[U-Boot] Pull request v2: u-boot-spi/master
Hi Tom,
Please pull this PR.
Changes for v2: - Skip "spi: Zap mpc52xx_spi.c and config" patch due to dependencies.
thanks! Jagan.
The following changes since commit 53e8ca22538c2cec691fe74098684a359302688c:
MAINTAINERS: DFU: Change e-mail address for DFU maintainer (2016-12-12 13:03:15 -0500)
git://git.denx.de/u-boot-spi.git master
for you to fetch changes up to db9225ba2686d6b7e249d00e1803bd07f71d6070:
sf: Do not force the DT memory map size to exactly match the device (2016-12-15 16:57:28 +0100)
---------------------------------------------------------------- Fabien Parent (1): mtd: spi: don't return -1 when scan succeed
Phil Edworthy (10): spi: cadence_qspi: Fix clearing of pol/pha bits spi: cadence_qspi: Fix baud rate calculation spi: cadence_qspi: Better debug information on the SPI clock rate spi: cadence_qspi: Use #define for bits instead of bit shifts spi: cadence_qspi: Clean up the #define names spi: cadence_qspi: Use spi mode at the point it is needed spi: cadence_qspi: Remove returns from end of void functions spi: cadence_qspi: Fix CS timings spi: cadence_qspi: Move DT prop code to match layout sf: Do not force the DT memory map size to exactly match the device
Simon Glass (1): spi: Add error checking for invalid bus widths
Vignesh R (1): ARM: dts: am437x-idk: Fix QSPI compatible string
arch/arm/dts/am437x-idk-evm.dts | 2 +- drivers/mtd/spi/spi_flash.c | 6 +- drivers/spi/cadence_qspi.c | 6 +- drivers/spi/cadence_qspi.h | 3 +- drivers/spi/cadence_qspi_apb.c | 185 ++++++++++++++++++---------------------- drivers/spi/spi-uclass.c | 4 +- 6 files changed, 93 insertions(+), 113 deletions(-)
On Thu, Dec 15, 2016 at 05:05:05PM +0100, Jagan Teki wrote:
Hi Tom,
Changes for v2:
thanks! Jagan.
Sandbox fails to build, and I'm not sure what else yet. Please put your PR through a round with travis-ci before submitting v3, thanks! And for the record, it will build any branch so you can put things into WIP-... or TEST-... or whatever you wish. I personally use WIP-... for my tests.
Hi Tom,
Changes for v2:
thanks! Jagan.
I don't think Sandbox will fail, since none of these related to this anyway I will re-ran the build and send.
thanks!
Hi Tom,
Changes for v2:
thanks! Jagan.
Never find any issues [1].
[1] https://paste.ubuntu.com/23639445/
thanks!
Hi Tom,
Changes for v2:
thanks! Jagan.
Note that sandbox isn't even in your list there. Please see https://travis-ci.org/trini/u-boot/jobs/184309388 for some examples of the build failure.
Hi Tom,
Changes for v2:
thanks! Jagan.
Fixed yesterday itself may be you are not re-based, and don't know why include that patch on run since this patch is not part of my PR?
thanks!
Hi Tom,
Changes for v2:
thanks! Jagan.
OK, I guess I didn't hit reset hard enough, sorry!
Hi Tom,
Changes for v2:
thanks! Jagan.
Jagan Teki
