[PATCH v2] imx8mm-cl-iot-gate: Split the defconfigs
Currently imx8mm-cl-iot-gate_defconfig fails to produce a working boot binary due to the lack of fip.bin:
BINMAN all Image 'main-section' is missing external blobs and is non-functional: blob-ext
Some images are invalid
To make the build process more consistent with the other i.MX8M targets, split the defconfig in two:
- imx8mm-cl-iot-gate_defconfig: standard defconfig that only requires ATF / DDR firmware.
- imx8mm-cl-iot-gate-optee_defconfig: "more advanced" defconfig that requires ATF / Optee / mbedtls / DDR firmware.
Signed-off-by: Fabio Estevam festevam@denx.de --- Changes since v1: - Fix typo in commit log - Add an entry in MAINTAINERS
arch/arm/dts/Makefile | 2 + .../dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi | 255 ++++++++++++++++++ arch/arm/dts/imx8mm-cl-iot-gate-optee.dts | 6 + arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi | 14 +- arch/arm/mach-imx/imx8m/Kconfig | 7 + board/compulab/imx8mm-cl-iot-gate/Kconfig | 2 +- board/compulab/imx8mm-cl-iot-gate/MAINTAINERS | 1 + configs/imx8mm-cl-iot-gate-optee_defconfig | 147 ++++++++++ 8 files changed, 420 insertions(+), 14 deletions(-) create mode 100644 arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mm-cl-iot-gate-optee.dts create mode 100644 configs/imx8mm-cl-iot-gate-optee_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c42715ead4..88f52cd390 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1127,6 +1127,8 @@ dtb-$(CONFIG_TARGET_PRESIDIO_ASIC) += ca-presidio-engboard.dtb
dtb-$(CONFIG_TARGET_IMX8MM_CL_IOT_GATE) += imx8mm-cl-iot-gate.dtb
+dtb-$(CONFIG_TARGET_IMX8MM_CL_IOT_GATE_OPTEE) += imx8mm-cl-iot-gate-optee.dtb + dtb-$(CONFIG_TARGET_EA_LPC3250DEVKITV2) += lpc3250-ea3250.dtb
targets += $(dtb-y) diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi b/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi new file mode 100644 index 0000000000..3226a244a9 --- /dev/null +++ b/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi @@ -0,0 +1,255 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ + +/ { + binman: binman { + multiple-images; + }; + + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + u-boot,dm-spl; + }; + + firmware { + optee { + compatible = "linaro,optee-tz"; + method = "smc"; + }; + }; +}; + +&{/soc@0} { + u-boot,dm-pre-reloc; + u-boot,dm-spl; +}; + +&clk { + u-boot,dm-spl; + u-boot,dm-pre-reloc; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + /delete-property/ assigned-clock-rates; +}; + +&osc_24m { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&aips1 { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&aips2 { + u-boot,dm-spl; +}; + +&aips3 { + u-boot,dm-spl; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +&pinctrl_uart3 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2_gpio { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3 { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&uart3 { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; +}; + +&usdhc2 { + u-boot,dm-spl; +}; + +&usdhc3 { + u-boot,dm-spl; +}; + +&i2c1 { + u-boot,dm-spl; +}; + +&i2c2 { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a30000/pmic@4b} { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000/i2c@30a30000/pmic@4b/regulators} { + u-boot,dm-spl; +}; + +&pinctrl_i2c2 { + u-boot,dm-spl; +}; + +&pinctrl_pmic { + u-boot,dm-spl; +}; + +&fec1 { + phy-reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; +}; + +&wdog1 { + u-boot,dm-spl; +}; + +&binman { + u-boot-spl-ddr { + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>; + align-size = <4>; + align = <4>; + + u-boot-spl { + align-end = <4>; + }; + + blob_1: blob-ext@1 { + filename = "lpddr4_pmu_train_1d_imem.bin"; + size = <0x8000>; + }; + + blob_2: blob-ext@2 { + filename = "lpddr4_pmu_train_1d_dmem.bin"; + size = <0x4000>; + }; + + blob_3: blob-ext@3 { + filename = "lpddr4_pmu_train_2d_imem.bin"; + size = <0x8000>; + }; + + blob_4: blob-ext@4 { + filename = "lpddr4_pmu_train_2d_dmem.bin"; + size = <0x4000>; + }; + }; + + flash { + mkimage { + args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; + + blob { + filename = "u-boot-spl-ddr.bin"; + }; + }; + }; + + itb { + filename = "u-boot.itb"; + + fit { + description = "Configuration to load ATF before U-Boot"; + #address-cells = <1>; + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; + + images { + uboot { + description = "U-Boot (64-bit)"; + type = "standalone"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SYS_TEXT_BASE>; + + uboot_blob: blob-ext { + filename = "u-boot-nodtb.bin"; + }; + }; + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x920000>; + entry = <0x920000>; + + atf_blob: blob-ext { + filename = "bl31.bin"; + }; + }; + + fip { + description = "Trusted Firmware FIP"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x40310000>; + + fip_blob: blob-ext{ + filename = "fip.bin"; + }; + }; + + fdt { + description = "NAME"; + type = "flat_dt"; + compression = "none"; + + uboot_fdt_blob: blob-ext { + filename = "u-boot.dtb"; + }; + }; + }; + + configurations { + default = "conf"; + + conf { + description = "NAME"; + firmware = "uboot"; + loadables = "atf", "fip"; + fdt = "fdt"; + }; + }; + }; + }; +}; diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-optee.dts b/arch/arm/dts/imx8mm-cl-iot-gate-optee.dts new file mode 100644 index 0000000000..4d0ef46997 --- /dev/null +++ b/arch/arm/dts/imx8mm-cl-iot-gate-optee.dts @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2019 NXP + */ + +#include "imx8mm-cl-iot-gate.dts" diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi index 3226a244a9..00927c1574 100644 --- a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi @@ -217,18 +217,6 @@ }; };
- fip { - description = "Trusted Firmware FIP"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - load = <0x40310000>; - - fip_blob: blob-ext{ - filename = "fip.bin"; - }; - }; - fdt { description = "NAME"; type = "flat_dt"; @@ -246,7 +234,7 @@ conf { description = "NAME"; firmware = "uboot"; - loadables = "atf", "fip"; + loadables = "atf"; fdt = "fdt"; }; }; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index ccaf106be5..dfda4cb70e 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -138,6 +138,13 @@ config TARGET_IMX8MM_CL_IOT_GATE select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 + +config TARGET_IMX8MM_CL_IOT_GATE_OPTEE + bool "CompuLab iot-gate-imx8 with optee support" + select BINMAN + select IMX8MM + select SUPPORT_SPL + select IMX8M_LPDDR4 endchoice
source "board/beacon/imx8mm/Kconfig" diff --git a/board/compulab/imx8mm-cl-iot-gate/Kconfig b/board/compulab/imx8mm-cl-iot-gate/Kconfig index 7f5c794bf5..f32102f24b 100644 --- a/board/compulab/imx8mm-cl-iot-gate/Kconfig +++ b/board/compulab/imx8mm-cl-iot-gate/Kconfig @@ -1,4 +1,4 @@ -if TARGET_IMX8MM_CL_IOT_GATE +if TARGET_IMX8MM_CL_IOT_GATE || TARGET_IMX8MM_CL_IOT_GATE_OPTEE
config SYS_BOARD default "imx8mm-cl-iot-gate" diff --git a/board/compulab/imx8mm-cl-iot-gate/MAINTAINERS b/board/compulab/imx8mm-cl-iot-gate/MAINTAINERS index 9c6b17095c..9db1fb6950 100644 --- a/board/compulab/imx8mm-cl-iot-gate/MAINTAINERS +++ b/board/compulab/imx8mm-cl-iot-gate/MAINTAINERS @@ -4,3 +4,4 @@ S: Maintained F: board/compulab/imx8mm-cl-iot-gate/ F: include/configs/imx8mm-cl-iot-gate.h F: configs/imx8mm-cl-iot-gate_defconfig +F: configs/imx8mm-cl-iot-gate-optee_defconfig diff --git a/configs/imx8mm-cl-iot-gate-optee_defconfig b/configs/imx8mm-cl-iot-gate-optee_defconfig new file mode 100644 index 0000000000..d918779960 --- /dev/null +++ b/configs/imx8mm-cl-iot-gate-optee_defconfig @@ -0,0 +1,147 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x4400 +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mm-cl-iot-gate-optee" +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_IMX8MM_CL_IOT_GATE_OPTEE=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/compulab/imx8mm-cl-iot-gate/imximage-8mm-lpddr4.cfg" +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_CMD_BOOTEFI_SELFTEST=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_SHA1SUM=y +CONFIG_CMD_BIND=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_TPM=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=2 +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MM=y +CONFIG_CLK_IMX8MM=y +CONFIG_DFU_TFTP=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y +CONFIG_UDP_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x44000000 +CONFIG_FASTBOOT_BUF_SIZE=0x5000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=2 +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_DM_KEYBOARD=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_ESDHC_IMX=y +CONFIG_DM_SPI_FLASH=y +CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PCI_ENDPOINT=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_BD71837=y +CONFIG_SPL_DM_PMIC_BD71837=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_BD71837=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_RTC_ABX80X=y +CONFIG_MXC_UART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_TEE=y +CONFIG_OPTEE=y +CONFIG_DM_THERMAL=y +CONFIG_TPM2_TIS_SPI=y +CONFIG_TPM2_FTPM_TEE=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_SDP_LOADADDR=0x40400000 +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_IMX_WATCHDOG=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_TPM=y +CONFIG_LZO=y +CONFIG_BZIP2=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_EFI_SET_TIME=y +CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_CAPSULE_FIRMWARE_FIT=y +CONFIG_EFI_SECURE_BOOT=y
Hi Paul,
Changes since v1:
If you apply your series that fixes the RAM size, does this patch work for you?
Thanks,
Fabio Estevam
Hi Fabio,
Yes. This patch works for me after fixing the top address.
I have another little comment on the name of bl31.bin as following.
I think we can call it bl2.bin now because now the dts is separated. So in this defconfig we don't need to take care the name compatibility of the non-optee defconfig.
And I'll write a document after your commits gets in to describe the detailed build steps. With Tom's corrections.
Yours, Paul
On Tue, 24 Aug 2021 at 06:06, Fabio Estevam festevam@gmail.com wrote:
Hi Paul,
blob-ext
Changes since v1:
Thanks,
Fabio Estevam
Fabio Estevam
Fabio Estevam
Paul Liu
