Is existing a way to globally disable some features such as ethernet or Nand support, instead of doing it for a specific board?
More over, I can't disable ethernet on the at91sam9261ek board by simply disable the #define CONFIG_DRIVER_DM9000 in the 'config/at91sam9261ek.h' file so it cause building errors.
Thanks for your support,
best regards,
Simon P.
Dear simon polette,
In message 72795ccb0904290301h1678e99br6fe3cfb0b4226d66@mail.gmail.com you wrote:
No, you cannot do this globally. Board configuration is always board specific.
That's to be expected. When you just disable the network driver with- out disabling support foir the network commands, the linker will run into unresolved external references to the network driver functions. You must also disable network commands support.
simon polette
