[PATCH] ARM: layerscape: Use ARCH_LS104?A insead of TARGET_LS104?ARDB
These frequency calculations depend on the RCW format, which is not dependent on any particular board. Switch to using ARCH symbols instead of TARGET.
This whole function could probably use less ifdefs, but for now just do a minimal conversion.
Fixes: 24cb6f2295 ("fsl-layerscape: Add fsl_esdhc peripheral clock support") Signed-off-by: Sean Anderson sean.anderson@seco.com ---
arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index 570105a75e..840e6d412b 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -29,8 +29,8 @@ void get_sys_info(struct sys_info *sys_info) * mux 2 clock for LS1043A/LS1046A. */ #if defined(CONFIG_SYS_DPAA_FMAN) || \ - defined(CONFIG_TARGET_LS1046ARDB) || \ - defined(CONFIG_TARGET_LS1043ARDB) + defined(CONFIG_ARCH_LS1046A) || \ + defined(CONFIG_ARCH_LS1043A) u32 rcw_tmp; #endif struct ccsr_clk *clk = (void *)(CONFIG_SYS_FSL_CLK_ADDR); @@ -129,13 +129,13 @@ void get_sys_info(struct sys_info *sys_info)
#define HWA_CGA_M2_CLK_SEL 0x00000007 #define HWA_CGA_M2_CLK_SHIFT 0 -#if defined(CONFIG_TARGET_LS1046ARDB) || defined(CONFIG_TARGET_LS1043ARDB) +#if defined(CONFIG_ARCH_LS1046A) || defined(CONFIG_ARCH_LS1043A) rcw_tmp = in_be32(&gur->rcwsr[15]); switch ((rcw_tmp & HWA_CGA_M2_CLK_SEL) >> HWA_CGA_M2_CLK_SHIFT) { case 1: sys_info->freq_cga_m2 = freq_c_pll[1]; break; -#if defined(CONFIG_TARGET_LS1046ARDB) +#if defined(CONFIG_ARCH_LS1046A) case 2: sys_info->freq_cga_m2 = freq_c_pll[1] / 2; break; @@ -143,7 +143,7 @@ void get_sys_info(struct sys_info *sys_info) case 3: sys_info->freq_cga_m2 = freq_c_pll[1] / 3; break; -#if defined(CONFIG_TARGET_LS1046ARDB) +#if defined(CONFIG_ARCH_LS1046A) case 6: sys_info->freq_cga_m2 = freq_c_pll[0] / 2; break;
- mux 2 clock for LS1043A/LS1046A.
u32 rcw_tmp;defined(CONFIG_ARCH_LS1043A)
ping?
ping?
Looks like this was already applied as bcb3dae3251 ("ARM: layerscape: Use ARCH_LS104?A insead of TARGET_LS104?ARDB").
--Sean
Sean Anderson
