[U-Boot] [PATCH v2 3/4] ARM: board: cm_fx6: fixup mtd partitions in the fdt
From: Christopher Spinrath christopher.spinrath@rwth-aachen.de
The cm-fx6 module has an on-board st,m25p compatible spi flash chip used for U-Boot (binary & environment). Overwrite the partitions in the device tree by the partition table provided in the mtdparts environment variable, if it is set.
This allows to specify a kernel independent partitioning in the environment and provides a convient way for the user to adapt the partition table.
Signed-off-by: Christopher Spinrath christopher.spinrath@rwth-aachen.de ---
Notes: Changes since v1: - remove #ifdef CONFIG_FDT_FIXUP_PARTITIONS guards (no longer required thanks to the stub introduced by patch 2 of this series) - fallback to the documented jedec,spi-nor compatible if the undocumented compatible st,m25p used by the vendor device treeis not in the dt
board/compulab/cm_fx6/cm_fx6.c | 18 +++++++++++++++++- 1 file changed, 17 insertions(+), 1 deletion(-)
diff --git a/board/compulab/cm_fx6/cm_fx6.c b/board/compulab/cm_fx6/cm_fx6.c index 712057a..566c19b 100644 --- a/board/compulab/cm_fx6/cm_fx6.c +++ b/board/compulab/cm_fx6/cm_fx6.c @@ -12,6 +12,7 @@ #include <dm.h> #include <fsl_esdhc.h> #include <miiphy.h> +#include <mtd_node.h> #include <netdev.h> #include <errno.h> #include <usb.h> @@ -28,6 +29,7 @@ #include <asm/io.h> #include <asm/gpio.h> #include <dm/platform_data/serial_mxc.h> +#include <jffs2/load_kernel.h> #include "common.h" #include "../common/eeprom.h" #include "../common/common.h" @@ -581,6 +583,17 @@ int cm_fx6_setup_ecspi(void) { return 0; }
#ifdef CONFIG_OF_BOARD_SETUP #define USDHC3_PATH "/soc/aips-bus@02100000/usdhc@02198000/" + +struct node_info nodes[] = { + /* + * Both entries target the same flash chip. The st,m25p compatible + * is used in the vendor device trees, while upstream uses (the + * documented) jedec,spi-nor comptatible. + */ + { "st,m25p", MTD_DEV_TYPE_NOR, }, + { "jedec,spi-nor", MTD_DEV_TYPE_NOR, }, +}; + int ft_board_setup(void *blob, bd_t *bd) { u32 baseboard_rev; @@ -589,6 +602,8 @@ int ft_board_setup(void *blob, bd_t *bd) char baseboard_name[16]; int err;
+ fdt_shrink_to_minimum(blob); /* Make room for new properties */ + /* MAC addr */ if (eth_getenv_enetaddr("ethaddr", enetaddr)) { fdt_find_and_setprop(blob, @@ -607,7 +622,6 @@ int ft_board_setup(void *blob, bd_t *bd) return 0; /* Assume not an early revision SB-FX6m baseboard */
if (!strncmp("SB-FX6m", baseboard_name, 7) && baseboard_rev <= 120) { - fdt_shrink_to_minimum(blob); /* Make room for new properties */ nodeoffset = fdt_path_offset(blob, USDHC3_PATH); fdt_delprop(blob, nodeoffset, "cd-gpios"); fdt_find_and_setprop(blob, USDHC3_PATH, "broken-cd", @@ -616,6 +630,8 @@ int ft_board_setup(void *blob, bd_t *bd) NULL, 0, 1); }
+ fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); + return 0; } #endif
Acked-by: Igor Grinberg grinberg@compulab.co.il
Igor Grinberg
