) + } +}; + +/* I2C3, J15 - RGB connector */ +struct i2c_pads_info i2c_pad_info2 = { + .scl = { + .i2c_mode = MX6_PAD_GPIO_5__I2C3_SCL | PC, + .gpio_mode = MX6_PAD_GPIO_5__GPIO_1_5 | PC, + .gp = IMX_GPIO_NR(1, 5) + }, + .sda = { + .i2c_mode = MX6_PAD_GPIO_16__I2C3_SDA | PC, + .gpio_mode = MX6_PAD_GPIO_16__GPIO_7_11 | PC, + .gp = IMX_GPIO_NR(7, 11) + } +}; + +iomux_v3_cfg_t const usdhc3_pads[] = { + MX6_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__USDHC3_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__USDHC3_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__USDHC3_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__USDHC3_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT5__GPIO_7_0 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ +}; + +iomux_v3_cfg_t const usdhc4_pads[] = { + MX6_PAD_SD4_CLK__USDHC4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_CMD__USDHC4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT0__USDHC4_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT1__USDHC4_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT2__USDHC4_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD4_DAT3__USDHC4_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_NANDF_D6__GPIO_2_6 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ +}; + +iomux_v3_cfg_t const enet_pads1[] = { + MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), + /* pin 35 - 1 (PHY_AD2) on reset */ + MX6_PAD_RGMII_RXC__GPIO_6_30 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 32 - 1 - (MODE0) all */ + MX6_PAD_RGMII_RD0__GPIO_6_25 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 31 - 1 - (MODE1) all */ + MX6_PAD_RGMII_RD1__GPIO_6_27 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 28 - 1 - (MODE2) all */ + MX6_PAD_RGMII_RD2__GPIO_6_28 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 27 - 1 - (MODE3) all */ + MX6_PAD_RGMII_RD3__GPIO_6_29 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 33 - 1 - (CLK125_EN) 125Mhz clockout enabled */ + MX6_PAD_RGMII_RX_CTL__GPIO_6_24 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 42 PHY nRST */ + MX6_PAD_EIM_D23__GPIO_3_23 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_ENET_RXD0__GPIO_1_27 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +iomux_v3_cfg_t const enet_pads2[] = { + MX6_PAD_RGMII_RXC__ENET_RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD0__ENET_RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD1__ENET_RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD2__ENET_RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD3__ENET_RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + +/* wl1271 pads on nitrogen6x */ +iomux_v3_cfg_t const wl12xx_pads[] = { + (MX6_PAD_NANDF_CS1__GPIO_6_14 & ~MUX_PAD_CTRL_MASK) + | MUX_PAD_CTRL(WEAK_PULLDOWN), + (MX6_PAD_NANDF_CS2__GPIO_6_15 & ~MUX_PAD_CTRL_MASK) + | MUX_PAD_CTRL(OUTPUT_40OHM), + (MX6_PAD_NANDF_CS3__GPIO_6_16 & ~MUX_PAD_CTRL_MASK) + | MUX_PAD_CTRL(OUTPUT_40OHM), +}; +#define WL12XX_WL_IRQ_GP IMX_GPIO_NR(6, 14) +#define WL12XX_WL_ENABLE_GP IMX_GPIO_NR(6, 15) +#define WL12XX_BT_ENABLE_GP IMX_GPIO_NR(6, 16) + +/* Button assignments for J14 */ +static iomux_v3_cfg_t const button_pads[] = { + /* Menu */ + MX6_PAD_NANDF_D1__GPIO_2_1 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Back */ + MX6_PAD_NANDF_D2__GPIO_2_2 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Labelled Search (mapped to Power under Android) */ + MX6_PAD_NANDF_D3__GPIO_2_3 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Home */ + MX6_PAD_NANDF_D4__GPIO_2_4 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Volume Down */ + MX6_PAD_GPIO_19__GPIO_4_5 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Volume Up */ + MX6_PAD_GPIO_18__GPIO_7_13 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), +}; + +static void setup_iomux_enet(void) +{ + gpio_direction_output(IMX_GPIO_NR(3, 23), 0); /* SABRE Lite PHY rst */ + gpio_direction_output(IMX_GPIO_NR(1, 27), 0); /* Nitrogen6X PHY rst */ + gpio_direction_output(IMX_GPIO_NR(6, 30), 1); + gpio_direction_output(IMX_GPIO_NR(6, 25), 1); + gpio_direction_output(IMX_GPIO_NR(6, 27), 1); + gpio_direction_output(IMX_GPIO_NR(6, 28), 1); + gpio_direction_output(IMX_GPIO_NR(6, 29), 1); + imx_iomux_v3_setup_multiple_pads(enet_pads1, ARRAY_SIZE(enet_pads1)); + gpio_direction_output(IMX_GPIO_NR(6, 24), 1); + + /* Need delay 10ms according to KSZ9021 spec */ + udelay(1000 * 10); + gpio_set_value(IMX_GPIO_NR(3, 23), 1); /* SABRE Lite PHY reset */ + gpio_set_value(IMX_GPIO_NR(1, 27), 1); /* Nitrogen6X PHY reset */ + + imx_iomux_v3_setup_multiple_pads(enet_pads2, ARRAY_SIZE(enet_pads2)); +} + +iomux_v3_cfg_t const usb_pads[] = { + MX6_PAD_GPIO_17__GPIO_7_12 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); + imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads)); +} + +#ifdef CONFIG_USB_EHCI_MX6 +int board_ehci_hcd_init(int port) +{ + imx_iomux_v3_setup_multiple_pads(usb_pads, ARRAY_SIZE(usb_pads)); + + /* Reset USB hub */ + gpio_direction_output(IMX_GPIO_NR(7, 12), 0); + mdelay(2); + gpio_set_value(IMX_GPIO_NR(7, 12), 1); + + return 0; +} +#endif + +#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC3_BASE_ADDR}, + {USDHC4_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret; + + if (cfg->esdhc_base == USDHC3_BASE_ADDR) { + gpio_direction_input(IMX_GPIO_NR(7, 0)); + ret = !gpio_get_value(IMX_GPIO_NR(7, 0)); + } else { + gpio_direction_input(IMX_GPIO_NR(2, 6)); + ret = !gpio_get_value(IMX_GPIO_NR(2, 6)); + } + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + s32 status = 0; + u32 index = 0; + + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); + + for (index = 0; index < CONFIG_SYS_FSL_USDHC_NUM; ++index) { + switch (index) { + case 0: + imx_iomux_v3_setup_multiple_pads( + usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + break; + case 1: + imx_iomux_v3_setup_multiple_pads( + usdhc4_pads, ARRAY_SIZE(usdhc4_pads)); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) then supported by the board (%d)\n", + index + 1, CONFIG_SYS_FSL_USDHC_NUM); + return status; + } + + status |= fsl_esdhc_initialize(bis, &usdhc_cfg[index]); + } + + return status; +} +#endif + +u32 get_board_rev(void) +{ + return 0x63000; +} + +#ifdef CONFIG_MXC_SPI +iomux_v3_cfg_t const ecspi1_pads[] = { + /* SS1 */ + MX6_PAD_EIM_D19__GPIO_3_19 | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D17__ECSPI1_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D18__ECSPI1_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D16__ECSPI1_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), +}; + +void setup_spi(void) +{ + gpio_direction_output(CONFIG_SF_DEFAULT_CS, 1); + imx_iomux_v3_setup_multiple_pads(ecspi1_pads, + ARRAY_SIZE(ecspi1_pads)); +} +#endif + +int board_phy_config(struct phy_device *phydev) +{ + /* min rx data delay */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW, 0x0); + /* min tx data delay */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW, 0x0); + /* max rx/tx clock delay, min rx/tx control */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_CLOCK_SKEW, 0xf0f0); + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + uint32_t base = IMX_FEC_BASE; + struct mii_dev *bus = NULL; + struct phy_device *phydev = NULL; + int ret; + + setup_iomux_enet(); + +#ifdef CONFIG_FEC_MXC + bus = fec_get_miibus(base, -1); + if (!bus) + return 0; + /* scan phy 4,5,6,7 */ + phydev = phy_find_by_mask(bus, (0xf << 4), PHY_INTERFACE_MODE_RGMII); + if (!phydev) { + free(bus); + return 0; + } + printf("using phy at %d\n", phydev->addr); + ret = fec_probe(bis, -1, base, bus, phydev); + if (ret) { + printf("FEC MXC: %s:failed\n", __func__); + free(phydev); + free(bus); + } +#endif + return 0; +} + +static void setup_buttons(void) +{ + imx_iomux_v3_setup_multiple_pads(button_pads, + ARRAY_SIZE(button_pads)); +} + +#ifdef CONFIG_CMD_SATA + +int setup_sata(void) +{ + struct iomuxc_base_regs *const iomuxc_regs + = (struct iomuxc_base_regs *) IOMUXC_BASE_ADDR; + int ret = enable_sata_clock(); + if (ret) + return ret; + + clrsetbits_le32(&iomuxc_regs->gpr[13], + IOMUXC_GPR13_SATA_MASK, + IOMUXC_GPR13_SATA_PHY_8_RXEQ_3P0DB + |IOMUXC_GPR13_SATA_PHY_7_SATA2M + |IOMUXC_GPR13_SATA_SPEED_3G + |(3<<IOMUXC_GPR13_SATA_PHY_6_SHIFT) + |IOMUXC_GPR13_SATA_SATA_PHY_5_SS_DISABLED + |IOMUXC_GPR13_SATA_SATA_PHY_4_ATTEN_9_16 + |IOMUXC_GPR13_SATA_PHY_3_TXBOOST_0P00_DB + |IOMUXC_GPR13_SATA_PHY_2_TX_1P104V + |IOMUXC_GPR13_SATA_PHY_1_SLOW); + + return 0; +} +#endif + +#if defined(CONFIG_VIDEO_IPUV3) + +static iomux_v3_cfg_t const backlight_pads[] = { + /* Backlight on RGB connector: J15 */ + MX6_PAD_SD1_DAT3__GPIO_1_21 | MUX_PAD_CTRL(NO_PAD_CTRL), +#define RGB_BACKLIGHT_GP IMX_GPIO_NR(1, 21) + + /* Backlight on LVDS connector: J6 */ + MX6_PAD_SD1_CMD__GPIO_1_18 | MUX_PAD_CTRL(NO_PAD_CTRL), +#define LVDS_BACKLIGHT_GP IMX_GPIO_NR(1, 18) +}; + +static iomux_v3_cfg_t const rgb_pads[] = { + MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK, + MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15, + MX6_PAD_DI0_PIN2__IPU1_DI0_PIN2, + MX6_PAD_DI0_PIN3__IPU1_DI0_PIN3, + MX6_PAD_DI0_PIN4__GPIO_4_20, + MX6_PAD_DISP0_DAT0__IPU1_DISP0_DAT_0, + MX6_PAD_DISP0_DAT1__IPU1_DISP0_DAT_1, + MX6_PAD_DISP0_DAT2__IPU1_DISP0_DAT_2, + MX6_PAD_DISP0_DAT3__IPU1_DISP0_DAT_3, + MX6_PAD_DISP0_DAT4__IPU1_DISP0_DAT_4, + MX6_PAD_DISP0_DAT5__IPU1_DISP0_DAT_5, + MX6_PAD_DISP0_DAT6__IPU1_DISP0_DAT_6, + MX6_PAD_DISP0_DAT7__IPU1_DISP0_DAT_7, + MX6_PAD_DISP0_DAT8__IPU1_DISP0_DAT_8, + MX6_PAD_DISP0_DAT9__IPU1_DISP0_DAT_9, + MX6_PAD_DISP0_DAT10__IPU1_DISP0_DAT_10, + MX6_PAD_DISP0_DAT11__IPU1_DISP0_DAT_11, + MX6_PAD_DISP0_DAT12__IPU1_DISP0_DAT_12, + MX6_PAD_DISP0_DAT13__IPU1_DISP0_DAT_13, + MX6_PAD_DISP0_DAT14__IPU1_DISP0_DAT_14, + MX6_PAD_DISP0_DAT15__IPU1_DISP0_DAT_15, + MX6_PAD_DISP0_DAT16__IPU1_DISP0_DAT_16, + MX6_PAD_DISP0_DAT17__IPU1_DISP0_DAT_17, + MX6_PAD_DISP0_DAT18__IPU1_DISP0_DAT_18, + MX6_PAD_DISP0_DAT19__IPU1_DISP0_DAT_19, + MX6_PAD_DISP0_DAT20__IPU1_DISP0_DAT_20, + MX6_PAD_DISP0_DAT21__IPU1_DISP0_DAT_21, + MX6_PAD_DISP0_DAT22__IPU1_DISP0_DAT_22, + MX6_PAD_DISP0_DAT23__IPU1_DISP0_DAT_23, +}; + +struct display_info_t { + int bus; + int addr; + int pixfmt; + int (*detect)(struct display_info_t const *dev); + void (*enable)(struct display_info_t const *dev); + struct fb_videomode mode; +}; + + +static int detect_hdmi(struct display_info_t const *dev) +{ + struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; + return readb(&hdmi->phy_stat0) & HDMI_PHY_HPD; +} + +static void enable_hdmi(struct display_info_t const *dev) +{ + struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; + u8 reg; + printf("%s: setup HDMI monitor\n", __func__); + reg = readb(&hdmi->phy_conf0); + reg |= HDMI_PHY_CONF0_PDZ_MASK; + writeb(reg, &hdmi->phy_conf0); + + udelay(3000); + reg |= HDMI_PHY_CONF0_ENTMDS_MASK; + writeb(reg, &hdmi->phy_conf0); + udelay(3000); + reg |= HDMI_PHY_CONF0_GEN2_TXPWRON_MASK; + writeb(reg, &hdmi->phy_conf0); + writeb(HDMI_MC_PHYRSTZ_ASSERT, &hdmi->mc_phyrstz); +} + +static int detect_i2c(struct display_info_t const *dev) +{ + return ((0 == i2c_set_bus_num(dev->bus)) + && + (0 == i2c_probe(dev->addr))); +} + +static void enable_lvds(struct display_info_t const *dev) +{ + struct iomuxc *iomux = (struct iomuxc *) + IOMUXC_BASE_ADDR; + u32 reg = readl(&iomux->gpr[2]); + reg |= IOMUXC_GPR2_DATA_WIDTH_CH0_24BIT; + writel(reg, &iomux->gpr[2]); + gpio_direction_output(LVDS_BACKLIGHT_GP, 1); +} + +static void enable_rgb(struct display_info_t const *dev) +{ + imx_iomux_v3_setup_multiple_pads( + rgb_pads, + ARRAY_SIZE(rgb_pads)); + gpio_direction_output(RGB_BACKLIGHT_GP, 1); +} + +static struct display_info_t const displays[] = {{ + .bus = -1, + .addr = 0, + .pixfmt = IPU_PIX_FMT_RGB24, + .detect = detect_hdmi, + .enable = enable_hdmi, + .mode = { + .name = "HDMI", + .refresh = 60, + .xres = 1024, + .yres = 768, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +} }, { + .bus = 2, + .addr = 0x4, + .pixfmt = IPU_PIX_FMT_LVDS666, + .detect = detect_i2c, + .enable = enable_lvds, + .mode = { + .name = "Hannstar-XGA", + .refresh = 60, + .xres = 1024, + .yres = 768, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +} }, { + .bus = 2, + .addr = 0x38, + .pixfmt = IPU_PIX_FMT_LVDS666, + .detect = detect_i2c, + .enable = enable_lvds, + .mode = { + .name = "wsvga-lvds", + .refresh = 60, + .xres = 1024, + .yres = 600, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +} }, { + .bus = 2, + .addr = 0x48, + .pixfmt = IPU_PIX_FMT_RGB666, + .detect = detect_i2c, + .enable = enable_rgb, + .mode = { + .name = "wvga-rgb", + .refresh = 57, + .xres = 800, + .yres = 480, + .pixclock = 37037, + .left_margin = 40, + .right_margin = 60, + .upper_margin = 10, + .lower_margin = 10, + .hsync_len = 20, + .vsync_len = 10, + .sync = 0, + .vmode = FB_VMODE_NONINTERLACED +} } }; + +int board_video_skip(void) +{ + int i; + int ret; + char const *panel = getenv("panel"); + if (!panel) { + for (i = 0; i < ARRAY_SIZE(displays); i++) { + struct display_info_t const *dev = displays+i; + if (dev->detect(dev)) { + panel = dev->mode.name; + printf("auto-detected panel %s\n", panel); + break; + } + } + if (!panel) { + panel = displays[0].mode.name; + printf("No panel detected: default to %s\n", panel); + } + } else { + for (i = 0; i < ARRAY_SIZE(displays); i++) { + if (!strcmp(panel, displays[i].mode.name)) + break; + } + } + if (i < ARRAY_SIZE(displays)) { + ret = ipuv3_fb_init(&displays[i].mode, 0, + displays[i].pixfmt); + if (!ret) { + displays[i].enable(displays+i); + printf("Display: %s (%ux%u)\n", + displays[i].mode.name, + displays[i].mode.xres, + displays[i].mode.yres); + } else + printf("LCD %s cannot be configured: %d\n", + displays[i].mode.name, ret); + } else { + printf("unsupported panel %s\n", panel); + ret = -EINVAL; + } + return (0 != ret); +} + +static void setup_display(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + struct hdmi_regs *hdmi = (struct hdmi_regs *)HDMI_ARB_BASE_ADDR; + + int reg; + + /* Turn on LDB0,IPU,IPU DI0 clocks */ + reg = __raw_readl(&mxc_ccm->CCGR3); + reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET + |MXC_CCM_CCGR3_LDB_DI0_MASK; + writel(reg, &mxc_ccm->CCGR3); + + /* Turn on HDMI PHY clock */ + reg = __raw_readl(&mxc_ccm->CCGR2); + reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK + |MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK; + writel(reg, &mxc_ccm->CCGR2); + + /* clear HDMI PHY reset */ + writeb(HDMI_MC_PHYRSTZ_DEASSERT, &hdmi->mc_phyrstz); + + /* set PFD1_FRAC to 0x13 == 455 MHz (480*18)/0x13 */ + writel(ANATOP_PFD_480_PFD1_FRAC_MASK, &anatop->pfd_480_clr); + writel(0x13<<ANATOP_PFD_480_PFD1_FRAC_SHIFT, &anatop->pfd_480_set); + + /* set LDB0, LDB1 clk select to 011/011 */ + reg = readl(&mxc_ccm->cs2cdr); + reg &= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK + |MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK); + reg |= (3<<MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET) + |(3<<MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET); + writel(reg, &mxc_ccm->cs2cdr); + + reg = readl(&mxc_ccm->cscmr2); + reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV; + writel(reg, &mxc_ccm->cscmr2); + + reg = readl(&mxc_ccm->chsccdr); + reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK + |MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK + |MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK); + reg |= (CHSCCDR_CLK_SEL_LDB_DI0 + <<MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET) + |(CHSCCDR_PODF_DIVIDE_BY_3 + <<MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET) + |(CHSCCDR_IPU_PRE_CLK_540M_PFD + <<MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); + writel(reg, &mxc_ccm->chsccdr); + + reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES + |IOMUXC_GPR2_DI1_VS_POLARITY_ACTIVE_HIGH + |IOMUXC_GPR2_DI0_VS_POLARITY_ACTIVE_LOW + |IOMUXC_GPR2_BIT_MAPPING_CH1_SPWG + |IOMUXC_GPR2_DATA_WIDTH_CH1_18BIT + |IOMUXC_GPR2_BIT_MAPPING_CH0_SPWG + |IOMUXC_GPR2_DATA_WIDTH_CH0_18BIT + |IOMUXC_GPR2_LVDS_CH1_MODE_DISABLED + |IOMUXC_GPR2_LVDS_CH0_MODE_ENABLED_DI0; + writel(reg, &iomux->gpr[2]); + + reg = readl(&iomux->gpr[3]); + reg = (reg & ~IOMUXC_GPR3_LVDS0_MUX_CTL_MASK) + | (IOMUXC_GPR3_MUX_SRC_IPU1_DI0 + <<IOMUXC_GPR3_LVDS0_MUX_CTL_OFFSET); + writel(reg, &iomux->gpr[3]); + + /* backlights off until needed */ + imx_iomux_v3_setup_multiple_pads(backlight_pads, + ARRAY_SIZE(backlight_pads)); + gpio_direction_input(LVDS_BACKLIGHT_GP); + gpio_direction_input(RGB_BACKLIGHT_GP); +} +#endif + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + /* Disable wl1271 For Nitrogen6w */ + gpio_direction_input(WL12XX_WL_IRQ_GP); + gpio_direction_output(WL12XX_WL_ENABLE_GP, 0); + gpio_direction_output(WL12XX_BT_ENABLE_GP, 0); + + imx_iomux_v3_setup_multiple_pads(wl12xx_pads, ARRAY_SIZE(wl12xx_pads)); + setup_buttons(); + +#if defined(CONFIG_VIDEO_IPUV3) + setup_display(); +#endif + return 0; +} + +/* + * Do not overwrite the console + * Use always serial for U-Boot console + */ +int overwrite_console(void) +{ + return 1; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + +#ifdef CONFIG_MXC_SPI + setup_spi(); +#endif + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info0); + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); + +#ifdef CONFIG_CMD_SATA + setup_sata(); +#endif + + return 0; +} + +int checkboard(void) +{ + if (gpio_get_value(WL12XX_WL_IRQ_GP)) + puts("Board: Nitrogen6X\n"); + else + puts("Board: SABRE Lite\n"); + + return 0; +} + +struct button_key { + char const *name; + unsigned gpnum; + char ident; +}; + +static struct button_key const buttons[] = { + {"back", IMX_GPIO_NR(2, 2), 'B'}, + {"home", IMX_GPIO_NR(2, 4), 'H'}, + {"menu", IMX_GPIO_NR(2, 1), 'M'}, + {"search", IMX_GPIO_NR(2, 3), 'S'}, + {"volup", IMX_GPIO_NR(7, 13), 'V'}, + {"voldown", IMX_GPIO_NR(4, 5), 'v'}, +}; + +/* + * generate a null-terminated string containing the buttons pressed + * returns number of keys pressed + */ +static int read_keys(char *buf) +{ + int i, numpressed = 0; + for (i = 0; i < ARRAY_SIZE(buttons); i++) { + if (!gpio_get_value(buttons[i].gpnum)) + buf[numpressed++] = buttons[i].ident; + } + buf[numpressed] = '\0'; + return numpressed; +} + +static int do_kbd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + char envvalue[ARRAY_SIZE(buttons)+1]; + int numpressed = read_keys(envvalue); + setenv("keybd", envvalue); + return numpressed == 0; +} + +U_BOOT_CMD( + kbd, 1, 1, do_kbd, + "Tests for keypresses, sets 'keybd' environment variable", + "Returns 0 (true) to shell if key is pressed." +); + +#ifdef CONFIG_PREBOOT +static char const kbd_magic_prefix[] = "key_magic"; +static char const kbd_command_prefix[] = "key_cmd"; + +static void preboot_keys(void) +{ + int numpressed; + char keypress[ARRAY_SIZE(buttons)+1]; + numpressed = read_keys(keypress); + if (numpressed) { + char *kbd_magic_keys = getenv("magic_keys"); + char *suffix; + /* + * loop over all magic keys + */ + for (suffix = kbd_magic_keys; *suffix; ++suffix) { + char *keys; + char magic[sizeof(kbd_magic_prefix) + 1]; + sprintf(magic, "%s%c", kbd_magic_prefix, *suffix); + keys = getenv(magic); + if (keys) { + if (!strcmp(keys, keypress)) + break; + } + } + if (*suffix) { + char cmd_name[sizeof(kbd_command_prefix) + 1]; + char *cmd; + sprintf(cmd_name, "%s%c", kbd_command_prefix, *suffix); + cmd = getenv(cmd_name); + if (cmd) { + setenv("preboot", cmd); + return; + } + } + } +} +#endif + +#ifdef CONFIG_CMD_BMODE +static const struct boot_mode board_boot_modes[] = { + /* 4 bit bus width */ + {"mmc0", MAKE_CFGVAL(0x40, 0x30, 0x00, 0x00)}, + {"mmc1", MAKE_CFGVAL(0x40, 0x38, 0x00, 0x00)}, + {NULL, 0}, +}; +#endif + +int misc_init_r(void) +{ +#ifdef CONFIG_PREBOOT + preboot_keys(); +#endif + +#ifdef CONFIG_CMD_BMODE + add_board_boot_modes(board_boot_modes); +#endif + return 0; +} diff --git a/boards.cfg b/boards.cfg index 7a0b79d..fb3b197 100644 --- a/boards.cfg +++ b/boards.cfg @@ -255,6 +255,12 @@ mx6qsabreauto arm armv7 mx6qsabreauto freesca mx6qsabrelite arm armv7 mx6qsabrelite freescale mx6 mx6qsabrelite:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg mx6qsabresd arm armv7 mx6qsabresd freescale mx6 mx6qsabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg eco5pk arm armv7 eco5pk 8dtech omap3 +nitrogen6dl arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 +nitrogen6dl2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048 +nitrogen6q arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024 +nitrogen6q2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 +nitrogen6s arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 +nitrogen6s1g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,SDRAM_MB=1024 cm_t35 arm armv7 cm_t35 - omap3 omap3_overo arm armv7 overo - omap3 omap3_pandora arm armv7 pandora - omap3 diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h new file mode 100644 index 0000000..05f6813 --- /dev/null +++ b/include/configs/nitrogen6x.h @@ -0,0 +1,286 @@ +/* + * Copyright (C) 2010-2011 Freescale Semiconductor, Inc. + * + * Configuration settings for the Boundary Devices Nitrogen6X + * and Freescale i.MX6Q Sabre Lite boards. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_MX6 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_MACH_TYPE 3769 + +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MISC_INIT_R +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART2_BASE + +#define CONFIG_CMD_SF +#ifdef CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SST +#define CONFIG_MXC_SPI +#define CONFIG_SF_DEFAULT_BUS 0 +#define CONFIG_SF_DEFAULT_CS (0|(IMX_GPIO_NR(3, 19)<<8)) +#define CONFIG_SF_DEFAULT_SPEED 25000000 +#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) +#endif + +/* I2C Configs */ +#define CONFIG_CMD_I2C +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_MXC +#define CONFIG_SYS_I2C_SPEED 100000 + +/* OCOTP Configs */ +#define CONFIG_CMD_IMXOTP +#ifdef CONFIG_CMD_IMXOTP +#define CONFIG_IMX_OTP +#define IMX_OTP_BASE OCOTP_BASE_ADDR +#define IMX_OTP_ADDR_MAX 0x7F +#define IMX_OTP_DATA_ERROR_VAL 0xBADABADA +#define IMX_OTPWRITE_ENABLED +#endif + +/* MMC Configs */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +#ifdef CONFIG_MX6Q +#define CONFIG_CMD_SATA +#endif + +/* + * SATA Configs + */ +#ifdef CONFIG_CMD_SATA +#define CONFIG_DWC_AHSATA +#define CONFIG_SYS_SATA_MAX_DEVICE 1 +#define CONFIG_DWC_AHSATA_PORT_ID 0 +#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR +#define CONFIG_LBA48 +#define CONFIG_LIBATA +#endif + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 6 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9021 + +/* USB Configs */ +#define CONFIG_CMD_USB +#define CONFIG_CMD_FAT +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX6 +#define CONFIG_USB_STORAGE +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_USB_ETHER_SMSC95XX +#define CONFIG_MXC_USB_PORT 1 +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 + +/* Miscellaneous commands */ +#define CONFIG_CMD_BMODE +#define CONFIG_CMD_SETEXPR + +/* Framebuffer and LCD */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_IPUV3 +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_LOGO +#define CONFIG_IPUV3_CLK 260000000 +#define CONFIG_CMD_HDMIDETECT +#define CONFIG_CONSOLE_MUX + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Command definition */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 1 + +#define CONFIG_PREBOOT "" + +#define CONFIG_LOADADDR 0x12000000 +#define CONFIG_SYS_TEXT_BASE 0x17800000 + +#ifdef CONFIG_CMD_SATA +#define CONFIG_DRIVE_SATA "sata " +#else +#define CONFIG_DRIVE_SATA +#endif + +#ifdef CONFIG_CMD_MMC +#define CONFIG_DRIVE_MMC "mmc " +#else +#define CONFIG_DRIVE_MMC +#endif + +#define CONFIG_DRIVE_TYPES CONFIG_DRIVE_SATA CONFIG_DRIVE_MMC + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console=ttymxc1\0" \ + "clearenv=if sf probe || sf probe || sf probe 1 ; then " \ + "sf erase 0xc0000 0x2000 && " \ + "echo restored environment to factory default ; fi\0" \ + "bootcmd=for dtype in " CONFIG_DRIVE_TYPES \ + "; do " \ + "for disk in 0 1 ; do ${dtype} dev ${disk} ;" \ + "for fs in fat ext2 ; do " \ + "${fs}load " \ + "${dtype} ${disk}:1 " \ + "10008000 " \ + "/6x_bootscript" \ + "&& source 10008000 ; " \ + "done ; " \ + "done ; " \ + "done; " \ + "setenv stdout serial,vga ; " \ + "echo ; echo 6x_bootscript not found ; " \ + "echo ; echo serial console at 115200, 8N1 ; echo ; " \ + "echo details at http://boundarydevices.com/6q_bootscript ; " \ + "setenv stdout serial\0" \ + "upgradeu=for dtype in " CONFIG_DRIVE_TYPES \ + "; do " \ + "for disk in 0 1 ; do ${dtype} dev ${disk} ;" \ + "for fs in fat ext2 ; do " \ + "${fs}load ${dtype} ${disk}:1 10008000 " \ + "/6x_upgrade " \ + "&& source 10008000 ; " \ + "done ; " \ + "done ; " \ + "done\0" \ + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "U-Boot > " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 1024 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MEMTEST_START 0x10000000 +#define CONFIG_SYS_MEMTEST_END 0x10010000 +#define CONFIG_SYS_MEMTEST_SCRATCH 0x10800000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_EDITING + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define PHYS_SDRAM_SIZE (CONFIG_DDR_MB * 1024 * 1024) + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SIZE (8 * 1024) + +/* #define CONFIG_ENV_IS_IN_MMC */ +#define CONFIG_ENV_IS_IN_SPI_FLASH + +#if defined(CONFIG_ENV_IS_IN_MMC) +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) +#define CONFIG_ENV_OFFSET (768 * 1024) +#define CONFIG_ENV_SECT_SIZE (8 * 1024) +#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS +#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS +#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#endif + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ + +#define CONFIG_SYS_DCACHE_OFF + +#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif + +#define CONFIG_CMD_BMP + +#define CONFIG_CMD_TIME +#define CONFIG_SYS_ALT_MEMTEST + +#endif /* __CONFIG_H */
On 3/9/2013 5:04 PM, Eric Nelson wrote:
diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c new file mode 100644 index 0000000..147bd91 --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -0,0 +1,895 @@ +int dram_init(void) +{
- gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
This will hang a solo if
PHYS_SDRAM_SIZE is bigger than actual memory size
which makes calling get_ram_size pretty useless.
Troy
Dear Troy,
If this is the case, then there is a bug in the code resp. the code is incomplete. get_ram_size() has always been used to detect smaller than the maximum possible (configured) RAM sizes; actually this is it's main purpose.
If this is not really working, then it needs to be fixed.
Hi Troy,
Since the DDR size must be known in the memory configuration file, this is equivalent to saying:
get_ram_size() will hang if we run the **wrong** U-Boot binary on the device
I think this is true for other reasons as well (SATA?).
The DDR size in this translated from the boards.cfg file, which defines CONFIG_DDR_MB for each configuration and nitrogen6x.h, which uses it to define PHYS_SDRAM_SIZE
But your point about calling get_ram_size() being useless is probably true.
Testing for RAM that we need to configure doesn't add anything.
Regards,
Eric
Dear Eric,
In message 1362873856-14785-1-git-send-email-eric.nelson@boundarydevices.com you wrote:
+Eric Nelson eric.nelson@boundarydevices.com
- nitrogen6dl i.MX6DL 1GB
- nitrogen6dl2g i.MX6DL 2GB
- nitrogen6q i.MX6Q/6D 1GB
- nitrogen6q2g i.MX6Q/6D 2GB
- nitrogen6s i.MX6S 512MB
- nitrogen6s1g i.MX6S 1GB
Why do we need different configurations for example for nitrogen6dl and nitrogen6dl2g? My understanding is that the difference is mainly the RAM size on the boards?
In this case it should be possible to configure U-Boot for the maximum possible RAM size (2 GB here?), then have get_ram_size() detect the actual available amount, and then adjust settings as needed.
At least this is how U-Boot ius supposed to work.
It is a maintenance nightmare if each and every configuration requires a separate U-Boot image. We don't want to have this.
Hi Wolfgang,
On 03/10/2013 12:59 AM, Wolfgang Denk wrote:
Dear Eric,
The difference is entirely the RAM size.
More specifically, it's the difference in the DDR density populated on the board.
I'm not certain.
The JEDEC spec for the DDR devices we're using have quite different settings in a couple of areas. In particular, the tRFC value is quite different between densities.
They do appear to be minimums though, so we may be able to configure for the slowest value, run get_ram_size(), then reset that value once we determine whether the larger or smaller parts were populated on the board.
Well...
That throws a wrinkle into the whole patch set, since all of this code presumes that we're running from DDR and other calibration data was also gathered based on the actual parts used.
If this is a hard requirement, I don't see a solution that doesn't require the use of SPL, which will clearly take a while.
Please advise,
Eric
Dear Eric Nelson,
I'm not certain.
Well, of course. Different memory types / sizes will require different initialization. But this you already have in place. Now go the final step and auto-select the configuration instead of having the user (and manufacturer, and service, etc.) all suffer from the pain of always needing to know which exact configuration is needed on some board.
This is wrong then and needs to be fixed. get_ram_size() should be used before relocation into RAM.
Hi Wolfgang,
On 03/10/2013 08:45 AM, Wolfgang Denk wrote:
Dear Eric Nelson,
I'm not certain.
What we don't have is auto-detection and implementing this logic requires that we execute code outside of DDR (i.e. through SPL in internal RAM).
There's no question that a (more) universal binary would be helpful, but in practice, checking the DDR parts isn't that different from double-checking the CPU variant populated on a board.
Troy's attempt at handling the CPU portion of things was nacked, which is what prompted me to this architecture of multiple CPU configurations.
Either you or I are missing something.
As it stands, there is no "execute before relocation into RAM". The CPU's ROM boot loader processes the settings in the DCD (essentially a set of register writes) and then copies the U-Boot code into DDR for execution.
The register writes need to configure the DDR before the copy.
The only way to change this is to use a first level loader that executes code within the internal RAM so the setup can be conditional.
Are you saying that submissions of board files that don't support SPL will be nacked, or only boards that want to support multiple memory configurations without SPL?
Please advise,
Eric
Dear Eric,
Correct.
I'm not sure what you want to tell me here. The thing is that you don't want to maintain a dozen of different configurations, resulting in a number of different, incompatible binary images, and you and your users will always live in fear they might install the wrong image and brick a system (OK, when you can boot from SDCard or similar recovery will be less painful, but you still suffer from the maintenance efforts).
I don't remember this. But I guess the reason was in the implementation, not in the idea?
But this doesn't scale.
In any case I'm missing time to provide longer explanations...
I understand this, and I'm trying to point out that this is an approach that is not useful in cases like yours where you have to support a large number of different configurations.
I probably should point out that with such a setup you MUST NOT use get_ram_size(), as it will write and modify the memory you are executing from, so depending on a number of things it may happily crash your system. get_ram_size() has always to be used before running any code from the RAM that is going to be tested.
Correct. In your situation this is the approach that shouldbe taken.
Please note that I did not NAK anything. I'm just trying to point out deficiencies (and in my opinion prety major deficiencies) in the submitted code, and to provide suggestions how to fix these. In my experience, it is easier to get such fixes done before the code goes into mainline - once it's in, both your own motivation and any backing you can get from management levels for the required efforts for such a rework will be in a much poorer state.
So I'm just aking suggestions. Do you by chancew feel you heard me use that sweet, innocent tone of voice before? Well, then I can stop here :-)
Thanks Wolfgang,
On 03/10/2013 03:03 PM, Wolfgang Denk wrote:
Dear Eric,
Correct.
I understand the point, but think the pain is manageable and mostly ours.
While we'd like to snap our fingers and have a "does everything right" boot loader, that will take a while ;)
Well, at least the use of i.MX plugins to do the job. The general response was something along the lines of:
**if** we want to support multiple CPU variants in a single binary, then it should be done with SPL.
While I believe this can be done, it hasn't yet, and will likely require some of the same changes to allow sets of register values to be expressed as data instead of code.
It appeared that the NAK stemmed from a desire for less complexity.
This patch set is the simplest implementation we can think of that still allows a single board file and directory to support multiple CPU options and memory configurations.
It scales better than where we were: having a single blob of hex data in board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg.
This step has broken things up into parts so that we **can** express multiple memory configurations within a single board directory, and I hope it moves the ball forward a step or two.
Our hope in getting this main-lined was that other upcoming Solo and Dual-Lite platforms could share some of the bits.
;) The addition of get_ram_size() was in response to your comment about the Wandboard submission, which does build upon the .cfg file structure of the nitrogen6x.
I guess that's what I get for adding it on the day of submission: it looked harmless though not very useful.
I guess I misunderstood then.
I'm sorry if I sound frustrated.
This is feedback I'd hoped to get to the RFC version back in January, and it will be some time before we're in a position to add SPL into the mix.
I'll wait for further feedback before determining if a V3 patch is warranted.
Regards,
Eric
Dear Eric,
When I say it doesn't scale, I'm not only thinking about yourown efforts, and your customers.
I also think about things like the increase of build and test time for _everybody_ who performs tests on U-Boot - instead of one board, we now have to build - how many? 6? - configurations. If we allow this now, others will copy this approach (and we cannot really reject it then). I really would like to avoid setting such a precedent here.
I'm well aware of this.
This may or mayu not make sense. It certainly depends on the specific requirements of the SoC / architecture in question.
I agree that supporting multiple SoCs indeed adds complexity. However, supporting different memory sizes has been supported by U-Boot (and actually already by PPCBoot) since day one, so this is not really considered rocket science. Also, SPL is not exactly new technology any more.
It does. But source base is one thing. Havnig to deal with a large number of configurations to build and test is another one, and here you put additional burdon on a large number of prople.
Understood and appreciated. But I also see this ias a strong reason to come up with a clean design, and not create bad examples which others without doubt will interpret as persuasive precedent.
You don't, and if you did I could very well understand how you feel.
I hope you can understand my position, too.
Sorry I missed it then.
I would also apprciate if others could comment - Stefano? Albert? Tom?
On 11/03/2013 12:15, Wolfgang Denk wrote:
Dear Eric,
Hi Wolfgang, hi Eric,
sorry to jump late in the discussion.
Firstly I sumarize something from your previous posting in this thread. As remark about first Wolfgangs's post, there is an issue that does not allow to use get_ram_size() to tune the RAM settings, as we are usual to do with other architectures. In fact, the processor itself reads these headers (in i.MX jargon the DCD tables) at the beginning of the image and sets itself the RAM controller, copying at the end u-boot from storage to RAM - without any intervention by U-Boot code. When get_ram_size() is called, the code already runs from RAM - this is has nothing to do with relocation.
This is why Eric pushes several configuration files, whose changes are due to the different RAM chips.
The way Troy / Eric tried to manage this was to add the "plugin" facility to the imximage. However, as you have already read in the thread, this adds not only complexity, but it is also *very* special for the i.MX, and cannot be reused at all for other processors. I do not like that i.MX becomes an island in the U-Boot world and I have discouraged the usage of i.MX plugins vs SPL.
The roadmap for me is that this complexity can be easy managed (and also having different SOCs with a single image, if desired) using SPL. This is now a well known technology and can add some important features borrowed by other SOCs (falcon mode, booting from different storages, etc.).
This at the end to explain Wolfgang why I was against adding "plugins" when the RFC patchset was set - without you have to read the whole discussion, that was pretty long ;-).
As set previously, my position is, since RFC patches were pushed in January, that some kind of complexity can be well managed with SPL instead of with very SOC specific code. However, in the meantime I said explicitely that I was not against the current patchset in the form Eric posted now. I understand this can be seen as a temporary solution, but let's increase the number of users using these boards, and taking into account that some other pending patches can help to switch to SPL.
In fact, there also other patchsets that I hope will be merged soon and will make the swicth to SPL easier - I mean Benoit's patches regarding NAND on MX5 and dropping old spl code from some boards.
Best regards, Stefano Babic
Hi Stefano,
Just to make sure I understand the plan:
Do you mean that you are willing to accept current Eric's series for adding nitrogen support into 2013.04, and after this we should work on converting it to the SPL mechanism for 2013.07?
Thanks,
Fabio Estevam
On 11/03/2013 14:18, Fabio Estevam wrote:
Hi Stefano,
IMHO, yes. The long term solution is using SPL, as well as it is already used in other SOCs. But at the moment, I tend to not block the current series, taking into account that we have not yet a i.MX6 board with SPL.
Thanks, Stefano. Sounds like a good approach.
Regards,
Fabio Estevam
Thanks Stefano,
Hi Stefano,
Then I'll forward a V3 (without get_ram_size()).
Do you want me to restrict the number of configurations to the "standard" memory configurations?
Please advise,
Eric
On 11/03/2013 15:02, Eric Nelson wrote:
Thanks Stefano,
Hi Stefano,
Well, this could avoid that we add now a lot of files with the hope that later they will be cleanued up, and then this does not happen - and further configurations will be added later after switching to SPL.
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Thanks Stefano,
Hi Stefano,
SPL.
Lets go this route AND make sure it's well documented enough that people with their own custom HW can easily adapt the existing examples to meet their setup (and yes, in the near future, work towards migration to SPL).
- -- Tom
Thanks Wolfgang,
On 03/11/2013 04:15 AM, Wolfgang Denk wrote:
Dear Eric,
Would it help if we restrict the number of boards directly in boards.cfg?
We can easily have local patches for the non-standard memory configurations in our repository, and this will at least allow build tests to include the processor variants.
<snip>
Our hope is that the things we're adding are useful, and not a burden.
We'll be happy to pursue the SPL route, but this won't be something that we can devote cycles to in the next few weeks.
Regards,
Eric
Dear Eric,
Not really. Thi sjust papers over the problem, but does not solve it.
Understood. Thanks.
participants (6)
Eric Nelson
Fabio Estevam
Stefano Babic
Troy Kisky
