Re: [DNX#2006040142001151] [U-Boot-Users] Xilinx ML403/PPC U-Boot support
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006040142001151] was created:
<snip>
bbosch@iphase.com wrote:
Peter Ryser writes:
BTW: you can find a snapshot of U-Boot with board support for ML300, ML310, ML403 and ML410 at http://www.xilinx.com/ml410-p/designs/u-boot.zip The snapshot contains the patches that have been submitted to this mailing list back in September of last year. For ML403 just use
Wolfgang,
Were the Xilinx patches (2005-09-28 thru 2005-10-02) rejected or lost, or are they still in your queue?
I'm also interested whether Xilinx EMAC or TEMAC ethernet driver is supported in this...(after reviewing the Xilinx zip file, it doesn't... sigh).
However, I do DO have an Ethernet driver for Xilinx EMAC and TEMAC for U-boot and it works... Unfortunately, it uses Xilinx copyrighted codes... Somehow, I doubt this is what you wanted.
Is Xilinx copyright ok with you?
Peter,
Do you happen to have a design for the ML403 that boots directly from the linear flash? Perhaps with devices mapped as in board/xilinx/ml403/xparameters.h? It would be easier to start with a design known to work with U-Boot.
Careful. ML403 reference design (as-is) is not using the Xilinx option of using side-by-side data access (32-bit fetch out of a single 16-bit flash), so XIP (execution in place) is evidently NOT supported in ML403. However, I had a new bit file built with side-by-side data access enabled, but haven't yet execute out of flash (no need because ML403 has a big memory.) But it correctly fetches 32-bit now. Ping me in a week on my progress with XIP and flash.
S. Egbert
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files for problems? Stop! Download the new AJAX search engine that makes searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://sel.as-us.falkag.net/sel?cmd=lnk&kid=103432&bid=230486&da... _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
</snip>
Your U-Boot support team
DENX Support System
