[U-Boot-Users] [PATCH] Make target for all ARM supplied and supported development boards - patch 007
The attached patch provides a make target for all ARM supplied and supported development boards.
It also ensures that all boards use the preferred mechanism for initial setup.
I have modified the other boards using arm cpus sx1 ns9750dev omap1510inn omap1610inn omap2420h4 omap5912osk omap730p2 to use the same mechanism.
It replaces my rejected patch 006 (thanks for the comments & suggestions Wolfgang) which contained an unintentional change to MAKEALL.
The patch was made against the GIT head:-
commit bccae9039e59ac09a776429119389a6a4e679fd7 tree 9361bea6cc2bca3d22876433406886cfc1e359de parent 6ebc79211420cd856c9825cf3ade8bd6fd54fee5 author Wolfgang Denk wd@pollux.denx.de Thu, 06 Oct 2005 01:50:50 +0200 committer Wolfgang Denk wd@pollux.denx.de Thu, 06 Oct 2005 01:50:50 +0200
Tested with MAKEALL (unpatched ;-} ) arm.
CHANGELOG: Provide make target for all ARM supplied & supported development boards Ensure all boards use lowlevel_init(), rather than platformsetup(). Patch 007 from Peter Pearse peter.pearse@arm.com 7th Oct 2005
Regards
Peter Pearse
In message 89A528FE6DB0FA44877BB2F05B846718032C835E@ZIPPY.Emea.Arm.com you wrote:
Sorry, does not apply any more.
It replaces my rejected patch 006 (thanks for the comments & suggestions Wolfgang) which contained an unintentional change to MAKEALL.=20
I rejected only the MAKEALL changes I didn't like, but applied all the rest.
Sorry - HEA Dis:
commit b8e16a3450fb9853a8b0ff617d70f1121b32c4c0 tree 26a0c89b61db362f3a5a83525f9686459b338c99 parent 64db4b10a532263dccd2b30c0ddb863b774ec473 author Wolfgang Denk wd@pollux.denx.de Thu, 06 Oct 2005 23:44:55 +0200 committer Wolfgang Denk wd@pollux.denx.de Thu, 06 Oct 2005 23:44:55 +0200
Cleanup
Peter, you're really taxing my patience.
Can you please explain why you cannot provide the "Patch by" entry in the format I ask you for again and again?
A suggestion - since you are using GIT, you could automatically generate the changelog from the patch comments and no longer keep this file under revision control. People using GIT would just run gitk or git log to see what has changed. For people using snapshot or releases, you would would put the changelog in the tarball.
It's even easier if you only accept patches in text/plain format and use GIT (or other tools on top) to automatically import the patches from the saved e-mail (the author information being automatically preserved).
Dear Catalin,
I would still need to copy & paste the information from the message, and collect submitter name and date from the mail headers. I think it is impoortant to be able to match a change to the original posting of the submitter on the mailing list.
In this respect, the CHANGELOG entry is a condensed form of the patch comments with additional information about the sugbmitter which I need in any case - no matter if I explicitely register it in a CHANGELOG file or not.
Please note that I also continue to keep the CVS server at SF in sync with all development going on on the main branch of the git repository. This is another place where the CHANGELOG file comes in handy.
It would be easier for me, indeed - much easier, as I would have to reject 98% of all submitted patches.
Also, I am strictly against automatically importing unchecked patches. Too many patches contain horrible nonsense and would basicly corrupt the repository. And if I have to process / filter the paches anyway, then it does not make any difference if I run this command or that one.
But thanks for the well-meant suggestion.
Scripts like 'git applymbox' or 'stg import --mail' can do this automatically. With StGIT you can even modify the patch multiple times before you decide to permanently store it in your repository.
You have a pre-commit hook in GIT which you can use to automatically append part of the patch description and author to the changelog file (like for Linux, you can ask people to have a short description on the first line or two, followed by an empty line and followed by a longer description).
Nobody prevents you from looking at the patch before applying it, or for applying it on a development branch and just moving it to the stable one (or just temporary applying them with StGIT and, if they prove to be OK, 'stg commit' to store them permanently).
All that matters is how you are used to work, it's pretty hard to change the work-flow after using it for years. Anyway, in case you want to automate the patch importing, I can help you with some scripts (or StGIT advice).
Regards,
Yes, I know. And it works fine if the submitted patchs follow th required conventions. But it is no exception here to receive a base64 encoded file "patch.bz2" which turns out to be a bzip2-compressed _tarball_ containing the patch plus eventually other files like the CHANGELOG entry.
As mentioned before: either I have to reject 90...95% of all patches because they cannot be processed automatically, or I have to do this stuff manually.
Yes, I know that such options exist, but I have to admit that I did not understand the documentation:
The default pre-commit hook, when enabled, catches introduction of lines with trailing whitespaces and aborts the commit when a such line is found.
"I can call spirits from the vasty deep." "Why so can I, or so can any man; but will they come when you do call for them?" - Shakespeare, 1 King Henry IV, Act III, Scene I.
I mean: as long as we cannot have people understand the requested CHANGELOG entry format (if they include such an entry at all), what is the chance that they will do what we ask for? :-(
Indeed.
I will certainly have to look into StGIT again.
Catalin Marinas
Peter Pearse
