[PATCH 00/26 v7] Refactor the architecture parts of mt7628
This patch series are divided into two parts:
The main part is to rewrite the whole architecture code of mt7628: * Lock parts of the d-cache for initial stack so the rest of the code can be reimplemented in C. * Memory controller & DDR initialization have been fully written to support detecting DDR size automatically. * DDR calibration has also been reimplemented with a clear logic. * Implemented a new sysreset driver to take advantage of the reset controller so we can drop the use of syscon-based sysreset to reduce size.
The second part is to add SPL support for mt7628: * With SPL enabled we can build the ROM-bootable and RAM-bootable binary simultaneously, and we can drop RAM boot related configs and defconfig files. * Generate compressed u-boot.bin image for SPL to reduce size of final combined binary. * Enable DM support for SPL for a more flexible device probing. * Add a demo board (mt7628_rfb) aims at router application.
Changes since v2: * Dropped a patch which removes unused parts of mt7628a.dtsi * Move lzma decompression support to common spl_nor.c * Move u-boot,dm-pre-reloc to u-boot-mt7628.dtsi
Changes since v3: * Rebased on newest master branch * Add a test for binman etype u-boot-lzma-img to make sure binman passes 100% code coverage * Use u-boot-with-spl.bin for SPL-enabled output file * Remove unused code from spl_nor loader.
Changes since v5: * Rebased on newest master branch * Made lzma decompressing support for legacy U-Boot images more generic, so that it can be easily integrated into other devices loaders as well
Changes since v6: * Add spl_image_get_comp() to enable the compiler to optimize the switch/case statement away due to Dead Code Elimination as suggested by Daniel * Moved cache flush to MIPS specific file as suggested by Daniel
Stefan Roese (6): spl: Extract legacy image handling into separate file spl: spl_legacy: Use IS_ENABLED() to remove #ifdef spl: spl_nor: Move legacy image loading into spl_legacy.c spl: spl_nor: Remove unused variable 'ret' warning mips: spl: Flush cache before jumping to U-Boot proper mips: mtmips: Increase CONFIG_SPL_SYS_MALLOC_F_LEN
Weijie Gao (20): mips: add support to restore exception vector base before booting linux mips: mtmips: add predefined i-cache/d-cache size and linesize mips: add an option to support initialize SRAM for initial stack mips: start.S: avoid overwriting outside gd when clearing global data in stack sysreset: add reset controller based reboot driver mips: mtmips: make use of sysreset-resetctrl for mt7628 soc configs: enable CONFIG_RESTORE_EXCEPTION_VECTOR_BASE for all mtmips boards mips: add a mtmips-specific field to architecture-specific global data mips: add a option to support not reserving malloc space on initial stack mips: mtmips: rewrite lowlevel codes of mt7628 dts: mtmips: add alternative pinmux node for uart2 mips: enable support for appending dtb to spl binary mips: add an option to enable u_boot_list section for SPL loaders in u-boot-spl.lds lib: enable lzma decompression support for SPL build Makefile: add support to generate LZMA compressed u-boot image tools: binman: add etype file for u-boot-lzma-img spl: spl_legacy: Add lzma decompression support for legacy image mips: mtmips: add SPL support mips: mtmips: enable SPL for all boards mips: mtmips: add support for mt7628-rfb
Makefile | 19 + arch/mips/Kconfig | 66 ++++ arch/mips/cpu/start.S | 16 +- arch/mips/cpu/u-boot-spl.lds | 4 +- arch/mips/dts/Makefile | 1 + arch/mips/dts/mediatek,mt7628-rfb.dts | 67 ++++ arch/mips/dts/mt7628-u-boot.dtsi | 56 +++ arch/mips/dts/mt7628a.dtsi | 17 +- arch/mips/include/asm/global_data.h | 3 + arch/mips/include/asm/u-boot-mips.h | 2 + arch/mips/lib/Makefile | 1 + arch/mips/lib/bootm.c | 3 + arch/mips/lib/spl.c | 21 ++ arch/mips/lib/traps.c | 19 + arch/mips/mach-mtmips/Kconfig | 135 +++---- arch/mips/mach-mtmips/Makefile | 8 +- arch/mips/mach-mtmips/cpu.c | 58 +--- arch/mips/mach-mtmips/ddr_cal.c | 211 +++++++++++ arch/mips/mach-mtmips/ddr_calibrate.c | 309 ----------------- arch/mips/mach-mtmips/ddr_init.c | 194 +++++++++++ arch/mips/mach-mtmips/include/mach/ddr.h | 52 +++ arch/mips/mach-mtmips/include/mach/mc.h | 180 ++++++++++ arch/mips/mach-mtmips/include/mach/serial.h | 13 + arch/mips/mach-mtmips/lowlevel_init.S | 328 ------------------ arch/mips/mach-mtmips/mt7628/Makefile | 6 + arch/mips/mach-mtmips/mt7628/ddr.c | 173 +++++++++ arch/mips/mach-mtmips/mt7628/init.c | 109 ++++++ arch/mips/mach-mtmips/mt7628/lowlevel_init.S | 161 +++++++++ arch/mips/mach-mtmips/mt7628/mt7628.h | 104 ++++++ arch/mips/mach-mtmips/mt7628/serial.c | 34 ++ arch/mips/mach-mtmips/mt76xx.h | 32 -- arch/mips/mach-mtmips/spl.c | 44 +++ board/gardena/smart-gateway-mt7688/board.c | 2 + board/mediatek/mt7628/Kconfig | 12 + board/mediatek/mt7628/MAINTAINERS | 7 + board/mediatek/mt7628/Makefile | 3 + board/mediatek/mt7628/board.c | 8 + common/spl/Makefile | 1 + common/spl/spl.c | 56 +-- common/spl/spl_legacy.c | 131 +++++++ common/spl/spl_nor.c | 27 +- ...gardena-smart-gateway-mt7688-ram_defconfig | 74 ---- .../gardena-smart-gateway-mt7688_defconfig | 14 +- configs/linkit-smart-7688-ram_defconfig | 65 ---- configs/linkit-smart-7688_defconfig | 14 +- configs/mt7628_rfb_defconfig | 46 +++ drivers/sysreset/Kconfig | 6 + drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_resetctl.c | 48 +++ .../configs/gardena-smart-gateway-mt7688.h | 21 +- include/configs/linkit-smart-7688.h | 22 +- include/configs/mt7628.h | 56 +++ include/spl.h | 13 + lib/Kconfig | 5 + lib/Makefile | 1 + tools/binman/README.entries | 15 + tools/binman/etype/u_boot_lzma_img.py | 28 ++ tools/binman/ftest.py | 7 + tools/binman/test/156_u_boot_lzma_img.dts | 11 + 59 files changed, 2108 insertions(+), 1032 deletions(-) create mode 100644 arch/mips/dts/mediatek,mt7628-rfb.dts create mode 100644 arch/mips/dts/mt7628-u-boot.dtsi create mode 100644 arch/mips/lib/spl.c create mode 100644 arch/mips/mach-mtmips/ddr_cal.c delete mode 100644 arch/mips/mach-mtmips/ddr_calibrate.c create mode 100644 arch/mips/mach-mtmips/ddr_init.c create mode 100644 arch/mips/mach-mtmips/include/mach/ddr.h create mode 100644 arch/mips/mach-mtmips/include/mach/mc.h create mode 100644 arch/mips/mach-mtmips/include/mach/serial.h delete mode 100644 arch/mips/mach-mtmips/lowlevel_init.S create mode 100644 arch/mips/mach-mtmips/mt7628/Makefile create mode 100644 arch/mips/mach-mtmips/mt7628/ddr.c create mode 100644 arch/mips/mach-mtmips/mt7628/init.c create mode 100644 arch/mips/mach-mtmips/mt7628/lowlevel_init.S create mode 100644 arch/mips/mach-mtmips/mt7628/mt7628.h create mode 100644 arch/mips/mach-mtmips/mt7628/serial.c delete mode 100644 arch/mips/mach-mtmips/mt76xx.h create mode 100644 arch/mips/mach-mtmips/spl.c create mode 100644 board/mediatek/mt7628/Kconfig create mode 100644 board/mediatek/mt7628/MAINTAINERS create mode 100644 board/mediatek/mt7628/Makefile create mode 100644 board/mediatek/mt7628/board.c create mode 100644 common/spl/spl_legacy.c delete mode 100644 configs/gardena-smart-gateway-mt7688-ram_defconfig delete mode 100644 configs/linkit-smart-7688-ram_defconfig create mode 100644 configs/mt7628_rfb_defconfig create mode 100644 drivers/sysreset/sysreset_resetctl.c create mode 100644 include/configs/mt7628.h create mode 100644 tools/binman/etype/u_boot_lzma_img.py create mode 100644 tools/binman/test/156_u_boot_lzma_img.dts
In U-Boot the exception vector base will be moved to top of memory, to be used to display register dump when exception occurs.
But some old linux kernel does not honor the base set in CP0_EBASE. A modified exception vector base will cause kernel crash.
This patch adds an option to enable reset exception vector base to its previous value, or a user configured value before booting linux kernel.
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: none
arch/mips/Kconfig | 30 +++++++++++++++++++++++++++++ arch/mips/include/asm/u-boot-mips.h | 2 ++ arch/mips/lib/bootm.c | 3 +++ arch/mips/lib/traps.c | 19 ++++++++++++++++++ 4 files changed, 54 insertions(+)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index a3ae603044..5e20feeefb 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -287,6 +287,36 @@ config MIPS_RELOCATION_TABLE_SIZE
If unsure, leave at the default value.
+config RESTORE_EXCEPTION_VECTOR_BASE + bool "Restore exception vector base before booting linux kernel" + default n + help + In U-Boot the exception vector base will be moved to top of memory, + to be used to display register dump when exception occurs. + But some old linux kernel does not honor the base set in CP0_EBASE. + A modified exception vector base will cause kernel crash. + + This option will restore the exception vector base to its previous + value. + + If unsure, say N. + +config OVERRIDE_EXCEPTION_VECTOR_BASE + bool "Override the exception vector base to be restored" + depends on RESTORE_EXCEPTION_VECTOR_BASE + default n + help + Enable this option if you want to use a different exception vector + base rather than the previously saved one. + +config NEW_EXCEPTION_VECTOR_BASE + hex "New exception vector base" + depends on OVERRIDE_EXCEPTION_VECTOR_BASE + range 0x80000000 0xbffff000 + default 0x80000000 + help + The exception vector base to be restored before booting linux kernel + endmenu
menu "OS boot interface" diff --git a/arch/mips/include/asm/u-boot-mips.h b/arch/mips/include/asm/u-boot-mips.h index 88438b9576..8b37cc4029 100644 --- a/arch/mips/include/asm/u-boot-mips.h +++ b/arch/mips/include/asm/u-boot-mips.h @@ -9,4 +9,6 @@ void except_vec_ejtag_debug(void);
int arch_misc_init(void);
+void trap_restore(void); + #endif /* _U_BOOT_MIPS_H_ */ diff --git a/arch/mips/lib/bootm.c b/arch/mips/lib/bootm.c index 8c0d7672f2..f1db6d23b8 100644 --- a/arch/mips/lib/bootm.c +++ b/arch/mips/lib/bootm.c @@ -294,6 +294,9 @@ static void boot_jump_linux(bootm_headers_t *images) bootstage_report(); #endif
+ if (CONFIG_IS_ENABLED(RESTORE_EXCEPTION_VECTOR_BASE)) + trap_restore(); + if (images->ft_len) kernel(-2, (ulong)images->ft_addr, 0, 0); else diff --git a/arch/mips/lib/traps.c b/arch/mips/lib/traps.c index b8568c00fe..8fff7541e3 100644 --- a/arch/mips/lib/traps.c +++ b/arch/mips/lib/traps.c @@ -20,6 +20,8 @@
DECLARE_GLOBAL_DATA_PTR;
+static unsigned long saved_ebase; + static void show_regs(const struct pt_regs *regs) { const int field = 2 * sizeof(unsigned long); @@ -102,7 +104,24 @@ void trap_init(ulong reloc_addr) set_handler(0x180, &except_vec3_generic, 0x80); set_handler(0x280, &except_vec_ejtag_debug, 0x80);
+ saved_ebase = read_c0_ebase() & 0xfffff000; + write_c0_ebase(ebase); clear_c0_status(ST0_BEV); execution_hazard_barrier(); } + +void trap_restore(void) +{ + set_c0_status(ST0_BEV); + execution_hazard_barrier(); + +#ifdef CONFIG_OVERRIDE_EXCEPTION_VECTOR_BASE + write_c0_ebase(CONFIG_NEW_EXCEPTION_VECTOR_BASE & 0xfffff000); +#else + write_c0_ebase(saved_ebase); +#endif + + clear_c0_status(ST0_BEV); + execution_hazard_barrier(); +}
Both mt7620 and mt7628 has the same cache configuration. There is no need to use CONFIG_SYS_CACHE_SIZE_AUTO to probe it at runtime.
Add them into Kconfig to reduce some code size.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: none
arch/mips/mach-mtmips/Kconfig | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index c8dcf19c0d..8e10719b27 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -7,6 +7,18 @@ config SYS_MALLOC_F_LEN config SYS_SOC default "mt7628" if SOC_MT7628
+config SYS_DCACHE_SIZE + default 32768 + +config SYS_DCACHE_LINE_SIZE + default 32 + +config SYS_ICACHE_SIZE + default 65536 + +config SYS_ICACHE_LINE_SIZE + default 32 + choice prompt "MediaTek MIPS SoC select"
Currently CONFIG_MIPS_INIT_STACK_IN_SRAM assumes the memory space for the initial stack can be used directly. However on some platform the SRAM needs initialization, e.g. lock cache.
This patch adds an option to allow a new function mips_sram_init() being called before setup_stack_gd.
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: none
arch/mips/Kconfig | 9 +++++++++ arch/mips/cpu/start.S | 7 +++++++ 2 files changed, 16 insertions(+)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 5e20feeefb..bf30a56101 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -419,6 +419,15 @@ config MIPS_INIT_STACK_IN_SRAM lowlevel_init. Thus lowlevel_init does not need to be implemented in assembler.
+config MIPS_SRAM_INIT + bool + default n + depends on MIPS_INIT_STACK_IN_SRAM + help + Select this if the SRAM for initial stack needs to be initialized + before it can be used. If enabled, a function mips_sram_init() will + be called just before setup_stack_gd. + config SYS_DCACHE_SIZE int default 0 diff --git a/arch/mips/cpu/start.S b/arch/mips/cpu/start.S index 1d21b2324a..f9805fa000 100644 --- a/arch/mips/cpu/start.S +++ b/arch/mips/cpu/start.S @@ -216,6 +216,13 @@ wr_done: #endif
#ifdef CONFIG_MIPS_INIT_STACK_IN_SRAM +#ifdef CONFIG_MIPS_SRAM_INIT + /* Initialize the SRAM first */ + PTR_LA t9, mips_sram_init + jalr t9 + nop +#endif + /* Set up initial stack and global data */ setup_stack_gd
When setting up initial stack, global data will also be put in the stack, and being cleared.
The assembler instructions for clearing gd is as follows:
move t0, k0 1: PTR_S zero, 0(t0) blt t0, t1, 1b PTR_ADDIU t0, PTRSIZE
t0 is the start address of gd, t1 is the end address of gd (t0 + GD_SIZE).
[PTR_ADDIU t0, PTRSIZE] is in the delay slot of [blt t0, t1, 1b], so it will be executed before the branch operation.
However the comparison for the BLT instruction is done before executing the delay slot. This means when the last word just before k1 is cleared, the loop will continue to run once. This will clear an extra word at k1, which is outside the global data.
Global data is placed at the top of the stack. If the initial stack is a SRAM or locked cache, the area outside them may be inaccessible. A write operation performed in this area may cause an exception.
To solve this, [PTR_ADDIU t0, PTRSIZE] should be placed before the BLT instruction.
arch/mips/cpu/start.S | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/mips/cpu/start.S b/arch/mips/cpu/start.S index f9805fa000..dd93df9e4a 100644 --- a/arch/mips/cpu/start.S +++ b/arch/mips/cpu/start.S @@ -71,8 +71,9 @@ move t0, k0 1: PTR_S zero, 0(t0) + PTR_ADDIU t0, PTRSIZE blt t0, t1, 1b - PTR_ADDIU t0, PTRSIZE + nop
#if CONFIG_VAL(SYS_MALLOC_F_LEN) PTR_S sp, GD_MALLOC_BASE(k0) # gd->malloc_base offset
Some chips provide their sysreset function in reset controller, which is normally a bit written to 1 to perform the sysreset.
This patch adds a new sysreset driver to take advantage of it.
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: none
drivers/sysreset/Kconfig | 6 ++++ drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_resetctl.c | 48 ++++++++++++++++++++++++++++ 3 files changed, 55 insertions(+) create mode 100644 drivers/sysreset/sysreset_resetctl.c
diff --git a/drivers/sysreset/Kconfig b/drivers/sysreset/Kconfig index f09e138bb8..4be7433404 100644 --- a/drivers/sysreset/Kconfig +++ b/drivers/sysreset/Kconfig @@ -101,6 +101,12 @@ config SYSRESET_WATCHDOG help Reboot support for generic watchdog reset.
+config SYSRESET_RESETCTL + bool "Enable support for reset controller reboot driver" + select DM_RESET + help + Reboot support using generic reset controller. + config SYSRESET_X86 bool "Enable support for x86 processor reboot driver" depends on X86 diff --git a/drivers/sysreset/Makefile b/drivers/sysreset/Makefile index 51af68fad3..3ed4bab9e3 100644 --- a/drivers/sysreset/Makefile +++ b/drivers/sysreset/Makefile @@ -16,5 +16,6 @@ obj-$(CONFIG_SYSRESET_SOCFPGA_S10) += sysreset_socfpga_s10.o obj-$(CONFIG_SYSRESET_TI_SCI) += sysreset-ti-sci.o obj-$(CONFIG_SYSRESET_SYSCON) += sysreset_syscon.o obj-$(CONFIG_SYSRESET_WATCHDOG) += sysreset_watchdog.o +obj-$(CONFIG_SYSRESET_RESETCTL) += sysreset_resetctl.o obj-$(CONFIG_$(SPL_TPL_)SYSRESET_X86) += sysreset_x86.o obj-$(CONFIG_TARGET_XTFPGA) += sysreset_xtfpga.o diff --git a/drivers/sysreset/sysreset_resetctl.c b/drivers/sysreset/sysreset_resetctl.c new file mode 100644 index 0000000000..b8203ba605 --- /dev/null +++ b/drivers/sysreset/sysreset_resetctl.c @@ -0,0 +1,48 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <sysreset.h> +#include <reset.h> + +struct resetctl_reboot_priv { + struct reset_ctl_bulk resets; +}; + +static int resetctl_reboot_request(struct udevice *dev, enum sysreset_t type) +{ + struct resetctl_reboot_priv *priv = dev_get_priv(dev); + + return reset_assert_bulk(&priv->resets); +} + +static struct sysreset_ops resetctl_reboot_ops = { + .request = resetctl_reboot_request, +}; + +int resetctl_reboot_probe(struct udevice *dev) +{ + struct resetctl_reboot_priv *priv = dev_get_priv(dev); + + return reset_get_bulk(dev, &priv->resets); +} + +static const struct udevice_id resetctl_reboot_ids[] = { + { .compatible = "resetctl-reboot" }, + { } +}; + +U_BOOT_DRIVER(resetctl_reboot) = { + .id = UCLASS_SYSRESET, + .name = "resetctl_reboot", + .of_match = resetctl_reboot_ids, + .ops = &resetctl_reboot_ops, + .priv_auto_alloc_size = sizeof(struct resetctl_reboot_priv), + .probe = resetctl_reboot_probe, +};
This patch replaces sysreset-syscon with sysreset-resetctrl for mt7628 soc.
Reviewed-by: Stefan Roese sr@denx.de Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: none
arch/mips/dts/mt7628a.dtsi | 10 +++++----- arch/mips/mach-mtmips/Kconfig | 1 + configs/gardena-smart-gateway-mt7688-ram_defconfig | 1 - configs/gardena-smart-gateway-mt7688_defconfig | 1 - configs/linkit-smart-7688-ram_defconfig | 1 - configs/linkit-smart-7688_defconfig | 1 - 6 files changed, 6 insertions(+), 9 deletions(-)
diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index 76a80c8952..409695b5c7 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -46,11 +46,11 @@ reg = <0x0 0x100>; };
- syscon-reboot { - compatible = "syscon-reboot"; - regmap = <&sysc>; - offset = <0x34>; - mask = <0x1>; + reboot: resetctl-reboot { + compatible = "resetctl-reboot"; + + resets = <&rstctrl MT7628_SYS_RST>; + reset-names = "sysreset"; };
clkctrl: clkctrl@0x2c { diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 8e10719b27..8cb76c4560 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -27,6 +27,7 @@ config SOC_MT7628 select MIPS_L1_CACHE_SHIFT_5 select PINCTRL_MT7628 select MTK_SERIAL + select SYSRESET_RESETCTL help This supports MediaTek MT7628/MT7688.
diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig index dbc94b4106..5e10a4051e 100644 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -68,7 +68,6 @@ CONFIG_MT7628_ETH=y CONFIG_PHY=y CONFIG_SPI=y CONFIG_MT7621_SPI=y -CONFIG_SYSRESET_SYSCON=y CONFIG_WDT=y CONFIG_WDT_MT7621=y CONFIG_LZMA=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 23d8ddb128..7a496fe5b3 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -71,7 +71,6 @@ CONFIG_MT7628_ETH=y CONFIG_PHY=y CONFIG_SPI=y CONFIG_MT7621_SPI=y -CONFIG_SYSRESET_SYSCON=y CONFIG_WDT=y CONFIG_WDT_MT7621=y CONFIG_LZMA=y diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig index d1691abfda..7f29617ddc 100644 --- a/configs/linkit-smart-7688-ram_defconfig +++ b/configs/linkit-smart-7688-ram_defconfig @@ -53,7 +53,6 @@ CONFIG_PHY=y CONFIG_MT76X8_USB_PHY=y CONFIG_SPI=y CONFIG_MT7621_SPI=y -CONFIG_SYSRESET_SYSCON=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index a567c0c507..484c338348 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -57,7 +57,6 @@ CONFIG_PHY=y CONFIG_MT76X8_USB_PHY=y CONFIG_SPI=y CONFIG_MT7621_SPI=y -CONFIG_SYSRESET_SYSCON=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y
This patch enables CONFIG_RESTORE_EXCEPTION_VECTOR_BASE for all mtmips boards.
configs/gardena-smart-gateway-mt7688-ram_defconfig | 1 + configs/gardena-smart-gateway-mt7688_defconfig | 1 + configs/linkit-smart-7688-ram_defconfig | 1 + configs/linkit-smart-7688_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig index 5e10a4051e..48b7a43633 100644 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_ENV_OFFSET_REDUND=0xB0000 CONFIG_ARCH_MTMIPS=y +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 7a496fe5b3..7f040f5762 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -11,6 +11,7 @@ CONFIG_ARCH_MTMIPS=y CONFIG_BOOT_ROM=y CONFIG_ONBOARD_DDR2_SIZE_1024MBIT=y CONFIG_ONBOARD_DDR2_CHIP_WIDTH_16BIT=y +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig index 7f29617ddc..1db94db41f 100644 --- a/configs/linkit-smart-7688-ram_defconfig +++ b/configs/linkit-smart-7688-ram_defconfig @@ -6,6 +6,7 @@ CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ARCH_MTMIPS=y CONFIG_BOARD_LINKIT_SMART_7688=y +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_FIT=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 484c338348..7993976443 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -9,6 +9,7 @@ CONFIG_BOARD_LINKIT_SMART_7688=y CONFIG_BOOT_ROM=y CONFIG_ONBOARD_DDR2_SIZE_1024MBIT=y CONFIG_ONBOARD_DDR2_CHIP_WIDTH_16BIT=y +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_FIT=y
SoCs of mtmips can use different CPU frequencies depending on the HW/SW configurations. For example mt7628 uses 580MHz clock if the input xtal frequency is 40MHz, and 575MHz clock if the xtal is 25MHz. Upon cold boot the CPU uses the xtal frequency directly.
So hardcoding the timer frequency (half of the CPU frequency) in CONFIG_SYS_MIPS_TIMER_FREQ is not a good idea for this case.
This patch adds a mtmips-specific field timer_freq to arch_global_data. This field will be used later in mtmips-specific get_tbclk() to provide accurate timer frequency in different boot stage.
arch/mips/include/asm/global_data.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/mips/include/asm/global_data.h b/arch/mips/include/asm/global_data.h index 7b4ad083ba..4c30fab871 100644 --- a/arch/mips/include/asm/global_data.h +++ b/arch/mips/include/asm/global_data.h @@ -27,6 +27,9 @@ struct arch_global_data { #ifdef CONFIG_MIPS_L2_CACHE unsigned short l2_line_size; #endif +#ifdef CONFIG_ARCH_MTMIPS + unsigned long timer_freq; +#endif };
#include <asm-generic/global_data.h>
The initial stack on some platforms is too small to hold a large malloc space. This patch adds a option to allow these platforms not reserving the malloc space on initial stack. These platforms should set the malloc base after DRAM is usable.
arch/mips/Kconfig | 18 ++++++++++++++++++ arch/mips/cpu/start.S | 6 ++++-- 2 files changed, 22 insertions(+), 2 deletions(-)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index bf30a56101..5f82caf8be 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -317,6 +317,24 @@ config NEW_EXCEPTION_VECTOR_BASE help The exception vector base to be restored before booting linux kernel
+config INIT_STACK_WITHOUT_MALLOC_F + bool "Do not reserve malloc space on initial stack" + default n + help + Enable this option if you don't want to reserve malloc space on + initial stack. This is useful if the initial stack can't hold large + malloc space. Platform should set the malloc_base later when DRAM is + ready to use. + +config SPL_INIT_STACK_WITHOUT_MALLOC_F + bool "Do not reserve malloc space on initial stack in SPL" + default n + help + Enable this option if you don't want to reserve malloc space on + initial stack. This is useful if the initial stack can't hold large + malloc space. Platform should set the malloc_base later when DRAM is + ready to use. + endmenu
menu "OS boot interface" diff --git a/arch/mips/cpu/start.S b/arch/mips/cpu/start.S index dd93df9e4a..6de9a2f362 100644 --- a/arch/mips/cpu/start.S +++ b/arch/mips/cpu/start.S @@ -59,7 +59,8 @@ sp, sp, GD_SIZE # reserve space for gd and sp, sp, t0 # force 16 byte alignment move k0, sp # save gd pointer -#if CONFIG_VAL(SYS_MALLOC_F_LEN) +#if CONFIG_VAL(SYS_MALLOC_F_LEN) && \ + !CONFIG_IS_ENABLED(INIT_STACK_WITHOUT_MALLOC_F) li t2, CONFIG_VAL(SYS_MALLOC_F_LEN) PTR_SUBU \ sp, sp, t2 # reserve space for early malloc @@ -75,7 +76,8 @@ blt t0, t1, 1b nop
-#if CONFIG_VAL(SYS_MALLOC_F_LEN) +#if CONFIG_VAL(SYS_MALLOC_F_LEN) && \ + !CONFIG_IS_ENABLED(INIT_STACK_WITHOUT_MALLOC_F) PTR_S sp, GD_MALLOC_BASE(k0) # gd->malloc_base offset #endif .endm
This patch rewrites the mtmips architecture with the following changes:
1. Move MT7628 soc parts into a subfolder. 2. Lock parts of D-Cache as temporary stack. 3. Reimplement DDR initialization in C language. 4. Reimplement DDR calibration in a clear logic. 5. Add full support for auto size detection for DDR1 and DDR2. 6. Use accurate CPU clock depending on the input xtal frequency for timer and delay functions.
Note:
print_cpuinfo() has incompatible parts with MT7620 so it's moved into mt7628 subfolder.
arch/mips/mach-mtmips/Kconfig | 69 +--- arch/mips/mach-mtmips/Makefile | 7 +- arch/mips/mach-mtmips/cpu.c | 58 +--- arch/mips/mach-mtmips/ddr_cal.c | 211 +++++++++++ arch/mips/mach-mtmips/ddr_calibrate.c | 309 ----------------- arch/mips/mach-mtmips/ddr_init.c | 194 +++++++++++ arch/mips/mach-mtmips/include/mach/ddr.h | 52 +++ arch/mips/mach-mtmips/include/mach/mc.h | 180 ++++++++++ arch/mips/mach-mtmips/lowlevel_init.S | 328 ------------------ arch/mips/mach-mtmips/mt7628/Makefile | 5 + arch/mips/mach-mtmips/mt7628/ddr.c | 173 +++++++++ arch/mips/mach-mtmips/mt7628/init.c | 109 ++++++ arch/mips/mach-mtmips/mt7628/lowlevel_init.S | 161 +++++++++ arch/mips/mach-mtmips/mt7628/mt7628.h | 104 ++++++ arch/mips/mach-mtmips/mt76xx.h | 32 -- .../gardena-smart-gateway-mt7688_defconfig | 2 - configs/linkit-smart-7688_defconfig | 2 - 17 files changed, 1201 insertions(+), 795 deletions(-) create mode 100644 arch/mips/mach-mtmips/ddr_cal.c delete mode 100644 arch/mips/mach-mtmips/ddr_calibrate.c create mode 100644 arch/mips/mach-mtmips/ddr_init.c create mode 100644 arch/mips/mach-mtmips/include/mach/ddr.h create mode 100644 arch/mips/mach-mtmips/include/mach/mc.h delete mode 100644 arch/mips/mach-mtmips/lowlevel_init.S create mode 100644 arch/mips/mach-mtmips/mt7628/Makefile create mode 100644 arch/mips/mach-mtmips/mt7628/ddr.c create mode 100644 arch/mips/mach-mtmips/mt7628/init.c create mode 100644 arch/mips/mach-mtmips/mt7628/lowlevel_init.S create mode 100644 arch/mips/mach-mtmips/mt7628/mt7628.h delete mode 100644 arch/mips/mach-mtmips/mt76xx.h
diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 8cb76c4560..3f25de8b85 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -19,12 +19,18 @@ config SYS_ICACHE_SIZE config SYS_ICACHE_LINE_SIZE default 32
+config SYS_TEXT_BASE + default 0x9c000000 + choice prompt "MediaTek MIPS SoC select"
config SOC_MT7628 bool "MT7628" select MIPS_L1_CACHE_SHIFT_5 + select MIPS_INIT_STACK_IN_SRAM + select MIPS_SRAM_INIT + select SYS_MIPS_CACHE_INIT_RAM_LOAD select PINCTRL_MT7628 select MTK_SERIAL select SYSRESET_RESETCTL @@ -79,69 +85,6 @@ config BOOT_ROM
endchoice
-choice - prompt "DDR2 size" - -config ONBOARD_DDR2_SIZE_256MBIT - bool "256MBit (32MByte) total size" - depends on BOOT_ROM - help - Use 256MBit (32MByte) of DDR total size - -config ONBOARD_DDR2_SIZE_512MBIT - bool "512MBit (64MByte) total size" - depends on BOOT_ROM - help - Use 512MBit (64MByte) of DDR total size - -config ONBOARD_DDR2_SIZE_1024MBIT - bool "1024MBit (128MByte) total size" - depends on BOOT_ROM - help - Use 1024MBit (128MByte) of DDR total size - -config ONBOARD_DDR2_SIZE_2048MBIT - bool "2048MBit (256MByte) total size" - depends on BOOT_ROM - help - Use 2048MBit (256MByte) of DDR total size - -endchoice - -choice - prompt "DDR2 chip width" - -config ONBOARD_DDR2_CHIP_WIDTH_8BIT - bool "8bit DDR chip width" - depends on BOOT_ROM - help - Use DDR chips with 8bit width - -config ONBOARD_DDR2_CHIP_WIDTH_16BIT - bool "16bit DDR chip width" - depends on BOOT_ROM - help - Use DDR chips with 16bit width - -endchoice - -choice - prompt "DDR2 bus width" - -config ONBOARD_DDR2_BUS_WIDTH_16BIT - bool "16bit DDR bus width" - depends on BOOT_ROM - help - Use 16bit DDR bus width - -config ONBOARD_DDR2_BUS_WIDTH_32BIT - bool "32bit DDR bus width" - depends on BOOT_ROM - help - Use 32bit DDR bus width - -endchoice - config SUPPORTS_BOOT_RAM bool
diff --git a/arch/mips/mach-mtmips/Makefile b/arch/mips/mach-mtmips/Makefile index 1f3e65e8a5..72f0369030 100644 --- a/arch/mips/mach-mtmips/Makefile +++ b/arch/mips/mach-mtmips/Makefile @@ -1,8 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+
obj-y += cpu.o +obj-y += ddr_init.o +obj-y += ddr_cal.o
-ifndef CONFIG_SKIP_LOWLEVEL_INIT -obj-y += ddr_calibrate.o -obj-y += lowlevel_init.o -endif +obj-$(CONFIG_SOC_MT7628) += mt7628/ diff --git a/arch/mips/mach-mtmips/cpu.c b/arch/mips/mach-mtmips/cpu.c index 8976ef57c7..459a9673eb 100644 --- a/arch/mips/mach-mtmips/cpu.c +++ b/arch/mips/mach-mtmips/cpu.c @@ -4,69 +4,17 @@ */
#include <common.h> -#include <dm.h> -#include <init.h> #include <malloc.h> -#include <ram.h> -#include <wdt.h> -#include <asm/io.h> #include <linux/io.h> #include <linux/sizes.h> -#include "mt76xx.h"
-#define STR_LEN 6 - -#ifdef CONFIG_BOOT_ROM -int mach_cpu_init(void) -{ - ddr_calibrate(); - - return 0; -} -#endif +DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { +#ifdef CONFIG_SKIP_LOWLEVEL_INIT gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, SZ_256M); - - return 0; -} - -int print_cpuinfo(void) -{ - static const char * const boot_str[] = { "PLL (3-Byte SPI Addr)", - "PLL (4-Byte SPI Addr)", - "XTAL (3-Byte SPI Addr)", - "XTAL (4-Byte SPI Addr)" }; - const void *blob = gd->fdt_blob; - void __iomem *sysc_base; - char buf[STR_LEN + 1]; - fdt_addr_t base; - fdt_size_t size; - char *str; - int node; - u32 val; - - /* Get system controller base address */ - node = fdt_node_offset_by_compatible(blob, -1, "ralink,mt7620a-sysc"); - if (node < 0) - return -FDT_ERR_NOTFOUND; - - base = fdtdec_get_addr_size_auto_noparent(blob, node, "reg", - 0, &size, true); - if (base == FDT_ADDR_T_NONE) - return -EINVAL; - - sysc_base = ioremap_nocache(base, size); - - str = (char *)sysc_base + MT76XX_CHIPID_OFFS; - snprintf(buf, STR_LEN + 1, "%s", str); - val = readl(sysc_base + MT76XX_CHIP_REV_ID_OFFS); - printf("CPU: %-*s Rev %ld.%ld - ", STR_LEN, buf, - (val & GENMASK(11, 8)) >> 8, val & GENMASK(3, 0)); - - val = (readl(sysc_base + MT76XX_SYSCFG0_OFFS) & GENMASK(3, 1)) >> 1; - printf("Boot from %s\n", boot_str[val]); +#endif
return 0; } diff --git a/arch/mips/mach-mtmips/ddr_cal.c b/arch/mips/mach-mtmips/ddr_cal.c new file mode 100644 index 0000000000..0ea7c7d5e1 --- /dev/null +++ b/arch/mips/mach-mtmips/ddr_cal.c @@ -0,0 +1,211 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <asm/addrspace.h> +#include <asm/cacheops.h> +#include <linux/bitops.h> +#include <linux/io.h> +#include <mach/mc.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define COARSE_MIN_START 6 +#define FINE_MIN_START 15 +#define COARSE_MAX_START 7 +#define FINE_MAX_START 0 + +#define NUM_OF_CACHELINE 128 +#define TEST_PAT_SIZE (NUM_OF_CACHELINE * CONFIG_SYS_CACHELINE_SIZE) + +#define INIT_DQS_VAL ((7 << DQS1_DELAY_COARSE_TUNING_S) | \ + (4 << DQS1_DELAY_FINE_TUNING_S) | \ + (7 << DQS0_DELAY_COARSE_TUNING_S) | \ + (4 << DQS0_DELAY_FINE_TUNING_S)) + +static inline void pref_op(int op, const volatile void *addr) +{ + __asm__ __volatile__("pref %0, 0(%1)" : : "i" (op), "r" (addr)); +} + +static inline int dqs_test_valid(void __iomem *memc, u32 memsize, u32 dqsval, + u32 bias) +{ + u32 *nca, *ca; + u32 off; + int i; + + for (off = 0; off < memsize - TEST_PAT_SIZE; off += (memsize >> 6)) { + nca = (u32 *)KSEG1ADDR(off); + ca = (u32 *)KSEG0ADDR(off); + + writel(INIT_DQS_VAL, memc + MEMCTL_DDR_DQS_DLY_REG); + wmb(); + + for (i = 0; i < TEST_PAT_SIZE / sizeof(u32); i++) + ca[i] = 0x1f1f1f1f; + + for (i = 0; i < TEST_PAT_SIZE / sizeof(u32); i++) + nca[i] = (u32)nca + i + bias; + + writel(dqsval, memc + MEMCTL_DDR_DQS_DLY_REG); + wmb(); + + for (i = 0; i < TEST_PAT_SIZE; i += CONFIG_SYS_CACHELINE_SIZE) + mips_cache(HIT_INVALIDATE_D, (u8 *)ca + i); + wmb(); + + for (i = 0; i < TEST_PAT_SIZE; i += CONFIG_SYS_CACHELINE_SIZE) + pref_op(0, (u8 *)ca + i); + + for (i = 0; i < TEST_PAT_SIZE / sizeof(u32); i++) { + if (ca[i] != (u32)nca + i + bias) + return -1; + } + } + + return 0; +} + +static inline u32 dqs_find_max(void __iomem *memc, u32 memsize, u32 initval, + u32 maxval, u32 shift, u32 regval) +{ + u32 fieldval = initval, dqsval; + + do { + dqsval = regval | (fieldval << shift); + + if (dqs_test_valid(memc, memsize, dqsval, 3)) + break; + + fieldval++; + } while (fieldval <= maxval); + + return fieldval; +} + +static inline u32 dqs_find_min(void __iomem *memc, u32 memsize, u32 initval, + u32 minval, u32 shift, u32 regval) +{ + u32 fieldval = initval, dqsval; + + while (fieldval > minval) { + dqsval = regval | (fieldval << shift); + + if (dqs_test_valid(memc, memsize, dqsval, 1)) { + fieldval++; + break; + } + + fieldval--; + } + + return fieldval; +} + +void ddr_calibrate(void __iomem *memc, u32 memsize, u32 bw) +{ + u32 dqs_coarse_min, dqs_coarse_max, dqs_coarse_val; + u32 dqs_fine_min, dqs_fine_max, dqs_fine_val; + u32 dqs_coarse_min_limit, dqs_fine_min_limit; + u32 dlls, dqs_dll, ddr_cfg2_reg; + u32 dqs_dly_tmp, dqs_dly, test_dqs, shift; + u32 rem, mask; + int i; + + /* Disable Self-refresh */ + clrbits_32(memc + MEMCTL_DDR_SELF_REFRESH_REG, SR_AUTO_EN); + + /* Save DDR_CFG2 and modify its DQS gating window */ + ddr_cfg2_reg = readl(memc + MEMCTL_DDR_CFG2_REG); + mask = DQS0_GATING_WINDOW_M; + if (bw == IND_SDRAM_WIDTH_16BIT) + mask |= DQS1_GATING_WINDOW_M; + clrbits_32(memc + MEMCTL_DDR_CFG2_REG, mask); + + /* Get minimum available DQS value */ + dlls = readl(memc + MEMCTL_DLL_DBG_REG); + dlls = (dlls & MST_DLY_SEL_M) >> MST_DLY_SEL_S; + + dqs_dll = dlls >> 4; + if (dqs_dll <= 8) + dqs_coarse_min_limit = 8 - dqs_dll; + else + dqs_coarse_min_limit = 0; + + dqs_dll = dlls & 0xf; + if (dqs_dll <= 8) + dqs_fine_min_limit = 8 - dqs_dll; + else + dqs_fine_min_limit = 0; + + /* Initial DQS register value */ + dqs_dly = INIT_DQS_VAL; + + /* Calibrate DQS0 and/or DQS1 */ + for (i = 0; i < bw; i++) { + shift = i * 8; + dqs_dly &= ~(0xff << shift); + + /* Find maximum DQS coarse-grain */ + dqs_dly_tmp = dqs_dly | (0xf << shift); + dqs_coarse_max = dqs_find_max(memc, memsize, COARSE_MAX_START, + 0xf, 4 + shift, dqs_dly_tmp); + + /* Find maximum DQS fine-grain */ + dqs_dly_tmp = dqs_dly | (dqs_coarse_max << (4 + shift)); + test_dqs = dqs_find_max(memc, memsize, FINE_MAX_START, 0xf, + shift, dqs_dly_tmp); + + if (test_dqs == FINE_MAX_START) { + dqs_coarse_max--; + dqs_fine_max = 0xf; + } else { + dqs_fine_max = test_dqs - 1; + } + + /* Find minimum DQS coarse-grain */ + dqs_dly_tmp = dqs_dly; + dqs_coarse_min = dqs_find_min(memc, memsize, COARSE_MIN_START, + dqs_coarse_min_limit, 4 + shift, + dqs_dly_tmp); + + /* Find minimum DQS fine-grain */ + dqs_dly_tmp = dqs_dly | (dqs_coarse_min << (4 + shift)); + test_dqs = dqs_find_min(memc, memsize, FINE_MIN_START, + dqs_fine_min_limit, shift, dqs_dly_tmp); + + if (test_dqs == FINE_MIN_START + 1) { + dqs_coarse_min++; + dqs_fine_min = 0; + } else { + dqs_fine_min = test_dqs; + } + + /* Calculate central DQS coarse/fine value */ + dqs_coarse_val = (dqs_coarse_max + dqs_coarse_min) >> 1; + rem = (dqs_coarse_max + dqs_coarse_min) % 2; + + dqs_fine_val = (rem * 4) + ((dqs_fine_max + dqs_fine_min) >> 1); + if (dqs_fine_val >= 0x10) { + dqs_coarse_val++; + dqs_fine_val -= 8; + } + + /* Save current DQS value */ + dqs_dly |= ((dqs_coarse_val << 4) | dqs_fine_val) << shift; + } + + /* Set final DQS value */ + writel(dqs_dly, memc + MEMCTL_DDR_DQS_DLY_REG); + + /* Restore DDR_CFG2 */ + writel(ddr_cfg2_reg, memc + MEMCTL_DDR_CFG2_REG); + + /* Enable Self-refresh */ + setbits_32(memc + MEMCTL_DDR_SELF_REFRESH_REG, SR_AUTO_EN); +} diff --git a/arch/mips/mach-mtmips/ddr_calibrate.c b/arch/mips/mach-mtmips/ddr_calibrate.c deleted file mode 100644 index 3cd440804d..0000000000 --- a/arch/mips/mach-mtmips/ddr_calibrate.c +++ /dev/null @@ -1,309 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2018 Stefan Roese sr@denx.de - * - * This code is mostly based on the code extracted from this MediaTek - * github repository: - * - * https://github.com/MediaTek-Labs/linkit-smart-uboot.git - * - * I was not able to find a specific license or other developers - * copyrights here, so I can't add them here. - * - * Most functions in this file are copied from the MediaTek U-Boot - * repository. Without any documentation, it was impossible to really - * implement this differently. So its mostly a cleaned-up version of - * the original code, with only support for the MT7628 / MT7688 SoC. - */ - -#include <common.h> -#include <cpu_func.h> -#include <linux/io.h> -#include <asm/cacheops.h> -#include <asm/io.h> -#include "mt76xx.h" - -#define NUM_OF_CACHELINE 128 -#define MIN_START 6 -#define MIN_FINE_START 0xf -#define MAX_START 7 -#define MAX_FINE_START 0x0 - -#define CPU_FRAC_DIV 1 - -#if defined(CONFIG_ONBOARD_DDR2_SIZE_256MBIT) -#define DRAM_BUTTOM 0x02000000 -#endif -#if defined(CONFIG_ONBOARD_DDR2_SIZE_512MBIT) -#define DRAM_BUTTOM 0x04000000 -#endif -#if defined(CONFIG_ONBOARD_DDR2_SIZE_1024MBIT) -#define DRAM_BUTTOM 0x08000000 -#endif -#if defined(CONFIG_ONBOARD_DDR2_SIZE_2048MBIT) -#define DRAM_BUTTOM 0x10000000 -#endif - -static inline void cal_memcpy(void *src, void *dst, u32 size) -{ - u8 *psrc = (u8 *)src; - u8 *pdst = (u8 *)dst; - int i; - - for (i = 0; i < size; i++, psrc++, pdst++) - *pdst = *psrc; -} - -static inline void cal_memset(void *src, u8 pat, u32 size) -{ - u8 *psrc = (u8 *)src; - int i; - - for (i = 0; i < size; i++, psrc++) - *psrc = pat; -} - -#define pref_op(hint, addr) \ - __asm__ __volatile__( \ - ".set push\n" \ - ".set noreorder\n" \ - "pref %0, %1\n" \ - ".set pop\n" \ - : \ - : "i" (hint), "R" (*(u8 *)(addr))) - -static inline void cal_patgen(u32 start_addr, u32 size, u32 bias) -{ - u32 *addr = (u32 *)start_addr; - int i; - - for (i = 0; i < size; i++) - addr[i] = start_addr + i + bias; -} - -static inline int test_loop(int k, int dqs, u32 test_dqs, u32 *coarse_dqs, - u32 offs, u32 pat, u32 val) -{ - u32 nc_addr; - u32 *c_addr; - int i; - - for (nc_addr = 0xa0000000; - nc_addr < (0xa0000000 + DRAM_BUTTOM - NUM_OF_CACHELINE * 32); - nc_addr += (DRAM_BUTTOM >> 6) + offs) { - writel(0x00007474, (void *)MT76XX_MEMCTRL_BASE + 0x64); - wmb(); /* Make sure store if finished */ - - c_addr = (u32 *)(nc_addr & 0xdfffffff); - cal_memset(((u8 *)c_addr), 0x1F, NUM_OF_CACHELINE * 32); - cal_patgen(nc_addr, NUM_OF_CACHELINE * 8, pat); - - if (dqs > 0) - writel(0x00000074 | - (((k == 1) ? coarse_dqs[dqs] : test_dqs) << 12) | - (((k == 0) ? val : test_dqs) << 8), - (void *)MT76XX_MEMCTRL_BASE + 0x64); - else - writel(0x00007400 | - (((k == 1) ? coarse_dqs[dqs] : test_dqs) << 4) | - (((k == 0) ? val : test_dqs) << 0), - (void *)MT76XX_MEMCTRL_BASE + 0x64); - wmb(); /* Make sure store if finished */ - - invalidate_dcache_range((u32)c_addr, - (u32)c_addr + - NUM_OF_CACHELINE * 32); - wmb(); /* Make sure store if finished */ - - for (i = 0; i < NUM_OF_CACHELINE * 8; i++) { - if (i % 8 == 0) - pref_op(0, &c_addr[i]); - } - - for (i = 0; i < NUM_OF_CACHELINE * 8; i++) { - if (c_addr[i] != nc_addr + i + pat) - return -1; - } - } - - return 0; -} - -void ddr_calibrate(void) -{ - u32 min_coarse_dqs[2]; - u32 max_coarse_dqs[2]; - u32 min_fine_dqs[2]; - u32 max_fine_dqs[2]; - u32 coarse_dqs[2]; - u32 fine_dqs[2]; - int reg = 0, ddr_cfg2_reg; - int flag; - int i, k; - int dqs = 0; - u32 min_coarse_dqs_bnd, min_fine_dqs_bnd, coarse_dqs_dll, fine_dqs_dll; - u32 val; - u32 fdiv = 0, frac = 0; - - /* Setup clock to run at full speed */ - val = readl((void *)MT76XX_DYN_CFG0_REG); - fdiv = (u32)((val >> 8) & 0x0F); - if (CPU_FRAC_DIV < 1 || CPU_FRAC_DIV > 10) - frac = val & 0x0f; - else - frac = CPU_FRAC_DIV; - - while (frac < fdiv) { - val = readl((void *)MT76XX_DYN_CFG0_REG); - fdiv = (val >> 8) & 0x0f; - fdiv--; - val &= ~(0x0f << 8); - val |= (fdiv << 8); - writel(val, (void *)MT76XX_DYN_CFG0_REG); - udelay(500); - val = readl((void *)MT76XX_DYN_CFG0_REG); - fdiv = (val >> 8) & 0x0f; - } - - clrbits_le32((void *)MT76XX_MEMCTRL_BASE + 0x10, BIT(4)); - ddr_cfg2_reg = readl((void *)MT76XX_MEMCTRL_BASE + 0x48); - clrbits_le32((void *)MT76XX_MEMCTRL_BASE + 0x48, - (0x3 << 28) | (0x3 << 26)); - - min_coarse_dqs[0] = MIN_START; - min_coarse_dqs[1] = MIN_START; - min_fine_dqs[0] = MIN_FINE_START; - min_fine_dqs[1] = MIN_FINE_START; - max_coarse_dqs[0] = MAX_START; - max_coarse_dqs[1] = MAX_START; - max_fine_dqs[0] = MAX_FINE_START; - max_fine_dqs[1] = MAX_FINE_START; - dqs = 0; - - /* Add by KP, DQS MIN boundary */ - reg = readl((void *)MT76XX_MEMCTRL_BASE + 0x20); - coarse_dqs_dll = (reg & 0xf00) >> 8; - fine_dqs_dll = (reg & 0xf0) >> 4; - if (coarse_dqs_dll <= 8) - min_coarse_dqs_bnd = 8 - coarse_dqs_dll; - else - min_coarse_dqs_bnd = 0; - - if (fine_dqs_dll <= 8) - min_fine_dqs_bnd = 8 - fine_dqs_dll; - else - min_fine_dqs_bnd = 0; - /* DQS MIN boundary */ - -DQS_CAL: - - for (k = 0; k < 2; k++) { - u32 test_dqs; - - if (k == 0) - test_dqs = MAX_START; - else - test_dqs = MAX_FINE_START; - - do { - flag = test_loop(k, dqs, test_dqs, max_coarse_dqs, - 0x400, 0x3, 0xf); - if (flag == -1) - break; - - test_dqs++; - } while (test_dqs <= 0xf); - - if (k == 0) { - max_coarse_dqs[dqs] = test_dqs; - } else { - test_dqs--; - - if (test_dqs == MAX_FINE_START - 1) { - max_coarse_dqs[dqs]--; - max_fine_dqs[dqs] = 0xf; - } else { - max_fine_dqs[dqs] = test_dqs; - } - } - } - - for (k = 0; k < 2; k++) { - u32 test_dqs; - - if (k == 0) - test_dqs = MIN_START; - else - test_dqs = MIN_FINE_START; - - do { - flag = test_loop(k, dqs, test_dqs, min_coarse_dqs, - 0x480, 0x1, 0x0); - if (k == 0) { - if (flag == -1 || - test_dqs == min_coarse_dqs_bnd) - break; - - test_dqs--; - - if (test_dqs < min_coarse_dqs_bnd) - break; - } else { - if (flag == -1) { - test_dqs++; - break; - } else if (test_dqs == min_fine_dqs_bnd) { - break; - } - - test_dqs--; - - if (test_dqs < min_fine_dqs_bnd) - break; - } - } while (test_dqs >= 0); - - if (k == 0) { - min_coarse_dqs[dqs] = test_dqs; - } else { - if (test_dqs == MIN_FINE_START + 1) { - min_coarse_dqs[dqs]++; - min_fine_dqs[dqs] = 0x0; - } else { - min_fine_dqs[dqs] = test_dqs; - } - } - } - - if (dqs == 0) { - dqs = 1; - goto DQS_CAL; - } - - for (i = 0; i < 2; i++) { - u32 temp; - - coarse_dqs[i] = (max_coarse_dqs[i] + min_coarse_dqs[i]) >> 1; - temp = - (((max_coarse_dqs[i] + min_coarse_dqs[i]) % 2) * 4) + - ((max_fine_dqs[i] + min_fine_dqs[i]) >> 1); - if (temp >= 0x10) { - coarse_dqs[i]++; - fine_dqs[i] = (temp - 0x10) + 0x8; - } else { - fine_dqs[i] = temp; - } - } - reg = (coarse_dqs[1] << 12) | (fine_dqs[1] << 8) | - (coarse_dqs[0] << 4) | fine_dqs[0]; - - clrbits_le32((void *)MT76XX_MEMCTRL_BASE + 0x10, BIT(4)); - writel(reg, (void *)MT76XX_MEMCTRL_BASE + 0x64); - writel(ddr_cfg2_reg, (void *)MT76XX_MEMCTRL_BASE + 0x48); - setbits_le32((void *)MT76XX_MEMCTRL_BASE + 0x10, BIT(4)); - - for (i = 0; i < 2; i++) - debug("[%02X%02X%02X%02X]", min_coarse_dqs[i], - min_fine_dqs[i], max_coarse_dqs[i], max_fine_dqs[i]); - debug("\nDDR Calibration DQS reg = %08X\n", reg); -} diff --git a/arch/mips/mach-mtmips/ddr_init.c b/arch/mips/mach-mtmips/ddr_init.c new file mode 100644 index 0000000000..cd355cc840 --- /dev/null +++ b/arch/mips/mach-mtmips/ddr_init.c @@ -0,0 +1,194 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <linux/bitops.h> +#include <linux/io.h> +#include <linux/sizes.h> +#include <mach/ddr.h> +#include <mach/mc.h> + +#define DDR_BW_TEST_PAT 0xaa5555aa + +static const u32 dram_size[] = { + [DRAM_8MB] = SZ_8M, + [DRAM_16MB] = SZ_16M, + [DRAM_32MB] = SZ_32M, + [DRAM_64MB] = SZ_64M, + [DRAM_128MB] = SZ_128M, + [DRAM_256MB] = SZ_256M, +}; + +static void dram_test_write(u32 addr, u32 val) +{ + volatile ulong *target = (volatile ulong *)(KSEG1 + addr); + + sync(); + *target = val; + sync(); +} + +static u32 dram_test_read(u32 addr) +{ + volatile ulong *target = (volatile ulong *)(KSEG1 + addr); + u32 val; + + sync(); + val = *target; + sync(); + + return val; +} + +static int dram_addr_test_bit(u32 bit) +{ + u32 val; + + dram_test_write(0, 0); + dram_test_write(BIT(bit), DDR_BW_TEST_PAT); + val = dram_test_read(0); + + if (val == DDR_BW_TEST_PAT) + return 1; + + return 0; +} + +static void mc_ddr_init(void __iomem *memc, const struct mc_ddr_cfg *cfg, + u32 dq_dly, u32 dqs_dly, mc_reset_t mc_reset, u32 bw) +{ + u32 val; + + mc_reset(1); + __udelay(200); + mc_reset(0); + + clrbits_32(memc + MEMCTL_SDRAM_CFG1_REG, RBC_MAPPING); + + writel(cfg->cfg2, memc + MEMCTL_DDR_CFG2_REG); + writel(cfg->cfg3, memc + MEMCTL_DDR_CFG3_REG); + writel(cfg->cfg4, memc + MEMCTL_DDR_CFG4_REG); + writel(dq_dly, memc + MEMCTL_DDR_DQ_DLY_REG); + writel(dqs_dly, memc + MEMCTL_DDR_DQS_DLY_REG); + + writel(cfg->cfg0, memc + MEMCTL_DDR_CFG0_REG); + + val = cfg->cfg1; + if (bw) { + val &= ~IND_SDRAM_WIDTH_M; + val |= (bw << IND_SDRAM_WIDTH_S) & IND_SDRAM_WIDTH_M; + } + + writel(val, memc + MEMCTL_DDR_CFG1_REG); + + clrsetbits_32(memc + MEMCTL_PWR_SAVE_CNT_REG, SR_TAR_CNT_M, + 1 << SR_TAR_CNT_S); + + setbits_32(memc + MEMCTL_DDR_SELF_REFRESH_REG, SR_AUTO_EN); +} + +void ddr1_init(struct mc_ddr_init_param *param) +{ + enum mc_dram_size sz; + u32 bw = 0; + + /* First initialization, determine bus width */ + mc_ddr_init(param->memc, ¶m->cfgs[DRAM_8MB], param->dq_dly, + param->dqs_dly, param->mc_reset, IND_SDRAM_WIDTH_16BIT); + + /* Test bus width */ + dram_test_write(0, DDR_BW_TEST_PAT); + if (dram_test_read(0) == DDR_BW_TEST_PAT) + bw = IND_SDRAM_WIDTH_16BIT; + else + bw = IND_SDRAM_WIDTH_8BIT; + + /* Second initialization, determine DDR capacity */ + mc_ddr_init(param->memc, ¶m->cfgs[DRAM_128MB], param->dq_dly, + param->dqs_dly, param->mc_reset, bw); + + if (dram_addr_test_bit(9)) { + sz = DRAM_8MB; + } else { + if (dram_addr_test_bit(10)) { + if (dram_addr_test_bit(23)) + sz = DRAM_16MB; + else + sz = DRAM_32MB; + } else { + if (dram_addr_test_bit(24)) + sz = DRAM_64MB; + else + sz = DRAM_128MB; + } + } + + /* Final initialization, with DDR calibration */ + mc_ddr_init(param->memc, ¶m->cfgs[sz], param->dq_dly, + param->dqs_dly, param->mc_reset, bw); + + /* Return actual DDR configuration */ + param->memsize = dram_size[sz]; + param->bus_width = bw; +} + +void ddr2_init(struct mc_ddr_init_param *param) +{ + enum mc_dram_size sz; + u32 bw = 0; + + /* First initialization, determine bus width */ + mc_ddr_init(param->memc, ¶m->cfgs[DRAM_32MB], param->dq_dly, + param->dqs_dly, param->mc_reset, IND_SDRAM_WIDTH_16BIT); + + /* Test bus width */ + dram_test_write(0, DDR_BW_TEST_PAT); + if (dram_test_read(0) == DDR_BW_TEST_PAT) + bw = IND_SDRAM_WIDTH_16BIT; + else + bw = IND_SDRAM_WIDTH_8BIT; + + /* Second initialization, determine DDR capacity */ + mc_ddr_init(param->memc, ¶m->cfgs[DRAM_256MB], param->dq_dly, + param->dqs_dly, param->mc_reset, bw); + + if (bw == IND_SDRAM_WIDTH_16BIT) { + if (dram_addr_test_bit(10)) { + sz = DRAM_32MB; + } else { + if (dram_addr_test_bit(24)) { + if (dram_addr_test_bit(27)) + sz = DRAM_64MB; + else + sz = DRAM_128MB; + } else { + sz = DRAM_256MB; + } + } + } else { + if (dram_addr_test_bit(23)) { + sz = DRAM_32MB; + } else { + if (dram_addr_test_bit(24)) { + if (dram_addr_test_bit(27)) + sz = DRAM_64MB; + else + sz = DRAM_128MB; + } else { + sz = DRAM_256MB; + } + } + } + + /* Final initialization, with DDR calibration */ + mc_ddr_init(param->memc, ¶m->cfgs[sz], param->dq_dly, + param->dqs_dly, param->mc_reset, bw); + + /* Return actual DDR configuration */ + param->memsize = dram_size[sz]; + param->bus_width = bw; +} diff --git a/arch/mips/mach-mtmips/include/mach/ddr.h b/arch/mips/mach-mtmips/include/mach/ddr.h new file mode 100644 index 0000000000..f92198137b --- /dev/null +++ b/arch/mips/mach-mtmips/include/mach/ddr.h @@ -0,0 +1,52 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _MTMIPS_DDR_H_ +#define _MTMIPS_DDR_H_ + +#include <linux/io.h> +#include <linux/types.h> + +enum mc_dram_size { + DRAM_8MB, + DRAM_16MB, + DRAM_32MB, + DRAM_64MB, + DRAM_128MB, + DRAM_256MB, + + __DRAM_SZ_MAX +}; + +struct mc_ddr_cfg { + u32 cfg0; + u32 cfg1; + u32 cfg2; + u32 cfg3; + u32 cfg4; +}; + +typedef void (*mc_reset_t)(int assert); + +struct mc_ddr_init_param { + void __iomem *memc; + + u32 dq_dly; + u32 dqs_dly; + + const struct mc_ddr_cfg *cfgs; + mc_reset_t mc_reset; + + u32 memsize; + u32 bus_width; +}; + +void ddr1_init(struct mc_ddr_init_param *param); +void ddr2_init(struct mc_ddr_init_param *param); +void ddr_calibrate(void __iomem *memc, u32 memsize, u32 bw); + +#endif /* _MTMIPS_DDR_H_ */ diff --git a/arch/mips/mach-mtmips/include/mach/mc.h b/arch/mips/mach-mtmips/include/mach/mc.h new file mode 100644 index 0000000000..d7d623a63b --- /dev/null +++ b/arch/mips/mach-mtmips/include/mach/mc.h @@ -0,0 +1,180 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _MTMIPS_MC_H_ +#define _MTMIPS_MC_H_ + +#define MEMCTL_SDRAM_CFG0_REG 0x00 +#define DIS_CLK_GT 0x80000000 +#define CLK_SLEW_S 29 +#define CLK_SLEW_M 0x60000000 +#define TWR 0x10000000 +#define TMRD_S 24 +#define TMRD_M 0xf000000 +#define TRFC_S 20 +#define TRFC_M 0xf00000 +#define TCAS_S 16 +#define TCAS_M 0x30000 +#define TRAS_S 12 +#define TRAS_M 0xf000 +#define TRCD_S 8 +#define TRCD_M 0x300 +#define TRC_S 4 +#define TRC_M 0xf0 +#define TRP_S 0 +#define TRP_M 0x03 + +#define MEMCTL_SDRAM_CFG1_REG 0x04 +#define SDRAM_INIT_START 0x80000000 +#define SDRAM_INIT_DONE 0x40000000 +#define RBC_MAPPING 0x20000000 +#define PWR_DOWN_EN 0x10000000 +#define PWR_DOWN_MODE 0x8000000 +#define SDRAM_WIDTH 0x1000000 +#define NUMCOLS_S 20 +#define NUMCOLS_M 0x300000 +#define NUMROWS_S 16 +#define NUMROWS_M 0x30000 +#define TREFR_S 0 +#define TREFR_M 0xffff + +#define MEMCTL_DDR_SELF_REFRESH_REG 0x10 +#define ODT_SRC_SEL_S 24 +#define ODT_SRC_SEL_M 0xf000000 +#define ODT_OFF_DLY_S 20 +#define ODT_OFF_DLY_M 0xf00000 +#define ODT_ON_DLY_S 16 +#define ODT_ON_DLY_M 0xf0000 +#define SR_AUTO_EN 0x10 +#define SRACK_B 0x02 +#define SRREQ_B 0x01 + +#define MEMCTL_PWR_SAVE_CNT_REG 0x14 +#define PD_CNT_S 24 +#define PD_CNT_M 0xff000000 +#define SR_TAR_CNT_S 0 +#define SR_TAR_CNT_M 0xffffff + +#define MEMCTL_DLL_DBG_REG 0x20 +#define TDC_STABLE_S 12 +#define TDC_STABLE_M 0x3f000 +#define MST_DLY_SEL_S 4 +#define MST_DLY_SEL_M 0xff0 +#define CURR_STATE_S 1 +#define CURR_STATE_M 0x06 +#define ADLL_LOCK_DONE 0x01 + +#define MEMCTL_DDR_CFG0_REG 0x40 +#define T_RRD_S 28 +#define T_RRD_M 0xf0000000 +#define T_RAS_S 23 +#define T_RAS_M 0xf800000 +#define T_RP_S 19 +#define T_RP_M 0x780000 +#define T_RFC_S 13 +#define T_RFC_M 0x7e000 +#define T_REFI_S 0 +#define T_REFI_M 0x1fff + +#define MEMCTL_DDR_CFG1_REG 0x44 +#define T_WTR_S 28 +#define T_WTR_M 0xf0000000 +#define T_RTP_S 24 +#define T_RTP_M 0xf000000 +#define USER_DATA_WIDTH 0x200000 +#define IND_SDRAM_SIZE_S 18 +#define IND_SDRAM_SIZE_M 0x1c0000 +#define IND_SDRAM_SIZE_8MB 1 +#define IND_SDRAM_SIZE_16MB 2 +#define IND_SDRAM_SIZE_32MB 3 +#define IND_SDRAM_SIZE_64MB 4 +#define IND_SDRAM_SIZE_128MB 5 +#define IND_SDRAM_SIZE_256MB 6 +#define IND_SDRAM_WIDTH_S 16 +#define IND_SDRAM_WIDTH_M 0x30000 +#define IND_SDRAM_WIDTH_8BIT 1 +#define IND_SDRAM_WIDTH_16BIT 2 +#define EXT_BANK_S 14 +#define EXT_BANK_M 0xc000 +#define TOTAL_SDRAM_WIDTH_S 12 +#define TOTAL_SDRAM_WIDTH_M 0x3000 +#define T_WR_S 8 +#define T_WR_M 0xf00 +#define T_MRD_S 4 +#define T_MRD_M 0xf0 +#define T_RCD_S 0 +#define T_RCD_M 0x0f + +#define MEMCTL_DDR_CFG2_REG 0x48 +#define REGE 0x80000000 +#define DDR2_MODE 0x40000000 +#define DQS0_GATING_WINDOW_S 28 +#define DQS0_GATING_WINDOW_M 0x30000000 +#define DQS1_GATING_WINDOW_S 26 +#define DQS1_GATING_WINDOW_M 0xc000000 +#define PD 0x1000 +#define WR_S 9 +#define WR_M 0xe00 +#define DLLRESET 0x100 +#define TESTMODE 0x80 +#define CAS_LATENCY_S 4 +#define CAS_LATENCY_M 0x70 +#define BURST_TYPE 0x08 +#define BURST_LENGTH_S 0 +#define BURST_LENGTH_M 0x07 + +#define MEMCTL_DDR_CFG3_REG 0x4c +#define Q_OFF 0x1000 +#define RDOS 0x800 +#define DIS_DIFF_DQS 0x400 +#define OCD_S 7 +#define OCD_M 0x380 +#define RTT1 0x40 +#define ADDITIVE_LATENCY_S 3 +#define ADDITIVE_LATENCY_M 0x38 +#define RTT0 0x04 +#define DS 0x02 +#define DLL 0x01 + +#define MEMCTL_DDR_CFG4_REG 0x50 +#define FAW_S 0 +#define FAW_M 0x0f + +#define MEMCTL_DDR_DQ_DLY_REG 0x60 +#define DQ1_DELAY_SEL_S 24 +#define DQ1_DELAY_SEL_M 0xff000000 +#define DQ0_DELAY_SEL_S 16 +#define DQ0_DELAY_SEL_M 0xff0000 +#define DQ1_DELAY_COARSE_TUNING_S 12 +#define DQ1_DELAY_COARSE_TUNING_M 0xf000 +#define DQ1_DELAY_FINE_TUNING_S 8 +#define DQ1_DELAY_FINE_TUNING_M 0xf00 +#define DQ0_DELAY_COARSE_TUNING_S 4 +#define DQ0_DELAY_COARSE_TUNING_M 0xf0 +#define DQ0_DELAY_FINE_TUNING_S 0 +#define DQ0_DELAY_FINE_TUNING_M 0x0f + +#define MEMCTL_DDR_DQS_DLY_REG 0x64 +#define DQS1_DELAY_SEL_S 24 +#define DQS1_DELAY_SEL_M 0xff000000 +#define DQS0_DELAY_SEL_S 16 +#define DQS0_DELAY_SEL_M 0xff0000 +#define DQS1_DELAY_COARSE_TUNING_S 12 +#define DQS1_DELAY_COARSE_TUNING_M 0xf000 +#define DQS1_DELAY_FINE_TUNING_S 8 +#define DQS1_DELAY_FINE_TUNING_M 0xf00 +#define DQS0_DELAY_COARSE_TUNING_S 4 +#define DQS0_DELAY_COARSE_TUNING_M 0xf0 +#define DQS0_DELAY_FINE_TUNING_S 0 +#define DQS0_DELAY_FINE_TUNING_M 0x0f + +#define MEMCTL_DDR_DLL_SLV_REG 0x68 +#define DLL_SLV_UPDATE_MODE 0x100 +#define DQS_DLY_SEL_EN 0x80 +#define DQ_DLY_SEL_EN 0x01 + +#endif /* _MTMIPS_MC_H_ */ diff --git a/arch/mips/mach-mtmips/lowlevel_init.S b/arch/mips/mach-mtmips/lowlevel_init.S deleted file mode 100644 index aa707e0de6..0000000000 --- a/arch/mips/mach-mtmips/lowlevel_init.S +++ /dev/null @@ -1,328 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (c) 2018 Stefan Roese sr@denx.de - * - * This code is mostly based on the code extracted from this MediaTek - * github repository: - * - * https://github.com/MediaTek-Labs/linkit-smart-uboot.git - * - * I was not able to find a specific license or other developers - * copyrights here, so I can't add them here. - */ - -#include <config.h> -#include <asm/regdef.h> -#include <asm/mipsregs.h> -#include <asm/addrspace.h> -#include <asm/asm.h> -#include "mt76xx.h" - -#ifndef BIT -#define BIT(nr) (1 << (nr)) -#endif - -#define DELAY_USEC(us) ((us) / 100) - -#define DDR_CFG1_CHIP_WIDTH_MASK (0x3 << 16) -#define DDR_CFG1_BUS_WIDTH_MASK (0x3 << 12) - -#if defined(CONFIG_ONBOARD_DDR2_SIZE_256MBIT) -#define DDR_CFG1_SIZE_VAL 0x222e2323 -#define DDR_CFG4_SIZE_VAL 7 -#endif -#if defined(CONFIG_ONBOARD_DDR2_SIZE_512MBIT) -#define DDR_CFG1_SIZE_VAL 0x22322323 -#define DDR_CFG4_SIZE_VAL 9 -#endif -#if defined(CONFIG_ONBOARD_DDR2_SIZE_1024MBIT) -#define DDR_CFG1_SIZE_VAL 0x22362323 -#define DDR_CFG4_SIZE_VAL 9 -#endif -#if defined(CONFIG_ONBOARD_DDR2_SIZE_2048MBIT) -#define DDR_CFG1_SIZE_VAL 0x223a2323 -#define DDR_CFG4_SIZE_VAL 9 -#endif - -#if defined(CONFIG_ONBOARD_DDR2_CHIP_WIDTH_8BIT) -#define DDR_CFG1_CHIP_WIDTH_VAL (0x1 << 16) -#endif -#if defined(CONFIG_ONBOARD_DDR2_CHIP_WIDTH_16BIT) -#define DDR_CFG1_CHIP_WIDTH_VAL (0x2 << 16) -#endif - -#if defined(CONFIG_ONBOARD_DDR2_BUS_WIDTH_16BIT) -#define DDR_CFG1_BUS_WIDTH_VAL (0x2 << 12) -#endif -#if defined(CONFIG_ONBOARD_DDR2_BUS_WIDTH_32BIT) -#define DDR_CFG1_BUS_WIDTH_VAL (0x3 << 12) -#endif - - .set noreorder - -LEAF(lowlevel_init) - - /* Load base addresses as physical addresses for later usage */ - li s0, CKSEG1ADDR(MT76XX_SYSCTL_BASE) - li s1, CKSEG1ADDR(MT76XX_MEMCTRL_BASE) - li s2, CKSEG1ADDR(MT76XX_RGCTRL_BASE) - - /* polling CPLL is ready */ - li t1, DELAY_USEC(1000000) - la t5, MT76XX_ROM_STATUS_REG -1: - lw t2, 0(t5) - andi t2, t2, 0x1 - bnez t2, CPLL_READY - subu t1, t1, 1 - bgtz t1, 1b - nop - la t0, MT76XX_CLKCFG0_REG - lw t3, 0(t0) - ori t3, t3, 0x1 - sw t3, 0(t0) - b CPLL_DONE - nop -CPLL_READY: - la t0, MT76XX_CLKCFG0_REG - lw t1, 0(t0) - li t2, ~0x0c - and t1, t1, t2 - ori t1, t1, 0xc - sw t1, 0(t0) - la t0, MT76XX_DYN_CFG0_REG - lw t3, 0(t0) - li t5, ~((0x0f << 8) | (0x0f << 0)) - and t3, t3, t5 - li t5, (10 << 8) | (1 << 0) - or t3, t3, t5 - sw t3, 0(t0) - la t0, MT76XX_CLKCFG0_REG - lw t3, 0(t0) - li t4, ~0x0F - and t3, t3, t4 - ori t3, t3, 0xc - sw t3, 0(t0) - lw t3, 0(t0) - ori t3, t3, 0x08 - sw t3, 0(t0) - -CPLL_DONE: - /* Reset MC */ - lw t2, 0x34(s0) - ori t2, BIT(10) - sw t2, 0x34(s0) - nop - - /* - * SDR and DDR initialization: delay 200us - */ - li t0, DELAY_USEC(200 + 40) - li t1, 0x1 -1: - sub t0, t0, t1 - bnez t0, 1b - nop - - /* set DRAM IO PAD for MT7628IC */ - /* DDR LDO Enable */ - lw t4, 0x100(s2) - li t2, BIT(31) - or t4, t4, t2 - sw t4, 0x100(s2) - lw t4, 0x10c(s2) - j LDO_1P8V - nop -LDO_1P8V: - li t2, ~BIT(6) - and t4, t4, t2 - sw t4, 0x10c(s2) - j DDRLDO_SOFT_START -LDO_2P5V: - /* suppose external DDR1 LDO 2.5V */ - li t2, BIT(6) - or t4, t4, t2 - sw t4, 0x10c(s2) - -DDRLDO_SOFT_START: - lw t2, 0x10c(s2) - li t3, BIT(16) - or t2, t2, t3 - sw t2, 0x10c(s2) - li t3, DELAY_USEC(250*50) -LDO_DELAY: - subu t3, t3, 1 - bnez t3, LDO_DELAY - nop - - lw t2, 0x10c(s2) - li t3, BIT(18) - or t2, t2, t3 - sw t2, 0x10c(s2) - -SET_RG_BUCK_FPWM: - lw t2, 0x104(s2) - ori t2, t2, BIT(10) - sw t2, 0x104(s2) - -DDR_PAD_CFG: - /* clean CLK PAD */ - lw t2, 0x704(s2) - li t8, 0xfffff0f0 - and t2, t2, t8 - /* clean CMD PAD */ - lw t3, 0x70c(s2) - li t8, 0xfffff0f0 - and t3, t3, t8 - /* clean DQ IPAD */ - lw t4, 0x710(s2) - li t8, 0xfffff8ff - and t4, t4, t8 - /* clean DQ OPAD */ - lw t5, 0x714(s2) - li t8, 0xfffff0f0 - and t5, t5, t8 - /* clean DQS IPAD */ - lw t6, 0x718(s2) - li t8, 0xfffff8ff - and t6, t6, t8 - /* clean DQS OPAD */ - lw t7, 0x71c(s2) - li t8, 0xfffff0f0 - and t7, t7, t8 - - lw t9, 0xc(s0) - srl t9, t9, 16 - andi t9, t9, 0x1 - bnez t9, MT7628_AN_DDR1_PAD -MT7628_KN_PAD: - li t8, 0x00000303 - or t2, t2, t8 - or t3, t3, t8 - or t5, t5, t8 - or t7, t7, t8 - li t8, 0x00000000 - or t4, t4, t8 - or t6, t6, t8 - j SET_PAD_CFG -MT7628_AN_DDR1_PAD: - lw t1, 0x10(s0) - andi t1, t1, 0x1 - beqz t1, MT7628_AN_DDR2_PAD - li t8, 0x00000c0c - or t2, t2, t8 - li t8, 0x00000202 - or t3, t3, t8 - li t8, 0x00000707 - or t5, t5, t8 - li t8, 0x00000c0c - or t7, t7, t8 - li t8, 0x00000000 - or t4, t4, t8 - or t6, t6, t8 - j SET_PAD_CFG -MT7628_AN_DDR2_PAD: - li t8, 0x00000c0c - or t2, t2, t8 - li t8, 0x00000202 - or t3, t3, t8 - li t8, 0x00000404 - or t5, t5, t8 - li t8, 0x00000c0c - or t7, t7, t8 - li t8, 0x00000000 /* ODT off */ - or t4, t4, t8 - or t6, t6, t8 - -SET_PAD_CFG: - sw t2, 0x704(s2) - sw t3, 0x70c(s2) - sw t4, 0x710(s2) - sw t5, 0x714(s2) - sw t6, 0x718(s2) - sw t7, 0x71c(s2) - - /* - * DDR initialization: reset pin to 0 - */ - lw t2, 0x34(s0) - and t2, ~BIT(10) - sw t2, 0x34(s0) - nop - - /* - * DDR initialization: wait til reg DDR_CFG1 bit 21 equal to 1 (ready) - */ -DDR_READY: - li t1, DDR_CFG1_REG - lw t0, 0(t1) - nop - and t2, t0, BIT(21) - beqz t2, DDR_READY - nop - - /* - * DDR initialization - * - * Only DDR2 supported right now. DDR2 support can be added, once - * boards using it will get added to mainline U-Boot. - */ - li t1, DDR_CFG2_REG - lw t0, 0(t1) - nop - and t0, ~BIT(30) - and t0, ~(7 << 4) - or t0, (4 << 4) - or t0, BIT(30) - or t0, BIT(11) - sw t0, 0(t1) - nop - - li t1, DDR_CFG3_REG - lw t2, 0(t1) - /* Disable ODT; reference board ok, ev board fail */ - and t2, ~BIT(6) - or t2, BIT(2) - li t0, DDR_CFG4_REG - lw t1, 0(t0) - li t2, ~(0x01f | 0x0f0) - and t1, t1, t2 - ori t1, t1, DDR_CFG4_SIZE_VAL - sw t1, 0(t0) - nop - - /* - * DDR initialization: config size and width on reg DDR_CFG1 - */ - li t6, DDR_CFG1_SIZE_VAL - - and t6, ~DDR_CFG1_CHIP_WIDTH_MASK - or t6, DDR_CFG1_CHIP_WIDTH_VAL - - /* CONFIG DDR_CFG1[13:12] about TOTAL WIDTH */ - and t6, ~DDR_CFG1_BUS_WIDTH_MASK - or t6, DDR_CFG1_BUS_WIDTH_VAL - - li t5, DDR_CFG1_REG - sw t6, 0(t5) - nop - - /* - * DDR: enable self auto refresh for power saving - * enable it by default for both RAM and ROM version (for CoC) - */ - lw t1, 0x14(s1) - nop - and t1, 0xff000000 - or t1, 0x01 - sw t1, 0x14(s1) - nop - lw t1, 0x10(s1) - nop - or t1, 0x10 - sw t1, 0x10(s1) - nop - - jr ra - nop - END(lowlevel_init) diff --git a/arch/mips/mach-mtmips/mt7628/Makefile b/arch/mips/mach-mtmips/mt7628/Makefile new file mode 100644 index 0000000000..db62e90d77 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7628/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += lowlevel_init.o +obj-y += init.o +obj-y += ddr.o diff --git a/arch/mips/mach-mtmips/mt7628/ddr.c b/arch/mips/mach-mtmips/mt7628/ddr.c new file mode 100644 index 0000000000..06c0ca6854 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7628/ddr.c @@ -0,0 +1,173 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <asm/addrspace.h> +#include <linux/bitops.h> +#include <linux/sizes.h> +#include <linux/io.h> +#include <mach/ddr.h> +#include <mach/mc.h> +#include "mt7628.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* DDR2 DQ_DLY */ +#define DDR2_DQ_DLY \ + ((0x8 << DQ1_DELAY_COARSE_TUNING_S) | \ + (0x2 << DQ1_DELAY_FINE_TUNING_S) | \ + (0x8 << DQ0_DELAY_COARSE_TUNING_S) | \ + (0x2 << DQ0_DELAY_FINE_TUNING_S)) + +/* DDR2 DQS_DLY */ +#define DDR2_DQS_DLY \ + ((0x8 << DQS1_DELAY_COARSE_TUNING_S) | \ + (0x3 << DQS1_DELAY_FINE_TUNING_S) | \ + (0x8 << DQS0_DELAY_COARSE_TUNING_S) | \ + (0x3 << DQS0_DELAY_FINE_TUNING_S)) + +const struct mc_ddr_cfg ddr1_cfgs_200mhz[] = { + [DRAM_8MB] = { 0x34A1EB94, 0x20262324, 0x28000033, 0x00000002, 0x00000000 }, + [DRAM_16MB] = { 0x34A1EB94, 0x202A2324, 0x28000033, 0x00000002, 0x00000000 }, + [DRAM_32MB] = { 0x34A1E5CA, 0x202E2324, 0x28000033, 0x00000002, 0x00000000 }, + [DRAM_64MB] = { 0x3421E5CA, 0x20322324, 0x28000033, 0x00000002, 0x00000000 }, + [DRAM_128MB] = { 0x241B05CA, 0x20362334, 0x28000033, 0x00000002, 0x00000000 }, +}; + +const struct mc_ddr_cfg ddr1_cfgs_160mhz[] = { + [DRAM_8MB] = { 0x239964A1, 0x20262323, 0x00000033, 0x00000002, 0x00000000 }, + [DRAM_16MB] = { 0x239964A1, 0x202A2323, 0x00000033, 0x00000002, 0x00000000 }, + [DRAM_32MB] = { 0x239964A1, 0x202E2323, 0x00000033, 0x00000002, 0x00000000 }, + [DRAM_64MB] = { 0x239984A1, 0x20322323, 0x00000033, 0x00000002, 0x00000000 }, + [DRAM_128MB] = { 0x239AB4A1, 0x20362333, 0x00000033, 0x00000002, 0x00000000 }, +}; + +const struct mc_ddr_cfg ddr2_cfgs_200mhz[] = { + [DRAM_32MB] = { 0x2519E2E5, 0x222E2323, 0x68000C43, 0x00000452, 0x0000000A }, + [DRAM_64MB] = { 0x249AA2E5, 0x22322323, 0x68000C43, 0x00000452, 0x0000000A }, + [DRAM_128MB] = { 0x249B42E5, 0x22362323, 0x68000C43, 0x00000452, 0x0000000A }, + [DRAM_256MB] = { 0x249CE2E5, 0x223A2323, 0x68000C43, 0x00000452, 0x0000000A }, +}; + +const struct mc_ddr_cfg ddr2_cfgs_160mhz[] = { + [DRAM_32MB] = { 0x23918250, 0x222E2322, 0x40000A43, 0x00000452, 0x00000006 }, + [DRAM_64MB] = { 0x239A2250, 0x22322322, 0x40000A43, 0x00000452, 0x00000008 }, + [DRAM_128MB] = { 0x2392A250, 0x22362322, 0x40000A43, 0x00000452, 0x00000008 }, + [DRAM_256MB] = { 0x24140250, 0x223A2322, 0x40000A43, 0x00000452, 0x00000008 }, +}; + +static void mt7628_memc_reset(int assert) +{ + void __iomem *sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + + if (assert) + setbits_32(sysc + SYSCTL_RSTCTL_REG, MC_RST); + else + clrbits_32(sysc + SYSCTL_RSTCTL_REG, MC_RST); +} + +static void mt7628_ddr_pad_ldo_config(int ddr_type, int pkg_type) +{ + void __iomem *rgc = ioremap_nocache(RGCTL_BASE, RGCTL_SIZE); + u32 ck_pad1, cmd_pad1, dq_pad0, dq_pad1, dqs_pad0, dqs_pad1; + + setbits_32(rgc + RGCTL_PMU_G0_REG, PMU_CFG_EN); + + if (ddr_type == DRAM_DDR1) + setbits_32(rgc + RGCTL_PMU_G3_REG, RG_DDRLDO_VOSEL); + else + clrbits_32(rgc + RGCTL_PMU_G3_REG, RG_DDRLDO_VOSEL); + + setbits_32(rgc + RGCTL_PMU_G3_REG, NI_DDRLDO_EN); + + __udelay(250 * 50); + + setbits_32(rgc + RGCTL_PMU_G3_REG, NI_DDRLDO_STB); + setbits_32(rgc + RGCTL_PMU_G1_REG, RG_BUCK_FPWM); + + ck_pad1 = readl(rgc + RGCTL_DDR_PAD_CK_G1_REG); + cmd_pad1 = readl(rgc + RGCTL_DDR_PAD_CMD_G1_REG); + dq_pad0 = readl(rgc + RGCTL_DDR_PAD_DQ_G0_REG); + dq_pad1 = readl(rgc + RGCTL_DDR_PAD_DQ_G1_REG); + dqs_pad0 = readl(rgc + RGCTL_DDR_PAD_DQS_G0_REG); + dqs_pad1 = readl(rgc + RGCTL_DDR_PAD_DQS_G1_REG); + + ck_pad1 &= ~(DRVP_M | DRVN_M); + cmd_pad1 &= ~(DRVP_M | DRVN_M); + dq_pad0 &= ~RTT_M; + dq_pad1 &= ~(DRVP_M | DRVN_M); + dqs_pad0 &= ~RTT_M; + dqs_pad1 &= ~(DRVP_M | DRVN_M); + + if (pkg_type == PKG_ID_KN) { + ck_pad1 |= (3 << DRVP_S) | (3 << DRVN_S); + cmd_pad1 |= (3 << DRVP_S) | (3 << DRVN_S); + dq_pad1 |= (3 << DRVP_S) | (3 << DRVN_S); + dqs_pad1 |= (3 << DRVP_S) | (3 << DRVN_S); + } else { + ck_pad1 |= (12 << DRVP_S) | (12 << DRVN_S); + cmd_pad1 |= (2 << DRVP_S) | (2 << DRVN_S); + dqs_pad1 |= (12 << DRVP_S) | (12 << DRVN_S); + if (ddr_type == DRAM_DDR1) + dq_pad1 |= (7 << DRVP_S) | (7 << DRVN_S); + else + dq_pad1 |= (4 << DRVP_S) | (4 << DRVN_S); + } + + writel(ck_pad1, rgc + RGCTL_DDR_PAD_CK_G1_REG); + writel(cmd_pad1, rgc + RGCTL_DDR_PAD_CMD_G1_REG); + writel(dq_pad0, rgc + RGCTL_DDR_PAD_DQ_G0_REG); + writel(dq_pad1, rgc + RGCTL_DDR_PAD_DQ_G1_REG); + writel(dqs_pad0, rgc + RGCTL_DDR_PAD_DQS_G0_REG); + writel(dqs_pad1, rgc + RGCTL_DDR_PAD_DQS_G1_REG); +} + +void mt7628_ddr_init(void) +{ + void __iomem *sysc; + int ddr_type, pkg_type, lspd; + struct mc_ddr_init_param param; + + sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + ddr_type = readl(sysc + SYSCTL_SYSCFG0_REG) & DRAM_TYPE; + pkg_type = !!(readl(sysc + SYSCTL_CHIP_REV_ID_REG) & PKG_ID); + lspd = readl(sysc + SYSCTL_CLKCFG0_REG) & + (CPU_PLL_FROM_BBP | CPU_PLL_FROM_XTAL); + + mt7628_memc_reset(1); + __udelay(200); + + mt7628_ddr_pad_ldo_config(ddr_type, pkg_type); + + param.memc = ioremap_nocache(MEMCTL_BASE, MEMCTL_SIZE); + param.dq_dly = DDR2_DQ_DLY; + param.dqs_dly = DDR2_DQS_DLY; + param.mc_reset = mt7628_memc_reset; + param.memsize = 0; + param.bus_width = 0; + + if (pkg_type == PKG_ID_KN) + ddr_type = DRAM_DDR1; + + if (ddr_type == DRAM_DDR1) { + if (lspd) + param.cfgs = ddr1_cfgs_160mhz; + else + param.cfgs = ddr1_cfgs_200mhz; + ddr1_init(¶m); + } else { + if (lspd) + param.cfgs = ddr2_cfgs_160mhz; + else + param.cfgs = ddr2_cfgs_200mhz; + ddr2_init(¶m); + } + + ddr_calibrate(param.memc, param.memsize, param.bus_width); + + gd->ram_size = param.memsize; +} diff --git a/arch/mips/mach-mtmips/mt7628/init.c b/arch/mips/mach-mtmips/mt7628/init.c new file mode 100644 index 0000000000..77d1f2ea0d --- /dev/null +++ b/arch/mips/mach-mtmips/mt7628/init.c @@ -0,0 +1,109 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dm/uclass.h> +#include <dt-bindings/clock/mt7628-clk.h> +#include <linux/io.h> +#include "mt7628.h" + +DECLARE_GLOBAL_DATA_PTR; + +static void set_init_timer_freq(void) +{ + void __iomem *sysc; + u32 bs, val, timer_freq_post; + + sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + + /* We can't use the clk driver as the DM has not been initialized yet */ + bs = readl(sysc + SYSCTL_SYSCFG0_REG); + if ((bs & XTAL_FREQ_SEL) == XTAL_25MHZ) { + gd->arch.timer_freq = 25000000; + timer_freq_post = 575000000; + } else { + gd->arch.timer_freq = 40000000; + timer_freq_post = 580000000; + } + + val = readl(sysc + SYSCTL_CLKCFG0_REG); + if (!(val & (CPU_PLL_FROM_BBP | CPU_PLL_FROM_XTAL))) + gd->arch.timer_freq = timer_freq_post; +} + +void mt7628_init(void) +{ + set_init_timer_freq(); + + mt7628_ddr_init(); +} + +int print_cpuinfo(void) +{ + void __iomem *sysc; + struct udevice *clkdev; + u32 val, ver, eco, pkg, ddr, chipmode, ee; + ulong cpu_clk, bus_clk, xtal_clk, timer_freq; + struct clk clk; + int ret; + + sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + + val = readl(sysc + SYSCTL_CHIP_REV_ID_REG); + ver = (val & VER_M) >> VER_S; + eco = (val & ECO_M) >> ECO_S; + pkg = !!(val & PKG_ID); + + val = readl(sysc + SYSCTL_SYSCFG0_REG); + ddr = val & DRAM_TYPE; + chipmode = (val & CHIP_MODE_M) >> CHIP_MODE_S; + + val = readl(sysc + SYSCTL_EFUSE_CFG_REG); + ee = val & EFUSE_MT7688; + + printf("CPU: MediaTek MT%u%c ver:%u eco:%u\n", + ee ? 7688 : 7628, pkg ? 'A' : 'K', ver, eco); + + printf("Boot: DDR%s, SPI-NOR %u-Byte Addr, CPU clock from %s\n", + ddr ? "" : "2", chipmode & 0x01 ? 4 : 3, + chipmode & 0x02 ? "XTAL" : "CPLL"); + + ret = uclass_get_device_by_driver(UCLASS_CLK, DM_GET_DRIVER(mt7628_clk), + &clkdev); + if (ret) + return ret; + + clk.dev = clkdev; + + clk.id = CLK_CPU; + cpu_clk = clk_get_rate(&clk); + + clk.id = CLK_SYS; + bus_clk = clk_get_rate(&clk); + + clk.id = CLK_XTAL; + xtal_clk = clk_get_rate(&clk); + + clk.id = CLK_MIPS_CNT; + timer_freq = clk_get_rate(&clk); + + /* Set final timer frequency */ + if (timer_freq) + gd->arch.timer_freq = timer_freq; + + printf("Clock: CPU: %luMHz, Bus: %luMHz, XTAL: %luMHz\n", + cpu_clk / 1000000, bus_clk / 1000000, xtal_clk / 1000000); + + return 0; +} + +ulong notrace get_tbclk(void) +{ + return gd->arch.timer_freq; +} diff --git a/arch/mips/mach-mtmips/mt7628/lowlevel_init.S b/arch/mips/mach-mtmips/mt7628/lowlevel_init.S new file mode 100644 index 0000000000..e4a6c03580 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7628/lowlevel_init.S @@ -0,0 +1,161 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <config.h> +#include <asm-offsets.h> +#include <asm/cacheops.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/addrspace.h> +#include <asm/asm.h> +#include "mt7628.h" + +/* Set temporary stack address range */ +#ifndef CONFIG_SYS_INIT_SP_ADDR +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + \ + CONFIG_SYS_INIT_SP_OFFSET) +#endif + +#define CACHE_STACK_SIZE 0x4000 +#define CACHE_STACK_BASE (CONFIG_SYS_INIT_SP_ADDR - CACHE_STACK_SIZE) + +#define DELAY_USEC(us) ((58 * (us)) / 3) + + .set noreorder + +LEAF(mips_sram_init) +#ifndef CONFIG_SKIP_LOWLEVEL_INIT + /* Setup CPU PLL */ + li t0, DELAY_USEC(1000000) + li t1, KSEG1ADDR(SYSCTL_BASE + SYSCTL_ROM_STATUS_REG) + li t2, KSEG1ADDR(SYSCTL_BASE + SYSCTL_CLKCFG0_REG) + +_check_rom_status: + lw t3, 0(t1) + andi t3, t3, 1 + bnez t3, _rom_normal + subu t0, t0, 1 + bnez t0, _check_rom_status + nop + + lw t3, 0(t2) + ori t3, (CPU_PLL_FROM_BBP | CPU_PLL_FROM_XTAL) + xori t3, CPU_PLL_FROM_BBP + b _cpu_pll_done + nop + +_rom_normal: + lw t3, 0(t2) + ori t3, (CPU_PLL_FROM_BBP | CPU_PLL_FROM_XTAL | \ + DIS_BBP_SLEEP | EN_BBP_CLK) + xori t3, (CPU_PLL_FROM_BBP | CPU_PLL_FROM_XTAL) + +_cpu_pll_done: + sw t3, 0(t2) + + li t2, KSEG1ADDR(RBUSCTL_BASE + RBUSCTL_DYN_CFG0_REG) + lw t3, 0(t2) + ori t3, t3, (CPU_FDIV_M | CPU_FFRAC_M) + xori t3, t3, (CPU_FDIV_M | CPU_FFRAC_M) + ori t3, t3, ((1 << CPU_FDIV_S) | (1 << CPU_FFRAC_S)) + sw t3, 0(t2) + + /* Clear WST & SPR bits in ErrCtl */ + mfc0 t0, CP0_ECC + ins t0, zero, 30, 2 + mtc0 t0, CP0_ECC + ehb + + /* Simply initialize I-Cache */ + li a0, 0 + li a1, CONFIG_SYS_ICACHE_SIZE + + mtc0 zero, CP0_TAGLO /* Zero to DDataLo */ + +1: cache INDEX_STORE_TAG_I, 0(a0) + addiu a0, CONFIG_SYS_ICACHE_LINE_SIZE + bne a0, a1, 1b + nop + + /* Simply initialize D-Cache */ + li a0, 0 + li a1, CONFIG_SYS_DCACHE_SIZE + + mtc0 zero, CP0_TAGLO, 2 + +2: cache INDEX_STORE_TAG_D, 0(a0) + addiu a0, CONFIG_SYS_DCACHE_LINE_SIZE + bne a0, a1, 2b + nop + + /* Set KSEG0 Cachable */ + mfc0 t0, CP0_CONFIG + and t0, t0, MIPS_CONF_IMPL + or t0, t0, CONF_CM_CACHABLE_NONCOHERENT + mtc0 t0, CP0_CONFIG + ehb + + /* Lock D-Cache */ + PTR_LI a0, CACHE_STACK_BASE /* D-Cache lock base */ + li a1, CACHE_STACK_SIZE /* D-Cache lock size */ + li a2, 0x1ffff800 /* Mask of DTagLo[PTagLo] */ + +3: + /* Lock one cacheline */ + and t0, a0, a2 + ori t0, 0xe0 /* Valid & Dirty & Lock bits */ + mtc0 t0, CP0_TAGLO, 2 /* Write to DTagLo */ + ehb + cache INDEX_STORE_TAG_D, 0(a0) + + addiu a0, CONFIG_SYS_DCACHE_LINE_SIZE + sub a1, CONFIG_SYS_DCACHE_LINE_SIZE + bnez a1, 3b + nop +#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ + + jr ra + nop + END(mips_sram_init) + +NESTED(lowlevel_init, 0, ra) + /* Save ra and do real lowlevel initialization */ + move s0, ra + + PTR_LA t9, mt7628_init + jalr t9 + nop + + move ra, s0 + +#if CONFIG_IS_ENABLED(INIT_STACK_WITHOUT_MALLOC_F) + /* Set malloc base */ + li t0, (CONFIG_SYS_INIT_SP_ADDR + 15) & (~15) + PTR_S t0, GD_MALLOC_BASE(k0) # gd->malloc_base offset +#endif + + /* Write back data in locked cache to DRAM */ + PTR_LI a0, CACHE_STACK_BASE /* D-Cache unlock base */ + li a1, CACHE_STACK_SIZE /* D-Cache unlock size */ + +1: + cache HIT_WRITEBACK_INV_D, 0(a0) + addiu a0, CONFIG_SYS_DCACHE_LINE_SIZE + sub a1, CONFIG_SYS_DCACHE_LINE_SIZE + bnez a1, 1b + nop + + /* Set KSEG0 Uncached */ + mfc0 t0, CP0_CONFIG + and t0, t0, MIPS_CONF_IMPL + or t0, t0, CONF_CM_UNCACHED + mtc0 t0, CP0_CONFIG + ehb + + jr ra + nop + END(lowlevel_init) diff --git a/arch/mips/mach-mtmips/mt7628/mt7628.h b/arch/mips/mach-mtmips/mt7628/mt7628.h new file mode 100644 index 0000000000..391880b014 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7628/mt7628.h @@ -0,0 +1,104 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _MT7628_H_ +#define _MT7628_H_ + +#define SYSCTL_BASE 0x10000000 +#define SYSCTL_SIZE 0x100 +#define MEMCTL_BASE 0x10000300 +#define MEMCTL_SIZE 0x100 +#define RBUSCTL_BASE 0x10000400 +#define RBUSCTL_SIZE 0x100 +#define RGCTL_BASE 0x10001000 +#define RGCTL_SIZE 0x800 + +#define SYSCTL_EFUSE_CFG_REG 0x08 +#define EFUSE_MT7688 0x100000 + +#define SYSCTL_CHIP_REV_ID_REG 0x0c +#define PKG_ID 0x10000 +#define PKG_ID_AN 1 +#define PKG_ID_KN 0 +#define VER_S 8 +#define VER_M 0xf00 +#define ECO_S 0 +#define ECO_M 0x0f + +#define SYSCTL_SYSCFG0_REG 0x10 +#define XTAL_FREQ_SEL 0x40 +#define XTAL_40MHZ 1 +#define XTAL_25MHZ 0 +#define CHIP_MODE_S 1 +#define CHIP_MODE_M 0x0e +#define DRAM_TYPE 0x01 +#define DRAM_DDR1 1 +#define DRAM_DDR2 0 + +#define SYSCTL_ROM_STATUS_REG 0x28 + +#define SYSCTL_CLKCFG0_REG 0x2c +#define DIS_BBP_SLEEP 0x08 +#define EN_BBP_CLK 0x04 +#define CPU_PLL_FROM_BBP 0x02 +#define CPU_PLL_FROM_XTAL 0x01 + +#define SYSCTL_RSTCTL_REG 0x34 +#define MC_RST 0x400 + +#define SYSCTL_AGPIO_CFG_REG 0x3c +#define EPHY_GPIO_AIO_EN_S 17 +#define EPHY_GPIO_AIO_EN_M 0x1e0000 + +#define SYSCTL_GPIO_MODE1_REG 0x60 +#define UART2_MODE_S 26 +#define UART2_MODE_M 0xc000000 +#define UART1_MODE_S 24 +#define UART1_MODE_M 0x3000000 +#define UART0_MODE_S 8 +#define UART0_MODE_M 0x300 +#define SPIS_MODE_S 2 +#define SPIS_MODE_M 0x0c + +#define RBUSCTL_DYN_CFG0_REG 0x40 +#define CPU_FDIV_S 8 +#define CPU_FDIV_M 0xf00 +#define CPU_FFRAC_S 0 +#define CPU_FFRAC_M 0x0f + +#define RGCTL_PMU_G0_REG 0x100 +#define PMU_CFG_EN 0x80000000 + +#define RGCTL_PMU_G1_REG 0x104 +#define RG_BUCK_FPWM 0x02 + +#define RGCTL_PMU_G3_REG 0x10c +#define NI_DDRLDO_STB 0x40000 +#define NI_DDRLDO_EN 0x10000 +#define RG_DDRLDO_VOSEL 0x40 + +#define RGCTL_DDR_PAD_CK_G0_REG 0x700 +#define RGCTL_DDR_PAD_CMD_G0_REG 0x708 +#define RGCTL_DDR_PAD_DQ_G0_REG 0x710 +#define RGCTL_DDR_PAD_DQS_G0_REG 0x718 +#define RTT_S 8 +#define RTT_M 0x700 + +#define RGCTL_DDR_PAD_CK_G1_REG 0x704 +#define RGCTL_DDR_PAD_CMD_G1_REG 0x70c +#define RGCTL_DDR_PAD_DQ_G1_REG 0x714 +#define RGCTL_DDR_PAD_DQS_G1_REG 0x71c +#define DRVP_S 0 +#define DRVP_M 0x0f +#define DRVN_S 8 +#define DRVN_M 0xf00 + +#ifndef __ASSEMBLY__ +void mt7628_ddr_init(void); +#endif + +#endif /* _MT7628_H_ */ diff --git a/arch/mips/mach-mtmips/mt76xx.h b/arch/mips/mach-mtmips/mt76xx.h deleted file mode 100644 index 17473ea8f1..0000000000 --- a/arch/mips/mach-mtmips/mt76xx.h +++ /dev/null @@ -1,32 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2018 Stefan Roese sr@denx.de - */ - -#ifndef __MT76XX_H -#define __MT76XX_H - -#define MT76XX_SYSCTL_BASE 0x10000000 - -#define MT76XX_CHIPID_OFFS 0x00 -#define MT76XX_CHIP_REV_ID_OFFS 0x0c -#define MT76XX_SYSCFG0_OFFS 0x10 - -#define MT76XX_MEMCTRL_BASE (MT76XX_SYSCTL_BASE + 0x0300) -#define MT76XX_RGCTRL_BASE (MT76XX_SYSCTL_BASE + 0x1000) - -#define MT76XX_ROM_STATUS_REG (MT76XX_SYSCTL_BASE + 0x0028) -#define MT76XX_CLKCFG0_REG (MT76XX_SYSCTL_BASE + 0x002c) -#define MT76XX_DYN_CFG0_REG (MT76XX_SYSCTL_BASE + 0x0440) - -#define DDR_CFG1_REG (MT76XX_MEMCTRL_BASE + 0x44) -#define DDR_CFG2_REG (MT76XX_MEMCTRL_BASE + 0x48) -#define DDR_CFG3_REG (MT76XX_MEMCTRL_BASE + 0x4c) -#define DDR_CFG4_REG (MT76XX_MEMCTRL_BASE + 0x50) - -#ifndef __ASSEMBLY__ -/* Prototypes */ -void ddr_calibrate(void); -#endif - -#endif diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 7f040f5762..0209af0fc9 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -9,8 +9,6 @@ CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_ENV_OFFSET_REDUND=0xB0000 CONFIG_ARCH_MTMIPS=y CONFIG_BOOT_ROM=y -CONFIG_ONBOARD_DDR2_SIZE_1024MBIT=y -CONFIG_ONBOARD_DDR2_CHIP_WIDTH_16BIT=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 7993976443..34066dd293 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -7,8 +7,6 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_ARCH_MTMIPS=y CONFIG_BOARD_LINKIT_SMART_7688=y CONFIG_BOOT_ROM=y -CONFIG_ONBOARD_DDR2_SIZE_1024MBIT=y -CONFIG_ONBOARD_DDR2_CHIP_WIDTH_16BIT=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y
This patch adds a new pinmux for UART2, which shares the pins with SPIS.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: none
arch/mips/dts/mt7628a.dtsi | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index 409695b5c7..2200135a77 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -110,6 +110,11 @@ function = "uart2"; };
+ uart2_pwm_pins: uart2_pwm_pins { + groups = "spis"; + function = "pwm_uart2"; + }; + i2c_pins: i2c_pins { groups = "i2c"; function = "i2c";
If CONFIG_SPL_OF_CONTROL is enabled for SPL and CONFIG_OF_SEPARATE is also enabled, the dtb will be appended to the u-boot-spl.bin.
When calling dm_init_and_scan() in SPL, fdtdec_setup() will try to locate dtb at the end of u-boot-spl.bin, by referencing to _image_binary_end.
However _image_binary_end is currently missing in u-boot-spl.lds. This patch adds _image_binary_end to u-boot-spl.lds to make sure linking u-boot-spl will not fail.
Reviewed-by: Stefan Roese sr@denx.de Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: none
arch/mips/cpu/u-boot-spl.lds | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/mips/cpu/u-boot-spl.lds b/arch/mips/cpu/u-boot-spl.lds index d08d6222c4..e467491639 100644 --- a/arch/mips/cpu/u-boot-spl.lds +++ b/arch/mips/cpu/u-boot-spl.lds @@ -37,6 +37,8 @@ SECTIONS . = ALIGN(4); __image_copy_end = .;
+ _image_binary_end = .; + .bss (NOLOAD) : { __bss_start = .; *(.bss*)
u_boot_list is not only used by DM, but also by some SPL image load methods such as spl_nor.c.
This patch adds an option CONFIG_SPL_LOADER_SUPPORT in conjunction with CONFIG_SPL_DM surrounding the u_boot_list section to make sure SPL image loaders can be correctly built into u-boot SPL without DM enabled.
arch/mips/Kconfig | 6 ++++++ arch/mips/cpu/u-boot-spl.lds | 2 +- 2 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 5f82caf8be..7b9d0072eb 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -335,6 +335,12 @@ config SPL_INIT_STACK_WITHOUT_MALLOC_F malloc space. Platform should set the malloc_base later when DRAM is ready to use.
+config SPL_LOADER_SUPPORT + bool + default n + help + Enable this option if you want to use SPL loaders without DM enabled. + endmenu
menu "OS boot interface" diff --git a/arch/mips/cpu/u-boot-spl.lds b/arch/mips/cpu/u-boot-spl.lds index e467491639..28ea4f2a48 100644 --- a/arch/mips/cpu/u-boot-spl.lds +++ b/arch/mips/cpu/u-boot-spl.lds @@ -27,7 +27,7 @@ SECTIONS *(SORT_BY_ALIGNMENT(.sdata*)) } > .spl_mem
-#ifdef CONFIG_SPL_DM +#if defined(CONFIG_SPL_DM) || defined(CONFIG_SPL_LOADER_SUPPORT) . = ALIGN(4); .u_boot_list : { KEEP(*(SORT(.u_boot_list*)));
This patch enables LZMA decompression support for SPL build
Reviewed-by: Stefan Roese sr@denx.de Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: none
lib/Kconfig | 5 +++++ lib/Makefile | 1 + 2 files changed, 6 insertions(+)
diff --git a/lib/Kconfig b/lib/Kconfig index 452f390c80..a441cd162a 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -429,6 +429,11 @@ config SPL_LZ4 fast compression and decompression speed. It belongs to the LZ77 family of byte-oriented compression schemes.
+config SPL_LZMA + bool "Enable LZMA decompression support for SPL build" + help + This enables support for LZMA compression altorithm for SPL boot. + config SPL_LZO bool "Enable LZO decompression support in SPL" help diff --git a/lib/Makefile b/lib/Makefile index 5f88d92850..283b00ffe6 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -67,6 +67,7 @@ obj-$(CONFIG_$(SPL_)ZLIB) += zlib/ obj-$(CONFIG_$(SPL_)ZSTD) += zstd/ obj-$(CONFIG_$(SPL_)GZIP) += gunzip.o obj-$(CONFIG_$(SPL_)LZO) += lzo/ +obj-$(CONFIG_$(SPL_)LZMA) += lzma/ obj-$(CONFIG_$(SPL_)LZ4) += lz4_wrapper.o
obj-$(CONFIG_LIBAVB) += libavb/
This patch adds support for generating LZMA compressed u-boot image. The compressed image can be used for SPL to reduce the size of the u-boot binary.
Reviewed-by: Stefan Roese sr@denx.de Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: none
Makefile | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/Makefile b/Makefile index 26307fd4a6..ffc1e28bd0 100644 --- a/Makefile +++ b/Makefile @@ -1000,6 +1000,9 @@ append = cat $(filter-out $< $(PHONY), $^) >> $@ quiet_cmd_pad_cat = CAT $@ cmd_pad_cat = $(cmd_objcopy) && $(append) || rm -f $@
+quiet_cmd_lzma = LZMA $@ +cmd_lzma = lzma -c -z -k -9 $< > $@ + cfg: u-boot.cfg
quiet_cmd_cfgcheck = CFGCHK $2 @@ -1382,6 +1385,16 @@ else UBOOT_BIN := u-boot.bin endif
+MKIMAGEFLAGS_u-boot-lzma.img = -A $(ARCH) -T standalone -C lzma -O u-boot \ + -a $(CONFIG_SYS_TEXT_BASE) -e $(CONFIG_SYS_UBOOT_START) \ + -n "U-Boot $(UBOOTRELEASE) for $(BOARD) board" + +u-boot.bin.lzma: u-boot.bin FORCE + $(call if_changed,lzma) + +u-boot-lzma.img: u-boot.bin.lzma FORCE + $(call if_changed,mkimage) + u-boot-dtb.img u-boot.img u-boot.kwb u-boot.pbl u-boot-ivt.img: \ $(if $(CONFIG_SPL_LOAD_FIT),u-boot-nodtb.bin \ $(if $(CONFIG_OF_SEPARATE)$(CONFIG_OF_EMBED)$(CONFIG_OF_HOSTFILE),dts/dt.dtb) \
This patch adds etype u-boot-lzma-img for binman. README.entries is also updated.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes since v3: none
tools/binman/README.entries | 15 ++++++++++++ tools/binman/etype/u_boot_lzma_img.py | 28 +++++++++++++++++++++++ tools/binman/ftest.py | 7 ++++++ tools/binman/test/156_u_boot_lzma_img.dts | 11 +++++++++ 4 files changed, 61 insertions(+) create mode 100644 tools/binman/etype/u_boot_lzma_img.py create mode 100644 tools/binman/test/156_u_boot_lzma_img.dts
diff --git a/tools/binman/README.entries b/tools/binman/README.entries index 6a816bba6b..0aea9b8f6d 100644 --- a/tools/binman/README.entries +++ b/tools/binman/README.entries @@ -747,6 +747,21 @@ applications.
+Entry: u-boot-lzma-img: U-Boot legacy image with contents compressed by LZMA +---------------------------------------------------------------------------- + +Properties / Entry arguments: + - filename: Filename of u-boot-lzma.img (default 'u-boot-lzma.img') + +This is the U-Boot binary as a packaged image, in legacy format. It has a +header which allows it to be loaded at the correct address for execution. +Its contents are compressed by LZMA. + +You should use FIT (Flat Image Tree) instead of the legacy image for new +applications. + + + Entry: u-boot-nodtb: U-Boot flat binary without device tree appended --------------------------------------------------------------------
diff --git a/tools/binman/etype/u_boot_lzma_img.py b/tools/binman/etype/u_boot_lzma_img.py new file mode 100644 index 0000000000..966d6a46da --- /dev/null +++ b/tools/binman/etype/u_boot_lzma_img.py @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0 +# Copyright (C) 2020 MediaTek Inc. All Rights Reserved. +# Author: Weijie Gao weijie.gao@mediatek.com +# +# Entry-type module for U-Boot legacy image with contents compressed by LZMA +# + +from entry import Entry +from blob import Entry_blob + +class Entry_u_boot_lzma_img(Entry_blob): + """U-Boot legacy image with contents compressed by LZMA + + Properties / Entry arguments: + - filename: Filename of u-boot-lzma.img (default 'u-boot-lzma.img') + + This is the U-Boot binary as a packaged image, in legacy format. It has a + header which allows it to be loaded at the correct address for execution. + Its contents are compressed by LZMA. + + You should use FIT (Flat Image Tree) instead of the legacy image for new + applications. + """ + def __init__(self, section, etype, node): + Entry_blob.__init__(self, section, etype, node) + + def GetDefaultFilename(self): + return 'u-boot-lzma.img' diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 872b855444..0ff7487b96 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -39,6 +39,7 @@ import tout # Contents of test files, corresponding to different entry types U_BOOT_DATA = b'1234' U_BOOT_IMG_DATA = b'img' +U_BOOT_LZMA_IMG_DATA = b'lzma-img' U_BOOT_SPL_DATA = b'56780123456789abcdefghi' U_BOOT_TPL_DATA = b'tpl9876543210fedcbazyw' BLOB_DATA = b'89' @@ -115,6 +116,7 @@ class TestFunctional(unittest.TestCase): # Create some test files TestFunctional._MakeInputFile('u-boot.bin', U_BOOT_DATA) TestFunctional._MakeInputFile('u-boot.img', U_BOOT_IMG_DATA) + TestFunctional._MakeInputFile('u-boot-lzma.img', U_BOOT_LZMA_IMG_DATA) TestFunctional._MakeInputFile('spl/u-boot-spl.bin', U_BOOT_SPL_DATA) TestFunctional._MakeInputFile('tpl/u-boot-tpl.bin', U_BOOT_TPL_DATA) TestFunctional._MakeInputFile('blobfile', BLOB_DATA) @@ -1078,6 +1080,11 @@ class TestFunctional(unittest.TestCase): data = self._DoReadFile('036_u_boot_img.dts') self.assertEqual(U_BOOT_IMG_DATA, data)
+ def testUBootLzmaImg(self): + """Test that u-boot-lzma.img can be put in a file""" + data = self._DoReadFile('156_u_boot_lzma_img.dts') + self.assertEqual(U_BOOT_LZMA_IMG_DATA, data) + def testNoMicrocode(self): """Test that a missing microcode region is detected""" with self.assertRaises(ValueError) as e: diff --git a/tools/binman/test/156_u_boot_lzma_img.dts b/tools/binman/test/156_u_boot_lzma_img.dts new file mode 100644 index 0000000000..f49d014216 --- /dev/null +++ b/tools/binman/test/156_u_boot_lzma_img.dts @@ -0,0 +1,11 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot-lzma-img { + }; + }; +};
This patch moves the legacy image handling into a separate file, which will be extended with other legacy image features later.
No function change intended.
Signed-off-by: Stefan Roese sr@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Weijie Gao weijie.gao@mediatek.com Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com --- Changes in v7: - None
Changes in v6: - New patch
common/spl/Makefile | 1 + common/spl/spl.c | 56 +++++++++-------------------------------- common/spl/spl_legacy.c | 54 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 67 insertions(+), 44 deletions(-) create mode 100644 common/spl/spl_legacy.c
diff --git a/common/spl/Makefile b/common/spl/Makefile index eaa57f5ce5..c576a78126 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -10,6 +10,7 @@ ifdef CONFIG_SPL_BUILD obj-$(CONFIG_$(SPL_TPL_)FRAMEWORK) += spl.o obj-$(CONFIG_$(SPL_TPL_)BOOTROM_SUPPORT) += spl_bootrom.o obj-$(CONFIG_$(SPL_TPL_)LOAD_FIT) += spl_fit.o +obj-$(CONFIG_$(SPL_TPL_)LEGACY_IMAGE_SUPPORT) += spl_legacy.o obj-$(CONFIG_$(SPL_TPL_)NOR_SUPPORT) += spl_nor.o obj-$(CONFIG_$(SPL_TPL_)XIP_SUPPORT) += spl_xip.o obj-$(CONFIG_$(SPL_TPL_)YMODEM_SUPPORT) += spl_ymodem.o diff --git a/common/spl/spl.c b/common/spl/spl.c index 932e6ab98a..b0f0e1557b 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -254,6 +254,14 @@ static int spl_load_fit_image(struct spl_image_info *spl_image, } #endif
+__weak int spl_parse_legacy_header(struct spl_image_info *spl_image, + const struct image_header *header) +{ + /* LEGACY image not supported */ + debug("Legacy boot image support not enabled, proceeding to other boot methods\n"); + return -EINVAL; +} + int spl_parse_image_header(struct spl_image_info *spl_image, const struct image_header *header) { @@ -264,51 +272,11 @@ int spl_parse_image_header(struct spl_image_info *spl_image, return ret; #endif if (image_get_magic(header) == IH_MAGIC) { -#ifdef CONFIG_SPL_LEGACY_IMAGE_SUPPORT - u32 header_size = sizeof(struct image_header); - -#ifdef CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK - /* check uImage header CRC */ - if (!image_check_hcrc(header)) { - puts("SPL: Image header CRC check failed!\n"); - return -EINVAL; - } -#endif - - if (spl_image->flags & SPL_COPY_PAYLOAD_ONLY) { - /* - * On some system (e.g. powerpc), the load-address and - * entry-point is located at address 0. We can't load - * to 0-0x40. So skip header in this case. - */ - spl_image->load_addr = image_get_load(header); - spl_image->entry_point = image_get_ep(header); - spl_image->size = image_get_data_size(header); - } else { - spl_image->entry_point = image_get_ep(header); - /* Load including the header */ - spl_image->load_addr = image_get_load(header) - - header_size; - spl_image->size = image_get_data_size(header) + - header_size; - } -#ifdef CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK - /* store uImage data length and CRC to check later */ - spl_image->dcrc_data = image_get_load(header); - spl_image->dcrc_length = image_get_data_size(header); - spl_image->dcrc = image_get_dcrc(header); -#endif + int ret;
- spl_image->os = image_get_os(header); - spl_image->name = image_get_name(header); - debug(SPL_TPL_PROMPT - "payload image: %32s load addr: 0x%lx size: %d\n", - spl_image->name, spl_image->load_addr, spl_image->size); -#else - /* LEGACY image not supported */ - debug("Legacy boot image support not enabled, proceeding to other boot methods\n"); - return -EINVAL; -#endif + ret = spl_parse_legacy_header(spl_image, header); + if (ret) + return ret; } else { #ifdef CONFIG_SPL_PANIC_ON_RAW_IMAGE /* diff --git a/common/spl/spl_legacy.c b/common/spl/spl_legacy.c new file mode 100644 index 0000000000..33f3587e3b --- /dev/null +++ b/common/spl/spl_legacy.c @@ -0,0 +1,54 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Stefan Roese sr@denx.de + */ + +#include <common.h> +#include <spl.h> + +int spl_parse_legacy_header(struct spl_image_info *spl_image, + const struct image_header *header) +{ + u32 header_size = sizeof(struct image_header); + +#ifdef CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK + /* check uImage header CRC */ + if (!image_check_hcrc(header)) { + puts("SPL: Image header CRC check failed!\n"); + return -EINVAL; + } +#endif + + if (spl_image->flags & SPL_COPY_PAYLOAD_ONLY) { + /* + * On some system (e.g. powerpc), the load-address and + * entry-point is located at address 0. We can't load + * to 0-0x40. So skip header in this case. + */ + spl_image->load_addr = image_get_load(header); + spl_image->entry_point = image_get_ep(header); + spl_image->size = image_get_data_size(header); + } else { + spl_image->entry_point = image_get_ep(header); + /* Load including the header */ + spl_image->load_addr = image_get_load(header) - + header_size; + spl_image->size = image_get_data_size(header) + + header_size; + } + +#ifdef CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK + /* store uImage data length and CRC to check later */ + spl_image->dcrc_data = image_get_load(header); + spl_image->dcrc_length = image_get_data_size(header); + spl_image->dcrc = image_get_dcrc(header); +#endif + + spl_image->os = image_get_os(header); + spl_image->name = image_get_name(header); + debug(SPL_TPL_PROMPT + "payload image: %32s load addr: 0x%lx size: %d\n", + spl_image->name, spl_image->load_addr, spl_image->size); + + return 0; +}
Am 21.04.20 um 09:28 schrieb Stefan Roese:
Changes in v7:
- None
Changes in v6:
- New patch
Use IS_ENABLED() instead of #ifdef CONFIG_ to remove one #ifdef.
No functional change intended.
common/spl/spl_legacy.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/common/spl/spl_legacy.c b/common/spl/spl_legacy.c index 33f3587e3b..772135193e 100644 --- a/common/spl/spl_legacy.c +++ b/common/spl/spl_legacy.c @@ -11,13 +11,12 @@ int spl_parse_legacy_header(struct spl_image_info *spl_image, { u32 header_size = sizeof(struct image_header);
-#ifdef CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK /* check uImage header CRC */ - if (!image_check_hcrc(header)) { + if (IS_ENABLED(CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK) && + !image_check_hcrc(header)) { puts("SPL: Image header CRC check failed!\n"); return -EINVAL; } -#endif
if (spl_image->flags & SPL_COPY_PAYLOAD_ONLY) { /*
Changes in v7:
- None
Changes in v6:
- New patch
Move the legacy image loading into spl_legacy.c. This makes it easier to extend the legacy image handling with new features that other SPL loaders might use (e.g. spl_spi.c etc).
Signed-off-by: Stefan Roese sr@denx.de Cc: Weijie Gao weijie.gao@mediatek.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com --- Changes in v7: - Don't include "ret" usage cleanup in this patch
common/spl/spl_legacy.c | 20 ++++++++++++++++++++ common/spl/spl_nor.c | 15 +++++++-------- include/spl.h | 13 +++++++++++++ 3 files changed, 40 insertions(+), 8 deletions(-)
diff --git a/common/spl/spl_legacy.c b/common/spl/spl_legacy.c index 772135193e..7f00fc8885 100644 --- a/common/spl/spl_legacy.c +++ b/common/spl/spl_legacy.c @@ -51,3 +51,23 @@ int spl_parse_legacy_header(struct spl_image_info *spl_image,
return 0; } + +int spl_load_legacy_img(struct spl_image_info *spl_image, + struct spl_load_info *load, ulong header) +{ + struct image_header hdr; + int ret; + + /* Read header into local struct */ + load->read(load, header, sizeof(hdr), &hdr); + + ret = spl_parse_image_header(spl_image, &hdr); + if (ret) + return ret; + + /* Read image */ + load->read(load, header + sizeof(hdr), spl_image->size, + (void *)(unsigned long)spl_image->load_addr); + + return 0; +} diff --git a/common/spl/spl_nor.c b/common/spl/spl_nor.c index b1e79b9ded..217ae71c35 100644 --- a/common/spl/spl_nor.c +++ b/common/spl/spl_nor.c @@ -107,14 +107,13 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, spl_nor_get_uboot_base()); }
- ret = spl_parse_image_header(spl_image, - (const struct image_header *)spl_nor_get_uboot_base()); - if (ret) - return ret; - - memcpy((void *)(unsigned long)spl_image->load_addr, - (void *)(spl_nor_get_uboot_base() + sizeof(struct image_header)), - spl_image->size); + /* Legacy image handling */ + if (IS_ENABLED(CONFIG_SPL_LEGACY_IMAGE_SUPPORT)) { + load.bl_len = 1; + load.read = spl_nor_load_read; + return spl_load_legacy_img(spl_image, &load, + spl_nor_get_uboot_base()); + }
return 0; } diff --git a/include/spl.h b/include/spl.h index 5d8d14dbf5..a6bb9ba755 100644 --- a/include/spl.h +++ b/include/spl.h @@ -223,6 +223,19 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, #define SPL_COPY_PAYLOAD_ONLY 1 #define SPL_FIT_FOUND 2
+/** + * spl_load_legacy_img() - Loads a legacy image from a device. + * @spl_image: Image description to set up + * @load: Structure containing the information required to load data. + * @header: Pointer to image header (including appended image) + * + * Reads an legacy image from the device. Loads u-boot image to + * specified load address. + * Returns 0 on success. + */ +int spl_load_legacy_img(struct spl_image_info *spl_image, + struct spl_load_info *load, ulong header); + /** * spl_load_imx_container() - Loads a imx container image from a device. * @spl_image: Image description to set up
Changes in v7:
Changes in v6:
- New patch
With the if statement now for the legacy image handling, the compiler now generates this compile time warning:
common/spl/spl_nor.c:27:6: warning: unused variable 'ret' [-Wunused-variable]
This patch removes this warning by changing the 'ret' variable handling.
Signed-off-by: Stefan Roese sr@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Weijie Gao weijie.gao@mediatek.com Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com --- Changes in v7: - New patch
common/spl/spl_nor.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/common/spl/spl_nor.c b/common/spl/spl_nor.c index 217ae71c35..3f03ffe6a3 100644 --- a/common/spl/spl_nor.c +++ b/common/spl/spl_nor.c @@ -24,7 +24,6 @@ unsigned long __weak spl_nor_get_uboot_base(void) static int spl_nor_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) { - int ret; __maybe_unused const struct image_header *header; __maybe_unused struct spl_load_info load;
@@ -43,6 +42,8 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, header = (const struct image_header *)CONFIG_SYS_OS_BASE; #ifdef CONFIG_SPL_LOAD_FIT if (image_get_magic(header) == FDT_MAGIC) { + int ret; + debug("Found FIT\n"); load.bl_len = 1; load.read = spl_nor_load_read; @@ -61,6 +62,7 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, #endif if (image_get_os(header) == IH_OS_LINUX) { /* happy - was a Linux */ + int ret;
ret = spl_parse_image_header(spl_image, header); if (ret) @@ -93,11 +95,9 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, debug("Found FIT format U-Boot\n"); load.bl_len = 1; load.read = spl_nor_load_read; - ret = spl_load_simple_fit(spl_image, &load, - spl_nor_get_uboot_base(), - (void *)header); - - return ret; + return spl_load_simple_fit(spl_image, &load, + spl_nor_get_uboot_base(), + (void *)header); } #endif if (IS_ENABLED(CONFIG_SPL_LOAD_IMX_CONTAINER)) {
Changes in v7:
- New patch
This patch adds support for decompressing LZMA compressed u-boot payload in legacy uImage format.
Using this patch together with u-boot-lzma.img may be useful for some platforms as they can reduce the size and load time of u-boot payload.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com Signed-off-by: Stefan Roese sr@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com --- Changes in v7: - Add spl_image_get_comp() to enable the compiler to optimize the switch/case statement away due to Dead Code Elimination as suggested by Daniel
common/spl/spl_legacy.c | 62 +++++++++++++++++++++++++++++++++++++++-- 1 file changed, 60 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl_legacy.c b/common/spl/spl_legacy.c index 7f00fc8885..29d3ec7073 100644 --- a/common/spl/spl_legacy.c +++ b/common/spl/spl_legacy.c @@ -4,8 +4,15 @@ */
#include <common.h> +#include <malloc.h> #include <spl.h>
+#include <lzma/LzmaTypes.h> +#include <lzma/LzmaDec.h> +#include <lzma/LzmaTools.h> + +#define LZMA_LEN (1 << 20) + int spl_parse_legacy_header(struct spl_image_info *spl_image, const struct image_header *header) { @@ -52,10 +59,27 @@ int spl_parse_legacy_header(struct spl_image_info *spl_image, return 0; }
+/* + * This function is added explicitly to avoid code size increase, when + * no compression method is enabled. The compiler will optimize the + * following switch/case statement in spl_load_legacy_img() away due to + * Dead Code Elimination. + */ +static inline int spl_image_get_comp(const struct image_header *hdr) +{ + if (IS_ENABLED(CONFIG_SPL_LZMA)) + return image_get_comp(hdr); + + return IH_COMP_NONE; +} + int spl_load_legacy_img(struct spl_image_info *spl_image, struct spl_load_info *load, ulong header) { + __maybe_unused SizeT lzma_len; + __maybe_unused void *src; struct image_header hdr; + ulong dataptr; int ret;
/* Read header into local struct */ @@ -65,9 +89,43 @@ int spl_load_legacy_img(struct spl_image_info *spl_image, if (ret) return ret;
+ dataptr = header + sizeof(hdr); + /* Read image */ - load->read(load, header + sizeof(hdr), spl_image->size, - (void *)(unsigned long)spl_image->load_addr); + switch (spl_image_get_comp(&hdr)) { + case IH_COMP_NONE: + load->read(load, dataptr, spl_image->size, + (void *)(unsigned long)spl_image->load_addr); + break; + + case IH_COMP_LZMA: + lzma_len = LZMA_LEN; + + debug("LZMA: Decompressing %08lx to %08lx\n", + dataptr, spl_image->load_addr); + src = malloc(spl_image->size); + if (!src) { + printf("Unable to allocate %d bytes for LZMA\n", + spl_image->size); + return -ENOMEM; + } + + load->read(load, dataptr, spl_image->size, src); + ret = lzmaBuffToBuffDecompress((void *)spl_image->load_addr, + &lzma_len, src, spl_image->size); + if (ret) { + printf("LZMA decompression error: %d\n", ret); + return ret; + } + + spl_image->size = lzma_len; + break; + + default: + debug("Compression method %s is not supported\n", + genimg_get_comp_short_name(image_get_comp(&hdr))); + return -EINVAL; + }
return 0; }
This patch adds a MIPS specific jump_to_image_no_args() implementation, which flushes the U-Boot proper image loaded from the boot device in SPL before jumping to it.
It has been noticed on MT76x8, that this cache flush is needed. Other MIPS platforms might need it as well.
Signed-off-by: Stefan Roese sr@denx.de Cc: Weijie Gao weijie.gao@mediatek.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com --- Changes in v7: - Moved to MIPS specific file as suggested by Daniel
arch/mips/lib/Makefile | 1 + arch/mips/lib/spl.c | 21 +++++++++++++++++++++ 2 files changed, 22 insertions(+) create mode 100644 arch/mips/lib/spl.c
diff --git a/arch/mips/lib/Makefile b/arch/mips/lib/Makefile index 24a72d9c97..9ee1fcb5c7 100644 --- a/arch/mips/lib/Makefile +++ b/arch/mips/lib/Makefile @@ -12,5 +12,6 @@ obj-y += traps.o
obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-$(CONFIG_CMD_GO) += boot.o +obj-$(CONFIG_SPL_BUILD) += spl.o
lib-$(CONFIG_USE_PRIVATE_LIBGCC) += ashldi3.o ashrdi3.o lshrdi3.o diff --git a/arch/mips/lib/spl.c b/arch/mips/lib/spl.c new file mode 100644 index 0000000000..7ba3e53f6d --- /dev/null +++ b/arch/mips/lib/spl.c @@ -0,0 +1,21 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Stefan Roese sr@denx.de + */ + +#include <common.h> +#include <cpu_func.h> +#include <spl.h> + +void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) +{ + typedef void __noreturn (*image_entry_noargs_t)(void); + image_entry_noargs_t image_entry = + (image_entry_noargs_t)spl_image->entry_point; + + /* Flush cache before jumping to application */ + flush_cache((unsigned long)spl_image->load_addr, spl_image->size); + + debug("image entry point: 0x%lx\n", spl_image->entry_point); + image_entry(); +}
Changes in v7:
Changes in v6:
- New patch
This patch adds SPL support for mtmips platform. The lowlevel architecture is split into SPL and the rest parts are built into a memory loadable u-boot image. Optional SPL_DM and OF_CONTROL are also supported.
The increment of size is very small (< 10 KiB) if SPL_DM and OF_CONTROL are not enabled and the memory bootable u-boot (u-boot.img) is generated automatically so there is not need to add a separate config for it.
A lzma compressed payload (u-boot-lzma.img) is also generated and it will be combined with u-boot-spl.bin to form the unified ROM bootable binary u-boot-mtmips.bin.
A spl loader is added to support uncompress the payload.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: generate output file using u-boot-with-spl.bin
Makefile | 6 +++ arch/mips/Kconfig | 3 ++ arch/mips/dts/mt7628-u-boot.dtsi | 56 +++++++++++++++++++++ arch/mips/dts/mt7628a.dtsi | 2 +- arch/mips/mach-mtmips/Kconfig | 26 ++++++++++ arch/mips/mach-mtmips/Makefile | 1 + arch/mips/mach-mtmips/include/mach/serial.h | 13 +++++ arch/mips/mach-mtmips/mt7628/Makefile | 1 + arch/mips/mach-mtmips/mt7628/serial.c | 34 +++++++++++++ arch/mips/mach-mtmips/spl.c | 44 ++++++++++++++++ 10 files changed, 185 insertions(+), 1 deletion(-) create mode 100644 arch/mips/dts/mt7628-u-boot.dtsi create mode 100644 arch/mips/mach-mtmips/include/mach/serial.h create mode 100644 arch/mips/mach-mtmips/mt7628/serial.c create mode 100644 arch/mips/mach-mtmips/spl.c
diff --git a/Makefile b/Makefile index ffc1e28bd0..1e619bfc8b 100644 --- a/Makefile +++ b/Makefile @@ -938,6 +938,12 @@ endif
ALL-$(CONFIG_ARCH_MEDIATEK) += u-boot-mtk.bin
+ifeq ($(CONFIG_SPL),y) +ALL-$(CONFIG_ARCH_MTMIPS) += u-boot-with-spl.bin +else +ALL-$(CONFIG_ARCH_MTMIPS) += u-boot.bin +endif + # Add optional build target if defined in board/cpu/soc headers ifneq ($(CONFIG_BUILD_TARGET),) ALL-y += $(CONFIG_BUILD_TARGET:"%"=%) diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 7b9d0072eb..4c1eea1ccc 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -98,6 +98,9 @@ config ARCH_MTMIPS select SUPPORTS_CPU_MIPS32_R2 select SUPPORTS_LITTLE_ENDIAN select SYSRESET + select SUPPORT_SPL + select SPL_LZMA + select BINMAN
config ARCH_JZ47XX bool "Support Ingenic JZ47xx" diff --git a/arch/mips/dts/mt7628-u-boot.dtsi b/arch/mips/dts/mt7628-u-boot.dtsi new file mode 100644 index 0000000000..9149187762 --- /dev/null +++ b/arch/mips/dts/mt7628-u-boot.dtsi @@ -0,0 +1,56 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +/ { + binman { + filename = "u-boot-mips.bin"; + pad-byte = <0xff>; + +#ifdef CONFIG_SPL + u-boot-spl { + }; + + u-boot-lzma-img { + }; +#else + u-boot { + }; +#endif + }; +}; + +&palmbus { + u-boot,dm-pre-reloc; +}; + +&reboot { + u-boot,dm-pre-reloc; +}; + +&clkctrl { + u-boot,dm-pre-reloc; +}; + +&rstctrl { + u-boot,dm-pre-reloc; +}; + +&pinctrl { + u-boot,dm-pre-reloc; +}; + +&uart0 { + u-boot,dm-pre-reloc; +}; + +&uart1 { + u-boot,dm-pre-reloc; +}; + +&uart2 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index 2200135a77..6baa63add3 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -33,7 +33,7 @@ #clock-cells = <0>; };
- palmbus@10000000 { + palmbus: palmbus@10000000 { compatible = "palmbus", "simple-bus"; reg = <0x10000000 0x200000>; ranges = <0x0 0x10000000 0x1FFFFF>; diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 3f25de8b85..81cec53e72 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -20,8 +20,18 @@ config SYS_ICACHE_LINE_SIZE default 32
config SYS_TEXT_BASE + default 0x9c000000 if !SPL + default 0x80200000 if SPL + +config SPL_TEXT_BASE default 0x9c000000
+config SPL_LOADER_SUPPORT + default y + +config SPL_PAYLOAD + default "u-boot-lzma.img" + choice prompt "MediaTek MIPS SoC select"
@@ -34,6 +44,14 @@ config SOC_MT7628 select PINCTRL_MT7628 select MTK_SERIAL select SYSRESET_RESETCTL + select SPL_SEPARATE_BSS if SPL + select SPL_INIT_STACK_WITHOUT_MALLOC_F if SPL + select SPL_OF_CONTROL if SPL_DM + select SPL_SIMPLE_BUS if SPL_DM + select SPL_DM_SERIAL if SPL_DM + select SPL_CLK if SPL_DM && SPL_SERIAL_SUPPORT + select SPL_SYSRESET if SPL_DM + select SPL_OF_LIBFDT if SPL_OF_CONTROL help This supports MediaTek MT7628/MT7688.
@@ -88,6 +106,14 @@ endchoice config SUPPORTS_BOOT_RAM bool
+config SPL_UART2_SPIS_PINMUX + bool "Use alternative pinmux for UART2 in SPL stage" + depends on SPL_SERIAL_SUPPORT + default n + help + Select this if the UART2 of your board is connected to GPIO 16/17 + (shared with SPIS) rather than the usual GPIO 20/21. + source "board/gardena/smart-gateway-mt7688/Kconfig" source "board/seeed/linkit-smart-7688/Kconfig"
diff --git a/arch/mips/mach-mtmips/Makefile b/arch/mips/mach-mtmips/Makefile index 72f0369030..a7e6a66304 100644 --- a/arch/mips/mach-mtmips/Makefile +++ b/arch/mips/mach-mtmips/Makefile @@ -3,5 +3,6 @@ obj-y += cpu.o obj-y += ddr_init.o obj-y += ddr_cal.o +obj-$(CONFIG_SPL_BUILD) += spl.o
obj-$(CONFIG_SOC_MT7628) += mt7628/ diff --git a/arch/mips/mach-mtmips/include/mach/serial.h b/arch/mips/mach-mtmips/include/mach/serial.h new file mode 100644 index 0000000000..bfa246b428 --- /dev/null +++ b/arch/mips/mach-mtmips/include/mach/serial.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _MTMIPS_SERIAL_H_ +#define _MTMIPS_SERIAL_H_ + +void mtmips_spl_serial_init(void); + +#endif /* _MTMIPS_SERIAL_H_ */ diff --git a/arch/mips/mach-mtmips/mt7628/Makefile b/arch/mips/mach-mtmips/mt7628/Makefile index db62e90d77..7e139d5adf 100644 --- a/arch/mips/mach-mtmips/mt7628/Makefile +++ b/arch/mips/mach-mtmips/mt7628/Makefile @@ -3,3 +3,4 @@ obj-y += lowlevel_init.o obj-y += init.o obj-y += ddr.o +obj-$(CONFIG_SPL_BUILD) += serial.o diff --git a/arch/mips/mach-mtmips/mt7628/serial.c b/arch/mips/mach-mtmips/mt7628/serial.c new file mode 100644 index 0000000000..a7d324792d --- /dev/null +++ b/arch/mips/mach-mtmips/mt7628/serial.c @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <asm/io.h> +#include "mt7628.h" + +void mtmips_spl_serial_init(void) +{ +#ifdef CONFIG_SPL_SERIAL_SUPPORT + void __iomem *base = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + +#if CONFIG_CONS_INDEX == 1 + clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART0_MODE_M); +#elif CONFIG_CONS_INDEX == 2 + clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART1_MODE_M); +#elif CONFIG_CONS_INDEX == 3 + setbits_32(base + SYSCTL_AGPIO_CFG_REG, EPHY_GPIO_AIO_EN_M); +#ifdef CONFIG_SPL_UART2_SPIS_PINMUX + setbits_32(base + SYSCTL_GPIO_MODE1_REG, SPIS_MODE_M); + clrsetbits_32(base + SYSCTL_GPIO_MODE1_REG, UART2_MODE_M, + 1 << UART2_MODE_S); +#else + clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART2_MODE_M); + clrsetbits_32(base + SYSCTL_GPIO_MODE1_REG, SPIS_MODE_M, + 1 << SPIS_MODE_S); +#endif /* CONFIG_SPL_UART2_SPIS_PINMUX */ +#endif /* CONFIG_CONS_INDEX */ +#endif /* CONFIG_SPL_SERIAL_SUPPORT */ +} diff --git a/arch/mips/mach-mtmips/spl.c b/arch/mips/mach-mtmips/spl.c new file mode 100644 index 0000000000..2a24af70c3 --- /dev/null +++ b/arch/mips/mach-mtmips/spl.c @@ -0,0 +1,44 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <fdt.h> +#include <spl.h> +#include <asm/sections.h> +#include <linux/sizes.h> +#include <mach/serial.h> + +void __noreturn board_init_f(ulong dummy) +{ + spl_init(); + +#ifdef CONFIG_SPL_SERIAL_SUPPORT + /* + * mtmips_spl_serial_init() is useful if debug uart is enabled, + * or DM based serial is not enabled. + */ + mtmips_spl_serial_init(); + preloader_console_init(); +#endif + + board_init_r(NULL, 0); +} + +void board_boot_order(u32 *spl_boot_list) +{ + spl_boot_list[0] = BOOT_DEVICE_NOR; +} + +unsigned long spl_nor_get_uboot_base(void) +{ + void *uboot_base = __image_copy_end; + + if (fdt_magic(uboot_base) == FDT_MAGIC) + return (unsigned long)uboot_base + fdt_totalsize(uboot_base); + + return (unsigned long)uboot_base; +}
- select SUPPORT_SPL
- select SPL_LZMA
- select BINMAN
- Copyright (C) 2020 MediaTek Inc.
- Author: Weijie Gao weijie.gao@mediatek.com
- binman {
pad-byte = <0xff>;
+#ifdef CONFIG_SPL
u-boot-spl {
u-boot-lzma-img {
+#else
u-boot {
+&palmbus {
- u-boot,dm-pre-reloc;
+&reboot {
+&clkctrl {
+&rstctrl {
+&pinctrl {
+&uart0 {
+&uart1 {
+&uart2 {
- palmbus: palmbus@10000000 { compatible = "palmbus", "simple-bus"; reg = <0x10000000 0x200000>; ranges = <0x0 0x10000000 0x1FFFFF>;
- default 0x9c000000 if !SPL
- default 0x80200000 if SPL
- default y
on my request this was introduced as generic MIPS symbol with patch 13/26. So maybe it's a left-over and should be removed. Either "config ARCH_MTMIPS" or "config SOC_MT7628" should select this symbol.
+config SPL_PAYLOAD
- default "u-boot-lzma.img"
- select SPL_SEPARATE_BSS if SPL
- select SPL_INIT_STACK_WITHOUT_MALLOC_F if SPL
- select SPL_OF_CONTROL if SPL_DM
- select SPL_SIMPLE_BUS if SPL_DM
- select SPL_DM_SERIAL if SPL_DM
- select SPL_CLK if SPL_DM && SPL_SERIAL_SUPPORT
- select SPL_SYSRESET if SPL_DM
- select SPL_OF_LIBFDT if SPL_OF_CONTROL help This supports MediaTek MT7628/MT7688.
- bool "Use alternative pinmux for UART2 in SPL stage"
- depends on SPL_SERIAL_SUPPORT
- default n
- help
- void __iomem *base = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE);
- clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART0_MODE_M);
- clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART1_MODE_M);
- setbits_32(base + SYSCTL_AGPIO_CFG_REG, EPHY_GPIO_AIO_EN_M);
- setbits_32(base + SYSCTL_GPIO_MODE1_REG, SPIS_MODE_M);
- clrsetbits_32(base + SYSCTL_GPIO_MODE1_REG, UART2_MODE_M,
1 << UART2_MODE_S);
+#else
- clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART2_MODE_M);
- clrsetbits_32(base + SYSCTL_GPIO_MODE1_REG, SPIS_MODE_M,
1 << SPIS_MODE_S);
- Copyright (C) 2020 MediaTek Inc. All Rights Reserved.
- spl_init();
- mtmips_spl_serial_init();
- preloader_console_init();
- board_init_r(NULL, 0);
- spl_boot_list[0] = BOOT_DEVICE_NOR;
- void *uboot_base = __image_copy_end;
- if (fdt_magic(uboot_base) == FDT_MAGIC)
- return (unsigned long)uboot_base;
Hi Daniel,
- # Add optional build target if defined in board/cpu/soc headers ifneq ($(CONFIG_BUILD_TARGET),) ALL-y += $(CONFIG_BUILD_TARGET:"%"=%)
select SUPPORT_SPL
select SPL_LZMA
select BINMAN
- binman {
pad-byte = <0xff>;
+#ifdef CONFIG_SPL
u-boot-spl {
u-boot-lzma-img {
+#else
u-boot {
+&palmbus {
+&reboot {
+&clkctrl {
+&rstctrl {
+&pinctrl {
+&uart0 {
+&uart1 {
+&uart2 {
- default y
Thanks for spotting. Would it be okay to fix this up with an incremental patch once this series is in mainline, to not "pollute" the list more? If no other changes are required of course.
Thanks, Stefan
Am 21.04.20 um 13:34 schrieb Stefan Roese:
Hi Daniel,
diff --git a/Makefile b/Makefile index ffc1e28bd0..1e619bfc8b 100644 --- a/Makefile +++ b/Makefile @@ -938,6 +938,12 @@ endif ALL-$(CONFIG_ARCH_MEDIATEK) += u-boot-mtk.bin +ifeq ($(CONFIG_SPL),y) +ALL-$(CONFIG_ARCH_MTMIPS) += u-boot-with-spl.bin +else +ALL-$(CONFIG_ARCH_MTMIPS) += u-boot.bin +endif
# Add optional build target if defined in board/cpu/soc headers ifneq ($(CONFIG_BUILD_TARGET),) ALL-y += $(CONFIG_BUILD_TARGET:"%"=%) diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 7b9d0072eb..4c1eea1ccc 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -98,6 +98,9 @@ config ARCH_MTMIPS select SUPPORTS_CPU_MIPS32_R2 select SUPPORTS_LITTLE_ENDIAN select SYSRESET + select SUPPORT_SPL + select SPL_LZMA + select BINMAN config ARCH_JZ47XX bool "Support Ingenic JZ47xx" diff --git a/arch/mips/dts/mt7628-u-boot.dtsi b/arch/mips/dts/mt7628-u-boot.dtsi new file mode 100644 index 0000000000..9149187762 --- /dev/null +++ b/arch/mips/dts/mt7628-u-boot.dtsi @@ -0,0 +1,56 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
+&uart2 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index 2200135a77..6baa63add3 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -33,7 +33,7 @@ #clock-cells = <0>; }; - palmbus@10000000 { + palmbus: palmbus@10000000 { compatible = "palmbus", "simple-bus"; reg = <0x10000000 0x200000>; ranges = <0x0 0x10000000 0x1FFFFF>; diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 3f25de8b85..81cec53e72 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -20,8 +20,18 @@ config SYS_ICACHE_LINE_SIZE default 32 config SYS_TEXT_BASE + default 0x9c000000 if !SPL + default 0x80200000 if SPL
+config SPL_TEXT_BASE default 0x9c000000 +config SPL_LOADER_SUPPORT + default y
Thanks, Stefan
I could fix it when applying, but I'm not sure about ARCH_MTMIPS or SOC_MT7628
On 21.04.20 13:57, Daniel Schwierzeck wrote:
<snip>
Thanks, Stefan
That would be most welcome. Please go with "SOC_MT7628".
Thanks, Stefan
This patch enables SPL for all mtmips boards. And also remove defconfig files which are intend to build ram bootable u-boot files.
SPL_DM and OF_CONTROL are enabled for both boards.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: add CONFIG_SPL_PAD_TO=0 to make sure no padding added
arch/mips/mach-mtmips/Kconfig | 26 ------- board/gardena/smart-gateway-mt7688/board.c | 2 + ...gardena-smart-gateway-mt7688-ram_defconfig | 74 ------------------- .../gardena-smart-gateway-mt7688_defconfig | 10 ++- configs/linkit-smart-7688-ram_defconfig | 65 ---------------- configs/linkit-smart-7688_defconfig | 10 ++- .../configs/gardena-smart-gateway-mt7688.h | 21 +++++- include/configs/linkit-smart-7688.h | 22 +++++- 8 files changed, 59 insertions(+), 171 deletions(-) delete mode 100644 configs/gardena-smart-gateway-mt7688-ram_defconfig delete mode 100644 configs/linkit-smart-7688-ram_defconfig
diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 81cec53e72..ad28ef3a8c 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -64,7 +64,6 @@ config BOARD_GARDENA_SMART_GATEWAY_MT7688 bool "GARDENA smart Gateway" depends on SOC_MT7628 select BOARD_LATE_INIT - select SUPPORTS_BOOT_RAM help GARDENA smart Gateway boards have a MT7688 SoC with 128 MiB of RAM and 8 MiB of flash (SPI NOR) and additional SPI NAND storage. @@ -72,7 +71,6 @@ config BOARD_GARDENA_SMART_GATEWAY_MT7688 config BOARD_LINKIT_SMART_7688 bool "LinkIt Smart 7688" depends on SOC_MT7628 - select SUPPORTS_BOOT_RAM help Seeed LinkIt Smart 7688 boards have a MT7688 SoC with 128 MiB of RAM and 32 MiB of flash (SPI). @@ -82,30 +80,6 @@ config BOARD_LINKIT_SMART_7688
endchoice
-choice - prompt "Boot mode" - -config BOOT_RAM - bool "RAM boot" - depends on SUPPORTS_BOOT_RAM - help - This builds an image that is linked to a RAM address. It can be used - for booting from CFE via TFTP using an ELF image, but it can also be - booted from RAM by other bootloaders using a BIN image. - -config BOOT_ROM - bool "ROM boot" - depends on SUPPORTS_BOOT_RAM - help - This builds an image that is linked to a ROM address. It can be - used as main bootloader image which is programmed onto the onboard - flash storage (SPI NOR). - -endchoice - -config SUPPORTS_BOOT_RAM - bool - config SPL_UART2_SPIS_PINMUX bool "Use alternative pinmux for UART2 in SPL stage" depends on SPL_SERIAL_SUPPORT diff --git a/board/gardena/smart-gateway-mt7688/board.c b/board/gardena/smart-gateway-mt7688/board.c index 48cf3091e9..776afa43a6 100644 --- a/board/gardena/smart-gateway-mt7688/board.c +++ b/board/gardena/smart-gateway-mt7688/board.c @@ -295,8 +295,10 @@ err_free: return ret; }
+#ifndef CONFIG_SPL_BUILD U_BOOT_CMD( fd_write, 1, 0, do_fd_write, "Write test factory-data values to SPI NOR", "\n" ); +#endif diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig deleted file mode 100644 index 48b7a43633..0000000000 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ /dev/null @@ -1,74 +0,0 @@ -CONFIG_MIPS=y -CONFIG_SYS_TEXT_BASE=0x80010000 -CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_ENV_OFFSET=0xA0000 -CONFIG_SYS_BOOTCOUNT_ADDR=0xb000006c -CONFIG_NR_DRAM_BANKS=1 -CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y -CONFIG_ENV_OFFSET_REDUND=0xB0000 -CONFIG_ARCH_MTMIPS=y -CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y -# CONFIG_MIPS_BOOT_ENV_LEGACY is not set -CONFIG_MIPS_BOOT_FDT=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_OF_STDOUT_VIA_ALIAS=y -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="cp.b 83000000 84000000 10000 && dhcp uEnv.txt && env import -t ${fileaddr} ${filesize} && run do_u_boot_init; reset" -CONFIG_USE_PREBOOT=y -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_LICENSE=y -# CONFIG_CMD_ELF is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_MEMINFO=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -# CONFIG_CMD_LOADS is not set -CONFIG_CMD_MTD=y -CONFIG_CMD_SPI=y -CONFIG_CMD_WDT=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_BOOTCOUNT=y -CONFIG_CMD_TIME=y -CONFIG_CMD_UUID=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="spi-nand0=spi0.1,nor0=spi0.0" -CONFIG_MTDPARTS_DEFAULT="spi0.0:640k(uboot),64k(uboot_env0),64k(uboot_env1),64k(factory),-(unused);spi0.1:-(nand)" -CONFIG_CMD_UBI=y -CONFIG_DEFAULT_DEVICE_TREE="gardena-smart-gateway-mt7688" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -# CONFIG_DM_DEVICE_REMOVE is not set -CONFIG_HAVE_BLOCK_DEVICE=y -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_LED=y -CONFIG_LED_BLINK=y -CONFIG_LED_GPIO=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_SPI_NAND=y -CONFIG_SPI_FLASH_GIGADEVICE=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_SPI_FLASH_XMC=y -CONFIG_SPI_FLASH_MTD=y -CONFIG_MTD_UBI_BEB_LIMIT=22 -CONFIG_MT7628_ETH=y -CONFIG_PHY=y -CONFIG_SPI=y -CONFIG_MT7621_SPI=y -CONFIG_WDT=y -CONFIG_WDT_MT7621=y -CONFIG_LZMA=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 0209af0fc9..e01fc937c1 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -1,14 +1,17 @@ CONFIG_MIPS=y -CONFIG_SYS_TEXT_BASE=0x9c000000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ENV_OFFSET=0xA0000 CONFIG_SYS_BOOTCOUNT_ADDR=0xb000006c +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x20000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_ENV_OFFSET_REDUND=0xB0000 CONFIG_ARCH_MTMIPS=y -CONFIG_BOOT_ROM=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y @@ -23,6 +26,8 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_LICENSE=y # CONFIG_CMD_ELF is not set @@ -49,6 +54,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_HAVE_BLOCK_DEVICE=y CONFIG_BOOTCOUNT_LIMIT=y diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig deleted file mode 100644 index 1db94db41f..0000000000 --- a/configs/linkit-smart-7688-ram_defconfig +++ /dev/null @@ -1,65 +0,0 @@ -CONFIG_MIPS=y -CONFIG_SYS_TEXT_BASE=0x80010000 -CONFIG_ENV_SIZE=0x4000 -CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_ENV_OFFSET=0x80000 -CONFIG_NR_DRAM_BANKS=1 -CONFIG_ARCH_MTMIPS=y -CONFIG_BOARD_LINKIT_SMART_7688=y -CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y -# CONFIG_MIPS_BOOT_ENV_LEGACY is not set -CONFIG_MIPS_BOOT_FDT=y -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_OF_STDOUT_VIA_ALIAS=y -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_LICENSE=y -# CONFIG_CMD_ELF is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_MEMINFO=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -# CONFIG_CMD_LOADS is not set -CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_TIME=y -CONFIG_CMD_FS_GENERIC=y -# CONFIG_DOS_PARTITION is not set -CONFIG_DEFAULT_DEVICE_TREE="linkit-smart-7688" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -# CONFIG_DM_DEVICE_REMOVE is not set -CONFIG_BLK=y -CONFIG_LED=y -CONFIG_LED_BLINK=y -CONFIG_LED_GPIO=y -CONFIG_MTD=y -CONFIG_SPI_FLASH_GIGADEVICE=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_SPI_FLASH_MTD=y -CONFIG_MT7628_ETH=y -CONFIG_PHY=y -CONFIG_MT76X8_USB_PHY=y -CONFIG_SPI=y -CONFIG_MT7621_SPI=y -CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_EHCI_GENERIC=y -CONFIG_USB_STORAGE=y -CONFIG_FS_EXT4=y -CONFIG_FS_FAT=y -CONFIG_LZMA=y -CONFIG_LZO=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 34066dd293..642755ec65 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -1,12 +1,15 @@ CONFIG_MIPS=y -CONFIG_SYS_TEXT_BASE=0x9c000000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ENV_OFFSET=0x80000 +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x20000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y CONFIG_ARCH_MTMIPS=y CONFIG_BOARD_LINKIT_SMART_7688=y -CONFIG_BOOT_ROM=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y @@ -16,6 +19,8 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_LICENSE=y # CONFIG_CMD_ELF is not set @@ -39,6 +44,7 @@ CONFIG_DEFAULT_DEVICE_TREE="linkit-smart-7688" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_BLK=y CONFIG_LED=y diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h index 59c60743d2..6412efcbf8 100644 --- a/include/configs/gardena-smart-gateway-mt7688.h +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -16,10 +16,29 @@
#define CONFIG_SYS_INIT_SP_OFFSET 0x400000
-#ifdef CONFIG_BOOT_RAM +/* SPL */ +#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) #define CONFIG_SKIP_LOWLEVEL_INIT #endif
+#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SPL_BSS_START_ADDR 0x80010000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x10000 +#define CONFIG_SPL_MAX_SIZE 0x10000 +#define CONFIG_SPL_PAD_TO 0 + +/* Dummy value */ +#define CONFIG_SYS_UBOOT_BASE 0 + +/* Serial SPL */ +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL_SUPPORT) +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_NS16550_CLK 40000000 +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM1 0xb0000c00 +#define CONFIG_CONS_INDEX 1 +#endif + /* UART */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ 230400, 460800, 921600 } diff --git a/include/configs/linkit-smart-7688.h b/include/configs/linkit-smart-7688.h index ca5b693e4c..4276e95dee 100644 --- a/include/configs/linkit-smart-7688.h +++ b/include/configs/linkit-smart-7688.h @@ -16,10 +16,30 @@
+#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SPL_BSS_START_ADDR 0x80010000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x10000 +#define CONFIG_SPL_MAX_SIZE 0x10000 +#define CONFIG_SPL_PAD_TO 0 + +/* Dummy value */ +#define CONFIG_SYS_UBOOT_BASE 0 + +/* Serial SPL */ +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL_SUPPORT) +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_NS16550_CLK 40000000 +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM3 0xb0000e00 +#define CONFIG_CONS_INDEX 3 + +#endif + /* UART */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ 230400, 460800, 921600 }
This patch adds support for mt7628 reference board. SPL_DM and DT are not enabled for SPL to save about 17KiB for u-boot-spl.bin.
arch/mips/dts/Makefile | 1 + arch/mips/dts/mediatek,mt7628-rfb.dts | 67 +++++++++++++++++++++++++++ arch/mips/mach-mtmips/Kconfig | 9 ++++ board/mediatek/mt7628/Kconfig | 12 +++++ board/mediatek/mt7628/MAINTAINERS | 7 +++ board/mediatek/mt7628/Makefile | 3 ++ board/mediatek/mt7628/board.c | 8 ++++ configs/mt7628_rfb_defconfig | 46 ++++++++++++++++++ include/configs/mt7628.h | 56 ++++++++++++++++++++++ 9 files changed, 209 insertions(+) create mode 100644 arch/mips/dts/mediatek,mt7628-rfb.dts create mode 100644 board/mediatek/mt7628/Kconfig create mode 100644 board/mediatek/mt7628/MAINTAINERS create mode 100644 board/mediatek/mt7628/Makefile create mode 100644 board/mediatek/mt7628/board.c create mode 100644 configs/mt7628_rfb_defconfig create mode 100644 include/configs/mt7628.h
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index c9d75596f2..cbd0c8bc8b 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -17,6 +17,7 @@ dtb-$(CONFIG_BOARD_COMTREND_CT5361) += comtrend,ct-5361.dtb dtb-$(CONFIG_BOARD_COMTREND_VR3032U) += comtrend,vr-3032u.dtb dtb-$(CONFIG_BOARD_COMTREND_WAP5813N) += comtrend,wap-5813n.dtb dtb-$(CONFIG_BOARD_HUAWEI_HG556A) += huawei,hg556a.dtb +dtb-$(CONFIG_BOARD_MT7628_RFB) += mediatek,mt7628-rfb.dtb dtb-$(CONFIG_BOARD_NETGEAR_CG3100D) += netgear,cg3100d.dtb dtb-$(CONFIG_BOARD_NETGEAR_DGND3700V2) += netgear,dgnd3700v2.dtb dtb-$(CONFIG_BOARD_SAGEM_FAST1704) += sagem,f@st1704.dtb diff --git a/arch/mips/dts/mediatek,mt7628-rfb.dts b/arch/mips/dts/mediatek,mt7628-rfb.dts new file mode 100644 index 0000000000..6ff36daa6e --- /dev/null +++ b/arch/mips/dts/mediatek,mt7628-rfb.dts @@ -0,0 +1,67 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +/dts-v1/; + +#include "mt7628a.dtsi" + +/ { + compatible = "mediatek,mt7628-rfb", "ralink,mt7628a-soc"; + model = "MediaTek MT7628 RFB"; + + aliases { + serial0 = &uart0; + spi0 = &spi0; + }; + + chosen { + stdout-path = &uart0; + }; +}; + +&pinctrl { + state_default: pin_state { + pleds { + groups = "p0led", "p1led", "p2led", "p3led", "p4led"; + function = "led"; + }; + }; +}; + +&uart0 { + status = "okay"; +}; + +&spi0 { + status = "okay"; + num-cs = <2>; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <25000000>; + reg = <0>; + }; +}; + +ð { + mediatek,wan-port = <0>; + + pinctrl-names = "default"; + pinctrl-0 = <&ephy_router_mode>; +}; + +&mmc { + bus-width = <4>; + cap-sd-highspeed; + + pinctrl-names = "default"; + pinctrl-0 = <&sd_router_mode>; + + status = "okay"; +}; diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index ad28ef3a8c..5931081556 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -78,6 +78,14 @@ config BOARD_LINKIT_SMART_7688 ethernet ports, 1 USB port, 1 UART, GPIO buttons and LEDs, and a MT7688 (PCIe).
+config BOARD_MT7628_RFB + bool "MediaTek MT7628 RFB" + depends on SOC_MT7628 + help + The reference design of MT7628. The board has 128 MiB DDR2, 8 MiB + SPI-NOR flash, 1 built-in switch with 5 ports, 1 UART, 1 USB host, + 1 SDXC, 1 PCIe socket and JTAG pins. + endchoice
config SPL_UART2_SPIS_PINMUX @@ -89,6 +97,7 @@ config SPL_UART2_SPIS_PINMUX (shared with SPIS) rather than the usual GPIO 20/21.
source "board/gardena/smart-gateway-mt7688/Kconfig" +source "board/mediatek/mt7628/Kconfig" source "board/seeed/linkit-smart-7688/Kconfig"
endmenu diff --git a/board/mediatek/mt7628/Kconfig b/board/mediatek/mt7628/Kconfig new file mode 100644 index 0000000000..d6b6f9d632 --- /dev/null +++ b/board/mediatek/mt7628/Kconfig @@ -0,0 +1,12 @@ +if BOARD_MT7628_RFB + +config SYS_BOARD + default "mt7628" + +config SYS_VENDOR + default "mediatek" + +config SYS_CONFIG_NAME + default "mt7628" + +endif diff --git a/board/mediatek/mt7628/MAINTAINERS b/board/mediatek/mt7628/MAINTAINERS new file mode 100644 index 0000000000..032fd0e2f7 --- /dev/null +++ b/board/mediatek/mt7628/MAINTAINERS @@ -0,0 +1,7 @@ +MT7628_RFB BOARD +M: Weijie Gao weijie.gao@mediatek.com +S: Maintained +F: board/mediatek/mt7628 +F: include/configs/mt7628.h +F: configs/mt7628_rfb_defconfig +F: arch/mips/dts/mediatek,mt7628-rfb.dts diff --git a/board/mediatek/mt7628/Makefile b/board/mediatek/mt7628/Makefile new file mode 100644 index 0000000000..db129c5aba --- /dev/null +++ b/board/mediatek/mt7628/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += board.o diff --git a/board/mediatek/mt7628/board.c b/board/mediatek/mt7628/board.c new file mode 100644 index 0000000000..f837a06fbb --- /dev/null +++ b/board/mediatek/mt7628/board.c @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> diff --git a/configs/mt7628_rfb_defconfig b/configs/mt7628_rfb_defconfig new file mode 100644 index 0000000000..eb73dbb490 --- /dev/null +++ b/configs/mt7628_rfb_defconfig @@ -0,0 +1,46 @@ +CONFIG_MIPS=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x30000 +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x20000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_ARCH_MTMIPS=y +CONFIG_BOARD_MT7628_RFB=y +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y +CONFIG_MIPS_BOOT_FDT=y +CONFIG_FIT=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_NOR_SUPPORT=y +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_DM is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_SPI=y +# CONFIG_CMD_NFS is not set +# CONFIG_PARTITIONS is not set +CONFIG_DEFAULT_DEVICE_TREE="mediatek,mt7628-rfb" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +# CONFIG_INPUT is not set +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_MT7628_ETH=y +# CONFIG_SPECIFY_CONSOLE_INDEX is not set +CONFIG_SPI=y +CONFIG_MT7621_SPI=y +CONFIG_LZMA=y diff --git a/include/configs/mt7628.h b/include/configs/mt7628.h new file mode 100644 index 0000000000..9b9218d296 --- /dev/null +++ b/include/configs/mt7628.h @@ -0,0 +1,56 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef __CONFIG_MT7628_H +#define __CONFIG_MT7628_H + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_MIPS_TIMER_FREQ 290000000 + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_MALLOC_LEN 0x100000 +#define CONFIG_SYS_BOOTPARAMS_LEN 0x20000 + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_LOAD_ADDR 0x80010000 + +#define CONFIG_SYS_INIT_SP_OFFSET 0x80000 + +#define CONFIG_SYS_BOOTM_LEN 0x1000000 + +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_CBSIZE 1024 + +/* Serial SPL */ +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL_SUPPORT) +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_NS16550_CLK 40000000 +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM1 0xb0000c00 +#define CONFIG_CONS_INDEX 1 +#endif + +/* Serial common */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ + 230400, 460800, 921600 } + +/* SPL */ +#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif + +#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SPL_BSS_START_ADDR 0x80010000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x10000 +#define CONFIG_SPL_MAX_SIZE 0x10000 +#define CONFIG_SPL_PAD_TO 0 + +/* Dummy value */ +#define CONFIG_SYS_UBOOT_BASE 0 + +#endif /* __CONFIG_MT7628_H */
Since SPL now uses malloc to allocate the buffer for the compressed image before decompression to the destination address, we need to configure a big enough malloc space in SPL. 256k seems to be big enough even for the GARDENA board.
Signed-off-by: Stefan Roese sr@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Weijie Gao weijie.gao@mediatek.com --- Changes in v7: - None
configs/gardena-smart-gateway-mt7688_defconfig | 4 ++-- configs/linkit-smart-7688_defconfig | 2 +- configs/mt7628_rfb_defconfig | 2 +- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index e01fc937c1..0aeba1e2e2 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -4,9 +4,9 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ENV_OFFSET=0xA0000 -CONFIG_SYS_BOOTCOUNT_ADDR=0xb000006c CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL_SYS_MALLOC_F_LEN=0x20000 +CONFIG_SYS_BOOTCOUNT_ADDR=0xb000006c +CONFIG_SPL_SYS_MALLOC_F_LEN=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 642755ec65..8e13cee58d 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -5,7 +5,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ENV_OFFSET=0x80000 CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL_SYS_MALLOC_F_LEN=0x20000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_ARCH_MTMIPS=y diff --git a/configs/mt7628_rfb_defconfig b/configs/mt7628_rfb_defconfig index eb73dbb490..ce3e0263d1 100644 --- a/configs/mt7628_rfb_defconfig +++ b/configs/mt7628_rfb_defconfig @@ -5,7 +5,7 @@ CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ENV_OFFSET=0x30000 CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL_SYS_MALLOC_F_LEN=0x20000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_ARCH_MTMIPS=y
This patch series are divided into two parts:
The main part is to rewrite the whole architecture code of mt7628:
- Lock parts of the d-cache for initial stack so the rest of the code can be reimplemented in C.
- Memory controller & DDR initialization have been fully written to support detecting DDR size automatically.
- DDR calibration has also been reimplemented with a clear logic.
- Implemented a new sysreset driver to take advantage of the reset controller so we can drop the use of syscon-based sysreset to reduce size.
The second part is to add SPL support for mt7628:
- With SPL enabled we can build the ROM-bootable and RAM-bootable binary simultaneously, and we can drop RAM boot related configs and defconfig files.
- Generate compressed u-boot.bin image for SPL to reduce size of final combined binary.
- Enable DM support for SPL for a more flexible device probing.
- Add a demo board (mt7628_rfb) aims at router application.
Changes since v2:
- Dropped a patch which removes unused parts of mt7628a.dtsi
- Move lzma decompression support to common spl_nor.c
- Move u-boot,dm-pre-reloc to u-boot-mt7628.dtsi
Changes since v3:
- Rebased on newest master branch
- Add a test for binman etype u-boot-lzma-img to make sure binman passes 100% code coverage
- Use u-boot-with-spl.bin for SPL-enabled output file
- Remove unused code from spl_nor loader.
Changes since v5:
- Made lzma decompressing support for legacy U-Boot images more generic, so that it can be easily integrated into other devices loaders as well
Changes since v6:
- Moved cache flush to MIPS specific file as suggested by Daniel
Stefan Roese (6): spl: Extract legacy image handling into separate file spl: spl_legacy: Use IS_ENABLED() to remove #ifdef spl: spl_nor: Move legacy image loading into spl_legacy.c spl: spl_nor: Remove unused variable 'ret' warning mips: spl: Flush cache before jumping to U-Boot proper mips: mtmips: Increase CONFIG_SPL_SYS_MALLOC_F_LEN
Weijie Gao (20): mips: add support to restore exception vector base before booting linux mips: mtmips: add predefined i-cache/d-cache size and linesize mips: add an option to support initialize SRAM for initial stack mips: start.S: avoid overwriting outside gd when clearing global data in stack sysreset: add reset controller based reboot driver mips: mtmips: make use of sysreset-resetctrl for mt7628 soc configs: enable CONFIG_RESTORE_EXCEPTION_VECTOR_BASE for all mtmips boards mips: add a mtmips-specific field to architecture-specific global data mips: add a option to support not reserving malloc space on initial stack mips: mtmips: rewrite lowlevel codes of mt7628 dts: mtmips: add alternative pinmux node for uart2 mips: enable support for appending dtb to spl binary mips: add an option to enable u_boot_list section for SPL loaders in u-boot-spl.lds lib: enable lzma decompression support for SPL build Makefile: add support to generate LZMA compressed u-boot image tools: binman: add etype file for u-boot-lzma-img spl: spl_legacy: Add lzma decompression support for legacy image mips: mtmips: add SPL support mips: mtmips: enable SPL for all boards mips: mtmips: add support for mt7628-rfb
Makefile | 19 + arch/mips/Kconfig | 66 ++++ arch/mips/cpu/start.S | 16 +- arch/mips/cpu/u-boot-spl.lds | 4 +- arch/mips/dts/Makefile | 1 + arch/mips/dts/mediatek,mt7628-rfb.dts | 67 ++++ arch/mips/dts/mt7628-u-boot.dtsi | 56 +++ arch/mips/dts/mt7628a.dtsi | 17 +- arch/mips/include/asm/global_data.h | 3 + arch/mips/include/asm/u-boot-mips.h | 2 + arch/mips/lib/Makefile | 1 + arch/mips/lib/bootm.c | 3 + arch/mips/lib/spl.c | 21 ++ arch/mips/lib/traps.c | 19 + arch/mips/mach-mtmips/Kconfig | 135 +++---- arch/mips/mach-mtmips/Makefile | 8 +- arch/mips/mach-mtmips/cpu.c | 58 +--- arch/mips/mach-mtmips/ddr_cal.c | 211 +++++++++++ arch/mips/mach-mtmips/ddr_calibrate.c | 309 ----------------- arch/mips/mach-mtmips/ddr_init.c | 194 +++++++++++ arch/mips/mach-mtmips/include/mach/ddr.h | 52 +++ arch/mips/mach-mtmips/include/mach/mc.h | 180 ++++++++++ arch/mips/mach-mtmips/include/mach/serial.h | 13 + arch/mips/mach-mtmips/lowlevel_init.S | 328 ------------------ arch/mips/mach-mtmips/mt7628/Makefile | 6 + arch/mips/mach-mtmips/mt7628/ddr.c | 173 +++++++++ arch/mips/mach-mtmips/mt7628/init.c | 109 ++++++ arch/mips/mach-mtmips/mt7628/lowlevel_init.S | 161 +++++++++ arch/mips/mach-mtmips/mt7628/mt7628.h | 104 ++++++ arch/mips/mach-mtmips/mt7628/serial.c | 34 ++ arch/mips/mach-mtmips/mt76xx.h | 32 -- arch/mips/mach-mtmips/spl.c | 44 +++ board/gardena/smart-gateway-mt7688/board.c | 2 + board/mediatek/mt7628/Kconfig | 12 + board/mediatek/mt7628/MAINTAINERS | 7 + board/mediatek/mt7628/Makefile | 3 + board/mediatek/mt7628/board.c | 8 + common/spl/Makefile | 1 + common/spl/spl.c | 56 +-- common/spl/spl_legacy.c | 131 +++++++ common/spl/spl_nor.c | 27 +- ...gardena-smart-gateway-mt7688-ram_defconfig | 74 ---- .../gardena-smart-gateway-mt7688_defconfig | 14 +- configs/linkit-smart-7688-ram_defconfig | 65 ---- configs/linkit-smart-7688_defconfig | 14 +- configs/mt7628_rfb_defconfig | 46 +++ drivers/sysreset/Kconfig | 6 + drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_resetctl.c | 48 +++ .../configs/gardena-smart-gateway-mt7688.h | 21 +- include/configs/linkit-smart-7688.h | 22 +- include/configs/mt7628.h | 56 +++ include/spl.h | 13 + lib/Kconfig | 5 + lib/Makefile | 1 + tools/binman/README.entries | 15 + tools/binman/etype/u_boot_lzma_img.py | 28 ++ tools/binman/ftest.py | 7 + tools/binman/test/156_u_boot_lzma_img.dts | 11 + 59 files changed, 2108 insertions(+), 1032 deletions(-) create mode 100644 arch/mips/dts/mediatek,mt7628-rfb.dts create mode 100644 arch/mips/dts/mt7628-u-boot.dtsi create mode 100644 arch/mips/lib/spl.c create mode 100644 arch/mips/mach-mtmips/ddr_cal.c delete mode 100644 arch/mips/mach-mtmips/ddr_calibrate.c create mode 100644 arch/mips/mach-mtmips/ddr_init.c create mode 100644 arch/mips/mach-mtmips/include/mach/ddr.h create mode 100644 arch/mips/mach-mtmips/include/mach/mc.h create mode 100644 arch/mips/mach-mtmips/include/mach/serial.h delete mode 100644 arch/mips/mach-mtmips/lowlevel_init.S create mode 100644 arch/mips/mach-mtmips/mt7628/Makefile create mode 100644 arch/mips/mach-mtmips/mt7628/ddr.c create mode 100644 arch/mips/mach-mtmips/mt7628/init.c create mode 100644 arch/mips/mach-mtmips/mt7628/lowlevel_init.S create mode 100644 arch/mips/mach-mtmips/mt7628/mt7628.h create mode 100644 arch/mips/mach-mtmips/mt7628/serial.c delete mode 100644 arch/mips/mach-mtmips/mt76xx.h create mode 100644 arch/mips/mach-mtmips/spl.c create mode 100644 board/mediatek/mt7628/Kconfig create mode 100644 board/mediatek/mt7628/MAINTAINERS create mode 100644 board/mediatek/mt7628/Makefile create mode 100644 board/mediatek/mt7628/board.c create mode 100644 common/spl/spl_legacy.c delete mode 100644 configs/gardena-smart-gateway-mt7688-ram_defconfig delete mode 100644 configs/linkit-smart-7688-ram_defconfig create mode 100644 configs/mt7628_rfb_defconfig create mode 100644 drivers/sysreset/sysreset_resetctl.c create mode 100644 include/configs/mt7628.h create mode 100644 tools/binman/etype/u_boot_lzma_img.py create mode 100644 tools/binman/test/156_u_boot_lzma_img.dts
series applied to u-boot-mips/next with some reordering of patches and some minor fixups. The binman patch was left out because binman wasn't used anymore since v4.
Daniel Schwierzeck
Stefan Roese
