[U-Boot] [PATCH] imx6: fix pl301_mx6qper1_bch clock gating setup
Current code sets reserved CG1 bits instead of CG6 bits for pl301_mx6qper1_bch clock. Fix it.
Signed-off-by: Anatolij Gustschin agust@denx.de Cc: Heiko Schocher hs@denx.de Cc: Stefan Roese sr@denx.de Cc: Tim Harvey tharvey@gateworks.com --- board/aristainetos/aristainetos.c | 2 +- board/barco/titanium/titanium.c | 2 +- board/gateworks/gw_ventana/gw_ventana.c | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/aristainetos/aristainetos.c b/board/aristainetos/aristainetos.c index 3bfcf5b..bb946b5 100644 --- a/board/aristainetos/aristainetos.c +++ b/board/aristainetos/aristainetos.c @@ -433,7 +433,7 @@ static void setup_gpmi_nand(void) MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK | MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK | MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK | - MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET); + MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_MASK);
/* enable apbh clock gating */ setbits_le32(&mxc_ccm->CCGR0, MXC_CCM_CCGR0_APBHDMA_MASK); diff --git a/board/barco/titanium/titanium.c b/board/barco/titanium/titanium.c index 84a7b84..bcf45a2 100644 --- a/board/barco/titanium/titanium.c +++ b/board/barco/titanium/titanium.c @@ -177,7 +177,7 @@ static void setup_gpmi_nand(void) MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK | MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK | MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK | - MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET); + MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_MASK);
/* enable apbh clock gating */ setbits_le32(&mxc_ccm->CCGR0, MXC_CCM_CCGR0_APBHDMA_MASK); diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index a222921..b51c104 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -259,7 +259,7 @@ static void setup_gpmi_nand(void) MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK | MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK | MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK | - MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET); + MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_MASK);
Hi Anatolij,
Please take a look at this patch: https://www.mail-archive.com/u-boot@lists.denx.de/msg145208.html function setup_gpmi_io_clk().
It's not in mainline yet, but Stefano already applied it to his tree, and using it will both fix the problem, and get rid of all this code duplication.
Hi Nikita,
On Tue, 16 Sep 2014 11:55:04 +0300 Nikita Kiryanov nikita@compulab.co.il wrote:
Ah, okay. I was not aware of your changes.
Thanks,
Anatolij
Anatolij Gustschin
Nikita Kiryanov
