[U-Boot-Users] [PATCH] Unify pixis_reset altbank across board families
Basically, refactor the CFG_PIXIS_VBOOT_MASK values into the separate board config files.
Signed-off-by: Jason Jin Jason.jin@freescale.com Signed-off-by: Jon Loeliger jdl@freescale.com ---
diff --git a/board/freescale/common/pixis.c b/board/freescale/common/pixis.c index fd99a93..45dcf4d 100644 --- a/board/freescale/common/pixis.c +++ b/board/freescale/common/pixis.c @@ -207,13 +207,16 @@ void read_from_px_regs_altbank(int set) out8(PIXIS_BASE + PIXIS_VCFGEN1, tmp); }
+#ifndef CFG_PIXIS_VBOOT_MASK +#define CFG_PIXIS_VBOOT_MASK 0x40 +#endif
void set_altbank(void) { u8 tmp;
tmp = in8(PIXIS_BASE + PIXIS_VBOOT); - tmp ^= 0x40; + tmp ^= CFG_PIXIS_VBOOT_MASK;
out8(PIXIS_BASE + PIXIS_VBOOT, tmp); } diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index f580cca..13e2a2c 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -198,6 +198,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define PIXIS_VSPEED1 0x18 /* VELA VSpeed 1 */ #define PIXIS_VCLKH 0x19 /* VELA VCLKH register */ #define PIXIS_VCLKL 0x1A /* VELA VCLKL register */ +#define CFG_PIXIS_VBOOT_MASK 0x40 /* Reset altbank mask*/
/* define to use L1 as initial stack */ diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 7d8a380..3e05260 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -201,6 +201,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define PIXIS_VSPEED1 0x18 /* VELA VSpeed 1 */ #define PIXIS_VCLKH 0x19 /* VELA VCLKH register */ #define PIXIS_VCLKL 0x1A /* VELA VCLKL register */ +#define CFG_PIXIS_VBOOT_MASK 0x40 /* Reset altbank mask*/
#define CFG_MAX_FLASH_BANKS 2 /* number of banks */ #define CFG_MAX_FLASH_SECT 128 /* sectors per device */
Jon Loeliger
