Re: [U-Boot] [PATCH 2/3] ZOOM2 detect the version of the zoom2
Jean-Christophe,
Based on your review I have made the changes you asked for.
Tom
@@ -60,6 +61,46 @@ static u32 gpmc_serial_TL16CP754C[GPMC_MAX_REG] = { 0x1D0904C4, 0 };
+/* Used to track the revision of the board */ +int zoom2_revision = ZOOM2_REVISION_UNKNOWN;
add static and as the beagle provide a function to get the current version
Tom : Ok added See +/* Used to track the revision of the board */ +static ZOOM2_REVISION zoom2_revision = ZOOM2_REVISION_UNKNOWN; + +/* + * Routine: zoom2_get_revision + * Description: Return the revision of the Zoom2 this code is running on. + */ +ZOOM2_REVISION zoom2_get_revision(void) +{ + return zoom2_revision; +}
- printf("Board revision ");
- if (ZOOM2_REVISION_PRODUCTION == zoom2_revision)
printf("Production\n");
- else if (ZOOM2_REVISION_BETA == zoom2_revision)
printf("Beta\n");
- else
printf("Unknown\n");
please use switch
Tom : Ok done. See + switch (zoom2_revision) { + case (ZOOM2_REVISION_PRODUCTION): + printf("Production\n"); + break; + case (ZOOM2_REVISION_BETA): + printf("Beta\n"); + break; + default: + printf("Unknown\n"); + break; + } +}
+#define ZOOM2_REVISION_UNKNOWN 0 +#define ZOOM2_REVISION_ALPHA 1 +#define ZOOM2_REVISION_BETA 2 +#define ZOOM2_REVISION_PRODUCTION 3
please use an emum
Tom : Ok See +typedef enum { + ZOOM2_REVISION_UNKNOWN = 0, + ZOOM2_REVISION_ALPHA, + ZOOM2_REVISION_BETA, + ZOOM2_REVISION_PRODUCTION +} ZOOM2_REVISION;
Also changed this comment in beagle.c
/* * Routine: beagle_get_revision - * Description: Return revision of the BeagleBoard this code is running on. + * Description: Return the revision of the BeagleBoard this code is running on.
Using the example for reading a gpio, shows the problem. NULL should be the gpio number.
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- doc/README.omap3 | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/doc/README.omap3 b/doc/README.omap3 index e05e816..66e781d 100644 --- a/doc/README.omap3 +++ b/doc/README.omap3 @@ -106,7 +106,7 @@ To clear a bit : To read a bit :
if (!omap_request_gpio(N)) { - omap_set_gpio_direction(NULL, 1); + omap_set_gpio_direction(N, 1); val = omap_get_gpio_datain(N); omap_free_gpio(N); }
There are currently 3 versions of the zoom2 board. The production board, that is currently being released. The beta board, similar in form to the production board but not released. The alpha board, a set of PCBs with a very limited circulation.
GPIO 94 is used to determine the version of the board. If GPIO 94 is clear, the board is a production board, otherwise it is a beta board.
The alpha board will likely be mistaken for a beta board. An alpha board was unavailible for testing.
This has been tested on the beta and production boards.
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- board/omap3/zoom2/zoom2.c | 62 ++++++++++++++++++++++++++++++++++++++++++-- board/omap3/zoom2/zoom2.h | 9 ++++++ 2 files changed, 68 insertions(+), 3 deletions(-)
diff --git a/board/omap3/zoom2/zoom2.c b/board/omap3/zoom2/zoom2.c index e5c248d..94231da 100644 --- a/board/omap3/zoom2/zoom2.c +++ b/board/omap3/zoom2/zoom2.c @@ -33,6 +33,7 @@ #include <status_led.h> #endif #include <asm/io.h> +#include <asm/arch/gpio.h> #include <asm/arch/mem.h> #include <asm/arch/mux.h> #include <asm/arch/sys_proto.h> @@ -60,6 +61,60 @@ static u32 gpmc_serial_TL16CP754C[GPMC_MAX_REG] = { 0x1D0904C4, 0 };
+/* Used to track the revision of the board */ +static ZOOM2_REVISION zoom2_revision = ZOOM2_REVISION_UNKNOWN; + +/* + * Routine: zoom2_get_revision + * Description: Return the revision of the Zoom2 this code is running on. + */ +ZOOM2_REVISION zoom2_get_revision(void) +{ + return zoom2_revision; +} + +/* + * Routine: zoom2_identify + * Description: Detect which version of Zoom2 we are running on. + */ +void zoom2_identify(void) +{ + /* + * To check for production board vs beta board, + * check if gpio 94 is clear. + * + * No way yet to check for alpha board identity. + * Alpha boards were produced in very limited quantities + * and they are not commonly used. They are mentioned here + * only for completeness. + */ + if (!omap_request_gpio(94)) { + unsigned int val; + + omap_set_gpio_direction(94, 1); + val = omap_get_gpio_datain(94); + omap_free_gpio(94); + + if (val) + zoom2_revision = ZOOM2_REVISION_BETA; + else + zoom2_revision = ZOOM2_REVISION_PRODUCTION; + } + + printf("Board revision "); + switch (zoom2_revision) { + case (ZOOM2_REVISION_PRODUCTION): + printf("Production\n"); + break; + case (ZOOM2_REVISION_BETA): + printf("Beta\n"); + break; + default: + printf("Unknown\n"); + break; + } +} + /* * Routine: board_init * Description: Early hardware init. @@ -96,10 +151,11 @@ int board_init (void) * Routine: misc_init_r * Description: Configure zoom board specific configurations */ -int misc_init_r (void) +int misc_init_r(void) { - power_init_r (); - dieid_num_r (); + zoom2_identify(); + power_init_r(); + dieid_num_r(); return 0; }
diff --git a/board/omap3/zoom2/zoom2.h b/board/omap3/zoom2/zoom2.h index cae8a7a..b12b0fa 100644 --- a/board/omap3/zoom2/zoom2.h +++ b/board/omap3/zoom2/zoom2.h @@ -32,6 +32,15 @@ const omap3_sysinfo sysinfo = { "NAND", };
+typedef enum { + ZOOM2_REVISION_UNKNOWN = 0, + ZOOM2_REVISION_ALPHA, + ZOOM2_REVISION_BETA, + ZOOM2_REVISION_PRODUCTION +} ZOOM2_REVISION; + +extern ZOOM2_REVISION zoom2_get_revision(void); + /* * IEN - Input Enable * IDIS - Input Disable
There is no new functionality in the change.
This change is a conversion from the using raw register access to using the OMAP3 GPIO API described in doc/README.omap3.
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- board/omap3/beagle/beagle.c | 32 ++++++++++++++++++-------------- 1 files changed, 18 insertions(+), 14 deletions(-)
diff --git a/board/omap3/beagle/beagle.c b/board/omap3/beagle/beagle.c index 7eb70ee..d268e18 100644 --- a/board/omap3/beagle/beagle.c +++ b/board/omap3/beagle/beagle.c @@ -33,6 +33,7 @@ #include <asm/io.h> #include <asm/arch/mux.h> #include <asm/arch/sys_proto.h> +#include <asm/arch/gpio.h> #include <asm/mach-types.h> #include "beagle.h"
@@ -57,7 +58,7 @@ int board_init(void)
/* * Routine: beagle_get_revision - * Description: Return revision of the BeagleBoard this code is running on. + * Description: Return the revision of the BeagleBoard this code is running on. * If it is a revision Ax/Bx board, this function returns 0, * on a revision C board you will get a 1. */ @@ -74,22 +75,25 @@ int beagle_get_revision(void) */ void beagle_identify(void) { - gpio_t *gpio6_base = (gpio_t *)OMAP34XX_GPIO6_BASE; - - /* Configure GPIO 171 as input */ - writel(readl(&gpio6_base->oe) | GPIO11, &gpio6_base->oe); - - /* Get value of GPIO 171 */ - beagle_revision_c = readl(&gpio6_base->datain) & BOARD_REVISION_MASK; + beagle_revision_c = 0; + if (!omap_request_gpio(171)) { + unsigned int val; + + omap_set_gpio_direction(171, 1); + val = omap_get_gpio_datain(171); + omap_free_gpio(171); + + if (val) + beagle_revision_c = 0; + else + beagle_revision_c = 1; + }
printf("Board revision "); - if (beagle_revision_c) { - printf("Ax/Bx\n"); - beagle_revision_c = 0; - } else { + if (beagle_revision_c) printf("C\n"); - beagle_revision_c = 1; - } + else + printf("Ax/Bx\n"); }
val = omap_get_gpio_datain(N); omap_free_gpio(N); }omap_set_gpio_direction(N, 1);
-- 1.6.0.5
no uppercase please if you are ok I'll remane it before apply
static zoom2_revision revision = ZOOM2_REVISION_UNKNOWN;
Best Regards, J.
<snip>
Please do. Thanks Tom
Best Regards, J.
applied to arm/next
Best Regards, J.
Signed-off-by: Tom Rix Tom.Rix@windriver.com Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- board/omap3/zoom2/zoom2.c | 62 ++++++++++++++++++++++++++++++++++++++++++-- board/omap3/zoom2/zoom2.h | 9 ++++++ 2 files changed, 68 insertions(+), 3 deletions(-)
diff --git a/board/omap3/zoom2/zoom2.c b/board/omap3/zoom2/zoom2.c index e5c248d..08fdafb 100644 --- a/board/omap3/zoom2/zoom2.c +++ b/board/omap3/zoom2/zoom2.c @@ -33,6 +33,7 @@ #include <status_led.h> #endif #include <asm/io.h> +#include <asm/arch/gpio.h> #include <asm/arch/mem.h> #include <asm/arch/mux.h> #include <asm/arch/sys_proto.h> @@ -60,6 +61,60 @@ static u32 gpmc_serial_TL16CP754C[GPMC_MAX_REG] = { 0x1D0904C4, 0 };
+/* Used to track the revision of the board */ +static zoom2_revision revision = ZOOM2_REVISION_UNKNOWN; + +/* + * Routine: zoom2_get_revision + * Description: Return the revision of the Zoom2 this code is running on. + */ +zoom2_revision zoom2_get_revision(void) +{ + return revision; +} + +/* + * Routine: zoom2_identify + * Description: Detect which version of Zoom2 we are running on. + */ +void zoom2_identify(void) +{ + /* + * To check for production board vs beta board, + * check if gpio 94 is clear. + * + * No way yet to check for alpha board identity. + * Alpha boards were produced in very limited quantities + * and they are not commonly used. They are mentioned here + * only for completeness. + */ + if (!omap_request_gpio(94)) { + unsigned int val; + + omap_set_gpio_direction(94, 1); + val = omap_get_gpio_datain(94); + omap_free_gpio(94); + + if (val) + revision = ZOOM2_REVISION_BETA; + else + revision = ZOOM2_REVISION_PRODUCTION; + } + + printf("Board revision "); + switch (revision) { + case ZOOM2_REVISION_PRODUCTION: + printf("Production\n"); + break; + case ZOOM2_REVISION_BETA: + printf("Beta\n"); + break; + default: + printf("Unknown\n"); + break; + } +} + /* * Routine: board_init * Description: Early hardware init. @@ -96,10 +151,11 @@ int board_init (void) * Routine: misc_init_r * Description: Configure zoom board specific configurations */ -int misc_init_r (void) +int misc_init_r(void) { - power_init_r (); - dieid_num_r (); + zoom2_identify(); + power_init_r(); + dieid_num_r(); return 0; }
diff --git a/board/omap3/zoom2/zoom2.h b/board/omap3/zoom2/zoom2.h index cae8a7a..a21d1d6 100644 --- a/board/omap3/zoom2/zoom2.h +++ b/board/omap3/zoom2/zoom2.h @@ -32,6 +32,15 @@ const omap3_sysinfo sysinfo = { "NAND", };
+typedef enum { + ZOOM2_REVISION_UNKNOWN = 0, + ZOOM2_REVISION_ALPHA, + ZOOM2_REVISION_BETA, + ZOOM2_REVISION_PRODUCTION +} zoom2_revision; + +zoom2_revision zoom2_get_revision(void); + /* * IEN - Input Enable * IDIS - Input Disable
<snip>
<snip>
+typedef enum {
- ZOOM2_REVISION_UNKNOWN = 0,
- ZOOM2_REVISION_ALPHA,
- ZOOM2_REVISION_BETA,
- ZOOM2_REVISION_PRODUCTION
+} zoom2_revision;
Looks fine. Thanks! Tom
- IEN - Input Enable
- IDIS - Input Disable
Tom
Tom Rix
