[PATCH] net: zynq: Free allocated buffers in case of error
Driver probe function is called again and again in case of error. Malloc space is getting full which is is reported by: Insufficient RAM for page table: 0x15000 > 0x14000. Please increase the size in get_page_table_size() ### ERROR ### Please RESET the board ###
The patch is freeing allocated buffers on error path to avoid panic.
drivers/net/zynq_gem.c | 22 +++++++++++++++++----- 1 file changed, 17 insertions(+), 5 deletions(-)
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 879129653df3..745c65cf471c 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -659,8 +659,10 @@ static int zynq_gem_probe(struct udevice *dev)
/* Align bd_space to MMU_SECTION_SHIFT */ bd_space = memalign(1 << MMU_SECTION_SHIFT, BD_SPACE); - if (!bd_space) - return -ENOMEM; + if (!bd_space) { + ret = -ENOMEM; + goto err1; + }
mmu_set_region_dcache_behaviour((phys_addr_t)bd_space, BD_SPACE, DCACHE_OFF); @@ -672,7 +674,7 @@ static int zynq_gem_probe(struct udevice *dev) ret = clk_get_by_name(dev, "tx_clk", &priv->clk); if (ret < 0) { dev_err(dev, "failed to get clock\n"); - return -EINVAL; + goto err1; }
priv->bus = mdio_alloc(); @@ -682,9 +684,19 @@ static int zynq_gem_probe(struct udevice *dev)
ret = mdio_register_seq(priv->bus, dev->seq); if (ret) - return ret; + goto err2;
- return zynq_phy_init(dev); + ret = zynq_phy_init(dev); + if (ret) + goto err2; + + return ret; + +err2: + free(priv->rxbuffers); +err1: + free(priv->tx_bd); + return ret; }
static int zynq_gem_remove(struct udevice *dev)
čt 6. 2. 2020 v 16:04 odesílatel Michal Simek michal.simek@xilinx.com napsal:
if (!bd_space)
return -ENOMEM;
if (!bd_space) {
ret = -ENOMEM;
goto err1;
} mmu_set_region_dcache_behaviour((phys_addr_t)bd_space, BD_SPACE, DCACHE_OFF);
return -EINVAL;
goto err1; } priv->bus = mdio_alloc();
return ret;
goto err2;
if (ret)
goto err2;
return ret;
+err2:
+err1:
free(priv->tx_bd);
return ret;
2.25.0
Applied. M
Michal Simek
Michal Simek
