[PATCH 1/2] xilinx: Align dfu ram with booti command
Image should be loaded to 0x80000 address and not to $kernel_addr_r. Also kernel_addr, fdt_addr and fdt_size in zynqmp case are not defined that's why define it to be aligned with Versal.
include/configs/xilinx_versal.h | 2 +- include/configs/xilinx_zynqmp.h | 6 ++++-- 2 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/include/configs/xilinx_versal.h b/include/configs/xilinx_versal.h index 804525dcad26..32cd5b21f7b7 100644 --- a/include/configs/xilinx_versal.h +++ b/include/configs/xilinx_versal.h @@ -54,7 +54,7 @@ #define DFU_ALT_INFO_RAM \ "dfu_ram_info=" \ "setenv dfu_alt_info " \ - "Image ram $kernel_addr_r $kernel_size_r\\;" \ + "Image ram 80000 $kernel_size_r\\;" \ "system.dtb ram $fdt_addr_r $fdt_size_r\0" \ "dfu_ram=run dfu_ram_info && dfu 0 ram 0\0" \ "thor_ram=run dfu_ram_info && thordown 0 ram 0\0" diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index e7cfebee7c46..86f292761b38 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -58,8 +58,8 @@ #define DFU_ALT_INFO_RAM \ "dfu_ram_info=" \ "setenv dfu_alt_info " \ - "Image ram $kernel_addr $kernel_size\\;" \ - "system.dtb ram $fdt_addr $fdt_size\0" \ + "Image ram 80000 $kernel_size_r\\;" \ + "system.dtb ram $fdt_addr_r $fdt_size_r\0" \ "dfu_ram=run dfu_ram_info && dfu 0 ram 0\0" \ "thor_ram=run dfu_ram_info && thordown 0 ram 0\0"
@@ -101,8 +101,10 @@ #define ENV_MEM_LAYOUT_SETTINGS \ "fdt_high=10000000\0" \ "fdt_addr_r=0x40000000\0" \ + "fdt_size_r=0x400000\0" \ "pxefile_addr_r=0x10000000\0" \ "kernel_addr_r=0x18000000\0" \ + "kernel_size_r=0x10000000\0" \ "scriptaddr=0x20000000\0" \ "ramdisk_addr_r=0x02100000\0" \ "script_size_f=0x80000\0" \
Enable DFU tftp support for firmware update. Fill dfu_ram_tftp variable to have command present for showing how to use it.
boot FIT image has been created from below fragment. Key part is that type of image has to be firmware. Also based on experiment load property is completely ignored and base addresses are taken from dfu_alt_info variable.
$ cat update_uboot.its /dts-v1/;
/ { description = "Automatic U-Boot update"; #address-cells = <1>;
images { Image { description = "Kernel"; data = /incbin/("/tftpboot/Image"); compression = "none"; arch = "arm64"; type = "firmware"; os = "linux"; load = <0x80000>; entry = <0x80000>; hash-1 { algo = "sha1"; }; }; system.dtb { description = "DTB"; data = /incbin/("/tftpboot/system.dtb"); compression = "none"; arch = "arm64"; type = "firmware"; load = <0>; hash-1 { algo = "sha1"; }; }; }; };
$ mkimage -f update_uboot.its /tftpboot/boot
When U-Boot starts get IP address and server IP. dhcp setenv serverip 192.168.0.105
And then run prepared command. run dfu_ram_tftp
configs/xilinx_zynqmp_virt_defconfig | 1 + include/configs/xilinx_zynqmp.h | 4 +++- 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index d77ba051624e..2d84f0c04e12 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -69,6 +69,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SCSI_AHCI=y CONFIG_SATA_CEVA=y CONFIG_CLK_ZYNQMP=y +CONFIG_DFU_TFTP=y CONFIG_DFU_RAM=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_FLASH=y diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 86f292761b38..f45a1a2272d3 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -61,7 +61,9 @@ "Image ram 80000 $kernel_size_r\\;" \ "system.dtb ram $fdt_addr_r $fdt_size_r\0" \ "dfu_ram=run dfu_ram_info && dfu 0 ram 0\0" \ - "thor_ram=run dfu_ram_info && thordown 0 ram 0\0" + "thor_ram=run dfu_ram_info && thordown 0 ram 0\0" \ + "dfu_ram_tftp=run dfu_ram_info && setenv updatefile boot && " \ + "setenv loadaddr 10000000 && dfu tftp ram 0\0"
#define DFU_ALT_INFO \ DFU_ALT_INFO_RAM
st 15. 7. 2020 v 15:51 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
#define DFU_ALT_INFO \ DFU_ALT_INFO_RAM -- 2.27.0
Applied. M
"Image ram $kernel_addr_r $kernel_size_r\\\\;" \
"Image ram 80000 $kernel_size_r\\\\;" \ "system.dtb ram $fdt_addr_r $fdt_size_r\0" \ "dfu_ram=run dfu_ram_info && dfu 0 ram 0\0" \ "thor_ram=run dfu_ram_info && thordown 0 ram 0\0"
"Image ram $kernel_addr $kernel_size\\\\;" \
-- 2.27.0
Applied. M
Michal Simek
Michal Simek
