[PATCH 1/2] mx53loco: Remove unused mx53loco_video.c file
Since commit 1fa43cad8625 ("video: Drop references to CONFIG_VIDEO et al") the mx53loco_video.c is no longer used.
Remove the unused file.
Signed-off-by: Fabio Estevam festevam@denx.de --- board/freescale/mx53loco/mx53loco_video.c | 114 ---------------------- 1 file changed, 114 deletions(-) delete mode 100644 board/freescale/mx53loco/mx53loco_video.c
diff --git a/board/freescale/mx53loco/mx53loco_video.c b/board/freescale/mx53loco/mx53loco_video.c deleted file mode 100644 index ff3fc8ce3e..0000000000 --- a/board/freescale/mx53loco/mx53loco_video.c +++ /dev/null @@ -1,114 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2012 Freescale Semiconductor, Inc. - * Fabio Estevam fabio.estevam@freescale.com - */ - -#include <common.h> -#include <env.h> -#include <linux/list.h> -#include <asm/gpio.h> -#include <asm/arch/iomux-mx53.h> -#include <linux/fb.h> -#include <ipu_pixfmt.h> - -#define MX53LOCO_LCD_POWER IMX_GPIO_NR(3, 24) - -static struct fb_videomode const claa_wvga = { - .name = "CLAA07LC0ACW", - .refresh = 57, - .xres = 800, - .yres = 480, - .pixclock = 37037, - .left_margin = 40, - .right_margin = 60, - .upper_margin = 10, - .lower_margin = 10, - .hsync_len = 20, - .vsync_len = 10, - .sync = 0, - .vmode = FB_VMODE_NONINTERLACED -}; - -static struct fb_videomode const seiko_wvga = { - .name = "Seiko-43WVF1G", - .refresh = 60, - .xres = 800, - .yres = 480, - .pixclock = 29851, /* picosecond (33.5 MHz) */ - .left_margin = 89, - .right_margin = 164, - .upper_margin = 23, - .lower_margin = 10, - .hsync_len = 10, - .vsync_len = 10, - .sync = 0, -}; - -void setup_iomux_lcd(void) -{ - static const iomux_v3_cfg_t lcd_pads[] = { - MX53_PAD_DI0_DISP_CLK__IPU_DI0_DISP_CLK, - MX53_PAD_DI0_PIN15__IPU_DI0_PIN15, - MX53_PAD_DI0_PIN2__IPU_DI0_PIN2, - MX53_PAD_DI0_PIN3__IPU_DI0_PIN3, - MX53_PAD_DISP0_DAT0__IPU_DISP0_DAT_0, - MX53_PAD_DISP0_DAT1__IPU_DISP0_DAT_1, - MX53_PAD_DISP0_DAT2__IPU_DISP0_DAT_2, - MX53_PAD_DISP0_DAT3__IPU_DISP0_DAT_3, - MX53_PAD_DISP0_DAT4__IPU_DISP0_DAT_4, - MX53_PAD_DISP0_DAT5__IPU_DISP0_DAT_5, - MX53_PAD_DISP0_DAT6__IPU_DISP0_DAT_6, - MX53_PAD_DISP0_DAT7__IPU_DISP0_DAT_7, - MX53_PAD_DISP0_DAT8__IPU_DISP0_DAT_8, - MX53_PAD_DISP0_DAT9__IPU_DISP0_DAT_9, - MX53_PAD_DISP0_DAT10__IPU_DISP0_DAT_10, - MX53_PAD_DISP0_DAT11__IPU_DISP0_DAT_11, - MX53_PAD_DISP0_DAT12__IPU_DISP0_DAT_12, - MX53_PAD_DISP0_DAT13__IPU_DISP0_DAT_13, - MX53_PAD_DISP0_DAT14__IPU_DISP0_DAT_14, - MX53_PAD_DISP0_DAT15__IPU_DISP0_DAT_15, - MX53_PAD_DISP0_DAT16__IPU_DISP0_DAT_16, - MX53_PAD_DISP0_DAT17__IPU_DISP0_DAT_17, - MX53_PAD_DISP0_DAT18__IPU_DISP0_DAT_18, - MX53_PAD_DISP0_DAT19__IPU_DISP0_DAT_19, - MX53_PAD_DISP0_DAT20__IPU_DISP0_DAT_20, - MX53_PAD_DISP0_DAT21__IPU_DISP0_DAT_21, - MX53_PAD_DISP0_DAT22__IPU_DISP0_DAT_22, - MX53_PAD_DISP0_DAT23__IPU_DISP0_DAT_23, - }; - - imx_iomux_v3_setup_multiple_pads(lcd_pads, ARRAY_SIZE(lcd_pads)); - - /* Turn on GPIO backlight */ - imx_iomux_v3_setup_pad(MX53_PAD_EIM_D24__GPIO3_24); - gpio_direction_output(MX53LOCO_LCD_POWER, 1); - - /* Turn on display contrast */ - imx_iomux_v3_setup_pad(MX53_PAD_GPIO_1__GPIO1_1); - gpio_direction_output(IMX_GPIO_NR(1, 1), 1); -} - -int board_video_skip(void) -{ - int ret; - char const *e = env_get("panel"); - - if (e) { - if (strcmp(e, "seiko") == 0) { - ret = ipuv3_fb_init(&seiko_wvga, 0, IPU_PIX_FMT_RGB24); - if (ret) - printf("Seiko cannot be configured: %d\n", ret); - return ret; - } - } - - /* - * 'panel' env variable not found or has different value than 'seiko' - * Defaulting to claa lcd. - */ - ret = ipuv3_fb_init(&claa_wvga, 0, IPU_PIX_FMT_RGB565); - if (ret) - printf("CLAA cannot be configured: %d\n", ret); - return ret; -}
Since commit 1fa43cad8625 ("video: Drop references to CONFIG_VIDEO et al") the mx51evk_video.c is no longer used.
Signed-off-by: Fabio Estevam festevam@denx.de --- board/freescale/mx51evk/mx51evk_video.c | 98 ------------------------- 1 file changed, 98 deletions(-) delete mode 100644 board/freescale/mx51evk/mx51evk_video.c
diff --git a/board/freescale/mx51evk/mx51evk_video.c b/board/freescale/mx51evk/mx51evk_video.c deleted file mode 100644 index 3715c5d738..0000000000 --- a/board/freescale/mx51evk/mx51evk_video.c +++ /dev/null @@ -1,98 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2012 Freescale Semiconductor, Inc. - * Fabio Estevam fabio.estevam@freescale.com - */ - -#include <common.h> -#include <env.h> -#include <linux/list.h> -#include <asm/gpio.h> -#include <asm/arch/iomux-mx51.h> -#include <linux/fb.h> -#include <ipu_pixfmt.h> - -#define MX51EVK_LCD_3V3 IMX_GPIO_NR(4, 9) -#define MX51EVK_LCD_5V IMX_GPIO_NR(4, 10) -#define MX51EVK_LCD_BACKLIGHT IMX_GPIO_NR(3, 4) - -static struct fb_videomode const claa_wvga = { - .name = "CLAA07LC0ACW", - .refresh = 57, - .xres = 800, - .yres = 480, - .pixclock = 37037, - .left_margin = 40, - .right_margin = 60, - .upper_margin = 10, - .lower_margin = 10, - .hsync_len = 20, - .vsync_len = 10, - .sync = 0, - .vmode = FB_VMODE_NONINTERLACED -}; - -static struct fb_videomode const dvi = { - .name = "DVI panel", - .refresh = 60, - .xres = 1024, - .yres = 768, - .pixclock = 15385, - .left_margin = 220, - .right_margin = 40, - .upper_margin = 21, - .lower_margin = 7, - .hsync_len = 60, - .vsync_len = 10, - .sync = 0, - .vmode = FB_VMODE_NONINTERLACED -}; - -void setup_iomux_lcd(void) -{ - /* DI2_PIN15 */ - imx_iomux_v3_setup_pad(MX51_PAD_DI_GP4__DI2_PIN15); - - /* Pad settings for DI2_DISP_CLK */ - imx_iomux_v3_setup_pad(NEW_PAD_CTRL(MX51_PAD_DI2_DISP_CLK__DI2_DISP_CLK, - PAD_CTL_PKE | PAD_CTL_DSE_MAX | PAD_CTL_SRE_SLOW)); - - /* Turn on 3.3V voltage for LCD */ - imx_iomux_v3_setup_pad(NEW_PAD_CTRL(MX51_PAD_CSI2_D12__GPIO4_9, - NO_PAD_CTRL)); - gpio_direction_output(MX51EVK_LCD_3V3, 1); - - /* Turn on 5V voltage for LCD */ - imx_iomux_v3_setup_pad(NEW_PAD_CTRL(MX51_PAD_CSI2_D13__GPIO4_10, - NO_PAD_CTRL)); - gpio_direction_output(MX51EVK_LCD_5V, 1); - - /* Turn on GPIO backlight */ - imx_iomux_v3_setup_pad(NEW_PAD_CTRL(MX51_PAD_DI1_D1_CS__GPIO3_4, - NO_PAD_CTRL)); - gpio_direction_output(MX51EVK_LCD_BACKLIGHT, 1); -} - -int board_video_skip(void) -{ - int ret; - char const *e = env_get("panel"); - - if (e) { - if (strcmp(e, "claa") == 0) { - ret = ipuv3_fb_init(&claa_wvga, 1, IPU_PIX_FMT_RGB565); - if (ret) - printf("claa cannot be configured: %d\n", ret); - return ret; - } - } - - /* - * 'panel' env variable not found or has different value than 'claa' - * Defaulting to dvi output. - */ - ret = ipuv3_fb_init(&dvi, 0, IPU_PIX_FMT_RGB24); - if (ret) - printf("dvi cannot be configured: %d\n", ret); - return ret; -}
From: Fabio Estevam festevam@denx.de Since commit 1fa43cad8625 ("video: Drop references to CONFIG_VIDEO et al") the mx51evk_video.c is no longer used. Remove the unused file. Signed-off-by: Fabio Estevam festevam@denx.de
Applied to u-boot-imx, next, thanks !
Best regards, Stefano Babic
From: Fabio Estevam festevam@denx.de Since commit 1fa43cad8625 ("video: Drop references to CONFIG_VIDEO et al") the mx53loco_video.c is no longer used. Remove the unused file. Signed-off-by: Fabio Estevam festevam@denx.de
Fabio Estevam
sbabic@denx.de
