[PATCH] phy: rockchip: inno-usb2: fix hang when multiple controllers exit
The OHCI and EHCI controllers are both bound to the same PHY. They will both do init and power_on operations when the controller is brought up and both do power_off and exit when the controller is stopped. However, the PHY uclass of U-Boot is not as sane as we thought -- they won't maintain a status mark for PHYs, and thus the functions of the PHYs could be called for multiple times. Calling init/power_on for multiple times have no severe problems, however calling power_off/exit for multiple times have a problem -- the first exit call will stop the PHY clock, and power_off/exit calls after it still trying to write to PHY registers. The write operation to PHY registers will fail because clock is already stopped.
Adapt the count mechanism from phy-sun4i-usb to both init/exit and power_on/power_off functions to phy-rockchip-inno-usb2 to fix this problem. With this stopping USB controllers (manually or before booting a kernel) will work.
Signed-off-by: Icenowy Zheng icenowy@aosc.io Fixes: ac97a9ece14e ("phy: rockchip: Add Rockchip USB2PHY driver") --- drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 21 +++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c index 62b8ba3a4a..be9cc99d90 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -62,6 +62,8 @@ struct rockchip_usb2phy { void *reg_base; struct clk phyclk; const struct rockchip_usb2phy_cfg *phy_cfg; + int init_count; + int power_on_count; };
static inline int property_enable(void *reg_base, @@ -92,6 +94,10 @@ static int rockchip_usb2phy_power_on(struct phy *phy) struct rockchip_usb2phy *priv = dev_get_priv(parent); const struct rockchip_usb2phy_port_cfg *port_cfg = us2phy_get_port(phy);
+ priv->power_on_count++; + if (priv->power_on_count != 1) + return 0; + property_enable(priv->reg_base, &port_cfg->phy_sus, false);
/* waiting for the utmi_clk to become stable */ @@ -106,6 +112,10 @@ static int rockchip_usb2phy_power_off(struct phy *phy) struct rockchip_usb2phy *priv = dev_get_priv(parent); const struct rockchip_usb2phy_port_cfg *port_cfg = us2phy_get_port(phy);
+ priv->power_on_count--; + if (priv->power_on_count != 0) + return 0; + property_enable(priv->reg_base, &port_cfg->phy_sus, true);
return 0; @@ -118,6 +128,10 @@ static int rockchip_usb2phy_init(struct phy *phy) const struct rockchip_usb2phy_port_cfg *port_cfg = us2phy_get_port(phy); int ret;
+ priv->init_count++; + if (priv->init_count != 1) + return 0; + ret = clk_enable(&priv->phyclk); if (ret) { dev_err(phy->dev, "failed to enable phyclk (ret=%d)\n", ret); @@ -140,6 +154,10 @@ static int rockchip_usb2phy_exit(struct phy *phy) struct udevice *parent = dev_get_parent(phy->dev); struct rockchip_usb2phy *priv = dev_get_priv(parent);
+ priv->init_count--; + if (priv->init_count != 0) + return 0; + clk_disable(&priv->phyclk);
return 0; @@ -212,6 +230,9 @@ static int rockchip_usb2phy_probe(struct udevice *dev) return ret; }
+ priv->power_on_count = 0; + priv->init_count = 0; + return 0; }
Tested-by: Peter Robinson pbrobinson@gmail.com
Tested on Rock960 and Pinebook Pro with both USB1 and USB2 devices connected and it fixes issues I have seen. Thanks!
int init_count;
int power_on_count;
property_enable(priv->reg_base, &port_cfg->phy_sus, false); /* waiting for the utmi_clk to become stable */
property_enable(priv->reg_base, &port_cfg->phy_sus, true); return 0;
priv->init_count++;
priv->init_count--;
clk_disable(&priv->phyclk); return 0;
-- 2.30.2
Hi Icenowy Zheng,
In my view, it is better to implement this mechanism in phy-uclass which resemble Linux Kernel have implemented that can avoid do duplication of work in each SoC's PHY driver.
BR. Frank
int init_count;
- priv->init_count++;
- if (priv->init_count != 1)
- ret = clk_enable(&priv->phyclk); if (ret) { dev_err(phy->dev, "failed to enable phyclk (ret=%d)\n", ret);
priv->init_count--;
- priv->power_on_count = 0;
- priv->init_count = 0;
- return 0; }
于 2021年4月7日 GMT+08:00 下午2:42:34, Frank Wang frank.wang@rock-chips.com 写到:
Hi Icenowy Zheng,
I'm afraid of breaking existing drivers when implementing it in uclass, although I agree this will be more clean.
BR. Frank
will
up
However,
multiple
PHY
clock
is already stopped.
booting
int init_count;
*phy)
*phy)
*phy)
int ret;
*phy)
priv->init_count--;
*dev)
return ret;
- return 0; }
Hi Icenowy Zheng,
Why would it break existing drivers? Refer to clk-uclass, the count mechanism was also introduced later from commit "e6849e2fd clk: introduce enable_count". So fix it in framework codes is much better than in each instance drivers just like clk-uclass.
BR. Frank
BR. Frank
will
up
However,
multiple
PHY
clock
is already stopped.
booting
int init_count;
*phy)
*phy)
*phy)
int ret;
*phy)
priv->init_count--;
*dev)
return ret; }
- return 0; }
于 2021年4月7日 GMT+08:00 下午3:28:53, Frank Wang frank.wang@rock-chips.com 写到:
Hi Icenowy Zheng,
of
uclass,
Okay, I will try.
BR. Frank
BR. Frank
will
up
However,
multiple
PHY
PHY
clock
is already stopped.
booting
int init_count;
*phy)
phy
*phy)
*phy)
int ret;
*phy)
priv->init_count--;
udevice
*dev)
return ret; }
- return 0; }
Hi Icenowy Zheng,
of
uclass,
Okay, I will try.
Any progress on this one? I can also confirm that the patch solves hanging on ExitBootServices() when I'm using a USB flash drive, but it still hangs with a USB keyboard plugged in.
g.
BR. Frank
BR. Frank
will
up
However,
multiple
PHY
PHY
clock
is already stopped.
booting
int init_count;
*phy)
phy
*phy)
*phy)
int ret;
*phy)
priv->init_count--;
udevice
*dev)
return ret; }
}return 0;
- int init_count;
- int power_on_count;
priv->init_count--;
-- 2.30.2
Are there any plans of submitting this patch to u-boot mainline? I recently got a pinebook pro and got u-boot mainline working as-is plus this patch. I can confirm that this fixes the issue for me.
在 2021-10-23星期六的 13:23 -0400,Siva Mahadevan写道:
diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c index 62b8ba3a4a..be9cc99d90 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -62,6 +62,8 @@ struct rockchip_usb2phy { void *reg_base; struct clk phyclk; const struct rockchip_usb2phy_cfg *phy_cfg; + int init_count; + int power_on_count; }; static inline int property_enable(void *reg_base, @@ -92,6 +94,10 @@ static int rockchip_usb2phy_power_on(struct phy *phy) struct rockchip_usb2phy *priv = dev_get_priv(parent); const struct rockchip_usb2phy_port_cfg *port_cfg = us2phy_get_port(phy); + priv->power_on_count++; + if (priv->power_on_count != 1) + return 0;
property_enable(priv->reg_base, &port_cfg->phy_sus, false); /* waiting for the utmi_clk to become stable */ @@ -106,6 +112,10 @@ static int rockchip_usb2phy_power_off(struct phy *phy) struct rockchip_usb2phy *priv = dev_get_priv(parent); const struct rockchip_usb2phy_port_cfg *port_cfg = us2phy_get_port(phy); + priv->power_on_count--; + if (priv->power_on_count != 0) + return 0;
property_enable(priv->reg_base, &port_cfg->phy_sus, true); return 0; @@ -118,6 +128,10 @@ static int rockchip_usb2phy_init(struct phy *phy) const struct rockchip_usb2phy_port_cfg *port_cfg = us2phy_get_port(phy); int ret; + priv->init_count++; + if (priv->init_count != 1) + return 0;
ret = clk_enable(&priv->phyclk); if (ret) { dev_err(phy->dev, "failed to enable phyclk (ret=%d)\n", ret); @@ -140,6 +154,10 @@ static int rockchip_usb2phy_exit(struct phy *phy) struct udevice *parent = dev_get_parent(phy->dev); struct rockchip_usb2phy *priv = dev_get_priv(parent); + priv->init_count--; + if (priv->init_count != 0) + return 0;
clk_disable(&priv->phyclk); return 0; @@ -212,6 +230,9 @@ static int rockchip_usb2phy_probe(struct udevice *dev) return ret; } + priv->power_on_count = 0; + priv->init_count = 0;
return 0; } -- 2.30.2
The current maintainer wants a fix in PHY framework instead of the specific driver, but I am recently not interested in fixing it (because PBP is my daily driver now, and I don't dare to do dangerous BL development that will lead to regression on it).
int init_count;
int power_on_count;
priv->init_count++;
priv->init_count--;
-- 2.30.2
From what I can tell the maintainer is correct - the PHY uclass should
be updated as clk was. There is a sandbox driver for the PHY uclass so you can add a test for it the new behaviour. I don't think there is too much risk of a regression, but in any case it seems like the correct fix to me.
participants (6)
Frank Wang
Grant Likely
Icenowy Zheng
Peter Robinson
Siva Mahadevan
