[U-Boot] [PATCH] drivers: hierarchize drivers Kconfig menu
The menuconfig for drivers are getting more and more cluttered and unreadable because too many entries are displayed in a single flat menu. Use hierarchic menu for each category.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/core/Kconfig | 4 ++++ drivers/crypto/Kconfig | 4 ++++ drivers/demo/Kconfig | 4 ++++ drivers/gpio/Kconfig | 8 ++++++++ drivers/i2c/Kconfig | 8 ++++++++ drivers/led/Kconfig | 4 ++++ drivers/misc/Kconfig | 8 ++++++++ drivers/rtc/Kconfig | 8 ++++++++ drivers/serial/Kconfig | 8 ++++++++ drivers/sound/Kconfig | 4 ++++ drivers/usb/Kconfig | 8 ++++++++ drivers/video/Kconfig | 8 ++++++++ 12 files changed, 76 insertions(+)
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index e40372d..9cc888d 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -1,3 +1,5 @@ +menu "Generic Driver Options" + config DM bool "Enable Driver Model" help @@ -59,3 +61,5 @@ config DM_SEQ_ALIAS Most boards will have a '/aliases' node containing the path to numbered devices (e.g. serial0 = &serial0). This feature can be disabled if it is not required, to save code space in SPL. + +endmenu diff --git a/drivers/crypto/Kconfig b/drivers/crypto/Kconfig index bd26a2b..1ea116b 100644 --- a/drivers/crypto/Kconfig +++ b/drivers/crypto/Kconfig @@ -1 +1,5 @@ +menu "Hardware crypto devices" + source drivers/crypto/fsl/Kconfig + +endmenu diff --git a/drivers/demo/Kconfig b/drivers/demo/Kconfig index 7a8ce18..98bb633 100644 --- a/drivers/demo/Kconfig +++ b/drivers/demo/Kconfig @@ -1,3 +1,5 @@ +menu "Demo for driver model" + config DM_DEMO bool "Enable demo uclass support" depends on DM @@ -24,3 +26,5 @@ config DM_DEMO_SHAPE a shape when the 'demo hello' command is executed which targets this device. It can be used to help understand how driver model works. + +endmenu diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 0c43777..5934597 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -1,3 +1,9 @@ +# +# GPIO infrastructure and drivers +# + +menu "GPIO Support" + config DM_GPIO bool "Enable Driver Model for GPIO drivers" depends on DM @@ -42,3 +48,5 @@ config VYBRID_GPIO default n help Say yes here to support Vybrid vf610 GPIOs. + +endmenu diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 86fb36b..b8b2250 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -1,3 +1,9 @@ +# +# I2C subsystem configuration +# + +menu "I2C support" + config DM_I2C bool "Enable Driver Model for I2C drivers" depends on DM @@ -73,3 +79,5 @@ config SYS_I2C_UNIPHIER_F help Support for UniPhier FIFO-builtin I2C controller driver. This I2C controller is used on PH1-Pro4 or newer UniPhier SoCs. + +endmenu diff --git a/drivers/led/Kconfig b/drivers/led/Kconfig index de5feea..b21bc94 100644 --- a/drivers/led/Kconfig +++ b/drivers/led/Kconfig @@ -1,3 +1,5 @@ +menu "LED Support" + config LED bool "Enable LED support" depends on DM @@ -24,3 +26,5 @@ config LED_GPIO GPIOs may be on the SoC or some other device which provides GPIOs. The GPIO driver must used driver model. LEDs are configured using the device tree. + +endmenu diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 3b7f76a..f29a169 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -1,3 +1,9 @@ +# +# Multifunction miscellaneous devices +# + +menu "Multifunction device drivers" + config CMD_CROS_EC bool "Enable crosec command" depends on CROS_EC @@ -82,3 +88,5 @@ config RESET Each driver can provide a reset method which will be called to effect a reset. The uclass will try all available drivers when reset_walk() is called. + +endmenu diff --git a/drivers/rtc/Kconfig b/drivers/rtc/Kconfig index bd63621..b5d9048 100644 --- a/drivers/rtc/Kconfig +++ b/drivers/rtc/Kconfig @@ -1,3 +1,9 @@ +# +# RTC drivers configuration +# + +menu "Real Time Clock" + config DM_RTC bool "Enable Driver Model for RTC drivers" depends on DM @@ -6,3 +12,5 @@ config DM_RTC then provides the rtc_get()/rtc_set() interface, delegating to drivers to perform the actual functions. See rtc.h for a description of the API. + +endmenu diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 4829284..b87eb01 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -1,3 +1,9 @@ +# +# Serial device configuration +# + +menu "Serial drivers" + config DM_SERIAL bool "Enable Driver Model for serial drivers" depends on DM @@ -102,3 +108,5 @@ config UNIPHIER_SERIAL help If you have a UniPhier based board and want to use the on-chip serial ports, say Y to this option. If unsure, say N. + +endmenu diff --git a/drivers/sound/Kconfig b/drivers/sound/Kconfig index 3b96e84..5de86c0 100644 --- a/drivers/sound/Kconfig +++ b/drivers/sound/Kconfig @@ -1,3 +1,5 @@ +menu "Sound support" + config SOUND bool "Enable sound support" help @@ -53,3 +55,5 @@ config SOUND_WM8994 Enable the wm8994 audio codec. This is connected via I2S for audio data and I2C for codec control. At present it only works with the Samsung I2S driver. + +endmenu diff --git a/drivers/usb/Kconfig b/drivers/usb/Kconfig index 3fa5b2e..19b1b3d 100644 --- a/drivers/usb/Kconfig +++ b/drivers/usb/Kconfig @@ -1,3 +1,9 @@ +# +# USB device configuration +# + +menu "USB support" + config USB_ARCH_HAS_HCD def_bool y
@@ -60,3 +66,5 @@ config USB_STORAGE board's USB port.
endif + +endmenu diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 9ae23e8..892781d 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -1,3 +1,9 @@ +# +# Video configuration +# + +menu "Graphics support" + config VIDEO_VESA bool "Enable VESA video driver support" default n @@ -240,3 +246,5 @@ config VIDEO_TEGRA124 HDMI. At present only eDP is supported by U-Boot. This option enables this support which can be used on devices which have an eDP display connected. + +endmenu
That looks like a valuable addition to me!
I had started dealing with the USB side of this in a series currently under review. I'll drop the USB bits from my series and base the next version on top of this patch.
Thanks!
+menu "I2C support"
+menu "USB support"
endif
+endmenu
This patch was submitted a week ago and I need it for merging another series of mine, that was already accepted.
Is there anything preventing this patch from being merged at this point?
Thanks!
Thanks!
+menu "I2C support"
+menu "USB support"
endif
+endmenu
People not having just one patch on their plate and thus being busy ;-)
Best regards, Marek Vasut
Of course, I'm just sending this as a reminder, to get the discussion started on this patch. I know that everyone's busy around here and I fully understand that the process takes some time. Still, I believe a reminder once in a while (a week seems fair enough) is good thing, too!
Hi Masahiro,
On Sun, Jul 26, 2015 at 1:46 AM, Masahiro Yamada yamada.masahiro@socionext.com wrote:
+menu "I2C support"
+menu "USB support"
endif
+endmenu
With this patch, there are still single entries under Device Drivers main menu like:
[] Enable clock driver support [] Enable CPU drivers using Driver Model [] Enable Driver Model for Ethernet drivers [] Network device support ---- [] Enable Chrome OS EC keyboard support [] Enable sandbox TPM driver [] Enable RAM drivers using Driver Model [] Driver support for thermal devices
Can we make those into sub-menus as well?
Regards, Bin
Hi Bin,
Looks like I missed some items.. Anyway, they do not have many drivers below them, so menuconfig is not so messy.
Do you want me send v2, or will you send a follow-up patch?
2015-08-01 20:11 GMT+09:00 Bin Meng bmeng.cn@gmail.com:
Hi Masahiro,
+menu "I2C support"
+menu "USB support"
endif
+endmenu
Regards, Bin _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Masahiro,
On Sat, Aug 1, 2015 at 9:27 PM, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Hi Bin,
I can send a follow-up patch.
Hi Masahiro,
[snip]
Regards, Bin
On 25 July 2015 at 11:46, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Simon Glass sjg@chromium.org
participants (6)
Bin Meng
Masahiro Yamada
Paul Kocialkowski
