[PATCH v4 0/3] arch: riscv: jh7110: Correctly zero L2 LIM
This series is the second version of Bo Gan's L2 LIM series. Original author hasn't sent v2 for almost 2 months, so I decided to take over this series.
Background information: JH7110 SPL runs in L2 LIM (2M in size mapped at 0x8000000). It consists of 16 0x20000 sized regions, each one can be used as either L2 cache way or SRAM (not both). From top to bottom, there're ways 0-15. The way 0 is always enabled, at most 0x1e0000 can be used.
In SPL, we don't enable any cache ways, thus all 15 (except way 0) ways can be used. However, due to HW requirement, we must zero the LIM before use. This is because ECC is applied to LIM, and if not cleared first, the ECC part is invalid, which can trigger ECC errors when reading/writing data.
There are several issues currently. We clear L2 LIM from __bss_end to 0x81FFFFF in `harts_early_init`. This is wrong because:
1. Each hart (in the middle of a function call) overwriting its own stack and other harts' stacks. (data-race and data-corruption) 2. Lottery winner hart can be doing `board_init_f_init_reserve`, while other harts're in the middle of zeroing L2 LIM. (data-race)
To fix this, we split the job, such that there's one and only one owner of zeroing a specific region (No data-race). A new SPL config option `SPL_ZERO_MEM_BEFORE_USE` is introduced. Allowing The zeroing to happen in the same code path. (much easier to reason about).
Changes since v1: - Separate single patch into several patches
Changes since v2: - Fix typo (ZERO_MEM_BEFORE_USE to SPL_ZERO_MEM_BEFORE_USE)
Changes since v3: - Revert v3's fix since original implementation is actually right
Shengyu Qu (3): riscv: Kconfig: Add SPL_ZERO_MEM_BEFORE_USE riscv: Add SPL_ZERO_MEM_BEFORE_USE implementation riscv: cpu: jh7110: Select SPL_ZERO_MEM_BEFORE_USE
arch/riscv/Kconfig | 8 ++++++++ arch/riscv/cpu/jh7110/Kconfig | 1 + arch/riscv/cpu/jh7110/spl.c | 25 ------------------------- arch/riscv/cpu/start.S | 12 ++++++++++++ common/init/board_init.c | 3 +++ 5 files changed, 24 insertions(+), 25 deletions(-)
Shengyu Qu
