[U-Boot-Users] [PATCH 4/6 part 8] PHY support for QE
Subject: [PATCH] PHY support for QE
drivers/sysdev/qe_lib/ucc/ucc_geth_phy.c | 568 ++++++++++++++++++++++++++++++ drivers/sysdev/qe_lib/ucc/ucc_geth_phy.h | 262 ++++++++++++++ 2 files changed, 830 insertions(+), 0 deletions(-) create mode 100644 drivers/sysdev/qe_lib/ucc/ucc_geth_phy.c create mode 100644 drivers/sysdev/qe_lib/ucc/ucc_geth_phy.h
e066a4f092e8a4812983e0ff5fde933c4727e354 diff --git a/drivers/sysdev/qe_lib/ucc/ucc_geth_phy.c b/drivers/sysdev/qe_lib/ucc/ucc_geth_phy.c new file mode 100644 index 0000000..7cf725b --- /dev/null +++ b/drivers/sysdev/qe_lib/ucc/ucc_geth_phy.c @@ -0,0 +1,568 @@ +/* + * drivers/sysdev/qe_lib/ucc/ucc_geth_phy.c + * + * UCC GETH Driver -- PHY handling + * Driver for UEC on QE + * Based on 8260_io/fcc_enet.c + * + * Copyright (c) 2002-2006 Freescale Semiconductor, Inc. + * Author: Shlomi Gridish + * Maintainer: Kumar Gala (kumar.gala@freescale.com) + * + * History: + * 20060601 tanya jiang (tanya.jiang@freescale.com) + * Code style fixed; move from cpu/mpc83xx to drivers/sysdev + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + */ + +#include "common.h" +#include "net.h" +#include "malloc.h" +#include "list.h" +#include "asm/errno.h" +#include "immap_qe.h" +#include "qe.h" +#include "asm/io.h" +#include "ucc.h" +#include "ucc_fast.h" +#include "ucc_geth.h" +#include "ucc_geth_phy.h" + +#include "miiphy.h" + +#define UGETH_VERBOSE_DEBUG +#define ugphy_printk(format, arg...) \ + printf(format "\n", ## arg) + +#define ugphy_dbg(format, arg...) \ + ugphy_printk(format , ## arg) +#define ugphy_err(format, arg...) \ + ugphy_printk(format , ## arg) +#define ugphy_info(format, arg...) \ + ugphy_printk(format , ## arg) +#define ugphy_warn(format, arg...) \ + ugphy_printk(format , ## arg) + +#ifdef UGETH_VERBOSE_DEBUG +#define ugphy_vdbg ugphy_dbg +#else +#define ugphy_vdbg(ugeth, fmt, args...) do { } while (0) +#endif /* UGETH_VERBOSE_DEBUG */ + +static void config_genmii_advert(struct ugeth_mii_info *mii_info); +static void genmii_setup_forced(struct ugeth_mii_info *mii_info); +static void genmii_restart_aneg(struct ugeth_mii_info *mii_info); +static int gbit_config_aneg(struct ugeth_mii_info *mii_info); +static int genmii_config_aneg(struct ugeth_mii_info *mii_info); +static int genmii_update_link(struct ugeth_mii_info *mii_info); +static int genmii_read_status(struct ugeth_mii_info *mii_info); +u16 phy_read(struct ugeth_mii_info *mii_info, u16 regnum); +void phy_write(struct ugeth_mii_info *mii_info, u16 regnum, u16 val); + +/* Write value to the PHY for this device to the register at regnum, */ +/* waiting until the write is done before it returns. All PHY */ +/* configuration has to be done through the TSEC1 MIIM regs */ +void write_phy_reg(struct eth_device *dev, int mii_id, int regnum, int value) +{ + ucc_geth_private_t *ugeth = (ucc_geth_private_t *) dev->priv; + ucc_geth_t *ug_regs; + enet_tbi_mii_reg_e mii_reg = (enet_tbi_mii_reg_e) regnum; + u32 tmp_reg; + + ug_regs = ugeth->ug_regs; + + /* Stop the MII management read cycle */ + out_be32(&ug_regs->miimcom, 0); + /* Setting up the MII Mangement Address Register */ + tmp_reg = ((u32) mii_id << MIIMADD_PHY_ADDRESS_SHIFT) | mii_reg; + out_be32(&ug_regs->miimadd, tmp_reg); + + /* Setting up the MII Mangement Control Register with the value */ + out_be32(&ug_regs->miimcon, (u32) value); + + /* Wait till MII management write is complete */ + while ((in_be32(&ug_regs->miimind)) & MIIMIND_BUSY) ; + + udelay(100000); +} + +/* Reads from register regnum in the PHY for device dev, */ +/* returning the value. Clears miimcom first. All PHY */ +/* configuration has to be done through the TSEC1 MIIM regs */ +int read_phy_reg(struct eth_device *dev, int mii_id, int regnum) +{ + ucc_geth_private_t *ugeth = (ucc_geth_private_t *) dev->priv; + ucc_geth_t *ug_regs; + enet_tbi_mii_reg_e mii_reg = (enet_tbi_mii_reg_e) regnum; + u32 tmp_reg; + u16 value; + + ug_regs = ugeth->ug_regs; + + /* Setting up the MII Mangement Address Register */ + tmp_reg = ((u32) mii_id << MIIMADD_PHY_ADDRESS_SHIFT) | mii_reg; + out_be32(&ug_regs->miimadd, tmp_reg); + + /* Perform an MII management read cycle */ + out_be32(&ug_regs->miimcom, 0); + out_be32(&ug_regs->miimcom, MIIMCOM_READ_CYCLE); + + /* Wait till MII management write is complete */ + while ((in_be32(&ug_regs->miimind)) & + (MIIMIND_NOT_VALID | MIIMIND_BUSY)) ; + + udelay(100000); + + /* Read MII management status */ + value = (u16) in_be32(&ug_regs->miimstat); + if (value == 0xffff) + ugphy_warn("read wrong value : mii_id %d,mii_reg %d, base %08x", + mii_id, mii_reg, (u32) & (ug_regs->miimcfg)); + + return (value); +} + +void mii_clear_phy_interrupt(struct ugeth_mii_info *mii_info) +{ + if (mii_info->phyinfo->ack_interrupt) + mii_info->phyinfo->ack_interrupt(mii_info); +} + +void mii_configure_phy_interrupt(struct ugeth_mii_info *mii_info, + u32 interrupts) +{ + mii_info->interrupts = interrupts; + if (mii_info->phyinfo->config_intr) + mii_info->phyinfo->config_intr(mii_info); +} + +/* Writes MII_ADVERTISE with the appropriate values, after + * sanitizing advertise to make sure only supported features + * are advertised + */ +static void config_genmii_advert(struct ugeth_mii_info *mii_info) +{ + u32 advertise; + u16 adv; + + /* Only allow advertising what this PHY supports */ + mii_info->advertising &= mii_info->phyinfo->features; + advertise = mii_info->advertising; + + /* Setup standard advertisement */ + adv = phy_read(mii_info, PHY_ANAR); + adv &= ~(ADVERTISE_ALL | ADVERTISE_100BASE4); + if (advertise & ADVERTISED_10baseT_Half) + adv |= ADVERTISE_10HALF; + if (advertise & ADVERTISED_10baseT_Full) + adv |= ADVERTISE_10FULL; + if (advertise & ADVERTISED_100baseT_Half) + adv |= ADVERTISE_100HALF; + if (advertise & ADVERTISED_100baseT_Full) + adv |= ADVERTISE_100FULL; + phy_write(mii_info, PHY_ANAR, adv); +} + +static void genmii_setup_forced(struct ugeth_mii_info *mii_info) +{ + u16 ctrl; + u32 features = mii_info->phyinfo->features; + + ctrl = phy_read(mii_info, PHY_BMCR); + + ctrl &= + ~(PHY_BMCR_DPLX | PHY_BMCR_100_MBPS | PHY_BMCR_1000_MBPS | + PHY_BMCR_AUTON); + ctrl |= PHY_BMCR_RESET; + + switch (mii_info->speed) { + case SPEED_1000: + if (features & (SUPPORTED_1000baseT_Half + | SUPPORTED_1000baseT_Full)) { + ctrl |= PHY_BMCR_1000_MBPS; + break; + } + mii_info->speed = SPEED_100; + case SPEED_100: + if (features & (SUPPORTED_100baseT_Half + | SUPPORTED_100baseT_Full)) { + ctrl |= PHY_BMCR_100_MBPS; + break; + } + mii_info->speed = SPEED_10; + case SPEED_10: + if (features & (SUPPORTED_10baseT_Half + | SUPPORTED_10baseT_Full)) + break; + default: /* Unsupported speed! */ + ugphy_err("%s: Bad speed!", mii_info->dev->name); + break; + } + + phy_write(mii_info, PHY_BMCR, ctrl); +} + +/* Enable and Restart Autonegotiation */ +static void genmii_restart_aneg(struct ugeth_mii_info *mii_info) +{ + u16 ctl; + + ctl = phy_read(mii_info, PHY_BMCR); + ctl |= (PHY_BMCR_AUTON | PHY_BMCR_RST_NEG); + phy_write(mii_info, PHY_BMCR, ctl); +} + +static int gbit_config_aneg(struct ugeth_mii_info *mii_info) +{ + u16 adv; + u32 advertise; + + if (mii_info->autoneg) { + /* Configure the ADVERTISE register */ + config_genmii_advert(mii_info); + advertise = mii_info->advertising; + + adv = phy_read(mii_info, MII_1000BASETCONTROL); + adv &= ~(MII_1000BASETCONTROL_FULLDUPLEXCAP | + MII_1000BASETCONTROL_HALFDUPLEXCAP); + if (advertise & SUPPORTED_1000baseT_Half) + adv |= MII_1000BASETCONTROL_HALFDUPLEXCAP; + if (advertise & SUPPORTED_1000baseT_Full) + adv |= MII_1000BASETCONTROL_FULLDUPLEXCAP; + phy_write(mii_info, MII_1000BASETCONTROL, adv); + + /* Start/Restart aneg */ + genmii_restart_aneg(mii_info); + } else + genmii_setup_forced(mii_info); + + return 0; +} + +static int marvell_config_aneg(struct ugeth_mii_info *mii_info) +{ + /* The Marvell PHY has an errata which requires + * that certain registers get written in order + * to restart autonegotiation */ + phy_write(mii_info, PHY_BMCR, PHY_BMCR_RESET); + + phy_write(mii_info, 0x1d, 0x1f); + phy_write(mii_info, 0x1e, 0x200c); + phy_write(mii_info, 0x1d, 0x5); + phy_write(mii_info, 0x1e, 0); + phy_write(mii_info, 0x1e, 0x100); + + gbit_config_aneg(mii_info); + + return 0; +} +static int genmii_config_aneg(struct ugeth_mii_info *mii_info) +{ + if (mii_info->autoneg) { + config_genmii_advert(mii_info); + genmii_restart_aneg(mii_info); + } else + genmii_setup_forced(mii_info); + + return 0; +} + +static int genmii_update_link(struct ugeth_mii_info *mii_info) +{ + u16 status; + + /* Do a fake read */ + phy_read(mii_info, PHY_BMSR); + + /* Read link and autonegotiation status */ + status = phy_read(mii_info, PHY_BMSR); + if ((status & PHY_BMSR_LS) == 0) + mii_info->link = 0; + else + mii_info->link = 1; + + /* If we are autonegotiating, and not done, + * return an error */ + if (mii_info->autoneg && !(status & PHY_BMSR_AUTN_COMP)) + return -EAGAIN; + + return 0; +} + +static int genmii_read_status(struct ugeth_mii_info *mii_info) +{ + u16 status; + int err; + + /* Update the link, but return if there + * was an error */ + err = genmii_update_link(mii_info); + if (err) + return err; + + if (mii_info->autoneg) { + status = phy_read(mii_info, PHY_ANLPAR); + + if (status & (PHY_ANLPAR_10FD | PHY_ANLPAR_TXFD)) + mii_info->duplex = DUPLEX_FULL; + else + mii_info->duplex = DUPLEX_HALF; + if (status & (PHY_ANLPAR_TXFD | PHY_ANLPAR_TX)) + mii_info->speed = SPEED_100; + else + mii_info->speed = SPEED_10; + mii_info->pause = 0; + } + /* On non-aneg, we assume what we put in BMCR is the speed, + * though magic-aneg shouldn't prevent this case from occurring + */ + + return 0; +} +static int marvell_read_status(struct ugeth_mii_info *mii_info) +{ + u16 status; + int err; + + /* Update the link, but return if there + * was an error */ + err = genmii_update_link(mii_info); + if (err) + return err; + + /* If the link is up, read the speed and duplex */ + /* If we aren't autonegotiating, assume speeds + * are as set */ + if (mii_info->autoneg && mii_info->link) { + int speed; + status = phy_read(mii_info, MII_M1011_PHY_SPEC_STATUS); + +#if 0 + /* If speed and duplex aren't resolved, + * return an error. Isn't this handled + * by checking aneg? + */ + if ((status & MII_M1011_PHY_SPEC_STATUS_RESOLVED) == 0) + return -EAGAIN; +#endif + + /* Get the duplexity */ + if (status & MII_M1011_PHY_SPEC_STATUS_FULLDUPLEX) + mii_info->duplex = DUPLEX_FULL; + else + mii_info->duplex = DUPLEX_HALF; + + /* Get the speed */ + speed = status & MII_M1011_PHY_SPEC_STATUS_SPD_MASK; + switch (speed) { + case MII_M1011_PHY_SPEC_STATUS_1000: + mii_info->speed = SPEED_1000; + break; + case MII_M1011_PHY_SPEC_STATUS_100: + mii_info->speed = SPEED_100; + break; + default: + mii_info->speed = SPEED_10; + break; + } + mii_info->pause = 0; + } + + return 0; +} + +static int marvell_ack_interrupt(struct ugeth_mii_info *mii_info) +{ + /* Clear the interrupts by reading the reg */ + phy_read(mii_info, MII_M1011_IEVENT); + + return 0; +} + +static int marvell_config_intr(struct ugeth_mii_info *mii_info) +{ + if (mii_info->interrupts == MII_INTERRUPT_ENABLED) + phy_write(mii_info, MII_M1011_IMASK, MII_M1011_IMASK_INIT); + else + phy_write(mii_info, MII_M1011_IMASK, MII_M1011_IMASK_CLEAR); + + return 0; +} + +static int dm9161_init(struct ugeth_mii_info *mii_info) +{ + /* Reset the PHY */ + phy_write(mii_info, PHY_BMCR, + phy_read(mii_info, PHY_BMCR) | PHY_BMCR_RESET); + /* PHY and MAC connect */ + phy_write(mii_info, PHY_BMCR, + phy_read(mii_info, PHY_BMCR) & ~PHY_BMCR_ISO); +#if CONFIG_RMII_MODE == 1 + phy_write(mii_info, MII_DM9161_SCR, MII_DM9161_SCR_RMII_INIT); +#else + phy_write(mii_info, MII_DM9161_SCR, MII_DM9161_SCR_INIT); +#endif + config_genmii_advert(mii_info); + /* Start/restart aneg */ + genmii_config_aneg(mii_info); + + udelay(3000000); + + return 0; +} + +static int dm9161_config_aneg(struct ugeth_mii_info *mii_info) +{ + return 0; +} + +static int dm9161_read_status(struct ugeth_mii_info *mii_info) +{ + u16 status; + int err; + + /* Update the link, but return if there was an error */ + err = genmii_update_link(mii_info); + if (err) + return err; + /* If the link is up, read the speed and duplex + If we aren't autonegotiating assume speeds are as set */ + if (mii_info->autoneg && mii_info->link) { + status = phy_read(mii_info, MII_DM9161_SCSR); + if (status & (MII_DM9161_SCSR_100F | MII_DM9161_SCSR_100H)) + mii_info->speed = SPEED_100; + else + mii_info->speed = SPEED_10; + + if (status & (MII_DM9161_SCSR_100F | MII_DM9161_SCSR_10F)) + mii_info->duplex = DUPLEX_FULL; + else + mii_info->duplex = DUPLEX_HALF; + } + + return 0; +} + +static int dm9161_ack_interrupt(struct ugeth_mii_info *mii_info) +{ + /* Clear the interrupt by reading the reg */ + phy_read(mii_info, MII_DM9161_INTR); + + return 0; +} + +static int dm9161_config_intr(struct ugeth_mii_info *mii_info) +{ + if (mii_info->interrupts == MII_INTERRUPT_ENABLED) + phy_write(mii_info, MII_DM9161_INTR, MII_DM9161_INTR_INIT); + else + phy_write(mii_info, MII_DM9161_INTR, MII_DM9161_INTR_STOP); + + return 0; +} + +static void dm9161_close(struct ugeth_mii_info *mii_info) +{ +} + +static struct phy_info phy_info_dm9161 = { + .phy_id = 0x0181b880, + .phy_id_mask = 0x0ffffff0, + .name = "Davicom DM9161E", + .init = dm9161_init, + .config_aneg = dm9161_config_aneg, + .read_status = dm9161_read_status, + .close = dm9161_close, +}; + +static struct phy_info phy_info_dm9161a = { + .phy_id = 0x0181b8a0, + .phy_id_mask = 0x0ffffff0, + .name = "Davicom DM9161A", + .features = MII_BASIC_FEATURES, + .init = dm9161_init, + .config_aneg = dm9161_config_aneg, + .read_status = dm9161_read_status, + .ack_interrupt = dm9161_ack_interrupt, + .config_intr = dm9161_config_intr, + .close = dm9161_close, +}; + +static struct phy_info phy_info_marvell = { + .phy_id = 0x01410c00, + .phy_id_mask = 0xffffff00, + .name = "Marvell 88E11x1", + .features = MII_GBIT_FEATURES, + .config_aneg = &marvell_config_aneg, + .read_status = &marvell_read_status, + .ack_interrupt = &marvell_ack_interrupt, + .config_intr = &marvell_config_intr, +}; + +static struct phy_info phy_info_genmii = { + .phy_id = 0x00000000, + .phy_id_mask = 0x00000000, + .name = "Generic MII", + .features = MII_BASIC_FEATURES, + .config_aneg = genmii_config_aneg, + .read_status = genmii_read_status, +}; + +static struct phy_info *phy_info[] = { + &phy_info_dm9161, + &phy_info_dm9161a, + &phy_info_marvell, + &phy_info_genmii, + NULL +}; + +u16 phy_read(struct ugeth_mii_info *mii_info, u16 regnum) +{ + return mii_info->mdio_read(mii_info->dev, mii_info->mii_id, regnum); +} + +void phy_write(struct ugeth_mii_info *mii_info, u16 regnum, u16 val) +{ + mii_info->mdio_write(mii_info->dev, mii_info->mii_id, regnum, val); +} + +/* Use the PHY ID registers to determine what type of PHY is attached + * to device dev. return a struct phy_info structure describing that PHY + */ +struct phy_info *get_phy_info(struct ugeth_mii_info *mii_info) +{ + u16 phy_reg; + u32 phy_ID; + int i; + struct phy_info *theInfo = NULL; + + /* Grab the bits from PHYIR1, and put them in the upper half */ + phy_reg = phy_read(mii_info, PHY_PHYIDR1); + phy_ID = (phy_reg & 0xffff) << 16; + + /* Grab the bits from PHYIR2, and put them in the lower half */ + phy_reg = phy_read(mii_info, PHY_PHYIDR2); + phy_ID |= (phy_reg & 0xffff); + + /* loop through all the known PHY types, and find one that */ + /* matches the ID we read from the PHY. */ + for (i = 0; phy_info[i]; i++) + if (phy_info[i]->phy_id == (phy_ID & phy_info[i]->phy_id_mask)) { + theInfo = phy_info[i]; + break; + } + + /* This shouldn't happen, as we have generic PHY support */ + if (theInfo == NULL) { + ugphy_info("geth: PHY id %x is not supported!", phy_ID); + return NULL; + } else { + ugphy_info("geth: PHY is %s (%x)", theInfo->name, phy_ID); + } + + return theInfo; +} diff --git a/drivers/sysdev/qe_lib/ucc/ucc_geth_phy.h b/drivers/sysdev/qe_lib/ucc/ucc_geth_phy.h new file mode 100644 index 0000000..a711116 --- /dev/null +++ b/drivers/sysdev/qe_lib/ucc/ucc_geth_phy.h @@ -0,0 +1,262 @@ +/* + * drivers/sysdev/qe_lib/ucc/ucc_geth_phy.h + * + * UCC GETH Driver Header File + * + * Copyright (c) 2002-2006 Freescale Semiconductor, Inc. + * Author: Shlomi Gridish + * Maintainer: Kumar Gala (kumar.gala@freescale.com) + * + * History: + * 20060601 tanya jiang (tanya.jiang@freescale.com) + * Code style fixed; move from cpu/mpc83xx to drivers/sysdev + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + */ +#ifndef __UCC_GETH_PHY_H__ +#define __UCC_GETH_PHY_H__ + +#define MII_end ((u32)-2) +#define MII_read ((u32)-1) + +#define MIIMIND_BUSY 0x00000001 +#define MIIMIND_NOTVALID 0x00000004 + +#define UGETH_AN_TIMEOUT 2000 + +/* 1000BT control (Marvell & BCM54xx at least) */ +#define MII_1000BASETCONTROL 0x09 +#define MII_1000BASETCONTROL_FULLDUPLEXCAP 0x0200 +#define MII_1000BASETCONTROL_HALFDUPLEXCAP 0x0100 + +/* Cicada Extended Control Register 1 */ +#define MII_CIS8201_EXT_CON1 0x17 +#define MII_CIS8201_EXTCON1_INIT 0x0000 + +/* Cicada Interrupt Mask Register */ +#define MII_CIS8201_IMASK 0x19 +#define MII_CIS8201_IMASK_IEN 0x8000 +#define MII_CIS8201_IMASK_SPEED 0x4000 +#define MII_CIS8201_IMASK_LINK 0x2000 +#define MII_CIS8201_IMASK_DUPLEX 0x1000 +#define MII_CIS8201_IMASK_MASK 0xf000 + +/* Cicada Interrupt Status Register */ +#define MII_CIS8201_ISTAT 0x1a +#define MII_CIS8201_ISTAT_STATUS 0x8000 +#define MII_CIS8201_ISTAT_SPEED 0x4000 +#define MII_CIS8201_ISTAT_LINK 0x2000 +#define MII_CIS8201_ISTAT_DUPLEX 0x1000 + +/* Cicada Auxiliary Control/Status Register */ +#define MII_CIS8201_AUX_CONSTAT 0x1c +#define MII_CIS8201_AUXCONSTAT_INIT 0x0004 +#define MII_CIS8201_AUXCONSTAT_DUPLEX 0x0020 +#define MII_CIS8201_AUXCONSTAT_SPEED 0x0018 +#define MII_CIS8201_AUXCONSTAT_GBIT 0x0010 +#define MII_CIS8201_AUXCONSTAT_100 0x0008 + +/* 88E1011 PHY Status Register */ +#define MII_M1011_PHY_SPEC_STATUS 0x11 +#define MII_M1011_PHY_SPEC_STATUS_1000 0x8000 +#define MII_M1011_PHY_SPEC_STATUS_100 0x4000 +#define MII_M1011_PHY_SPEC_STATUS_SPD_MASK 0xc000 +#define MII_M1011_PHY_SPEC_STATUS_FULLDUPLEX 0x2000 +#define MII_M1011_PHY_SPEC_STATUS_RESOLVED 0x0800 +#define MII_M1011_PHY_SPEC_STATUS_LINK 0x0400 + +#define MII_M1011_IEVENT 0x13 +#define MII_M1011_IEVENT_CLEAR 0x0000 + +#define MII_M1011_IMASK 0x12 +#define MII_M1011_IMASK_INIT 0x6400 +#define MII_M1011_IMASK_CLEAR 0x0000 + +#define MII_DM9161_SCR 0x10 +#define MII_DM9161_SCR_INIT 0x0610 +#define MII_DM9161_SCR_RMII_INIT 0x0710 + +/* DM9161 Specified Configuration and Status Register */ +#define MII_DM9161_SCSR 0x11 +#define MII_DM9161_SCSR_100F 0x8000 +#define MII_DM9161_SCSR_100H 0x4000 +#define MII_DM9161_SCSR_10F 0x2000 +#define MII_DM9161_SCSR_10H 0x1000 + +/* DM9161 Interrupt Register */ +#define MII_DM9161_INTR 0x15 +#define MII_DM9161_INTR_PEND 0x8000 +#define MII_DM9161_INTR_DPLX_MASK 0x0800 +#define MII_DM9161_INTR_SPD_MASK 0x0400 +#define MII_DM9161_INTR_LINK_MASK 0x0200 +#define MII_DM9161_INTR_MASK 0x0100 +#define MII_DM9161_INTR_DPLX_CHANGE 0x0010 +#define MII_DM9161_INTR_SPD_CHANGE 0x0008 +#define MII_DM9161_INTR_LINK_CHANGE 0x0004 +#define MII_DM9161_INTR_INIT 0x0000 +#define MII_DM9161_INTR_STOP \ + (MII_DM9161_INTR_DPLX_MASK | MII_DM9161_INTR_SPD_MASK \ + | MII_DM9161_INTR_LINK_MASK | MII_DM9161_INTR_MASK) + +/* DM9161 10BT Configuration/Status */ +#define MII_DM9161_10BTCSR 0x12 +#define MII_DM9161_10BTCSR_INIT 0x7800 + +#define MII_BASIC_FEATURES (SUPPORTED_10baseT_Half | \ + SUPPORTED_10baseT_Full | \ + SUPPORTED_100baseT_Half | \ + SUPPORTED_100baseT_Full | \ + SUPPORTED_Autoneg | \ + SUPPORTED_TP | \ + SUPPORTED_MII) + +#define MII_GBIT_FEATURES (MII_BASIC_FEATURES | \ + SUPPORTED_1000baseT_Half | \ + SUPPORTED_1000baseT_Full) + +#define MII_READ_COMMAND 0x00000001 + +#define MII_INTERRUPT_DISABLED 0x0 +#define MII_INTERRUPT_ENABLED 0x1 + +#define SPEED_10 10 +#define SPEED_100 100 +#define SPEED_1000 1000 + +/* Duplex, half or full. */ +#define DUPLEX_HALF 0x00 +#define DUPLEX_FULL 0x01 + +/* Indicates what features are supported by the interface. */ +#define SUPPORTED_10baseT_Half (1 << 0) +#define SUPPORTED_10baseT_Full (1 << 1) +#define SUPPORTED_100baseT_Half (1 << 2) +#define SUPPORTED_100baseT_Full (1 << 3) +#define SUPPORTED_1000baseT_Half (1 << 4) +#define SUPPORTED_1000baseT_Full (1 << 5) +#define SUPPORTED_Autoneg (1 << 6) +#define SUPPORTED_TP (1 << 7) +#define SUPPORTED_AUI (1 << 8) +#define SUPPORTED_MII (1 << 9) +#define SUPPORTED_FIBRE (1 << 10) +#define SUPPORTED_BNC (1 << 11) +#define SUPPORTED_10000baseT_Full (1 << 12) + +#define ADVERTISED_10baseT_Half (1 << 0) +#define ADVERTISED_10baseT_Full (1 << 1) +#define ADVERTISED_100baseT_Half (1 << 2) +#define ADVERTISED_100baseT_Full (1 << 3) +#define ADVERTISED_1000baseT_Half (1 << 4) +#define ADVERTISED_1000baseT_Full (1 << 5) +#define ADVERTISED_Autoneg (1 << 6) +#define ADVERTISED_TP (1 << 7) +#define ADVERTISED_AUI (1 << 8) +#define ADVERTISED_MII (1 << 9) +#define ADVERTISED_FIBRE (1 << 10) +#define ADVERTISED_BNC (1 << 11) +#define ADVERTISED_10000baseT_Full (1 << 12) + +/* Advertisement control register. */ +#define ADVERTISE_SLCT 0x001f /* Selector bits */ +#define ADVERTISE_CSMA 0x0001 /* Only selector supported */ +#define ADVERTISE_10HALF 0x0020 /* Try for 10mbps half-duplex */ +#define ADVERTISE_10FULL 0x0040 /* Try for 10mbps full-duplex */ +#define ADVERTISE_100HALF 0x0080 /* Try for 100mbps half-duplex */ +#define ADVERTISE_100FULL 0x0100 /* Try for 100mbps full-duplex */ +#define ADVERTISE_100BASE4 0x0200 /* Try for 100mbps 4k packets */ +#define ADVERTISE_RESV 0x1c00 /* Unused... */ +#define ADVERTISE_RFAULT 0x2000 /* Say we can detect faults */ +#define ADVERTISE_LPACK 0x4000 /* Ack link partners response */ +#define ADVERTISE_NPAGE 0x8000 /* Next page bit */ + +#define ADVERTISE_FULL (ADVERTISE_100FULL | ADVERTISE_10FULL | \ + ADVERTISE_CSMA) +#define ADVERTISE_ALL (ADVERTISE_10HALF | ADVERTISE_10FULL | \ + ADVERTISE_100HALF | ADVERTISE_100FULL) + +/* Taken from mii_if_info and sungem_phy.h */ +struct ugeth_mii_info { + /* Information about the PHY type */ + /* And management functions */ + struct phy_info *phyinfo; + + struct eth_device *dev; + + /* forced speed & duplex (no autoneg) + * partner speed & duplex & pause (autoneg) + */ + int speed; + int duplex; + int pause; + + /* The most recently read link state */ + int link; + + /* Enabled Interrupts */ + u32 interrupts; + + u32 advertising; + int autoneg; + int mii_id; + + /* private data pointer */ + /* For use by PHYs to maintain extra state */ + void *priv; + + /* Provided by ethernet driver */ + int (*mdio_read) (struct eth_device * dev, int mii_id, int reg); + void (*mdio_write) (struct eth_device * dev, int mii_id, int reg, + int val); +}; + +/* struct phy_info: a structure which defines attributes for a PHY + * + * id will contain a number which represents the PHY. During + * startup, the driver will poll the PHY to find out what its + * UID--as defined by registers 2 and 3--is. The 32-bit result + * gotten from the PHY will be ANDed with phy_id_mask to + * discard any bits which may change based on revision numbers + * unimportant to functionality + * + * There are 6 commands which take a ugeth_mii_info structure. + * Each PHY must declare config_aneg, and read_status. + */ +struct phy_info { + u32 phy_id; + char *name; + unsigned int phy_id_mask; + u32 features; + + /* Called to initialize the PHY */ + int (*init) (struct ugeth_mii_info * mii_info); + + /* Called to suspend the PHY for power */ + int (*suspend) (struct ugeth_mii_info * mii_info); + + /* Reconfigures autonegotiation (or disables it) */ + int (*config_aneg) (struct ugeth_mii_info * mii_info); + + /* Determines the negotiated speed and duplex */ + int (*read_status) (struct ugeth_mii_info * mii_info); + + /* Clears any pending interrupts */ + int (*ack_interrupt) (struct ugeth_mii_info * mii_info); + + /* Enables or disables interrupts */ + int (*config_intr) (struct ugeth_mii_info * mii_info); + + /* Clears up any memory if needed */ + void (*close) (struct ugeth_mii_info * mii_info); +}; + +struct phy_info *get_phy_info(struct ugeth_mii_info *mii_info); +void write_phy_reg(struct eth_device *dev, int mii_id, int regnum, int value); +int read_phy_reg(struct eth_device *dev, int mii_id, int regnum); +void mii_clear_phy_interrupt(struct ugeth_mii_info *mii_info); +void mii_configure_phy_interrupt(struct ugeth_mii_info *mii_info, + u32 interrupts); + +#endif /* __UCC_GETH_PHY_H__ */
Jiang Bo-r61859
