[U-Boot] [PATCH] dm: allow setting driver_data before/during bind
This will allow a driver's bind function to use the driver data. One example is the Tegra186 GPIO driver, which instantiates child devices for each of its GPIO ports, yet supports two different HW instances each with a different set of ports, and identified by the udevice_id .data field.
Signed-off-by: Stephen Warren swarren@nvidia.com --- drivers/core/device.c | 7 ++++--- drivers/core/lists.c | 6 +++--- drivers/gpio/dwapb_gpio.c | 2 +- drivers/gpio/s5p_gpio.c | 2 +- drivers/gpio/sunxi_gpio.c | 2 +- drivers/gpio/tegra_gpio.c | 2 +- drivers/mtd/spi/sandbox.c | 2 +- drivers/net/mvpp2.c | 3 ++- drivers/pci/pci-uclass.c | 5 ++--- drivers/power/pmic/pmic-uclass.c | 2 +- drivers/usb/host/usb-uclass.c | 5 ++--- include/dm/device-internal.h | 5 +++-- 12 files changed, 22 insertions(+), 21 deletions(-)
diff --git a/drivers/core/device.c b/drivers/core/device.c index 74688dc95075..dc66e2400de6 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -27,8 +27,8 @@ DECLARE_GLOBAL_DATA_PTR;
int device_bind(struct udevice *parent, const struct driver *drv, - const char *name, void *platdata, int of_offset, - struct udevice **devp) + const char *name, void *platdata, ulong driver_data, + int of_offset, struct udevice **devp) { struct udevice *dev, *dev2; struct uclass *uc; @@ -56,6 +56,7 @@ int device_bind(struct udevice *parent, const struct driver *drv, INIT_LIST_HEAD(&dev->devres_head); #endif dev->platdata = platdata; + dev->driver_data = driver_data; dev->name = name; dev->of_offset = of_offset; dev->parent = parent; @@ -227,7 +228,7 @@ int device_bind_by_name(struct udevice *parent, bool pre_reloc_only, return -EPERM;
return device_bind(parent, drv, info->name, (void *)info->platdata, - -1, devp); + 0, -1, devp); }
static void *alloc_priv(int size, uint flags) diff --git a/drivers/core/lists.c b/drivers/core/lists.c index a72db13a119a..ac5a788e7e2b 100644 --- a/drivers/core/lists.c +++ b/drivers/core/lists.c @@ -89,7 +89,7 @@ int device_bind_driver_to_node(struct udevice *parent, const char *drv_name, debug("Cannot find driver '%s'\n", drv_name); return -ENOENT; } - ret = device_bind(parent, drv, dev_name, NULL, node, devp); + ret = device_bind(parent, drv, dev_name, NULL, 0, node, devp); if (ret) { debug("Cannot create device named '%s' (err=%d)\n", dev_name, ret); @@ -170,7 +170,8 @@ int lists_bind_fdt(struct udevice *parent, const void *blob, int offset, }
dm_dbg(" - found match at '%s'\n", entry->name); - ret = device_bind(parent, entry, name, NULL, offset, &dev); + ret = device_bind(parent, entry, name, NULL, id->data, + offset, &dev); if (ret == -ENODEV) { dm_dbg("Driver '%s' refuses to bind\n", entry->name); continue; @@ -180,7 +181,6 @@ int lists_bind_fdt(struct udevice *parent, const void *blob, int offset, ret); return ret; } else { - dev->driver_data = id->data; found = true; if (devp) *devp = dev; diff --git a/drivers/gpio/dwapb_gpio.c b/drivers/gpio/dwapb_gpio.c index 72cec4880095..dcbf4c7b0877 100644 --- a/drivers/gpio/dwapb_gpio.c +++ b/drivers/gpio/dwapb_gpio.c @@ -137,7 +137,7 @@ static int gpio_dwapb_bind(struct udevice *dev) goto err;
ret = device_bind(dev, dev->driver, plat->name, - plat, -1, &subdev); + plat, 0, -1, &subdev); if (ret) goto err;
diff --git a/drivers/gpio/s5p_gpio.c b/drivers/gpio/s5p_gpio.c index 0f22b238ba99..d4e1822c3646 100644 --- a/drivers/gpio/s5p_gpio.c +++ b/drivers/gpio/s5p_gpio.c @@ -344,7 +344,7 @@ static int gpio_exynos_bind(struct udevice *parent)
plat->bank_name = fdt_get_name(blob, node, NULL); ret = device_bind(parent, parent->driver, - plat->bank_name, plat, -1, &dev); + plat->bank_name, plat, 0, -1, &dev); if (ret) return ret;
diff --git a/drivers/gpio/sunxi_gpio.c b/drivers/gpio/sunxi_gpio.c index a7cec18d57fb..715239dae38e 100644 --- a/drivers/gpio/sunxi_gpio.c +++ b/drivers/gpio/sunxi_gpio.c @@ -306,7 +306,7 @@ static int gpio_sunxi_bind(struct udevice *parent) plat->gpio_count = SUNXI_GPIOS_PER_BANK;
ret = device_bind(parent, parent->driver, - plat->bank_name, plat, -1, &dev); + plat->bank_name, plat, 0, -1, &dev); if (ret) return ret; dev->of_offset = parent->of_offset; diff --git a/drivers/gpio/tegra_gpio.c b/drivers/gpio/tegra_gpio.c index 5a031159ca37..1949029d8978 100644 --- a/drivers/gpio/tegra_gpio.c +++ b/drivers/gpio/tegra_gpio.c @@ -360,7 +360,7 @@ static int gpio_tegra_bind(struct udevice *parent) plat->port_name = gpio_port_name(base_port);
ret = device_bind(parent, parent->driver, - plat->port_name, plat, -1, &dev); + plat->port_name, plat, 0, -1, &dev); if (ret) return ret; dev->of_offset = parent->of_offset; diff --git a/drivers/mtd/spi/sandbox.c b/drivers/mtd/spi/sandbox.c index 53470b90ce87..4244b8b8e6e7 100644 --- a/drivers/mtd/spi/sandbox.c +++ b/drivers/mtd/spi/sandbox.c @@ -581,7 +581,7 @@ int sandbox_sf_bind_emul(struct sandbox_state *state, int busnum, int cs, puts("Cannot find sandbox_sf_emul driver\n"); return -ENOENT; } - ret = device_bind(bus, drv, str, NULL, of_offset, &emul); + ret = device_bind(bus, drv, str, NULL, 0, of_offset, &emul); if (ret) { printf("Cannot create emul device for spec '%s' (err=%d)\n", spec, ret); diff --git a/drivers/net/mvpp2.c b/drivers/net/mvpp2.c index 900a04c0eeeb..5ca5ee10f50c 100644 --- a/drivers/net/mvpp2.c +++ b/drivers/net/mvpp2.c @@ -4168,7 +4168,8 @@ static int mvpp2_base_bind(struct udevice *parent) sprintf(name, "mvpp2-%d", id);
/* Create child device UCLASS_ETH and bind it */ - device_bind(parent, &mvpp2_driver, name, plat, subnode, &dev); + device_bind(parent, &mvpp2_driver, name, plat, 0, subnode, + &dev); dev->of_offset = subnode; }
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 32590ce498a7..6b9d56b3de25 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -629,12 +629,11 @@ static int pci_find_and_bind_driver(struct udevice *parent, * find another driver. For now this doesn't seem * necesssary, so just bind the first match. */ - ret = device_bind(parent, drv, drv->name, NULL, -1, - &dev); + ret = device_bind(parent, drv, drv->name, NULL, + find_id->driver_data, -1, &dev); if (ret) goto error; debug("%s: Match found: %s\n", __func__, drv->name); - dev->driver_data = find_id->driver_data; *devp = dev; return 0; } diff --git a/drivers/power/pmic/pmic-uclass.c b/drivers/power/pmic/pmic-uclass.c index 7211026aecbe..d85c62a2dc0e 100644 --- a/drivers/power/pmic/pmic-uclass.c +++ b/drivers/power/pmic/pmic-uclass.c @@ -60,7 +60,7 @@ int pmic_bind_children(struct udevice *pmic, int offset,
debug(" - found child driver: '%s'\n", drv->name);
- ret = device_bind(pmic, drv, node_name, NULL, + ret = device_bind(pmic, drv, node_name, NULL, 0, node, &child); if (ret) { debug(" - child binding error: %d\n", ret); diff --git a/drivers/usb/host/usb-uclass.c b/drivers/usb/host/usb-uclass.c index 69c9a504ebb8..bb88ef0e6b14 100644 --- a/drivers/usb/host/usb-uclass.c +++ b/drivers/usb/host/usb-uclass.c @@ -501,12 +501,11 @@ static int usb_find_and_bind_driver(struct udevice *parent, * find another driver. For now this doesn't seem * necesssary, so just bind the first match. */ - ret = device_bind(parent, drv, drv->name, NULL, -1, - &dev); + ret = device_bind(parent, drv, drv->name, NULL, + id->driver_info, -1, &dev); if (ret) goto error; debug("%s: Match found: %s\n", __func__, drv->name); - dev->driver_data = id->driver_info; plat = dev_get_parent_platdata(dev); plat->id = *id; *devp = dev; diff --git a/include/dm/device-internal.h b/include/dm/device-internal.h index b348ad5231bd..8ce11bf04186 100644 --- a/include/dm/device-internal.h +++ b/include/dm/device-internal.h @@ -29,14 +29,15 @@ struct udevice; * @platdata: Pointer to data for this device - the structure is device- * specific but may include the device's I/O address, etc.. This is NULL for * devices which use device tree. + * @driver_data: The value to be stored in the device's driver_data field. * @of_offset: Offset of device tree node for this device. This is -1 for * devices which don't use device tree. * @devp: if non-NULL, returns a pointer to the bound device * @return 0 if OK, -ve on error */ int device_bind(struct udevice *parent, const struct driver *drv, - const char *name, void *platdata, int of_offset, - struct udevice **devp); + const char *name, void *platdata, ulong driver_data, + int of_offset, struct udevice **devp);
/** * device_bind_by_name: Create a device and bind it to a driver
Hi Stephen,
I'm not sure this extra parameter carries its weight:
- most callers just pass 0 - the field is supposed to be set up by device tree and probing tables, not code - bind() methods should not care about the driver data (they are not allowed to touch hardware), so setting it later is fine - you can already pass platform data to the driver which is the preferred communication method from a parent to its children
Also it's not clear from your Tegra 186 GPIO patch where you are using this.
On 05/01/2016 01:27 PM, Simon Glass wrote:
Hi Stephen,
The same is true of the existing platdata field in many cases.
While the existence of this new parameter does allow arbitrary code to set the parameter, this patch only actually sets the parameter in the case where DT and probing tables have determined that value.
Not touching HW is fine, but the driver data can still feed into purely SW decisions that bind makes. More details below.
I don't believe this is possible for devices instantiated from DT is it? In that case, platform data is always NULL:
int lists_bind_fdt(struct udevice *parent, const void *blob, int offset, struct udevice **devp) ... ret = device_bind(parent, entry, name, NULL, id->data, offset, &dev);
(That quoted code is with this patch applied, and the NULL value is the platform data parameter.)
Here's the relevant part from the Tegra186 GPIO driver patch I posted:
+static int tegra186_gpio_bind(struct udevice *parent) +{
- struct tegra186_gpio_platdata *parent_plat = parent->platdata;
- struct tegra186_gpio_ctlr_data *ctlr_data =
(struct tegra186_gpio_ctlr_data *)parent->driver_data;
- /* If this is a child device, there is nothing to do here */
- if (parent_plat)
- for (port = 0; port < ctlr_data->port_count; port++) {
plat->name = ctlr_data->ports[port].name;
plat->regs = &(regs[ctlr_data->ports[port].offset / 4]);
The data is used to determine how many child devices (one per port) to create, and the name and register offset of each one. This is modelled after the logic in the previous Tegra GPIO driver that you wrote, with the unfortunate modification that the register layout is more "interesting" on Tegra186, and so we can't determine the number of and parameters for the child devices purely algorithmically, since the register layout is decidedly non-linear.
I suppose an alternative would be to create separate U_BOOT_DRIVER()s for each compatible value with different register layout, and then have the bind() for each of those call into some common implementation with a hard-coded parameter. Still, it seems like the usage in the current code is exactly what udevice_id.data is for; to avoid having to implement separate functions that do that.
Perhaps the creation of the child devices could happen in probe() rather than bind()? I imagine there's some reason this wouldn't work (such as this causing the devices to be created too late to be referenced by other drivers?) or you would have done this in the existing Tegra GPIO driver.
Hi Stephen,
tables, not code
- if (parent_plat)
Simon, any more thoughts on how the Tegra186 GPIO should handle the need for HW knowledge in bind()? I'd like to repost that driver soon, and doing so requires resolving this discussion. Thanks.
Hi Stephen,
Hi Stephen,
Yes, but platdata is defined to be needed by bind(), whereas driver_data is supposed to be used in probe() to find out which device tree compatible string matched. Remember that the device tree properties are not looked at during bind(), only later. So it makes sense to include platdata in the device_bind() call, but not driver_data.
not code
I don't think so. That value is set in lists_bind_fdt().
I wonder if you could set it yourself after calling device_bind()?
That's right. For DT the paltform data is set up in the ofdata_to_platdata() method. Since you are using DT, you should follow that convention.
if (parent_plat)
OK I see. This feels like something that your device tree should describe. Failing that, how about a hard-coded table of information in the source code? You can look through the table and create the appropriate child devices.
Yes, but you should use different compatible strings for the nodes. As I understand it, you only have a single node, so re-purposing this does not seem right to me.
Best not - it is good to have the devices known on start-up. Let me know if the above solution doesn't work.
On 05/10/2016 08:25 PM, Simon Glass wrote:
Hi Stephen,
Hi Stephen,
This seems to conflict with the documentation in include/dm/device.h; it claims that platdata is created by calling ofdata_to_platdata() just before calling probe(), at least for the DT case (for the case where U_BOOT_DEVICE is used, the platdata is available right from the start).
I couldn't find anywhere in the documentation that states when driver_data is supposed to be used; could you point me at it so I can read it?
Hmm, drivers/gpio/tegra_gpio.c:gpio_tegra_bind() uses DT (which you wrote or at least converted it to DM and chose where to put the DT accesses), and you very recently reviewed and applied "video: tegra: refuse to bind to disabled dcs" which modified drivers/video/tegra.c:tegra_lcd_bind() to use DT.
Admittedly I do now see the following in doc/driver-model/README.txt:
The device's bind() method is permitted to perform simple actions, but should not scan the device tree node, not initialise hardware, nor set up structures or allocate memory. All of these tasks should be left for the probe() method.
... but then I wonder why that rule was enforced for the patch in this thread, but not in the other cases?
This inconsistency in review is extremely frustrating to me.
not code
Sure, but that function is only used from 3 places, and explicitly accepts a parameter to indicate which DT node to instantiate a device for. It won't work unless a valid DT node is passed to it, and therefore can only work for DT-based probing.
The Tegra186 GPIO driver explicitly needs to use the data inside the driver's bind() function in order to know how many child devices to instantiate. Setting the value after calling device_bind() (which the core DM code already does) is too late.
For reference, you can see the exact code at: http://lists.denx.de/pipermail/u-boot/2016-April/252238.html "gpio: add Tegra186 GPIO driver"
Search for "tegra186_gpio_bind" and look at the assignment to, and use of, ctlr_data.
I had also quoted that part of the code in my previous email.
This is the opposite of what you said above, which was that platdata is for bind().
if (parent_plat)
DT generally describes the presence of HW blocks, not the internal details of those HW blocks, since that is a fixed facet of the hardware design and can be statically derived from the value of the compatible property.
Equally, I'm not sure how describing the details of the HW differences in DT would help. The details need to be known by the driver's bind() function, which you and the U-Boot documentation both state isn't allowed to access DT.
That is EXACTLY what the code is doing. The only issue is that the driver supports two different compatible properties and needs to know which one was found in DT in order to use the right table. That's what driver_data is; the .data value from the udevice_id/of_match table.
That's EXACTLY what the code does. However, there is currently no way for bind() to find out which entry in the udevice_id table matched, since the DM core currently sets driver_data after calling bind() rather than before.
I must not understand what you're conveying by "single node" here. To quote the example from the Tegra186 GPIO DT binding documentation, here is what the DT looks like:
gpio@2200000 { compatible = "nvidia,tegra186-gpio"; reg-names = "security", "gpio"; reg = <0x0 0x2200000 0x0 0x10000>, <0x0 0x2210000 0x0 0x10000>; interrupts = <0 47 IRQ_TYPE_LEVEL_HIGH>, <0 50 IRQ_TYPE_LEVEL_HIGH>, <0 53 IRQ_TYPE_LEVEL_HIGH>, <0 56 IRQ_TYPE_LEVEL_HIGH>, <0 59 IRQ_TYPE_LEVEL_HIGH>, <0 180 IRQ_TYPE_LEVEL_HIGH>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; };
gpio@c2f0000 { compatible = "nvidia,tegra186-gpio-aon"; reg-names = "security", "gpio"; reg = <0x0 0xc2f0000 0x0 0x1000>, <0x0 0xc2f1000 0x0 0x1000>; interrupts = <0 60 IRQ_TYPE_LEVEL_HIGH>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; };
Those two HW blocks are roughly but not exactly the same HW. Hence, there are two compatible values. The two HW blocks are similar enough to be handled by a single driver though, and hence the udevice_id table has two entries:
static const struct udevice_id tegra186_gpio_ids[] = { { .compatible = "nvidia,tegra186-gpio", .data = (ulong)&tegra186_gpio_main_data, }, { .compatible = "nvidia,tegra186-gpio-aon", .data = (ulong)&tegra186_gpio_aon_data, }, { } };
The .data value there provides all necessary information for the driver to handle both HW block designs.
All I need is to be able to access the ".data" from that table in bind(), whereas the DM core currently doesn't allow that.
I must admit, I didn't see any solution offered in your email.
If the child devices must be created in bind(), which I do agree makes sense, then bind() must be able to determine which udevice_id table entry is related to the device being bound. Is there another way to do that besides using the driver_data from the udevice_id table? I suppose I could make bind() go read the compatible property from the DT node for the device, and manually search through the udevice_id table and find the matching entry. However, that would be duplicating work the DM core has already done, and exposes by setting the device's driver_data right after calling the driver's bind(), so doesn't make sense to me.
Hi Stephen,
Hi Stephen,
Hi Stephen,
Exactly. That isn't a conflict. It's just that with DT the platform data is provided by ofdata_to_platdata() whereas without it (the degenerate case) it must be provided before bind().
No, but we should add something. See device.h:
* @of_offset: Device tree node offset for this device (- for none) * @driver_data: Driver data word for the entry that matched this device with * its driver
It is related to DT, nothing else.
Re GPIO, this is because on tegra this information is not present in the DT - it uses the 'interrupts' property to figure out the number of GPIO banks. It does not involve using driverdata.
The video thing is checking for a disabled device, something that is already done in dm_scan_fdt_node().
See above. There are always grey areas, but the two you cite don't involve core DM changes.
not code
I'm really not sure what you are saying here. It seems quite straightforward to me:
- For the DT case (which is normal), the device tree data is used by ofdata_to_platdata() to create the platdata. Before that there is no platdata. The driver_data indicates which compatible string was matched - For the non-DT case (abnormal) it is provided by U_BOOT_DEVICE() and available before bind()
()>>> struct udevice **devp)
if (parent_plat)
It would help because each bank would have a separate node, so you wouldn't need any of this logic.
OK I see.
gpio@2200000 { compatible = "nvidia,tegra186-gpio"; reg-names = "security", "gpio"; reg = <0x0 0x2200000 0x0 0x10000>, <0x0 0x2210000 0x0 0x10000>; interrupts = <0 47 IRQ_TYPE_LEVEL_HIGH>, <0 50 IRQ_TYPE_LEVEL_HIGH>, <0 53 IRQ_TYPE_LEVEL_HIGH>, <0 56 IRQ_TYPE_LEVEL_HIGH>, <0 59 IRQ_TYPE_LEVEL_HIGH>, <0 180 IRQ_TYPE_LEVEL_HIGH>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; }; gpio@c2f0000 { compatible = "nvidia,tegra186-gpio-aon"; reg-names = "security", "gpio"; reg = <0x0 0xc2f0000 0x0 0x1000>, <0x0 0xc2f1000 0x0 0x1000>; interrupts = <0 60 IRQ_TYPE_LEVEL_HIGH>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; };
OK
I was suggesting passing the platform data pointer to device_bind(), but actually it doesn't help here as it is the parent device that needs it.
This is a hard case. I think the least worst alternative is to add a new device_bind_with_driver_data() function which can be called only within driver model (from lists_bind_fdt() and I suppose device_bind()). The existing device_bind() function signature can then be left alone. Would that suit?
If so, can you please do a core DM patch and update the README to explain this usage?
Stephen Warren
