[PATCH 1/4] arm: mvebu: Fix compatible string for nand controller
Linux kernel uses compatible string "marvell,armada370-nand-controller" for nand controllers on Armada 370/XP/38x. U-Boot currently uses mix of "marvell,armada370-nand" and "marvell,mvebu-pxa3xx-nand".
So unify it and use just Linux kernel compatible string.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/dts/armada-370-xp.dtsi | 2 +- arch/arm/dts/armada-375.dtsi | 2 +- arch/arm/dts/armada-38x.dtsi | 2 +- arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi | 2 +- drivers/mtd/nand/raw/pxa3xx_nand.c | 2 +- 5 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/arm/dts/armada-370-xp.dtsi b/arch/arm/dts/armada-370-xp.dtsi index 50fc0be9f73b..4cd168c95784 100644 --- a/arch/arm/dts/armada-370-xp.dtsi +++ b/arch/arm/dts/armada-370-xp.dtsi @@ -246,7 +246,7 @@ };
nand@d0000 { - compatible = "marvell,armada370-nand"; + compatible = "marvell,armada370-nand-controller"; reg = <0xd0000 0x54>; #address-cells = <1>; #size-cells = <1>; diff --git a/arch/arm/dts/armada-375.dtsi b/arch/arm/dts/armada-375.dtsi index ff0ad7a9c7fd..fcb9245fd496 100644 --- a/arch/arm/dts/armada-375.dtsi +++ b/arch/arm/dts/armada-375.dtsi @@ -541,7 +541,7 @@ };
nand@d0000 { - compatible = "marvell,armada370-nand"; + compatible = "marvell,armada370-nand-controller"; reg = <0xd0000 0x54>; #address-cells = <1>; #size-cells = <1>; diff --git a/arch/arm/dts/armada-38x.dtsi b/arch/arm/dts/armada-38x.dtsi index 061bd7852081..6979c0c50584 100644 --- a/arch/arm/dts/armada-38x.dtsi +++ b/arch/arm/dts/armada-38x.dtsi @@ -555,7 +555,7 @@ };
nand_controller: nand-controller@d0000 { - compatible = "marvell,armada370-nand","marvell,mvebu-pxa3xx-nand"; + compatible = "marvell,armada370-nand-controller"; reg = <0xd0000 0x54>; #address-cells = <1>; #size-cells = <0>; diff --git a/arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi b/arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi index 90cad85506d0..fdbe168a8734 100644 --- a/arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi +++ b/arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi @@ -5,7 +5,7 @@ };
&nand_controller { - compatible="marvell,mvebu-pxa3xx-nand"; + compatible="marvell,armada370-nand-controller"; status = "okay"; label = "pxa3xx_nand-0"; nand-rb = <0>; diff --git a/drivers/mtd/nand/raw/pxa3xx_nand.c b/drivers/mtd/nand/raw/pxa3xx_nand.c index 20d1aee7b3e1..9c29e8a6c214 100644 --- a/drivers/mtd/nand/raw/pxa3xx_nand.c +++ b/drivers/mtd/nand/raw/pxa3xx_nand.c @@ -429,7 +429,7 @@ static struct nand_ecclayout ecc_layout_8KB_bch8bit = {
static const struct udevice_id pxa3xx_nand_dt_ids[] = { { - .compatible = "marvell,mvebu-pxa3xx-nand", + .compatible = "marvell,armada370-nand-controller", .data = PXA3XX_NAND_VARIANT_ARMADA370, }, {
* Replace skeleton.dtsi by explicit #address-cells / #size-cells * Add sdramc@1400 and phy@18300 nodes * Remove (unused) timeout-ms i2c properties * Fix compatible string for UARTs * Add interrupts properties for watchdog
Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/dts/armada-38x.dtsi | 55 ++++++++++++++++++++++++++++++++---- 1 file changed, 50 insertions(+), 5 deletions(-)
diff --git a/arch/arm/dts/armada-38x.dtsi b/arch/arm/dts/armada-38x.dtsi index 6979c0c50584..7731a205698e 100644 --- a/arch/arm/dts/armada-38x.dtsi +++ b/arch/arm/dts/armada-38x.dtsi @@ -9,13 +9,15 @@ * Thomas Petazzoni thomas.petazzoni@free-electrons.com */
-#include "skeleton.dtsi" #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/interrupt-controller/irq.h>
#define MBUS_ID(target,attributes) (((target) << 24) | ((attributes) << 16))
/ { + #address-cells = <1>; + #size-cells = <1>; + model = "Marvell Armada 38x family SoC"; compatible = "marvell,armada380";
@@ -103,6 +105,11 @@ #size-cells = <1>; ranges = <0 MBUS_ID(0xf0, 0x01) 0 0x100000>;
+ sdramc: sdramc@1400 { + compatible = "marvell,armada-xp-sdram-controller"; + reg = <0x1400 0x500>; + }; + L2: cache-controller@8000 { compatible = "arm,pl310-cache"; reg = <0x8000 0x1000>; @@ -148,7 +155,6 @@ #address-cells = <1>; #size-cells = <0>; interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; - timeout-ms = <1000>; clocks = <&coreclk 0>; status = "disabled"; }; @@ -159,13 +165,12 @@ #address-cells = <1>; #size-cells = <0>; interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; - timeout-ms = <1000>; clocks = <&coreclk 0>; status = "disabled"; };
uart0: serial@12000 { - compatible = "snps,dw-apb-uart"; + compatible = "marvell,armada-38x-uart", "ns16550a"; reg = <0x12000 0x100>; reg-shift = <2>; interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; @@ -175,7 +180,7 @@ };
uart1: serial@12100 { - compatible = "snps,dw-apb-uart"; + compatible = "marvell,armada-38x-uart", "ns16550a"; reg = <0x12100 0x100>; reg-shift = <2>; interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; @@ -338,6 +343,44 @@ #clock-cells = <1>; };
+ comphy: phy@18300 { + compatible = "marvell,armada-380-comphy"; + reg-names = "comphy", "conf"; + reg = <0x18300 0x100>, <0x18460 4>; + #address-cells = <1>; + #size-cells = <0>; + + comphy0: phy@0 { + reg = <0>; + #phy-cells = <1>; + }; + + comphy1: phy@1 { + reg = <1>; + #phy-cells = <1>; + }; + + comphy2: phy@2 { + reg = <2>; + #phy-cells = <1>; + }; + + comphy3: phy@3 { + reg = <3>; + #phy-cells = <1>; + }; + + comphy4: phy@4 { + reg = <4>; + #phy-cells = <1>; + }; + + comphy5: phy@5 { + reg = <5>; + #phy-cells = <1>; + }; + }; + coreclk: mvebu-sar@18600 { compatible = "marvell,armada-380-core-clock"; reg = <0x18600 0x04>; @@ -379,6 +422,8 @@ reg = <0x20300 0x34>, <0x20704 0x4>, <0x18260 0x4>; clocks = <&coreclk 2>, <&refclk>; clock-names = "nbclk", "fixed"; + interrupts-extended = <&gic GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>, + <&gic GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; };
cpurst: cpurst@20800 {
On 27.07.22 14:47, Pali Rohár wrote:
- Replace skeleton.dtsi by explicit #address-cells / #size-cells
- Add sdramc@1400 and phy@18300 nodes
- Remove (unused) timeout-ms i2c properties
- Fix compatible string for UARTs
- Add interrupts properties for watchdog
Thanks, Stefan
- Thomas Petazzoni thomas.petazzoni@free-electrons.com
- #address-cells = <1>;
- #size-cells = <1>;
- model = "Marvell Armada 38x family SoC"; compatible = "marvell,armada380";
timeout-ms = <1000>; clocks = <&coreclk 0>; status = "disabled"; }; uart0: serial@12000 {
comphy: phy@18300 {
#size-cells = <0>;
comphy0: phy@0 {
reg = <0>;
#phy-cells = <1>;
comphy1: phy@1 {
reg = <1>;
#phy-cells = <1>;
comphy2: phy@2 {
reg = <2>;
#phy-cells = <1>;
comphy3: phy@3 {
reg = <3>;
#phy-cells = <1>;
comphy4: phy@4 {
reg = <4>;
#phy-cells = <1>;
comphy5: phy@5 {
reg = <5>;
#phy-cells = <1>;
<&gic GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; }; cpurst: cpurst@20800 {
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
comphy: phy@18300 {
#size-cells = <0>;
comphy0: phy@0 {
reg = <0>;
#phy-cells = <1>;
comphy1: phy@1 {
reg = <1>;
#phy-cells = <1>;
comphy2: phy@2 {
reg = <2>;
#phy-cells = <1>;
comphy3: phy@3 {
reg = <3>;
#phy-cells = <1>;
comphy4: phy@4 {
reg = <4>;
#phy-cells = <1>;
comphy5: phy@5 {
reg = <5>;
#phy-cells = <1>;
* Define PCIe interrupts
Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/dts/armada-385.dtsi | 52 ++++++++++++++++++++++++++++++------ 1 file changed, 44 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/armada-385.dtsi b/arch/arm/dts/armada-385.dtsi index 581a7d9beac3..48072fc7fd4a 100644 --- a/arch/arm/dts/armada-385.dtsi +++ b/arch/arm/dts/armada-385.dtsi @@ -69,17 +69,26 @@ reg = <0x0800 0 0 0 0>; #address-cells = <3>; #size-cells = <2>; + interrupt-names = "intx"; + interrupts-extended = <&gic GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; #interrupt-cells = <1>; ranges = <0x82000000 0 0 0x82000000 0x1 0 1 0 0x81000000 0 0 0x81000000 0x1 0 1 0>; bus-range = <0x00 0xff>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie1_intc 0>, + <0 0 0 2 &pcie1_intc 1>, + <0 0 0 3 &pcie1_intc 2>, + <0 0 0 4 &pcie1_intc 3>; marvell,pcie-port = <0>; marvell,pcie-lane = <0>; clocks = <&gateclk 8>; resets = <&systemc 0 0>; status = "disabled"; + pcie1_intc: interrupt-controller { + interrupt-controller; + #interrupt-cells = <1>; + }; };
/* x1 port */ @@ -89,17 +98,26 @@ reg = <0x1000 0 0 0 0>; #address-cells = <3>; #size-cells = <2>; + interrupt-names = "intx"; + interrupts-extended = <&gic GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; #interrupt-cells = <1>; ranges = <0x82000000 0 0 0x82000000 0x2 0 1 0 0x81000000 0 0 0x81000000 0x2 0 1 0>; bus-range = <0x00 0xff>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie2_intc 0>, + <0 0 0 2 &pcie2_intc 1>, + <0 0 0 3 &pcie2_intc 2>, + <0 0 0 4 &pcie2_intc 3>; marvell,pcie-port = <1>; marvell,pcie-lane = <0>; clocks = <&gateclk 5>; resets = <&systemc 0 1>; status = "disabled"; + pcie2_intc: interrupt-controller { + interrupt-controller; + #interrupt-cells = <1>; + }; };
/* x1 port */ @@ -109,17 +127,26 @@ reg = <0x1800 0 0 0 0>; #address-cells = <3>; #size-cells = <2>; + interrupt-names = "intx"; + interrupts-extended = <&gic GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; #interrupt-cells = <1>; ranges = <0x82000000 0 0 0x82000000 0x3 0 1 0 0x81000000 0 0 0x81000000 0x3 0 1 0>; bus-range = <0x00 0xff>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie3_intc 0>, + <0 0 0 2 &pcie3_intc 1>, + <0 0 0 3 &pcie3_intc 2>, + <0 0 0 4 &pcie3_intc 3>; marvell,pcie-port = <2>; marvell,pcie-lane = <0>; clocks = <&gateclk 6>; resets = <&systemc 0 2>; status = "disabled"; + pcie3_intc: interrupt-controller { + interrupt-controller; + #interrupt-cells = <1>; + }; };
/* @@ -132,17 +159,26 @@ reg = <0x2000 0 0 0 0>; #address-cells = <3>; #size-cells = <2>; + interrupt-names = "intx"; + interrupts-extended = <&gic GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; #interrupt-cells = <1>; ranges = <0x82000000 0 0 0x82000000 0x4 0 1 0 0x81000000 0 0 0x81000000 0x4 0 1 0>; bus-range = <0x00 0xff>; - interrupt-map-mask = <0 0 0 0>; - interrupt-map = <0 0 0 0 &gic GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie4_intc 0>, + <0 0 0 2 &pcie4_intc 1>, + <0 0 0 3 &pcie4_intc 2>, + <0 0 0 4 &pcie4_intc 3>; marvell,pcie-port = <3>; marvell,pcie-lane = <0>; clocks = <&gateclk 7>; resets = <&systemc 0 3>; status = "disabled"; + pcie4_intc: interrupt-controller { + interrupt-controller; + #interrupt-cells = <1>; + }; }; }; };
- Define PCIe interrupts
Thanks, Stefan
}; }; /* x1 port */
}; }; /* x1 port */
Thanks, Stefan
}; }; /* x1 port */
}; }; /* x1 port */
* Add SPDX-License-Identifier * Add SFP and LED nodes * Fix PHY nad NOR nodes * Remove duplicates from u-boot.dtsi file
Signed-off-by: Pali Rohár pali@kernel.org --- .../dts/armada-385-turris-omnia-u-boot.dtsi | 5 +- arch/arm/dts/armada-385-turris-omnia.dts | 228 ++++++++++++++---- 2 files changed, 183 insertions(+), 50 deletions(-)
diff --git a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi index 5a22cc64a1a5..ec12298fd40c 100644 --- a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi +++ b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi @@ -28,11 +28,8 @@ i2c@5 { u-boot,dm-pre-reloc;
- /* ATSHA204A at address 0x64 */ crypto@64 { u-boot,dm-pre-reloc; - compatible = "atmel,atsha204a"; - reg = <0x64>; }; }; }; @@ -42,7 +39,7 @@ &spi0 { u-boot,dm-pre-reloc;
- spi-nor@0 { + flash@0 { u-boot,dm-pre-reloc;
partitions { diff --git a/arch/arm/dts/armada-385-turris-omnia.dts b/arch/arm/dts/armada-385-turris-omnia.dts index fe5c0b1b5915..e213c64dca4f 100644 --- a/arch/arm/dts/armada-385-turris-omnia.dts +++ b/arch/arm/dts/armada-385-turris-omnia.dts @@ -1,43 +1,10 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) /* * Device Tree file for the Turris Omnia * * Copyright (C) 2016 Uwe Kleine-König uwe@kleine-koenig.org * Copyright (C) 2016 Tomas Hlavacek tmshlvkc@gmail.com * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is licensed under the terms of the GNU General Public - * License version 2. This program is licensed "as is" without - * any warranty of any kind, whether express or implied. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -/* * Schematic available at https://www.turris.cz/doc/_media/rtrom01-schema.pdf */
@@ -45,6 +12,7 @@
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> #include "armada-385.dtsi"
/ { @@ -70,7 +38,8 @@ ranges = <MBUS_ID(0xf0, 0x01) 0 0xf1000000 0x100000 MBUS_ID(0x01, 0x1d) 0 0xfff00000 0x100000 MBUS_ID(0x09, 0x19) 0 0xf1100000 0x10000 - MBUS_ID(0x09, 0x15) 0 0xf1110000 0x10000>; + MBUS_ID(0x09, 0x15) 0 0xf1110000 0x10000 + MBUS_ID(0x0c, 0x04) 0 0xf1200000 0x100000>;
internal-regs {
@@ -108,19 +77,48 @@ pcie@1,0 { /* Port 0, Lane 0 */ status = "okay"; + slot-power-limit-milliwatt = <10000>; };
pcie@2,0 { /* Port 1, Lane 0 */ status = "okay"; + slot-power-limit-milliwatt = <10000>; };
pcie@3,0 { /* Port 2, Lane 0 */ status = "okay"; + slot-power-limit-milliwatt = <10000>; }; }; }; + + sfp: sfp { + compatible = "sff,sfp"; + i2c-bus = <&sfp_i2c>; + tx-fault-gpios = <&pcawan 0 GPIO_ACTIVE_HIGH>; + tx-disable-gpios = <&pcawan 1 GPIO_ACTIVE_HIGH>; + rate-select0-gpios = <&pcawan 2 GPIO_ACTIVE_HIGH>; + los-gpios = <&pcawan 3 GPIO_ACTIVE_HIGH>; + mod-def0-gpios = <&pcawan 4 GPIO_ACTIVE_LOW>; + maximum-power-milliwatt = <3000>; + + /* + * For now this has to be enabled at boot time by U-Boot when + * a SFP module is present. Read more in the comment in the + * eth2 node below. + */ + status = "disabled"; + }; +}; + +&bm { + status = "okay"; +}; + +&bm_bppi { + status = "okay"; };
/* Connected to 88E6176 switch, port 6 */ @@ -129,6 +127,9 @@ pinctrl-0 = <&ge0_rgmii_pins>; status = "okay"; phy-mode = "rgmii"; + buffer-manager = <&bm>; + bm,pool-long = <0>; + bm,pool-short = <3>;
fixed-link { speed = <1000>; @@ -142,6 +143,9 @@ pinctrl-0 = <&ge1_rgmii_pins>; status = "okay"; phy-mode = "rgmii"; + buffer-manager = <&bm>; + bm,pool-long = <1>; + bm,pool-short = <3>;
fixed-link { speed = <1000>; @@ -151,9 +155,23 @@
/* WAN port */ ð2 { + /* + * eth2 is connected via a multiplexor to both the SFP cage and to + * ethernet-phy@1. The multiplexor switches the signal to SFP cage when + * a SFP module is present, as determined by the mode-def0 GPIO. + * + * Until kernel supports this configuration properly, in case SFP module + * is present, U-Boot has to enable the sfp node above, remove phy + * handle and add managed = "in-band-status" property. + */ status = "okay"; phy-mode = "sgmii"; - phy = <&phy1>; + phy-handle = <&phy1>; + phys = <&comphy5 2>; + sfp = <&sfp>; + buffer-manager = <&bm>; + bm,pool-long = <2>; + bm,pool-short = <3>; };
&i2c0 { @@ -166,7 +184,6 @@ #address-cells = <1>; #size-cells = <0>; reg = <0x70>; - status = "okay";
i2c@0 { #address-cells = <1>; @@ -180,10 +197,114 @@ gpio-controller; };
- /* leds device (in STM32F0) at address 0x2b */ + led-controller@2b { + compatible = "cznic,turris-omnia-leds"; + reg = <0x2b>; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + /* + * LEDs are controlled by MCU (STM32F0) at + * address 0x2b. + * + * LED functions are not stable yet: + * - there are 3 LEDs connected via MCU to PCIe + * ports. One of these ports supports mSATA. + * There is no mSATA nor PCIe function. + * For now we use LED_FUNCTION_WLAN, since + * in most cases users have wifi cards in + * these slots + * - there are 2 LEDs dedicated for user: A and + * B. Again there is no such function defined. + * For now we use LED_FUNCTION_INDICATOR + */ + + multi-led@0 { + reg = <0x0>; + color = <LED_COLOR_ID_RGB>; + function = LED_FUNCTION_INDICATOR; + function-enumerator = <2>; + }; + + multi-led@1 { + reg = <0x1>; + color = <LED_COLOR_ID_RGB>; + function = LED_FUNCTION_INDICATOR; + function-enumerator = <1>; + }; + + multi-led@2 { + reg = <0x2>; + color = <LED_COLOR_ID_RGB>; + function = LED_FUNCTION_WLAN; + function-enumerator = <3>; + }; + + multi-led@3 { + reg = <0x3>; + color = <LED_COLOR_ID_RGB>; + function = LED_FUNCTION_WLAN; + function-enumerator = <2>; + }; + + multi-led@4 { + reg = <0x4>; + color = <LED_COLOR_ID_RGB>; + function = LED_FUNCTION_WLAN; + function-enumerator = <1>; + }; + + multi-led@5 { + reg = <0x5>; + color = <LED_COLOR_ID_RGB>; + function = LED_FUNCTION_WAN; + }; + + multi-led@6 { + reg = <0x6>; + color = <LED_COLOR_ID_RGB>; + function = LED_FUNCTION_LAN; + function-enumerator = <4>; + }; + + multi-led@7 { + reg = <0x7>; + color = <LED_COLOR_ID_RGB>; + function = LED_FUNCTION_LAN; + function-enumerator = <3>; + }; + + multi-led@8 { + reg = <0x8>; + color = <LED_COLOR_ID_RGB>; + function = LED_FUNCTION_LAN; + function-enumerator = <2>; + }; + + multi-led@9 { + reg = <0x9>; + color = <LED_COLOR_ID_RGB>; + function = LED_FUNCTION_LAN; + function-enumerator = <1>; + }; + + multi-led@a { + reg = <0xa>; + color = <LED_COLOR_ID_RGB>; + function = LED_FUNCTION_LAN; + function-enumerator = <0>; + }; + + multi-led@b { + reg = <0xb>; + color = <LED_COLOR_ID_RGB>; + function = LED_FUNCTION_POWER; + }; + };
eeprom@54 { - compatible = "at,24c64"; + compatible = "atmel,24c64"; reg = <0x54>;
/* The EEPROM contains data for bootloader. @@ -222,7 +343,7 @@ /* routed to PCIe2 connector (CN62A) */ };
- i2c@4 { + sfp_i2c: i2c@4 { #address-cells = <1>; #size-cells = <0>; reg = <4>; @@ -235,7 +356,11 @@ #size-cells = <0>; reg = <5>;
- /* ATSHA204A at address 0x64 */ + /* ATSHA204A-MAHDA-T crypto module */ + crypto@64 { + compatible = "atmel,atsha204a"; + reg = <0x64>; + }; };
i2c@6 { @@ -277,23 +402,29 @@ pinctrl-0 = <&mdio_pins>; status = "okay";
- phy1: phy@1 { - status = "okay"; - compatible = "ethernet-phy-id0141.0DD1", "ethernet-phy-ieee802.3-c22"; + phy1: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; reg = <1>; + marvell,reg-init = <3 18 0 0x4985>, + <3 16 0xfff0 0x0001>;
/* irq is connected to &pcawan pin 7 */ };
/* Switch MV88E6176 at address 0x10 */ switch@10 { + pinctrl-names = "default"; + pinctrl-0 = <&swint_pins>; compatible = "marvell,mv88e6085"; #address-cells = <1>; #size-cells = <0>; - dsa,member = <0 0>;
+ dsa,member = <0 0>; reg = <0x10>;
+ interrupt-parent = <&gpio1>; + interrupts = <13 IRQ_TYPE_LEVEL_LOW>; + ports { #address-cells = <1>; #size-cells = <0>; @@ -346,6 +477,11 @@ marvell,function = "gpio"; };
+ swint_pins: swint-pins { + marvell,pins = "mpp45"; + marvell,function = "gpio"; + }; + spi0cs0_pins: spi0cs0-pins { marvell,pins = "mpp25"; marvell,function = "spi0"; @@ -362,7 +498,7 @@ pinctrl-0 = <&spi0_pins &spi0cs0_pins>; status = "okay";
- spi-nor@0 { + flash@0 { compatible = "spansion,s25fl164k", "jedec,spi-nor"; #address-cells = <1>; #size-cells = <1>;
- Add SPDX-License-Identifier
- Add SFP and LED nodes
- Fix PHY nad NOR nodes
- Remove duplicates from u-boot.dtsi file
Thanks, Stefan
}; };reg = <0x64>; };
- spi-nor@0 {
partitions {
- Device Tree file for the Turris Omnia
- Copyright (C) 2016 Uwe Kleine-König uwe@kleine-koenig.org
- Copyright (C) 2016 Tomas Hlavacek tmshlvkc@gmail.com
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is licensed under the terms of the GNU General Public
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
- Schematic available at https://www.turris.cz/doc/_media/rtrom01-schema.pdf
@@ -45,6 +12,7 @@
internal-regs {
slot-power-limit-milliwatt = <10000>; }; pcie@2,0 { /* Port 1, Lane 0 */ status = "okay";
slot-power-limit-milliwatt = <10000>; }; pcie@3,0 { /* Port 2, Lane 0 */ status = "okay";
sfp: sfp {
* eth2 node below.
+&bm {
- status = "okay";
+&bm_bppi {
status = "okay"; };
bm,pool-long = <0>;
bm,pool-long = <1>;
/* WAN port */ ð2 {
status = "okay"; phy-mode = "sgmii";*/
- phy = <&phy1>;
sfp = <&sfp>;
bm,pool-long = <2>;
&i2c0 {
status = "okay";
led-controller@2b {
reg = <0x2b>;
#size-cells = <0>;
status = "okay";
* address 0x2b.
* these slots
multi-led@0 {
reg = <0x0>;
multi-led@1 {
reg = <0x1>;
multi-led@2 {
reg = <0x2>;
multi-led@3 {
reg = <0x3>;
multi-led@4 {
reg = <0x4>;
multi-led@5 {
reg = <0x5>;
multi-led@6 {
reg = <0x6>;
multi-led@7 {
reg = <0x7>;
multi-led@8 {
reg = <0x8>;
multi-led@9 {
reg = <0x9>;
multi-led@a {
reg = <0xa>;
multi-led@b {
reg = <0xb>;
}; eeprom@54 {
compatible = "atmel,24c64"; reg = <0x54>; /* The EEPROM contains data for bootloader.
i2c@4 {
crypto@64 {
reg = <0x64>;
i2c@6 {
- phy1: phy@1 {
status = "okay";
reg = <1>;
dsa,member = <0 0>;
dsa,member = <0 0>;
reg = <0x10>;
- swint_pins: swint-pins {
- spi0cs0_pins: spi0cs0-pins { marvell,pins = "mpp25"; marvell,function = "spi0";
- spi-nor@0 {
- flash@0 { compatible = "spansion,s25fl164k", "jedec,spi-nor"; #address-cells = <1>; #size-cells = <1>;
Thanks, Stefan
- spi-nor@0 {
partitions {
- whole.
conditions:
@@ -45,6 +12,7 @@
internal-regs {
sfp: sfp {
* eth2 node below.
+&bm {
- status = "okay";
+&bm_bppi {
status = "okay"; };
bm,pool-long = <0>;
bm,pool-long = <1>;
/* WAN port */ ð2 {
- phy = <&phy1>;
sfp = <&sfp>;
bm,pool-long = <2>;
&i2c0 {
status = "okay";
led-controller@2b {
reg = <0x2b>;
#size-cells = <0>;
status = "okay";
* address 0x2b.
* these slots
multi-led@0 {
reg = <0x0>;
multi-led@1 {
reg = <0x1>;
multi-led@2 {
reg = <0x2>;
multi-led@3 {
reg = <0x3>;
multi-led@4 {
reg = <0x4>;
multi-led@5 {
reg = <0x5>;
multi-led@6 {
reg = <0x6>;
multi-led@7 {
reg = <0x7>;
multi-led@8 {
reg = <0x8>;
multi-led@9 {
reg = <0x9>;
multi-led@a {
reg = <0xa>;
multi-led@b {
reg = <0xb>;
}; eeprom@54 {
i2c@4 {
crypto@64 {
reg = <0x64>;
i2c@6 {
- phy1: phy@1 {
status = "okay";
reg = <1>;
dsa,member = <0 0>;
dsa,member = <0 0>;
reg = <0x10>;
- spi-nor@0 {
Hi Pali
nand@d0000 {
nand@d0000 {
&nand_controller {
I prefer that adding compatible go in a different patch
Michael
2.20.1
On Wednesday 27 July 2022 14:55:51 Michael Nazzareno Trimarchi wrote:
Hi Pali
nand@d0000 {
nand@d0000 {
&nand_controller {
Hello! All this are fixes for Armada DTS files, so I put it into series which updates Armada 38x DTS files. But to do not introduce a build or runtime error, it is needed to fix compatible string also in pxa3xx_nand driver in the same patch. Meaning, it has to be atomic change.
Michael
2.20.1
Hi
Hi Pali
nand@d0000 {
compatible =
nand@d0000 {
compatible =
compatible =
compatible =
&nand_controller {
If you add the compatible before all the patches you don't break anything. Just queue before the others
Michael
Michael
2.20.1
On Wednesday 27 July 2022 20:41:51 Michael Nazzareno Trimarchi wrote:
Hi
Hi Pali
nand@d0000 {
compatible =
nand@d0000 {
compatible =
compatible =
compatible =
&nand_controller {
The issue is that this change does not add compatible. It replaces existing compatible by the correct one.
Michael
Michael
2.20.1
Hi
Hi
Hi Pali
nand@d0000 {
compatible =
compatible =
nand@d0000 {
compatible =
compatible =
compatible =
compatible =
&nand_controller {
anything.
Yes, ok you are scared about not working more that not building.
Don't like to much but ok, your intention is clear.
Michael
Michael
Michael
2.20.1
Hi Pali
nand@d0000 {
nand@d0000 {
&nand_controller {
I personally have no issues with this approach and frankly would have done it also in one atomic change.
Thanks, Stefan
Thanks, Stefan
nand@d0000 {
nand@d0000 {
&nand_controller {
- compatible="marvell,armada370-nand-controller"; status = "okay"; label = "pxa3xx_nand-0"; nand-rb = <0>;
.data = PXA3XX_NAND_VARIANT_ARMADA370, }, {.compatible = "marvell,armada370-nand-controller",
Hi
Acked-by: Michael Trimarchi michael@amarulasolutions.com
Michael
Thanks, Stefan
nand@d0000 {
nand@d0000 {
&nand_controller {
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
Hi Stefan
On Thu, Jul 28, 2022 at 9:45 AM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi
Are you going to queue them?
Michael
Michael
Thanks, Stefan
nand@d0000 {
nand@d0000 {
&nand_controller {
-- Michael Nazzareno Trimarchi Co-Founder & Chief Executive Officer M. +39 347 913 2170 michael@amarulasolutions.com __________________________________
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com www.amarulasolutions.com
On 29.07.22 11:38, Michael Nazzareno Trimarchi wrote:
Hi Stefan
Hi
Yes. Is this okay with you?
Thanks, Stefan
Michael
Michael
Thanks, Stefan
nand@d0000 {
nand@d0000 {
&nand_controller {
Thanks, Stefan
nand@d0000 {
nand@d0000 {
&nand_controller {
Pali Rohár
Stefan Roese
