[U-Boot] [PATCH] cmd_bdinfo: check for CONFIG_ARC instead of CONFIG_ARC700
For all flavours of ARC we execute the same code in "bdinfo" so we may safely check for CONFIG_ARC. This is especially important since we're about to add more types of ARC so existing check won't work in all cases.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com Cc: Tom Rini trini@ti.com --- common/cmd_bdinfo.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index f0b713c..e6d8a7a 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -515,7 +515,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; }
-#elif defined(CONFIG_ARC700) +#elif defined(CONFIG_ARC)
int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) {
Alexey Brodkin
