[PATCH 0/4] rockchip: rk3399pro: Add Add Rock Pi N10 support
Rock Pi N10 is a Rockchip RK3399Pro based SBC, which has - VMARC RK3399Pro SOM (as per SMARC standard) from Vamrs. - Dalang carrier board from Radxa.
All the required dts(i) files are synced from linux-next v5.7-rc1 since the current sync available for rk3399 is the same.
Any inputs? Jagan.
Jagan Teki (4): arm64: dts: rockchip: Sync v5.7-rc1 rk3399pro.dtsi arm64: dts: rockchip: Sync v5.7-rc1 VMARC RK3399Pro SOM ARM: dts: rockchip: Sync v5.7-rc1 Radxa Dalang Carrier arm64: dts: rockchip: Add Radxa Rock Pi N10 initial support
arch/arm/dts/Makefile | 3 +- .../arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi | 7 + arch/arm/dts/rk3399pro-rock-pi-n10.dts | 18 + arch/arm/dts/rk3399pro-u-boot.dtsi | 6 + arch/arm/dts/rk3399pro-vmarc-som.dtsi | 333 ++++++++++++++++++ arch/arm/dts/rk3399pro.dtsi | 22 ++ .../dts/rockchip-radxa-dalang-carrier.dtsi | 81 +++++ board/rockchip/evb_rk3399/MAINTAINERS | 6 + configs/rock-pi-n10-rk3399pro_defconfig | 46 +++ 9 files changed, 521 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399pro-rock-pi-n10.dts create mode 100644 arch/arm/dts/rk3399pro-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399pro-vmarc-som.dtsi create mode 100644 arch/arm/dts/rk3399pro.dtsi create mode 100644 arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi create mode 100644 configs/rock-pi-n10-rk3399pro_defconfig
Sync linux-next v5.7-rc1 rk3399pro.dtsi.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399pro.dtsi | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+) create mode 100644 arch/arm/dts/rk3399pro.dtsi
diff --git a/arch/arm/dts/rk3399pro.dtsi b/arch/arm/dts/rk3399pro.dtsi new file mode 100644 index 0000000000..bb5ebf6608 --- /dev/null +++ b/arch/arm/dts/rk3399pro.dtsi @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd. + +#include "rk3399.dtsi" + +/ { + compatible = "rockchip,rk3399pro"; +}; + +/* Default to enabled since AP talk to NPU part over pcie */ +&pcie_phy { + status = "okay"; +}; + +/* Default to enabled since AP talk to NPU part over pcie */ +&pcie0 { + ep-gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; + num-lanes = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_clkreqn_cpm>; + status = "okay"; +};
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- compatible = "rockchip,rk3399pro";
- status = "okay";
- ep-gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
- pinctrl-names = "default";
- pinctrl-0 = <&pcie_clkreqn_cpm>;
- status = "okay";
VMARC RK3399Pro SOM is a standard SMARC SOM design with Rockchip RK3399Pro SoC, which is designed by Vamrs.
Specification: - Rockchip RK3399Pro - PMIC: RK809-3 - SD slot, 16GiB eMMC - 2xUSB-2.0, 1xUSB3.0 - USB-C for power supply - Ethernet, PCIe - HDMI, MIPI-DSI/CSI, eDP
Add initial support for VMARC RK3399Pro SOM, this would use with associated carrier board.
Sync this dtsi from linux-next v5.7-rc1.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399pro-vmarc-som.dtsi | 333 ++++++++++++++++++++++++++ 1 file changed, 333 insertions(+) create mode 100644 arch/arm/dts/rk3399pro-vmarc-som.dtsi
diff --git a/arch/arm/dts/rk3399pro-vmarc-som.dtsi b/arch/arm/dts/rk3399pro-vmarc-som.dtsi new file mode 100644 index 0000000000..0a516334f1 --- /dev/null +++ b/arch/arm/dts/rk3399pro-vmarc-som.dtsi @@ -0,0 +1,333 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd + * Copyright (c) 2019 Vamrs Limited + * Copyright (c) 2019 Amarula Solutions(India) + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/pwm/pwm.h> + +/ { + compatible = "vamrs,rk3399pro-vmarc-som", "rockchip,rk3399pro"; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; + + vcc12v_dcin: vcc12v-dcin-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&emmc_phy { + status = "okay"; +}; + +&gmac { + assigned-clocks = <&cru SCLK_RMII_SRC>; + assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-supply = <&vcc_lan>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x28>; + rx_delay = <0x11>; +}; + +&i2c0 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <180>; + i2c-scl-falling-time-ns = <30>; + status = "okay"; + + rk809: pmic@20 { + compatible = "rockchip,rk809"; + reg = <0x20>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PC2 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "rk808-clkout1", "rk808-clkout2"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc5-supply = <&vcc_buck5>; + vcc6-supply = <&vcc_buck5>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc5v0_sys>; + + regulators { + vdd_log: DCDC_REG1 { + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-initial-mode = <0x2>; + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-initial-mode = <0x2>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc3v3_sys: DCDC_REG4 { + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-initial-mode = <0x2>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_buck5: DCDC_REG5 { + regulator-name = "vcc_buck5"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2200000>; + regulator-max-microvolt = <2200000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <2200000>; + }; + }; + + vcca_0v9: LDO_REG1 { + regulator-name = "vcca_0v9"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8: LDO_REG2 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_0v9: LDO_REG3 { + regulator-name = "vcc_0v9"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vcca_1v8: LDO_REG4 { + regulator-name = "vcca_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1850000>; + regulator-max-microvolt = <1850000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + /* + * As per BSP, but schematic not showing any regulator + * pin for LD05. + */ + vdd1v5_dvp: LDO_REG5 { + regulator-name = "vdd1v5_dvp"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_3v0: LDO_REG7 { + regulator-name = "vccio_3v0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd: LDO_REG8 { + regulator-name = "vccio_sd"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + /* + * As per BSP, but schematic not showing any regulator + * pin for LD09. + */ + vcc_sd: LDO_REG9 { + regulator-name = "vcc_sd"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc5v0_usb2: SWITCH_REG1 { + regulator-name = "vcc5v0_usb2"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <5000000>; + }; + }; + + vccio_3v3: vcc_lan: SWITCH_REG2 { + regulator-name = "vccio_3v3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&io_domains { + status = "okay"; + bt656-supply = <&vcca_1v8>; + sdmmc-supply = <&vccio_sd>; + gpio1830-supply = <&vccio_3v0>; +}; + +&pmu_io_domains { + status = "okay"; + pmu1830-supply = <&vcc_1v8>; +}; + +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; + status = "okay"; +}; + +&tsadc { + status = "okay"; + rockchip,hw-tshut-mode = <1>; + rockchip,hw-tshut-polarity = <1>; +}; + +&pinctrl { + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = + <1 RK_PC2 0 &pcfg_pull_up>; + }; + }; +};
Specification:
- PMIC: RK809-3
- Ethernet, PCIe
Thanks, - Kever
- Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd
- Copyright (c) 2019 Vamrs Limited
- Copyright (c) 2019 Amarula Solutions(India)
- compatible = "vamrs,rk3399pro-vmarc-som", "rockchip,rk3399pro";
- clkin_gmac: external-gmac-clock {
#clock-cells = <0>;
- vcc12v_dcin: vcc12v-dcin-regulator {
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys-regulator {
regulator-boot-on;
+&cpu_l0 {
- cpu-supply = <&vdd_cpu_l>;
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&emmc_phy {
- status = "okay";
+&gmac {
- assigned-clocks = <&cru SCLK_RMII_SRC>;
- assigned-clock-parents = <&clkin_gmac>;
- clock_in_out = "input";
- phy-supply = <&vcc_lan>;
- phy-mode = "rgmii";
- pinctrl-0 = <&rgmii_pins>;
- snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 10000 50000>;
- tx_delay = <0x28>;
- rx_delay = <0x11>;
+&i2c0 {
- clock-frequency = <400000>;
- i2c-scl-rising-time-ns = <180>;
- i2c-scl-falling-time-ns = <30>;
- status = "okay";
- rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v8: LDO_REG2 {
regulator-boot-on;
vcc_0v9: LDO_REG3 {
regulator-boot-on;
regulator-boot-on;
* pin for LD05.
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
* pin for LD09.
vcc_sd: LDO_REG9 {
regulator-boot-on;
regulator-boot-on;
+&io_domains {
- status = "okay";
- bt656-supply = <&vcca_1v8>;
- sdmmc-supply = <&vccio_sd>;
- gpio1830-supply = <&vccio_3v0>;
+&pmu_io_domains {
- status = "okay";
- pmu1830-supply = <&vcc_1v8>;
+&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- mmc-hs400-enhanced-strobe;
- non-removable;
- status = "okay";
+&tsadc {
- status = "okay";
- rockchip,hw-tshut-mode = <1>;
- rockchip,hw-tshut-polarity = <1>;
+&pinctrl {
- pmic {
rockchip,pins =
Carrier board often referred as baseboard. For making complete SBC or any other industrial boards, these carrier boards will be used with associated SOMs.
Radxa has Dalang carrier board which supports on-board peripherals, ports like USB-2.0, USB-3.0, HDMI, MIPI DSI/CSI, eDP, Ethernet, WiFi, PCIe, USB-C, 40-Pin GPIO header and etc.
Right now Dalang carrier board is used with two SBC-variants: Rock Pi N10 => VMARC RK3399Por SOM + Dalang carrier board Rock Pi N8 => VMARC RK3288 SOM + Dalang carrier board(+codec)
So add this carrier board dtsi as a separate file in ARM directory, so-that the same can reuse it in both rk3288, rk3399pro variants of Rockchip SOMs.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- .../dts/rockchip-radxa-dalang-carrier.dtsi | 81 +++++++++++++++++++ 1 file changed, 81 insertions(+) create mode 100644 arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi
diff --git a/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi b/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi new file mode 100644 index 0000000000..df3712aedf --- /dev/null +++ b/arch/arm/dts/rockchip-radxa-dalang-carrier.dtsi @@ -0,0 +1,81 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd + * Copyright (c) 2019 Radxa Limited + * Copyright (c) 2019 Amarula Solutions(India) + */ + +#include <dt-bindings/pwm/pwm.h> + +/ { + chosen { + stdout-path = "serial2:1500000n8"; + }; +}; + +&gmac { + status = "okay"; +}; + +&i2c1 { + status = "okay"; + i2c-scl-rising-time-ns = <140>; + i2c-scl-falling-time-ns = <30>; +}; + +&i2c2 { + status = "okay"; + clock-frequency = <400000>; + + hym8563: hym8563@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "hym8563"; + pinctrl-names = "default"; + pinctrl-0 = <&hym8563_int>; + interrupt-parent = <&gpio4>; + interrupts = <30 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; + disable-wp; + vqmmc-supply = <&vccio_sd>; + max-frequency = <150000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&pinctrl { + hym8563 { + hym8563_int: hym8563-int { + rockchip,pins = + <4 RK_PD6 0 &pcfg_pull_up>; + }; + }; +};
Thanks, - Kever
- Copyright (c) 2019 Radxa Limited
- chosen {
+&gmac {
- status = "okay";
+&i2c1 {
- status = "okay";
- i2c-scl-rising-time-ns = <140>;
+&i2c2 {
- status = "okay";
- hym8563: hym8563@51 {
reg = <0x51>;
#clock-cells = <0>;
+&pwm0 {
- status = "okay";
+&pwm2 {
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>;
- disable-wp;
- vqmmc-supply = <&vccio_sd>;
- max-frequency = <150000000>;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>;
- status = "okay";
+&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_cts>;
- status = "okay";
+&uart2 {
- status = "okay";
+&pinctrl {
- hym8563 {
rockchip,pins =
Rock Pi N10 is a Rockchip RK3399Pro based SBC, which has - VMARC RK3399Pro SOM (as per SMARC standard) from Vamrs. - Compatible carrier board from Radxa.
VAMRC RK3399Pro SOM need to mount on top of radxa dalang carrier board for making Rock Pi N10 SBC.
So, add initial support for Rock Pi N10 by including rk3399, rk3399pro vamrc-som and raxda dalang carrier board dtsi files.
rk3399pro-rock-pi-n10.dts was synced from linux-next v5.7-rc1.
Tested - ROCK PI N10 Model B - ROCK PI N10 Model C - Boot from SD
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/Makefile | 3 +- .../arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi | 7 +++ arch/arm/dts/rk3399pro-rock-pi-n10.dts | 18 ++++++++ arch/arm/dts/rk3399pro-u-boot.dtsi | 6 +++ board/rockchip/evb_rk3399/MAINTAINERS | 6 +++ configs/rock-pi-n10-rk3399pro_defconfig | 46 +++++++++++++++++++ 6 files changed, 85 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399pro-rock-pi-n10.dts create mode 100644 arch/arm/dts/rk3399pro-u-boot.dtsi create mode 100644 configs/rock-pi-n10-rk3399pro_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9900b44274..07dfe06230 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -136,7 +136,8 @@ dtb-$(CONFIG_ROCKCHIP_RK3399) += \ rk3399-roc-pc-mezzanine.dtb \ rk3399-rock-pi-4.dtb \ rk3399-rock960.dtb \ - rk3399-rockpro64.dtb + rk3399-rockpro64.dtb \ + rk3399pro-rock-pi-n10.dtb
dtb-$(CONFIG_ROCKCHIP_RV1108) += \ rv1108-elgin-r1.dtb \ diff --git a/arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi b/arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi new file mode 100644 index 0000000000..946a0230db --- /dev/null +++ b/arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399pro-u-boot.dtsi" +#include "rk3399-sdram-lpddr3-4GB-1600.dtsi" diff --git a/arch/arm/dts/rk3399pro-rock-pi-n10.dts b/arch/arm/dts/rk3399pro-rock-pi-n10.dts new file mode 100644 index 0000000000..6ac2d4d721 --- /dev/null +++ b/arch/arm/dts/rk3399pro-rock-pi-n10.dts @@ -0,0 +1,18 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd + * Copyright (c) 2019 Radxa Limited + * Copyright (c) 2019 Amarula Solutions(India) + */ + +/dts-v1/; +#include "rk3399.dtsi" +#include "rk3399-opp.dtsi" +#include "rk3399pro-vmarc-som.dtsi" +#include <rockchip-radxa-dalang-carrier.dtsi> + +/ { + model = "Radxa ROCK Pi N10"; + compatible = "radxa,rockpi-n10", "vamrs,rk3399pro-vmarc-som", + "rockchip,rk3399pro"; +}; diff --git a/arch/arm/dts/rk3399pro-u-boot.dtsi b/arch/arm/dts/rk3399pro-u-boot.dtsi new file mode 100644 index 0000000000..7bddc3acdb --- /dev/null +++ b/arch/arm/dts/rk3399pro-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-u-boot.dtsi" diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS index 792df1087f..578638a58b 100644 --- a/board/rockchip/evb_rk3399/MAINTAINERS +++ b/board/rockchip/evb_rk3399/MAINTAINERS @@ -68,3 +68,9 @@ M: Jagan Teki jagan@amarulasolutions.com S: Maintained F: configs/rock-pi-4-rk3399_defconfig F: arch/arm/dts/rk3399-rock-pi-4-u-boot.dtsi + +ROCK-PI-N10 +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: configs/rock-pi-n10-rk3399pro_defconfig +F: arch/arm/dts/rk3399pro-rock-pi-n10-u-boot.dtsi diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig new file mode 100644 index 0000000000..c705ce01ce --- /dev/null +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -0,0 +1,46 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_TARGET_EVB_RK3399=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399pro-rock-pi-n10.dtb" +CONFIG_MISC_INIT_R=y +CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_TPL=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399pro-rock-pi-n10" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_ERRNO_STR=y
Tested
- Boot from SD
Thanks, - Kever
- Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com
- model = "Radxa ROCK Pi N10";
- compatible = "radxa,rockpi-n10", "vamrs,rk3399pro-vmarc-som",
Jagan Teki
Kever Yang
