[U-Boot] Please pull u-boot-x86
Hi Tom,
This PR includes the following x86 changes for v2019.10: - Tangier ACPI table fixes - Support getting high memory size on QEMU x86 - Show UEFI images involved in crash for x86 - EFI loader conventional memory map fix
The following changes since commit c705fc3b40b88bfbf465448643c91da71426df2f:
arm: ti: Add missing "=" from previous fix (2019-09-09 10:55:45 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-x86
for you to fetch changes up to dd4faa964f0741c314b4f1c09f27c07aedc5cdf0:
x86: tangier: Use spaces over TABs in ASL code (2019-09-10 16:19:03 +0800)
---------------------------------------------------------------- Andy Shevchenko (6): tools: Add ifwitool to .gitignore x86: acpi: Slightly reduce binary size of ACPI tables for Tangier x86: acpi: Annotate struct acpi_table_header with __packed x86: tangier: Reserve PCI ECAM in motherboard resources x86: tangier: Fix off-by-one error when preparing CSRT x86: tangier: Use spaces over TABs in ASL code
Bin Meng (4): x86: Drop weak version board_get_usable_ram_top() x86: qemu: Extract getting memory size to a separate routine x86: qemu: Support getting high memory size x86: qemu: Report high memory in the E820 table
Heinrich Schuchardt (1): x86: show UEFI images involved in crash
Park, Aiden (2): doc: slimbootloader: Update Linux booting steps on QEMU x86: efi_loader: Use efi_add_conventional_memory_map()
arch/x86/cpu/i386/interrupt.c | 14 ++++++++++++++ arch/x86/cpu/qemu/dram.c | 36 ++++++++++++++++++++++++++++++++---- arch/x86/cpu/qemu/e820.c | 59 ++++++++++++++++++++++++++++++++++++++++------------------- arch/x86/cpu/tangier/acpi.c | 5 +++-- arch/x86/include/asm/acpi_table.h | 2 +- arch/x86/include/asm/arch-qemu/qemu.h | 18 ++++++++++++++++++ arch/x86/include/asm/arch-tangier/acpi/platform.asl | 3 ++- arch/x86/include/asm/arch-tangier/acpi/southcluster.asl | 47 ++++++++++++++++++++++++++++++++--------------- arch/x86/include/asm/arch-tangier/iomap.h | 10 ++++++++++ arch/x86/lib/e820.c | 17 ++++++++++++++--- arch/x86/lib/init_helpers.c | 6 ------ doc/board/intel/slimbootloader.rst | 22 ++++++++++++++++++++++ tools/.gitignore | 1 + 13 files changed, 189 insertions(+), 51 deletions(-) create mode 100644 arch/x86/include/asm/arch-tangier/iomap.h
Regards, Bin
On Tue, Sep 10, 2019 at 08:35:30PM +0800, Bin Meng wrote:
Hi Tom,
Bin Meng
