[U-Boot] [PATCH 1/2] hush: Treat trailing || and && as incomplete statements
A || or && at the end of a command should behave just like an if statment that is not complete.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com --- common/hush.c | 16 +++++++++++++--- 1 file changed, 13 insertions(+), 3 deletions(-)
diff --git a/common/hush.c b/common/hush.c index 4c84c2f..43edcfa 100644 --- a/common/hush.c +++ b/common/hush.c @@ -214,6 +214,7 @@ struct p_context { int old_flag; /* for figuring out valid reserved words */ struct p_context *stack; int type; /* define type of parser : ";$" common or special symbol */ + pipe_style last_followup; /* PIPE_BG, PIPE_SEQ, PIPE_OR, PIPE_AND */ /* How about quoting status? */ };
@@ -2534,7 +2535,7 @@ static int done_command(struct p_context *ctx) ) { #endif debug_printf("done_command: skipping null command\n"); - return 0; + return 1; } else if (prog) { pi->num_progs++; debug_printf("done_command: num_progs incremented to %d\n",pi->num_progs); @@ -2567,9 +2568,15 @@ static int done_command(struct p_context *ctx) static int done_pipe(struct p_context *ctx, pipe_style type) { struct pipe *new_p; - done_command(ctx); /* implicit closure of previous command */ + int ret; + + ret = done_command(ctx); /* implicit closure of previous command */ + /* The current command is null so don't allocate a new one */ + if (ret && type == PIPE_SEQ) + return ret; debug_printf("done_pipe, type %d\n", type); ctx->pipe->followup = type; + ctx->last_followup = type; ctx->pipe->r_mode = ctx->w; new_p=new_pipe(); ctx->pipe->next = new_p; @@ -2962,7 +2969,10 @@ int parse_stream(o_string *dest, struct p_context *ctx, if (end_trigger != '\0' && ch=='\n') done_pipe(ctx,PIPE_SEQ); } - if (ch == end_trigger && !dest->quote && ctx->w==RES_NONE) { + if (ch == end_trigger && !dest->quote && + ctx->w == RES_NONE && + ctx->last_followup != PIPE_AND && + ctx->last_followup != PIPE_OR) { debug_printf("leaving parse_stream (triggered)\n"); return 0; }
Disallow commands like "&& true" and "false && || true"
Signed-off-by: Joe Hershberger joe.hershberger@ni.com --- common/hush.c | 14 +++++++++++++- 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/common/hush.c b/common/hush.c index 43edcfa..1427557 100644 --- a/common/hush.c +++ b/common/hush.c @@ -1805,6 +1805,11 @@ static int run_list_real(struct pipe *pi) } rmode = pi->r_mode; debug_printf("rmode=%d if_code=%d next_if_code=%d skip_more=%d\n", rmode, if_code, next_if_code, skip_more_in_this_rmode); + if ((pi->followup == PIPE_OR || pi->followup == PIPE_AND) && + (pi->num_progs == 0 || pi->next->num_progs == 0)) { + puts("Pipe syntax error\n"); + return -1; + } if (rmode == skip_more_in_this_rmode && flag_skip) { if (pi->followup == PIPE_SEQ) flag_skip=0; continue; @@ -2940,6 +2945,7 @@ int parse_stream(o_string *dest, struct p_context *ctx, redir_type redir_style; #endif int next; + int ret;
/* Only double-quote state is handled in the state variable dest->quote. * A single-quote triggers a bypass of the main loop until its mate is @@ -3056,7 +3062,13 @@ int parse_stream(o_string *dest, struct p_context *ctx, #endif case ';': done_word(dest, ctx); - done_pipe(ctx,PIPE_SEQ); + ret = done_pipe(ctx, PIPE_SEQ); + if (ret && + (ctx->last_followup == PIPE_AND || + ctx->last_followup == PIPE_OR)) { + puts("Pipe syntax error\n"); + return 1; + } break; case '&': done_word(dest, ctx);
Dear Joe,
I really appreciate your patches. But after having spent some time on hush bug fixes myself (I submitted a few patches some time ago - to kill them later when I learned I was just chiseling at the top of somce iceberg) I seriously doubt if it makes senxe to try fixing the many, many bugs in the old version of hush that is included with U-Boot.
You may have a look over the fence at what Barebox fixed in this area, but the result will probably be the same.
I fear that such patches, while fixing a nasty problem here and there, will create other and maybe even more nasty problems in unexpacted areas.
My suggestion is to save such efforts, and rather spend the time on adating a more recent version of hush to U-Boot; getting things like shell functions or backtic evaluation would be more than welcome to many of us, I guess.
Hi Wolfgang,
On Thu, Nov 8, 2012 at 5:04 PM, Wolfgang Denk wd@denx.de wrote:
Dear Joe,
I'm not attempting to make it perfect. Far from it. I'm just trying to make it work for the use-cases that keep my scripts from working properly or prevent me from doing something I'm trying to do in the script..
I didn't even know that project existed. Given how early they forked, I'd be surprised if there is much to gain there, but there hasn't been much in the way of changes to hush in either u-boot or barebox. I'll glace at it and see if there's anything obviously useful.
I share your fear. I try to find the simplest and most unobtrusive ways to get the behavior I want in the hopes that these surgical changes don't have unintended effects.
I agree it would be nice to have more shell features, but I fear it's an awful lot of work. At least for now I'm just trying to get key functionality that I need, which can be fixed with minimal source changes, and that I think others will find useful.
Where is the source project that hush came from anyway? Some old busybox? Would you still recommend it over a more currently used busybox shell?
-Joe
Joe Hershberger
Joe Hershberger
