RE: [U-Boot-Users] CONFIG_BOOTBINFUNC for AT91RM9200
Dear Steven & Wolfgang,
There is perhaps a confusion between _relocation_ and _copy_.
Beware to the fact that actually the AT91RM9200 starter code (especially start.S) does not relocate any code from Flash to RAM (as we can see it into PowerPC starter code, for example) but rather do a simple copy of u-boot code from Flash to RAM.
_TEXT_BASE is still defined with a RAM address!
This way to do is unfortunately inherited from ATMEL with their 2 stages boot process.
Regards - Luc
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users-admin@lists.sourceforge.net]On Behalf Of Wolfgang Denk Sent: mardi 23 novembre 2004 17:43 To: Steven Scholz Cc: u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] CONFIG_BOOTBINFUNC for AT91RM9200
In message 41A35A7E.1020605@imc-berlin.de you wrote:
is there a standard way in U-Boot to prevent to the startup
code from relocating
into RAM?
No. U-Boot will always relocate itself to RAM. Well, nearly always - in any halfway sane implementation.
I know that arm920t figures out the currebt address.
compares it to _TEXT_BASE
and decides wether to relocate or not.
relocate: /* relocate U-Boot to
RAM */
adr r0, _start /* r0 <- current
position of code */
ldr r1, _TEXT_BASE /* test if we run from
flash or RAM */
cmp r0, r1 /* don't reloc during
debug */
I wish that code was never written.
So there might be no need for a define like
CFG_DONT_RELOCATE. But how about
other cpus?
All CPUs always relocate the code to RAM. This is the general case. Anything else is not supported.
(I am asking cause you wrapped the relocate code in
cpu/at91rm9200/start.S with
CONFIG_BOOTBINFUNC instead of using the above technique.
Please consider the CONFIG_BOOTBINFUNC as an optimization of effort and effect (read: quick & dirty hack). Feel free to clean up as long the result is working code, too.
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Fools ignore complexity. Pragmatists suffer it. Some can avoid it. Geniuses remove it. - Perlis's Programming Proverb #58, SIGPLAN Notices, Sept. 1982
SF email is sponsored by - The IT Product Guide Read honest & candid reviews on hundreds of IT Products from real users. Discover which products truly live up to the hype. Start reading now. http://productguide.itmanagersjournal.com/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Paugam Luc
