[U-Boot-Users] Loading a kernel on MX31ADS using U-boot
I am using U-boot 1.3.2 with the MX31ADS patches posted by Guennadi Liakhovetski.
I would like to load the zImage kernel from Freescale Linux BSP via TFTP and mount the rootfs via NFS.
Does anyone have an example for doing this? I am not sure what address should I use to load the kernel into RAM.
Thanks,
Fabio Estevam
__________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
You nead a uImage. Just use the same kernel sources and do make uImage instead of zImage.
Load it to 0x80800000. You can also try the patch below, which will give you a better default environment, it shall be submitted to the list soon.
Thanks Guennadi --- Guennadi Liakhovetski
[PATCH] mx31ads: Fix default environment
Fix wrong load address in RAM, undefined environment variables, make the default environment more usable.
Signed-off-by: Guennadi Liakhovetski lg@denx.de --- include/configs/mx31ads.h | 25 ++++++++++++++++++------- 1 files changed, 18 insertions(+), 7 deletions(-)
diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 78e2545..3ad3883 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -80,13 +80,24 @@ #define CONFIG_IPADDR 192.168.23.168 #define CONFIG_SERVERIP 192.168.23.2
-#define CONFIG_EXTRA_ENV_SETTINGS \ - "bootargs_base=setenv bootargs console=ttymxc0,115200\0" \ - "bootargs_nfs=setenv bootargs $(bootargs) root=/dev/nfs ip=dhcp nfsroot=$(serverip):$(nfsrootfs),v3,tcp\0" \ - "bootcmd=run bootcmd_net\0" \ - "bootcmd_net=run bootargs_base bootargs_mtd bootargs_nfs; tftpboot 0x80000000 uImage-mx31; bootm\0" \ - "prg_uboot=tftpboot 0x80000000 u-boot-mx31ads.bin; protect off 0xa0000000 0xa001ffff; erase 0xa0000000 0xa001ffff; cp.b 0x80000000 0xa0000000 $(filesize)\0" - +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "load_addr=0x80800000\0" \ + "uboot_addr=0xa0000000\0" \ + "uboot=mx31ads/u-boot.bin\0" \ + "kernel=mx31ads/uImage\0" \ + "nfsroot=/opt/eldk/arm\0" \ + "bootargs_base=setenv bootargs console=ttymxc0,115200\0" \ + "bootargs_nfs=setenv bootargs ${bootargs} root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "bootcmd=run bootcmd_net\0" \ + "bootcmd_net=run bootargs_base bootargs_nfs; " \ + "tftpboot ${load_addr} ${kernel}; bootm\0" \ + "prg_uboot=tftpboot ${load_addr} ${uboot}; " \ + "protect off ${uboot_addr} 0xa003ffff; " \ + "erase ${uboot_addr} 0xa003ffff; " \ + "cp.b ${load_addr} ${uboot_addr} ${filesize}; " \ + "setenv filesize; saveenv\0"
#define CONFIG_DRIVER_CS8900 1 #define CS8900_BASE 0xb4020300
Hi Guennadi,
I tried to load the kernel at 0x80800000, but this is what I get: Hit any key to stop autoboot: 0 => run bootargs_base bootargs_nfs => tftp 80800000 uImage TFTP from server 10.29.244.101; our IP address is 10.29.244.102 Filename 'uImage'. Load address: 0x80800000 Loading: ################################################################# ########################### done Bytes transferred = 1339152 (146f10 hex) => bootm ## Booting image at 80800000 ... Image Name: Linux-2.6.22 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1339088 Bytes = 1.3 MB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK OK
Starting kernel ...
Uncompressing Linux............................................................. ................................... done, booting the kernel. (then it freezes)
I generated uImage manually by doing: ./mkimage -A arm -O linux -T kernel -C none -a 0x80008000 -e 0x80008000 -n 'Linux-2.6.22' -d zImage uImage
Used 0x80008000 to match the value of ZRELADDR in /arch/arm/mach-mx3/Makefile.boot from Freescale Linux BSP.
Any suggestions?
Thanks,
Fabio Estevam
Freescale
not
into
RAM.
Thanks Guennadi
- "netdev=eth0\0" \
- "load_addr=0x80800000\0" \
- "uboot_addr=0xa0000000\0" \
- "uboot=mx31ads/u-boot.bin\0" \
- "kernel=mx31ads/uImage\0" \
- "nfsroot=/opt/eldk/arm\0" \
- "bootargs_nfs=setenv bootargs ${bootargs}
root=/dev/nfs " \
- "bootcmd_net=run bootargs_base bootargs_nfs; " \
- "prg_uboot=tftpboot ${load_addr} ${uboot}; " \
1.5.4
Starting kernel ...
I'll just assume your uImage is correct - although I don't understand why you don't just do make uImage. Apart from that, verify that your console= command line parameter is correct, your machine ID matches, and that you don't have a jtag debugger like bdi2000 connected when you're trying to boot.
Hi Guennadi,
Now I generated uImage correctly and it boots fine.
Have you ever tried to boot U-boot from NAND (K9K1G08U0B) on the i.MX31ADS?
Thanks,
Fabio Estevam
is
(uncompressed)
Starting kernel ...
Uncompressing
the
zImage
uImage
Linux
BSP.
Thanks Guennadi
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Don't miss this year's exciting event. There's still time to save $100. Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javao...
U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/u-boot-users
Hi Jens,
Yes, I used LTIB for building the kernel:
export SYSCFG_KTARG=uImage ./ltib -p kernel -m prep ./ltib -p kernel -m scbuild ./ltib -p kernel -m scdeploy
The uImage is generated at: .../rpm/BUILD/linux/arch/arm/boot/uImage
Regards,
Fabio Estevam
--- Jens Gehrlein sew_s@tqs.de wrote:
Hi Fabio,
Fabio Estevam schrieb:
Hi Guennadi,
fine.
How did you build this Kernel? Did you use the LTIB?
Regards Jens
____________________________________________________________________________________ Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Hi Jens,
Regards,
Fabio Estevam
Thank you very much. I will try it as soon as I come to the Linux part.
Regards Jens
Hi Guennadi,
I have the same problem on our board: I don't see the console outputs if the BDI2000 cable is connected to the target, although the BDI is in mode "reset run". Do have an idea why?
Best Regards, Jens
No, I don't know "why", but that's exactly why I've mentioned it above - I had the same problem here and I spent about half a day trying to figure out why it didn't boot.
Hi Jens,
Have you tried to pass the "jtag=on" option into the kernel command line?
Regards,
Fabio Estevam
--- On Wed, 5/14/08, Jens Gehrlein sew_s@tqs.de wrote:
From: Jens Gehrlein sew_s@tqs.de Subject: Re: [U-Boot-Users] Loading a kernel on MX31ADS using U-boot To: "Guennadi Liakhovetski" g.liakhovetski@gmx.de Cc: u-boot-users@lists.sourceforge.net Date: Wednesday, May 14, 2008, 4:08 AM Hi Guennadi,
boot.
Best Regards, Jens
This SF.net email is sponsored by: Microsoft Defy all challenges. Microsoft(R) Visual Studio 2008. http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Hi Fabio,
Hi Jens,
Yippee! This works. Thank you very much for this hint! Where is this parameter documented? I didn't found anything in linux/Documentation or with google.
boot.
Best Regards, Jens
Yes, this is a Freescale specific option as part of the BSP for mainly debugging purpose.
Regards,
Fabio Estevam
Fabio Estevam
Jens Gehrlein
