[U-Boot] [PATCH] eNET: Fix undefined reference to `monitor_flash_len'
commit cfbe861506e2dc3250ac99dc45bb3d1ac60f4857 removed the definition of monitor_flash_len from the eNET which was not picked up due to extensive use of the SRAM configuration target for testing
Signed-off-by: Graeme Russ graeme.russ@gmail.com --- board/eNET/eNET.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/board/eNET/eNET.c b/board/eNET/eNET.c index dd0ce54..2a5636c 100644 --- a/board/eNET/eNET.c +++ b/board/eNET/eNET.c @@ -35,6 +35,8 @@
DECLARE_GLOBAL_DATA_PTR;
+unsigned long monitor_flash_len = CONFIG_SYS_MONITOR_LEN; + static void enet_timer_isr(void); static void enet_toggle_run_led(void); static void enet_setup_pars(void);
Applied to u-boot-x86, master branch, thanks.
Regards,
Graeme Russ
Graeme Russ
