[U-Boot] [PATCH 2/2] Update Kilauea board support to use PPC4xx DDR autocalibration routines.
Signed-off-by: Adam Graham agraham@amcc.com --- cpu/ppc4xx/44x_spd_ddr2.c | 158 ++++++++++++++++++++++++---------------- cpu/ppc4xx/Makefile | 3 + include/asm-ppc/ppc4xx-sdram.h | 3 +- include/common.h | 21 +++++ include/configs/kilauea.h | 19 +++++ include/ppc440.h | 13 --- include/ppc4xx.h | 13 +++ 7 files changed, 153 insertions(+), 77 deletions(-)
diff --git a/cpu/ppc4xx/44x_spd_ddr2.c b/cpu/ppc4xx/44x_spd_ddr2.c index 15250d4..f1d7684 100644 --- a/cpu/ppc4xx/44x_spd_ddr2.c +++ b/cpu/ppc4xx/44x_spd_ddr2.c @@ -60,8 +60,6 @@ "SDRAM_" #mnemonic, SDRAM_##mnemonic, data); \ } while (0)
-static inline void ppc4xx_ibm_ddr2_register_dump(void); - #if defined(CONFIG_SPD_EEPROM)
/*-----------------------------------------------------------------------------+ @@ -260,62 +258,19 @@ static void program_ecc_addr(unsigned long start_address, unsigned long num_bytes, unsigned long tlb_word2_i_value); #endif +#if !defined(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) static void program_DQS_calibration(unsigned long *dimm_populated, - unsigned char *iic0_dimm_addr, - unsigned long num_dimm_banks); + unsigned char *iic0_dimm_addr, + unsigned long num_dimm_banks); #ifdef HARD_CODED_DQS /* calibration test with hardvalues */ static void test(void); #else static void DQS_calibration_process(void); #endif +#endif int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); void dcbz_area(u32 start_address, u32 num_bytes);
-static u32 mfdcr_any(u32 dcr) -{ - u32 val; - - switch (dcr) { - case SDRAM_R0BAS + 0: - val = mfdcr(SDRAM_R0BAS + 0); - break; - case SDRAM_R0BAS + 1: - val = mfdcr(SDRAM_R0BAS + 1); - break; - case SDRAM_R0BAS + 2: - val = mfdcr(SDRAM_R0BAS + 2); - break; - case SDRAM_R0BAS + 3: - val = mfdcr(SDRAM_R0BAS + 3); - break; - default: - printf("DCR %d not defined in case statement!!!\n", dcr); - val = 0; /* just to satisfy the compiler */ - } - - return val; -} - -static void mtdcr_any(u32 dcr, u32 val) -{ - switch (dcr) { - case SDRAM_R0BAS + 0: - mtdcr(SDRAM_R0BAS + 0, val); - break; - case SDRAM_R0BAS + 1: - mtdcr(SDRAM_R0BAS + 1, val); - break; - case SDRAM_R0BAS + 2: - mtdcr(SDRAM_R0BAS + 2, val); - break; - case SDRAM_R0BAS + 3: - mtdcr(SDRAM_R0BAS + 3, val); - break; - default: - printf("DCR %d not defined in case statement!!!\n", dcr); - } -} - static unsigned char spd_read(uchar chip, uint addr) { unsigned char data[2]; @@ -609,7 +564,11 @@ phys_size_t initdram(int board_type) /*------------------------------------------------------------------ * DQS calibration. *-----------------------------------------------------------------*/ +#if defined(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) + DQS_autocalibration(); +#else program_DQS_calibration(dimm_populated, iic0_dimm_addr, num_dimm_banks); +#endif
#ifdef CONFIG_DDR_ECC /*------------------------------------------------------------------ @@ -2329,18 +2288,6 @@ static unsigned long is_ecc_enabled(void) return ecc; }
-static void blank_string(int size) -{ - int i; - - for (i=0; i<size; i++) - putc('\b'); - for (i=0; i<size; i++) - putc(' '); - for (i=0; i<size; i++) - putc('\b'); -} - #ifdef CONFIG_DDR_ECC /*-----------------------------------------------------------------------------+ * program_ecc. @@ -2468,6 +2415,7 @@ static void program_ecc_addr(unsigned long start_address, } #endif
+#if !defined(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) /*-----------------------------------------------------------------------------+ * program_DQS_calibration. *-----------------------------------------------------------------------------*/ @@ -3001,7 +2949,8 @@ static void test(void) (ppcMfdcr_sdram(SDRAM_MCOPT1) & ~SDRAM_MCOPT1_MCHK_MASK) | ecc_temp); } -#endif +#endif /* !HARD_CODED_DQS */ +#endif /* !defined(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) */
#else /* CONFIG_SPD_EEPROM */
@@ -3104,9 +3053,12 @@ phys_size_t initdram(int board_type) /* Set Delay Control Registers */
mtsdram(SDRAM_DLCR, CFG_SDRAM0_DLCR); + +#if !defined(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) mtsdram(SDRAM_RDCC, CFG_SDRAM0_RDCC); mtsdram(SDRAM_RQDC, CFG_SDRAM0_RQDC); mtsdram(SDRAM_RFDC, CFG_SDRAM0_RFDC); +#endif /* !CONFIG_PPC4xx_DDR_AUTOCALIBRATION */
/* * Enable Controller by SDRAM0_MCOPT2[DCEN] = 1: @@ -3115,18 +3067,98 @@ phys_size_t initdram(int board_type) mfsdram(SDRAM_MCOPT2, val); mtsdram(SDRAM_MCOPT2, val | SDRAM_MCOPT2_DCEN_ENABLE);
+#if defined(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) +#if !defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) + /*------------------------------------------------------------------ + | DQS calibration. + +-----------------------------------------------------------------*/ + DQS_autocalibration(); +#endif /* !defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) */ +#endif /* CONFIG_PPC4xx_DDR_AUTOCALIBRATION */ + #if defined(CONFIG_DDR_ECC) ecc_init(CFG_SDRAM_BASE, CFG_MBYTES_SDRAM << 20); #endif /* defined(CONFIG_DDR_ECC) */
ppc4xx_ibm_ddr2_register_dump(); + +#if defined(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) + /* + * Clear potential errors resulting from auto-calibration. + * If not done, then we could get an interrupt later on when + * exceptions are enabled. + */ + set_mcsr(get_mcsr()); +#endif /* CONFIG_PPC4xx_DDR_AUTOCALIBRATION */ + #endif /* !defined(CONFIG_NAND_U_BOOT) || defined(CONFIG_NAND_SPL) */
return (CFG_MBYTES_SDRAM << 20); } #endif /* CONFIG_SPD_EEPROM */
-static inline void ppc4xx_ibm_ddr2_register_dump(void) +#if !defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) +#if defined(CONFIG_440) +u32 mfdcr_any(u32 dcr) +{ + u32 val; + + switch (dcr) { + case SDRAM_R0BAS + 0: + val = mfdcr(SDRAM_R0BAS + 0); + break; + case SDRAM_R0BAS + 1: + val = mfdcr(SDRAM_R0BAS + 1); + break; + case SDRAM_R0BAS + 2: + val = mfdcr(SDRAM_R0BAS + 2); + break; + case SDRAM_R0BAS + 3: + val = mfdcr(SDRAM_R0BAS + 3); + break; + default: + printf("DCR %d not defined in case statement!!!\n", dcr); + val = 0; /* just to satisfy the compiler */ + } + + return val; +} + +void mtdcr_any(u32 dcr, u32 val) +{ + switch (dcr) { + case SDRAM_R0BAS + 0: + mtdcr(SDRAM_R0BAS + 0, val); + break; + case SDRAM_R0BAS + 1: + mtdcr(SDRAM_R0BAS + 1, val); + break; + case SDRAM_R0BAS + 2: + mtdcr(SDRAM_R0BAS + 2, val); + break; + case SDRAM_R0BAS + 3: + mtdcr(SDRAM_R0BAS + 3, val); + break; + default: + printf("DCR %d not defined in case statement!!!\n", dcr); + } +} +#endif /* defined(CONFIG_440) */ + +void blank_string(int size) +{ + int i; + + for (i = 0; i < size; i++) + putc('\b'); + for (i = 0; i < size; i++) + putc(' '); + for (i = 0; i < size; i++) + putc('\b'); +} +#endif /* !defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) */ + +inline void ppc4xx_ibm_ddr2_register_dump(void) { #if defined(DEBUG) printf("\nPPC4xx IBM DDR2 Register Dump:\n"); diff --git a/cpu/ppc4xx/Makefile b/cpu/ppc4xx/Makefile index c773400..75f3e49 100644 --- a/cpu/ppc4xx/Makefile +++ b/cpu/ppc4xx/Makefile @@ -35,6 +35,9 @@ SOBJS += kgdb.o COBJS := 40x_spd_sdram.o COBJS += 44x_spd_ddr.o COBJS += 44x_spd_ddr2.o +ifdef CONFIG_PPC4xx_DDR_AUTOCALIBRATION +COBJS += 4xx_ibm_ddr2_autocalib.o +endif COBJS += 4xx_pci.o COBJS += 4xx_pcie.o COBJS += bedbug_405.o diff --git a/include/asm-ppc/ppc4xx-sdram.h b/include/asm-ppc/ppc4xx-sdram.h index 0174d62..a1ef029 100644 --- a/include/asm-ppc/ppc4xx-sdram.h +++ b/include/asm-ppc/ppc4xx-sdram.h @@ -29,6 +29,7 @@ /* * SDRAM Controller */ + /* * XXX - ToDo: Revisit file to change all these lower case defines into * upper case. Also needs to be done in the controller setup code too @@ -256,6 +257,7 @@ #define SDRAM_DLYCAL_DLCV_ENCODE(x) (((x)<<2) & SDRAM_DLYCAL_DLCV_MASK) #define SDRAM_DLYCAL_DLCV_DECODE(x) (((x) & SDRAM_DLYCAL_DLCV_MASK)>>2)
+#if !defined(CONFIG_405EX) /* * Memory queue defines */ @@ -293,7 +295,6 @@
#define SDRAM_PLBADDUHB (SDRAMQ_DCR_BASE+0x10) /* PLB base address upper 32 LL */
-#if !defined(CONFIG_405EX) /* * Memory Bank 0-7 configuration */ diff --git a/include/common.h b/include/common.h index a394988..2516bfd 100644 --- a/include/common.h +++ b/include/common.h @@ -287,6 +287,27 @@ void pciinfo (int, int); #endif #endif
+/* + * Prototypes + */ +#if defined(CONFIG_SDRAM_PPC4xx_IBM_DDR2) +void blank_string(int); +inline void ppc4xx_ibm_ddr2_register_dump(void); +#if defined(CONFIG_440) +u32 mfdcr_any(u32); +void mtdcr_any(u32, u32); +#endif +#if defined(CONFIG_SPD_EEPROM) +u32 ddr_wrdtr(u32); +u32 ddr_clktr(u32); +void spd_ddr_init_hang(void); +#endif +#endif /* defined(CONFIG_SDRAM_PPC4xx_IBM_DDR2) */ + +#if defined(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) +u32 DQS_autocalibration(void); +#endif /* CONFIG_PPC4xx_DDR_AUTOCALIBRATION */ + int misc_init_f (void); int misc_init_r (void);
diff --git a/include/configs/kilauea.h b/include/configs/kilauea.h index a475f97..f9eaa77 100644 --- a/include/configs/kilauea.h +++ b/include/configs/kilauea.h @@ -223,6 +223,22 @@ *----------------------------------------------------------------------*/ #define CFG_MBYTES_SDRAM (256) /* 256MB */
+/* + * CONFIG_PPC4xx_DDR_AUTOCALIBRATION + * + * Note: DDR Autocalibration Method_A scans the full range of possible PPC4xx + * SDRAM Controller DDR autocalibration values and takes a lot longer + * to run than Method_B. + * (See the Method_A and Method_B algorithm discription in the file: + * cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c) + * Define CONFIG_PPC4xx_DDR_METHOD_A to use DDR autocalibration Method_A + * + * DDR Autocalibration Method_B is the default. + */ +#define CONFIG_PPC4xx_DDR_AUTOCALIBRATION /* IBM DDR autocalibration */ +#define DEBUG_PPC4xx_DDR_AUTOCALIBRATION /* dynamic DDR autocal debug */ +#undef CONFIG_PPC4xx_DDR_METHOD_A + #define CFG_SDRAM0_MB0CF_BASE (( 0 << 20) + CFG_SDRAM_BASE)
/* DDR1/2 SDRAM Device Control Register Data Values */ @@ -386,6 +402,9 @@ #define CONFIG_HAS_ETH1 1 /* add support for "eth1addr" */ #define CONFIG_PHY1_ADDR 2
+/* Debug messages for the DDR autocalibration */ +#define CONFIG_AUTOCALIB "silent\0" /* default is non-verbose */ + /* * Default environment variables */ diff --git a/include/ppc440.h b/include/ppc440.h index 3584fd2..be8d3ff 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -2064,19 +2064,6 @@
#ifndef __ASSEMBLY__
-static inline u32 get_mcsr(void) -{ - u32 val; - - asm volatile("mfspr %0, 0x23c" : "=r" (val) :); - return val; -} - -static inline void set_mcsr(u32 val) -{ - asm volatile("mtspr 0x23c, %0" : "=r" (val) :); -} - #endif /* _ASMLANGUAGE */
#endif /* __PPC440_H__ */ diff --git a/include/ppc4xx.h b/include/ppc4xx.h index 59a3b06..e216663 100644 --- a/include/ppc4xx.h +++ b/include/ppc4xx.h @@ -203,6 +203,19 @@ typedef struct unsigned long pllPlbDiv; } PPC4xx_SYS_INFO;
+static inline u32 get_mcsr(void) +{ + u32 val; + + asm volatile("mfspr %0, 0x23c" : "=r" (val) :); + return val; +} + +static inline void set_mcsr(u32 val) +{ + asm volatile("mtspr 0x23c, %0" : "=r" (val) :); +} + #endif /* __ASSEMBLY__ */
#endif /* __PPC4XX_H__ */
Applied to u-boot-ppc4xx repository. Thanks.
Best regards, Stefan
Adam Graham
Stefan Roese
