Pull request for efi-2023-07-rc1-2
Dear Tom,
The following changes since commit 5db4972a5bbdbf9e3af48ffc9bc4fec73b7b6a79:
Merge tag 'u-boot-nand-20230417' of https://source.denx.de/u-boot/custodians/u-boot-nand-flash (2023-04-17 10:47:33 -0400)
https://source.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2023-07-rc1-2
for you to fetch changes up to b10bfd0019f601e2608370ed47741da201423d55:
efi_loader: Fix flexible array member definitions (2023-04-21 08:50:35 +0200)
Gitlab CI showed no issues: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/16067
---------------------------------------------------------------- Pull request for efi-2023-07-rc1-2
Documentation:
* Describe Python coding style
UEFI:
* Enable tests for authenticated capsules on the sandbox * Fix pylint warnings * Correct struct efi_hii_keyboard_layout definition
---------------------------------------------------------------- Heinrich Schuchardt (5): doc: codingstyle: Python coding style efi_loader: remove unused efi_capsule_authenticate test: fix pylint warning for capsule tests sandbox: enable CONFIG_EFI_CAPSULE_AUTHENTICATE test: fix launch_efi()
Ilias Apalodimas (1): efi_loader: Fix flexible array member definitions
configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + doc/develop/codingstyle.rst | 7 ++++ include/efi_api.h | 2 +- lib/efi_loader/efi_capsule.c | 6 ---- test/py/tests/test_efi_capsule/conftest.py | 27 +++++--------- .../test_efi_capsule/test_capsule_firmware_fit.py | 35 +++++++++--------- .../test_capsule_firmware_signed_fit.py | 41 +++++++++++----------- .../test_capsule_firmware_signed_raw.py | 38 ++++++++++---------- test/py/tests/test_efi_fit.py | 4 ++- 10 files changed, 78 insertions(+), 84 deletions(-)
On Fri, Apr 21, 2023 at 02:20:27PM +0200, Heinrich Schuchardt wrote:
Dear Tom,
