[U-Boot] [PATCH] add ASTRO MCF5373L board
This patch adds support for ASTRO board(s) based on MCF5373L.
Signed-off-by: Wolfgang Wegner w.wegner@astro-kom.de --- There is another board (series) in the queue to be submitted, thus I added a subdirectory for all our boards.
Makefile | 12 + board/astro/mcf5373l/Makefile | 44 +++ board/astro/mcf5373l/astro.h | 39 +++ board/astro/mcf5373l/config.mk | 28 ++ board/astro/mcf5373l/fpga.c | 424 +++++++++++++++++++++++ board/astro/mcf5373l/mcf5373l.c | 204 +++++++++++ board/astro/mcf5373l/u-boot.lds | 142 ++++++++ board/astro/mcf5373l/update.c | 699 ++++++++++++++++++++++++++++++++++++++ include/configs/astro_mcf5373l.h | 516 ++++++++++++++++++++++++++++ 9 files changed, 2108 insertions(+), 0 deletions(-) create mode 100644 board/astro/mcf5373l/Makefile create mode 100644 board/astro/mcf5373l/astro.h create mode 100644 board/astro/mcf5373l/config.mk create mode 100644 board/astro/mcf5373l/fpga.c create mode 100644 board/astro/mcf5373l/mcf5373l.c create mode 100644 board/astro/mcf5373l/u-boot.lds create mode 100644 board/astro/mcf5373l/update.c create mode 100644 include/configs/astro_mcf5373l.h
diff --git a/Makefile b/Makefile index 75b2c1e..924e210 100644 --- a/Makefile +++ b/Makefile @@ -2263,6 +2263,18 @@ M5485HFE_config : unconfig TASREG_config : unconfig @$(MKCONFIG) $(@:_config=) m68k mcf52x2 tasreg esd
+astro_mcf5373l_config \ +astro_mcf5373l_ram_config : unconfig + @if [ "$@" = "astro_mcf5373l_ram_config" ] ; then \ + echo "#define CONFIG_MONITOR_IS_IN_RAM" >> $(obj)include/config.h ; \ + echo "TEXT_BASE = 0x40020000" > $(obj)board/astro/mcf5373l/config.tmp ; \ + $(XECHO) "... for RAM boot ..." ; \ + else \ + echo "TEXT_BASE = 0x00000000" > $(obj)board/astro/mcf5373l/config.tmp ; \ + $(XECHO) "... for FLASH boot ..." ; \ + fi + @$(MKCONFIG) -a astro_mcf5373l m68k mcf532x mcf5373l astro + ######################################################################### ## MPC83xx Systems ######################################################################### diff --git a/board/astro/mcf5373l/Makefile b/board/astro/mcf5373l/Makefile new file mode 100644 index 0000000..e0b1bc6 --- /dev/null +++ b/board/astro/mcf5373l/Makefile @@ -0,0 +1,44 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS = $(BOARD).o fpga.o update.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/astro/mcf5373l/astro.h b/board/astro/mcf5373l/astro.h new file mode 100644 index 0000000..9478787 --- /dev/null +++ b/board/astro/mcf5373l/astro.h @@ -0,0 +1,39 @@ +#ifndef __ASTRO_H__ +#define __ASTRO_H__ + +int rs_serial_init(int port, int baud); +void astro_put_char(char ch); +int astro_is_char(void); +int astro_get_char(void); + +/* data structures used for communication (update.c) */ +typedef struct _s_karten_id { + char Kartentyp; + char Hardwareversion; + char Softwareversion; + char SoftwareSubversion; /* " ","a",.."z" */ + char FPGA_Version_Alt; + char FPGA_Version_Xil; +} s_karten_id; + +typedef struct { + unsigned char mode; + unsigned char deviation; + unsigned short freq; +} __attribute__ ((packed)) s_output_params; + +typedef struct { + unsigned short SatFreq; + unsigned char SatDatAllg; + unsigned short Symbolrate; + unsigned char Viterbirate; + unsigned char Symbolrate_L; + s_output_params output_params; + unsigned char Reserve; + unsigned char Kartenfehler; + unsigned short dummy_ts_id; + unsigned char dummy_pat_ver; + unsigned char dummy_sdt_ver; +} __attribute__ ((packed)) s_datensatz; + +#endif /* __ASTRO_H__ */ diff --git a/board/astro/mcf5373l/config.mk b/board/astro/mcf5373l/config.mk new file mode 100644 index 0000000..59752c1 --- /dev/null +++ b/board/astro/mcf5373l/config.mk @@ -0,0 +1,28 @@ +# +# (C) Copyright 2000-2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# Coldfire contribution by Bernhard Kuhn bkuhn@metrowerks.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +echo "BOARD DIR = $(BOARDDIR)" +sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp + +PLATFORM_CPPFLAGS += -DTEXT_BASE=$(TEXT_BASE) diff --git a/board/astro/mcf5373l/fpga.c b/board/astro/mcf5373l/fpga.c new file mode 100644 index 0000000..eb1bf49 --- /dev/null +++ b/board/astro/mcf5373l/fpga.c @@ -0,0 +1,424 @@ +/* + * (C) Copyright 2006 + * Wolfgang Wegner, ASTRO Strobel Kommunikationssysteme GmbH, + * w.wegner@astro-kom.de + * + * based on the files by + * Heiko Schocher, DENX Software Engineering, hs@denx.de + * and + * Rich Ireland, Enterasys Networks, rireland@enterasys.com. + * Keith Outwater, keith_outwater@mvis.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +/* + * Altera/Xilinx FPGA configuration support for the ASTRO "URMEL" board + */ + +#include <common.h> +#include <watchdog.h> +#include <altera.h> +#include <ACEX1K.h> +#include <spartan3.h> +#include <command.h> +#include <asm/immap_5329.h> +#include "fpga.h" + +DECLARE_GLOBAL_DATA_PTR; + +int altera_pre_fn (int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + +/* first, set the required pins to GPIO function */ + /* PAR_T0IN -> GPIO */ + gpiop->par_timer &= 0xfc; + /* all QSPI pins -> GPIO */ + gpiop->par_qspi = 0x0000; + /* U0RTS, U0CTS -> GPIO */ + gpiop->par_uart &= 0xfff3; + /* all PWM pins -> GPIO */ + gpiop->par_pwm = 0x00; +/* next, set data direction registers */ + gpiop->pddr_timer = 0x01; + gpiop->pddr_qspi = 0x25; + gpiop->pddr_uart = 0x0c; + gpiop->pddr_pwm = 0x04; + +/* ensure other SPI peripherals are deselected */ + gpiop->ppd_uart = 0x08; + gpiop->ppd_qspi = 0x38; + +/* CONFIG = 0 STATUS = 0 -> FPGA in reset state */ + gpiop->pclrr_uart = 0xFB; +/* enable Altera configuration by clearing QSPI_CS2 and DT0IN */ + gpiop->pclrr_timer = 0xFE; + gpiop->pclrr_qspi = 0xDF; + return FPGA_SUCCESS; +} + +/* Set the state of CONFIG Pin */ +int altera_config_fn (int assert_config, int flush, int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + if (assert_config) + gpiop->ppd_uart = 0x04; + else + gpiop->pclrr_uart = 0xFB; + return FPGA_SUCCESS; +} + +/* Returns the state of STATUS Pin */ +int altera_status_fn (int cookie) +{ + unsigned char reg; + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + reg = (gpiop->ppd_pwm >> 3) & 0x01; + if (reg) { + return FPGA_FAIL; + } + return FPGA_SUCCESS; +} + +/* Returns the state of CONF_DONE Pin */ +int altera_done_fn (int cookie) +{ + unsigned char reg; + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + reg = (gpiop->ppd_pwm >> 5) & 0x01; + if (reg) + return FPGA_FAIL; + return FPGA_SUCCESS; +} + +/* writes the complete buffer to the FPGA + writing the complete buffer in one function is much faster, + then calling it for every bit */ +int altera_write_fn (void *buf, size_t len, int flush, int cookie) +{ + size_t bytecount = 0; + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + unsigned char *data = (unsigned char *)buf; + unsigned char val = 0; + int i; + int len_40 = len / 40; + + while (bytecount < len) { + val = data[bytecount++]; + i = 8; + do { + gpiop->pclrr_qspi = 0xFB; + if (val & 0x01) + gpiop->ppd_qspi = 0x01; + else + gpiop->pclrr_qspi = 0xFE; + gpiop->ppd_qspi = 0x04; + val >>= 1; + i--; + } while (i > 0); + + if (bytecount % len_40 == 0) { +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET (); +#endif +#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK + putc ('.'); /* let them know we are alive */ +#endif +#ifdef CONFIG_SYS_FPGA_CHECK_CTRLC + if (ctrlc ()) + return FPGA_FAIL; +#endif + } + } + return FPGA_SUCCESS; +} + +/* called, when programming is aborted */ +int altera_abort_fn (int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + gpiop->ppd_qspi = 0x20; + gpiop->ppd_uart = 0x08; + return FPGA_SUCCESS; +} + +/* called, when programming was succesful */ +int altera_post_fn (int cookie) +{ + return altera_abort_fn (cookie); +} + +/* Note that these are pointers to code that is in Flash. They will be + * relocated at runtime. + * FIXME: relocation not yet working for coldfire, see below! + */ +Altera_CYC2_Passive_Serial_fns altera_fns = { + altera_pre_fn, + altera_config_fn, + altera_status_fn, + altera_done_fn, + altera_write_fn, + altera_abort_fn, + altera_post_fn +}; + +Altera_desc altera_fpga[CONFIG_FPGA_COUNT] = { + {Altera_CYC2, + passive_serial, + 85903, + (void *)&altera_fns, + NULL, + 0} +}; + +/* + * Initialize the fpga. Return 1 on success, 0 on failure. + */ +int astro5373l_altera_load (void) +{ + int i; + + for (i = 0; i < CONFIG_FPGA_COUNT; i++) { +/* I did not yet manage to get relocation work properly, + * so set stuff here instead of static initialisation: */ + altera_fns.pre = altera_pre_fn; + altera_fns.config = altera_config_fn; + altera_fns.status = altera_status_fn; + altera_fns.done = altera_done_fn; + altera_fns.write = altera_write_fn; + altera_fns.abort = altera_abort_fn; + altera_fns.post = altera_post_fn; + altera_fpga[i].iface_fns = (void *)&altera_fns; + fpga_add (fpga_altera, &altera_fpga[i]); + } + return 1; +} + +/* + * Set the FPGA's PROG_B line to the specified level + */ +int xilinx_pgm_fn (int assert, int flush, int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + if (assert) + gpiop->pclrr_uart = 0xFB; + else + gpiop->ppd_uart = 0x04; + return assert; +} + +/* + * Test the state of the active-low FPGA INIT line. Return 1 on INIT + * asserted (low). + */ +int xilinx_init_fn (int cookie) +{ + unsigned char state; + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + state = (gpiop->ppd_pwm & 0x08) >> 3; + if (state) + return 0; + else + return 1; +} + +/* + * Test the state of the active-high FPGA DONE pin + */ +int xilinx_done_fn (int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + return (gpiop->ppd_pwm & 0x20) >> 5; +} + +/* + * Abort an FPGA operation + */ +int xilinx_abort_fn (int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; +/* ensure all SPI peripherals and FPGAs are deselected */ + gpiop->ppd_uart = 0x08; + gpiop->ppd_timer = 0x01; + gpiop->ppd_qspi = 0x38; + return FPGA_FAIL; +} + +/* + * FPGA pre-configuration function. Just make sure that + * FPGA reset is asserted to keep the FPGA from starting up after + * configuration. + */ +int xilinx_pre_config_fn (int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; +/* first, set the required pins to GPIO function */ + /* PAR_T0IN -> GPIO */ + gpiop->par_timer &= 0xfc; + /* all QSPI pins -> GPIO */ + gpiop->par_qspi = 0x0000; + /* U0RTS, U0CTS -> GPIO */ + gpiop->par_uart &= 0xfff3; + /* all PWM pins -> GPIO */ + gpiop->par_pwm = 0x00; +/* next, set data direction registers */ + gpiop->pddr_timer = 0x01; + gpiop->pddr_qspi = 0x25; + gpiop->pddr_uart = 0x0c; + gpiop->pddr_pwm = 0x04; + +/* ensure other SPI peripherals are deselected */ + gpiop->ppd_uart = 0x08; + gpiop->ppd_qspi = 0x38; + gpiop->ppd_timer = 0x01; + +/* CONFIG = 0 STATUS = 0 -> FPGA in reset state */ + gpiop->pclrr_uart = 0xFB; +/* enable Xilinx configuration by clearing QSPI_CS2 and U0CTS */ + gpiop->pclrr_uart = 0xF7; + gpiop->pclrr_qspi = 0xDF; + return 0; +} + +/* + * FPGA post configuration function. Should perform a test if FPGA is running... + */ +int xilinx_post_config_fn (int cookie) +{ + int rc = 0; + + /* + * no test yet + */ + return rc; +} + +int xilinx_clk_fn (int assert_clk, int flush, int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + if (assert_clk) + gpiop->ppd_qspi = 0x04; + else + gpiop->pclrr_qspi = 0xFB; + return assert_clk; +} + +int xilinx_wr_fn (int assert_write, int flush, int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + if (assert_write) + gpiop->ppd_qspi = 0x01; + else + gpiop->pclrr_qspi = 0xFE; + return assert_write; +} + +int xilinx_fastwr_fn (void *buf, size_t len, int flush, int cookie) +{ + size_t bytecount = 0; + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + unsigned char *data = (unsigned char *)buf; + unsigned char val = 0; + int i; + int len_40 = len / 40; + + for (bytecount = 0; bytecount < len; bytecount++) { + val = *(data++); + for (i = 8; i > 0; i--) { + gpiop->pclrr_qspi = 0xFB; + if (val & 0x80) + gpiop->ppd_qspi = 0x01; + else + gpiop->pclrr_qspi = 0xFE; + gpiop->ppd_qspi = 0x04; + val <<= 1; + } + if (bytecount % len_40 == 0) { +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET (); +#endif +#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK + putc ('.'); /* let them know we are alive */ +#endif +#ifdef CONFIG_SYS_FPGA_CHECK_CTRLC + if (ctrlc ()) + return FPGA_FAIL; +#endif + } + } + return FPGA_SUCCESS; +} + +/* Note that these are pointers to code that is in Flash. They will be + * relocated at runtime. + * FIXME: relocation not yet working for coldfire, see below! + */ +Xilinx_Spartan3_Slave_Serial_fns xilinx_fns = { + xilinx_pre_config_fn, + xilinx_pgm_fn, + xilinx_clk_fn, + xilinx_init_fn, + xilinx_done_fn, + xilinx_wr_fn, + 0, + xilinx_fastwr_fn +}; + +Xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { + {Xilinx_Spartan3, + slave_serial, + XILINX_XC3S4000_SIZE, + (void *)&xilinx_fns, + 0} +}; + +/* + * Initialize the fpga. Return 1 on success, 0 on failure. + */ +int astro5373l_xilinx_load (void) +{ + int i; + + fpga_init (); + + for (i = 0; i < CONFIG_FPGA_COUNT; i++) { +/* I did not yet manage to get relocation work properly, + * so set stuff here instead of static initialisation: */ + xilinx_fns.pre = xilinx_pre_config_fn; + xilinx_fns.pgm = xilinx_pgm_fn; + xilinx_fns.clk = xilinx_clk_fn; + xilinx_fns.init = xilinx_init_fn; + xilinx_fns.done = xilinx_done_fn; + xilinx_fns.wr = xilinx_wr_fn; + xilinx_fns.bwr = xilinx_fastwr_fn; + xilinx_fpga[i].iface_fns = (void *)&xilinx_fns; + fpga_add (fpga_xilinx, &xilinx_fpga[i]); + } + return 1; +} diff --git a/board/astro/mcf5373l/mcf5373l.c b/board/astro/mcf5373l/mcf5373l.c new file mode 100644 index 0000000..0c87128 --- /dev/null +++ b/board/astro/mcf5373l/mcf5373l.c @@ -0,0 +1,204 @@ +/* + * (C) Copyright 2000-2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * modified by Wolfgang Wegner w.wegner@astro-kom.de for ASTRO 5373l + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <watchdog.h> +#include <command.h> +#include <asm/m5329.h> +#include <asm/immap_5329.h> + +/* needed for astro bus: */ +#include <asm/uart.h> +#include "astro.h" + +DECLARE_GLOBAL_DATA_PTR; +extern void uart_port_conf (void); + +extern int astro5373l_altera_load (void); +extern int astro5373l_xilinx_load (void); + +int checkboard (void) +{ + puts ("Board: "); + puts ("ASTRO MCF5373L (Urmel) Board\n"); + return 0; +} + +phys_size_t initdram (int board_type) +{ +#if !defined(CONFIG_MONITOR_IS_IN_RAM) + volatile sdram_t *sdp = (volatile sdram_t *)(MMAP_SDRAM); + +/* GPIO configuration for bus should be set correctly from reset, so we do not care! + * First, set up address space: at this point, we should be running from internal SRAM; + * so use CONFIG_SYS_SDRAM_BASE as the base address for SDRAM, and do not care where it is + */ + sdp->cs0 = (CONFIG_SYS_SDRAM_BASE & 0xFFF00000) | 0x00000018; +/* I am not sure from the data sheet, but it seems burst length has to be 8 + * for the 16 bit data bus we use; so these values are for BL = 8 + */ + sdp->cfg1 = 0x33211530; + sdp->cfg2 = 0x56570000; /* for BL = 4: 0x34330000 */ +/* send PrechargeALL, REF and IREF remain cleared! */ + sdp->ctrl = 0xE1462C02; + udelay (1); +/* refresh SDRAM twice */ + sdp->ctrl = 0xE1462C04; + udelay (1); + sdp->ctrl = 0xE1462C04; +/* init MR */ + sdp->mode = 0x008D0000; +/* initialize EMR */ + sdp->mode = 0x80010000; +/* wait until DLL is locked */ + udelay (1); +/* enable automatic refresh, lock mode register, clear iref and ipall */ + sdp->ctrl = 0x71462C00; +/* Dummy write to start SDRAM */ + *((volatile unsigned long *)CONFIG_SYS_SDRAM_BASE) = 0; +#endif + + return CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; +} + +int testdram (void) +{ + printf ("DRAM test not implemented!\n"); + + return (0); +} + +#define UART_BASE MMAP_UART0 +int rs_serial_init (int port, int baud) +{ + volatile uart_t *uart; + u32 counter; + + switch (port) { + case 0: + uart = (volatile uart_t *)(MMAP_UART0); + break; + case 1: + uart = (volatile uart_t *)(MMAP_UART1); + break; + case 2: + uart = (volatile uart_t *)(MMAP_UART2); + break; + default: + uart = (volatile uart_t *)(MMAP_UART0); + } + + uart_port_conf (); + + /* write to SICR: SIM2 = uart mode,dcd does not affect rx */ + uart->ucr = UART_UCR_RESET_RX; + uart->ucr = UART_UCR_RESET_TX; + uart->ucr = UART_UCR_RESET_ERROR; + uart->ucr = UART_UCR_RESET_MR; + __asm__ ("nop"); + + uart->uimr = 0; + + /* write to CSR: RX/TX baud rate from timers */ + uart->ucsr = (UART_UCSR_RCS_SYS_CLK | UART_UCSR_TCS_SYS_CLK); + + uart->umr = (UART_UMR_BC_8 | UART_UMR_PM_NONE); + uart->umr = UART_UMR_SB_STOP_BITS_1; + + /* Setting up BaudRate */ + counter = (u32) (gd->bus_clk / (baud)); + counter >>= 5; + + /* write to CTUR: divide counter upper byte */ + uart->ubg1 = (u8) ((counter & 0xff00) >> 8); + /* write to CTLR: divide counter lower byte */ + uart->ubg2 = (u8) (counter & 0x00ff); + + uart->ucr = (UART_UCR_RX_ENABLED | UART_UCR_TX_ENABLED); + + return (0); +} + +void astro_put_char (char ch) +{ + volatile uart_t *uart; + int i; + + uart = (volatile uart_t *)(MMAP_UART0); + /* Wait for last character to go. */ + for (i = 0; (i < 0x10000); i++) + if (uart->usr & UART_USR_TXRDY) + break; + uart->utb = ch; + + return; +} + +int astro_is_char (void) +{ + volatile uart_t *uart; + + uart = (volatile uart_t *)(MMAP_UART0); + return (uart->usr & UART_USR_RXRDY); +} + +int astro_get_char (void) +{ + volatile uart_t *uart; + + uart = (volatile uart_t *)(MMAP_UART0); + while (!(uart->usr & UART_USR_RXRDY)) ; + return uart->urb; +} + +int misc_init_r (void) +{ + int retval = 0; + + puts ("Configure Xilinx FPGA..."); + retval = astro5373l_xilinx_load (); + if (!retval) { + puts ("failed!\n"); + return retval; + } + puts ("done\n"); + + puts ("Configure Altera FPGA..."); + retval = astro5373l_altera_load (); + if (!retval) { + puts ("failed!\n"); + return retval; + } + puts ("done\n"); + + return retval; +} + +#ifdef CONFIG_SYS_FLASH_CFI +void sync (void) +{ + /* This sync function is PowerPC instruction, + coldfire does not have this instruction. Dummy function */ +} +#endif diff --git a/board/astro/mcf5373l/u-boot.lds b/board/astro/mcf5373l/u-boot.lds new file mode 100644 index 0000000..a9a4e0a --- /dev/null +++ b/board/astro/mcf5373l/u-boot.lds @@ -0,0 +1,142 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(m68k) +/* Do we need any of these for elf? + __DYNAMIC = 0; */ +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + cpu/mcf532x/start.o (.text) + lib_m68k/traps.o (.text) + lib_m68k/interrupts.o (.text) + common/dlmalloc.o (.text) + lib_generic/zlib.o (.text) + + . = DEFINED(env_offset) ? env_offset : .; + common/env_embedded.o (.text) + + *(.text) +/* *(.fixup)*/ + *(.got1) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + + .reloc : + { + __got_start = .; + *(.got) + __got_end = .; + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss : + { + _sbss = .; + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + . = ALIGN(4); + _ebss = .; + } + _end = . ; + PROVIDE (end = .); +} diff --git a/board/astro/mcf5373l/update.c b/board/astro/mcf5373l/update.c new file mode 100644 index 0000000..ac57816 --- /dev/null +++ b/board/astro/mcf5373l/update.c @@ -0,0 +1,699 @@ +/* + * (C) Copyright 2006-2009 + * Adnan El-Bardawil a.el-bardawil@astro-kom.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define DEBUG_INFO 1 +#define DEBUG_ERROR 1 + +/* dummy software version to signal card is in boot loader */ +#define SOFTWARE_VERSION 0x00 +#define SOFTWARE_SUBVERSION ' ' + +#define CMD_INIT 0 +#define CMD_NEW 1 +#define CMD_TX 2 +#define CMD_RX 3 +#define CMD_OK 4 +#define CMD_FAIL 5 +#define CMD_CH_RX 6 +#define CMD_TX_END 7 +#define CMD_RX_END 8 +#define CMD_TX_RDY 9 +#define CMD_RX_RDY 10 +#define CMD_RX_ERROR 11 + +#define INT_CMD_IDLE 0 +#define INT_CMD_WR_CONF 1 +#define INT_CMD_INIT_LVL 2 +#define INT_CMD_INIT_PID 4 +#define INT_CMD_INIT_UKW 8 +#define INT_CMD_SEL_SERV 16 +#define INT_CMD_FLASH_MODE 32 +#define INT_CMD_WRITE_FLASH 64 +#define INT_CMD_RESTART 128 +#define INT_CMD_PROG_START 256 +#define INT_CMD_PROG_READY 512 +#define INT_CMD_INIT_TIME 1024 + +#define FL_STAT_IDLE 0 +#define FL_STAT_ERASE 1 +#define FL_STAT_PROG 2 +#define FL_STAT_ERROR 4 + +#include <common.h> +#include <watchdog.h> +#include <command.h> +#include <asm/m5329.h> +#include <asm/immap_5329.h> +#include <flash.h> +#include "astro.h" + +#include <asm/uart.h> + +DECLARE_GLOBAL_DATA_PTR; + +/*----------------------------------------------------------------------- + * UART update subcommand codes + */ + +#define F_Daten_Speichern 0x00 /* save parameters on card */ +#define F_Daten_Lesen 0x01 /* read parameters */ +#define F_Karteninfo_Lesen 0x10 /* read 5 Byte card information */ +#define F_Kartenfehler_Lesen 0x11 /* read 4 Byte card error */ +#define F_Transparente_Daten 0x20 /* length byte + data */ + +#define SC_Prepare_for_Flash_Data 0xc0 +#define SC_Flash_Data 0xc1 +#define SC_Clear_CRC 0xc2 +#define SC_Check_CRC 0xc3 +#define SC_Restart 0xc4 + +typedef struct { + unsigned char command; + unsigned char length; + unsigned char subcommand; + unsigned char channel; +} rcv_cmd_s; + +s_karten_id Karteninformation; + +s_output_params output_params[2]; + +struct { + s_datensatz A; + s_datensatz B; +} Datensatz; + +typedef struct { + int cnt; + int stat; +} command_s; + +typedef struct { + int cnt; + int length; + unsigned char *buffer; +} comm_status; + +const ulong fl_base[3] = { 0x80000, 0x540000, 0x6c0000 }; +const char fl_type_str[3][6] = { "Kernel", "Xilinx", "Altera" }; + +/* info for FLASH chips */ +extern flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; + +unsigned long crc, crc_count; + +/* CRC divisor value */ +#define CRC_POLYNOM 0x800500 + +void do_crc (unsigned char data) +{ + unsigned char count; + + crc |= data; + for (count = 0; count < 8; count++) { + crc <<= 1; + if (crc & 0x1000000) + crc ^= CRC_POLYNOM; + } + crc_count++; +} + +int dez2hex (int in) +{ + int out; + + out = 16 * (in / 10); + out += (in % 10); + return out; +} + +/* somehow inlining the function failed, so we use a define instead */ +#define astro_read_select(dummy) \ + (((((volatile eport_t *)MMAP_EPORT)->pdr >> 6) & 0x01) == 0x0) + +static unsigned char flash_buffer[0x10000]; +static unsigned long flash_data_length, flash_data_count; +static unsigned long flash_prog_count, flash_sect_count; +static unsigned char flash_data_type, crc_en, crc_status; +static int flash_prog_stat; +static ulong fl_adr, fl_sector; +static unsigned char uart_buffer[64]; + +void fl_prog (ushort int_command) +{ + int s, i; + + /* nothing to do if we are not in flash mode */ + if ((int_command & INT_CMD_FLASH_MODE) == 0x0) + return; + + fl_adr = fl_base[flash_data_type] + flash_prog_count; + fl_sector = fl_adr >> 17; + + if (flash_prog_stat == FL_STAT_IDLE) { + if (((flash_prog_count & 0x1ffff) == 0) && + ((flash_prog_count >> 17) == flash_sect_count)) { + flash_protect (FLAG_PROTECT_CLEAR, fl_adr, + fl_adr + 0x1ffff, flash_info); + s = flash_erase_nb (flash_info, fl_sector); + flash_prog_stat = FL_STAT_ERASE; + } + else if ((flash_data_count >= (flash_prog_count + 64)) + || ((int_command & INT_CMD_WRITE_FLASH) + && (flash_data_count > flash_prog_count))) { + s = write_buff_nb (flash_info, + flash_buffer + + (flash_prog_count & 0xffff), + fl_adr, 64); + flash_prog_stat = FL_STAT_PROG; + } + } + else if (flash_prog_stat == FL_STAT_ERASE) { + s = flash_full_status_check_nb (flash_info, fl_sector, + 0, "erase"); + if (s != ERR_BUSY) { + if (s == ERR_OK) { + flash_sect_count++; + flash_prog_stat = FL_STAT_IDLE; + } + else + flash_prog_stat = FL_STAT_ERROR; + } + } + else if (flash_prog_stat == FL_STAT_PROG) { + s = flash_full_status_check_nb (flash_info, fl_sector, + 0, "write"); + if (s != ERR_BUSY) { + if (s == ERR_OK) { + flash_prog_stat = FL_STAT_IDLE; + for (i = 0; i < 64; i++) + if (flash_buffer + [(flash_prog_count + i) + & 0xffff] != + *((unsigned char *)fl_adr + + i)) + flash_prog_stat = + FL_STAT_ERROR; + if ((flash_prog_count & 0xfff) == 0) + printf ("."); + flash_prog_count += 64; + if (((flash_prog_count & 0x1ffff) == 0) + || + ((int_command & INT_CMD_WRITE_FLASH) + && (flash_data_count <= + flash_prog_count))) { + flash_protect (FLAG_PROTECT_SET, + fl_adr & 0xfffe0000, + fl_adr | 0x1ffff, + flash_info); + } + } + else + flash_prog_stat = FL_STAT_ERROR; + } + } +} + +void handle_rx_char (unsigned char rx_data, command_s *cmd, + int *rcv_cnt, rcv_cmd_s *rcv_cmd, + comm_status *rx_stat) +{ + volatile uart_t *uart; + + uart = (volatile uart_t *)(MMAP_UART0); + if (uart->usr & UART_USR_OE) { + if (DEBUG_ERROR) + printf ("UART FIFO Overrun Error!"); + uart->usr = UART_UCR_RESET_ERROR | UART_UCR_RESET_RX; + cmd->stat = CMD_RX_ERROR; + } + if (cmd->stat == CMD_INIT) { + if (*rcv_cnt == 0) { + /* First received Byte is the Command */ + rcv_cmd->command = rx_data; + /* non-Transparent Data: start Command Processing */ + if (rcv_cmd->command != F_Transparente_Daten) { + cmd->stat = CMD_NEW; + cmd->cnt++; + } + else + (*rcv_cnt)++; + } + else { + /* Length and Subcommand for Transparent Data */ + if (*rcv_cnt == 1) { + rcv_cmd->length = rx_data; + (*rcv_cnt)++; + } + else { + rcv_cmd->subcommand = rx_data; + cmd->stat = CMD_NEW; + cmd->cnt++; + } + } + } + else if ((cmd->stat == CMD_RX) || (cmd->stat == CMD_RX_END)) { + /* Store received Data to Rx Buffer */ + *(rx_stat->buffer + (rx_stat->cnt)) = rx_data; + if (crc_en) + do_crc (rx_data); + (rx_stat->cnt)++; + if (rx_stat->cnt == rx_stat->length) { + cmd->stat = (cmd->stat == CMD_RX_END) ? + CMD_INIT : CMD_RX_RDY; + } + } + else if (cmd->stat == CMD_CH_RX) + rcv_cmd->channel = rx_data; +} + +/* handle a transparent data command; these are used for software update + * return value is 1 if cmd_stat is set to CMD_INIT to let caller decide + * to reset the receive count, else 0. + */ +int handle_transparent_command (command_s *cmd, rcv_cmd_s *rcv_cmd, + comm_status *rx_stat, comm_status *tx_stat, + unsigned short *int_command) +{ + int i; + ulong ext_crc; + + switch (rcv_cmd->subcommand) { +/***************************************************************************/ +/** Prepare for Flash Data **/ +/***************************************************************************/ + case SC_Prepare_for_Flash_Data: + + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = uart_buffer; + rx_stat->length = 5; + rx_stat->cnt = 0; + cmd->stat = CMD_RX; + } + else if (cmd->stat == CMD_RX_RDY) { + for (i = 0; i < 4; i++) + flash_data_length = (flash_data_length << 8) + + uart_buffer[i + 1]; + flash_data_type = uart_buffer[0]; +#if DEBUG_INFO + printf (" -- Flash Programming Initialized -- \n"); + printf (" -- Receiving %lu Bytes of type ", + flash_data_length); + for (i = 0; i < 6; i++) + printf ("%c", fl_type_str[flash_data_type][i]); + printf (" [0x%lx]\n", fl_base[flash_data_type]); +#endif + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + tx_stat->cnt = 0; + cmd->stat = CMD_TX; + } + else if (cmd->stat == CMD_TX_RDY) { + crc_count = 0; + crc = 0; + flash_data_count = 0; + flash_prog_count = 0; + flash_sect_count = 0; + flash_prog_stat = FL_STAT_IDLE; + crc_en = 0; + *int_command = INT_CMD_FLASH_MODE; + cmd->stat = CMD_INIT; + return 1; + } + break; +/***************************************************************************/ +/** Receive Flash Data **/ +/***************************************************************************/ + case SC_Flash_Data: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = flash_buffer + + (flash_data_count & 0xffff); + rx_stat->length = rcv_cmd->length - 1; + rx_stat->cnt = 0; + cmd->stat = CMD_RX; + crc_en = 1; + } + else if (cmd->stat == CMD_RX_RDY) { + crc_en = 0; + flash_data_count += rcv_cmd->length - 1; + cmd->stat = CMD_INIT; + return 1; + } + break; +/***************************************************************************/ +/** Clear CRC **/ +/***************************************************************************/ + case SC_Clear_CRC: + if (cmd->stat == CMD_NEW) { + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + tx_stat->cnt = 0; + cmd->stat = CMD_TX_END; + crc_count = 0; + crc = 0; + } + break; +/***************************************************************************/ +/** Check_CRC -> Write to Flash **/ +/***************************************************************************/ + case SC_Check_CRC: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = uart_buffer; + rx_stat->length = 2; + rx_stat->cnt = 0; + cmd->stat = CMD_RX; + } + else if (cmd->stat == CMD_RX_RDY) { + if ((flash_data_count <= flash_prog_count) + || (flash_prog_stat == FL_STAT_ERROR)) { + crc_status = 0; + ext_crc = (uart_buffer[0] << 8) | + uart_buffer[1]; + if (uart_buffer[0] != ((crc >> 16) & 0xff)) + crc_status = 1; + if (uart_buffer[1] != ((crc >> 8) & 0xff)) + crc_status = 1; + if (flash_prog_stat == FL_STAT_ERROR) + crc_status |= 2; + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 4; + uart_buffer[2] = rcv_cmd->subcommand; + uart_buffer[3] = (crc >> 16); + uart_buffer[4] = (crc >> 8); + uart_buffer[5] = crc_status; +#if DEBUG_INFO + printf (" CRC %u / %lu of %lu kB \n", + crc_status, + (flash_data_count >> 10), + (flash_data_length >> 10)); +#endif + tx_stat->buffer = uart_buffer; + tx_stat->length = 6; + tx_stat->cnt = 0; + cmd->stat = CMD_TX_END; + if (crc_status) { + flash_prog_count = + flash_data_count = + (flash_data_count & 0xffff0000) + - 0x10000; + flash_prog_stat = FL_STAT_IDLE; + *int_command = INT_CMD_FLASH_MODE; + } + } + if (flash_data_count & 0xffff) + *int_command |= INT_CMD_WRITE_FLASH; + } + break; +/***************************************************************************/ +/** Restart **/ +/***************************************************************************/ + case SC_Restart: + if (cmd->stat == CMD_NEW) { + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + tx_stat->cnt = 0; + cmd->stat = CMD_TX; + crc_count = 0; + crc = 0; + } + else if (cmd->stat == CMD_TX_RDY) { + *int_command = INT_CMD_RESTART; + cmd->stat = CMD_INIT; + return 1; + } + break; + } + return 0; +} + +/* handle a general command (i.e. status and version information query) + * return value is always 0 except for transparent data where the + * return code is passed through to allow caller reset receive count. + */ +int handle_command (command_s *cmd, rcv_cmd_s *rcv_cmd, comm_status *rx_stat, + comm_status *tx_stat, unsigned short *int_command) +{ + int rv = 0; + + switch (rcv_cmd->command) { + +/***************************************************************************/ +/** Kartenfehler lesen **/ +/***************************************************************************/ + case F_Kartenfehler_Lesen: +#if DEBUG_INFO + printf ("Kartenfehler lesen\n"); +#endif + uart_buffer[0] = 0; + uart_buffer[1] = 0; + uart_buffer[2] = 0; + uart_buffer[3] = 0; + tx_stat->buffer = uart_buffer; + tx_stat->length = 4; + tx_stat->cnt = 0; + + cmd->stat = CMD_TX_END; + break; + +/***************************************************************************/ +/** Betriebsdaten lesen **/ +/***************************************************************************/ + case F_Daten_Lesen: + if (cmd->stat == CMD_NEW) { +#if DEBUG_INFO + printf ("Datensatz lesen\n"); +#endif + tx_stat->buffer = (unsigned char *) &Datensatz.A; + Datensatz.A.output_params = output_params[0]; + cmd->stat = CMD_TX; + } + else if (cmd->stat == CMD_TX_RDY) { + tx_stat->buffer = (unsigned char *) &Datensatz.B; + Datensatz.B.output_params = output_params[1]; + cmd->stat = CMD_TX_END; + } + tx_stat->length = 13; + tx_stat->cnt = 0; + break; + +/***************************************************************************/ +/** Karteninfo lesen **/ +/***************************************************************************/ + case F_Karteninfo_Lesen: +#if DEBUG_INFO + printf ("Karteninfo lesen\n"); +#endif + Karteninformation.Softwareversion = + ((*int_command) & INT_CMD_FLASH_MODE) ? + 0xEE : SOFTWARE_VERSION; + + tx_stat->buffer = (unsigned char *)&Karteninformation; + tx_stat->length = 5; + tx_stat->cnt = 0; + cmd->stat = CMD_TX_END; + break; + + case F_Transparente_Daten: + rv = handle_transparent_command (cmd, rcv_cmd, rx_stat, + tx_stat, int_command); + break; + } + return rv; +} + +/* transmit data prepared in comm_status structure */ +void transmit_buffer(comm_status *tx_stat) +{ + while (tx_stat->cnt < tx_stat->length) { + astro_put_char (tx_stat->buffer[tx_stat->cnt]); + tx_stat->cnt++; + } +} + +int do_update (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) +{ + unsigned char rx_data; + + comm_status rx_stat, tx_stat; + command_s cmd; + int rcv_cnt, i; + rcv_cmd_s rcv_cmd; + unsigned short int_command; + + int select, old_select, got_char; + volatile eport_t *eport = (volatile eport_t *)MMAP_EPORT; + volatile gpio_t *gpio = (volatile gpio_t *)MMAP_GPIO; + + volatile uart_t *uart; + char *env_string; + + uart = (volatile uart_t *)(MMAP_UART0); + + cmd.cnt = 0; + + /* we set some dummy parameters to make the protocol work */ + Karteninformation.Kartentyp = ASTRO_ID; + env_string = getenv ("loaderversion"); + if (env_string != NULL) { + i = (int)simple_strtol (env_string, NULL, 10); + Karteninformation.Hardwareversion = dez2hex (i); + } + else + Karteninformation.Hardwareversion = 0x10; + Karteninformation.Softwareversion = SOFTWARE_VERSION; + Karteninformation.SoftwareSubversion = SOFTWARE_SUBVERSION; + Karteninformation.FPGA_Version_Alt = 0x12; + Karteninformation.FPGA_Version_Xil = 0x13; + + Datensatz.A.Symbolrate = 0x5027; + Datensatz.A.Viterbirate = 0x34; + Datensatz.A.SatFreq = 0x6616; + Datensatz.A.Kartenfehler = 0; + + Datensatz.B.Symbolrate = 0x5027; + Datensatz.B.Viterbirate = 0x34; + Datensatz.B.SatFreq = 0x6616; + Datensatz.B.Kartenfehler = 0; + + puts ("Initializing serial port to ASTRO-Bus...\n"); + /* init serial port */ + rs_serial_init (0, 2400); + /* set UART pin for UART */ + gpio->par_uart |= 0x0003; + /* set select pin as GPIO */ + gpio->par_irq &= 0x0FF0; + /* set select pin as input */ + eport->pdr &= 0xBF; + /* set interrupt to both falling and rising edge + * (no IRQ used, though) + */ + eport->par |= 0x3000; + + int_command = 0; + + rcv_cnt = 0; + cmd.stat = CMD_INIT; + old_select = astro_read_select (); + + while (int_command != INT_CMD_RESTART) { + +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET (); +#endif + +/***************************************************************************/ +/** Flash program routine **/ +/***************************************************************************/ + + fl_prog (int_command); + +/***************************************************************************/ +/** UART Card Select Routine **/ +/***************************************************************************/ + + /* Write ID on Card Select */ + + select = astro_read_select (); + if ((select) && (!old_select)) { + /* set low baud rate for ID only */ + rs_serial_init (0, 2400); + astro_put_char (ASTRO_ID); + + /* Wait for TX finished before switching baudrate */ + while ((uart->usr & UART_USR_TXEMP) == 0) { + } + + /* set high baud rate */ + rs_serial_init (0, 115200); + // Reset the Receive Byte Counter + rcv_cnt = 0; + cmd.stat = CMD_INIT; + } + else if ((!select) && old_select) { + if (cmd.stat != CMD_INIT) { + cmd.stat = CMD_FAIL; + if (DEBUG_ERROR) + printf ("Command %u: 0x%02x failed\n", + cmd.cnt, rcv_cmd.command); + } + } + + old_select = select; + + got_char = astro_is_char (); + if (got_char) + rx_data = astro_get_char (); + + if (select) { +/***************************************************************************/ +/** UART RX Routine **/ +/***************************************************************************/ + if (got_char) + handle_rx_char (rx_data, &cmd, &rcv_cnt, + &rcv_cmd, &rx_stat); + +/***************************************************************************/ +/** Command Control Routine **/ +/***************************************************************************/ + if ((cmd.stat == CMD_NEW) + || (cmd.stat == CMD_CH_RX) + || (cmd.stat == CMD_RX_RDY) + || (cmd.stat == CMD_TX_RDY)) { + i = handle_command (&cmd, &rcv_cmd, + &rx_stat, &tx_stat, + &int_command); + if(i) + rcv_cnt = 0; + } + +/***************************************************************************/ +/** UART TX Routine **/ +/***************************************************************************/ + if ((cmd.stat == CMD_TX) || (cmd.stat == CMD_TX_END)) { + transmit_buffer(&tx_stat); + if (cmd.stat == CMD_TX_END) { + /* Reset the Receive Byte Counter */ + rcv_cnt = 0; + cmd.stat = CMD_INIT; + } + else + cmd.stat = CMD_TX_RDY; + } + } + } + return 0; +} + +U_BOOT_CMD (update, 2, 1, do_update, + "update - update function information\n", + "\n - print information for update\n" + "update N\n - print information for update # N\n"); diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h new file mode 100644 index 0000000..2ce80f8 --- /dev/null +++ b/include/configs/astro_mcf5373l.h @@ -0,0 +1,516 @@ +/* + * Configuation settings for the Sentec Cobra Board. + * + * (C) Copyright 2003 Josef Baumgartner josef.baumgartner@telex.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* configuration for ASTRO "Urmel" board. + * Originating from Cobra5272 configuration, messed up by + * Wolfgang Wegner w.wegner@astro-kom.de + * Please do not bother the original author with bug reports + * concerning this file. + */ + +/* --- + * board/config.h - configuration options, board specific + * --- + */ + +#ifndef _CONFIG_ASTRO_MCF5373L_H +#define _CONFIG_ASTRO_MCF5373L_H + +/* either of CONFIG_ASTRO_V532, CONFIG_ASTRO_V512 or + * CONFIG_ASTRO_TWIN7S2 has to be defined! + */ +#define CONFIG_ASTRO_V532 1 + +#if CONFIG_ASTRO_V532 +#define ASTRO_ID 0xF8 +#elif CONFIG_ASTRO_V512 +#define ASTRO_ID 0xFA +#elif CONFIG_ASTRO_TWIN7S2 +#define ASTRO_ID 0xF9 +#elif CONFIG_ASTRO_V912 +#define ASTRO_ID 0xFC +#elif CONFIG_ASTRO_COFDMDUOS2 +#define ASTRO_ID 0xFB +#else +#error No card type defined! +#endif + +/* --- + * Define processor + * possible values for Urmel board: only Coldfire M5373 processor supported + * (please do not change) + * --- + */ + +/* it seems not clear yet which processor defines we should use */ +#define CONFIG_MCF537x /* define processor family */ +#define CONFIG_MCF532x /* define processor family */ +#define CONFIG_M5373 /* define processor type */ +#define CONFIG_ASTRO5373L /* define board type */ + +/* Command line configuration */ +#include <config_cmd_default.h> + +/* --- + * CONFIG_MONITOR_IS_IN_RAM defines if u-boot is started from a different + * bootloader residing in flash or loaded via BDM + * --- + */ + +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define ENABLE_NETWORK 0 +#define ENABLE_JFFS 0 +#else +#define ENABLE_NETWORK 1 +#define ENABLE_JFFS 1 +#endif + +/* --- + * Define which commmands should be available at u-boot command prompt + * --- + */ + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DATE +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_MISC +#define CONFIG_CMD_XIMG +#if ENABLE_NETWORK +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING +#else +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#endif +#if ENABLE_JFFS +#define CONFIG_CMD_JFFS2 +#endif +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_LOADB +#define CONFIG_CMD_FPGA +#define CONFIG_CMDLINE_EDITING + +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#if ENABLE_NETWORK +#define CONFIG_MCFFEC +#ifdef CONFIG_MCFFEC +# define CONFIG_NET_MULTI 1 +# define CONFIG_MII 1 +# define CONFIG_SYS_DISCOVER_PHY +# define CONFIG_SYS_RX_ETH_BUFFER 8 +# define CONFIG_SYS_FAULT_ECHO_LINK_DOWN + +# define CONFIG_SYS_FEC0_PINMUX 0 +# define CONFIG_SYS_FEC0_MIIBASE CONFIG_SYS_FEC0_IOBASE +# define MCFFEC_TOUT_LOOP 50000 +/* If CONFIG_SYS_DISCOVER_PHY is not defined - hardcoded */ +# ifndef CONFIG_SYS_DISCOVER_PHY +# define FECDUPLEX FULL +# define FECSPEED _100BASET +# else +# ifndef CONFIG_SYS_FAULT_ECHO_LINK_DOWN +# define CONFIG_SYS_FAULT_ECHO_LINK_DOWN +# endif +# endif /* CONFIG_SYS_DISCOVER_PHY */ +#endif +#endif + +#define CONFIG_MCFRTC +#undef RTC_DEBUG + +/* Timer */ +#define CONFIG_MCFTMR +#undef CONFIG_MCFPIT + +/* I2C */ +#define CONFIG_FSL_I2C +#define CONFIG_HARD_I2C /* I2C with hw support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_SYS_I2C_SPEED 80000 +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_OFFSET 0x58000 +#define CONFIG_SYS_IMMR CONFIG_SYS_MBAR + +/* --- + * Defines processor clock - important for correct timings concerning serial + * interface etc. + * CONFIG_SYS_HZ gives unit: 1000 -> 1 Hz ^= 1000 ms + * --- + */ + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_CLK 80000000 +#define CONFIG_SYS_CPU_CLK CONFIG_SYS_CLK * 3 +#define CONFIG_SYS_SDRAM_SIZE 32 /* SDRAM size in MB */ + +#define CONFIG_SYS_CORE_SRAM_SIZE 0x8000 +#define CONFIG_SYS_CORE_SRAM 0x80000000 + +#define CONFIG_SYS_UNIFY_CACHE + +/* --- + * Enable use of Ethernet + * --- + */ + +/* ethernet could be useful for debugging */ +/* #define FEC_ENET */ + +/* --- + * Define baudrate for UART1 (console output, tftp, ...) + * default value of CONFIG_BAUDRATE for Sentec board: 19200 baud + * CONFIG_SYS_BAUDRATE_TABLE defines values that can be selected in u-boot command + * interface + * --- + */ + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600 , 19200 , 38400 , 57600, 115200 } + +#define CONFIG_MCFUART +#define CONFIG_SYS_UART_PORT (2) +#define CONFIG_SYS_UART2_ALT3_GPIO + +/* --- + * set "#if 0" to "#if 1" if (Hardware)-WATCHDOG should be enabled & change + * timeout acc. to your needs + * #define CONFIG_WATCHDOG_TIMEOUT x , x is timeout in milliseconds, e. g. 10000 + * for 10 sec + * --- + */ + +#ifndef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_WATCHDOG +#define CONFIG_WATCHDOG_TIMEOUT 3355 /* timeout in milliseconds */ +#endif + +/* --- + * Configuration for environment + * Environment is embedded in u-boot in the second sector of the flash + * --- + */ + +#ifndef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_ENV_OFFSET 0x1FF8000 +#define CONFIG_ENV_SECT_SIZE 0x8000 +#define CONFIG_ENV_IS_IN_FLASH 1 +#else +/* environment in RAM - I hope we can thus use a single PC-based application + to load an image, load U-Boot, load an environment and then start U-Boot + to execute the commands from the environment. Just the feedback is still + missing then... */ +#define CONFIG_ENV_ADDR 0x40060000 +#define CONFIG_ENV_SECT_SIZE 0x8000 +#define CONFIG_ENV_IS_IN_FLASH 1 +#endif + +// here we put our FPGA configuration... +#define CONFIG_MISC_INIT_R 1 + +/* + *----------------------------------------------------------------------------- + * Define user parameters that have to be customized most likely + *----------------------------------------------------------------------------- + */ + +/* AUTOBOOT settings - booting images automatically by u-boot after power on */ + +/* beware - watchdog is not service during autoboot delay time! */ +/* used for autoboot, delay in seconds u-boot will wait before starting + defined (auto-)boot command, setting to -1 disables delay, setting to + 0 will too prevent access to u-boot command interface: u-boot then has + to be reflashed */ +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_BOOTDELAY 1 +#else +#define CONFIG_BOOTDELAY 1 +#endif + +/* The following settings will be contained in the environment block ; if you +want to use a neutral environment all those settings can be manually set in +u-boot: 'set' command */ + +#define _QUOTEME(x) #x +#define QUOTEME(x) _QUOTEME(x) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loaderversion=11\0" \ + "card_id="QUOTEME(ASTRO_ID)"\0" \ + "alterafile=0\0" \ + "xilinxfile=0\0" \ + "xilinxload=imxtract 0x540000 $xilinxfile 0x41000000&&fpga load 0 0x41000000 $filesize\0" \ + "alteraload=imxtract 0x6c0000 $alterafile 0x41000000&&fpga load 1 0x41000000 $filesize\0" \ + "env_default=1\0" \ + "env_check=if test $env_default -eq 1; then setenv env_default 0;saveenv;fi\0" + +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_BOOTCOMMAND "" /* Autoboot command, please enter a valid image address in flash */ +#else +#if CONFIG_ASTRO_V532 +#define CONFIG_BOOTCOMMAND "protect off 0x80000 0x1ffffff;run env_check;run xilinxload&&run alteraload&&bootm 0x80000;update;reset" +#else +#define CONFIG_BOOTCOMMAND "protect off 0x80000 0x1ffffff;run env_check;run xilinxload&&bootm 0x80000;update;reset" +#endif +#endif + +/* default bootargs that are considered during boot */ +#define CONFIG_BOOTARGS " console=ttyS2,115200 rootfstype=romfs loaderversion=$loaderversion" + +/* User network settings */ + +#define CONFIG_ETHADDR 00:00:00:00:00:09 /* default ethernet MAC addr. */ +#define CONFIG_IPADDR 192.168.100.2 /* default board IP address */ +#define CONFIG_SERVERIP 192.168.100.1 /* default tftp server IP address */ + +#define CONFIG_SYS_PROMPT "URMEL > " /* Layout of u-boot prompt*/ + +#define CONFIG_SYS_LOAD_ADDR 0x20000 /*Defines default RAM address +from which user programs will be started */ + +/*---*/ + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ + +#if (CONFIG_COMMANDS & CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_FPGA_COUNT 1 +#define CONFIG_FPGA +#define CONFIG_FPGA_XILINX +#define CONFIG_FPGA_SPARTAN3 +#define CONFIG_FPGA_ALTERA +#define CONFIG_FPGA_CYCLON2 +#define CONFIG_SYS_FPGA_PROG_FEEDBACK +#define CONFIG_SYS_FPGA_WAIT 1000 + +/* + *----------------------------------------------------------------------------- + * End of user parameters to be customized + *----------------------------------------------------------------------------- + */ + +/* --- + * Defines memory range for test + * --- + */ + +#define CONFIG_SYS_MEMTEST_START 0x400 +#define CONFIG_SYS_MEMTEST_END 0x380000 + +/* --- + * Low Level Configuration Settings + * (address mappings, register initial values, etc.) + * You should know what you are doing if you make changes here. + * --- + */ + +/* --- + * Base register address + * --- + */ + +#define CONFIG_SYS_MBAR 0xFC000000 /* Register Base Addrs */ + +/* --- + * System Conf. Reg. & System Protection Reg. + * --- + */ + +#define CONFIG_SYS_SCR 0x0003; +#define CONFIG_SYS_SPR 0xffff; + +/* --- + * Ethernet settings + * --- + */ + +#if ENABLE_NETWORK +#define CONFIG_SYS_DISCOVER_PHY +#define CONFIG_SYS_ENET_BD_BASE 0x780000 +#endif + +/*----------------------------------------------------------------------- + * Definitions for initial stack pointer and data area (in internal SRAM) + */ +#define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 +#define CONFIG_SYS_INIT_RAM_END 0x8000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_CTRL 0x221 +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +/*----------------------------------------------------------------------- + * Start addresses for the final memory configuration + * (Set up by the startup code) + * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 + * + * WW: please note that this can not be 0 for some processors... + * the MCF5373 can only start at 0x40000000 to 0x7FF00000 + */ +#define CONFIG_SYS_SDRAM_BASE 0x40000000 + +/*----------------------------------------------------------------------- + * Chipselect bank definitions + */ +/* + * CS0 - Flash 32MB (first 16MB) + * CS1 - Flash 32MB (second half) + * CS2 - FPGA + * CS3 - FPGA + * CS4 - Available + * CS5 - Available + */ +#define CONFIG_SYS_CS0_BASE 0 +#define CONFIG_SYS_CS0_MASK 0x00ff0001 +#define CONFIG_SYS_CS0_CTRL 0x00001fc0 + +#define CONFIG_SYS_CS1_BASE 0x01000000 +#define CONFIG_SYS_CS1_MASK 0x00ff0001 +#define CONFIG_SYS_CS1_CTRL 0x00001fc0 + +#define CONFIG_SYS_CS2_BASE 0x20000000 +#define CONFIG_SYS_CS2_MASK 0x00ff0001 +#define CONFIG_SYS_CS2_CTRL 0x0000fec0 + +#define CONFIG_SYS_CS3_BASE 0x21000000 +#define CONFIG_SYS_CS3_MASK 0x00ff0001 +#define CONFIG_SYS_CS3_CTRL 0x0000fec0 + +/* + *------------------------------------------------------------------------- + * RAM SIZE (is defined above) + *----------------------------------------------------------------------- + */ + +/* + *----------------------------------------------------------------------- + */ + +#define CONFIG_SYS_FLASH_BASE 0x00000000 + +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_SYS_MONITOR_BASE 0x40020000 +#else +// This is mainly used during relocation in start.S +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_FLASH_BASE + 0x400) +#endif +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ + +#define CONFIG_SYS_BOOTPARAMS_LEN 64*1024 +#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization ?? + */ +#define CONFIG_SYS_BOOTMAPSZ (CONFIG_SYS_SDRAM_BASE + (CONFIG_SYS_SDRAM_SIZE << 20)) + +/*----------------------------------------------------------------------- + * FLASH organization + */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 259 /* max number of sectors on one chip */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 1000 /* flash timeout */ + +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_SIZE 0x2000000 +#define CONFIG_SYS_FLASH_PROTECTION 1 +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 +#define CONFIG_SYS_FLASH_CFI_NONBLOCK 1 + +#if ENABLE_JFFS +/* JFFS Partition offset set */ +#define CONFIG_SYS_JFFS2_FIRST_BANK 0 +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 +/* 512k reserved for u-boot */ +#define CONFIG_SYS_JFFS2_FIRST_SECTOR 0x40 +#endif + +/*----------------------------------------------------------------------- + * Cache Configuration + */ +#define CONFIG_SYS_CACHELINE_SIZE 16 + +/*----------------------------------------------------------------------- + * Memory bank definitions + * + * Please refer also to Motorola Coldfire user manual - Chapter XXX + * http://e-www.motorola.com/files/dsp/doc/ref_manual/MCF5272UM.pdf + */ + // Flash: 16 Bit SRAM/ROM standard interface, enabled +#define CONFIG_SYS_BR0_PRELIM 0x00000201 +#define CONFIG_SYS_OR0_PRELIM 0x00000014 + +#define CONFIG_SYS_BR1_PRELIM 0 +#define CONFIG_SYS_OR1_PRELIM 0 + +#define CONFIG_SYS_BR2_PRELIM 0 +#define CONFIG_SYS_OR2_PRELIM 0 + +#define CONFIG_SYS_BR3_PRELIM 0 +#define CONFIG_SYS_OR3_PRELIM 0 + +#define CONFIG_SYS_BR4_PRELIM 0 +#define CONFIG_SYS_OR4_PRELIM 0 + +#define CONFIG_SYS_BR5_PRELIM 0 +#define CONFIG_SYS_OR5_PRELIM 0 + +#define CONFIG_SYS_BR6_PRELIM 0 +#define CONFIG_SYS_OR6_PRELIM 0 + +// SDRAM: 32 Bit (cache-line) size, enabled +#define CONFIG_SYS_BR7_PRELIM 0x00000701 +#define CONFIG_SYS_OR7_PRELIM 0xFF00007C + +/*----------------------------------------------------------------------- + * Port configuration (GPIO) + */ +#define CONFIG_SYS_PACNT 0x00000000 /* PortA control reg.: All pins are external +GPIO*/ +#define CONFIG_SYS_PADDR 0x00FF /* PortA direction reg.: PA7 to PA0 are outputs +(1^=output, 0^=input) */ +#define CONFIG_SYS_PADAT LED_STAT_0 /* PortA value reg.: Turn all LED off */ +#define CONFIG_SYS_PBCNT 0x55554155 /* PortB control reg.: Ethernet/UART +configuration */ +#define CONFIG_SYS_PBDDR 0x0000 /* PortB direction: All pins configured as inputs */ +#define CONFIG_SYS_PBDAT 0x0000 /* PortB value reg. */ +#define CONFIG_SYS_PDCNT 0x00000000 /* PortD control reg. */ + +#endif /* _CONFIG_ASTRO_MCF5373L_H */
Dear Wolfgang Wegner,
In message 1260378648-19232-1-git-send-email-w.wegner@astro-kom.de you wrote:
This patch adds support for ASTRO board(s) based on MCF5373L.
Signed-off-by: Wolfgang Wegner w.wegner@astro-kom.de
There is another board (series) in the queue to be submitted, thus I added a subdirectory for all our boards.
Makefile | 12 + board/astro/mcf5373l/Makefile | 44 +++ board/astro/mcf5373l/astro.h | 39 +++ board/astro/mcf5373l/config.mk | 28 ++ board/astro/mcf5373l/fpga.c | 424 +++++++++++++++++++++++ board/astro/mcf5373l/mcf5373l.c | 204 +++++++++++ board/astro/mcf5373l/u-boot.lds | 142 ++++++++ board/astro/mcf5373l/update.c | 699 ++++++++++++++++++++++++++++++++++++++ include/configs/astro_mcf5373l.h | 516 ++++++++++++++++++++++++++++ 9 files changed, 2108 insertions(+), 0 deletions(-) create mode 100644 board/astro/mcf5373l/Makefile create mode 100644 board/astro/mcf5373l/astro.h create mode 100644 board/astro/mcf5373l/config.mk create mode 100644 board/astro/mcf5373l/fpga.c create mode 100644 board/astro/mcf5373l/mcf5373l.c create mode 100644 board/astro/mcf5373l/u-boot.lds create mode 100644 board/astro/mcf5373l/update.c create mode 100644 include/configs/astro_mcf5373l.h
Entries for MAINTAINERS and MAKEALL missing.
diff --git a/Makefile b/Makefile index 75b2c1e..924e210 100644 --- a/Makefile +++ b/Makefile @@ -2263,6 +2263,18 @@ M5485HFE_config : unconfig TASREG_config : unconfig @$(MKCONFIG) $(@:_config=) m68k mcf52x2 tasreg esd
+astro_mcf5373l_config \ +astro_mcf5373l_ram_config : unconfig
- @if [ "$@" = "astro_mcf5373l_ram_config" ] ; then \
echo "#define CONFIG_MONITOR_IS_IN_RAM" >> $(obj)include/config.h ; \
echo "TEXT_BASE = 0x40020000" > $(obj)board/astro/mcf5373l/config.tmp ; \
$(XECHO) "... for RAM boot ..." ; \
- else \
echo "TEXT_BASE = 0x00000000" > $(obj)board/astro/mcf5373l/config.tmp ; \
$(XECHO) "... for FLASH boot ..." ; \
- fi
- @$(MKCONFIG) -a astro_mcf5373l m68k mcf532x mcf5373l astro
Please keep lists sorted, and don't add such scripting to the Makefile. It is not needed any more.
- char Kartentyp;
- char Hardwareversion;
- char Softwareversion;
- char SoftwareSubversion; /* " ","a",.."z" */
- char FPGA_Version_Alt;
- char FPGA_Version_Xil;
+} s_karten_id;
Variable names must be all lower case. Please fix globally.
+typedef struct {
- unsigned char mode;
- unsigned char deviation;
- unsigned short freq;
And please decide for one language. Don;t use half german and half English names. Note that English is striclty preferred.
- Altera/Xilinx FPGA configuration support for the ASTRO "URMEL" board
- volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO;
Incorrect indentation. Please fix globally.
- /* PAR_T0IN -> GPIO */
- gpiop->par_timer &= 0xfc;
Please use I/O accessors to access device registers. Please fix globally.
- writing the complete buffer in one function is much faster,
- then calling it for every bit */
Incorrect multiline comment. Please fix globally.
- Test the state of the active-low FPGA INIT line. Return 1 on INIT
- asserted (low).
- unsigned char state;
- state = (gpiop->ppd_pwm & 0x08) >> 3;
- if (state)
- else
return 1;
Simplify:
return ((gpiop->ppd_pwm & 0x08) != 0);
(but use I/O accessor instead.
- return CONFIG_SYS_SDRAM_SIZE * 1024 * 1024;
Use get_ram_size() ?
- printf ("DRAM test not implemented!\n");
- return (0);
We already have a number of memory tests. Don't reinvent the wheel.
- volatile uart_t *uart;
- int i;
- uart = (volatile uart_t *)(MMAP_UART0);
- /* Wait for last character to go. */
- for (i = 0; (i < 0x10000); i++)
break;
Braces needed for multiline statement. And you probably want to use a better timeout.
Do you really need a board specific linker script?
Looks as if you wanted to use an enum here?
Macros use all caps names. And decide for _one_ language.
Cool. Yet another CRC function :-(
- int out;
- out = 16 * (in / 10);
- out += (in % 10);
- return out;
Get rid of this and use proper conversion routines.
- if (flash_prog_stat == FL_STAT_IDLE) {
Move 'else' on previous line.
flash_buffer +
fl_adr, 64);
- else if (flash_prog_stat == FL_STAT_ERASE) {
Ditto.
0, "erase");
if (s == ERR_OK) {
flash_sect_count++;
else
And again. Please fix indentation globally.
if (s == ERR_OK) {
if (flash_buffer
& 0xffff] !=
i))
flash_prog_stat =
FL_STAT_ERROR;
This looks very much unreadable.
Quoting "Documentation/CodingStyle":
Now, some people will claim that having 8-character indentations makes the code move too far to the right, and makes it hard to read on a 80-character terminal screen. The answer to that is that if you need more than 3 levels of indentation, you're screwed anyway, and should fix your program.
- if (env_string != NULL) {
Why are you doing this? Why not simply
Karteninformation.Hardwareversion = simple_strtol(env_string, NULL, 16); ?
Also mind that the CodingStyle does not allow for spaces between function name and '('. Please fix globally.
No C++ comments, please.
if (select) {
Indentation wrong, incorrect multiline comment. Please fix globally.
Check oif this help message really looks what you think it should look like. For example, the last '\n' is probably wrong.
- Enable use of Ethernet
Do not add dead code.
- set "#if 0" to "#if 1" if (Hardware)-WATCHDOG should be enabled & change
- timeout acc. to your needs
- #define CONFIG_WATCHDOG_TIMEOUT x , x is timeout in milliseconds, e. g. 10000
- for 10 sec
Which "#if 0" are you referring to in the comment?
- "loaderversion=11\0" \
- "card_id="QUOTEME(ASTRO_ID)"\0" \
- "alterafile=0\0" \
- "xilinxfile=0\0" \
- "xilinxload=imxtract 0x540000 $xilinxfile 0x41000000&&fpga load 0 0x41000000 $filesize\0" \
- "alteraload=imxtract 0x6c0000 $alterafile 0x41000000&&fpga load 1 0x41000000 $filesize\0" \
Lines too long, Please fix globally.
NAK.
Remove these settings, and never ever use bogus or stolen MAC addresses.
Dear Wolfgang Denk,
thank you for all the comments and suggestions and sorry for that many reasons to complain! I just would like to ask a few questions in-line.
- else \
- fi
How can I avoid this scripting? I took the freescale EVM boards as a reference. Could you please point me to a better example on how to set these variables, especially TEXT_BASE, on a per-target basis?
Sorry if this is a stupid question, but so this should read:
tmp_char = readb(&gpiop->par_timer); tmp_char &= 0xfc; writeb(tmp_char, &gpiop->par_timer);
And how about word and long-word registers? As far as I understand from asm-m68k/io.h, the I/O accessors do byte-swap, how does this make sense on a big-endian-only device?
Probably not in this case, but unfortunately this is what all current Coldfire boards do, and I am not familiar enough with ld to overlook which consequences changing this might have.
(It may be trivial for MCF53xx, but for other devices like MCF5445x with the possibility for serial boot, there are big differences between the different linker files.)
I have no choice here. The CRC algorithm is dictated, so either I can use an already existing CRC function implementing exactly this scheme (sorry for not having searched for it yet), or I have to implement it here. :-(
0, "erase");
if (s == ERR_OK) {
flash_sect_count++;
else
Sorry to ask, but which part of indentation is wrong here? (Except the else/if you quoted in the other examples)
Regards, Wolfgang
The new "mkconfig" script allows you to generate CONFIG_MK_* variables from the make target names, which you then can use to adjust other settings.
Right.
There should be non-swapping accessor functions as well.
Hm...
Tsi Chung Liew, are you planning for some cleanup to use a single common linker script for all boards without special requirements?
There are probably just a few major "types" ?
0, "erase");
if (s == ERR_OK) {
flash_sect_count++;
else
the "else" must be on the same line as the "}".
Dear Wolfgang Denk,
- else \
- fi
Another question here: which sorting scheme should I adhere to? With the exception of the tasreg board, all coldfire boards are sorted according to their processor number (this sorting is in turn alphabetical, not numerical, probably because it better represents the family affiliation), only the tasreg board is at the end of the list according to the alphabetical order of the board names...
Best regards, Wolfgang
- else \
- fi
Please use the equivalent of "sort -f" on the make target names.
Signed-off-by: Wolfgang Wegner w.wegner@astro-kom.de --- I hope to have addressed all the comments and errors that were present in the first submission; exceptions are the linker script because there was no feedback by Tsi Chung Liew on this issue and the crc routine because the update protocol is fixed and uses this (as far as I can see) non-standard CRC polynomial. This patch (or the boot script/images) relies on the following previously sent patches: add include/asm-m68k/unaligned.h (Message-Id 1260376332-15835-1-git-send-email-w.wegner@astro-kom.de) non-blocking flash write/erase/status check functions (Message-Id 1260374411-11299-1-git-send-email-w.wegner@astro-kom.de) add ability to handle compressed images to imxtract (Message-Id 1260436281-31824-1-git-send-email-w.wegner@astro-kom.de) add block write function to spartan3 slave serial load (Message-Id 1256918102-3760-1-git-send-email-w.wegner@astro-kom.de) allow MCF532x to use CONFIG_MONITOR_IS_IN_RAM (Message-Id 1256739061-13311-2-git-send-email-w.wegner@astro-kom.de) MCF532x: make icache_enable use CONFIG_SYS_SDRAM_SIZE (Message-Id 1256739061-13311-1-git-send-email-w.wegner@astro-kom.de)
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 4 + board/astro/mcf5373l/Makefile | 44 +++ board/astro/mcf5373l/astro.h | 39 +++ board/astro/mcf5373l/config.mk | 27 ++ board/astro/mcf5373l/fpga.c | 431 ++++++++++++++++++++++++++ board/astro/mcf5373l/mcf5373l.c | 209 +++++++++++++ board/astro/mcf5373l/u-boot.lds | 142 +++++++++ board/astro/mcf5373l/update.c | 625 ++++++++++++++++++++++++++++++++++++++ include/configs/astro_mcf5373l.h | 427 ++++++++++++++++++++++++++ 11 files changed, 1953 insertions(+), 0 deletions(-) create mode 100644 board/astro/mcf5373l/Makefile create mode 100644 board/astro/mcf5373l/astro.h create mode 100644 board/astro/mcf5373l/config.mk create mode 100644 board/astro/mcf5373l/fpga.c create mode 100644 board/astro/mcf5373l/mcf5373l.c create mode 100644 board/astro/mcf5373l/u-boot.lds create mode 100644 board/astro/mcf5373l/update.c create mode 100644 include/configs/astro_mcf5373l.h
diff --git a/MAINTAINERS b/MAINTAINERS index 9734b1d..016a308 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -869,6 +869,10 @@ TsiChung Liew Tsi-Chung.Liew@freescale.com M5475EVB mcf547x_8x M5485EVB mcf547x_8x
+Wolfgang Wegner w.wegner@astro-kom.de + + astro_mcf5373l MCF5373L + ######################################################################### # AVR32 Systems: # # # diff --git a/MAKEALL b/MAKEALL index ab1bb6f..6f4f76c 100755 --- a/MAKEALL +++ b/MAKEALL @@ -822,6 +822,7 @@ LIST_microblaze=" \ #########################################################################
LIST_coldfire=" \ + astro_mcf5373l \ cobra5272 \ EB+MCF-EV123 \ EB+MCF-EV123_internal \ diff --git a/Makefile b/Makefile index 75b2c1e..a8d3517 100644 --- a/Makefile +++ b/Makefile @@ -2024,6 +2024,10 @@ ZPC1900_config: unconfig ## Coldfire #########################################################################
+astro_mcf5373l_config \ +astro_mcf5373l_RAM_config : unconfig + @$(MKCONFIG) -t $(@:_config=) astro_mcf5373l m68k mcf532x mcf5373l astro + M5208EVBE_config : unconfig @$(MKCONFIG) $(@:_config=) m68k mcf52x2 m5208evbe freescale
diff --git a/board/astro/mcf5373l/Makefile b/board/astro/mcf5373l/Makefile new file mode 100644 index 0000000..e0b1bc6 --- /dev/null +++ b/board/astro/mcf5373l/Makefile @@ -0,0 +1,44 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS = $(BOARD).o fpga.o update.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/astro/mcf5373l/astro.h b/board/astro/mcf5373l/astro.h new file mode 100644 index 0000000..b11c194 --- /dev/null +++ b/board/astro/mcf5373l/astro.h @@ -0,0 +1,39 @@ +#ifndef __ASTRO_H__ +#define __ASTRO_H__ + +int rs_serial_init(int port, int baud); +void astro_put_char(char ch); +int astro_is_char(void); +int astro_get_char(void); + +/* data structures used for communication (update.c) */ +typedef struct card_id { + char card_type; + char hardware_version; + char software_version; + char software_subversion; /* " ","a".."z" */ + char fpga_version_altera; + char fpga_version_xilinx; +} card_id_t; + +typedef struct { + unsigned char mode; + unsigned char deviation; + unsigned short freq; +} __attribute__ ((packed)) output_params_t; + +typedef struct { + unsigned short satfreq; + unsigned char satdatallg; + unsigned short symbolrate; + unsigned char viterbirate; + unsigned char symbolrate_l; + output_params_t output_params; + unsigned char reserve; + unsigned char card_error; + unsigned short dummy_ts_id; + unsigned char dummy_pat_ver; + unsigned char dummy_sdt_ver; +} __attribute__ ((packed)) parameters_t; + +#endif /* __ASTRO_H__ */ diff --git a/board/astro/mcf5373l/config.mk b/board/astro/mcf5373l/config.mk new file mode 100644 index 0000000..6316a30 --- /dev/null +++ b/board/astro/mcf5373l/config.mk @@ -0,0 +1,27 @@ +# +# (C) Copyright 2000-2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# Coldfire contribution by Bernhard Kuhn bkuhn@metrowerks.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +TEXT_BASE = $(CONFIG_TEXT_BASE) + +PLATFORM_CPPFLAGS += -DTEXT_BASE=$(TEXT_BASE) diff --git a/board/astro/mcf5373l/fpga.c b/board/astro/mcf5373l/fpga.c new file mode 100644 index 0000000..aa06c08 --- /dev/null +++ b/board/astro/mcf5373l/fpga.c @@ -0,0 +1,431 @@ +/* + * (C) Copyright 2006 + * Wolfgang Wegner, ASTRO Strobel Kommunikationssysteme GmbH, + * w.wegner@astro-kom.de + * + * based on the files by + * Heiko Schocher, DENX Software Engineering, hs@denx.de + * and + * Rich Ireland, Enterasys Networks, rireland@enterasys.com. + * Keith Outwater, keith_outwater@mvis.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +/* + * Altera/Xilinx FPGA configuration support for the ASTRO "URMEL" board + */ + +#include <common.h> +#include <watchdog.h> +#include <altera.h> +#include <ACEX1K.h> +#include <spartan3.h> +#include <command.h> +#include <asm/immap_5329.h> +#include <asm/io.h> +#include "fpga.h" + +DECLARE_GLOBAL_DATA_PTR; + +int altera_pre_fn (int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + unsigned char tmp_char; + unsigned short tmp_short; + + /* first, set the required pins to GPIO function */ + /* PAR_T0IN -> GPIO */ + tmp_char = readb(&gpiop->par_timer); + tmp_char &= 0xfc; + writeb(tmp_char, &gpiop->par_timer); + /* all QSPI pins -> GPIO */ + writew(0x0000, &gpiop->par_qspi); + /* U0RTS, U0CTS -> GPIO */ + tmp_short = __raw_readw(&gpiop->par_uart); + tmp_short &= 0xfff3; + __raw_writew(tmp_short, &gpiop->par_uart); + /* all PWM pins -> GPIO */ + writeb(0x00, &gpiop->par_pwm); + /* next, set data direction registers */ + writeb(0x01, &gpiop->pddr_timer); + writeb(0x25, &gpiop->pddr_qspi); + writeb(0x0c, &gpiop->pddr_uart); + writeb(0x04, &gpiop->pddr_pwm); + + /* ensure other SPI peripherals are deselected */ + writeb(0x08, &gpiop->ppd_uart); + writeb(0x38, &gpiop->ppd_qspi); + + /* CONFIG = 0 STATUS = 0 -> FPGA in reset state */ + writeb(0xFB, &gpiop->pclrr_uart); + /* enable Altera configuration by clearing QSPI_CS2 and DT0IN */ + writeb(0xFE, &gpiop->pclrr_timer); + writeb(0xDF, &gpiop->pclrr_qspi); + return FPGA_SUCCESS; +} + +/* Set the state of CONFIG Pin */ +int altera_config_fn (int assert_config, int flush, int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + if (assert_config) + writeb(0x04, &gpiop->ppd_uart); + else + writeb(0xFB, &gpiop->pclrr_uart); + return FPGA_SUCCESS; +} + +/* Returns the state of STATUS Pin */ +int altera_status_fn (int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + if (readb(&gpiop->ppd_pwm) & 0x08) + return FPGA_FAIL; + return FPGA_SUCCESS; +} + +/* Returns the state of CONF_DONE Pin */ +int altera_done_fn (int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + if (readb(&gpiop->ppd_pwm) & 0x20) + return FPGA_FAIL; + return FPGA_SUCCESS; +} + +/* writes the complete buffer to the FPGA + writing the complete buffer in one function is much faster, + then calling it for every bit */ +int altera_write_fn (void *buf, size_t len, int flush, int cookie) +{ + size_t bytecount = 0; + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + unsigned char *data = (unsigned char *)buf; + unsigned char val = 0; + int i; + int len_40 = len / 40; + + while (bytecount < len) { + val = data[bytecount++]; + i = 8; + do { + writeb(0xFB, &gpiop->pclrr_qspi); + if (val & 0x01) + writeb(0x01, &gpiop->ppd_qspi); + else + writeb(0xFE, &gpiop->pclrr_qspi); + writeb(0x04, &gpiop->ppd_qspi); + val >>= 1; + i--; + } while (i > 0); + + if (bytecount % len_40 == 0) { +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET (); +#endif +#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK + putc ('.'); /* let them know we are alive */ +#endif +#ifdef CONFIG_SYS_FPGA_CHECK_CTRLC + if (ctrlc ()) + return FPGA_FAIL; +#endif + } + } + return FPGA_SUCCESS; +} + +/* called, when programming is aborted */ +int altera_abort_fn (int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + writeb(0x20, &gpiop->ppd_qspi); + writeb(0x08, &gpiop->ppd_uart); + return FPGA_SUCCESS; +} + +/* called, when programming was succesful */ +int altera_post_fn (int cookie) +{ + return altera_abort_fn (cookie); +} + +/* Note that these are pointers to code that is in Flash. They will be + * relocated at runtime. + * FIXME: relocation not yet working for coldfire, see below! + */ +Altera_CYC2_Passive_Serial_fns altera_fns = { + altera_pre_fn, + altera_config_fn, + altera_status_fn, + altera_done_fn, + altera_write_fn, + altera_abort_fn, + altera_post_fn +}; + +Altera_desc altera_fpga[CONFIG_FPGA_COUNT] = { + {Altera_CYC2, + passive_serial, + 85903, + (void *)&altera_fns, + NULL, + 0} +}; + +/* + * Initialize the fpga. Return 1 on success, 0 on failure. + */ +int astro5373l_altera_load (void) +{ + int i; + + for (i = 0; i < CONFIG_FPGA_COUNT; i++) { + /* I did not yet manage to get relocation work properly, + * so set stuff here instead of static initialisation: + */ + altera_fns.pre = altera_pre_fn; + altera_fns.config = altera_config_fn; + altera_fns.status = altera_status_fn; + altera_fns.done = altera_done_fn; + altera_fns.write = altera_write_fn; + altera_fns.abort = altera_abort_fn; + altera_fns.post = altera_post_fn; + altera_fpga[i].iface_fns = (void *)&altera_fns; + fpga_add (fpga_altera, &altera_fpga[i]); + } + return 1; +} + +/* + * Set the FPGA's PROG_B line to the specified level + */ +int xilinx_pgm_fn (int assert, int flush, int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + if (assert) + writeb(0xFB, &gpiop->pclrr_uart); + else + writeb(0x04, &gpiop->ppd_uart); + return assert; +} + +/* + * Test the state of the active-low FPGA INIT line. Return 1 on INIT + * asserted (low). + */ +int xilinx_init_fn (int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + return ((readb(&gpiop->ppd_pwm) & 0x08) == 0); +} + +/* + * Test the state of the active-high FPGA DONE pin + */ +int xilinx_done_fn (int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + return (readb(&gpiop->ppd_pwm) & 0x20) >> 5; +} + +/* + * Abort an FPGA operation + */ +int xilinx_abort_fn (int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + /* ensure all SPI peripherals and FPGAs are deselected */ + writeb(0x08, &gpiop->ppd_uart); + writeb(0x01, &gpiop->ppd_timer); + writeb(0x38, &gpiop->ppd_qspi); + return FPGA_FAIL; +} + +/* + * FPGA pre-configuration function. Just make sure that + * FPGA reset is asserted to keep the FPGA from starting up after + * configuration. + */ +int xilinx_pre_config_fn (int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + unsigned char tmp_char; + unsigned short tmp_short; + + /* first, set the required pins to GPIO function */ + /* PAR_T0IN -> GPIO */ + tmp_char = readb(&gpiop->par_timer); + tmp_char &= 0xfc; + writeb(tmp_char, &gpiop->par_timer); + /* all QSPI pins -> GPIO */ + writew(0x0000, &gpiop->par_qspi); + /* U0RTS, U0CTS -> GPIO */ + tmp_short = __raw_readw(&gpiop->par_uart); + tmp_short &= 0xfff3; + __raw_writew(tmp_short, &gpiop->par_uart); + /* all PWM pins -> GPIO */ + writeb(0x00, &gpiop->par_pwm); + /* next, set data direction registers */ + writeb(0x01, &gpiop->pddr_timer); + writeb(0x25, &gpiop->pddr_qspi); + writeb(0x0c, &gpiop->pddr_uart); + writeb(0x04, &gpiop->pddr_pwm); + + /* ensure other SPI peripherals are deselected */ + writeb(0x08, &gpiop->ppd_uart); + writeb(0x38, &gpiop->ppd_qspi); + writeb(0x01, &gpiop->ppd_timer); + + /* CONFIG = 0, STATUS = 0 -> FPGA in reset state */ + writeb(0xFB, &gpiop->pclrr_uart); + /* enable Xilinx configuration by clearing QSPI_CS2 and U0CTS */ + writeb(0xF7, &gpiop->pclrr_uart); + writeb(0xDF, &gpiop->pclrr_qspi); + return 0; +} + +/* + * FPGA post configuration function. Should perform a test if FPGA is running... + */ +int xilinx_post_config_fn (int cookie) +{ + int rc = 0; + + /* + * no test yet + */ + return rc; +} + +int xilinx_clk_fn (int assert_clk, int flush, int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + if (assert_clk) + writeb(0x04, &gpiop->ppd_qspi); + else + writeb(0xFB, &gpiop->pclrr_qspi); + return assert_clk; +} + +int xilinx_wr_fn (int assert_write, int flush, int cookie) +{ + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + + if (assert_write) + writeb(0x01, &gpiop->ppd_qspi); + else + writeb(0xFE, &gpiop->pclrr_qspi); + return assert_write; +} + +int xilinx_fastwr_fn (void *buf, size_t len, int flush, int cookie) +{ + size_t bytecount = 0; + volatile gpio_t *gpiop = (volatile gpio_t *)MMAP_GPIO; + unsigned char *data = (unsigned char *)buf; + unsigned char val = 0; + int i; + int len_40 = len / 40; + + for (bytecount = 0; bytecount < len; bytecount++) { + val = *(data++); + for (i = 8; i > 0; i--) { + writeb(0xFB, &gpiop->pclrr_qspi); + if (val & 0x80) + writeb(0x01, &gpiop->ppd_qspi); + else + writeb(0xFE, &gpiop->pclrr_qspi); + writeb(0x04, &gpiop->ppd_qspi); + val <<= 1; + } + if (bytecount % len_40 == 0) { +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET (); +#endif +#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK + putc ('.'); /* let them know we are alive */ +#endif +#ifdef CONFIG_SYS_FPGA_CHECK_CTRLC + if (ctrlc ()) + return FPGA_FAIL; +#endif + } + } + return FPGA_SUCCESS; +} + +/* Note that these are pointers to code that is in Flash. They will be + * relocated at runtime. + * FIXME: relocation not yet working for coldfire, see below! + */ +Xilinx_Spartan3_Slave_Serial_fns xilinx_fns = { + xilinx_pre_config_fn, + xilinx_pgm_fn, + xilinx_clk_fn, + xilinx_init_fn, + xilinx_done_fn, + xilinx_wr_fn, + 0, + xilinx_fastwr_fn +}; + +Xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { + {Xilinx_Spartan3, + slave_serial, + XILINX_XC3S4000_SIZE, + (void *)&xilinx_fns, + 0} +}; + +/* + * Initialize the fpga. Return 1 on success, 0 on failure. + */ +int astro5373l_xilinx_load (void) +{ + int i; + + fpga_init (); + + for (i = 0; i < CONFIG_FPGA_COUNT; i++) { + /* I did not yet manage to get relocation work properly, + * so set stuff here instead of static initialisation: + */ + xilinx_fns.pre = xilinx_pre_config_fn; + xilinx_fns.pgm = xilinx_pgm_fn; + xilinx_fns.clk = xilinx_clk_fn; + xilinx_fns.init = xilinx_init_fn; + xilinx_fns.done = xilinx_done_fn; + xilinx_fns.wr = xilinx_wr_fn; + xilinx_fns.bwr = xilinx_fastwr_fn; + xilinx_fpga[i].iface_fns = (void *)&xilinx_fns; + fpga_add (fpga_xilinx, &xilinx_fpga[i]); + } + return 1; +} diff --git a/board/astro/mcf5373l/mcf5373l.c b/board/astro/mcf5373l/mcf5373l.c new file mode 100644 index 0000000..ca46165 --- /dev/null +++ b/board/astro/mcf5373l/mcf5373l.c @@ -0,0 +1,209 @@ +/* + * (C) Copyright 2000-2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * modified by Wolfgang Wegner w.wegner@astro-kom.de for ASTRO 5373l + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <watchdog.h> +#include <command.h> +#include <asm/m5329.h> +#include <asm/immap_5329.h> +#include <asm/io.h> + +/* needed for astro bus: */ +#include <asm/uart.h> +#include "astro.h" + +DECLARE_GLOBAL_DATA_PTR; +extern void uart_port_conf (void); + +extern int astro5373l_altera_load (void); +extern int astro5373l_xilinx_load (void); + +int checkboard (void) +{ + puts ("Board: "); + puts ("ASTRO MCF5373L (Urmel) Board\n"); + return 0; +} + +phys_size_t initdram (int board_type) +{ +#if !defined(CONFIG_MONITOR_IS_IN_RAM) + volatile sdram_t *sdp = (volatile sdram_t *)(MMAP_SDRAM); + + /* GPIO configuration for bus should be set correctly from reset, + * so we do not care! First, set up address space: at this point, + * we should be running from internal SRAM; + * so use CONFIG_SYS_SDRAM_BASE as the base address for SDRAM, + * and do not care where it is + */ + __raw_writel((CONFIG_SYS_SDRAM_BASE & 0xFFF00000) | 0x00000018, + &sdp->cs0); + __raw_writel((CONFIG_SYS_SDRAM_BASE & 0xFFF00000) | 0x00000000, + &sdp->cs1); + /* I am not sure from the data sheet, but it seems burst length + * has to be 8 for the 16 bit data bus we use; + * so these values are for BL = 8 + */ + __raw_writel(0x33211530, &sdp->cfg1); + __raw_writel(0x56570000, &sdp->cfg2); + /* send PrechargeALL, REF and IREF remain cleared! */ + __raw_writel(0xE1462C02, &sdp->ctrl); + udelay (1); + /* refresh SDRAM twice */ + __raw_writel(0xE1462C04, &sdp->ctrl); + udelay (1); + __raw_writel(0xE1462C04, &sdp->ctrl); + /* init MR */ + __raw_writel(0x008D0000, &sdp->mode); + /* initialize EMR */ + __raw_writel(0x80010000, &sdp->mode); + /* wait until DLL is locked */ + udelay (1); + /* enable automatic refresh, lock mode register, + * clear iref and ipall + */ + __raw_writel(0x71462C00, &sdp->ctrl); + /* Dummy write to start SDRAM */ + writel(0, CONFIG_SYS_SDRAM_BASE); +#endif + + /* for get_ram_size() to work, both CS areas have to be + * configured, i.e. CS1 has to be explicitely disabled, else + * probing for memory will cause the SDRAM bus to hang! + * (Do not rely on the SDCS register(s) being set to 0x00000000 + * during reset as stated in the data sheet.) + */ + return get_ram_size((unsigned long *)CONFIG_SYS_SDRAM_BASE, + 0x80000000 - CONFIG_SYS_SDRAM_BASE); +} + +#define UART_BASE MMAP_UART0 +int rs_serial_init (int port, int baud) +{ + volatile uart_t *uart; + u32 counter; + + switch (port) { + case 0: + uart = (volatile uart_t *)(MMAP_UART0); + break; + case 1: + uart = (volatile uart_t *)(MMAP_UART1); + break; + case 2: + uart = (volatile uart_t *)(MMAP_UART2); + break; + default: + uart = (volatile uart_t *)(MMAP_UART0); + } + + uart_port_conf (); + + /* write to SICR: SIM2 = uart mode,dcd does not affect rx */ + writeb(UART_UCR_RESET_RX, &uart->ucr); + writeb(UART_UCR_RESET_TX, &uart->ucr); + writeb(UART_UCR_RESET_ERROR, &uart->ucr); + writeb(UART_UCR_RESET_MR, &uart->ucr); + __asm__ ("nop"); + + writeb(0, &uart->uimr); + + /* write to CSR: RX/TX baud rate from timers */ + writeb(UART_UCSR_RCS_SYS_CLK | UART_UCSR_TCS_SYS_CLK, &uart->ucsr); + + writeb(UART_UMR_BC_8 | UART_UMR_PM_NONE, &uart->umr); + writeb(UART_UMR_SB_STOP_BITS_1, &uart->umr); + + /* Setting up BaudRate */ + counter = (u32) (gd->bus_clk / (baud)); + counter >>= 5; + + /* write to CTUR: divide counter upper byte */ + writeb((u8) ((counter & 0xff00) >> 8), &uart->ubg1); + /* write to CTLR: divide counter lower byte */ + writeb((u8) (counter & 0x00ff), &uart->ubg2); + + writeb(UART_UCR_RX_ENABLED | UART_UCR_TX_ENABLED, &uart->ucr); + + return (0); +} + +void astro_put_char (char ch) +{ + volatile uart_t *uart; + unsigned long timer; + + uart = (volatile uart_t *)(MMAP_UART0); + /* Wait for last character to go. Timeout of 6ms should + * be enough for our lowest baud rate of 2400. + */ + timer = get_timer(0); + while (get_timer(timer) < 6) { + if (readb(&uart->usr) & UART_USR_TXRDY) + break; + } + writeb(ch, &uart->utb); + + return; +} + +int astro_is_char (void) +{ + volatile uart_t *uart; + + uart = (volatile uart_t *)(MMAP_UART0); + return (readb(&uart->usr) & UART_USR_RXRDY); +} + +int astro_get_char (void) +{ + volatile uart_t *uart; + + uart = (volatile uart_t *)(MMAP_UART0); + while (!(readb(&uart->usr) & UART_USR_RXRDY)) ; + return readb(&uart->urb); +} + +int misc_init_r (void) +{ + int retval = 0; + + puts ("Configure Xilinx FPGA..."); + retval = astro5373l_xilinx_load (); + if (!retval) { + puts ("failed!\n"); + return retval; + } + puts ("done\n"); + + puts ("Configure Altera FPGA..."); + retval = astro5373l_altera_load (); + if (!retval) { + puts ("failed!\n"); + return retval; + } + puts ("done\n"); + + return retval; +} diff --git a/board/astro/mcf5373l/u-boot.lds b/board/astro/mcf5373l/u-boot.lds new file mode 100644 index 0000000..a9a4e0a --- /dev/null +++ b/board/astro/mcf5373l/u-boot.lds @@ -0,0 +1,142 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(m68k) +/* Do we need any of these for elf? + __DYNAMIC = 0; */ +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + cpu/mcf532x/start.o (.text) + lib_m68k/traps.o (.text) + lib_m68k/interrupts.o (.text) + common/dlmalloc.o (.text) + lib_generic/zlib.o (.text) + + . = DEFINED(env_offset) ? env_offset : .; + common/env_embedded.o (.text) + + *(.text) +/* *(.fixup)*/ + *(.got1) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + + .reloc : + { + __got_start = .; + *(.got) + __got_end = .; + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss : + { + _sbss = .; + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + . = ALIGN(4); + _ebss = .; + } + _end = . ; + PROVIDE (end = .); +} diff --git a/board/astro/mcf5373l/update.c b/board/astro/mcf5373l/update.c new file mode 100644 index 0000000..a5b10cd --- /dev/null +++ b/board/astro/mcf5373l/update.c @@ -0,0 +1,625 @@ +/* + * (C) Copyright 2006-2009 + * Adnan El-Bardawil a.el-bardawil@astro-kom.de + * Wolfgang Wegner w.wegner@astro-kom.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <watchdog.h> +#include <command.h> +#include <asm/m5329.h> +#include <asm/immap_5329.h> +#include <asm/io.h> +#include <flash.h> +#include "astro.h" + +#include <asm/uart.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define DEBUG_INFO 1 +#define DEBUG_ERROR 1 + +/* dummy software version to signal card is in boot loader */ +#define SOFTWARE_VERSION 0x00 +#define SOFTWARE_SUBVERSION ' ' + +typedef enum { + CMD_INIT = 0, + CMD_NEW, + CMD_TX, + CMD_RX, + CMD_RX_RDY, + CMD_RX_ERROR +} cmd_stat_e; + +#define INT_CMD_IDLE 0 +#define INT_CMD_FLASH_MODE 1 +#define INT_CMD_WRITE_FLASH 2 +#define INT_CMD_RESTART 4 + +#define FL_STAT_IDLE 0 +#define FL_STAT_ERASE 1 +#define FL_STAT_PROG 2 +#define FL_STAT_ERROR 4 + +/*----------------------------------------------------------------------- + * UART update subcommand codes + */ + +#define F_SAVE_PARAMETERS 0x00 /* save parameters on card */ +#define F_READ_PARAMETERS 0x01 /* read parameters */ +#define F_READ_CARDINFO 0x10 /* read card information */ +#define F_READ_ERROR_STATUS 0x11 /* read card error */ +#define F_TRANSPARENT_DATA 0x20 /* length byte + data */ + +#define SC_PREPARE_FOR_FLASH_DATA 0xc0 +#define SC_FLASH_DATA 0xc1 +#define SC_CLEAR_CRC 0xc2 +#define SC_CHECK_CRC 0xc3 +#define SC_RESTART 0xc4 + +typedef struct { + unsigned char command; + unsigned char length; + unsigned char subcommand; +} rcv_cmd_t; + +card_id_t card_information; + +struct { + parameters_t a; + parameters_t b; +} parameters; + +typedef struct { + int cnt; + cmd_stat_e stat; +} upd_command_t; + +typedef struct { + int cnt; + int length; + unsigned char *buffer; +} comm_status_t; + +const unsigned long fl_base[3] = { 0x80000, 0x540000, 0x6c0000 }; +const char fl_type_str[3][6] = { "Kernel", "Xilinx", "Altera" }; + +/* info for FLASH chips */ +extern flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; + +unsigned long crc, crc_count; + +/* CRC divisor value */ +#define CRC_POLYNOM 0x800500 + +void do_crc(unsigned char data) +{ + unsigned char count; + + crc |= data; + for (count = 0; count < 8; count++) { + crc <<= 1; + if (crc & 0x1000000) + crc ^= CRC_POLYNOM; + } + crc_count++; +} + +static unsigned char flash_buffer[0x10000]; +static unsigned long flash_data_length, flash_data_count; +static unsigned long flash_prog_count, flash_sect_count; +static unsigned char flash_data_type, crc_en; +static int flash_prog_stat; +static unsigned char uart_buffer[64]; + +void fl_prog(int force_write) +{ + int s, i; + unsigned long fl_adr, fl_sector; + + fl_adr = fl_base[flash_data_type] + flash_prog_count; + fl_sector = fl_adr >> 17; + + switch(flash_prog_stat) { + case FL_STAT_IDLE: + if (((flash_prog_count & 0x1ffff) == 0) && + ((flash_prog_count >> 17) == flash_sect_count)) { + flash_protect(FLAG_PROTECT_CLEAR, fl_adr, + fl_adr + 0x1ffff, flash_info); + s = flash_erase_nb(flash_info, fl_sector); + flash_prog_stat = FL_STAT_ERASE; + } else if ((flash_data_count >= (flash_prog_count + 64)) + || (force_write + && (flash_data_count > flash_prog_count))) { + s = write_buff_nb(flash_info, + flash_buffer + + (flash_prog_count & 0xffff), + fl_adr, 64); + flash_prog_stat = FL_STAT_PROG; + } + break; + case FL_STAT_ERASE: + s = flash_full_status_check_nb(flash_info, fl_sector, + 0, "erase"); + if (s != ERR_BUSY) { + if (s == ERR_OK) { + flash_sect_count++; + flash_prog_stat = FL_STAT_IDLE; + } else { + flash_prog_stat = FL_STAT_ERROR; + } + } + break; + case FL_STAT_PROG: + s = flash_full_status_check_nb(flash_info, fl_sector, + 0, "write"); + if (s == ERR_BUSY) + return; + + if (s != ERR_OK) { + flash_prog_stat = FL_STAT_ERROR; + return; + } + + flash_prog_stat = FL_STAT_IDLE; + for (i = 0; i < 64; i++) { + if (flash_buffer[(flash_prog_count + i) & 0xffff] != + *((unsigned char *)fl_adr + i)) + flash_prog_stat = FL_STAT_ERROR; + } + if ((flash_prog_count & 0xfff) == 0) + printf("."); + flash_prog_count += 64; + if (((flash_prog_count & 0x1ffff) == 0) + || (force_write + && (flash_data_count <= flash_prog_count))) { + flash_protect(FLAG_PROTECT_SET, + fl_adr & 0xfffe0000, + fl_adr | 0x1ffff, + flash_info); + } + break; + } +} + +void handle_rx_char(unsigned char rx_data, upd_command_t *cmd, + int *rcv_cnt, rcv_cmd_t *rcv_cmd, + comm_status_t *rx_stat) +{ + volatile uart_t *uart; + + uart = (volatile uart_t *)(MMAP_UART0); + if (readb(&uart->usr) & UART_USR_OE) { +#if DEBUG_ERROR + printf("UART FIFO Overrun Error!\n"); +#endif + writeb(UART_UCR_RESET_ERROR, &uart->ucr); + cmd->stat = CMD_RX_ERROR; + } + if (cmd->stat == CMD_INIT) { + if (*rcv_cnt == 0) { + /* First received Byte is the Command */ + rcv_cmd->command = rx_data; + /* non-Transparent Data: start Command Processing */ + if (rcv_cmd->command != F_TRANSPARENT_DATA) { + cmd->stat = CMD_NEW; + cmd->cnt++; + } else { + (*rcv_cnt)++; + } + } else { + /* Length and Subcommand for Transparent Data */ + if (*rcv_cnt == 1) { + rcv_cmd->length = rx_data; + (*rcv_cnt)++; + } else { + rcv_cmd->subcommand = rx_data; + cmd->stat = CMD_NEW; + cmd->cnt++; + } + } + } else if (cmd->stat == CMD_RX) { + /* Store received Data to Rx Buffer */ + rx_stat->buffer[rx_stat->cnt] = rx_data; + if (crc_en) + do_crc(rx_data); + (rx_stat->cnt)++; + if (rx_stat->cnt == rx_stat->length) + cmd->stat = CMD_RX_RDY; + } +} + +/* handle a transparent data command; these are used for software update + * return value is 1 if cmd_stat is set to CMD_INIT to let caller decide + * to reset the receive count, else 0. + */ +int handle_transparent_command(upd_command_t *cmd, rcv_cmd_t *rcv_cmd, + comm_status_t *rx_stat, comm_status_t *tx_stat, + unsigned char *int_command) +{ + int i; + unsigned char crc_status; + + if (cmd->stat == CMD_NEW) { + rx_stat->cnt = 0; + rx_stat->length = rcv_cmd->length - 1; + } + switch (rcv_cmd->subcommand) { + case SC_PREPARE_FOR_FLASH_DATA: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = uart_buffer; + cmd->stat = CMD_RX; + } else if (cmd->stat == CMD_RX_RDY) { + for (i = 0; i < 4; i++) + flash_data_length = (flash_data_length << 8) + + uart_buffer[i + 1]; + flash_data_type = uart_buffer[0]; +#if DEBUG_INFO + printf(" -- Flash Programming Initialized -- \n"); + printf(" -- Receiving %lu Bytes of type ", + flash_data_length); + for (i = 0; i < 6; i++) + printf("%c", fl_type_str[flash_data_type][i]); + printf(" [0x%lx]\n", fl_base[flash_data_type]); +#endif + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + crc_count = 0; + crc = 0; + flash_data_count = 0; + flash_prog_count = 0; + flash_sect_count = 0; + flash_prog_stat = FL_STAT_IDLE; + crc_en = 0; + *int_command = INT_CMD_FLASH_MODE; + cmd->stat = CMD_TX; + return 1; + } + break; + case SC_FLASH_DATA: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = flash_buffer + + (flash_data_count & 0xffff); + rx_stat->cnt = 0; + cmd->stat = CMD_RX; + crc_en = 1; + } else if (cmd->stat == CMD_RX_RDY) { + crc_en = 0; + flash_data_count += rcv_cmd->length - 1; + cmd->stat = CMD_INIT; + return 1; + } + break; + case SC_CLEAR_CRC: + if (cmd->stat == CMD_NEW) { + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + cmd->stat = CMD_TX; + crc_count = 0; + crc = 0; + } + break; + case SC_CHECK_CRC: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = uart_buffer; + cmd->stat = CMD_RX; + } else if (cmd->stat == CMD_RX_RDY) { + if ((flash_data_count <= flash_prog_count) + || (flash_prog_stat == FL_STAT_ERROR)) { + crc_status = 0; + if (uart_buffer[0] != ((crc >> 16) & 0xff)) + crc_status = 1; + if (uart_buffer[1] != ((crc >> 8) & 0xff)) + crc_status = 1; + if (flash_prog_stat == FL_STAT_ERROR) + crc_status |= 2; + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 4; + uart_buffer[2] = rcv_cmd->subcommand; + uart_buffer[3] = (crc >> 16); + uart_buffer[4] = (crc >> 8); + uart_buffer[5] = crc_status; +#if DEBUG_INFO + printf(" CRC %u / %lu of %lu kB \n", + crc_status, + (flash_data_count >> 10), + (flash_data_length >> 10)); +#endif + tx_stat->buffer = uart_buffer; + tx_stat->length = 6; + cmd->stat = CMD_TX; + if (crc_status) { + flash_prog_count = + flash_data_count = + (flash_data_count & 0xffff0000) + - 0x10000; + flash_prog_stat = FL_STAT_IDLE; + *int_command = INT_CMD_FLASH_MODE; + } + } + if (flash_data_count & 0xffff) + *int_command |= INT_CMD_WRITE_FLASH; + } + break; + case SC_RESTART: + if (cmd->stat == CMD_NEW) { + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + cmd->stat = CMD_TX; + crc_count = 0; + crc = 0; + /* set restart command; sending the reply + * is done before finishing the loop. + */ + *int_command = INT_CMD_RESTART; + return 1; + } + break; + default: + /* for un-handled zero length transparent command, + * we have to handle this condition first! + */ + if ((cmd->stat == CMD_RX_RDY) + || (rx_stat->cnt == rx_stat->length)) + cmd->stat = CMD_INIT; + else if (cmd->stat == CMD_NEW) + cmd->stat = CMD_RX; + } + return 0; +} + +/* handle a general command (i.e. status and version information query) + * return value is always 0 except for transparent data where the + * return code is passed through to allow caller reset receive count. + */ +int handle_command(upd_command_t *cmd, rcv_cmd_t *rcv_cmd, + comm_status_t *rx_stat, comm_status_t *tx_stat, + unsigned char *int_command) +{ + int rv = 0; + + switch (rcv_cmd->command) { + case F_READ_ERROR_STATUS: +#if DEBUG_INFO + printf("read error status\n"); +#endif + uart_buffer[0] = 0; + uart_buffer[1] = 0; + uart_buffer[2] = 0; + uart_buffer[3] = 0; + tx_stat->buffer = uart_buffer; + tx_stat->length = 4; + cmd->stat = CMD_TX; + break; + case F_READ_PARAMETERS: + if (cmd->stat == CMD_NEW) { +#if DEBUG_INFO + printf("read parameters\n"); +#endif + memcpy(uart_buffer, (unsigned char *)¶meters.a, + 2 * sizeof(parameters_t)); + cmd->stat = CMD_TX; + tx_stat->length = 2 * sizeof(parameters_t); + } + break; + case F_READ_CARDINFO: +#if DEBUG_INFO + printf("read card info\n"); +#endif + card_information.software_version = + ((*int_command) & INT_CMD_FLASH_MODE) ? + 0xEE : SOFTWARE_VERSION; + tx_stat->buffer = (unsigned char *)&card_information; + tx_stat->length = 5; + cmd->stat = CMD_TX; + break; + + case F_TRANSPARENT_DATA: + rv = handle_transparent_command(cmd, rcv_cmd, rx_stat, + tx_stat, int_command); + break; + } + return rv; +} + +/* transmit data prepared in comm_status_t structure */ +void transmit_buffer(comm_status_t *tx_stat) +{ + int cnt; + for (cnt = 0; cnt < tx_stat->length; cnt++) + astro_put_char(tx_stat->buffer[cnt]); +} + +int do_update(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) +{ + unsigned char rx_data; + comm_status_t rx_stat, tx_stat; + upd_command_t cmd; + int rcv_cnt; + rcv_cmd_t rcv_cmd; + unsigned char int_command, tmp_char; + unsigned short tmp_short; + + int select, old_select, got_char; + volatile eport_t *eport = (volatile eport_t *)MMAP_EPORT; + volatile gpio_t *gpio = (volatile gpio_t *)MMAP_GPIO; + volatile uart_t *uart = (volatile uart_t *)MMAP_UART0; + char *env_string; + + cmd.cnt = 0; + + /* we set some dummy parameters to make the protocol work */ + card_information.card_type = ASTRO_ID; + env_string = getenv("loaderversion"); + if (env_string != NULL) { + card_information.hardware_version = + (int)simple_strtol(env_string, NULL, 16); + } else { + card_information.hardware_version = 0x10; + } + card_information.software_version = SOFTWARE_VERSION; + card_information.software_subversion = SOFTWARE_SUBVERSION; + card_information.fpga_version_altera = 0x12; + card_information.fpga_version_xilinx = 0x13; + + parameters.a.symbolrate = 0x5027; + parameters.a.viterbirate = 0x34; + parameters.a.satfreq = 0x6616; + parameters.a.card_error = 0; + + parameters.b.symbolrate = 0x5027; + parameters.b.viterbirate = 0x34; + parameters.b.satfreq = 0x6616; + parameters.b.card_error = 0; + + puts("Initializing serial port to ASTRO bus...\n"); + /* init serial port */ + rs_serial_init(0, 2400); + /* set UART pin for UART */ + tmp_short = __raw_readw(&gpio->par_uart); + tmp_short |= 0x0003; + __raw_writew(tmp_short, &gpio->par_uart); + /* set select pin as GPIO */ + tmp_short = __raw_readw(&gpio->par_irq); + tmp_short &= 0x0FF0; + __raw_writew(tmp_short, &gpio->par_irq); + /* set select pin as input */ + tmp_char = readb(&eport->pdr); + tmp_char &= 0xBF; + writeb(tmp_char, &eport->pdr); + /* set interrupt to both falling and rising edge + * (no IRQ used, though) + */ + tmp_short = __raw_readw(&eport->par); + tmp_short |= 0x3000; + __raw_writew(tmp_short, &eport->par); + + int_command = INT_CMD_IDLE; + + rcv_cnt = 0; + cmd.stat = CMD_INIT; + old_select = 0; /* always start from "deselected" state */ + rx_data = 0xFF; + + while (int_command != INT_CMD_RESTART) { + +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET(); +#endif + + /***************************************** + ** Flash program routine ** + ** only called in flash mode ** + ***************************************** + */ + if (int_command & INT_CMD_FLASH_MODE) + fl_prog(int_command & INT_CMD_WRITE_FLASH); + + /***************************************** + ** UART Card Select Routine ** + ***************************************** + */ + + /* Write ID on Card Select */ + select = ((readb(&eport->pdr) & 0x40) == 0x0); + + if ((select) && (!old_select)) { + /* set low baud rate for ID only */ + rs_serial_init(0, 2400); + astro_put_char(ASTRO_ID); + + /* Wait for TX finished before switching baudrate */ + while ((readb(&uart->usr) & UART_USR_TXEMP) == 0) { + } + + /* set high baud rate */ + rs_serial_init(0, 115200); + /* Reset the Receive Byte Counter */ + rcv_cnt = 0; + cmd.stat = CMD_INIT; + } else if ((!select) && old_select && (cmd.stat != CMD_INIT)) { + cmd.stat = CMD_INIT; +#if DEBUG_ERROR + printf("Command %u: 0x%02x (0x%02x) failed," + " len %d, cnt %d\n", + cmd.cnt, rcv_cmd.command, + rcv_cmd.subcommand, rcv_cmd.length, + rx_stat.cnt); +#endif + } + + old_select = select; + + got_char = astro_is_char(); + if (got_char) + rx_data = astro_get_char(); + + if (select) { + /***************************************** + ** UART RX Routine ** + ***************************************** + */ + if (got_char) + handle_rx_char(rx_data, &cmd, &rcv_cnt, + &rcv_cmd, &rx_stat); + + /***************************************** + ** Command Control Routine ** + ***************************************** + */ + if ((cmd.stat == CMD_NEW) + || (cmd.stat == CMD_RX_RDY)) { + if (handle_command(&cmd, &rcv_cmd, + &rx_stat, &tx_stat, + &int_command)) + rcv_cnt = 0; + } + + /***************************************** + ** UART TX Routine ** + ***************************************** + */ + if (cmd.stat == CMD_TX) { + transmit_buffer(&tx_stat); + /* Reset the Receive Byte Counter */ + rcv_cnt = 0; + cmd.stat = CMD_INIT; + } + } + } + /* restart is done outside, so we simply leave this function */ + return 0; +} + +U_BOOT_CMD(update, 1, 1, do_update, + "automatic update via ASTRO bus", + "\n - start the update, waiting for transfer via bus"); diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h new file mode 100644 index 0000000..a3451e1 --- /dev/null +++ b/include/configs/astro_mcf5373l.h @@ -0,0 +1,427 @@ +/* + * Configuration settings for the Sentec Cobra Board. + * + * (C) Copyright 2003 Josef Baumgartner josef.baumgartner@telex.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* configuration for ASTRO "Urmel" board. + * Originating from Cobra5272 configuration, messed up by + * Wolfgang Wegner w.wegner@astro-kom.de + * Please do not bother the original author with bug reports + * concerning this file. + */ + +/* --- + * board/config.h - configuration options, board specific + * --- + */ + +#ifndef _CONFIG_ASTRO_MCF5373L_H +#define _CONFIG_ASTRO_MCF5373L_H + +/* set the card type to actually compile for; either of + * the possibilities listed below has to be used! + */ +#define CONFIG_ASTRO_V532 1 + +#if CONFIG_ASTRO_V532 +#define ASTRO_ID 0xF8 +#elif CONFIG_ASTRO_V512 +#define ASTRO_ID 0xFA +#elif CONFIG_ASTRO_TWIN7S2 +#define ASTRO_ID 0xF9 +#elif CONFIG_ASTRO_V912 +#define ASTRO_ID 0xFC +#elif CONFIG_ASTRO_COFDMDUOS2 +#define ASTRO_ID 0xFB +#else +#error No card type defined! +#endif + +/* --- + * Define processor + * possible values for Urmel board: only Coldfire M5373 processor supported + * (please do not change) + * --- + */ + +/* it seems not clear yet which processor defines we should use */ +#define CONFIG_MCF537x /* define processor family */ +#define CONFIG_MCF532x /* define processor family */ +#define CONFIG_M5373 /* define processor type */ +#define CONFIG_ASTRO5373L /* define board type */ + +/* Command line configuration */ +#include <config_cmd_default.h> + +/* --- + * CONFIG_MK_RAM defines if u-boot is loaded via BDM (or started from + * a different bootloader that has already performed RAM setup) or + * started directly from flash, which is the regular case for production + * boards. + * --- + */ +#ifdef CONFIG_MK_RAM +#define CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_TEXT_BASE 0x40020000 +#define ENABLE_JFFS 0 +#else +#define CONFIG_TEXT_BASE 0x00000000 +#define ENABLE_JFFS 1 +#endif + +/* --- + * Define which commmands should be available at u-boot command prompt + * --- + */ + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DATE +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_MISC +#define CONFIG_CMD_XIMG +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#if ENABLE_JFFS +#define CONFIG_CMD_JFFS2 +#endif +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_LOADB +#define CONFIG_CMD_FPGA +#define CONFIG_CMDLINE_EDITING + +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_MCFRTC +#undef RTC_DEBUG + +/* Timer */ +#define CONFIG_MCFTMR +#undef CONFIG_MCFPIT + +/* I2C */ +#define CONFIG_FSL_I2C +#define CONFIG_HARD_I2C /* I2C with hw support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_SYS_I2C_SPEED 80000 +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_OFFSET 0x58000 +#define CONFIG_SYS_IMMR CONFIG_SYS_MBAR + +/* --- + * Defines processor clock - important for correct timings concerning serial + * interface etc. + * CONFIG_SYS_HZ gives unit: 1000 -> 1 Hz ^= 1000 ms + * --- + */ + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_CLK 80000000 +#define CONFIG_SYS_CPU_CLK CONFIG_SYS_CLK * 3 +#define CONFIG_SYS_SDRAM_SIZE 32 /* SDRAM size in MB */ + +#define CONFIG_SYS_CORE_SRAM_SIZE 0x8000 +#define CONFIG_SYS_CORE_SRAM 0x80000000 + +#define CONFIG_SYS_UNIFY_CACHE + +/* --- + * Define baudrate for UART1 (console output, tftp, ...) + * default value of CONFIG_BAUDRATE for Sentec board: 19200 baud + * CONFIG_SYS_BAUDRATE_TABLE defines values that can be selected + * in u-boot command interface + * --- + */ + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600 , 19200 , 38400 , 57600, 115200 } + +#define CONFIG_MCFUART +#define CONFIG_SYS_UART_PORT (2) +#define CONFIG_SYS_UART2_ALT3_GPIO + +/* --- + * Watchdog configuration; Watchdog is disabled for running from RAM + * and set to highest possible value else. Beware there is no check + * in the watchdog code to validate the timeout value set here! + * --- + */ + +#ifndef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_WATCHDOG +#define CONFIG_WATCHDOG_TIMEOUT 3355 /* timeout in milliseconds */ +#endif + +/* --- + * Configuration for environment + * Environment is embedded in u-boot in the second sector of the flash + * --- + */ + +#ifndef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_ENV_OFFSET 0x1FF8000 +#define CONFIG_ENV_SECT_SIZE 0x8000 +#define CONFIG_ENV_IS_IN_FLASH 1 +#else +/* environment in RAM - This is used to use a single PC-based application + * to load an image, load U-Boot, load an environment and then start U-Boot + * to execute the commands from the environment. Feedback is done via setting + * and reading memory locations. + */ +#define CONFIG_ENV_ADDR 0x40060000 +#define CONFIG_ENV_SECT_SIZE 0x8000 +#define CONFIG_ENV_IS_IN_FLASH 1 +#endif + +/* here we put our FPGA configuration... */ +#define CONFIG_MISC_INIT_R 1 + +/* + *----------------------------------------------------------------------------- + * Define user parameters that have to be customized most likely + *----------------------------------------------------------------------------- + */ + +/* AUTOBOOT settings - booting images automatically by u-boot after power on */ + +/* used for autoboot, delay in seconds u-boot will wait before starting + * defined (auto-)boot command, setting to -1 disables delay, setting to + * 0 will too prevent access to u-boot command interface: u-boot then has + * to be reflashed + * beware - watchdog is not serviced during autoboot delay time! + */ +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_BOOTDELAY 1 +#else +#define CONFIG_BOOTDELAY 1 +#endif + +/* The following settings will be contained in the environment block ; if you + * want to use a neutral environment all those settings can be manually set in + * u-boot: 'set' command */ + +#define _QUOTEME(x) #x +#define QUOTEME(x) _QUOTEME(x) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loaderversion=11\0" \ + "card_id="QUOTEME(ASTRO_ID)"\0" \ + "alterafile=0\0" \ + "xilinxfile=0\0" \ + "xilinxload=imxtract 0x540000 $xilinxfile 0x41000000&&"\ + "fpga load 0 0x41000000 $filesize\0" \ + "alteraload=imxtract 0x6c0000 $alterafile 0x41000000&&"\ + "fpga load 1 0x41000000 $filesize\0" \ + "env_default=1\0" \ + "env_check=if test $env_default -eq 1;"\ + " then setenv env_default 0;saveenv;fi\0" + +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_BOOTCOMMAND "" /* no autoboot in this case */ +#else +#if CONFIG_ASTRO_V532 +#define CONFIG_BOOTCOMMAND "protect off 0x80000 0x1ffffff;run env_check;"\ + "run xilinxload&&run alteraload&&bootm 0x80000;"\ + "update;reset" +#else +#define CONFIG_BOOTCOMMAND "protect off 0x80000 0x1ffffff;run env_check;"\ + "run xilinxload&&bootm 0x80000;update;reset" +#endif +#endif + +/* default bootargs that are considered during boot */ +#define CONFIG_BOOTARGS " console=ttyS2,115200 rootfstype=romfs"\ + " loaderversion=$loaderversion" + +#define CONFIG_SYS_PROMPT "URMEL > " + +/* default RAM address for user programs */ +#define CONFIG_SYS_LOAD_ADDR 0x20000 + +/*---*/ + +#define CONFIG_SYS_LONGHELP + +#if (CONFIG_COMMANDS & CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 +#else +#define CONFIG_SYS_CBSIZE 256 +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_FPGA_COUNT 1 +#define CONFIG_FPGA +#define CONFIG_FPGA_XILINX +#define CONFIG_FPGA_SPARTAN3 +#define CONFIG_FPGA_ALTERA +#define CONFIG_FPGA_CYCLON2 +#define CONFIG_SYS_FPGA_PROG_FEEDBACK +#define CONFIG_SYS_FPGA_WAIT 1000 + +/* + *----------------------------------------------------------------------------- + * End of user parameters to be customized + *----------------------------------------------------------------------------- + */ + +/* --- + * Defines memory range for test + * --- + */ + +#define CONFIG_SYS_MEMTEST_START 0x40020000 +#define CONFIG_SYS_MEMTEST_END 0x41ffffff + +/* --- + * Low Level Configuration Settings + * (address mappings, register initial values, etc.) + * You should know what you are doing if you make changes here. + * --- + */ + +/* --- + * Base register address + * --- + */ + +#define CONFIG_SYS_MBAR 0xFC000000 /* Register Base Addrs */ + +/* --- + * System Conf. Reg. & System Protection Reg. + * --- + */ + +#define CONFIG_SYS_SCR 0x0003; +#define CONFIG_SYS_SPR 0xffff; + +/*----------------------------------------------------------------------- + * Definitions for initial stack pointer and data area (in internal SRAM) + */ +#define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 +#define CONFIG_SYS_INIT_RAM_END 0x8000 +#define CONFIG_SYS_INIT_RAM_CTRL 0x221 +#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ + CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +/*----------------------------------------------------------------------- + * Start addresses for the final memory configuration + * (Set up by the startup code) + * for MCF5373, the allowable range is 0x40000000 to 0x7FF00000 + */ +#define CONFIG_SYS_SDRAM_BASE 0x40000000 + +/*----------------------------------------------------------------------- + * Chipselect bank definitions + */ +/* + * CS0 - Flash 32MB (first 16MB) + * CS1 - Flash 32MB (second half) + * CS2 - FPGA + * CS3 - FPGA + * CS4 - unused + * CS5 - unused + */ +#define CONFIG_SYS_CS0_BASE 0 +#define CONFIG_SYS_CS0_MASK 0x00ff0001 +#define CONFIG_SYS_CS0_CTRL 0x00001fc0 + +#define CONFIG_SYS_CS1_BASE 0x01000000 +#define CONFIG_SYS_CS1_MASK 0x00ff0001 +#define CONFIG_SYS_CS1_CTRL 0x00001fc0 + +#define CONFIG_SYS_CS2_BASE 0x20000000 +#define CONFIG_SYS_CS2_MASK 0x00ff0001 +#define CONFIG_SYS_CS2_CTRL 0x0000fec0 + +#define CONFIG_SYS_CS3_BASE 0x21000000 +#define CONFIG_SYS_CS3_MASK 0x00ff0001 +#define CONFIG_SYS_CS3_CTRL 0x0000fec0 + +/* + *------------------------------------------------------------------------- + * RAM SIZE (is defined above) + *----------------------------------------------------------------------- + */ + +/* + *----------------------------------------------------------------------- + */ + +#define CONFIG_SYS_FLASH_BASE 0x00000000 + +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_SYS_MONITOR_BASE CONFIG_TEXT_BASE +#else +/* This is mainly used during relocation in start.S */ +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_FLASH_BASE + 0x400) +#endif +/* Reserve 256 kB for Monitor */ +#define CONFIG_SYS_MONITOR_LEN (256 << 10) + +#define CONFIG_SYS_BOOTPARAMS_LEN 64*1024 +/* Reserve 128 kB for malloc() */ +#define CONFIG_SYS_MALLOC_LEN (128 << 10) + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization ?? + */ +#define CONFIG_SYS_BOOTMAPSZ (CONFIG_SYS_SDRAM_BASE + \ + (CONFIG_SYS_SDRAM_SIZE << 20)) + +/*----------------------------------------------------------------------- + * FLASH organization + */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 259 +#define CONFIG_SYS_FLASH_ERASE_TOUT 1000 + +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_SIZE 0x2000000 +#define CONFIG_SYS_FLASH_PROTECTION 1 +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 +#define CONFIG_SYS_FLASH_CFI_NONBLOCK 1 + +#if ENABLE_JFFS +/* JFFS Partition offset set */ +#define CONFIG_SYS_JFFS2_FIRST_BANK 0 +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 +/* 512k reserved for u-boot */ +#define CONFIG_SYS_JFFS2_FIRST_SECTOR 0x40 +#endif + +/*----------------------------------------------------------------------- + * Cache Configuration + */ +#define CONFIG_SYS_CACHELINE_SIZE 16 + +#endif /* _CONFIG_ASTRO_MCF5373L_H */
This patch adds support for ASTRO board(s) based on MCF5373L.
Signed-off-by: Wolfgang Wegner w.wegner@astro-kom.de --- v2->v3: fixed another load of coding style issues after finding out about checkpatch.pl... I hope to have addressed all the comments and errors that were present in the first submission; exceptions are the linker script because there was no feedback by Tsi Chung Liew on this issue, the crc routine because the update protocol is fixed and uses this (as far as I can see) non-standard CRC polynomial, and a single 81 character line in the configuration file because I see no sensible way to break it. This patch (or the boot script/images) relies on the following previously sent patches: add include/asm-m68k/unaligned.h (Message-Id 1260376332-15835-1-git-send-email-w.wegner@astro-kom.de) non-blocking flash write/erase/status check functions (Message-Id 1260374411-11299-1-git-send-email-w.wegner@astro-kom.de) add ability to handle compressed images to imxtract (Message-Id 1260436281-31824-1-git-send-email-w.wegner@astro-kom.de) add block write function to spartan3 slave serial load (Message-Id 1256918102-3760-1-git-send-email-w.wegner@astro-kom.de) allow MCF532x to use CONFIG_MONITOR_IS_IN_RAM (Message-Id 1256739061-13311-2-git-send-email-w.wegner@astro-kom.de) MCF532x: make icache_enable use CONFIG_SYS_SDRAM_SIZE (Message-Id 1256739061-13311-1-git-send-email-w.wegner@astro-kom.de)
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 4 + board/astro/mcf5373l/Makefile | 44 +++ board/astro/mcf5373l/astro.h | 44 +++ board/astro/mcf5373l/config.mk | 27 ++ board/astro/mcf5373l/fpga.c | 431 ++++++++++++++++++++++++++ board/astro/mcf5373l/mcf5373l.c | 206 +++++++++++++ board/astro/mcf5373l/u-boot.lds | 142 +++++++++ board/astro/mcf5373l/update.c | 625 ++++++++++++++++++++++++++++++++++++++ include/configs/astro_mcf5373l.h | 427 ++++++++++++++++++++++++++ 11 files changed, 1955 insertions(+), 0 deletions(-) create mode 100644 board/astro/mcf5373l/Makefile create mode 100644 board/astro/mcf5373l/astro.h create mode 100644 board/astro/mcf5373l/config.mk create mode 100644 board/astro/mcf5373l/fpga.c create mode 100644 board/astro/mcf5373l/mcf5373l.c create mode 100644 board/astro/mcf5373l/u-boot.lds create mode 100644 board/astro/mcf5373l/update.c create mode 100644 include/configs/astro_mcf5373l.h
diff --git a/board/astro/mcf5373l/Makefile b/board/astro/mcf5373l/Makefile new file mode 100644 index 0000000..e0b1bc6 --- /dev/null +++ b/board/astro/mcf5373l/Makefile @@ -0,0 +1,44 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS = $(BOARD).o fpga.o update.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/astro/mcf5373l/astro.h b/board/astro/mcf5373l/astro.h new file mode 100644 index 0000000..b55a6f7 --- /dev/null +++ b/board/astro/mcf5373l/astro.h @@ -0,0 +1,44 @@ +#ifndef __ASTRO_H__ +#define __ASTRO_H__ + +/* in mcf5373l.c */ +int rs_serial_init(int port, int baud); +void astro_put_char(char ch); +int astro_is_char(void); +int astro_get_char(void); + +/* in fpga.c */ +int astro5373l_altera_load(void); +int astro5373l_xilinx_load(void); + +/* data structures used for communication (update.c) */ +typedef struct card_id { + char card_type; + char hardware_version; + char software_version; + char software_subversion; /* " ","a".."z" */ + char fpga_version_altera; + char fpga_version_xilinx; +} card_id_t; + +typedef struct { + unsigned char mode; + unsigned char deviation; + unsigned short freq; +} __attribute__ ((packed)) output_params_t; + +typedef struct { + unsigned short satfreq; + unsigned char satdatallg; + unsigned short symbolrate; + unsigned char viterbirate; + unsigned char symbolrate_l; + output_params_t output_params; + unsigned char reserve; + unsigned char card_error; + unsigned short dummy_ts_id; + unsigned char dummy_pat_ver; + unsigned char dummy_sdt_ver; +} __attribute__ ((packed)) parameters_t; + +#endif /* __ASTRO_H__ */ diff --git a/board/astro/mcf5373l/config.mk b/board/astro/mcf5373l/config.mk new file mode 100644 index 0000000..6316a30 --- /dev/null +++ b/board/astro/mcf5373l/config.mk @@ -0,0 +1,27 @@ +# +# (C) Copyright 2000-2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# Coldfire contribution by Bernhard Kuhn bkuhn@metrowerks.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +TEXT_BASE = $(CONFIG_TEXT_BASE) + +PLATFORM_CPPFLAGS += -DTEXT_BASE=$(TEXT_BASE) diff --git a/board/astro/mcf5373l/fpga.c b/board/astro/mcf5373l/fpga.c new file mode 100644 index 0000000..7c0fb38 --- /dev/null +++ b/board/astro/mcf5373l/fpga.c @@ -0,0 +1,431 @@ +/* + * (C) Copyright 2006 + * Wolfgang Wegner, ASTRO Strobel Kommunikationssysteme GmbH, + * w.wegner@astro-kom.de + * + * based on the files by + * Heiko Schocher, DENX Software Engineering, hs@denx.de + * and + * Rich Ireland, Enterasys Networks, rireland@enterasys.com. + * Keith Outwater, keith_outwater@mvis.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +/* + * Altera/Xilinx FPGA configuration support for the ASTRO "URMEL" board + */ + +#include <common.h> +#include <watchdog.h> +#include <altera.h> +#include <ACEX1K.h> +#include <spartan3.h> +#include <command.h> +#include <asm/immap_5329.h> +#include <asm/io.h> +#include "fpga.h" + +DECLARE_GLOBAL_DATA_PTR; + +int altera_pre_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + unsigned char tmp_char; + unsigned short tmp_short; + + /* first, set the required pins to GPIO function */ + /* PAR_T0IN -> GPIO */ + tmp_char = readb(&gpiop->par_timer); + tmp_char &= 0xfc; + writeb(tmp_char, &gpiop->par_timer); + /* all QSPI pins -> GPIO */ + writew(0x0000, &gpiop->par_qspi); + /* U0RTS, U0CTS -> GPIO */ + tmp_short = __raw_readw(&gpiop->par_uart); + tmp_short &= 0xfff3; + __raw_writew(tmp_short, &gpiop->par_uart); + /* all PWM pins -> GPIO */ + writeb(0x00, &gpiop->par_pwm); + /* next, set data direction registers */ + writeb(0x01, &gpiop->pddr_timer); + writeb(0x25, &gpiop->pddr_qspi); + writeb(0x0c, &gpiop->pddr_uart); + writeb(0x04, &gpiop->pddr_pwm); + + /* ensure other SPI peripherals are deselected */ + writeb(0x08, &gpiop->ppd_uart); + writeb(0x38, &gpiop->ppd_qspi); + + /* CONFIG = 0 STATUS = 0 -> FPGA in reset state */ + writeb(0xFB, &gpiop->pclrr_uart); + /* enable Altera configuration by clearing QSPI_CS2 and DT0IN */ + writeb(0xFE, &gpiop->pclrr_timer); + writeb(0xDF, &gpiop->pclrr_qspi); + return FPGA_SUCCESS; +} + +/* Set the state of CONFIG Pin */ +int altera_config_fn(int assert_config, int flush, int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (assert_config) + writeb(0x04, &gpiop->ppd_uart); + else + writeb(0xFB, &gpiop->pclrr_uart); + return FPGA_SUCCESS; +} + +/* Returns the state of STATUS Pin */ +int altera_status_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (readb(&gpiop->ppd_pwm) & 0x08) + return FPGA_FAIL; + return FPGA_SUCCESS; +} + +/* Returns the state of CONF_DONE Pin */ +int altera_done_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (readb(&gpiop->ppd_pwm) & 0x20) + return FPGA_FAIL; + return FPGA_SUCCESS; +} + +/* writes the complete buffer to the FPGA + writing the complete buffer in one function is much faster, + then calling it for every bit */ +int altera_write_fn(void *buf, size_t len, int flush, int cookie) +{ + size_t bytecount = 0; + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + unsigned char *data = (unsigned char *)buf; + unsigned char val = 0; + int i; + int len_40 = len / 40; + + while (bytecount < len) { + val = data[bytecount++]; + i = 8; + do { + writeb(0xFB, &gpiop->pclrr_qspi); + if (val & 0x01) + writeb(0x01, &gpiop->ppd_qspi); + else + writeb(0xFE, &gpiop->pclrr_qspi); + writeb(0x04, &gpiop->ppd_qspi); + val >>= 1; + i--; + } while (i > 0); + + if (bytecount % len_40 == 0) { +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET(); +#endif +#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK + putc('.'); /* let them know we are alive */ +#endif +#ifdef CONFIG_SYS_FPGA_CHECK_CTRLC + if (ctrlc()) + return FPGA_FAIL; +#endif + } + } + return FPGA_SUCCESS; +} + +/* called, when programming is aborted */ +int altera_abort_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + writeb(0x20, &gpiop->ppd_qspi); + writeb(0x08, &gpiop->ppd_uart); + return FPGA_SUCCESS; +} + +/* called, when programming was succesful */ +int altera_post_fn(int cookie) +{ + return altera_abort_fn(cookie); +} + +/* Note that these are pointers to code that is in Flash. They will be + * relocated at runtime. + * FIXME: relocation not yet working for coldfire, see below! + */ +Altera_CYC2_Passive_Serial_fns altera_fns = { + altera_pre_fn, + altera_config_fn, + altera_status_fn, + altera_done_fn, + altera_write_fn, + altera_abort_fn, + altera_post_fn +}; + +Altera_desc altera_fpga[CONFIG_FPGA_COUNT] = { + {Altera_CYC2, + passive_serial, + 85903, + (void *)&altera_fns, + NULL, + 0} +}; + +/* + * Initialize the fpga. Return 1 on success, 0 on failure. + */ +int astro5373l_altera_load(void) +{ + int i; + + for (i = 0; i < CONFIG_FPGA_COUNT; i++) { + /* I did not yet manage to get relocation work properly, + * so set stuff here instead of static initialisation: + */ + altera_fns.pre = altera_pre_fn; + altera_fns.config = altera_config_fn; + altera_fns.status = altera_status_fn; + altera_fns.done = altera_done_fn; + altera_fns.write = altera_write_fn; + altera_fns.abort = altera_abort_fn; + altera_fns.post = altera_post_fn; + altera_fpga[i].iface_fns = (void *)&altera_fns; + fpga_add(fpga_altera, &altera_fpga[i]); + } + return 1; +} + +/* + * Set the FPGA's PROG_B line to the specified level + */ +int xilinx_pgm_fn(int assert, int flush, int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (assert) + writeb(0xFB, &gpiop->pclrr_uart); + else + writeb(0x04, &gpiop->ppd_uart); + return assert; +} + +/* + * Test the state of the active-low FPGA INIT line. Return 1 on INIT + * asserted (low). + */ +int xilinx_init_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + return (readb(&gpiop->ppd_pwm) & 0x08) == 0; +} + +/* + * Test the state of the active-high FPGA DONE pin + */ +int xilinx_done_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + return (readb(&gpiop->ppd_pwm) & 0x20) >> 5; +} + +/* + * Abort an FPGA operation + */ +int xilinx_abort_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + /* ensure all SPI peripherals and FPGAs are deselected */ + writeb(0x08, &gpiop->ppd_uart); + writeb(0x01, &gpiop->ppd_timer); + writeb(0x38, &gpiop->ppd_qspi); + return FPGA_FAIL; +} + +/* + * FPGA pre-configuration function. Just make sure that + * FPGA reset is asserted to keep the FPGA from starting up after + * configuration. + */ +int xilinx_pre_config_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + unsigned char tmp_char; + unsigned short tmp_short; + + /* first, set the required pins to GPIO function */ + /* PAR_T0IN -> GPIO */ + tmp_char = readb(&gpiop->par_timer); + tmp_char &= 0xfc; + writeb(tmp_char, &gpiop->par_timer); + /* all QSPI pins -> GPIO */ + writew(0x0000, &gpiop->par_qspi); + /* U0RTS, U0CTS -> GPIO */ + tmp_short = __raw_readw(&gpiop->par_uart); + tmp_short &= 0xfff3; + __raw_writew(tmp_short, &gpiop->par_uart); + /* all PWM pins -> GPIO */ + writeb(0x00, &gpiop->par_pwm); + /* next, set data direction registers */ + writeb(0x01, &gpiop->pddr_timer); + writeb(0x25, &gpiop->pddr_qspi); + writeb(0x0c, &gpiop->pddr_uart); + writeb(0x04, &gpiop->pddr_pwm); + + /* ensure other SPI peripherals are deselected */ + writeb(0x08, &gpiop->ppd_uart); + writeb(0x38, &gpiop->ppd_qspi); + writeb(0x01, &gpiop->ppd_timer); + + /* CONFIG = 0, STATUS = 0 -> FPGA in reset state */ + writeb(0xFB, &gpiop->pclrr_uart); + /* enable Xilinx configuration by clearing QSPI_CS2 and U0CTS */ + writeb(0xF7, &gpiop->pclrr_uart); + writeb(0xDF, &gpiop->pclrr_qspi); + return 0; +} + +/* + * FPGA post configuration function. Should perform a test if FPGA is running... + */ +int xilinx_post_config_fn(int cookie) +{ + int rc = 0; + + /* + * no test yet + */ + return rc; +} + +int xilinx_clk_fn(int assert_clk, int flush, int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (assert_clk) + writeb(0x04, &gpiop->ppd_qspi); + else + writeb(0xFB, &gpiop->pclrr_qspi); + return assert_clk; +} + +int xilinx_wr_fn(int assert_write, int flush, int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (assert_write) + writeb(0x01, &gpiop->ppd_qspi); + else + writeb(0xFE, &gpiop->pclrr_qspi); + return assert_write; +} + +int xilinx_fastwr_fn(void *buf, size_t len, int flush, int cookie) +{ + size_t bytecount = 0; + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + unsigned char *data = (unsigned char *)buf; + unsigned char val = 0; + int i; + int len_40 = len / 40; + + for (bytecount = 0; bytecount < len; bytecount++) { + val = *(data++); + for (i = 8; i > 0; i--) { + writeb(0xFB, &gpiop->pclrr_qspi); + if (val & 0x80) + writeb(0x01, &gpiop->ppd_qspi); + else + writeb(0xFE, &gpiop->pclrr_qspi); + writeb(0x04, &gpiop->ppd_qspi); + val <<= 1; + } + if (bytecount % len_40 == 0) { +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET(); +#endif +#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK + putc('.'); /* let them know we are alive */ +#endif +#ifdef CONFIG_SYS_FPGA_CHECK_CTRLC + if (ctrlc()) + return FPGA_FAIL; +#endif + } + } + return FPGA_SUCCESS; +} + +/* Note that these are pointers to code that is in Flash. They will be + * relocated at runtime. + * FIXME: relocation not yet working for coldfire, see below! + */ +Xilinx_Spartan3_Slave_Serial_fns xilinx_fns = { + xilinx_pre_config_fn, + xilinx_pgm_fn, + xilinx_clk_fn, + xilinx_init_fn, + xilinx_done_fn, + xilinx_wr_fn, + 0, + xilinx_fastwr_fn +}; + +Xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { + {Xilinx_Spartan3, + slave_serial, + XILINX_XC3S4000_SIZE, + (void *)&xilinx_fns, + 0} +}; + +/* + * Initialize the fpga. Return 1 on success, 0 on failure. + */ +int astro5373l_xilinx_load(void) +{ + int i; + + fpga_init(); + + for (i = 0; i < CONFIG_FPGA_COUNT; i++) { + /* I did not yet manage to get relocation work properly, + * so set stuff here instead of static initialisation: + */ + xilinx_fns.pre = xilinx_pre_config_fn; + xilinx_fns.pgm = xilinx_pgm_fn; + xilinx_fns.clk = xilinx_clk_fn; + xilinx_fns.init = xilinx_init_fn; + xilinx_fns.done = xilinx_done_fn; + xilinx_fns.wr = xilinx_wr_fn; + xilinx_fns.bwr = xilinx_fastwr_fn; + xilinx_fpga[i].iface_fns = (void *)&xilinx_fns; + fpga_add(fpga_xilinx, &xilinx_fpga[i]); + } + return 1; +} diff --git a/board/astro/mcf5373l/mcf5373l.c b/board/astro/mcf5373l/mcf5373l.c new file mode 100644 index 0000000..0f2c049 --- /dev/null +++ b/board/astro/mcf5373l/mcf5373l.c @@ -0,0 +1,206 @@ +/* + * (C) Copyright 2000-2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * modified by Wolfgang Wegner w.wegner@astro-kom.de for ASTRO 5373l + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <watchdog.h> +#include <command.h> +#include <asm/m5329.h> +#include <asm/immap_5329.h> +#include <asm/io.h> + +/* needed for astro bus: */ +#include <asm/uart.h> +#include "astro.h" + +DECLARE_GLOBAL_DATA_PTR; +extern void uart_port_conf(void); + +int checkboard(void) +{ + puts("Board: "); + puts("ASTRO MCF5373L (Urmel) Board\n"); + return 0; +} + +phys_size_t initdram(int board_type) +{ +#if !defined(CONFIG_MONITOR_IS_IN_RAM) + sdram_t *sdp = (sdram_t *)(MMAP_SDRAM); + + /* GPIO configuration for bus should be set correctly from reset, + * so we do not care! First, set up address space: at this point, + * we should be running from internal SRAM; + * so use CONFIG_SYS_SDRAM_BASE as the base address for SDRAM, + * and do not care where it is + */ + __raw_writel((CONFIG_SYS_SDRAM_BASE & 0xFFF00000) | 0x00000018, + &sdp->cs0); + __raw_writel((CONFIG_SYS_SDRAM_BASE & 0xFFF00000) | 0x00000000, + &sdp->cs1); + /* I am not sure from the data sheet, but it seems burst length + * has to be 8 for the 16 bit data bus we use; + * so these values are for BL = 8 + */ + __raw_writel(0x33211530, &sdp->cfg1); + __raw_writel(0x56570000, &sdp->cfg2); + /* send PrechargeALL, REF and IREF remain cleared! */ + __raw_writel(0xE1462C02, &sdp->ctrl); + udelay(1); + /* refresh SDRAM twice */ + __raw_writel(0xE1462C04, &sdp->ctrl); + udelay(1); + __raw_writel(0xE1462C04, &sdp->ctrl); + /* init MR */ + __raw_writel(0x008D0000, &sdp->mode); + /* initialize EMR */ + __raw_writel(0x80010000, &sdp->mode); + /* wait until DLL is locked */ + udelay(1); + /* enable automatic refresh, lock mode register, + * clear iref and ipall + */ + __raw_writel(0x71462C00, &sdp->ctrl); + /* Dummy write to start SDRAM */ + writel(0, CONFIG_SYS_SDRAM_BASE); +#endif + + /* for get_ram_size() to work, both CS areas have to be + * configured, i.e. CS1 has to be explicitely disabled, else + * probing for memory will cause the SDRAM bus to hang! + * (Do not rely on the SDCS register(s) being set to 0x00000000 + * during reset as stated in the data sheet.) + */ + return get_ram_size((unsigned long *)CONFIG_SYS_SDRAM_BASE, + 0x80000000 - CONFIG_SYS_SDRAM_BASE); +} + +#define UART_BASE MMAP_UART0 +int rs_serial_init(int port, int baud) +{ + uart_t *uart; + u32 counter; + + switch (port) { + case 0: + uart = (uart_t *)(MMAP_UART0); + break; + case 1: + uart = (uart_t *)(MMAP_UART1); + break; + case 2: + uart = (uart_t *)(MMAP_UART2); + break; + default: + uart = (uart_t *)(MMAP_UART0); + } + + uart_port_conf(); + + /* write to SICR: SIM2 = uart mode,dcd does not affect rx */ + writeb(UART_UCR_RESET_RX, &uart->ucr); + writeb(UART_UCR_RESET_TX, &uart->ucr); + writeb(UART_UCR_RESET_ERROR, &uart->ucr); + writeb(UART_UCR_RESET_MR, &uart->ucr); + __asm__ ("nop"); + + writeb(0, &uart->uimr); + + /* write to CSR: RX/TX baud rate from timers */ + writeb(UART_UCSR_RCS_SYS_CLK | UART_UCSR_TCS_SYS_CLK, &uart->ucsr); + + writeb(UART_UMR_BC_8 | UART_UMR_PM_NONE, &uart->umr); + writeb(UART_UMR_SB_STOP_BITS_1, &uart->umr); + + /* Setting up BaudRate */ + counter = (u32) (gd->bus_clk / (baud)); + counter >>= 5; + + /* write to CTUR: divide counter upper byte */ + writeb((u8) ((counter & 0xff00) >> 8), &uart->ubg1); + /* write to CTLR: divide counter lower byte */ + writeb((u8) (counter & 0x00ff), &uart->ubg2); + + writeb(UART_UCR_RX_ENABLED | UART_UCR_TX_ENABLED, &uart->ucr); + + return 0; +} + +void astro_put_char(char ch) +{ + uart_t *uart; + unsigned long timer; + + uart = (uart_t *)(MMAP_UART0); + /* Wait for last character to go. Timeout of 6ms should + * be enough for our lowest baud rate of 2400. + */ + timer = get_timer(0); + while (get_timer(timer) < 6) { + if (readb(&uart->usr) & UART_USR_TXRDY) + break; + } + writeb(ch, &uart->utb); + + return; +} + +int astro_is_char(void) +{ + uart_t *uart; + + uart = (uart_t *)(MMAP_UART0); + return readb(&uart->usr) & UART_USR_RXRDY; +} + +int astro_get_char(void) +{ + uart_t *uart; + + uart = (uart_t *)(MMAP_UART0); + while (!(readb(&uart->usr) & UART_USR_RXRDY)) ; + return readb(&uart->urb); +} + +int misc_init_r(void) +{ + int retval = 0; + + puts("Configure Xilinx FPGA..."); + retval = astro5373l_xilinx_load(); + if (!retval) { + puts("failed!\n"); + return retval; + } + puts("done\n"); + + puts("Configure Altera FPGA..."); + retval = astro5373l_altera_load(); + if (!retval) { + puts("failed!\n"); + return retval; + } + puts("done\n"); + + return retval; +} diff --git a/board/astro/mcf5373l/u-boot.lds b/board/astro/mcf5373l/u-boot.lds new file mode 100644 index 0000000..a9a4e0a --- /dev/null +++ b/board/astro/mcf5373l/u-boot.lds @@ -0,0 +1,142 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(m68k) +/* Do we need any of these for elf? + __DYNAMIC = 0; */ +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + cpu/mcf532x/start.o (.text) + lib_m68k/traps.o (.text) + lib_m68k/interrupts.o (.text) + common/dlmalloc.o (.text) + lib_generic/zlib.o (.text) + + . = DEFINED(env_offset) ? env_offset : .; + common/env_embedded.o (.text) + + *(.text) +/* *(.fixup)*/ + *(.got1) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + + .reloc : + { + __got_start = .; + *(.got) + __got_end = .; + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss : + { + _sbss = .; + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + . = ALIGN(4); + _ebss = .; + } + _end = . ; + PROVIDE (end = .); +} diff --git a/board/astro/mcf5373l/update.c b/board/astro/mcf5373l/update.c new file mode 100644 index 0000000..febe19b --- /dev/null +++ b/board/astro/mcf5373l/update.c @@ -0,0 +1,625 @@ +/* + * (C) Copyright 2006-2009 + * Adnan El-Bardawil a.el-bardawil@astro-kom.de + * Wolfgang Wegner w.wegner@astro-kom.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <watchdog.h> +#include <command.h> +#include <asm/m5329.h> +#include <asm/immap_5329.h> +#include <asm/io.h> +#include <flash.h> +#include "astro.h" + +#include <asm/uart.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define DEBUG_INFO 1 +#define DEBUG_ERROR 1 + +/* dummy software version to signal card is in boot loader */ +#define SOFTWARE_VERSION 0x00 +#define SOFTWARE_SUBVERSION ' ' + +typedef enum { + CMD_INIT = 0, + CMD_NEW, + CMD_TX, + CMD_RX, + CMD_RX_RDY, + CMD_RX_ERROR +} cmd_stat_e; + +#define INT_CMD_IDLE 0 +#define INT_CMD_FLASH_MODE 1 +#define INT_CMD_WRITE_FLASH 2 +#define INT_CMD_RESTART 4 + +#define FL_STAT_IDLE 0 +#define FL_STAT_ERASE 1 +#define FL_STAT_PROG 2 +#define FL_STAT_ERROR 4 + +/*----------------------------------------------------------------------- + * UART update subcommand codes + */ + +#define F_SAVE_PARAMETERS 0x00 /* save parameters on card */ +#define F_READ_PARAMETERS 0x01 /* read parameters */ +#define F_READ_CARDINFO 0x10 /* read card information */ +#define F_READ_ERROR_STATUS 0x11 /* read card error */ +#define F_TRANSPARENT_DATA 0x20 /* length byte + data */ + +#define SC_PREPARE_FOR_FLASH_DATA 0xc0 +#define SC_FLASH_DATA 0xc1 +#define SC_CLEAR_CRC 0xc2 +#define SC_CHECK_CRC 0xc3 +#define SC_RESTART 0xc4 + +typedef struct { + unsigned char command; + unsigned char length; + unsigned char subcommand; +} rcv_cmd_t; + +card_id_t card_information; + +struct { + parameters_t a; + parameters_t b; +} parameters; + +typedef struct { + int cnt; + cmd_stat_e stat; +} upd_command_t; + +typedef struct { + int cnt; + int length; + unsigned char *buffer; +} comm_status_t; + +const unsigned long fl_base[3] = { 0x80000, 0x540000, 0x6c0000 }; +const char fl_type_str[3][6] = { "Kernel", "Xilinx", "Altera" }; + +/* info for FLASH chips */ +extern flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; + +unsigned long crc, crc_count; + +/* CRC divisor value */ +#define CRC_POLYNOM 0x800500 + +void do_crc(unsigned char data) +{ + unsigned char count; + + crc |= data; + for (count = 0; count < 8; count++) { + crc <<= 1; + if (crc & 0x1000000) + crc ^= CRC_POLYNOM; + } + crc_count++; +} + +static unsigned char flash_buffer[0x10000]; +static unsigned long flash_data_length, flash_data_count; +static unsigned long flash_prog_count, flash_sect_count; +static unsigned char flash_data_type, crc_en; +static int flash_prog_stat; +static unsigned char uart_buffer[64]; + +void fl_prog(int force_write) +{ + int s, i; + unsigned long fl_adr, fl_sector; + + fl_adr = fl_base[flash_data_type] + flash_prog_count; + fl_sector = fl_adr >> 17; + + switch (flash_prog_stat) { + case FL_STAT_IDLE: + if (((flash_prog_count & 0x1ffff) == 0) && + ((flash_prog_count >> 17) == flash_sect_count)) { + flash_protect(FLAG_PROTECT_CLEAR, fl_adr, + fl_adr + 0x1ffff, flash_info); + s = flash_erase_nb(flash_info, fl_sector); + flash_prog_stat = FL_STAT_ERASE; + } else if ((flash_data_count >= (flash_prog_count + 64)) + || (force_write + && (flash_data_count > flash_prog_count))) { + s = write_buff_nb(flash_info, + flash_buffer + + (flash_prog_count & 0xffff), + fl_adr, 64); + flash_prog_stat = FL_STAT_PROG; + } + break; + case FL_STAT_ERASE: + s = flash_full_status_check_nb(flash_info, fl_sector, + 0, "erase"); + if (s != ERR_BUSY) { + if (s == ERR_OK) { + flash_sect_count++; + flash_prog_stat = FL_STAT_IDLE; + } else { + flash_prog_stat = FL_STAT_ERROR; + } + } + break; + case FL_STAT_PROG: + s = flash_full_status_check_nb(flash_info, fl_sector, + 0, "write"); + if (s == ERR_BUSY) + return; + + if (s != ERR_OK) { + flash_prog_stat = FL_STAT_ERROR; + return; + } + + flash_prog_stat = FL_STAT_IDLE; + for (i = 0; i < 64; i++) { + if (flash_buffer[(flash_prog_count + i) & 0xffff] != + *((unsigned char *)fl_adr + i)) + flash_prog_stat = FL_STAT_ERROR; + } + if ((flash_prog_count & 0xfff) == 0) + printf("."); + flash_prog_count += 64; + if (((flash_prog_count & 0x1ffff) == 0) + || (force_write + && (flash_data_count <= flash_prog_count))) { + flash_protect(FLAG_PROTECT_SET, + fl_adr & 0xfffe0000, + fl_adr | 0x1ffff, + flash_info); + } + break; + } +} + +void handle_rx_char(unsigned char rx_data, upd_command_t *cmd, + int *rcv_cnt, rcv_cmd_t *rcv_cmd, + comm_status_t *rx_stat) +{ + uart_t *uart; + + uart = (uart_t *)(MMAP_UART0); + if (readb(&uart->usr) & UART_USR_OE) { +#if DEBUG_ERROR + printf("UART FIFO Overrun Error!\n"); +#endif + writeb(UART_UCR_RESET_ERROR, &uart->ucr); + cmd->stat = CMD_RX_ERROR; + } + if (cmd->stat == CMD_INIT) { + if (*rcv_cnt == 0) { + /* First received Byte is the Command */ + rcv_cmd->command = rx_data; + /* non-Transparent Data: start Command Processing */ + if (rcv_cmd->command != F_TRANSPARENT_DATA) { + cmd->stat = CMD_NEW; + cmd->cnt++; + } else { + (*rcv_cnt)++; + } + } else { + /* Length and Subcommand for Transparent Data */ + if (*rcv_cnt == 1) { + rcv_cmd->length = rx_data; + (*rcv_cnt)++; + } else { + rcv_cmd->subcommand = rx_data; + cmd->stat = CMD_NEW; + cmd->cnt++; + } + } + } else if (cmd->stat == CMD_RX) { + /* Store received Data to Rx Buffer */ + rx_stat->buffer[rx_stat->cnt] = rx_data; + if (crc_en) + do_crc(rx_data); + (rx_stat->cnt)++; + if (rx_stat->cnt == rx_stat->length) + cmd->stat = CMD_RX_RDY; + } +} + +/* handle a transparent data command; these are used for software update + * return value is 1 if cmd_stat is set to CMD_INIT to let caller decide + * to reset the receive count, else 0. + */ +int handle_transparent_command(upd_command_t *cmd, rcv_cmd_t *rcv_cmd, + comm_status_t *rx_stat, comm_status_t *tx_stat, + unsigned char *int_command) +{ + int i; + unsigned char crc_status; + + if (cmd->stat == CMD_NEW) { + rx_stat->cnt = 0; + rx_stat->length = rcv_cmd->length - 1; + } + switch (rcv_cmd->subcommand) { + case SC_PREPARE_FOR_FLASH_DATA: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = uart_buffer; + cmd->stat = CMD_RX; + } else if (cmd->stat == CMD_RX_RDY) { + for (i = 0; i < 4; i++) + flash_data_length = (flash_data_length << 8) + + uart_buffer[i + 1]; + flash_data_type = uart_buffer[0]; +#if DEBUG_INFO + printf(" -- Flash Programming Initialized -- \n"); + printf(" -- Receiving %lu Bytes of type ", + flash_data_length); + for (i = 0; i < 6; i++) + printf("%c", fl_type_str[flash_data_type][i]); + printf(" [0x%lx]\n", fl_base[flash_data_type]); +#endif + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + crc_count = 0; + crc = 0; + flash_data_count = 0; + flash_prog_count = 0; + flash_sect_count = 0; + flash_prog_stat = FL_STAT_IDLE; + crc_en = 0; + *int_command = INT_CMD_FLASH_MODE; + cmd->stat = CMD_TX; + return 1; + } + break; + case SC_FLASH_DATA: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = flash_buffer + + (flash_data_count & 0xffff); + rx_stat->cnt = 0; + cmd->stat = CMD_RX; + crc_en = 1; + } else if (cmd->stat == CMD_RX_RDY) { + crc_en = 0; + flash_data_count += rcv_cmd->length - 1; + cmd->stat = CMD_INIT; + return 1; + } + break; + case SC_CLEAR_CRC: + if (cmd->stat == CMD_NEW) { + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + cmd->stat = CMD_TX; + crc_count = 0; + crc = 0; + } + break; + case SC_CHECK_CRC: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = uart_buffer; + cmd->stat = CMD_RX; + } else if (cmd->stat == CMD_RX_RDY) { + if ((flash_data_count <= flash_prog_count) + || (flash_prog_stat == FL_STAT_ERROR)) { + crc_status = 0; + if (uart_buffer[0] != ((crc >> 16) & 0xff)) + crc_status = 1; + if (uart_buffer[1] != ((crc >> 8) & 0xff)) + crc_status = 1; + if (flash_prog_stat == FL_STAT_ERROR) + crc_status |= 2; + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 4; + uart_buffer[2] = rcv_cmd->subcommand; + uart_buffer[3] = (crc >> 16); + uart_buffer[4] = (crc >> 8); + uart_buffer[5] = crc_status; +#if DEBUG_INFO + printf(" CRC %u / %lu of %lu kB \n", + crc_status, + (flash_data_count >> 10), + (flash_data_length >> 10)); +#endif + tx_stat->buffer = uart_buffer; + tx_stat->length = 6; + cmd->stat = CMD_TX; + if (crc_status) { + flash_prog_count = + flash_data_count = + (flash_data_count & 0xffff0000) + - 0x10000; + flash_prog_stat = FL_STAT_IDLE; + *int_command = INT_CMD_FLASH_MODE; + } + } + if (flash_data_count & 0xffff) + *int_command |= INT_CMD_WRITE_FLASH; + } + break; + case SC_RESTART: + if (cmd->stat == CMD_NEW) { + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + cmd->stat = CMD_TX; + crc_count = 0; + crc = 0; + /* set restart command; sending the reply + * is done before finishing the loop. + */ + *int_command = INT_CMD_RESTART; + return 1; + } + break; + default: + /* for un-handled zero length transparent command, + * we have to handle this condition first! + */ + if ((cmd->stat == CMD_RX_RDY) + || (rx_stat->cnt == rx_stat->length)) + cmd->stat = CMD_INIT; + else if (cmd->stat == CMD_NEW) + cmd->stat = CMD_RX; + } + return 0; +} + +/* handle a general command (i.e. status and version information query) + * return value is always 0 except for transparent data where the + * return code is passed through to allow caller reset receive count. + */ +int handle_command(upd_command_t *cmd, rcv_cmd_t *rcv_cmd, + comm_status_t *rx_stat, comm_status_t *tx_stat, + unsigned char *int_command) +{ + int rv = 0; + + switch (rcv_cmd->command) { + case F_READ_ERROR_STATUS: +#if DEBUG_INFO + printf("read error status\n"); +#endif + uart_buffer[0] = 0; + uart_buffer[1] = 0; + uart_buffer[2] = 0; + uart_buffer[3] = 0; + tx_stat->buffer = uart_buffer; + tx_stat->length = 4; + cmd->stat = CMD_TX; + break; + case F_READ_PARAMETERS: + if (cmd->stat == CMD_NEW) { +#if DEBUG_INFO + printf("read parameters\n"); +#endif + memcpy(uart_buffer, (unsigned char *)¶meters.a, + 2 * sizeof(parameters_t)); + cmd->stat = CMD_TX; + tx_stat->length = 2 * sizeof(parameters_t); + } + break; + case F_READ_CARDINFO: +#if DEBUG_INFO + printf("read card info\n"); +#endif + card_information.software_version = + ((*int_command) & INT_CMD_FLASH_MODE) ? + 0xEE : SOFTWARE_VERSION; + tx_stat->buffer = (unsigned char *)&card_information; + tx_stat->length = 5; + cmd->stat = CMD_TX; + break; + + case F_TRANSPARENT_DATA: + rv = handle_transparent_command(cmd, rcv_cmd, rx_stat, + tx_stat, int_command); + break; + } + return rv; +} + +/* transmit data prepared in comm_status_t structure */ +void transmit_buffer(comm_status_t *tx_stat) +{ + int cnt; + for (cnt = 0; cnt < tx_stat->length; cnt++) + astro_put_char(tx_stat->buffer[cnt]); +} + +int do_update(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + unsigned char rx_data; + comm_status_t rx_stat, tx_stat; + upd_command_t cmd; + int rcv_cnt; + rcv_cmd_t rcv_cmd; + unsigned char int_command, tmp_char; + unsigned short tmp_short; + + int select, old_select, got_char; + eport_t *eport = (eport_t *)MMAP_EPORT; + gpio_t *gpio = (gpio_t *)MMAP_GPIO; + uart_t *uart = (uart_t *)MMAP_UART0; + char *env_string; + + cmd.cnt = 0; + + /* we set some dummy parameters to make the protocol work */ + card_information.card_type = ASTRO_ID; + env_string = getenv("loaderversion"); + if (env_string != NULL) { + card_information.hardware_version = + (int)simple_strtol(env_string, NULL, 16); + } else { + card_information.hardware_version = 0x10; + } + card_information.software_version = SOFTWARE_VERSION; + card_information.software_subversion = SOFTWARE_SUBVERSION; + card_information.fpga_version_altera = 0x12; + card_information.fpga_version_xilinx = 0x13; + + parameters.a.symbolrate = 0x5027; + parameters.a.viterbirate = 0x34; + parameters.a.satfreq = 0x6616; + parameters.a.card_error = 0; + + parameters.b.symbolrate = 0x5027; + parameters.b.viterbirate = 0x34; + parameters.b.satfreq = 0x6616; + parameters.b.card_error = 0; + + puts("Initializing serial port to ASTRO bus...\n"); + /* init serial port */ + rs_serial_init(0, 2400); + /* set UART pin for UART */ + tmp_short = __raw_readw(&gpio->par_uart); + tmp_short |= 0x0003; + __raw_writew(tmp_short, &gpio->par_uart); + /* set select pin as GPIO */ + tmp_short = __raw_readw(&gpio->par_irq); + tmp_short &= 0x0FF0; + __raw_writew(tmp_short, &gpio->par_irq); + /* set select pin as input */ + tmp_char = readb(&eport->pdr); + tmp_char &= 0xBF; + writeb(tmp_char, &eport->pdr); + /* set interrupt to both falling and rising edge + * (no IRQ used, though) + */ + tmp_short = __raw_readw(&eport->par); + tmp_short |= 0x3000; + __raw_writew(tmp_short, &eport->par); + + int_command = INT_CMD_IDLE; + + rcv_cnt = 0; + cmd.stat = CMD_INIT; + old_select = 0; /* always start from "deselected" state */ + rx_data = 0xFF; + + while (int_command != INT_CMD_RESTART) { + +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET(); +#endif + + /***************************************** + ** Flash program routine ** + ** only called in flash mode ** + ***************************************** + */ + if (int_command & INT_CMD_FLASH_MODE) + fl_prog(int_command & INT_CMD_WRITE_FLASH); + + /***************************************** + ** UART Card Select Routine ** + ***************************************** + */ + + /* Write ID on Card Select */ + select = ((readb(&eport->pdr) & 0x40) == 0x0); + + if ((select) && (!old_select)) { + /* set low baud rate for ID only */ + rs_serial_init(0, 2400); + astro_put_char(ASTRO_ID); + + /* Wait for TX finished before switching baudrate */ + while ((readb(&uart->usr) & UART_USR_TXEMP) == 0) { + } + + /* set high baud rate */ + rs_serial_init(0, 115200); + /* Reset the Receive Byte Counter */ + rcv_cnt = 0; + cmd.stat = CMD_INIT; + } else if ((!select) && old_select && (cmd.stat != CMD_INIT)) { + cmd.stat = CMD_INIT; +#if DEBUG_ERROR + printf("Command %u: 0x%02x (0x%02x) failed," + " len %d, cnt %d\n", + cmd.cnt, rcv_cmd.command, + rcv_cmd.subcommand, rcv_cmd.length, + rx_stat.cnt); +#endif + } + + old_select = select; + + got_char = astro_is_char(); + if (got_char) + rx_data = astro_get_char(); + + if (select) { + /***************************************** + ** UART RX Routine ** + ***************************************** + */ + if (got_char) + handle_rx_char(rx_data, &cmd, &rcv_cnt, + &rcv_cmd, &rx_stat); + + /***************************************** + ** Command Control Routine ** + ***************************************** + */ + if ((cmd.stat == CMD_NEW) + || (cmd.stat == CMD_RX_RDY)) { + if (handle_command(&cmd, &rcv_cmd, + &rx_stat, &tx_stat, + &int_command)) + rcv_cnt = 0; + } + + /***************************************** + ** UART TX Routine ** + ***************************************** + */ + if (cmd.stat == CMD_TX) { + transmit_buffer(&tx_stat); + /* Reset the Receive Byte Counter */ + rcv_cnt = 0; + cmd.stat = CMD_INIT; + } + } + } + /* restart is done outside, so we simply leave this function */ + return 0; +} + +U_BOOT_CMD(update, 1, 1, do_update, + "automatic update via ASTRO bus", + "\n - start the update, waiting for transfer via bus"); diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h new file mode 100644 index 0000000..14ce839 --- /dev/null +++ b/include/configs/astro_mcf5373l.h @@ -0,0 +1,427 @@ +/* + * Configuration settings for the Sentec Cobra Board. + * + * (C) Copyright 2003 Josef Baumgartner josef.baumgartner@telex.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* configuration for ASTRO "Urmel" board. + * Originating from Cobra5272 configuration, messed up by + * Wolfgang Wegner w.wegner@astro-kom.de + * Please do not bother the original author with bug reports + * concerning this file. + */ + +/* --- + * board/config.h - configuration options, board specific + * --- + */ + +#ifndef _CONFIG_ASTRO_MCF5373L_H +#define _CONFIG_ASTRO_MCF5373L_H + +/* set the card type to actually compile for; either of + * the possibilities listed below has to be used! + */ +#define CONFIG_ASTRO_V532 1 + +#if CONFIG_ASTRO_V532 +#define ASTRO_ID 0xF8 +#elif CONFIG_ASTRO_V512 +#define ASTRO_ID 0xFA +#elif CONFIG_ASTRO_TWIN7S2 +#define ASTRO_ID 0xF9 +#elif CONFIG_ASTRO_V912 +#define ASTRO_ID 0xFC +#elif CONFIG_ASTRO_COFDMDUOS2 +#define ASTRO_ID 0xFB +#else +#error No card type defined! +#endif + +/* --- + * Define processor + * possible values for Urmel board: only Coldfire M5373 processor supported + * (please do not change) + * --- + */ + +/* it seems not clear yet which processor defines we should use */ +#define CONFIG_MCF537x /* define processor family */ +#define CONFIG_MCF532x /* define processor family */ +#define CONFIG_M5373 /* define processor type */ +#define CONFIG_ASTRO5373L /* define board type */ + +/* Command line configuration */ +#include <config_cmd_default.h> + +/* --- + * CONFIG_MK_RAM defines if u-boot is loaded via BDM (or started from + * a different bootloader that has already performed RAM setup) or + * started directly from flash, which is the regular case for production + * boards. + * --- + */ +#ifdef CONFIG_MK_RAM +#define CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_TEXT_BASE 0x40020000 +#define ENABLE_JFFS 0 +#else +#define CONFIG_TEXT_BASE 0x00000000 +#define ENABLE_JFFS 1 +#endif + +/* --- + * Define which commmands should be available at u-boot command prompt + * --- + */ + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DATE +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_MISC +#define CONFIG_CMD_XIMG +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#if ENABLE_JFFS +#define CONFIG_CMD_JFFS2 +#endif +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_LOADB +#define CONFIG_CMD_FPGA +#define CONFIG_CMDLINE_EDITING + +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_MCFRTC +#undef RTC_DEBUG + +/* Timer */ +#define CONFIG_MCFTMR +#undef CONFIG_MCFPIT + +/* I2C */ +#define CONFIG_FSL_I2C +#define CONFIG_HARD_I2C /* I2C with hw support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_SYS_I2C_SPEED 80000 +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_OFFSET 0x58000 +#define CONFIG_SYS_IMMR CONFIG_SYS_MBAR + +/* --- + * Defines processor clock - important for correct timings concerning serial + * interface etc. + * CONFIG_SYS_HZ gives unit: 1000 -> 1 Hz ^= 1000 ms + * --- + */ + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_CLK 80000000 +#define CONFIG_SYS_CPU_CLK (CONFIG_SYS_CLK * 3) +#define CONFIG_SYS_SDRAM_SIZE 32 /* SDRAM size in MB */ + +#define CONFIG_SYS_CORE_SRAM_SIZE 0x8000 +#define CONFIG_SYS_CORE_SRAM 0x80000000 + +#define CONFIG_SYS_UNIFY_CACHE + +/* --- + * Define baudrate for UART1 (console output, tftp, ...) + * default value of CONFIG_BAUDRATE for Sentec board: 19200 baud + * CONFIG_SYS_BAUDRATE_TABLE defines values that can be selected + * in u-boot command interface + * --- + */ + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600 , 19200 , 38400 , 57600, 115200 } + +#define CONFIG_MCFUART +#define CONFIG_SYS_UART_PORT (2) +#define CONFIG_SYS_UART2_ALT3_GPIO + +/* --- + * Watchdog configuration; Watchdog is disabled for running from RAM + * and set to highest possible value else. Beware there is no check + * in the watchdog code to validate the timeout value set here! + * --- + */ + +#ifndef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_WATCHDOG +#define CONFIG_WATCHDOG_TIMEOUT 3355 /* timeout in milliseconds */ +#endif + +/* --- + * Configuration for environment + * Environment is embedded in u-boot in the second sector of the flash + * --- + */ + +#ifndef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_ENV_OFFSET 0x1FF8000 +#define CONFIG_ENV_SECT_SIZE 0x8000 +#define CONFIG_ENV_IS_IN_FLASH 1 +#else +/* environment in RAM - This is used to use a single PC-based application + * to load an image, load U-Boot, load an environment and then start U-Boot + * to execute the commands from the environment. Feedback is done via setting + * and reading memory locations. + */ +#define CONFIG_ENV_ADDR 0x40060000 +#define CONFIG_ENV_SECT_SIZE 0x8000 +#define CONFIG_ENV_IS_IN_FLASH 1 +#endif + +/* here we put our FPGA configuration... */ +#define CONFIG_MISC_INIT_R 1 + +/* + *----------------------------------------------------------------------------- + * Define user parameters that have to be customized most likely + *----------------------------------------------------------------------------- + */ + +/* AUTOBOOT settings - booting images automatically by u-boot after power on */ + +/* used for autoboot, delay in seconds u-boot will wait before starting + * defined (auto-)boot command, setting to -1 disables delay, setting to + * 0 will too prevent access to u-boot command interface: u-boot then has + * to be reflashed + * beware - watchdog is not serviced during autoboot delay time! + */ +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_BOOTDELAY 1 +#else +#define CONFIG_BOOTDELAY 1 +#endif + +/* The following settings will be contained in the environment block ; if you + * want to use a neutral environment all those settings can be manually set in + * u-boot: 'set' command */ + +#define _QUOTEME(x) #x +#define QUOTEME(x) _QUOTEME(x) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loaderversion=11\0" \ + "card_id="QUOTEME(ASTRO_ID)"\0" \ + "alterafile=0\0" \ + "xilinxfile=0\0" \ + "xilinxload=imxtract 0x540000 $xilinxfile 0x41000000&&"\ + "fpga load 0 0x41000000 $filesize\0" \ + "alteraload=imxtract 0x6c0000 $alterafile 0x41000000&&"\ + "fpga load 1 0x41000000 $filesize\0" \ + "env_default=1\0" \ + "env_check=if test $env_default -eq 1;"\ + " then setenv env_default 0;saveenv;fi\0" + +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_BOOTCOMMAND "" /* no autoboot in this case */ +#else +#if CONFIG_ASTRO_V532 +#define CONFIG_BOOTCOMMAND "protect off 0x80000 0x1ffffff;run env_check;"\ + "run xilinxload&&run alteraload&&bootm 0x80000;"\ + "update;reset" +#else +#define CONFIG_BOOTCOMMAND "protect off 0x80000 0x1ffffff;run env_check;"\ + "run xilinxload&&bootm 0x80000;update;reset" +#endif +#endif + +/* default bootargs that are considered during boot */ +#define CONFIG_BOOTARGS " console=ttyS2,115200 rootfstype=romfs"\ + " loaderversion=$loaderversion" + +#define CONFIG_SYS_PROMPT "URMEL > " + +/* default RAM address for user programs */ +#define CONFIG_SYS_LOAD_ADDR 0x20000 + +/*---*/ + +#define CONFIG_SYS_LONGHELP + +#if (CONFIG_COMMANDS & CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 +#else +#define CONFIG_SYS_CBSIZE 256 +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_FPGA_COUNT 1 +#define CONFIG_FPGA +#define CONFIG_FPGA_XILINX +#define CONFIG_FPGA_SPARTAN3 +#define CONFIG_FPGA_ALTERA +#define CONFIG_FPGA_CYCLON2 +#define CONFIG_SYS_FPGA_PROG_FEEDBACK +#define CONFIG_SYS_FPGA_WAIT 1000 + +/* + *----------------------------------------------------------------------------- + * End of user parameters to be customized + *----------------------------------------------------------------------------- + */ + +/* --- + * Defines memory range for test + * --- + */ + +#define CONFIG_SYS_MEMTEST_START 0x40020000 +#define CONFIG_SYS_MEMTEST_END 0x41ffffff + +/* --- + * Low Level Configuration Settings + * (address mappings, register initial values, etc.) + * You should know what you are doing if you make changes here. + * --- + */ + +/* --- + * Base register address + * --- + */ + +#define CONFIG_SYS_MBAR 0xFC000000 /* Register Base Addrs */ + +/* --- + * System Conf. Reg. & System Protection Reg. + * --- + */ + +#define CONFIG_SYS_SCR 0x0003; +#define CONFIG_SYS_SPR 0xffff; + +/*----------------------------------------------------------------------- + * Definitions for initial stack pointer and data area (in internal SRAM) + */ +#define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 +#define CONFIG_SYS_INIT_RAM_END 0x8000 +#define CONFIG_SYS_INIT_RAM_CTRL 0x221 +#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ + CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +/*----------------------------------------------------------------------- + * Start addresses for the final memory configuration + * (Set up by the startup code) + * for MCF5373, the allowable range is 0x40000000 to 0x7FF00000 + */ +#define CONFIG_SYS_SDRAM_BASE 0x40000000 + +/*----------------------------------------------------------------------- + * Chipselect bank definitions + */ +/* + * CS0 - Flash 32MB (first 16MB) + * CS1 - Flash 32MB (second half) + * CS2 - FPGA + * CS3 - FPGA + * CS4 - unused + * CS5 - unused + */ +#define CONFIG_SYS_CS0_BASE 0 +#define CONFIG_SYS_CS0_MASK 0x00ff0001 +#define CONFIG_SYS_CS0_CTRL 0x00001fc0 + +#define CONFIG_SYS_CS1_BASE 0x01000000 +#define CONFIG_SYS_CS1_MASK 0x00ff0001 +#define CONFIG_SYS_CS1_CTRL 0x00001fc0 + +#define CONFIG_SYS_CS2_BASE 0x20000000 +#define CONFIG_SYS_CS2_MASK 0x00ff0001 +#define CONFIG_SYS_CS2_CTRL 0x0000fec0 + +#define CONFIG_SYS_CS3_BASE 0x21000000 +#define CONFIG_SYS_CS3_MASK 0x00ff0001 +#define CONFIG_SYS_CS3_CTRL 0x0000fec0 + +/* + *------------------------------------------------------------------------- + * RAM SIZE (is defined above) + *----------------------------------------------------------------------- + */ + +/* + *----------------------------------------------------------------------- + */ + +#define CONFIG_SYS_FLASH_BASE 0x00000000 + +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_SYS_MONITOR_BASE CONFIG_TEXT_BASE +#else +/* This is mainly used during relocation in start.S */ +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_FLASH_BASE + 0x400) +#endif +/* Reserve 256 kB for Monitor */ +#define CONFIG_SYS_MONITOR_LEN (256 << 10) + +#define CONFIG_SYS_BOOTPARAMS_LEN (64 * 1024) +/* Reserve 128 kB for malloc() */ +#define CONFIG_SYS_MALLOC_LEN (128 << 10) + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization ?? + */ +#define CONFIG_SYS_BOOTMAPSZ (CONFIG_SYS_SDRAM_BASE + \ + (CONFIG_SYS_SDRAM_SIZE << 20)) + +/*----------------------------------------------------------------------- + * FLASH organization + */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 259 +#define CONFIG_SYS_FLASH_ERASE_TOUT 1000 + +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_SIZE 0x2000000 +#define CONFIG_SYS_FLASH_PROTECTION 1 +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 +#define CONFIG_SYS_FLASH_CFI_NONBLOCK 1 + +#if ENABLE_JFFS +/* JFFS Partition offset set */ +#define CONFIG_SYS_JFFS2_FIRST_BANK 0 +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 +/* 512k reserved for u-boot */ +#define CONFIG_SYS_JFFS2_FIRST_SECTOR 0x40 +#endif + +/*----------------------------------------------------------------------- + * Cache Configuration + */ +#define CONFIG_SYS_CACHELINE_SIZE 16 + +#endif /* _CONFIG_ASTRO_MCF5373L_H */
Dear Wolfgang Wegner,
In message 1263231799-28685-1-git-send-email-w.wegner@astro-kom.de you wrote:
- /* GPIO configuration for bus should be set correctly from reset,
Incorrect multiline comment style.
- /* I am not sure from the data sheet, but it seems burst length
This happens in a number or places, please fix globally.
- UART update subcommand codes
These, too, please.
And these as well.
- End of user parameters to be customized
- Defines memory range for test
...and these.
Amazing haw many different comment styles you are using in a single patch. Guess you can apply for a record ;-)
Signed-off-by: Wolfgang Wegner w.wegner@astro-kom.de --- v3->v4: fixed multi-line comments v2->v3: fixed another load of coding style issues after finding out about checkpatch.pl... I hope to have addressed all the comments and errors that were present in the first submission; exceptions are the linker script because there was no feedback by Tsi Chung Liew on this issue, the crc routine because the update protocol is fixed and uses this (as far as I can see) non-standard CRC polynomial, and a single 81 character line in the configuration file because I see no sensible way to break it. This patch (or the boot script/images) relies on the following previously sent patches: add include/asm-m68k/unaligned.h (Message-Id 1260376332-15835-1-git-send-email-w.wegner@astro-kom.de) non-blocking flash write/erase/status check functions (Message-Id 1260374411-11299-1-git-send-email-w.wegner@astro-kom.de) add ability to handle compressed images to imxtract (Message-Id 1260436281-31824-1-git-send-email-w.wegner@astro-kom.de) add block write function to spartan3 slave serial load (Message-Id 1256918102-3760-1-git-send-email-w.wegner@astro-kom.de) allow MCF532x to use CONFIG_MONITOR_IS_IN_RAM (Message-Id 1256739061-13311-2-git-send-email-w.wegner@astro-kom.de) MCF532x: make icache_enable use CONFIG_SYS_SDRAM_SIZE (Message-Id 1256739061-13311-1-git-send-email-w.wegner@astro-kom.de)
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 4 + board/astro/mcf5373l/Makefile | 44 +++ board/astro/mcf5373l/astro.h | 44 +++ board/astro/mcf5373l/config.mk | 27 ++ board/astro/mcf5373l/fpga.c | 425 ++++++++++++++++++++++++++ board/astro/mcf5373l/mcf5373l.c | 211 +++++++++++++ board/astro/mcf5373l/u-boot.lds | 142 +++++++++ board/astro/mcf5373l/update.c | 615 ++++++++++++++++++++++++++++++++++++++ include/configs/astro_mcf5373l.h | 384 ++++++++++++++++++++++++ 11 files changed, 1901 insertions(+), 0 deletions(-) create mode 100644 board/astro/mcf5373l/Makefile create mode 100644 board/astro/mcf5373l/astro.h create mode 100644 board/astro/mcf5373l/config.mk create mode 100644 board/astro/mcf5373l/fpga.c create mode 100644 board/astro/mcf5373l/mcf5373l.c create mode 100644 board/astro/mcf5373l/u-boot.lds create mode 100644 board/astro/mcf5373l/update.c create mode 100644 include/configs/astro_mcf5373l.h
diff --git a/MAINTAINERS b/MAINTAINERS index 9734b1d..016a308 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -869,6 +869,10 @@ TsiChung Liew Tsi-Chung.Liew@freescale.com M5475EVB mcf547x_8x M5485EVB mcf547x_8x
+Wolfgang Wegner w.wegner@astro-kom.de + + astro_mcf5373l MCF5373L + ######################################################################### # AVR32 Systems: # # # diff --git a/MAKEALL b/MAKEALL index ab1bb6f..6f4f76c 100755 --- a/MAKEALL +++ b/MAKEALL @@ -822,6 +822,7 @@ LIST_microblaze=" \ #########################################################################
LIST_coldfire=" \ + astro_mcf5373l \ cobra5272 \ EB+MCF-EV123 \ EB+MCF-EV123_internal \ diff --git a/Makefile b/Makefile index 75b2c1e..a8d3517 100644 --- a/Makefile +++ b/Makefile @@ -2024,6 +2024,10 @@ ZPC1900_config: unconfig ## Coldfire #########################################################################
+astro_mcf5373l_config \ +astro_mcf5373l_RAM_config : unconfig + @$(MKCONFIG) -t $(@:_config=) astro_mcf5373l m68k mcf532x mcf5373l astro + M5208EVBE_config : unconfig @$(MKCONFIG) $(@:_config=) m68k mcf52x2 m5208evbe freescale
diff --git a/board/astro/mcf5373l/Makefile b/board/astro/mcf5373l/Makefile new file mode 100644 index 0000000..e0b1bc6 --- /dev/null +++ b/board/astro/mcf5373l/Makefile @@ -0,0 +1,44 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS = $(BOARD).o fpga.o update.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/astro/mcf5373l/astro.h b/board/astro/mcf5373l/astro.h new file mode 100644 index 0000000..b55a6f7 --- /dev/null +++ b/board/astro/mcf5373l/astro.h @@ -0,0 +1,44 @@ +#ifndef __ASTRO_H__ +#define __ASTRO_H__ + +/* in mcf5373l.c */ +int rs_serial_init(int port, int baud); +void astro_put_char(char ch); +int astro_is_char(void); +int astro_get_char(void); + +/* in fpga.c */ +int astro5373l_altera_load(void); +int astro5373l_xilinx_load(void); + +/* data structures used for communication (update.c) */ +typedef struct card_id { + char card_type; + char hardware_version; + char software_version; + char software_subversion; /* " ","a".."z" */ + char fpga_version_altera; + char fpga_version_xilinx; +} card_id_t; + +typedef struct { + unsigned char mode; + unsigned char deviation; + unsigned short freq; +} __attribute__ ((packed)) output_params_t; + +typedef struct { + unsigned short satfreq; + unsigned char satdatallg; + unsigned short symbolrate; + unsigned char viterbirate; + unsigned char symbolrate_l; + output_params_t output_params; + unsigned char reserve; + unsigned char card_error; + unsigned short dummy_ts_id; + unsigned char dummy_pat_ver; + unsigned char dummy_sdt_ver; +} __attribute__ ((packed)) parameters_t; + +#endif /* __ASTRO_H__ */ diff --git a/board/astro/mcf5373l/config.mk b/board/astro/mcf5373l/config.mk new file mode 100644 index 0000000..6316a30 --- /dev/null +++ b/board/astro/mcf5373l/config.mk @@ -0,0 +1,27 @@ +# +# (C) Copyright 2000-2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# Coldfire contribution by Bernhard Kuhn bkuhn@metrowerks.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +TEXT_BASE = $(CONFIG_TEXT_BASE) + +PLATFORM_CPPFLAGS += -DTEXT_BASE=$(TEXT_BASE) diff --git a/board/astro/mcf5373l/fpga.c b/board/astro/mcf5373l/fpga.c new file mode 100644 index 0000000..467461b --- /dev/null +++ b/board/astro/mcf5373l/fpga.c @@ -0,0 +1,425 @@ +/* + * (C) Copyright 2006 + * Wolfgang Wegner, ASTRO Strobel Kommunikationssysteme GmbH, + * w.wegner@astro-kom.de + * + * based on the files by + * Heiko Schocher, DENX Software Engineering, hs@denx.de + * and + * Rich Ireland, Enterasys Networks, rireland@enterasys.com. + * Keith Outwater, keith_outwater@mvis.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +/* Altera/Xilinx FPGA configuration support for the ASTRO "URMEL" board */ + +#include <common.h> +#include <watchdog.h> +#include <altera.h> +#include <ACEX1K.h> +#include <spartan3.h> +#include <command.h> +#include <asm/immap_5329.h> +#include <asm/io.h> +#include "fpga.h" + +DECLARE_GLOBAL_DATA_PTR; + +int altera_pre_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + unsigned char tmp_char; + unsigned short tmp_short; + + /* first, set the required pins to GPIO function */ + /* PAR_T0IN -> GPIO */ + tmp_char = readb(&gpiop->par_timer); + tmp_char &= 0xfc; + writeb(tmp_char, &gpiop->par_timer); + /* all QSPI pins -> GPIO */ + writew(0x0000, &gpiop->par_qspi); + /* U0RTS, U0CTS -> GPIO */ + tmp_short = __raw_readw(&gpiop->par_uart); + tmp_short &= 0xfff3; + __raw_writew(tmp_short, &gpiop->par_uart); + /* all PWM pins -> GPIO */ + writeb(0x00, &gpiop->par_pwm); + /* next, set data direction registers */ + writeb(0x01, &gpiop->pddr_timer); + writeb(0x25, &gpiop->pddr_qspi); + writeb(0x0c, &gpiop->pddr_uart); + writeb(0x04, &gpiop->pddr_pwm); + + /* ensure other SPI peripherals are deselected */ + writeb(0x08, &gpiop->ppd_uart); + writeb(0x38, &gpiop->ppd_qspi); + + /* CONFIG = 0 STATUS = 0 -> FPGA in reset state */ + writeb(0xFB, &gpiop->pclrr_uart); + /* enable Altera configuration by clearing QSPI_CS2 and DT0IN */ + writeb(0xFE, &gpiop->pclrr_timer); + writeb(0xDF, &gpiop->pclrr_qspi); + return FPGA_SUCCESS; +} + +/* Set the state of CONFIG Pin */ +int altera_config_fn(int assert_config, int flush, int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (assert_config) + writeb(0x04, &gpiop->ppd_uart); + else + writeb(0xFB, &gpiop->pclrr_uart); + return FPGA_SUCCESS; +} + +/* Returns the state of STATUS Pin */ +int altera_status_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (readb(&gpiop->ppd_pwm) & 0x08) + return FPGA_FAIL; + return FPGA_SUCCESS; +} + +/* Returns the state of CONF_DONE Pin */ +int altera_done_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (readb(&gpiop->ppd_pwm) & 0x20) + return FPGA_FAIL; + return FPGA_SUCCESS; +} + +/* + * writes the complete buffer to the FPGA + * writing the complete buffer in one function is much faster, + * then calling it for every bit + */ +int altera_write_fn(void *buf, size_t len, int flush, int cookie) +{ + size_t bytecount = 0; + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + unsigned char *data = (unsigned char *)buf; + unsigned char val = 0; + int i; + int len_40 = len / 40; + + while (bytecount < len) { + val = data[bytecount++]; + i = 8; + do { + writeb(0xFB, &gpiop->pclrr_qspi); + if (val & 0x01) + writeb(0x01, &gpiop->ppd_qspi); + else + writeb(0xFE, &gpiop->pclrr_qspi); + writeb(0x04, &gpiop->ppd_qspi); + val >>= 1; + i--; + } while (i > 0); + + if (bytecount % len_40 == 0) { +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET(); +#endif +#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK + putc('.'); /* let them know we are alive */ +#endif +#ifdef CONFIG_SYS_FPGA_CHECK_CTRLC + if (ctrlc()) + return FPGA_FAIL; +#endif + } + } + return FPGA_SUCCESS; +} + +/* called, when programming is aborted */ +int altera_abort_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + writeb(0x20, &gpiop->ppd_qspi); + writeb(0x08, &gpiop->ppd_uart); + return FPGA_SUCCESS; +} + +/* called, when programming was succesful */ +int altera_post_fn(int cookie) +{ + return altera_abort_fn(cookie); +} + +/* + * Note that these are pointers to code that is in Flash. They will be + * relocated at runtime. + * FIXME: relocation not yet working for coldfire, see below! + */ +Altera_CYC2_Passive_Serial_fns altera_fns = { + altera_pre_fn, + altera_config_fn, + altera_status_fn, + altera_done_fn, + altera_write_fn, + altera_abort_fn, + altera_post_fn +}; + +Altera_desc altera_fpga[CONFIG_FPGA_COUNT] = { + {Altera_CYC2, + passive_serial, + 85903, + (void *)&altera_fns, + NULL, + 0} +}; + +/* Initialize the fpga. Return 1 on success, 0 on failure. */ +int astro5373l_altera_load(void) +{ + int i; + + for (i = 0; i < CONFIG_FPGA_COUNT; i++) { + /* + * I did not yet manage to get relocation work properly, + * so set stuff here instead of static initialisation: + */ + altera_fns.pre = altera_pre_fn; + altera_fns.config = altera_config_fn; + altera_fns.status = altera_status_fn; + altera_fns.done = altera_done_fn; + altera_fns.write = altera_write_fn; + altera_fns.abort = altera_abort_fn; + altera_fns.post = altera_post_fn; + altera_fpga[i].iface_fns = (void *)&altera_fns; + fpga_add(fpga_altera, &altera_fpga[i]); + } + return 1; +} + +/* Set the FPGA's PROG_B line to the specified level */ +int xilinx_pgm_fn(int assert, int flush, int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (assert) + writeb(0xFB, &gpiop->pclrr_uart); + else + writeb(0x04, &gpiop->ppd_uart); + return assert; +} + +/* + * Test the state of the active-low FPGA INIT line. Return 1 on INIT + * asserted (low). + */ +int xilinx_init_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + return (readb(&gpiop->ppd_pwm) & 0x08) == 0; +} + +/* Test the state of the active-high FPGA DONE pin */ +int xilinx_done_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + return (readb(&gpiop->ppd_pwm) & 0x20) >> 5; +} + +/* Abort an FPGA operation */ +int xilinx_abort_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + /* ensure all SPI peripherals and FPGAs are deselected */ + writeb(0x08, &gpiop->ppd_uart); + writeb(0x01, &gpiop->ppd_timer); + writeb(0x38, &gpiop->ppd_qspi); + return FPGA_FAIL; +} + +/* + * FPGA pre-configuration function. Just make sure that + * FPGA reset is asserted to keep the FPGA from starting up after + * configuration. + */ +int xilinx_pre_config_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + unsigned char tmp_char; + unsigned short tmp_short; + + /* first, set the required pins to GPIO function */ + /* PAR_T0IN -> GPIO */ + tmp_char = readb(&gpiop->par_timer); + tmp_char &= 0xfc; + writeb(tmp_char, &gpiop->par_timer); + /* all QSPI pins -> GPIO */ + writew(0x0000, &gpiop->par_qspi); + /* U0RTS, U0CTS -> GPIO */ + tmp_short = __raw_readw(&gpiop->par_uart); + tmp_short &= 0xfff3; + __raw_writew(tmp_short, &gpiop->par_uart); + /* all PWM pins -> GPIO */ + writeb(0x00, &gpiop->par_pwm); + /* next, set data direction registers */ + writeb(0x01, &gpiop->pddr_timer); + writeb(0x25, &gpiop->pddr_qspi); + writeb(0x0c, &gpiop->pddr_uart); + writeb(0x04, &gpiop->pddr_pwm); + + /* ensure other SPI peripherals are deselected */ + writeb(0x08, &gpiop->ppd_uart); + writeb(0x38, &gpiop->ppd_qspi); + writeb(0x01, &gpiop->ppd_timer); + + /* CONFIG = 0, STATUS = 0 -> FPGA in reset state */ + writeb(0xFB, &gpiop->pclrr_uart); + /* enable Xilinx configuration by clearing QSPI_CS2 and U0CTS */ + writeb(0xF7, &gpiop->pclrr_uart); + writeb(0xDF, &gpiop->pclrr_qspi); + return 0; +} + +/* + * FPGA post configuration function. Should perform a test if FPGA is running. + */ +int xilinx_post_config_fn(int cookie) +{ + int rc = 0; + + /* + * no test yet + */ + return rc; +} + +int xilinx_clk_fn(int assert_clk, int flush, int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (assert_clk) + writeb(0x04, &gpiop->ppd_qspi); + else + writeb(0xFB, &gpiop->pclrr_qspi); + return assert_clk; +} + +int xilinx_wr_fn(int assert_write, int flush, int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (assert_write) + writeb(0x01, &gpiop->ppd_qspi); + else + writeb(0xFE, &gpiop->pclrr_qspi); + return assert_write; +} + +int xilinx_fastwr_fn(void *buf, size_t len, int flush, int cookie) +{ + size_t bytecount = 0; + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + unsigned char *data = (unsigned char *)buf; + unsigned char val = 0; + int i; + int len_40 = len / 40; + + for (bytecount = 0; bytecount < len; bytecount++) { + val = *(data++); + for (i = 8; i > 0; i--) { + writeb(0xFB, &gpiop->pclrr_qspi); + if (val & 0x80) + writeb(0x01, &gpiop->ppd_qspi); + else + writeb(0xFE, &gpiop->pclrr_qspi); + writeb(0x04, &gpiop->ppd_qspi); + val <<= 1; + } + if (bytecount % len_40 == 0) { +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET(); +#endif +#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK + putc('.'); /* let them know we are alive */ +#endif +#ifdef CONFIG_SYS_FPGA_CHECK_CTRLC + if (ctrlc()) + return FPGA_FAIL; +#endif + } + } + return FPGA_SUCCESS; +} + +/* + * Note that these are pointers to code that is in Flash. They will be + * relocated at runtime. + * FIXME: relocation not yet working for coldfire, see below! + */ +Xilinx_Spartan3_Slave_Serial_fns xilinx_fns = { + xilinx_pre_config_fn, + xilinx_pgm_fn, + xilinx_clk_fn, + xilinx_init_fn, + xilinx_done_fn, + xilinx_wr_fn, + 0, + xilinx_fastwr_fn +}; + +Xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { + {Xilinx_Spartan3, + slave_serial, + XILINX_XC3S4000_SIZE, + (void *)&xilinx_fns, + 0} +}; + +/* Initialize the fpga. Return 1 on success, 0 on failure. */ +int astro5373l_xilinx_load(void) +{ + int i; + + fpga_init(); + + for (i = 0; i < CONFIG_FPGA_COUNT; i++) { + /* + * I did not yet manage to get relocation work properly, + * so set stuff here instead of static initialisation: + */ + xilinx_fns.pre = xilinx_pre_config_fn; + xilinx_fns.pgm = xilinx_pgm_fn; + xilinx_fns.clk = xilinx_clk_fn; + xilinx_fns.init = xilinx_init_fn; + xilinx_fns.done = xilinx_done_fn; + xilinx_fns.wr = xilinx_wr_fn; + xilinx_fns.bwr = xilinx_fastwr_fn; + xilinx_fpga[i].iface_fns = (void *)&xilinx_fns; + fpga_add(fpga_xilinx, &xilinx_fpga[i]); + } + return 1; +} diff --git a/board/astro/mcf5373l/mcf5373l.c b/board/astro/mcf5373l/mcf5373l.c new file mode 100644 index 0000000..3c09a21 --- /dev/null +++ b/board/astro/mcf5373l/mcf5373l.c @@ -0,0 +1,211 @@ +/* + * (C) Copyright 2000-2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * modified by Wolfgang Wegner w.wegner@astro-kom.de for ASTRO 5373l + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <watchdog.h> +#include <command.h> +#include <asm/m5329.h> +#include <asm/immap_5329.h> +#include <asm/io.h> + +/* needed for astro bus: */ +#include <asm/uart.h> +#include "astro.h" + +DECLARE_GLOBAL_DATA_PTR; +extern void uart_port_conf(void); + +int checkboard(void) +{ + puts("Board: "); + puts("ASTRO MCF5373L (Urmel) Board\n"); + return 0; +} + +phys_size_t initdram(int board_type) +{ +#if !defined(CONFIG_MONITOR_IS_IN_RAM) + sdram_t *sdp = (sdram_t *)(MMAP_SDRAM); + + /* + * GPIO configuration for bus should be set correctly from reset, + * so we do not care! First, set up address space: at this point, + * we should be running from internal SRAM; + * so use CONFIG_SYS_SDRAM_BASE as the base address for SDRAM, + * and do not care where it is + */ + __raw_writel((CONFIG_SYS_SDRAM_BASE & 0xFFF00000) | 0x00000018, + &sdp->cs0); + __raw_writel((CONFIG_SYS_SDRAM_BASE & 0xFFF00000) | 0x00000000, + &sdp->cs1); + /* + * I am not sure from the data sheet, but it seems burst length + * has to be 8 for the 16 bit data bus we use; + * so these values are for BL = 8 + */ + __raw_writel(0x33211530, &sdp->cfg1); + __raw_writel(0x56570000, &sdp->cfg2); + /* send PrechargeALL, REF and IREF remain cleared! */ + __raw_writel(0xE1462C02, &sdp->ctrl); + udelay(1); + /* refresh SDRAM twice */ + __raw_writel(0xE1462C04, &sdp->ctrl); + udelay(1); + __raw_writel(0xE1462C04, &sdp->ctrl); + /* init MR */ + __raw_writel(0x008D0000, &sdp->mode); + /* initialize EMR */ + __raw_writel(0x80010000, &sdp->mode); + /* wait until DLL is locked */ + udelay(1); + /* + * enable automatic refresh, lock mode register, + * clear iref and ipall + */ + __raw_writel(0x71462C00, &sdp->ctrl); + /* Dummy write to start SDRAM */ + writel(0, CONFIG_SYS_SDRAM_BASE); +#endif + + /* + * for get_ram_size() to work, both CS areas have to be + * configured, i.e. CS1 has to be explicitely disabled, else + * probing for memory will cause the SDRAM bus to hang! + * (Do not rely on the SDCS register(s) being set to 0x00000000 + * during reset as stated in the data sheet.) + */ + return get_ram_size((unsigned long *)CONFIG_SYS_SDRAM_BASE, + 0x80000000 - CONFIG_SYS_SDRAM_BASE); +} + +#define UART_BASE MMAP_UART0 +int rs_serial_init(int port, int baud) +{ + uart_t *uart; + u32 counter; + + switch (port) { + case 0: + uart = (uart_t *)(MMAP_UART0); + break; + case 1: + uart = (uart_t *)(MMAP_UART1); + break; + case 2: + uart = (uart_t *)(MMAP_UART2); + break; + default: + uart = (uart_t *)(MMAP_UART0); + } + + uart_port_conf(); + + /* write to SICR: SIM2 = uart mode,dcd does not affect rx */ + writeb(UART_UCR_RESET_RX, &uart->ucr); + writeb(UART_UCR_RESET_TX, &uart->ucr); + writeb(UART_UCR_RESET_ERROR, &uart->ucr); + writeb(UART_UCR_RESET_MR, &uart->ucr); + __asm__ ("nop"); + + writeb(0, &uart->uimr); + + /* write to CSR: RX/TX baud rate from timers */ + writeb(UART_UCSR_RCS_SYS_CLK | UART_UCSR_TCS_SYS_CLK, &uart->ucsr); + + writeb(UART_UMR_BC_8 | UART_UMR_PM_NONE, &uart->umr); + writeb(UART_UMR_SB_STOP_BITS_1, &uart->umr); + + /* Setting up BaudRate */ + counter = (u32) (gd->bus_clk / (baud)); + counter >>= 5; + + /* write to CTUR: divide counter upper byte */ + writeb((u8) ((counter & 0xff00) >> 8), &uart->ubg1); + /* write to CTLR: divide counter lower byte */ + writeb((u8) (counter & 0x00ff), &uart->ubg2); + + writeb(UART_UCR_RX_ENABLED | UART_UCR_TX_ENABLED, &uart->ucr); + + return 0; +} + +void astro_put_char(char ch) +{ + uart_t *uart; + unsigned long timer; + + uart = (uart_t *)(MMAP_UART0); + /* + * Wait for last character to go. Timeout of 6ms should + * be enough for our lowest baud rate of 2400. + */ + timer = get_timer(0); + while (get_timer(timer) < 6) { + if (readb(&uart->usr) & UART_USR_TXRDY) + break; + } + writeb(ch, &uart->utb); + + return; +} + +int astro_is_char(void) +{ + uart_t *uart; + + uart = (uart_t *)(MMAP_UART0); + return readb(&uart->usr) & UART_USR_RXRDY; +} + +int astro_get_char(void) +{ + uart_t *uart; + + uart = (uart_t *)(MMAP_UART0); + while (!(readb(&uart->usr) & UART_USR_RXRDY)) ; + return readb(&uart->urb); +} + +int misc_init_r(void) +{ + int retval = 0; + + puts("Configure Xilinx FPGA..."); + retval = astro5373l_xilinx_load(); + if (!retval) { + puts("failed!\n"); + return retval; + } + puts("done\n"); + + puts("Configure Altera FPGA..."); + retval = astro5373l_altera_load(); + if (!retval) { + puts("failed!\n"); + return retval; + } + puts("done\n"); + + return retval; +} diff --git a/board/astro/mcf5373l/u-boot.lds b/board/astro/mcf5373l/u-boot.lds new file mode 100644 index 0000000..a9a4e0a --- /dev/null +++ b/board/astro/mcf5373l/u-boot.lds @@ -0,0 +1,142 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(m68k) +/* Do we need any of these for elf? + __DYNAMIC = 0; */ +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + cpu/mcf532x/start.o (.text) + lib_m68k/traps.o (.text) + lib_m68k/interrupts.o (.text) + common/dlmalloc.o (.text) + lib_generic/zlib.o (.text) + + . = DEFINED(env_offset) ? env_offset : .; + common/env_embedded.o (.text) + + *(.text) +/* *(.fixup)*/ + *(.got1) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + + .reloc : + { + __got_start = .; + *(.got) + __got_end = .; + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss : + { + _sbss = .; + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + . = ALIGN(4); + _ebss = .; + } + _end = . ; + PROVIDE (end = .); +} diff --git a/board/astro/mcf5373l/update.c b/board/astro/mcf5373l/update.c new file mode 100644 index 0000000..63170b3 --- /dev/null +++ b/board/astro/mcf5373l/update.c @@ -0,0 +1,615 @@ +/* + * (C) Copyright 2006-2009 + * Adnan El-Bardawil a.el-bardawil@astro-kom.de + * Wolfgang Wegner w.wegner@astro-kom.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <watchdog.h> +#include <command.h> +#include <asm/m5329.h> +#include <asm/immap_5329.h> +#include <asm/io.h> +#include <flash.h> +#include "astro.h" + +#include <asm/uart.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define DEBUG_INFO 1 +#define DEBUG_ERROR 1 + +/* dummy software version to signal card is in boot loader */ +#define SOFTWARE_VERSION 0x00 +#define SOFTWARE_SUBVERSION ' ' + +typedef enum { + CMD_INIT = 0, + CMD_NEW, + CMD_TX, + CMD_RX, + CMD_RX_RDY, + CMD_RX_ERROR +} cmd_stat_e; + +#define INT_CMD_IDLE 0 +#define INT_CMD_FLASH_MODE 1 +#define INT_CMD_WRITE_FLASH 2 +#define INT_CMD_RESTART 4 + +#define FL_STAT_IDLE 0 +#define FL_STAT_ERASE 1 +#define FL_STAT_PROG 2 +#define FL_STAT_ERROR 4 + +/* + * UART update subcommand codes + */ + +#define F_SAVE_PARAMETERS 0x00 /* save parameters on card */ +#define F_READ_PARAMETERS 0x01 /* read parameters */ +#define F_READ_CARDINFO 0x10 /* read card information */ +#define F_READ_ERROR_STATUS 0x11 /* read card error */ +#define F_TRANSPARENT_DATA 0x20 /* length byte + data */ + +#define SC_PREPARE_FOR_FLASH_DATA 0xc0 +#define SC_FLASH_DATA 0xc1 +#define SC_CLEAR_CRC 0xc2 +#define SC_CHECK_CRC 0xc3 +#define SC_RESTART 0xc4 + +typedef struct { + unsigned char command; + unsigned char length; + unsigned char subcommand; +} rcv_cmd_t; + +card_id_t card_information; + +struct { + parameters_t a; + parameters_t b; +} parameters; + +typedef struct { + int cnt; + cmd_stat_e stat; +} upd_command_t; + +typedef struct { + int cnt; + int length; + unsigned char *buffer; +} comm_status_t; + +const unsigned long fl_base[3] = { 0x80000, 0x540000, 0x6c0000 }; +const char fl_type_str[3][6] = { "Kernel", "Xilinx", "Altera" }; + +/* info for FLASH chips */ +extern flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; + +unsigned long crc, crc_count; + +/* CRC divisor value */ +#define CRC_POLYNOM 0x800500 + +void do_crc(unsigned char data) +{ + unsigned char count; + + crc |= data; + for (count = 0; count < 8; count++) { + crc <<= 1; + if (crc & 0x1000000) + crc ^= CRC_POLYNOM; + } + crc_count++; +} + +static unsigned char flash_buffer[0x10000]; +static unsigned long flash_data_length, flash_data_count; +static unsigned long flash_prog_count, flash_sect_count; +static unsigned char flash_data_type, crc_en; +static int flash_prog_stat; +static unsigned char uart_buffer[64]; + +void fl_prog(int force_write) +{ + int s, i; + unsigned long fl_adr, fl_sector; + + fl_adr = fl_base[flash_data_type] + flash_prog_count; + fl_sector = fl_adr >> 17; + + switch (flash_prog_stat) { + case FL_STAT_IDLE: + if (((flash_prog_count & 0x1ffff) == 0) && + ((flash_prog_count >> 17) == flash_sect_count)) { + flash_protect(FLAG_PROTECT_CLEAR, fl_adr, + fl_adr + 0x1ffff, flash_info); + s = flash_erase_nb(flash_info, fl_sector); + flash_prog_stat = FL_STAT_ERASE; + } else if ((flash_data_count >= (flash_prog_count + 64)) + || (force_write + && (flash_data_count > flash_prog_count))) { + s = write_buff_nb(flash_info, + flash_buffer + + (flash_prog_count & 0xffff), + fl_adr, 64); + flash_prog_stat = FL_STAT_PROG; + } + break; + case FL_STAT_ERASE: + s = flash_full_status_check_nb(flash_info, fl_sector, + 0, "erase"); + if (s != ERR_BUSY) { + if (s == ERR_OK) { + flash_sect_count++; + flash_prog_stat = FL_STAT_IDLE; + } else { + flash_prog_stat = FL_STAT_ERROR; + } + } + break; + case FL_STAT_PROG: + s = flash_full_status_check_nb(flash_info, fl_sector, + 0, "write"); + if (s == ERR_BUSY) + return; + + if (s != ERR_OK) { + flash_prog_stat = FL_STAT_ERROR; + return; + } + + flash_prog_stat = FL_STAT_IDLE; + for (i = 0; i < 64; i++) { + if (flash_buffer[(flash_prog_count + i) & 0xffff] != + *((unsigned char *)fl_adr + i)) + flash_prog_stat = FL_STAT_ERROR; + } + if ((flash_prog_count & 0xfff) == 0) + printf("."); + flash_prog_count += 64; + if (((flash_prog_count & 0x1ffff) == 0) + || (force_write + && (flash_data_count <= flash_prog_count))) { + flash_protect(FLAG_PROTECT_SET, + fl_adr & 0xfffe0000, + fl_adr | 0x1ffff, + flash_info); + } + break; + } +} + +void handle_rx_char(unsigned char rx_data, upd_command_t *cmd, + int *rcv_cnt, rcv_cmd_t *rcv_cmd, + comm_status_t *rx_stat) +{ + uart_t *uart; + + uart = (uart_t *)(MMAP_UART0); + if (readb(&uart->usr) & UART_USR_OE) { +#if DEBUG_ERROR + printf("UART FIFO Overrun Error!\n"); +#endif + writeb(UART_UCR_RESET_ERROR, &uart->ucr); + cmd->stat = CMD_RX_ERROR; + } + if (cmd->stat == CMD_INIT) { + if (*rcv_cnt == 0) { + /* First received Byte is the Command */ + rcv_cmd->command = rx_data; + /* non-Transparent Data: start Command Processing */ + if (rcv_cmd->command != F_TRANSPARENT_DATA) { + cmd->stat = CMD_NEW; + cmd->cnt++; + } else { + (*rcv_cnt)++; + } + } else { + /* Length and Subcommand for Transparent Data */ + if (*rcv_cnt == 1) { + rcv_cmd->length = rx_data; + (*rcv_cnt)++; + } else { + rcv_cmd->subcommand = rx_data; + cmd->stat = CMD_NEW; + cmd->cnt++; + } + } + } else if (cmd->stat == CMD_RX) { + /* Store received Data to Rx Buffer */ + rx_stat->buffer[rx_stat->cnt] = rx_data; + if (crc_en) + do_crc(rx_data); + (rx_stat->cnt)++; + if (rx_stat->cnt == rx_stat->length) + cmd->stat = CMD_RX_RDY; + } +} + +/* + * handle a transparent data command; these are used for software update + * return value is 1 if cmd_stat is set to CMD_INIT to let caller decide + * to reset the receive count, else 0. + */ +int handle_transparent_command(upd_command_t *cmd, rcv_cmd_t *rcv_cmd, + comm_status_t *rx_stat, comm_status_t *tx_stat, + unsigned char *int_command) +{ + int i; + unsigned char crc_status; + + if (cmd->stat == CMD_NEW) { + rx_stat->cnt = 0; + rx_stat->length = rcv_cmd->length - 1; + } + switch (rcv_cmd->subcommand) { + case SC_PREPARE_FOR_FLASH_DATA: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = uart_buffer; + cmd->stat = CMD_RX; + } else if (cmd->stat == CMD_RX_RDY) { + for (i = 0; i < 4; i++) + flash_data_length = (flash_data_length << 8) + + uart_buffer[i + 1]; + flash_data_type = uart_buffer[0]; +#if DEBUG_INFO + printf(" -- Flash Programming Initialized -- \n"); + printf(" -- Receiving %lu Bytes of type ", + flash_data_length); + for (i = 0; i < 6; i++) + printf("%c", fl_type_str[flash_data_type][i]); + printf(" [0x%lx]\n", fl_base[flash_data_type]); +#endif + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + crc_count = 0; + crc = 0; + flash_data_count = 0; + flash_prog_count = 0; + flash_sect_count = 0; + flash_prog_stat = FL_STAT_IDLE; + crc_en = 0; + *int_command = INT_CMD_FLASH_MODE; + cmd->stat = CMD_TX; + return 1; + } + break; + case SC_FLASH_DATA: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = flash_buffer + + (flash_data_count & 0xffff); + rx_stat->cnt = 0; + cmd->stat = CMD_RX; + crc_en = 1; + } else if (cmd->stat == CMD_RX_RDY) { + crc_en = 0; + flash_data_count += rcv_cmd->length - 1; + cmd->stat = CMD_INIT; + return 1; + } + break; + case SC_CLEAR_CRC: + if (cmd->stat == CMD_NEW) { + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + cmd->stat = CMD_TX; + crc_count = 0; + crc = 0; + } + break; + case SC_CHECK_CRC: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = uart_buffer; + cmd->stat = CMD_RX; + } else if (cmd->stat == CMD_RX_RDY) { + if ((flash_data_count <= flash_prog_count) + || (flash_prog_stat == FL_STAT_ERROR)) { + crc_status = 0; + if (uart_buffer[0] != ((crc >> 16) & 0xff)) + crc_status = 1; + if (uart_buffer[1] != ((crc >> 8) & 0xff)) + crc_status = 1; + if (flash_prog_stat == FL_STAT_ERROR) + crc_status |= 2; + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 4; + uart_buffer[2] = rcv_cmd->subcommand; + uart_buffer[3] = (crc >> 16); + uart_buffer[4] = (crc >> 8); + uart_buffer[5] = crc_status; +#if DEBUG_INFO + printf(" CRC %u / %lu of %lu kB \n", + crc_status, + (flash_data_count >> 10), + (flash_data_length >> 10)); +#endif + tx_stat->buffer = uart_buffer; + tx_stat->length = 6; + cmd->stat = CMD_TX; + if (crc_status) { + flash_prog_count = + flash_data_count = + (flash_data_count & 0xffff0000) + - 0x10000; + flash_prog_stat = FL_STAT_IDLE; + *int_command = INT_CMD_FLASH_MODE; + } + } + if (flash_data_count & 0xffff) + *int_command |= INT_CMD_WRITE_FLASH; + } + break; + case SC_RESTART: + if (cmd->stat == CMD_NEW) { + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + cmd->stat = CMD_TX; + crc_count = 0; + crc = 0; + /* + * set restart command; sending the reply + * is done before finishing the loop. + */ + *int_command = INT_CMD_RESTART; + return 1; + } + break; + default: + /* + * for un-handled zero length transparent command, + * we have to handle this condition first! + */ + if ((cmd->stat == CMD_RX_RDY) + || (rx_stat->cnt == rx_stat->length)) + cmd->stat = CMD_INIT; + else if (cmd->stat == CMD_NEW) + cmd->stat = CMD_RX; + } + return 0; +} + +/* + * handle a general command (i.e. status and version information query) + * return value is always 0 except for transparent data where the + * return code is passed through to allow caller reset receive count. + */ +int handle_command(upd_command_t *cmd, rcv_cmd_t *rcv_cmd, + comm_status_t *rx_stat, comm_status_t *tx_stat, + unsigned char *int_command) +{ + int rv = 0; + + switch (rcv_cmd->command) { + case F_READ_ERROR_STATUS: +#if DEBUG_INFO + printf("read error status\n"); +#endif + uart_buffer[0] = 0; + uart_buffer[1] = 0; + uart_buffer[2] = 0; + uart_buffer[3] = 0; + tx_stat->buffer = uart_buffer; + tx_stat->length = 4; + cmd->stat = CMD_TX; + break; + case F_READ_PARAMETERS: + if (cmd->stat == CMD_NEW) { +#if DEBUG_INFO + printf("read parameters\n"); +#endif + memcpy(uart_buffer, (unsigned char *)¶meters.a, + 2 * sizeof(parameters_t)); + cmd->stat = CMD_TX; + tx_stat->length = 2 * sizeof(parameters_t); + } + break; + case F_READ_CARDINFO: +#if DEBUG_INFO + printf("read card info\n"); +#endif + card_information.software_version = + ((*int_command) & INT_CMD_FLASH_MODE) ? + 0xEE : SOFTWARE_VERSION; + tx_stat->buffer = (unsigned char *)&card_information; + tx_stat->length = 5; + cmd->stat = CMD_TX; + break; + + case F_TRANSPARENT_DATA: + rv = handle_transparent_command(cmd, rcv_cmd, rx_stat, + tx_stat, int_command); + break; + } + return rv; +} + +/* transmit data prepared in comm_status_t structure */ +void transmit_buffer(comm_status_t *tx_stat) +{ + int cnt; + for (cnt = 0; cnt < tx_stat->length; cnt++) + astro_put_char(tx_stat->buffer[cnt]); +} + +int do_update(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + unsigned char rx_data; + comm_status_t rx_stat, tx_stat; + upd_command_t cmd; + int rcv_cnt; + rcv_cmd_t rcv_cmd; + unsigned char int_command, tmp_char; + unsigned short tmp_short; + + int select, old_select, got_char; + eport_t *eport = (eport_t *)MMAP_EPORT; + gpio_t *gpio = (gpio_t *)MMAP_GPIO; + uart_t *uart = (uart_t *)MMAP_UART0; + char *env_string; + + cmd.cnt = 0; + + /* we set some dummy parameters to make the protocol work */ + card_information.card_type = ASTRO_ID; + env_string = getenv("loaderversion"); + if (env_string != NULL) { + card_information.hardware_version = + (int)simple_strtol(env_string, NULL, 16); + } else { + card_information.hardware_version = 0x10; + } + card_information.software_version = SOFTWARE_VERSION; + card_information.software_subversion = SOFTWARE_SUBVERSION; + card_information.fpga_version_altera = 0x12; + card_information.fpga_version_xilinx = 0x13; + + parameters.a.symbolrate = 0x5027; + parameters.a.viterbirate = 0x34; + parameters.a.satfreq = 0x6616; + parameters.a.card_error = 0; + + parameters.b.symbolrate = 0x5027; + parameters.b.viterbirate = 0x34; + parameters.b.satfreq = 0x6616; + parameters.b.card_error = 0; + + puts("Initializing serial port to ASTRO bus...\n"); + /* init serial port */ + rs_serial_init(0, 2400); + /* set UART pin for UART */ + tmp_short = __raw_readw(&gpio->par_uart); + tmp_short |= 0x0003; + __raw_writew(tmp_short, &gpio->par_uart); + /* set select pin as GPIO */ + tmp_short = __raw_readw(&gpio->par_irq); + tmp_short &= 0x0FF0; + __raw_writew(tmp_short, &gpio->par_irq); + /* set select pin as input */ + tmp_char = readb(&eport->pdr); + tmp_char &= 0xBF; + writeb(tmp_char, &eport->pdr); + /* + * set interrupt to both falling and rising edge + * (no IRQ used, though) + */ + tmp_short = __raw_readw(&eport->par); + tmp_short |= 0x3000; + __raw_writew(tmp_short, &eport->par); + + int_command = INT_CMD_IDLE; + + rcv_cnt = 0; + cmd.stat = CMD_INIT; + old_select = 0; /* always start from "deselected" state */ + rx_data = 0xFF; + + while (int_command != INT_CMD_RESTART) { + +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET(); +#endif + + /* Flash program routine only called in flash mode */ + if (int_command & INT_CMD_FLASH_MODE) + fl_prog(int_command & INT_CMD_WRITE_FLASH); + + /* + * UART Card Select Routine + * Write ID on Card Select and switch baud rate + */ + select = ((readb(&eport->pdr) & 0x40) == 0x0); + + if ((select) && (!old_select)) { + /* set low baud rate for ID only */ + rs_serial_init(0, 2400); + astro_put_char(ASTRO_ID); + + /* Wait for TX finished before switching baudrate */ + while ((readb(&uart->usr) & UART_USR_TXEMP) == 0) { + } + + /* set high baud rate */ + rs_serial_init(0, 115200); + /* Reset the Receive Byte Counter */ + rcv_cnt = 0; + cmd.stat = CMD_INIT; + } else if ((!select) && old_select && (cmd.stat != CMD_INIT)) { + cmd.stat = CMD_INIT; +#if DEBUG_ERROR + printf("Command %u: 0x%02x (0x%02x) failed," + " len %d, cnt %d\n", + cmd.cnt, rcv_cmd.command, + rcv_cmd.subcommand, rcv_cmd.length, + rx_stat.cnt); +#endif + } + + old_select = select; + + got_char = astro_is_char(); + if (got_char) + rx_data = astro_get_char(); + + if (select) { + /* UART RX Routine */ + if (got_char) + handle_rx_char(rx_data, &cmd, &rcv_cnt, + &rcv_cmd, &rx_stat); + + /* Command Control Routine */ + if ((cmd.stat == CMD_NEW) + || (cmd.stat == CMD_RX_RDY)) { + if (handle_command(&cmd, &rcv_cmd, + &rx_stat, &tx_stat, + &int_command)) + rcv_cnt = 0; + } + + /* UART TX Routine */ + if (cmd.stat == CMD_TX) { + transmit_buffer(&tx_stat); + /* Reset the Receive Byte Counter */ + rcv_cnt = 0; + cmd.stat = CMD_INIT; + } + } + } + /* restart is done outside, so we simply leave this function */ + return 0; +} + +U_BOOT_CMD(update, 1, 1, do_update, + "automatic update via ASTRO bus", + "\n - start the update, waiting for transfer via bus"); diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h new file mode 100644 index 0000000..2a580dd --- /dev/null +++ b/include/configs/astro_mcf5373l.h @@ -0,0 +1,384 @@ +/* + * Configuration settings for the Sentec Cobra Board. + * + * (C) Copyright 2003 Josef Baumgartner josef.baumgartner@telex.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * configuration for ASTRO "Urmel" board. + * Originating from Cobra5272 configuration, messed up by + * Wolfgang Wegner w.wegner@astro-kom.de + * Please do not bother the original author with bug reports + * concerning this file. + */ + +#ifndef _CONFIG_ASTRO_MCF5373L_H +#define _CONFIG_ASTRO_MCF5373L_H + +/* + * set the card type to actually compile for; either of + * the possibilities listed below has to be used! + */ +#define CONFIG_ASTRO_V532 1 + +#if CONFIG_ASTRO_V532 +#define ASTRO_ID 0xF8 +#elif CONFIG_ASTRO_V512 +#define ASTRO_ID 0xFA +#elif CONFIG_ASTRO_TWIN7S2 +#define ASTRO_ID 0xF9 +#elif CONFIG_ASTRO_V912 +#define ASTRO_ID 0xFC +#elif CONFIG_ASTRO_COFDMDUOS2 +#define ASTRO_ID 0xFB +#else +#error No card type defined! +#endif + +/* + * Define processor + * possible values for Urmel board: only Coldfire M5373 processor supported + * (please do not change) + */ + +/* it seems not clear yet which processor defines we should use */ +#define CONFIG_MCF537x /* define processor family */ +#define CONFIG_MCF532x /* define processor family */ +#define CONFIG_M5373 /* define processor type */ +#define CONFIG_ASTRO5373L /* define board type */ + +/* Command line configuration */ +#include <config_cmd_default.h> + +/* + * CONFIG_MK_RAM defines if u-boot is loaded via BDM (or started from + * a different bootloader that has already performed RAM setup) or + * started directly from flash, which is the regular case for production + * boards. + */ +#ifdef CONFIG_MK_RAM +#define CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_TEXT_BASE 0x40020000 +#define ENABLE_JFFS 0 +#else +#define CONFIG_TEXT_BASE 0x00000000 +#define ENABLE_JFFS 1 +#endif + +/* Define which commmands should be available at u-boot command prompt */ + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DATE +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_MISC +#define CONFIG_CMD_XIMG +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#if ENABLE_JFFS +#define CONFIG_CMD_JFFS2 +#endif +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_LOADB +#define CONFIG_CMD_FPGA +#define CONFIG_CMDLINE_EDITING + +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_MCFRTC +#undef RTC_DEBUG + +/* Timer */ +#define CONFIG_MCFTMR +#undef CONFIG_MCFPIT + +/* I2C */ +#define CONFIG_FSL_I2C +#define CONFIG_HARD_I2C /* I2C with hw support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_SYS_I2C_SPEED 80000 +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_OFFSET 0x58000 +#define CONFIG_SYS_IMMR CONFIG_SYS_MBAR + +/* + * Defines processor clock - important for correct timings concerning serial + * interface etc. + * CONFIG_SYS_HZ gives unit: 1000 -> 1 Hz ^= 1000 ms + */ + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_CLK 80000000 +#define CONFIG_SYS_CPU_CLK (CONFIG_SYS_CLK * 3) +#define CONFIG_SYS_SDRAM_SIZE 32 /* SDRAM size in MB */ + +#define CONFIG_SYS_CORE_SRAM_SIZE 0x8000 +#define CONFIG_SYS_CORE_SRAM 0x80000000 + +#define CONFIG_SYS_UNIFY_CACHE + +/* + * Define baudrate for UART1 (console output, tftp, ...) + * default value of CONFIG_BAUDRATE for Sentec board: 19200 baud + * CONFIG_SYS_BAUDRATE_TABLE defines values that can be selected + * in u-boot command interface + */ + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600 , 19200 , 38400 , 57600, 115200 } + +#define CONFIG_MCFUART +#define CONFIG_SYS_UART_PORT (2) +#define CONFIG_SYS_UART2_ALT3_GPIO + +/* + * Watchdog configuration; Watchdog is disabled for running from RAM + * and set to highest possible value else. Beware there is no check + * in the watchdog code to validate the timeout value set here! + */ + +#ifndef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_WATCHDOG +#define CONFIG_WATCHDOG_TIMEOUT 3355 /* timeout in milliseconds */ +#endif + +/* + * Configuration for environment + * Environment is located in the last sector of the flash + */ + +#ifndef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_ENV_OFFSET 0x1FF8000 +#define CONFIG_ENV_SECT_SIZE 0x8000 +#define CONFIG_ENV_IS_IN_FLASH 1 +#else +/* + * environment in RAM - This is used to use a single PC-based application + * to load an image, load U-Boot, load an environment and then start U-Boot + * to execute the commands from the environment. Feedback is done via setting + * and reading memory locations. + */ +#define CONFIG_ENV_ADDR 0x40060000 +#define CONFIG_ENV_SECT_SIZE 0x8000 +#define CONFIG_ENV_IS_IN_FLASH 1 +#endif + +/* here we put our FPGA configuration... */ +#define CONFIG_MISC_INIT_R 1 + +/* Define user parameters that have to be customized most likely */ + +/* AUTOBOOT settings - booting images automatically by u-boot after power on */ + +/* + * used for autoboot, delay in seconds u-boot will wait before starting + * defined (auto-)boot command, setting to -1 disables delay, setting to + * 0 will too prevent access to u-boot command interface: u-boot then has + * to be reflashed + * beware - watchdog is not serviced during autoboot delay time! + */ +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_BOOTDELAY 1 +#else +#define CONFIG_BOOTDELAY 1 +#endif + +/* + * The following settings will be contained in the environment block ; if you + * want to use a neutral environment all those settings can be manually set in + * u-boot: 'set' command + */ + +#define _QUOTEME(x) #x +#define QUOTEME(x) _QUOTEME(x) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loaderversion=11\0" \ + "card_id="QUOTEME(ASTRO_ID)"\0" \ + "alterafile=0\0" \ + "xilinxfile=0\0" \ + "xilinxload=imxtract 0x540000 $xilinxfile 0x41000000&&"\ + "fpga load 0 0x41000000 $filesize\0" \ + "alteraload=imxtract 0x6c0000 $alterafile 0x41000000&&"\ + "fpga load 1 0x41000000 $filesize\0" \ + "env_default=1\0" \ + "env_check=if test $env_default -eq 1;"\ + " then setenv env_default 0;saveenv;fi\0" + +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_BOOTCOMMAND "" /* no autoboot in this case */ +#else +#if CONFIG_ASTRO_V532 +#define CONFIG_BOOTCOMMAND "protect off 0x80000 0x1ffffff;run env_check;"\ + "run xilinxload&&run alteraload&&bootm 0x80000;"\ + "update;reset" +#else +#define CONFIG_BOOTCOMMAND "protect off 0x80000 0x1ffffff;run env_check;"\ + "run xilinxload&&bootm 0x80000;update;reset" +#endif +#endif + +/* default bootargs that are considered during boot */ +#define CONFIG_BOOTARGS " console=ttyS2,115200 rootfstype=romfs"\ + " loaderversion=$loaderversion" + +#define CONFIG_SYS_PROMPT "URMEL > " + +/* default RAM address for user programs */ +#define CONFIG_SYS_LOAD_ADDR 0x20000 + +#define CONFIG_SYS_LONGHELP + +#if (CONFIG_COMMANDS & CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 +#else +#define CONFIG_SYS_CBSIZE 256 +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_FPGA_COUNT 1 +#define CONFIG_FPGA +#define CONFIG_FPGA_XILINX +#define CONFIG_FPGA_SPARTAN3 +#define CONFIG_FPGA_ALTERA +#define CONFIG_FPGA_CYCLON2 +#define CONFIG_SYS_FPGA_PROG_FEEDBACK +#define CONFIG_SYS_FPGA_WAIT 1000 + +/* End of user parameters to be customized */ + +/* Defines memory range for test */ + +#define CONFIG_SYS_MEMTEST_START 0x40020000 +#define CONFIG_SYS_MEMTEST_END 0x41ffffff + +/* + * Low Level Configuration Settings + * (address mappings, register initial values, etc.) + * You should know what you are doing if you make changes here. + */ + +/* Base register address */ + +#define CONFIG_SYS_MBAR 0xFC000000 /* Register Base Addrs */ + +/* System Conf. Reg. & System Protection Reg. */ + +#define CONFIG_SYS_SCR 0x0003; +#define CONFIG_SYS_SPR 0xffff; + +/* + * Definitions for initial stack pointer and data area (in internal SRAM) + */ +#define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 +#define CONFIG_SYS_INIT_RAM_END 0x8000 +#define CONFIG_SYS_INIT_RAM_CTRL 0x221 +#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ + CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +/* + * Start addresses for the final memory configuration + * (Set up by the startup code) + * for MCF5373, the allowable range is 0x40000000 to 0x7FF00000 + */ +#define CONFIG_SYS_SDRAM_BASE 0x40000000 + +/* + * Chipselect bank definitions + * + * CS0 - Flash 32MB (first 16MB) + * CS1 - Flash 32MB (second half) + * CS2 - FPGA + * CS3 - FPGA + * CS4 - unused + * CS5 - unused + */ +#define CONFIG_SYS_CS0_BASE 0 +#define CONFIG_SYS_CS0_MASK 0x00ff0001 +#define CONFIG_SYS_CS0_CTRL 0x00001fc0 + +#define CONFIG_SYS_CS1_BASE 0x01000000 +#define CONFIG_SYS_CS1_MASK 0x00ff0001 +#define CONFIG_SYS_CS1_CTRL 0x00001fc0 + +#define CONFIG_SYS_CS2_BASE 0x20000000 +#define CONFIG_SYS_CS2_MASK 0x00ff0001 +#define CONFIG_SYS_CS2_CTRL 0x0000fec0 + +#define CONFIG_SYS_CS3_BASE 0x21000000 +#define CONFIG_SYS_CS3_MASK 0x00ff0001 +#define CONFIG_SYS_CS3_CTRL 0x0000fec0 + +#define CONFIG_SYS_FLASH_BASE 0x00000000 + +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_SYS_MONITOR_BASE CONFIG_TEXT_BASE +#else +/* This is mainly used during relocation in start.S */ +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_FLASH_BASE + 0x400) +#endif +/* Reserve 256 kB for Monitor */ +#define CONFIG_SYS_MONITOR_LEN (256 << 10) + +#define CONFIG_SYS_BOOTPARAMS_LEN (64 * 1024) +/* Reserve 128 kB for malloc() */ +#define CONFIG_SYS_MALLOC_LEN (128 << 10) + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization ?? + */ +#define CONFIG_SYS_BOOTMAPSZ (CONFIG_SYS_SDRAM_BASE + \ + (CONFIG_SYS_SDRAM_SIZE << 20)) + +/* FLASH organization */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 259 +#define CONFIG_SYS_FLASH_ERASE_TOUT 1000 + +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_SIZE 0x2000000 +#define CONFIG_SYS_FLASH_PROTECTION 1 +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 +#define CONFIG_SYS_FLASH_CFI_NONBLOCK 1 + +#if ENABLE_JFFS +/* JFFS Partition offset set */ +#define CONFIG_SYS_JFFS2_FIRST_BANK 0 +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 +/* 512k reserved for u-boot */ +#define CONFIG_SYS_JFFS2_FIRST_SECTOR 0x40 +#endif + +/* Cache Configuration */ +#define CONFIG_SYS_CACHELINE_SIZE 16 + +#endif /* _CONFIG_ASTRO_MCF5373L_H */
This patch adds support for ASTRO board(s) based on MCF5373L.
Signed-off-by: Wolfgang Wegner w.wegner@astro-kom.de --- v4->v5: removed update.c and reference to non-blocking CFI to get at least the board included v3->v4: fixed multi-line comments v2->v3: fixed another load of coding style issues after finding out about checkpatch.pl... I hope to have addressed all the comments and errors that were present in the first submission; exceptions are the linker script because there was no feedback by Tsi Chung Liew on this issue, the crc routine because the update protocol is fixed and uses this (as far as I can see) non-standard CRC polynomial, and a single 81 character line in the configuration file because I see no sensible way to break it. This patch (or the boot script/images) relies on the following previously sent patches: add include/asm-m68k/unaligned.h (Message-Id 1260376332-15835-1-git-send-email-w.wegner@astro-kom.de) add ability to handle compressed images to imxtract (Message-Id 1260436281-31824-1-git-send-email-w.wegner@astro-kom.de) add block write function to spartan3 slave serial load (Message-Id 1256918102-3760-1-git-send-email-w.wegner@astro-kom.de) allow MCF532x to use CONFIG_MONITOR_IS_IN_RAM (Message-Id 1256739061-13311-2-git-send-email-w.wegner@astro-kom.de) MCF532x: make icache_enable use CONFIG_SYS_SDRAM_SIZE (Message-Id 1256739061-13311-1-git-send-email-w.wegner@astro-kom.de)
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 4 + board/astro/mcf5373l/Makefile | 44 ++++ board/astro/mcf5373l/astro.h | 44 ++++ board/astro/mcf5373l/config.mk | 27 +++ board/astro/mcf5373l/fpga.c | 425 ++++++++++++++++++++++++++++++++++++++ board/astro/mcf5373l/mcf5373l.c | 211 +++++++++++++++++++ board/astro/mcf5373l/u-boot.lds | 142 +++++++++++++ include/configs/astro_mcf5373l.h | 389 ++++++++++++++++++++++++++++++++++ 10 files changed, 1291 insertions(+), 0 deletions(-) create mode 100644 board/astro/mcf5373l/Makefile create mode 100644 board/astro/mcf5373l/astro.h create mode 100644 board/astro/mcf5373l/config.mk create mode 100644 board/astro/mcf5373l/fpga.c create mode 100644 board/astro/mcf5373l/mcf5373l.c create mode 100644 board/astro/mcf5373l/u-boot.lds create mode 100644 include/configs/astro_mcf5373l.h
diff --git a/board/astro/mcf5373l/Makefile b/board/astro/mcf5373l/Makefile new file mode 100644 index 0000000..c7a1d05 --- /dev/null +++ b/board/astro/mcf5373l/Makefile @@ -0,0 +1,44 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS = $(BOARD).o fpga.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/astro/mcf5373l/astro.h b/board/astro/mcf5373l/astro.h new file mode 100644 index 0000000..b55a6f7 --- /dev/null +++ b/board/astro/mcf5373l/astro.h @@ -0,0 +1,44 @@ +#ifndef __ASTRO_H__ +#define __ASTRO_H__ + +/* in mcf5373l.c */ +int rs_serial_init(int port, int baud); +void astro_put_char(char ch); +int astro_is_char(void); +int astro_get_char(void); + +/* in fpga.c */ +int astro5373l_altera_load(void); +int astro5373l_xilinx_load(void); + +/* data structures used for communication (update.c) */ +typedef struct card_id { + char card_type; + char hardware_version; + char software_version; + char software_subversion; /* " ","a".."z" */ + char fpga_version_altera; + char fpga_version_xilinx; +} card_id_t; + +typedef struct { + unsigned char mode; + unsigned char deviation; + unsigned short freq; +} __attribute__ ((packed)) output_params_t; + +typedef struct { + unsigned short satfreq; + unsigned char satdatallg; + unsigned short symbolrate; + unsigned char viterbirate; + unsigned char symbolrate_l; + output_params_t output_params; + unsigned char reserve; + unsigned char card_error; + unsigned short dummy_ts_id; + unsigned char dummy_pat_ver; + unsigned char dummy_sdt_ver; +} __attribute__ ((packed)) parameters_t; + +#endif /* __ASTRO_H__ */ diff --git a/board/astro/mcf5373l/config.mk b/board/astro/mcf5373l/config.mk new file mode 100644 index 0000000..6316a30 --- /dev/null +++ b/board/astro/mcf5373l/config.mk @@ -0,0 +1,27 @@ +# +# (C) Copyright 2000-2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# Coldfire contribution by Bernhard Kuhn bkuhn@metrowerks.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +TEXT_BASE = $(CONFIG_TEXT_BASE) + +PLATFORM_CPPFLAGS += -DTEXT_BASE=$(TEXT_BASE) diff --git a/board/astro/mcf5373l/fpga.c b/board/astro/mcf5373l/fpga.c new file mode 100644 index 0000000..467461b --- /dev/null +++ b/board/astro/mcf5373l/fpga.c @@ -0,0 +1,425 @@ +/* + * (C) Copyright 2006 + * Wolfgang Wegner, ASTRO Strobel Kommunikationssysteme GmbH, + * w.wegner@astro-kom.de + * + * based on the files by + * Heiko Schocher, DENX Software Engineering, hs@denx.de + * and + * Rich Ireland, Enterasys Networks, rireland@enterasys.com. + * Keith Outwater, keith_outwater@mvis.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +/* Altera/Xilinx FPGA configuration support for the ASTRO "URMEL" board */ + +#include <common.h> +#include <watchdog.h> +#include <altera.h> +#include <ACEX1K.h> +#include <spartan3.h> +#include <command.h> +#include <asm/immap_5329.h> +#include <asm/io.h> +#include "fpga.h" + +DECLARE_GLOBAL_DATA_PTR; + +int altera_pre_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + unsigned char tmp_char; + unsigned short tmp_short; + + /* first, set the required pins to GPIO function */ + /* PAR_T0IN -> GPIO */ + tmp_char = readb(&gpiop->par_timer); + tmp_char &= 0xfc; + writeb(tmp_char, &gpiop->par_timer); + /* all QSPI pins -> GPIO */ + writew(0x0000, &gpiop->par_qspi); + /* U0RTS, U0CTS -> GPIO */ + tmp_short = __raw_readw(&gpiop->par_uart); + tmp_short &= 0xfff3; + __raw_writew(tmp_short, &gpiop->par_uart); + /* all PWM pins -> GPIO */ + writeb(0x00, &gpiop->par_pwm); + /* next, set data direction registers */ + writeb(0x01, &gpiop->pddr_timer); + writeb(0x25, &gpiop->pddr_qspi); + writeb(0x0c, &gpiop->pddr_uart); + writeb(0x04, &gpiop->pddr_pwm); + + /* ensure other SPI peripherals are deselected */ + writeb(0x08, &gpiop->ppd_uart); + writeb(0x38, &gpiop->ppd_qspi); + + /* CONFIG = 0 STATUS = 0 -> FPGA in reset state */ + writeb(0xFB, &gpiop->pclrr_uart); + /* enable Altera configuration by clearing QSPI_CS2 and DT0IN */ + writeb(0xFE, &gpiop->pclrr_timer); + writeb(0xDF, &gpiop->pclrr_qspi); + return FPGA_SUCCESS; +} + +/* Set the state of CONFIG Pin */ +int altera_config_fn(int assert_config, int flush, int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (assert_config) + writeb(0x04, &gpiop->ppd_uart); + else + writeb(0xFB, &gpiop->pclrr_uart); + return FPGA_SUCCESS; +} + +/* Returns the state of STATUS Pin */ +int altera_status_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (readb(&gpiop->ppd_pwm) & 0x08) + return FPGA_FAIL; + return FPGA_SUCCESS; +} + +/* Returns the state of CONF_DONE Pin */ +int altera_done_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (readb(&gpiop->ppd_pwm) & 0x20) + return FPGA_FAIL; + return FPGA_SUCCESS; +} + +/* + * writes the complete buffer to the FPGA + * writing the complete buffer in one function is much faster, + * then calling it for every bit + */ +int altera_write_fn(void *buf, size_t len, int flush, int cookie) +{ + size_t bytecount = 0; + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + unsigned char *data = (unsigned char *)buf; + unsigned char val = 0; + int i; + int len_40 = len / 40; + + while (bytecount < len) { + val = data[bytecount++]; + i = 8; + do { + writeb(0xFB, &gpiop->pclrr_qspi); + if (val & 0x01) + writeb(0x01, &gpiop->ppd_qspi); + else + writeb(0xFE, &gpiop->pclrr_qspi); + writeb(0x04, &gpiop->ppd_qspi); + val >>= 1; + i--; + } while (i > 0); + + if (bytecount % len_40 == 0) { +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET(); +#endif +#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK + putc('.'); /* let them know we are alive */ +#endif +#ifdef CONFIG_SYS_FPGA_CHECK_CTRLC + if (ctrlc()) + return FPGA_FAIL; +#endif + } + } + return FPGA_SUCCESS; +} + +/* called, when programming is aborted */ +int altera_abort_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + writeb(0x20, &gpiop->ppd_qspi); + writeb(0x08, &gpiop->ppd_uart); + return FPGA_SUCCESS; +} + +/* called, when programming was succesful */ +int altera_post_fn(int cookie) +{ + return altera_abort_fn(cookie); +} + +/* + * Note that these are pointers to code that is in Flash. They will be + * relocated at runtime. + * FIXME: relocation not yet working for coldfire, see below! + */ +Altera_CYC2_Passive_Serial_fns altera_fns = { + altera_pre_fn, + altera_config_fn, + altera_status_fn, + altera_done_fn, + altera_write_fn, + altera_abort_fn, + altera_post_fn +}; + +Altera_desc altera_fpga[CONFIG_FPGA_COUNT] = { + {Altera_CYC2, + passive_serial, + 85903, + (void *)&altera_fns, + NULL, + 0} +}; + +/* Initialize the fpga. Return 1 on success, 0 on failure. */ +int astro5373l_altera_load(void) +{ + int i; + + for (i = 0; i < CONFIG_FPGA_COUNT; i++) { + /* + * I did not yet manage to get relocation work properly, + * so set stuff here instead of static initialisation: + */ + altera_fns.pre = altera_pre_fn; + altera_fns.config = altera_config_fn; + altera_fns.status = altera_status_fn; + altera_fns.done = altera_done_fn; + altera_fns.write = altera_write_fn; + altera_fns.abort = altera_abort_fn; + altera_fns.post = altera_post_fn; + altera_fpga[i].iface_fns = (void *)&altera_fns; + fpga_add(fpga_altera, &altera_fpga[i]); + } + return 1; +} + +/* Set the FPGA's PROG_B line to the specified level */ +int xilinx_pgm_fn(int assert, int flush, int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (assert) + writeb(0xFB, &gpiop->pclrr_uart); + else + writeb(0x04, &gpiop->ppd_uart); + return assert; +} + +/* + * Test the state of the active-low FPGA INIT line. Return 1 on INIT + * asserted (low). + */ +int xilinx_init_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + return (readb(&gpiop->ppd_pwm) & 0x08) == 0; +} + +/* Test the state of the active-high FPGA DONE pin */ +int xilinx_done_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + return (readb(&gpiop->ppd_pwm) & 0x20) >> 5; +} + +/* Abort an FPGA operation */ +int xilinx_abort_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + /* ensure all SPI peripherals and FPGAs are deselected */ + writeb(0x08, &gpiop->ppd_uart); + writeb(0x01, &gpiop->ppd_timer); + writeb(0x38, &gpiop->ppd_qspi); + return FPGA_FAIL; +} + +/* + * FPGA pre-configuration function. Just make sure that + * FPGA reset is asserted to keep the FPGA from starting up after + * configuration. + */ +int xilinx_pre_config_fn(int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + unsigned char tmp_char; + unsigned short tmp_short; + + /* first, set the required pins to GPIO function */ + /* PAR_T0IN -> GPIO */ + tmp_char = readb(&gpiop->par_timer); + tmp_char &= 0xfc; + writeb(tmp_char, &gpiop->par_timer); + /* all QSPI pins -> GPIO */ + writew(0x0000, &gpiop->par_qspi); + /* U0RTS, U0CTS -> GPIO */ + tmp_short = __raw_readw(&gpiop->par_uart); + tmp_short &= 0xfff3; + __raw_writew(tmp_short, &gpiop->par_uart); + /* all PWM pins -> GPIO */ + writeb(0x00, &gpiop->par_pwm); + /* next, set data direction registers */ + writeb(0x01, &gpiop->pddr_timer); + writeb(0x25, &gpiop->pddr_qspi); + writeb(0x0c, &gpiop->pddr_uart); + writeb(0x04, &gpiop->pddr_pwm); + + /* ensure other SPI peripherals are deselected */ + writeb(0x08, &gpiop->ppd_uart); + writeb(0x38, &gpiop->ppd_qspi); + writeb(0x01, &gpiop->ppd_timer); + + /* CONFIG = 0, STATUS = 0 -> FPGA in reset state */ + writeb(0xFB, &gpiop->pclrr_uart); + /* enable Xilinx configuration by clearing QSPI_CS2 and U0CTS */ + writeb(0xF7, &gpiop->pclrr_uart); + writeb(0xDF, &gpiop->pclrr_qspi); + return 0; +} + +/* + * FPGA post configuration function. Should perform a test if FPGA is running. + */ +int xilinx_post_config_fn(int cookie) +{ + int rc = 0; + + /* + * no test yet + */ + return rc; +} + +int xilinx_clk_fn(int assert_clk, int flush, int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (assert_clk) + writeb(0x04, &gpiop->ppd_qspi); + else + writeb(0xFB, &gpiop->pclrr_qspi); + return assert_clk; +} + +int xilinx_wr_fn(int assert_write, int flush, int cookie) +{ + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + + if (assert_write) + writeb(0x01, &gpiop->ppd_qspi); + else + writeb(0xFE, &gpiop->pclrr_qspi); + return assert_write; +} + +int xilinx_fastwr_fn(void *buf, size_t len, int flush, int cookie) +{ + size_t bytecount = 0; + gpio_t *gpiop = (gpio_t *)MMAP_GPIO; + unsigned char *data = (unsigned char *)buf; + unsigned char val = 0; + int i; + int len_40 = len / 40; + + for (bytecount = 0; bytecount < len; bytecount++) { + val = *(data++); + for (i = 8; i > 0; i--) { + writeb(0xFB, &gpiop->pclrr_qspi); + if (val & 0x80) + writeb(0x01, &gpiop->ppd_qspi); + else + writeb(0xFE, &gpiop->pclrr_qspi); + writeb(0x04, &gpiop->ppd_qspi); + val <<= 1; + } + if (bytecount % len_40 == 0) { +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET(); +#endif +#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK + putc('.'); /* let them know we are alive */ +#endif +#ifdef CONFIG_SYS_FPGA_CHECK_CTRLC + if (ctrlc()) + return FPGA_FAIL; +#endif + } + } + return FPGA_SUCCESS; +} + +/* + * Note that these are pointers to code that is in Flash. They will be + * relocated at runtime. + * FIXME: relocation not yet working for coldfire, see below! + */ +Xilinx_Spartan3_Slave_Serial_fns xilinx_fns = { + xilinx_pre_config_fn, + xilinx_pgm_fn, + xilinx_clk_fn, + xilinx_init_fn, + xilinx_done_fn, + xilinx_wr_fn, + 0, + xilinx_fastwr_fn +}; + +Xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { + {Xilinx_Spartan3, + slave_serial, + XILINX_XC3S4000_SIZE, + (void *)&xilinx_fns, + 0} +}; + +/* Initialize the fpga. Return 1 on success, 0 on failure. */ +int astro5373l_xilinx_load(void) +{ + int i; + + fpga_init(); + + for (i = 0; i < CONFIG_FPGA_COUNT; i++) { + /* + * I did not yet manage to get relocation work properly, + * so set stuff here instead of static initialisation: + */ + xilinx_fns.pre = xilinx_pre_config_fn; + xilinx_fns.pgm = xilinx_pgm_fn; + xilinx_fns.clk = xilinx_clk_fn; + xilinx_fns.init = xilinx_init_fn; + xilinx_fns.done = xilinx_done_fn; + xilinx_fns.wr = xilinx_wr_fn; + xilinx_fns.bwr = xilinx_fastwr_fn; + xilinx_fpga[i].iface_fns = (void *)&xilinx_fns; + fpga_add(fpga_xilinx, &xilinx_fpga[i]); + } + return 1; +} diff --git a/board/astro/mcf5373l/mcf5373l.c b/board/astro/mcf5373l/mcf5373l.c new file mode 100644 index 0000000..3c09a21 --- /dev/null +++ b/board/astro/mcf5373l/mcf5373l.c @@ -0,0 +1,211 @@ +/* + * (C) Copyright 2000-2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * modified by Wolfgang Wegner w.wegner@astro-kom.de for ASTRO 5373l + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <watchdog.h> +#include <command.h> +#include <asm/m5329.h> +#include <asm/immap_5329.h> +#include <asm/io.h> + +/* needed for astro bus: */ +#include <asm/uart.h> +#include "astro.h" + +DECLARE_GLOBAL_DATA_PTR; +extern void uart_port_conf(void); + +int checkboard(void) +{ + puts("Board: "); + puts("ASTRO MCF5373L (Urmel) Board\n"); + return 0; +} + +phys_size_t initdram(int board_type) +{ +#if !defined(CONFIG_MONITOR_IS_IN_RAM) + sdram_t *sdp = (sdram_t *)(MMAP_SDRAM); + + /* + * GPIO configuration for bus should be set correctly from reset, + * so we do not care! First, set up address space: at this point, + * we should be running from internal SRAM; + * so use CONFIG_SYS_SDRAM_BASE as the base address for SDRAM, + * and do not care where it is + */ + __raw_writel((CONFIG_SYS_SDRAM_BASE & 0xFFF00000) | 0x00000018, + &sdp->cs0); + __raw_writel((CONFIG_SYS_SDRAM_BASE & 0xFFF00000) | 0x00000000, + &sdp->cs1); + /* + * I am not sure from the data sheet, but it seems burst length + * has to be 8 for the 16 bit data bus we use; + * so these values are for BL = 8 + */ + __raw_writel(0x33211530, &sdp->cfg1); + __raw_writel(0x56570000, &sdp->cfg2); + /* send PrechargeALL, REF and IREF remain cleared! */ + __raw_writel(0xE1462C02, &sdp->ctrl); + udelay(1); + /* refresh SDRAM twice */ + __raw_writel(0xE1462C04, &sdp->ctrl); + udelay(1); + __raw_writel(0xE1462C04, &sdp->ctrl); + /* init MR */ + __raw_writel(0x008D0000, &sdp->mode); + /* initialize EMR */ + __raw_writel(0x80010000, &sdp->mode); + /* wait until DLL is locked */ + udelay(1); + /* + * enable automatic refresh, lock mode register, + * clear iref and ipall + */ + __raw_writel(0x71462C00, &sdp->ctrl); + /* Dummy write to start SDRAM */ + writel(0, CONFIG_SYS_SDRAM_BASE); +#endif + + /* + * for get_ram_size() to work, both CS areas have to be + * configured, i.e. CS1 has to be explicitely disabled, else + * probing for memory will cause the SDRAM bus to hang! + * (Do not rely on the SDCS register(s) being set to 0x00000000 + * during reset as stated in the data sheet.) + */ + return get_ram_size((unsigned long *)CONFIG_SYS_SDRAM_BASE, + 0x80000000 - CONFIG_SYS_SDRAM_BASE); +} + +#define UART_BASE MMAP_UART0 +int rs_serial_init(int port, int baud) +{ + uart_t *uart; + u32 counter; + + switch (port) { + case 0: + uart = (uart_t *)(MMAP_UART0); + break; + case 1: + uart = (uart_t *)(MMAP_UART1); + break; + case 2: + uart = (uart_t *)(MMAP_UART2); + break; + default: + uart = (uart_t *)(MMAP_UART0); + } + + uart_port_conf(); + + /* write to SICR: SIM2 = uart mode,dcd does not affect rx */ + writeb(UART_UCR_RESET_RX, &uart->ucr); + writeb(UART_UCR_RESET_TX, &uart->ucr); + writeb(UART_UCR_RESET_ERROR, &uart->ucr); + writeb(UART_UCR_RESET_MR, &uart->ucr); + __asm__ ("nop"); + + writeb(0, &uart->uimr); + + /* write to CSR: RX/TX baud rate from timers */ + writeb(UART_UCSR_RCS_SYS_CLK | UART_UCSR_TCS_SYS_CLK, &uart->ucsr); + + writeb(UART_UMR_BC_8 | UART_UMR_PM_NONE, &uart->umr); + writeb(UART_UMR_SB_STOP_BITS_1, &uart->umr); + + /* Setting up BaudRate */ + counter = (u32) (gd->bus_clk / (baud)); + counter >>= 5; + + /* write to CTUR: divide counter upper byte */ + writeb((u8) ((counter & 0xff00) >> 8), &uart->ubg1); + /* write to CTLR: divide counter lower byte */ + writeb((u8) (counter & 0x00ff), &uart->ubg2); + + writeb(UART_UCR_RX_ENABLED | UART_UCR_TX_ENABLED, &uart->ucr); + + return 0; +} + +void astro_put_char(char ch) +{ + uart_t *uart; + unsigned long timer; + + uart = (uart_t *)(MMAP_UART0); + /* + * Wait for last character to go. Timeout of 6ms should + * be enough for our lowest baud rate of 2400. + */ + timer = get_timer(0); + while (get_timer(timer) < 6) { + if (readb(&uart->usr) & UART_USR_TXRDY) + break; + } + writeb(ch, &uart->utb); + + return; +} + +int astro_is_char(void) +{ + uart_t *uart; + + uart = (uart_t *)(MMAP_UART0); + return readb(&uart->usr) & UART_USR_RXRDY; +} + +int astro_get_char(void) +{ + uart_t *uart; + + uart = (uart_t *)(MMAP_UART0); + while (!(readb(&uart->usr) & UART_USR_RXRDY)) ; + return readb(&uart->urb); +} + +int misc_init_r(void) +{ + int retval = 0; + + puts("Configure Xilinx FPGA..."); + retval = astro5373l_xilinx_load(); + if (!retval) { + puts("failed!\n"); + return retval; + } + puts("done\n"); + + puts("Configure Altera FPGA..."); + retval = astro5373l_altera_load(); + if (!retval) { + puts("failed!\n"); + return retval; + } + puts("done\n"); + + return retval; +} diff --git a/board/astro/mcf5373l/u-boot.lds b/board/astro/mcf5373l/u-boot.lds new file mode 100644 index 0000000..a9a4e0a --- /dev/null +++ b/board/astro/mcf5373l/u-boot.lds @@ -0,0 +1,142 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(m68k) +/* Do we need any of these for elf? + __DYNAMIC = 0; */ +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + cpu/mcf532x/start.o (.text) + lib_m68k/traps.o (.text) + lib_m68k/interrupts.o (.text) + common/dlmalloc.o (.text) + lib_generic/zlib.o (.text) + + . = DEFINED(env_offset) ? env_offset : .; + common/env_embedded.o (.text) + + *(.text) +/* *(.fixup)*/ + *(.got1) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + + .reloc : + { + __got_start = .; + *(.got) + __got_end = .; + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss : + { + _sbss = .; + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + . = ALIGN(4); + _ebss = .; + } + _end = . ; + PROVIDE (end = .); +} diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h new file mode 100644 index 0000000..1fe42f6 --- /dev/null +++ b/include/configs/astro_mcf5373l.h @@ -0,0 +1,389 @@ +/* + * Configuration settings for the Sentec Cobra Board. + * + * (C) Copyright 2003 Josef Baumgartner josef.baumgartner@telex.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * configuration for ASTRO "Urmel" board. + * Originating from Cobra5272 configuration, messed up by + * Wolfgang Wegner w.wegner@astro-kom.de + * Please do not bother the original author with bug reports + * concerning this file. + */ + +#ifndef _CONFIG_ASTRO_MCF5373L_H +#define _CONFIG_ASTRO_MCF5373L_H + +/* + * set the card type to actually compile for; either of + * the possibilities listed below has to be used! + */ +#define CONFIG_ASTRO_V532 1 + +#if CONFIG_ASTRO_V532 +#define ASTRO_ID 0xF8 +#elif CONFIG_ASTRO_V512 +#define ASTRO_ID 0xFA +#elif CONFIG_ASTRO_TWIN7S2 +#define ASTRO_ID 0xF9 +#elif CONFIG_ASTRO_V912 +#define ASTRO_ID 0xFC +#elif CONFIG_ASTRO_COFDMDUOS2 +#define ASTRO_ID 0xFB +#else +#error No card type defined! +#endif + +/* + * Define processor + * possible values for Urmel board: only Coldfire M5373 processor supported + * (please do not change) + */ + +/* it seems not clear yet which processor defines we should use */ +#define CONFIG_MCF537x /* define processor family */ +#define CONFIG_MCF532x /* define processor family */ +#define CONFIG_M5373 /* define processor type */ +#define CONFIG_ASTRO5373L /* define board type */ + +/* Command line configuration */ +#include <config_cmd_default.h> + +/* + * CONFIG_MK_RAM defines if u-boot is loaded via BDM (or started from + * a different bootloader that has already performed RAM setup) or + * started directly from flash, which is the regular case for production + * boards. + */ +#ifdef CONFIG_MK_RAM +#define CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_TEXT_BASE 0x40020000 +#define ENABLE_JFFS 0 +#else +#define CONFIG_TEXT_BASE 0x00000000 +#define ENABLE_JFFS 1 +#endif + +/* Define which commmands should be available at u-boot command prompt */ + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DATE +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_MISC +#define CONFIG_CMD_XIMG +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +#if ENABLE_JFFS +#define CONFIG_CMD_JFFS2 +#endif +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_LOADB +#define CONFIG_CMD_FPGA +#define CONFIG_CMDLINE_EDITING + +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_MCFRTC +#undef RTC_DEBUG + +/* Timer */ +#define CONFIG_MCFTMR +#undef CONFIG_MCFPIT + +/* I2C */ +#define CONFIG_FSL_I2C +#define CONFIG_HARD_I2C /* I2C with hw support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_SYS_I2C_SPEED 80000 +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_OFFSET 0x58000 +#define CONFIG_SYS_IMMR CONFIG_SYS_MBAR + +/* + * Defines processor clock - important for correct timings concerning serial + * interface etc. + * CONFIG_SYS_HZ gives unit: 1000 -> 1 Hz ^= 1000 ms + */ + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_CLK 80000000 +#define CONFIG_SYS_CPU_CLK (CONFIG_SYS_CLK * 3) +#define CONFIG_SYS_SDRAM_SIZE 32 /* SDRAM size in MB */ + +#define CONFIG_SYS_CORE_SRAM_SIZE 0x8000 +#define CONFIG_SYS_CORE_SRAM 0x80000000 + +#define CONFIG_SYS_UNIFY_CACHE + +/* + * Define baudrate for UART1 (console output, tftp, ...) + * default value of CONFIG_BAUDRATE for Sentec board: 19200 baud + * CONFIG_SYS_BAUDRATE_TABLE defines values that can be selected + * in u-boot command interface + */ + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600 , 19200 , 38400 , 57600, 115200 } + +#define CONFIG_MCFUART +#define CONFIG_SYS_UART_PORT (2) +#define CONFIG_SYS_UART2_ALT3_GPIO + +/* + * Watchdog configuration; Watchdog is disabled for running from RAM + * and set to highest possible value else. Beware there is no check + * in the watchdog code to validate the timeout value set here! + */ + +#ifndef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_WATCHDOG +#define CONFIG_WATCHDOG_TIMEOUT 3355 /* timeout in milliseconds */ +#endif + +/* + * Configuration for environment + * Environment is located in the last sector of the flash + */ + +#ifndef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_ENV_OFFSET 0x1FF8000 +#define CONFIG_ENV_SECT_SIZE 0x8000 +#define CONFIG_ENV_IS_IN_FLASH 1 +#else +/* + * environment in RAM - This is used to use a single PC-based application + * to load an image, load U-Boot, load an environment and then start U-Boot + * to execute the commands from the environment. Feedback is done via setting + * and reading memory locations. + */ +#define CONFIG_ENV_ADDR 0x40060000 +#define CONFIG_ENV_SECT_SIZE 0x8000 +#define CONFIG_ENV_IS_IN_FLASH 1 +#endif + +/* here we put our FPGA configuration... */ +#define CONFIG_MISC_INIT_R 1 + +/* Define user parameters that have to be customized most likely */ + +/* AUTOBOOT settings - booting images automatically by u-boot after power on */ + +/* + * used for autoboot, delay in seconds u-boot will wait before starting + * defined (auto-)boot command, setting to -1 disables delay, setting to + * 0 will too prevent access to u-boot command interface: u-boot then has + * to be reflashed + * beware - watchdog is not serviced during autoboot delay time! + */ +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_BOOTDELAY 1 +#else +#define CONFIG_BOOTDELAY 1 +#endif + +/* + * The following settings will be contained in the environment block ; if you + * want to use a neutral environment all those settings can be manually set in + * u-boot: 'set' command + */ + +#define _QUOTEME(x) #x +#define QUOTEME(x) _QUOTEME(x) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loaderversion=11\0" \ + "card_id="QUOTEME(ASTRO_ID)"\0" \ + "alterafile=0\0" \ + "xilinxfile=0\0" \ + "xilinxload=imxtract 0x540000 $xilinxfile 0x41000000&&"\ + "fpga load 0 0x41000000 $filesize\0" \ + "alteraload=imxtract 0x6c0000 $alterafile 0x41000000&&"\ + "fpga load 1 0x41000000 $filesize\0" \ + "env_default=1\0" \ + "env_check=if test $env_default -eq 1;"\ + " then setenv env_default 0;saveenv;fi\0" + +/* + * "update" is a non-standard command that has to be supplied + * by external update.c; This is not included in mainline because + * it needs non-blocking CFI routines. + */ +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_BOOTCOMMAND "" /* no autoboot in this case */ +#else +#if CONFIG_ASTRO_V532 +#define CONFIG_BOOTCOMMAND "protect off 0x80000 0x1ffffff;run env_check;"\ + "run xilinxload&&run alteraload&&bootm 0x80000;"\ + "update;reset" +#else +#define CONFIG_BOOTCOMMAND "protect off 0x80000 0x1ffffff;run env_check;"\ + "run xilinxload&&bootm 0x80000;update;reset" +#endif +#endif + +/* default bootargs that are considered during boot */ +#define CONFIG_BOOTARGS " console=ttyS2,115200 rootfstype=romfs"\ + " loaderversion=$loaderversion" + +#define CONFIG_SYS_PROMPT "URMEL > " + +/* default RAM address for user programs */ +#define CONFIG_SYS_LOAD_ADDR 0x20000 + +#define CONFIG_SYS_LONGHELP + +#if (CONFIG_COMMANDS & CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 +#else +#define CONFIG_SYS_CBSIZE 256 +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_FPGA_COUNT 1 +#define CONFIG_FPGA +#define CONFIG_FPGA_XILINX +#define CONFIG_FPGA_SPARTAN3 +#define CONFIG_FPGA_ALTERA +#define CONFIG_FPGA_CYCLON2 +#define CONFIG_SYS_FPGA_PROG_FEEDBACK +#define CONFIG_SYS_FPGA_WAIT 1000 + +/* End of user parameters to be customized */ + +/* Defines memory range for test */ + +#define CONFIG_SYS_MEMTEST_START 0x40020000 +#define CONFIG_SYS_MEMTEST_END 0x41ffffff + +/* + * Low Level Configuration Settings + * (address mappings, register initial values, etc.) + * You should know what you are doing if you make changes here. + */ + +/* Base register address */ + +#define CONFIG_SYS_MBAR 0xFC000000 /* Register Base Addrs */ + +/* System Conf. Reg. & System Protection Reg. */ + +#define CONFIG_SYS_SCR 0x0003; +#define CONFIG_SYS_SPR 0xffff; + +/* + * Definitions for initial stack pointer and data area (in internal SRAM) + */ +#define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 +#define CONFIG_SYS_INIT_RAM_END 0x8000 +#define CONFIG_SYS_INIT_RAM_CTRL 0x221 +#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ + CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +/* + * Start addresses for the final memory configuration + * (Set up by the startup code) + * for MCF5373, the allowable range is 0x40000000 to 0x7FF00000 + */ +#define CONFIG_SYS_SDRAM_BASE 0x40000000 + +/* + * Chipselect bank definitions + * + * CS0 - Flash 32MB (first 16MB) + * CS1 - Flash 32MB (second half) + * CS2 - FPGA + * CS3 - FPGA + * CS4 - unused + * CS5 - unused + */ +#define CONFIG_SYS_CS0_BASE 0 +#define CONFIG_SYS_CS0_MASK 0x00ff0001 +#define CONFIG_SYS_CS0_CTRL 0x00001fc0 + +#define CONFIG_SYS_CS1_BASE 0x01000000 +#define CONFIG_SYS_CS1_MASK 0x00ff0001 +#define CONFIG_SYS_CS1_CTRL 0x00001fc0 + +#define CONFIG_SYS_CS2_BASE 0x20000000 +#define CONFIG_SYS_CS2_MASK 0x00ff0001 +#define CONFIG_SYS_CS2_CTRL 0x0000fec0 + +#define CONFIG_SYS_CS3_BASE 0x21000000 +#define CONFIG_SYS_CS3_MASK 0x00ff0001 +#define CONFIG_SYS_CS3_CTRL 0x0000fec0 + +#define CONFIG_SYS_FLASH_BASE 0x00000000 + +#ifdef CONFIG_MONITOR_IS_IN_RAM +#define CONFIG_SYS_MONITOR_BASE CONFIG_TEXT_BASE +#else +/* This is mainly used during relocation in start.S */ +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_FLASH_BASE + 0x400) +#endif +/* Reserve 256 kB for Monitor */ +#define CONFIG_SYS_MONITOR_LEN (256 << 10) + +#define CONFIG_SYS_BOOTPARAMS_LEN (64 * 1024) +/* Reserve 128 kB for malloc() */ +#define CONFIG_SYS_MALLOC_LEN (128 << 10) + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization ?? + */ +#define CONFIG_SYS_BOOTMAPSZ (CONFIG_SYS_SDRAM_BASE + \ + (CONFIG_SYS_SDRAM_SIZE << 20)) + +/* FLASH organization */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 259 +#define CONFIG_SYS_FLASH_ERASE_TOUT 1000 + +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_SIZE 0x2000000 +#define CONFIG_SYS_FLASH_PROTECTION 1 +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 +#define CONFIG_SYS_FLASH_CFI_NONBLOCK 1 + +#if ENABLE_JFFS +/* JFFS Partition offset set */ +#define CONFIG_SYS_JFFS2_FIRST_BANK 0 +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 +/* 512k reserved for u-boot */ +#define CONFIG_SYS_JFFS2_FIRST_SECTOR 0x40 +#endif + +/* Cache Configuration */ +#define CONFIG_SYS_CACHELINE_SIZE 16 + +#endif /* _CONFIG_ASTRO_MCF5373L_H */
Signed-off-by: Wolfgang Wegner w.wegner@astro-kom.de --- This patch adds the external "update" command to ASTRO MCF5373L boards. It needs this previous patch that is not included in mainline: non-blocking flash write/erase/status check functions (Message-Id 1260374411-11299-1-git-send-email-w.wegner@astro-kom.de)
board/astro/mcf5373l/Makefile | 2 +- board/astro/mcf5373l/update.c | 615 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 616 insertions(+), 1 deletions(-) create mode 100644 board/astro/mcf5373l/update.c
diff --git a/board/astro/mcf5373l/Makefile b/board/astro/mcf5373l/Makefile index c7a1d05..e0b1bc6 100644 --- a/board/astro/mcf5373l/Makefile +++ b/board/astro/mcf5373l/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
-COBJS = $(BOARD).o fpga.o +COBJS = $(BOARD).o fpga.o update.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/astro/mcf5373l/update.c b/board/astro/mcf5373l/update.c new file mode 100644 index 0000000..63170b3 --- /dev/null +++ b/board/astro/mcf5373l/update.c @@ -0,0 +1,615 @@ +/* + * (C) Copyright 2006-2009 + * Adnan El-Bardawil a.el-bardawil@astro-kom.de + * Wolfgang Wegner w.wegner@astro-kom.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <watchdog.h> +#include <command.h> +#include <asm/m5329.h> +#include <asm/immap_5329.h> +#include <asm/io.h> +#include <flash.h> +#include "astro.h" + +#include <asm/uart.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define DEBUG_INFO 1 +#define DEBUG_ERROR 1 + +/* dummy software version to signal card is in boot loader */ +#define SOFTWARE_VERSION 0x00 +#define SOFTWARE_SUBVERSION ' ' + +typedef enum { + CMD_INIT = 0, + CMD_NEW, + CMD_TX, + CMD_RX, + CMD_RX_RDY, + CMD_RX_ERROR +} cmd_stat_e; + +#define INT_CMD_IDLE 0 +#define INT_CMD_FLASH_MODE 1 +#define INT_CMD_WRITE_FLASH 2 +#define INT_CMD_RESTART 4 + +#define FL_STAT_IDLE 0 +#define FL_STAT_ERASE 1 +#define FL_STAT_PROG 2 +#define FL_STAT_ERROR 4 + +/* + * UART update subcommand codes + */ + +#define F_SAVE_PARAMETERS 0x00 /* save parameters on card */ +#define F_READ_PARAMETERS 0x01 /* read parameters */ +#define F_READ_CARDINFO 0x10 /* read card information */ +#define F_READ_ERROR_STATUS 0x11 /* read card error */ +#define F_TRANSPARENT_DATA 0x20 /* length byte + data */ + +#define SC_PREPARE_FOR_FLASH_DATA 0xc0 +#define SC_FLASH_DATA 0xc1 +#define SC_CLEAR_CRC 0xc2 +#define SC_CHECK_CRC 0xc3 +#define SC_RESTART 0xc4 + +typedef struct { + unsigned char command; + unsigned char length; + unsigned char subcommand; +} rcv_cmd_t; + +card_id_t card_information; + +struct { + parameters_t a; + parameters_t b; +} parameters; + +typedef struct { + int cnt; + cmd_stat_e stat; +} upd_command_t; + +typedef struct { + int cnt; + int length; + unsigned char *buffer; +} comm_status_t; + +const unsigned long fl_base[3] = { 0x80000, 0x540000, 0x6c0000 }; +const char fl_type_str[3][6] = { "Kernel", "Xilinx", "Altera" }; + +/* info for FLASH chips */ +extern flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; + +unsigned long crc, crc_count; + +/* CRC divisor value */ +#define CRC_POLYNOM 0x800500 + +void do_crc(unsigned char data) +{ + unsigned char count; + + crc |= data; + for (count = 0; count < 8; count++) { + crc <<= 1; + if (crc & 0x1000000) + crc ^= CRC_POLYNOM; + } + crc_count++; +} + +static unsigned char flash_buffer[0x10000]; +static unsigned long flash_data_length, flash_data_count; +static unsigned long flash_prog_count, flash_sect_count; +static unsigned char flash_data_type, crc_en; +static int flash_prog_stat; +static unsigned char uart_buffer[64]; + +void fl_prog(int force_write) +{ + int s, i; + unsigned long fl_adr, fl_sector; + + fl_adr = fl_base[flash_data_type] + flash_prog_count; + fl_sector = fl_adr >> 17; + + switch (flash_prog_stat) { + case FL_STAT_IDLE: + if (((flash_prog_count & 0x1ffff) == 0) && + ((flash_prog_count >> 17) == flash_sect_count)) { + flash_protect(FLAG_PROTECT_CLEAR, fl_adr, + fl_adr + 0x1ffff, flash_info); + s = flash_erase_nb(flash_info, fl_sector); + flash_prog_stat = FL_STAT_ERASE; + } else if ((flash_data_count >= (flash_prog_count + 64)) + || (force_write + && (flash_data_count > flash_prog_count))) { + s = write_buff_nb(flash_info, + flash_buffer + + (flash_prog_count & 0xffff), + fl_adr, 64); + flash_prog_stat = FL_STAT_PROG; + } + break; + case FL_STAT_ERASE: + s = flash_full_status_check_nb(flash_info, fl_sector, + 0, "erase"); + if (s != ERR_BUSY) { + if (s == ERR_OK) { + flash_sect_count++; + flash_prog_stat = FL_STAT_IDLE; + } else { + flash_prog_stat = FL_STAT_ERROR; + } + } + break; + case FL_STAT_PROG: + s = flash_full_status_check_nb(flash_info, fl_sector, + 0, "write"); + if (s == ERR_BUSY) + return; + + if (s != ERR_OK) { + flash_prog_stat = FL_STAT_ERROR; + return; + } + + flash_prog_stat = FL_STAT_IDLE; + for (i = 0; i < 64; i++) { + if (flash_buffer[(flash_prog_count + i) & 0xffff] != + *((unsigned char *)fl_adr + i)) + flash_prog_stat = FL_STAT_ERROR; + } + if ((flash_prog_count & 0xfff) == 0) + printf("."); + flash_prog_count += 64; + if (((flash_prog_count & 0x1ffff) == 0) + || (force_write + && (flash_data_count <= flash_prog_count))) { + flash_protect(FLAG_PROTECT_SET, + fl_adr & 0xfffe0000, + fl_adr | 0x1ffff, + flash_info); + } + break; + } +} + +void handle_rx_char(unsigned char rx_data, upd_command_t *cmd, + int *rcv_cnt, rcv_cmd_t *rcv_cmd, + comm_status_t *rx_stat) +{ + uart_t *uart; + + uart = (uart_t *)(MMAP_UART0); + if (readb(&uart->usr) & UART_USR_OE) { +#if DEBUG_ERROR + printf("UART FIFO Overrun Error!\n"); +#endif + writeb(UART_UCR_RESET_ERROR, &uart->ucr); + cmd->stat = CMD_RX_ERROR; + } + if (cmd->stat == CMD_INIT) { + if (*rcv_cnt == 0) { + /* First received Byte is the Command */ + rcv_cmd->command = rx_data; + /* non-Transparent Data: start Command Processing */ + if (rcv_cmd->command != F_TRANSPARENT_DATA) { + cmd->stat = CMD_NEW; + cmd->cnt++; + } else { + (*rcv_cnt)++; + } + } else { + /* Length and Subcommand for Transparent Data */ + if (*rcv_cnt == 1) { + rcv_cmd->length = rx_data; + (*rcv_cnt)++; + } else { + rcv_cmd->subcommand = rx_data; + cmd->stat = CMD_NEW; + cmd->cnt++; + } + } + } else if (cmd->stat == CMD_RX) { + /* Store received Data to Rx Buffer */ + rx_stat->buffer[rx_stat->cnt] = rx_data; + if (crc_en) + do_crc(rx_data); + (rx_stat->cnt)++; + if (rx_stat->cnt == rx_stat->length) + cmd->stat = CMD_RX_RDY; + } +} + +/* + * handle a transparent data command; these are used for software update + * return value is 1 if cmd_stat is set to CMD_INIT to let caller decide + * to reset the receive count, else 0. + */ +int handle_transparent_command(upd_command_t *cmd, rcv_cmd_t *rcv_cmd, + comm_status_t *rx_stat, comm_status_t *tx_stat, + unsigned char *int_command) +{ + int i; + unsigned char crc_status; + + if (cmd->stat == CMD_NEW) { + rx_stat->cnt = 0; + rx_stat->length = rcv_cmd->length - 1; + } + switch (rcv_cmd->subcommand) { + case SC_PREPARE_FOR_FLASH_DATA: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = uart_buffer; + cmd->stat = CMD_RX; + } else if (cmd->stat == CMD_RX_RDY) { + for (i = 0; i < 4; i++) + flash_data_length = (flash_data_length << 8) + + uart_buffer[i + 1]; + flash_data_type = uart_buffer[0]; +#if DEBUG_INFO + printf(" -- Flash Programming Initialized -- \n"); + printf(" -- Receiving %lu Bytes of type ", + flash_data_length); + for (i = 0; i < 6; i++) + printf("%c", fl_type_str[flash_data_type][i]); + printf(" [0x%lx]\n", fl_base[flash_data_type]); +#endif + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + crc_count = 0; + crc = 0; + flash_data_count = 0; + flash_prog_count = 0; + flash_sect_count = 0; + flash_prog_stat = FL_STAT_IDLE; + crc_en = 0; + *int_command = INT_CMD_FLASH_MODE; + cmd->stat = CMD_TX; + return 1; + } + break; + case SC_FLASH_DATA: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = flash_buffer + + (flash_data_count & 0xffff); + rx_stat->cnt = 0; + cmd->stat = CMD_RX; + crc_en = 1; + } else if (cmd->stat == CMD_RX_RDY) { + crc_en = 0; + flash_data_count += rcv_cmd->length - 1; + cmd->stat = CMD_INIT; + return 1; + } + break; + case SC_CLEAR_CRC: + if (cmd->stat == CMD_NEW) { + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + cmd->stat = CMD_TX; + crc_count = 0; + crc = 0; + } + break; + case SC_CHECK_CRC: + if (cmd->stat == CMD_NEW) { + rx_stat->buffer = uart_buffer; + cmd->stat = CMD_RX; + } else if (cmd->stat == CMD_RX_RDY) { + if ((flash_data_count <= flash_prog_count) + || (flash_prog_stat == FL_STAT_ERROR)) { + crc_status = 0; + if (uart_buffer[0] != ((crc >> 16) & 0xff)) + crc_status = 1; + if (uart_buffer[1] != ((crc >> 8) & 0xff)) + crc_status = 1; + if (flash_prog_stat == FL_STAT_ERROR) + crc_status |= 2; + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 4; + uart_buffer[2] = rcv_cmd->subcommand; + uart_buffer[3] = (crc >> 16); + uart_buffer[4] = (crc >> 8); + uart_buffer[5] = crc_status; +#if DEBUG_INFO + printf(" CRC %u / %lu of %lu kB \n", + crc_status, + (flash_data_count >> 10), + (flash_data_length >> 10)); +#endif + tx_stat->buffer = uart_buffer; + tx_stat->length = 6; + cmd->stat = CMD_TX; + if (crc_status) { + flash_prog_count = + flash_data_count = + (flash_data_count & 0xffff0000) + - 0x10000; + flash_prog_stat = FL_STAT_IDLE; + *int_command = INT_CMD_FLASH_MODE; + } + } + if (flash_data_count & 0xffff) + *int_command |= INT_CMD_WRITE_FLASH; + } + break; + case SC_RESTART: + if (cmd->stat == CMD_NEW) { + uart_buffer[0] = rcv_cmd->command; + uart_buffer[1] = 1; + uart_buffer[2] = rcv_cmd->subcommand; + tx_stat->buffer = uart_buffer; + tx_stat->length = 3; + cmd->stat = CMD_TX; + crc_count = 0; + crc = 0; + /* + * set restart command; sending the reply + * is done before finishing the loop. + */ + *int_command = INT_CMD_RESTART; + return 1; + } + break; + default: + /* + * for un-handled zero length transparent command, + * we have to handle this condition first! + */ + if ((cmd->stat == CMD_RX_RDY) + || (rx_stat->cnt == rx_stat->length)) + cmd->stat = CMD_INIT; + else if (cmd->stat == CMD_NEW) + cmd->stat = CMD_RX; + } + return 0; +} + +/* + * handle a general command (i.e. status and version information query) + * return value is always 0 except for transparent data where the + * return code is passed through to allow caller reset receive count. + */ +int handle_command(upd_command_t *cmd, rcv_cmd_t *rcv_cmd, + comm_status_t *rx_stat, comm_status_t *tx_stat, + unsigned char *int_command) +{ + int rv = 0; + + switch (rcv_cmd->command) { + case F_READ_ERROR_STATUS: +#if DEBUG_INFO + printf("read error status\n"); +#endif + uart_buffer[0] = 0; + uart_buffer[1] = 0; + uart_buffer[2] = 0; + uart_buffer[3] = 0; + tx_stat->buffer = uart_buffer; + tx_stat->length = 4; + cmd->stat = CMD_TX; + break; + case F_READ_PARAMETERS: + if (cmd->stat == CMD_NEW) { +#if DEBUG_INFO + printf("read parameters\n"); +#endif + memcpy(uart_buffer, (unsigned char *)¶meters.a, + 2 * sizeof(parameters_t)); + cmd->stat = CMD_TX; + tx_stat->length = 2 * sizeof(parameters_t); + } + break; + case F_READ_CARDINFO: +#if DEBUG_INFO + printf("read card info\n"); +#endif + card_information.software_version = + ((*int_command) & INT_CMD_FLASH_MODE) ? + 0xEE : SOFTWARE_VERSION; + tx_stat->buffer = (unsigned char *)&card_information; + tx_stat->length = 5; + cmd->stat = CMD_TX; + break; + + case F_TRANSPARENT_DATA: + rv = handle_transparent_command(cmd, rcv_cmd, rx_stat, + tx_stat, int_command); + break; + } + return rv; +} + +/* transmit data prepared in comm_status_t structure */ +void transmit_buffer(comm_status_t *tx_stat) +{ + int cnt; + for (cnt = 0; cnt < tx_stat->length; cnt++) + astro_put_char(tx_stat->buffer[cnt]); +} + +int do_update(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + unsigned char rx_data; + comm_status_t rx_stat, tx_stat; + upd_command_t cmd; + int rcv_cnt; + rcv_cmd_t rcv_cmd; + unsigned char int_command, tmp_char; + unsigned short tmp_short; + + int select, old_select, got_char; + eport_t *eport = (eport_t *)MMAP_EPORT; + gpio_t *gpio = (gpio_t *)MMAP_GPIO; + uart_t *uart = (uart_t *)MMAP_UART0; + char *env_string; + + cmd.cnt = 0; + + /* we set some dummy parameters to make the protocol work */ + card_information.card_type = ASTRO_ID; + env_string = getenv("loaderversion"); + if (env_string != NULL) { + card_information.hardware_version = + (int)simple_strtol(env_string, NULL, 16); + } else { + card_information.hardware_version = 0x10; + } + card_information.software_version = SOFTWARE_VERSION; + card_information.software_subversion = SOFTWARE_SUBVERSION; + card_information.fpga_version_altera = 0x12; + card_information.fpga_version_xilinx = 0x13; + + parameters.a.symbolrate = 0x5027; + parameters.a.viterbirate = 0x34; + parameters.a.satfreq = 0x6616; + parameters.a.card_error = 0; + + parameters.b.symbolrate = 0x5027; + parameters.b.viterbirate = 0x34; + parameters.b.satfreq = 0x6616; + parameters.b.card_error = 0; + + puts("Initializing serial port to ASTRO bus...\n"); + /* init serial port */ + rs_serial_init(0, 2400); + /* set UART pin for UART */ + tmp_short = __raw_readw(&gpio->par_uart); + tmp_short |= 0x0003; + __raw_writew(tmp_short, &gpio->par_uart); + /* set select pin as GPIO */ + tmp_short = __raw_readw(&gpio->par_irq); + tmp_short &= 0x0FF0; + __raw_writew(tmp_short, &gpio->par_irq); + /* set select pin as input */ + tmp_char = readb(&eport->pdr); + tmp_char &= 0xBF; + writeb(tmp_char, &eport->pdr); + /* + * set interrupt to both falling and rising edge + * (no IRQ used, though) + */ + tmp_short = __raw_readw(&eport->par); + tmp_short |= 0x3000; + __raw_writew(tmp_short, &eport->par); + + int_command = INT_CMD_IDLE; + + rcv_cnt = 0; + cmd.stat = CMD_INIT; + old_select = 0; /* always start from "deselected" state */ + rx_data = 0xFF; + + while (int_command != INT_CMD_RESTART) { + +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) + WATCHDOG_RESET(); +#endif + + /* Flash program routine only called in flash mode */ + if (int_command & INT_CMD_FLASH_MODE) + fl_prog(int_command & INT_CMD_WRITE_FLASH); + + /* + * UART Card Select Routine + * Write ID on Card Select and switch baud rate + */ + select = ((readb(&eport->pdr) & 0x40) == 0x0); + + if ((select) && (!old_select)) { + /* set low baud rate for ID only */ + rs_serial_init(0, 2400); + astro_put_char(ASTRO_ID); + + /* Wait for TX finished before switching baudrate */ + while ((readb(&uart->usr) & UART_USR_TXEMP) == 0) { + } + + /* set high baud rate */ + rs_serial_init(0, 115200); + /* Reset the Receive Byte Counter */ + rcv_cnt = 0; + cmd.stat = CMD_INIT; + } else if ((!select) && old_select && (cmd.stat != CMD_INIT)) { + cmd.stat = CMD_INIT; +#if DEBUG_ERROR + printf("Command %u: 0x%02x (0x%02x) failed," + " len %d, cnt %d\n", + cmd.cnt, rcv_cmd.command, + rcv_cmd.subcommand, rcv_cmd.length, + rx_stat.cnt); +#endif + } + + old_select = select; + + got_char = astro_is_char(); + if (got_char) + rx_data = astro_get_char(); + + if (select) { + /* UART RX Routine */ + if (got_char) + handle_rx_char(rx_data, &cmd, &rcv_cnt, + &rcv_cmd, &rx_stat); + + /* Command Control Routine */ + if ((cmd.stat == CMD_NEW) + || (cmd.stat == CMD_RX_RDY)) { + if (handle_command(&cmd, &rcv_cmd, + &rx_stat, &tx_stat, + &int_command)) + rcv_cnt = 0; + } + + /* UART TX Routine */ + if (cmd.stat == CMD_TX) { + transmit_buffer(&tx_stat); + /* Reset the Receive Byte Counter */ + rcv_cnt = 0; + cmd.stat = CMD_INIT; + } + } + } + /* restart is done outside, so we simply leave this function */ + return 0; +} + +U_BOOT_CMD(update, 1, 1, do_update, + "automatic update via ASTRO bus", + "\n - start the update, waiting for transfer via bus");
Dear Wolfgang Denk,
On Mon, Jan 18, 2010 at 12:40:45AM +0100, Wolfgang Denk wrote:
Dear Wolfgang Wegner,
Incorrect multiline comment style.
fixed and re-submitted.
I guess the worst thing about all these is that all of these comment styles are already present in U-Boot, which is why I copy-and-pasted them in my files (except update.c, obviously). (So probably not even my record application would be successful. :-( )
Just out of curiosity (and maybe for future submissions): do you have a script or grep command to check for these incorrect multiline comments? I did not come up with a simple solution so double-checked it manually now before re-submitting, but would be more at ease to have a tool for checking.
Best regards, Wolfgang
Wolfgang Wegner
wolfgang@leila.ping.de
