[U-Boot] [PATCH 0/2] tegra124: Add support for Avionic Design platform
This adds support for the Avionic Design Tegra124 platform. It consists of the Meerkat SOM and a minimal baseboard Kein Baseboard. The as3722 is placed on a different bus as compared to nvidia Jetson, which makes the as3722 required.
Alban Bedel (1): power: as3722: Allow using on any i2c bus with any address
Julian Scheel (1): Add support the Avionic Design Meerkat COM and Kein Baseboard
arch/arm/dts/Makefile | 1 + arch/arm/dts/tegra124-kein-baseboard.dts | 66 ++++ arch/arm/dts/tegra124-meerkat.dtsi | 395 +++++++++++++++++++++ arch/arm/mach-tegra/board2.c | 2 +- arch/arm/mach-tegra/tegra124/Kconfig | 9 + board/avionic-design/common/meerkat.c | 70 ++++ .../avionic-design/common/pinmux-config-meerkat.h | 233 ++++++++++++ board/avionic-design/kein-baseboard/Kconfig | 15 + board/avionic-design/kein-baseboard/MAINTAINERS | 7 + board/avionic-design/kein-baseboard/Makefile | 9 + board/nvidia/jetson-tk1/jetson-tk1.c | 2 +- configs/kein-baseboard_defconfig | 21 ++ drivers/power/as3722.c | 4 +- include/configs/kein-baseboard.h | 76 ++++ include/power/as3722.h | 2 +- 15 files changed, 906 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/tegra124-kein-baseboard.dts create mode 100644 arch/arm/dts/tegra124-meerkat.dtsi create mode 100644 board/avionic-design/common/meerkat.c create mode 100644 board/avionic-design/common/pinmux-config-meerkat.h create mode 100644 board/avionic-design/kein-baseboard/Kconfig create mode 100644 board/avionic-design/kein-baseboard/MAINTAINERS create mode 100644 board/avionic-design/kein-baseboard/Makefile create mode 100644 configs/kein-baseboard_defconfig create mode 100644 include/configs/kein-baseboard.h
The init simply hardcoded the i2c bus and address to those used on jetson. Extend the init function to take the bus number and device address as parameter. As only jetson is using this code for now just fix this single use of the function.
Signed-off-by: Alban Bedel alban.bedel@avionic-design.de Reviewed-by: Julian Scheel julian@jusst.de --- arch/arm/mach-tegra/board2.c | 2 +- board/nvidia/jetson-tk1/jetson-tk1.c | 2 +- drivers/power/as3722.c | 4 +--- include/power/as3722.h | 2 +- 4 files changed, 4 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-tegra/board2.c b/arch/arm/mach-tegra/board2.c index ac274e1..55c50df 100644 --- a/arch/arm/mach-tegra/board2.c +++ b/arch/arm/mach-tegra/board2.c @@ -148,7 +148,7 @@ int board_init(void) # endif # endif /* CONFIG_TEGRA_PMU */ #ifdef CONFIG_AS3722_POWER - err = as3722_init(NULL); + err = as3722_init(NULL, 0, 0x40); if (err && err != -ENODEV) return err; #endif diff --git a/board/nvidia/jetson-tk1/jetson-tk1.c b/board/nvidia/jetson-tk1/jetson-tk1.c index 14f0ce5..7f16a4a 100644 --- a/board/nvidia/jetson-tk1/jetson-tk1.c +++ b/board/nvidia/jetson-tk1/jetson-tk1.c @@ -39,7 +39,7 @@ int tegra_pcie_board_init(void) struct udevice *pmic; int err;
- err = as3722_init(&pmic); + err = as3722_init(&pmic, 0, 0x40); if (err) { error("failed to initialize AS3722 PMIC: %d\n", err); return err; diff --git a/drivers/power/as3722.c b/drivers/power/as3722.c index c09e1de..321d65d 100644 --- a/drivers/power/as3722.c +++ b/drivers/power/as3722.c @@ -243,12 +243,10 @@ int as3722_get(struct udevice **devp) return i2c_get_chip_for_busnum(bus, address, 1, devp); }
-int as3722_init(struct udevice **devp) +int as3722_init(struct udevice **devp, unsigned int bus, unsigned int address) { struct udevice *pmic; u8 id, revision; - const unsigned int bus = 0; - const unsigned int address = 0x40; int err;
err = i2c_get_chip_for_busnum(bus, address, 1, &pmic); diff --git a/include/power/as3722.h b/include/power/as3722.h index 0f22482..c37b43a 100644 --- a/include/power/as3722.h +++ b/include/power/as3722.h @@ -14,7 +14,7 @@
struct udevice;
-int as3722_init(struct udevice **devp); +int as3722_init(struct udevice **devp, unsigned int bus, unsigned int address); int as3722_sd_enable(struct udevice *pmic, unsigned int sd); int as3722_sd_set_voltage(struct udevice *pmic, unsigned int sd, u8 value); int as3722_ldo_enable(struct udevice *pmic, unsigned int ldo);
Since you (Julian) are submitting this, it should be s-o-b you too.
Irrespective of my comments on the cover letter, this patch seems fine, so once the s-o-b is fixed, Acked-by: Stephen Warren swarren@nvidia.com
Add support for platforms based on the Meerkat COM module. Includes support for the minimal reference platform called Kein Baseboard, which in fact is sufficient to run most existing Meerkat carriers.
Signed-off-by: Julian Scheel julian@jusst.de --- arch/arm/dts/Makefile | 1 + arch/arm/dts/tegra124-kein-baseboard.dts | 66 ++++ arch/arm/dts/tegra124-meerkat.dtsi | 395 +++++++++++++++++++++ arch/arm/mach-tegra/tegra124/Kconfig | 9 + board/avionic-design/common/meerkat.c | 70 ++++ .../avionic-design/common/pinmux-config-meerkat.h | 233 ++++++++++++ board/avionic-design/kein-baseboard/Kconfig | 15 + board/avionic-design/kein-baseboard/MAINTAINERS | 7 + board/avionic-design/kein-baseboard/Makefile | 9 + configs/kein-baseboard_defconfig | 21 ++ include/configs/kein-baseboard.h | 76 ++++ 11 files changed, 902 insertions(+) create mode 100644 arch/arm/dts/tegra124-kein-baseboard.dts create mode 100644 arch/arm/dts/tegra124-meerkat.dtsi create mode 100644 board/avionic-design/common/meerkat.c create mode 100644 board/avionic-design/common/pinmux-config-meerkat.h create mode 100644 board/avionic-design/kein-baseboard/Kconfig create mode 100644 board/avionic-design/kein-baseboard/MAINTAINERS create mode 100644 board/avionic-design/kein-baseboard/Makefile create mode 100644 configs/kein-baseboard_defconfig create mode 100644 include/configs/kein-baseboard.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b574284..5452e69 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -41,6 +41,7 @@ dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra30-tec-ng.dtb \ tegra114-dalmore.dtb \ tegra124-jetson-tk1.dtb \ + tegra124-kein-baseboard.dtb \ tegra124-nyan-big.dtb \ tegra124-venice2.dtb \ tegra210-e2220-1170.dtb \ diff --git a/arch/arm/dts/tegra124-kein-baseboard.dts b/arch/arm/dts/tegra124-kein-baseboard.dts new file mode 100644 index 0000000..75a0b99 --- /dev/null +++ b/arch/arm/dts/tegra124-kein-baseboard.dts @@ -0,0 +1,66 @@ +/dts-v1/; + +#include "tegra124-meerkat.dtsi" + +/ { + model = "Avionic Design Kein Baseboard"; + compatible = "ad,kein-baseboard", "ad,meerkat", "nvidia,tegra124"; + + chosen { + stdout-path = &uartd; + }; + + serial@70006300 { + status = "okay"; + }; + + sdhci@700b0400 { + status = "okay"; + }; + + usb@7d000000 { + status = "okay"; + }; + + usb@7d004000 { + status = "okay"; + }; + + usb@7d008000 { + status = "okay"; + }; + + pcie-controller@01003000 { + status = "okay"; + + pci@1,0 { + status = "okay"; + }; + + pci@2,0 { + status = "okay"; + }; + }; + + regulators { + vdd_5v0: regulator@100 { + compatible = "regulator-fixed"; + reg = <100>; + regulator-name = "+VDD_5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_3v3: regulator@101 { + compatible = "regulator-fixed"; + reg = <101>; + regulator-name = "+VDD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + }; +}; diff --git a/arch/arm/dts/tegra124-meerkat.dtsi b/arch/arm/dts/tegra124-meerkat.dtsi new file mode 100644 index 0000000..88a7c86 --- /dev/null +++ b/arch/arm/dts/tegra124-meerkat.dtsi @@ -0,0 +1,395 @@ + +#include "tegra124.dtsi" + +/ { + model = "Avionic-Design Meerkat"; + compatible = "ad,meerkat", "nvidia,tegra124"; + + aliases { + i2c0 = "/i2c@7000c000"; + i2c1 = "/i2c@7000c400"; + i2c2 = "/i2c@7000c500"; + i2c3 = "/i2c@7000c700"; + i2c4 = "/i2c@7000d000"; + i2c5 = "/i2c@7000d100"; + + sdhci0 = "/sdhci@700b0600"; + sdhci1 = "/sdhci@700b0400"; + + usb0 = "/usb@7d000000"; + usb1 = "/usb@7d008000"; + }; + + memory { + device_type = "memory"; + reg = <0x80000000 0x80000000>; + }; + + pcie-controller@01003000 { + avddio-pex-supply = <&vdd_1v05_run>; + dvddio-pex-supply = <&vdd_1v05_run>; + avdd-pex-pll-supply = <&vdd_1v05_run>; + hvdd-pex-supply = <&vdd_3v3_lp0>; + hvdd-pex-pll-e-supply = <&vdd_3v3_lp0>; + vddio-pex-ctl-supply = <&vdd_3v3_lp0>; + avdd-pll-erefe-supply = <&avdd_1v05_run>; + }; + + /* Expansion GEN1_I2C_* */ + i2c@7000c000 { + clock-frequency = <100000>; + }; + + /* Expansion GEN2_I2C_* */ + i2c@7000c400 { + clock-frequency = <100000>; + }; + + /* Expansion CAM_I2C_* */ + i2c@7000c500 { + clock-frequency = <100000>; + }; + + /* HDMI DDC */ + hdmi_ddc: i2c@7000c700 { + clock-frequency = <100000>; + }; + + /* Expansion PWR_I2C_*, on-board components */ + i2c@7000d000 { + status = "okay"; + clock-frequency = <400000>; + + pmic: pmic@40 { + compatible = "ams,as3722"; + reg = <0x40>; + interrupts = <0 86 IRQ_TYPE_LEVEL_HIGH>; + + ams,system-power-controller; + + #interrupt-cells = <2>; + interrupt-controller; + + gpio-controller; + #gpio-cells = <2>; + + pinctrl-names = "default"; + pinctrl-0 = <&as3722_default>; + + as3722_default: pinmux { + gpio0 { + pins = "gpio0"; + function = "gpio"; + bias-pull-down; + }; + + gpio1_2_4_7 { + pins = "gpio1", "gpio2", "gpio4", "gpio7"; + function = "gpio"; + bias-pull-up; + }; + + gpio3_5_6 { + pins = "gpio3", "gpio5", "gpio6"; + bias-high-impedance; + }; + }; + + regulators { + vsup-sd2-supply = <&vdd_5v0_sys>; + vsup-sd3-supply = <&vdd_5v0_sys>; + vsup-sd4-supply = <&vdd_5v0_sys>; + vsup-sd5-supply = <&vdd_5v0_sys>; + vin-ldo0-supply = <&vdd_1v35_lp0>; + vin-ldo1-6-supply = <&vdd_3v3_run>; + vin-ldo2-5-7-supply = <&vddio_1v8>; + vin-ldo3-4-supply = <&vdd_3v3_sys>; + vin-ldo9-10-supply = <&vdd_5v0_sys>; + vin-ldo11-supply = <&vdd_3v3_run>; + + vdd_cpu: sd0 { + regulator-name = "+VDD_CPU_AP"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1400000>; + regulator-min-microamp = <3500000>; + regulator-max-microamp = <3500000>; + regulator-always-on; + regulator-boot-on; + ams,ext-control = <2>; + }; + + sd1 { + regulator-name = "+VDD_CORE"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-min-microamp = <2500000>; + regulator-max-microamp = <2500000>; + regulator-always-on; + regulator-boot-on; + ams,ext-control = <1>; + }; + + vdd_1v35_lp0: sd2 { + regulator-name = "+1V35_LP0(sd2)"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + }; + + sd3 { + regulator-name = "+1V35_LP0(sd3)"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_1v05_run: sd4 { + regulator-name = "+1V05_RUN"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + }; + + vddio_1v8: sd5 { + regulator-name = "+1V8_VDDIO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + vdd_gpu: sd6 { + regulator-name = "+VDD_GPU_AP"; + regulator-min-microvolt = <650000>; + regulator-max-microvolt = <1200000>; + regulator-min-microamp = <3500000>; + regulator-max-microamp = <3500000>; + regulator-boot-on; + regulator-always-on; + }; + + avdd_1v05_run: ldo0 { + regulator-name = "+1V05_RUN_AVDD"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + regulator-boot-on; + regulator-always-on; + ams,ext-control = <1>; + }; + + ldo1 { + regulator-name = "+1V8_RUN_CAM"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + ldo2 { + regulator-name = "+1V2_GEN_AVDD"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3 { + regulator-name = "+1V05_LP0_VDD_RTC"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-boot-on; + regulator-always-on; + ams,enable-tracking; + }; + + ldo4 { + regulator-name = "+2V8_RUN_CAM"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + + ldo5 { + regulator-name = "+1V2_RUN_CAM_FRONT"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + }; + + vddio_sdmmc3: ldo6 { + regulator-name = "+VDDIO_SDMMC3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + + ldo7 { + regulator-name = "+1V05_RUN_CAM_REAR"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + }; + + ldo9 { + regulator-name = "+3V3_RUN_TOUCH"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + + ldo10 { + regulator-name = "+2V8_RUN_CAM_AF"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + + ldo11 { + regulator-name = "+1V8_RUN_VPP_FUSE"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + }; + }; + }; + + i2c@7000d100 { + clock-frequency = <400000>; + }; + + spi@7000d400 { + spi-max-frequency = <25000000>; + }; + + spi@7000da00 { + spi-max-frequency = <25000000>; + }; + + padctl@7009f000 { + pinctrl-0 = <&padctl_default>; + pinctrl-names = "default"; + + padctl_default: pinmux { + usb3 { + nvidia,lanes = "pcie-0", "pcie-1"; + nvidia,function = "usb3"; + nvidia,iddq = <0>; + }; + + pcie { + nvidia,lanes = "pcie-2", "pcie-3", + "pcie-4"; + nvidia,function = "pcie"; + nvidia,iddq = <0>; + }; + + sata { + nvidia,lanes = "sata-0"; + nvidia,function = "sata"; + nvidia,iddq = <0>; + }; + }; + }; + + sdhci@700b0400 { + cd-gpios = <&gpio TEGRA_GPIO(V, 2) GPIO_ACTIVE_LOW>; + power-gpios = <&gpio TEGRA_GPIO(R, 0) GPIO_ACTIVE_HIGH>; + bus-width = <4>; + }; + + sdhci@700b0600 { + status = "okay"; + bus-width = <8>; + }; + + usb@7d000000 { + dr_mode = "otg"; + nvidia,vbus-gpio = <&gpio TEGRA_GPIO(N, 4) GPIO_ACTIVE_HIGH>; + }; + + usb@7d004000 { + phy_type = "utmi"; + nvidia,vbus-gpio = <&gpio TEGRA_GPIO(N, 5) GPIO_ACTIVE_HIGH>; + }; + + usb@7d008000 { + nvidia,vbus-gpio = <&gpio TEGRA_GPIO(FF, 1) GPIO_ACTIVE_HIGH>; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + vdd_mux: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "+VDD_MUX"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_5v0>; + }; + + vdd_5v0_sys: regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "+5V_SYS"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_mux>; + }; + + vdd_3v3_sys: regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "+3.3V_SYS"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vdd_3v3>; + }; + + vdd_3v3_run: regulator@3 { + compatible = "regulator-fixed"; + reg = <3>; + regulator-name = "+3.3V_RUN"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + gpio = <&pmic 1 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_3v3_sys>; + }; + + vdd_3v3_hdmi: regulator@4 { + compatible = "regulator-fixed"; + reg = <4>; + regulator-name = "+3.3V_AVDD_HDMI_AP_GATED"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vdd_3v3_run>; + }; + + vdd_3v3_lp0: regulator@5 { + compatible = "regulator-fixed"; + reg = <5>; + regulator-name = "+3.3V_LP0"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + gpio = <&pmic 2 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_3v3_sys>; + }; + + vdd_hdmi_pll: regulator@6 { + compatible = "regulator-fixed"; + reg = <6>; + regulator-name = "+1.05V_RUN_AVDD_HDMI_PLL"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + gpio = <&gpio TEGRA_GPIO(H, 7) GPIO_ACTIVE_LOW>; + vin-supply = <&vdd_1v05_run>; + }; + }; +}; diff --git a/arch/arm/mach-tegra/tegra124/Kconfig b/arch/arm/mach-tegra/tegra124/Kconfig index f3324ff..f21338f 100644 --- a/arch/arm/mach-tegra/tegra124/Kconfig +++ b/arch/arm/mach-tegra/tegra124/Kconfig @@ -21,6 +21,14 @@ config TARGET_NYAN_BIG config TARGET_VENICE2 bool "NVIDIA Tegra124 Venice2"
+config TARGET_KBB + bool "Avionic Design Kein Baseboard" + select CPU_V7_HAS_NONSEC if !SPL_BUILD + select CPU_V7_HAS_VIRT if !SPL_BUILD + help + Minimal baseboard for Avionic Design Meerkat COM. Should work with most + baseboard that follow the reference design. + endchoice
config SYS_SOC @@ -29,5 +37,6 @@ config SYS_SOC source "board/nvidia/jetson-tk1/Kconfig" source "board/nvidia/nyan-big/Kconfig" source "board/nvidia/venice2/Kconfig" +source "board/avionic-design/kein-baseboard/Kconfig"
endif diff --git a/board/avionic-design/common/meerkat.c b/board/avionic-design/common/meerkat.c new file mode 100644 index 0000000..2d1111f --- /dev/null +++ b/board/avionic-design/common/meerkat.c @@ -0,0 +1,70 @@ +/* + * (C) Copyright 2014, NVIDIA Corporation <www.nvidia.com> + * (C) Copyright 2015, Avionic Design <www.avionic-design.de> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <power/as3722.h> + +#include <asm/arch/gpio.h> +#include <asm/arch/pinmux.h> +#include "pinmux-config-meerkat.h" + +/* + * Routine: pinmux_init + * Description: Do individual peripheral pinmux configs + */ +void pinmux_init(void) +{ + pinmux_set_tristate_input_clamping(); + + pinmux_config_pingrp_table(meerkat_pingrps, + ARRAY_SIZE(meerkat_pingrps)); + + pinmux_config_drvgrp_table(meerkat_drvgrps, + ARRAY_SIZE(meerkat_drvgrps)); +} + +#ifdef CONFIG_PCI_TEGRA +int tegra_pcie_board_init(void) +{ + struct udevice *pmic; + int err; + + err = as3722_init(&pmic, 4, 0x40); + if (err) { + error("failed to initialize AS3722 PMIC: %d\n", err); + return err; + } + + err = as3722_sd_enable(pmic, 4); + if (err < 0) { + error("failed to enable SD4: %d\n", err); + return err; + } + + err = as3722_sd_set_voltage(pmic, 4, 0x24); + if (err < 0) { + error("failed to set SD4 voltage: %d\n", err); + return err; + } + + err = as3722_gpio_configure(pmic, 1, AS3722_GPIO_OUTPUT_VDDH | + AS3722_GPIO_INVERT); + if (err < 0) { + error("failed to configure GPIO#1 as output: %d\n", err); + return err; + } + + err = as3722_gpio_direction_output(pmic, 2, 1); + if (err < 0) { + error("failed to set GPIO#2 high: %d\n", err); + return err; + } + + return 0; +} +#endif /* PCI */ diff --git a/board/avionic-design/common/pinmux-config-meerkat.h b/board/avionic-design/common/pinmux-config-meerkat.h new file mode 100644 index 0000000..6be55fd --- /dev/null +++ b/board/avionic-design/common/pinmux-config-meerkat.h @@ -0,0 +1,233 @@ +/* + * Copyright (c) 2014, NVIDIA CORPORATION. All rights reserved. + * Copyright (c) 2015, Avionic Design GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _PINMUX_CONFIG_MEERKAT_H_ +#define _PINMUX_CONFIG_MEERKAT_H_ + +#define PINCFG(_pingrp, _mux, _pull, _tri, _io, _od, _rcv_sel) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .od = PMUX_PIN_OD_##_od, \ + .rcv_sel = PMUX_PIN_RCV_SEL_##_rcv_sel, \ + .lock = PMUX_PIN_LOCK_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +static const struct pmux_pingrp_config meerkat_pingrps[] = { + /* pingrp, mux, pull, tri, e_input, od, rcv_sel */ + PINCFG(CLK_32K_OUT_PA0, SOC, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_CTS_N_PA1, UARTC, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_FS_PA2, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_SCLK_PA3, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DIN_PA4, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP2_DOUT_PA5, I2S1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PB0, UARTD, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PB1, UARTD, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RTS_N_PC0, UARTC, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_TXD_PC2, IRDA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RXD_PC3, IRDA, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PC7, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG2, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG3, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PG4, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG5, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG6, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PG7, SPI4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH0, GMI, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH1, PWM1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH4, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PH6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PH7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI1, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI3, SPI4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PI5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PI7, RSVD1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PJ0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PJ2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART2_CTS_N_PJ5, UARTB, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(UART2_RTS_N_PJ6, UARTB, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PJ7, UARTD, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK0, SOC, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK3, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PK4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_OUT_PK5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SPDIF_IN_PK6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PK7, UARTD, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_FS_PN0, I2S0, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DIN_PN1, I2S0, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_DOUT_PN2, SATA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP1_SCLK_PN3, I2S0, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN0_PN4, USB, UP, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(USB_VBUS_EN1_PN5, USB, UP, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(HDMI_INT_PN7, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(ULPI_DATA7_PO0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA0_PO1, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA1_PO2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA2_PO3, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA3_PO4, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA4_PO5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA5_PO6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DATA6_PO7, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_FS_PP0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DIN_PP1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_DOUT_PP2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP3_SCLK_PP3, RSVD3, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_FS_PP4, I2S3, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DIN_PP5, I2S3, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_DOUT_PP6, I2S3, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP4_SCLK_PP7, I2S3, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL0_PQ0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL1_PQ1, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL2_PQ2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL3_PQ3, KBC, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL4_PQ4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL5_PQ5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL6_PQ6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_COL7_PQ7, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW0_PR0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW1_PR1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW2_PR2, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW3_PR3, SYS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW4_PR4, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW5_PR5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW6_PR6, DISPLAYA_ALT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW7_PR7, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW8_PS0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW9_PS1, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW10_PS2, RSVD2, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW11_PS3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW12_PS4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW13_PS5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW14_PS6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW15_PS7, SOC, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW16_PT0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(KB_ROW17_PT1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_CMD_PT7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU0, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU1, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU2, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PU5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PU6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PV0, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PV1, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CD_N_PV2, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_WP_N_PV3, SDMMC1, DOWN, TRISTATE, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DEFAULT, NORMAL), + PINCFG(GPIO_W2_AUD_PW2, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_W3_AUD_PW3, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_PW4, EXTPERIPH1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_OUT_PW5, EXTPERIPH2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(UART3_RXD_PW7, UARTC, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_PWM_PX0, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X1_AUD_PX1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DVFS_CLK_PX2, CLDVFS, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X3_AUD_PX3, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X4_AUD_PX4, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X5_AUD_PX5, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X6_AUD_PX6, DEFAULT, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(GPIO_X7_AUD_PX7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_CLK_PY0, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_DIR_PY1, SPI1, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_NXT_PY2, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(ULPI_STP_PY3, SPI1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT3_PY4, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT2_PY5, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT1_PY6, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_DAT0_PY7, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CLK_PZ0, SDMMC1, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC1_CMD_PZ1, SDMMC1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PBB0, VIMCLK2_ALT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CAM_I2C_SCL_PBB1, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(CAM_I2C_SDA_PBB2, I2C3, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PBB3, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB4, VGP4, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB6, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PBB7, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CAM_MCLK_PCC0, VI_ALT3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PCC1, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PCC2, DEFAULT, DOWN, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(CLK2_REQ_PCC5, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_RST_N_PDD1, PE0, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L0_CLKREQ_N_PDD2, PE0, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PEX_WAKE_N_PDD3, PE, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_RST_N_PDD5, PE1, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PEX_L1_CLKREQ_N_PDD6, PE1, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_OUT_PEE0, EXTPERIPH3, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CLK3_REQ_PEE1, DEFAULT, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(DAP_MCLK1_REQ_PEE2, SATA, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(SDMMC3_CLK_LB_OUT_PEE4, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(SDMMC3_CLK_LB_IN_PEE5, SDMMC3, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(DP_HPD_PFF0, DP, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(USB_VBUS_EN2_PFF1, USB, UP, NORMAL, INPUT, ENABLE, DEFAULT), + PINCFG(PFF2, DEFAULT, UP, NORMAL, INPUT, DISABLE, DEFAULT), + PINCFG(CORE_PWR_REQ, PWRON, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(CPU_PWR_REQ, RSVD2, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(PWR_INT_N, PMI, UP, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(RESET_OUT_N, RESET_OUT_N, NORMAL, NORMAL, OUTPUT, DEFAULT, DEFAULT), + PINCFG(OWR, RSVD2, DOWN, TRISTATE, OUTPUT, DEFAULT, NORMAL), + PINCFG(CLK_32K_IN, RSVD2, NORMAL, NORMAL, INPUT, DEFAULT, DEFAULT), + PINCFG(JTAG_RTCK, RTCK, UP, NORMAL, OUTPUT, DEFAULT, DEFAULT), +}; + +#define DRVCFG(_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) \ + { \ + .drvgrp = PMUX_DRVGRP_##_drvgrp, \ + .slwf = _slwf, \ + .slwr = _slwr, \ + .drvup = _drvup, \ + .drvdn = _drvdn, \ + .lpmd = PMUX_LPMD_##_lpmd, \ + .schmt = PMUX_SCHMT_##_schmt, \ + .hsm = PMUX_HSM_##_hsm, \ + } + +static const struct pmux_drvgrp_config meerkat_drvgrps[] = { +}; + +#endif /* PINMUX_CONFIG_MEERKAT_H */ diff --git a/board/avionic-design/kein-baseboard/Kconfig b/board/avionic-design/kein-baseboard/Kconfig new file mode 100644 index 0000000..e66267f --- /dev/null +++ b/board/avionic-design/kein-baseboard/Kconfig @@ -0,0 +1,15 @@ +if TARGET_KBB + +config SYS_BOARD + string + default "kein-baseboard" + +config SYS_VENDOR + string + default "avionic-design" + +config SYS_CONFIG_NAME + string + default "kein-baseboard" + +endif diff --git a/board/avionic-design/kein-baseboard/MAINTAINERS b/board/avionic-design/kein-baseboard/MAINTAINERS new file mode 100644 index 0000000..4fa20a9 --- /dev/null +++ b/board/avionic-design/kein-baseboard/MAINTAINERS @@ -0,0 +1,7 @@ +Kein Baseboard +M: Julian Scheel julian@jusst.de +M: Alban Bedel alban.bedel@avionic-design.de +S: Maintained +F: board/avionic-design/kein-baseboard +F: include/configs/kein-baseboard.h +F: configs/kein-baseboard_defconfig diff --git a/board/avionic-design/kein-baseboard/Makefile b/board/avionic-design/kein-baseboard/Makefile new file mode 100644 index 0000000..59760f6 --- /dev/null +++ b/board/avionic-design/kein-baseboard/Makefile @@ -0,0 +1,9 @@ +# +# (C) Copyright 2015 +# Avionic Design GmbH <www.avionic-design.de> +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += ../../nvidia/venice2/as3722_init.o +obj-y += ../common/meerkat.o diff --git a/configs/kein-baseboard_defconfig b/configs/kein-baseboard_defconfig new file mode 100644 index 0000000..a5a0686 --- /dev/null +++ b/configs/kein-baseboard_defconfig @@ -0,0 +1,21 @@ +CONFIG_ARM=y +CONFIG_TEGRA=y +CONFIG_SPL_DM=y +CONFIG_TEGRA124=y +CONFIG_TARGET_KBB=y +CONFIG_DEFAULT_DEVICE_TREE="tegra124-kein-baseboard" +CONFIG_SYS_PROMPT="Tegra124 (kein-baseboard) # " +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NFS is not set +CONFIG_PCI_TEGRA=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_RADOM_UUID=y diff --git a/include/configs/kein-baseboard.h b/include/configs/kein-baseboard.h new file mode 100644 index 0000000..407a23a --- /dev/null +++ b/include/configs/kein-baseboard.h @@ -0,0 +1,76 @@ +/* + * (C) Copyright 2014-2016 Avionic Design GmbH + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/sizes.h> + +/* enable PMIC */ +#define CONFIG_AS3722_POWER + +#include "tegra124-common.h" + +/* High-level configuration options */ +#define CONFIG_TEGRA_BOARD_STRING "Avionic-Design Kein Baseboard" + +/* Board-specific serial config */ +#define CONFIG_TEGRA_ENABLE_UARTD +#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTD_BASE + +/* I2C */ +#define CONFIG_SYS_I2C_TEGRA +#define CONFIG_CMD_I2C + +/* SD/MMC */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_TEGRA_MMC +#define CONFIG_CMD_MMC +#define CONFIG_CMD_GPT +#define CONFIG_RANDOM_UUID + +/* Environment in eMMC, at the end of 2nd "boot sector" */ +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 2 + +/* USB Host support */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_TEGRA +#define CONFIG_USB_MAX_CONTROLLER_COUNT 3 +#define CONFIG_USB_STORAGE +#define CONFIG_CMD_USB + +/* USB networking support */ +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_RNDIS +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_USB_ETHER_MCS7830 +#define CONFIG_USB_ETHER_SMSC95XX + +/* PCI host support */ +#define CONFIG_PCI +#define CONFIG_PCI_PNP +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PCI_ENUM + +/* General networking support */ +#define CONFIG_CMD_DHCP + +/* support the new (FDT-based) image format */ +#define CONFIG_FIT + +#include "tegra-common-usb-gadget.h" +#include "tegra-common-post.h" + +#define CONFIG_ARMV7_PSCI 1 +/* Reserve top 1M for secure RAM */ +#define CONFIG_ARMV7_SECURE_BASE 0xfff00000 +#define CONFIG_ARMV7_SECURE_RESERVE_SIZE 0x00100000 + +#endif /* __CONFIG_H */
- aliases {
/i2c@7000d000 is alias i2c0 on all other Tegra boards that have I2C aliases.
+config TARGET_KBB
- bool "Avionic Design Kein Baseboard"
- select CPU_V7_HAS_NONSEC if !SPL_BUILD
- select CPU_V7_HAS_VIRT if !SPL_BUILD
- help
I hope "KBB" doesn't turn out to be too generic and cause conflicts. I might suggest TARGET_AD_KBB. However, I suppose we can just rename this if it becomes a problem later, so perhaps it isn't worth fixing.
- err = as3722_gpio_configure(pmic, 1, AS3722_GPIO_OUTPUT_VDDH |
- if (err < 0) {
return err;
- err = as3722_gpio_direction_output(pmic, 2, 1);
- if (err < 0) {
return err;
Those two GPIO manipulations should likely be removed; see the recent change to similar code in jetson-tk1.c.
I'd like to see the pinmux config for this board added to https://github.com/NVIDIA/tegra-pinmux-scripts
That way, if we want to support other SW stacks and/or e.g. change the structure of these pinmux tables, we can simply re-generate this file with no issue.
Was this file auto-generated using a downstream version of tegra-pinmux-scripts? There's no comment indicating it was, and the most recent tegra-pinmux-scripts does add such a comment...
+if TARGET_KBB
It'd be nice if this directory name matched the Kconfig symbol.
That define shouldn't be necessary any more, following the conversion of Tegra to DM USB.
That define shouldn't be necessary any more, following the conversion of Tegra to DM PCI.
- aliases {
See topic mail, I think we can change that.
+config TARGET_KBB
- help
with most
I think changing to TARGET_KEIN_BASEBOARD might be the best? Matches the directory name and is unlikely to conflict with anything... Only a bit bulky.
- if (err < 0) {
return err;
- if (err < 0) {
return err;
Ack. I think this code was shamelessly stolen from jetson-tk1.c without rethinking, anyway.
In fact this pinmux is handcrafted and we do not maintain that excel sheet which tegra-pinmux-scripts uses. I'll start a discussion internally if we could provide it with reasonable effort.
+if TARGET_KBB
See above.
Ack, didn't spot that when rebasing to recent u-boot.
Ack again.
Thanks for the super fast review :) -Julian
Hi Stephen,
- aliases {
we just had a quick discussion about this and actually we explicitly changed it in our tree to a linear mapping of the controller addresses to be in sync with what we have in the l4t kernel. If it won't hurt you too much we'd like to keep it that way. Though if you feel really bad about it, we can change it to use the same mapping as Jetson uses.
-Julian
On 02/29/2016 03:20 AM, Julian Scheel wrote:
Hi Stephen,
- aliases {
That's probably fine; hopefully it won't be too confusing since aliases are supposed to be board-specific.
Let's make sure that the Linux kernel patches for this board have matching aliases and get Ack'd soon to make sure they don't diverge.
Hi Stephen,
- aliases {
I don't mind having the mapping like this for Meerkat. For anything in kernel space this should be completely irrelevant since the association is done via parent-child relationships in DT anyway.
The only place where the numbering matters is if you want to use the I2C busses from userspace (using i2c-dev) and in that case you're probably better off if you use some sort of lookup mechanism to find the correct I2C bus based on the MMIO address, instead of relying on hardcoded bus numbers.
Thierry
This doesn't appear to be quite true. It looks like the AS3722 is on the same physical bus, it's just that the I2C aliases in DT assign this bus a different number. Typically, all Tegra boards have the PMIC I2C bus as U-Boot I2C bus 0. Is there a good reason not to do that here?
You are indeed right. I was so sure about it being a different bus that I did not check it at all... In fact I don't see a real reason not do reorder the i2c to match the other platforms. But let me discuss it with Alban before changing.
Julian Scheel
Stephen Warren
Thierry Reding
