[U-Boot] [PATCH] mx6sabresd: Access SRC_SBMR1 register via structure
In U-boot it is preferred to access the register via structure pointer, so convert it such style.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx6sabresd/mx6sabresd.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index d5cd37d..bd8f55a 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -31,8 +31,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#define BOOT_CFG 0x020D8004 - #define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ PAD_CTL_SRE_FAST | PAD_CTL_HYS) @@ -300,7 +298,8 @@ int board_mmc_init(bd_t *bis)
return 0; #else - unsigned reg = readl(BOOT_CFG) >> 11; + struct src *psrc = (struct src *)SRC_BASE_ADDR; + unsigned reg = readl(&psrc->sbmr1) >> 11; /* * Upon reading BOOT_CFG register the following map is done: * Bit 11 and 12 of BOOT_CFG register can determine the current
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
