[PATCH v2] udoo_neo: fix udoo neo UNDEFINED
get_board_value function fails to get the right board configuration on second time that is call. This patch move get_board_value function at spl level, once is call, store the right configuration into gd static variable gd->board_type and fix the previous error. get_board_value is now call only one time.
Signed-off-by: Tommaso Merciai tomm.merciai@gmail.com --- Changes since v1 - get_board_value declared as void - fix gd->board_type, re-initialized after spl
board/udoo/neo/neo.c | 12 ++++++------ configs/udoo_neo_defconfig | 1 + 2 files changed, 7 insertions(+), 6 deletions(-)
diff --git a/board/udoo/neo/neo.c b/board/udoo/neo/neo.c index 62f81fff68..808b727fb0 100644 --- a/board/udoo/neo/neo.c +++ b/board/udoo/neo/neo.c @@ -308,7 +308,7 @@ int board_init(void) return 0; }
-static int get_board_value(void) +static void get_board_value(void) { int r184, r185;
@@ -333,12 +333,13 @@ static int get_board_value(void) * Extended 1 1 */
- return (r184 << 1) + r185; + gd->board_type = (r184 << 1) + r185; }
int board_early_init_f(void) { setup_iomux_uart(); + get_board_value();
return 0; } @@ -370,7 +371,7 @@ int board_mmc_init(struct bd_info *bis)
static char *board_string(void) { - switch (get_board_value()) { + switch (gd->board_type) { case UDOO_NEO_TYPE_BASIC: return "BASIC"; case UDOO_NEO_TYPE_BASIC_KS: @@ -498,8 +499,6 @@ static void ccgr_init(void)
static void spl_dram_init(void) { - int board = get_board_value(); - struct mx6_ddr_sysinfo sysinfo = { .dsize = 1, /* width of data bus: 1 = 32 bits */ .cs_density = 24, @@ -516,7 +515,8 @@ static void spl_dram_init(void) };
mx6sx_dram_iocfg(32, &mx6_ddr_ioregs, &mx6_grp_ioregs); - if (board == UDOO_NEO_TYPE_BASIC || board == UDOO_NEO_TYPE_BASIC_KS) + if (gd->board_type == UDOO_NEO_TYPE_BASIC || + gd->board_type == UDOO_NEO_TYPE_BASIC_KS) mx6_dram_cfg(&sysinfo, &neo_basic_mmcd_calib, &neo_basic_mem_ddr); else diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index ca08de1bd4..eff33909d7 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -62,3 +62,4 @@ CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y +CONFIG_BOARD_TYPES=y \ No newline at end of file
Hi Tommaso,
With this patch I get:
Board: UDOO Neo UNDEFINED
Fabio Estevam
Tommaso Merciai
