[U-Boot] [PATCH v3] armv8: QSPI: Add AHB bus 16MB+ size support
The default configuration for QSPI AHB bus can't support 16MB+. But some flash on NXP layerscape board are more than 16MB.
Signed-off-by: Yuan Yao yao.yuan@nxp.com --- Changed in v3: Rename the CONFIG_SYS_QSPI_ADDR to SYS_FSL_QSPI_ADDR. Changed in v2: Remove the CONFIG_QSPI_AHB_INIT into Kconfig. --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 7 ++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 42 ++++++++++++++++++++++ .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 1 + .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 1 + configs/ls1012afrdm_qspi_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 1 + configs/ls1012ardb_qspi_defconfig | 1 + configs/ls1046ardb_qspi_defconfig | 1 + 9 files changed, 56 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 94ec8d5..f078712 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -71,6 +71,13 @@ config NUM_DDR_CONTROLLERS default 3 if ARCH_LS2080A default 1
+config QSPI_AHB_INIT + bool "Init the QSPI AHB bus" + help + The default setting for QSPI AHB bus just support 3bytes addressing. + But some QSPI flash size up to 64MBytes, so initialize the QSPI AHB + bus for those flashes to support the full QSPI flash size. + config SYS_FSL_IFC_BANK_COUNT int "Maximum banks of Integrated flash controller" depends on ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 6c42387..2f54625 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -373,6 +373,45 @@ void fsl_lsch2_early_init_f(void) } #endif
+#ifdef CONFIG_QSPI_AHB_INIT +/* Enable 4bytes address support and fast read */ +int qspi_ahb_init(void) +{ + u32 *qspi_lut, lut_key, *qspi_key; + + qspi_key = (void *)SYS_FSL_QSPI_ADDR + 0x300; + qspi_lut = (void *)SYS_FSL_QSPI_ADDR + 0x310; + + lut_key = in_be32(qspi_key); + + if (lut_key == 0x5af05af0) { + /* That means the register is BE */ + out_be32(qspi_key, 0x5af05af0); + /* Unlock the lut table */ + out_be32(qspi_key + 1, 0x00000002); + out_be32(qspi_lut, 0x0820040c); + out_be32(qspi_lut + 1, 0x1c080c08); + out_be32(qspi_lut + 2, 0x00002400); + /* Lock the lut table */ + out_be32(qspi_key, 0x5af05af0); + out_be32(qspi_key + 1, 0x00000001); + } else { + /* That means the register is LE */ + out_le32(qspi_key, 0x5af05af0); + /* Unlock the lut table */ + out_le32(qspi_key + 1, 0x00000002); + out_le32(qspi_lut, 0x0820040c); + out_le32(qspi_lut + 1, 0x1c080c08); + out_le32(qspi_lut + 2, 0x00002400); + /* Lock the lut table */ + out_le32(qspi_key, 0x5af05af0); + out_le32(qspi_key + 1, 0x00000001); + } + + return 0; +} +#endif + #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { @@ -382,6 +421,9 @@ int board_late_init(void) #ifdef CONFIG_CHAIN_OF_TRUST fsl_setenv_chain_of_trust(); #endif +#ifdef CONFIG_QSPI_AHB_INIT + qspi_ahb_init(); +#endif
return 0; } diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index d88543d..ff0a88a 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -18,6 +18,7 @@ #define CONFIG_SYS_CCI400_ADDR (CONFIG_SYS_IMMR + 0x00180000) #define CONFIG_SYS_GIC400_ADDR (CONFIG_SYS_IMMR + 0x00400000) #define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x00530000) +#define SYS_FSL_QSPI_ADDR (CONFIG_SYS_IMMR + 0x00550000) #define CONFIG_SYS_FSL_ESDHC_ADDR (CONFIG_SYS_IMMR + 0x00560000) #define CONFIG_SYS_FSL_CSU_ADDR (CONFIG_SYS_IMMR + 0x00510000) #define CONFIG_SYS_FSL_GUTS_ADDR (CONFIG_SYS_IMMR + 0x00ee0000) diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 2df56f7..e18dcbd 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -19,6 +19,7 @@ #define CONFIG_SYS_FSL_CH3_CLK_GRPA_ADDR (CONFIG_SYS_IMMR + 0x00300000) #define CONFIG_SYS_FSL_CH3_CLK_GRPB_ADDR (CONFIG_SYS_IMMR + 0x00310000) #define CONFIG_SYS_FSL_CH3_CLK_CTRL_ADDR (CONFIG_SYS_IMMR + 0x00370000) +#define SYS_FSL_QSPI_ADDR (CONFIG_SYS_IMMR + 0x010c0000) #define CONFIG_SYS_FSL_ESDHC_ADDR (CONFIG_SYS_IMMR + 0x01140000) #define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x01240000) #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x011C0500) diff --git a/configs/ls1012afrdm_qspi_defconfig b/configs/ls1012afrdm_qspi_defconfig index 1f3d487..c83b2eb 100644 --- a/configs/ls1012afrdm_qspi_defconfig +++ b/configs/ls1012afrdm_qspi_defconfig @@ -34,3 +34,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_QSPI_AHB_INIT=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index c0514ae..27bccd1 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -38,3 +38,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_QSPI_AHB_INIT=y diff --git a/configs/ls1012ardb_qspi_defconfig b/configs/ls1012ardb_qspi_defconfig index 13c9f21..459682d 100644 --- a/configs/ls1012ardb_qspi_defconfig +++ b/configs/ls1012ardb_qspi_defconfig @@ -38,3 +38,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_QSPI_AHB_INIT=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index 8508c09..fa17373 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -24,3 +24,4 @@ CONFIG_SPI_FLASH=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y +CONFIG_QSPI_AHB_INIT=y
Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
york sun
Yuan Yao
