Pull request: u-boot-rockchip-20231007
Hi Tom,
Please pull the updates for rockchip platform: - Add Board: rk3568 Bananapi R2Pro; - Update pcie bifurcation support; - dwc_eth_qos controller support for rk3568 and rk3588; - Compressed binary support for U-Boot on rockchip platform; - dts and config updates for different board and soc;
CI: https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/pipelines/18045
Thanks, - Kever
The following changes since commit be2abe73df58a35da9e8d5afb13fccdf1b0faa8e:
Merge https://source.denx.de/u-boot/custodians/u-boot-riscv (2023-10-05 13:26:44 -0400)
https://source.denx.de/u-boot/custodians/u-boot-rockchip.git tags/u-boot-rockchip-20231007
for you to fetch changes up to a7c86c57fb404df0a807c2ad9717c510150b8ebb:
configs: rockchip: rk3308: enable CONFIG_OF_LIBFDT_OVERLAY (2023-10-07 10:48:16 +0800)
---------------------------------------------------------------- FUKAUMI Naoki (5): configs: rockchip: rock-pi-s: use default bootdelay (2s) arm: dts: rockchip: sync DT for RK3588 series with Linux arm: dts: rockchip: rock-5b: add support for PCIe3 and NVMe configs: rockchip: rk3308: use CONFIG_DEFAULT_FDT_FILE configs: rockchip: rk3308: enable CONFIG_OF_LIBFDT_OVERLAY
Frank Wunderlich (1): board: rockchip: Add Bananapi R2Pro Board
Jonas Karlman (19): pci: pcie_dw_rockchip: Configure number of lanes and link width speed phy: rockchip: snps-pcie3: Refactor to use clk_bulk API phy: rockchip: snps-pcie3: Refactor to use a phy_init ops phy: rockchip: snps-pcie3: Add bifurcation support for RK3568 phy: rockchip: snps-pcie3: Add support for RK3588 phy: rockchip: naneng-combphy: Use signal from comb PHY on RK3588 rockchip: rk3568-nanopi-r5: Update defconfig for NanoPi R5C and R5S rockchip: rk3568-nanopi-r5: Enable PCIe on NanoPi R5C and R5S rockchip: rk356x: Enable poweroff command power: regulator: Only run autoset once for each regulator rockchip: Port IO-domain driver for RK3568 from linux rockchip: board: Add minimal generic RK3566/RK3568 board net: dwc_eth_qos: Drop unused rx_pkt from eqos_priv net: dwc_eth_qos: Return error code when start fails net: dwc_eth_qos: Stop spam of RX packet not available message net: dwc_eth_qos: Add glue driver for GMAC on Rockchip RK3568 net: dwc_eth_qos_rockchip: Add support for RK3588 configs: rockchip: Enable ethernet driver on RK356x boards configs: rockchip: Enable ethernet driver on RK3588 boards
Joseph Chen (1): regulator: rk8xx: Return correct voltage for buck converters
Manoj Sai (4): spl: fit: support for booting a GZIP-compressed U-boot binary spl: fit: support for booting a LZMA-compressed U-boot binary rockchip: Add support to generate GZIP compressed U-boot binary rockchip: Add support to generate LZMA compressed U-boot binary
Massimo Pegorer (3): rockchip: Kconfig: Enable external TPL binary for rk3308 doc: rockchip: Update and improve info on rk3308, TPL and TF-A configs: rockchip: add DOS_PARTITION to RK3308 boards defconfig
shengfei Xu (1): regulator: rk8xx: Return correct voltage for switchout converters
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3568-bpi-r2-pro-u-boot.dtsi | 19 + arch/arm/dts/rk3568-bpi-r2-pro.dts | 852 +++++++++++++++++++++ arch/arm/dts/rk3568-generic-u-boot.dtsi | 14 + arch/arm/dts/rk3568-generic.dts | 38 + arch/arm/dts/rk3568-nanopi-r5c-u-boot.dtsi | 4 + arch/arm/dts/rk3568-nanopi-r5c.dts | 2 +- arch/arm/dts/rk3568-nanopi-r5s-u-boot.dtsi | 10 +- arch/arm/dts/rk3588-edgeble-neu6a-io-u-boot.dtsi | 1 - arch/arm/dts/rk3588-edgeble-neu6a.dtsi | 1 - arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi | 6 - arch/arm/dts/rk3588-edgeble-neu6b-io.dts | 66 ++ arch/arm/dts/rk3588-edgeble-neu6b.dtsi | 359 ++++++++- arch/arm/dts/rk3588-evb1-v10.dts | 720 ++++++++++++++++- arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 142 ++-- arch/arm/dts/rk3588-rock-5b.dts | 448 ++++++++++- arch/arm/dts/rk3588.dtsi | 215 ++++++ arch/arm/dts/rk3588s-rock-5a-u-boot.dtsi | 12 - arch/arm/dts/rk3588s-rock-5a.dts | 665 +++++++++++++++- arch/arm/dts/rk3588s-u-boot.dtsi | 162 ---- arch/arm/dts/rk3588s.dtsi | 367 +++++++++ arch/arm/dts/rockchip-u-boot.dtsi | 11 + arch/arm/mach-rockchip/Kconfig | 3 +- board/rockchip/evb_rk3568/MAINTAINERS | 14 + common/spl/spl_fit.c | 20 +- configs/bpi-r2-pro-rk3568_defconfig | 93 +++ configs/evb-rk3308_defconfig | 3 +- configs/evb-rk3568_defconfig | 6 +- configs/evb-rk3588_defconfig | 5 +- configs/generic-rk3568_defconfig | 64 ++ configs/lubancat-2-rk3568_defconfig | 3 + configs/nanopi-r5c-rk3568_defconfig | 18 +- configs/nanopi-r5s-rk3568_defconfig | 22 +- configs/neu6a-io-rk3588_defconfig | 2 - configs/neu6b-io-rk3588_defconfig | 2 - configs/odroid-m1-rk3568_defconfig | 3 + configs/quartz64-a-rk3566_defconfig | 4 + configs/quartz64-b-rk3566_defconfig | 4 + configs/radxa-cm3-io-rk3566_defconfig | 6 +- configs/roc-cc-rk3308_defconfig | 3 +- configs/rock-3a-rk3568_defconfig | 6 +- configs/rock-pi-s-rk3308_defconfig | 5 +- configs/rock5a-rk3588s_defconfig | 5 +- configs/rock5b-rk3588_defconfig | 4 +- configs/soquartz-blade-rk3566_defconfig | 3 + configs/soquartz-cm4-rk3566_defconfig | 3 + configs/soquartz-model-a-rk3566_defconfig | 4 + doc/README.rockchip | 10 +- doc/board/rockchip/rockchip.rst | 45 +- drivers/misc/Kconfig | 9 + drivers/misc/Makefile | 1 + drivers/misc/rockchip-io-domain.c | 167 ++++ drivers/net/Kconfig | 8 + drivers/net/Makefile | 1 + drivers/net/dwc_eth_qos.c | 33 +- drivers/net/dwc_eth_qos.h | 3 +- drivers/net/dwc_eth_qos_rockchip.c | 531 +++++++++++++ drivers/pci/pcie_dw_rockchip.c | 58 +- drivers/phy/rockchip/phy-rockchip-naneng-combphy.c | 6 + drivers/phy/rockchip/phy-rockchip-snps-pcie3.c | 230 ++++-- drivers/power/pmic/Kconfig | 1 + drivers/power/regulator/regulator-uclass.c | 18 +- drivers/power/regulator/rk8xx.c | 95 ++- include/configs/rk3308_common.h | 4 +- include/dt-bindings/ata/ahci.h | 20 + include/power/regulator.h | 1 + include/spl.h | 10 + 67 files changed, 5206 insertions(+), 465 deletions(-) create mode 100644 arch/arm/dts/rk3568-bpi-r2-pro-u-boot.dtsi create mode 100644 arch/arm/dts/rk3568-bpi-r2-pro.dts create mode 100644 arch/arm/dts/rk3568-generic-u-boot.dtsi create mode 100644 arch/arm/dts/rk3568-generic.dts create mode 100644 configs/bpi-r2-pro-rk3568_defconfig create mode 100644 configs/generic-rk3568_defconfig create mode 100644 drivers/misc/rockchip-io-domain.c create mode 100644 drivers/net/dwc_eth_qos_rockchip.c create mode 100644 include/dt-bindings/ata/ahci.h
Hi Tom,
Please ignore this PR, two patches are missing, sorry.
I will update a new version and send a new PR.
Thanks,
- Kever
On 2023/10/7 16:47, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
