[U-Boot] [PULL] Please pull u-boot-imx
Hi Tom,
please pull from u-boot-imx, thanks !
The following changes since commit 1d149eddcc0661b683002f76a8240491eba00dbb:
dm: Add timeline and guide for porting serial drivers (2015-11-20 13:59:54 -0500)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to a80a999c9b5c128cad2f67b4b32036bd4d667904:
arm: imx6: novena: Enable extfs support in SPL (2015-12-01 16:11:08 +0100)
---------------------------------------------------------------- Marek Vasut (3): arm: mx6: Reduce SPL malloc pool size arm: imx6: novena, gw_ventana: Fix use of pfuze100 bit definitions arm: imx6: novena: Enable extfs support in SPL
Michael Heimpold (1): ARM: mxs: fix VDDD brownout setting
Otavio Salvador (6): cgtqmx6eval: Add SPI NOR flash support cgtqmx6eval: Use SPI NOR to store the environment cgtqmx6eval: Add fastboot support cgtqmx6eval: Add SPL support iomux-v3: Take MX6D in consideration for imx_iomux_v3_setup_pad() cgtqmx6eval: Add DFU support
Peng Fan (1): video: ipu: simplify if else code
Sanchayan Maity (1): colibri_vf: Add board_usb_phy_mode function
Ye.Li (1): mx6: clock: Modify GPMI clock to support mx6sx
arch/arm/cpu/arm926ejs/mxs/spl_power_init.c | 4 +- arch/arm/cpu/armv7/mx6/Kconfig | 3 + arch/arm/cpu/armv7/mx6/clock.c | 12 +++ arch/arm/include/asm/imx-common/iomux-v3.h | 2 +- board/congatec/cgtqmx6eval/README | 78 +++++++++++++---- board/congatec/cgtqmx6eval/cgtqmx6eval.c | 599 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++-------------------- board/congatec/cgtqmx6eval/imximage.cfg | 143 ------------------------------ board/gateworks/gw_ventana/common.c | 2 +- board/kosagi/novena/novena.c | 2 +- board/toradex/colibri_vf/colibri_vf.c | 33 ++++++- configs/{cgtqmx6qeval_defconfig => cgtqmx6eval_defconfig} | 5 +- drivers/video/ipu_disp.c | 4 +- include/configs/cgtqmx6eval.h | 68 ++++++++++++-- include/configs/imx6_spl.h | 6 +- include/configs/novena.h | 1 + 15 files changed, 689 insertions(+), 273 deletions(-) delete mode 100644 board/congatec/cgtqmx6eval/imximage.cfg rename configs/{cgtqmx6qeval_defconfig => cgtqmx6eval_defconfig} (72%)
On Fri, Dec 04, 2015 at 12:57:22PM +0100, Stefano Babic wrote:
Hi Tom,
Stefano Babic
