[U-Boot] [PATCH v3] imx: spl: Partially revert "spl: eMMC/SD: Provide one __weak spl_boot_mode() function"
Commit d695d6627803 ("spl: eMMC/SD: Provide one __weak spl_boot_mode() function") breaks the boot on several i.MX6 boards, such as cuboxi and wandboard:
U-Boot SPL 2018.03-rc1-00212-g48914fc119 (Feb 10 2018 - 11:04:33 +1300) Trying to boot from MMC1 Failed to mount ext2 filesystem... spl_load_image_ext: ext4fs mount err - 0
Partially revert it so that we can boot U-Boot again on these i.MX6 platforms.
Reported-by: Jonathan Gray jsg@jsg.id.au Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- Changes since v2: - Do a partiall revert instead of full revert (Lukasz)
arch/arm/mach-imx/spl.c | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index a9079fc..b2521b2 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -132,6 +132,29 @@ int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) } #endif
+#if defined(CONFIG_SPL_MMC_SUPPORT) +/* called from spl_mmc to see type of boot mode for storage (RAW or FAT) */ +u32 spl_boot_mode(const u32 boot_device) +{ + switch (spl_boot_device()) { + /* for MMC return either RAW or FAT mode */ + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: +#if defined(CONFIG_SPL_FAT_SUPPORT) + return MMCSD_MODE_FS; +#elif defined(CONFIG_SUPPORT_EMMC_BOOT) + return MMCSD_MODE_EMMCBOOT; +#else + return MMCSD_MODE_RAW; +#endif + break; + default: + puts("spl: ERROR: unsupported device\n"); + hang(); + } +} +#endif + #if defined(CONFIG_SECURE_BOOT)
2018-02-15 12:41 GMT-02:00 Fabio Estevam fabio.estevam@nxp.com:
Tested-by: Breno Lima breno.lima@nxp.com
Was this intentionally not in your PR, Stefano? Thanks!
No, it was not intentionally :-(. I pick it up.
Regards, Stefano
Breno Matheus Lima
Fabio Estevam
Stefano Babic
