[U-Boot] [PATCH] armv8: fsl: ifc: Put IFC related code under CONFIG_FSL_IFC
IFC code is put under CONFIG_FSL_IFC
Signed-off-by: Sriram Dash sriram.dash@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 2 ++ arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 10 ++++++++++ 2 files changed, 12 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 639e9d2..a538d76 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -192,7 +192,9 @@ void bypass_smmu(void) void fsl_lsch3_early_init_f(void) { erratum_rcw_src(); +#ifdef CONFIG_FSL_IFC init_early_memctl_regs(); /* tighten IFC timing */ +#endif #ifdef CONFIG_SYS_FSL_ERRATUM_A009203 erratum_a009203(); #endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index c4e5ecc..f231688 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -102,6 +102,7 @@ static struct mm_region early_map[] = { { CONFIG_SYS_FSL_QSPI_BASE1, CONFIG_SYS_FSL_QSPI_BASE1, CONFIG_SYS_FSL_QSPI_SIZE1, PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_NON_SHARE}, +#ifdef CONFIG_FSL_IFC /* For IFC Region #1, only the first 4MB is cache-enabled */ { CONFIG_SYS_FSL_IFC_BASE1, CONFIG_SYS_FSL_IFC_BASE1, CONFIG_SYS_FSL_IFC_SIZE1_1, @@ -116,6 +117,7 @@ static struct mm_region early_map[] = { CONFIG_SYS_FSL_IFC_SIZE1, PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE }, +#endif { CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_SIZE1, #if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) @@ -125,11 +127,13 @@ static struct mm_region early_map[] = { #endif PTE_BLOCK_OUTER_SHARE | PTE_BLOCK_NS }, +#ifdef CONFIG_FSL_IFC /* Map IFC region #2 up to CONFIG_SYS_FLASH_BASE for NAND boot */ { CONFIG_SYS_FSL_IFC_BASE2, CONFIG_SYS_FSL_IFC_BASE2, CONFIG_SYS_FLASH_BASE - CONFIG_SYS_FSL_IFC_BASE2, PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE }, +#endif { CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_SIZE, PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | @@ -159,10 +163,12 @@ static struct mm_region early_map[] = { CONFIG_SYS_FSL_QSPI_SIZE, PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE }, +#ifdef CONFIG_FSL_IFC { CONFIG_SYS_FSL_IFC_BASE, CONFIG_SYS_FSL_IFC_BASE, CONFIG_SYS_FSL_IFC_SIZE, PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE }, +#endif { CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_SIZE1, #if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) @@ -206,10 +212,12 @@ static struct mm_region final_map[] = { PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE | PTE_BLOCK_PXN | PTE_BLOCK_UXN }, +#ifdef CONFIG_FSL_IFC { CONFIG_SYS_FSL_IFC_BASE2, CONFIG_SYS_FSL_IFC_BASE2, CONFIG_SYS_FSL_IFC_SIZE2, PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE }, +#endif { CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_SIZE, PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | @@ -304,10 +312,12 @@ static struct mm_region final_map[] = { PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE | PTE_BLOCK_PXN | PTE_BLOCK_UXN }, +#ifdef CONFIG_FSL_IFC { CONFIG_SYS_FSL_IFC_BASE, CONFIG_SYS_FSL_IFC_BASE, CONFIG_SYS_FSL_IFC_SIZE, PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | PTE_BLOCK_NON_SHARE }, +#endif { CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_SIZE1, PTE_BLOCK_MEMTYPE(MT_NORMAL) |
Applied to fsl-qoriq mater. Thanks.
York
Sriram Dash
York Sun
