[u-boot-test-hooks PATCH 1/7] travis-ci: Add qemu_arm_spl board
This is similar to the existing qemu_arm target, except that the 'bios' is image.bin (containing both SPL and U-Boot) rather than in u-boot.bin
bin/travis-ci/conf.qemu_arm_spl_na | 31 ++++++++++++++++++++++++++++++ 1 file changed, 31 insertions(+) create mode 100644 bin/travis-ci/conf.qemu_arm_spl_na
diff --git a/bin/travis-ci/conf.qemu_arm_spl_na b/bin/travis-ci/conf.qemu_arm_spl_na new file mode 100644 index 0000000..18c7fe5 --- /dev/null +++ b/bin/travis-ci/conf.qemu_arm_spl_na @@ -0,0 +1,31 @@ +# Copyright 2021 Google LLC +# Based on conf.vexpress_ca15_tc2_qemu which is: +# Copyright (c) 2016 Konsulko Group. All rights reserved. +# +# Permission is hereby granted, free of charge, to any person obtaining a +# copy of this software and associated documentation files (the "Software"), +# to deal in the Software without restriction, including without limitation +# the rights to use, copy, modify, merge, publish, distribute, sublicense, +# and/or sell copies of the Software, and to permit persons to whom the +# Software is furnished to do so, subject to the following conditions: +# +# The above copyright notice and this permission notice shall be included in +# all copies or substantial portions of the Software. +# +# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR +# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, +# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL +# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER +# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING +# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER +# DEALINGS IN THE SOFTWARE. + +console_impl=qemu +qemu_machine="virt" +qemu_binary="qemu-system-arm" +qemu_extra_args="-nographic -netdev user,id=net0,tftp=${UBOOT_TRAVIS_BUILD_DIR} -device e1000,netdev=net0 -device virtio-rng-pci" + +# Uses image.bin which contains SPL and U-Boot +qemu_kernel_args="-bios ${U_BOOT_BUILD_DIR}/image.bin" +reset_impl=none +flash_impl=none
Add a comment about the tools and drop the debugging, since this seems reliable now.
bin/flash.sdwire_relay_mount | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/bin/flash.sdwire_relay_mount b/bin/flash.sdwire_relay_mount index 4713c2f..f75d33f 100644 --- a/bin/flash.sdwire_relay_mount +++ b/bin/flash.sdwire_relay_mount @@ -21,12 +21,14 @@ # Designed for using SDwire uSD mux and selected power control: # https://wiki.tizen.org/SDWire
+# It requires these tools: +# sd-mux-ctrl at https://git.tizen.org/cgit/tools/testlab/sd-mux/ +# usbrelay + . poweroff.${power_impl}
sleep 0.1 -echo common
. flash.sdwire_common_mount
. poweron.${power_impl} -echo flash done
Applied to u-boot-test-hooks/master, thanks!
Just to be safe, check for the pattern only at the start of a line, since it is possible to add a comment with this in it.
bin/writer.rpi3_mount | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/bin/writer.rpi3_mount b/bin/writer.rpi3_mount index 7b078a1..97f24a5 100755 --- a/bin/writer.rpi3_mount +++ b/bin/writer.rpi3_mount @@ -41,7 +41,7 @@ fi
# Enable the UART and fix the GPU frequency so it works correctly sed -i '/enable_uart/c\enable_uart = 1' /media/rpi3_b_boot/config.txt -if ! grep -q gpu_freq=250 /media/rpi3_b_boot/config.txt; then +if ! grep -q "^gpu_freq=250" /media/rpi3_b_boot/config.txt; then echo 'gpu_freq=250' >>/media/rpi3_b_boot/config.txt fi
This code is duplicated in two scripts. Put it into a new wait_raw_device to avoid this. Also rename the 'done' variable to 'complete' to void confusing it with the end of the for loop.
bin/flash.sdwire_digital-loggers_raw | 15 +----------- bin/flash.sdwire_poweroff_raw | 15 +----------- bin/wait_raw_device | 34 ++++++++++++++++++++++++++++ 3 files changed, 36 insertions(+), 28 deletions(-) create mode 100644 bin/wait_raw_device
diff --git a/bin/flash.sdwire_digital-loggers_raw b/bin/flash.sdwire_digital-loggers_raw index 7d5fbc9..f9956f7 100644 --- a/bin/flash.sdwire_digital-loggers_raw +++ b/bin/flash.sdwire_digital-loggers_raw @@ -33,20 +33,7 @@ curl --data ${power_port}=OFF -o /dev/null --silent \ # Switch over to get USB card access sd-mux-ctrl --device-serial ${sdwire_serial} --ts
-# Wait for the device to become available -done=false -for i in {0..9}; do - if dd if=${raw_device} of=/dev/null count=1 >/dev/null 2>&1; then - done=true - break - fi - - sleep 1 -done -if [[ $done = false ]]; then - echo "Failed to access ${raw_device} after 10 tries" - exit 1 -fi +. wait_raw_device
writer.${flash_writer} ${raw_device} ${U_BOOT_BUILD_DIR}
diff --git a/bin/flash.sdwire_poweroff_raw b/bin/flash.sdwire_poweroff_raw index 28fa096..d82a3ef 100644 --- a/bin/flash.sdwire_poweroff_raw +++ b/bin/flash.sdwire_poweroff_raw @@ -34,20 +34,7 @@ mount_dir=/media/${mount_point} # Switch over to get USB card access sd-mux-ctrl --device-serial ${sdwire_serial} --ts
diff --git a/bin/wait_raw_device b/bin/wait_raw_device new file mode 100644 index 0000000..c292114 --- /dev/null +++ b/bin/wait_raw_device @@ -0,0 +1,34 @@ +# Copyright 2021 Google LLC +# +# Permission is hereby granted, free of charge, to any person obtaining a +# copy of this software and associated documentation files (the "Software"), +# to deal in the Software without restriction, including without limitation +# the rights to use, copy, modify, merge, publish, distribute, sublicense, +# and/or sell copies of the Software, and to permit persons to whom the +# Software is furnished to do so, subject to the following conditions: +# +# The above copyright notice and this permission notice shall be included in +# all copies or substantial portions of the Software. +# +# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR +# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, +# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL +# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER +# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING +# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER +# DEALINGS IN THE SOFTWARE. + +# Wait for the device ${raw_device} to become available +complete=false +for i in {0..9}; do + if dd if=${raw_device} of=/dev/null count=1 >/dev/null 2>&1; then + complete=true + break + fi + + sleep 1 +done +if [[ $complete = false ]]; then + echo "Failed to access ${raw_device} after 10 tries" + exit 1 +fi
Sometimes the umount takes a while. Add the same wait loop as is used for mount. Also rename the 'done' variable to 'complete' to void confusing it with the end of the for loop.
bin/flash.sdwire_common_mount | 28 ++++++++++++++++++++++++---- 1 file changed, 24 insertions(+), 4 deletions(-)
diff --git a/bin/flash.sdwire_common_mount b/bin/flash.sdwire_common_mount index d696abb..6c763e6 100644 --- a/bin/flash.sdwire_common_mount +++ b/bin/flash.sdwire_common_mount @@ -25,10 +25,10 @@ mount_dir=/media/${mount_point} # Switch over to get USB card access sd-mux-ctrl --device-serial ${sdwire_serial} --ts
-done=false +complete=false for i in {0..9}; do if out="$(mount UUID=${mount_uuid} 2>&1)"; then - done=true + complete=true break fi echo $out @@ -41,7 +41,7 @@ for i in {0..9}; do fi sleep 1 done -if [[ $done = false ]]; then +if [[ $complete = false ]]; then echo "Failed to mount UUID ${mount_uuid} after 10 tries" exit 1 fi @@ -53,7 +53,27 @@ if ! mountpoint -q ${mount_dir}; then fi
writer.${flash_writer} ${mount_dir} ${U_BOOT_BUILD_DIR} -umount ${mount_dir} + +complete=false +for i in {0..9}; do + if out="$(umount ${mount_dir} 2>&1)"; then + complete=true + break + fi + echo $out + sleep 1 +done + +if [[ $complete = false ]]; then + echo "Failed to umount UUID ${mount_uuid} after 10 tries" + exit 1 +fi + +# Sanity check +if mountpoint -q ${mount_dir}; then + echo "Mount ${mount_dir} still available after 'umount'" + exit 1 +fi
# Back to card access for the DUT sd-mux-ctrl --device-serial ${sdwire_serial} --dut
Add a config for samus, the Chromebook Pixel 2.
bin/kea/conf.chromebook_samus_sjg-samus | 30 +++++++++++++++++++++++++ 1 file changed, 30 insertions(+) create mode 100644 bin/kea/conf.chromebook_samus_sjg-samus
diff --git a/bin/kea/conf.chromebook_samus_sjg-samus b/bin/kea/conf.chromebook_samus_sjg-samus new file mode 100644 index 0000000..0e7db49 --- /dev/null +++ b/bin/kea/conf.chromebook_samus_sjg-samus @@ -0,0 +1,30 @@ +# Copyright 2021 Google LLC +# +# Permission is hereby granted, free of charge, to any person obtaining a +# copy of this software and associated documentation files (the "Software"), +# to deal in the Software without restriction, including without limitation +# the rights to use, copy, modify, merge, publish, distribute, sublicense, +# and/or sell copies of the Software, and to permit persons to whom the +# Software is furnished to do so, subject to the following conditions: +# +# The above copyright notice and this permission notice shall be included in +# all copies or substantial portions of the Software. +# +# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR +# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, +# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL +# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER +# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING +# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER +# DEALINGS IN THE SOFTWARE. + +reset_impl=servo +flash_impl=em100 +power_impl=servo + +em100_chip=W25Q64FV +em100_serial=DP033694 + +servo_name=samus + +. ubtest_common
Add some symlinks so that qemu can be used on ellesmere.
bin/ellesmere/conf.qemu_arm_na | 1 + bin/ellesmere/conf.qemu_arm_spl_na | 1 + 2 files changed, 2 insertions(+) create mode 120000 bin/ellesmere/conf.qemu_arm_na create mode 120000 bin/ellesmere/conf.qemu_arm_spl_na
diff --git a/bin/ellesmere/conf.qemu_arm_na b/bin/ellesmere/conf.qemu_arm_na new file mode 120000 index 0000000..aa91a9f --- /dev/null +++ b/bin/ellesmere/conf.qemu_arm_na @@ -0,0 +1 @@ +../travis-ci/conf.qemu_arm_na \ No newline at end of file diff --git a/bin/ellesmere/conf.qemu_arm_spl_na b/bin/ellesmere/conf.qemu_arm_spl_na new file mode 120000 index 0000000..e171c5a --- /dev/null +++ b/bin/ellesmere/conf.qemu_arm_spl_na @@ -0,0 +1 @@ +../travis-ci/conf.qemu_arm_spl_na \ No newline at end of file
Alright, so I think the best use of the public u-boot-test-hooks is to have first public CI used scripts (aka everything in {bin,py}/travis-ci) and then we should move to having a reference directory. It's not useful to everyone for example to have symlinks like these here, for your lab. But it is very useful to have things like bin/kea/conf.orangepi_pc_sjg-opi_pc which I used locally the other day to make bin/bill-the-cat/conf.pine64_plus_na and I think everyone would benefit from something like bin/references/conf.sunxi_with_sdwire_and_digital-loggers so that anyone else can figure out how to plumb in their own sunxi platform with sdwire and then whatever reference they also need for power control, if not a digital-loggers type "curl" solution.
Hi Tom,
OK. Can you apply the other patches? Then I'll check and try some renames.
On Sun, Oct 31, 2021 at 12:22:48PM -0600, Simon Glass wrote:
Hi Tom,
I'll review the rest of the series soon, yes.
On 30.10.2021 21.25, Simon Glass wrote:
^ Some mishap with the From: line here, since I did not write the patch?
Aside from the wrong-From, for a v2 in the future, I'm holding off on this until the passage stuff which makes use of this, is closer to going in.
Tuomas Tynkkynen
