[PATCH 1/5] tpm: cr50: Check for valid locality
When the Cr50 starts up it doesn't have a valid locality. The driver sets it to -1 to indicate that. Tracking this allows cr50_i2c_cleanup() to avoid releasing a locality that was not claimed.
However the helper functions that generate the flags use a u8 type which cannot support -1, so they return a locality of 0xff.
Fix this by updating the type. With this, 'tpm startup TPM2_SU_CLEAR' works as expected.
drivers/tpm/cr50_i2c.c | 16 ++++++++++++---- 1 file changed, 12 insertions(+), 4 deletions(-)
diff --git a/drivers/tpm/cr50_i2c.c b/drivers/tpm/cr50_i2c.c index ce61b72d222..f53924a8fcb 100644 --- a/drivers/tpm/cr50_i2c.c +++ b/drivers/tpm/cr50_i2c.c @@ -183,23 +183,31 @@ static int cr50_i2c_write(struct udevice *dev, u8 addr, const u8 *buffer, return cr50_i2c_wait_tpm_ready(dev); }
-static inline u8 tpm_access(u8 locality) +static inline u8 tpm_access(int locality) { + if (locality == -1) + locality = 0; return 0x0 | (locality << 4); }
-static inline u8 tpm_sts(u8 locality) +static inline u8 tpm_sts(int locality) { + if (locality == -1) + locality = 0; return 0x1 | (locality << 4); }
-static inline u8 tpm_data_fifo(u8 locality) +static inline u8 tpm_data_fifo(int locality) { + if (locality == -1) + locality = 0; return 0x5 | (locality << 4); }
-static inline u8 tpm_did_vid(u8 locality) +static inline u8 tpm_did_vid(int locality) { + if (locality == -1) + locality = 0; return 0x6 | (locality << 4); }
Update the TPM description to include the interrupt mechanicm since this is useful to know. Also add a warning if the TPM cannot be found and a debug line if it succeeds.
drivers/tpm/cr50_i2c.c | 22 ++++++++++++++++++---- 1 file changed, 18 insertions(+), 4 deletions(-)
diff --git a/drivers/tpm/cr50_i2c.c b/drivers/tpm/cr50_i2c.c index f53924a8fcb..8b792409631 100644 --- a/drivers/tpm/cr50_i2c.c +++ b/drivers/tpm/cr50_i2c.c @@ -380,7 +380,6 @@ out_err: static int cr50_i2c_send(struct udevice *dev, const u8 *buf, size_t len) { struct cr50_priv *priv = dev_get_priv(dev); - int status; size_t burstcnt, limit, sent = 0; u8 tpm_go[4] = { TPM_STS_GO }; @@ -557,9 +556,23 @@ static int cr50_i2c_get_desc(struct udevice *dev, char *buf, int size) { struct dm_i2c_chip *chip = dev_get_parent_plat(dev); struct cr50_priv *priv = dev_get_priv(dev); + int len; + + len = snprintf(buf, size, "cr50 TPM 2.0 (i2c %02x id %x), ", + chip->chip_addr, priv->vendor >> 16); + if (priv->use_irq) { + len += snprintf(buf + len, size - len, "irq=%s/%ld", + priv->irq.dev->name, priv->irq.id); + } else if (dm_gpio_is_valid(&priv->ready_gpio)) { + len += snprintf(buf + len, size - len, "gpio=%s/%u", + priv->ready_gpio.dev->name, + priv->ready_gpio.offset); + } else { + len += snprintf(buf + len, size - len, "delay=%d", + TIMEOUT_NO_IRQ_US); + }
- return snprintf(buf, size, "cr50 TPM 2.0 (i2c %02x id %x) irq=%d", - chip->chip_addr, priv->vendor >> 16, priv->use_irq); + return len; }
static int cr50_i2c_open(struct udevice *dev) @@ -702,11 +715,12 @@ static int cr50_i2c_probe(struct udevice *dev) mdelay(10); } if (vendor != CR50_DID_VID) { - log_debug("DID_VID %08x not recognised\n", vendor); + log_warning("DID_VID %08x not recognised\n", vendor); return log_msg_ret("vendor-id", -EXDEV); } priv->vendor = vendor; priv->locality = -1; + log_debug("Cr50 ready\n");
return 0; }
Applied to u-boot-dm, thanks!
Update the driver name to match the compatible string, so it can work with of-platdata.
drivers/tpm/cr50_i2c.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/tpm/cr50_i2c.c b/drivers/tpm/cr50_i2c.c index 8b792409631..b103a6fdc39 100644 --- a/drivers/tpm/cr50_i2c.c +++ b/drivers/tpm/cr50_i2c.c @@ -742,8 +742,8 @@ static const struct udevice_id cr50_i2c_ids[] = { { } };
-U_BOOT_DRIVER(cr50_i2c) = { - .name = "cr50_i2c", +U_BOOT_DRIVER(google_cr50) = { + .name = "google_cr50", .id = UCLASS_TPM, .of_match = cr50_i2c_ids, .ops = &cr50_i2c_ops,
GPIO_25 is not used on coral, so set it up in deep sleep.
arch/x86/dts/chromebook_coral.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/x86/dts/chromebook_coral.dts b/arch/x86/dts/chromebook_coral.dts index d66e128ae62..580a6e16da1 100644 --- a/arch/x86/dts/chromebook_coral.dts +++ b/arch/x86/dts/chromebook_coral.dts @@ -629,6 +629,7 @@ PAD_CFG0_TX_DISABLE | PAD_CFG0_ROUTE_IOAPIC | PAD_CFG0_TRIG_LEVEL | PAD_CFG0_RX_POL_INVERT) (PAD_CFG1_PULL_NONE | PAD_CFG1_IOSSTATE_TXD_RXE) + PAD_CFG_GPI(GPIO_25, UP_20K, DEEP) /* unused */
/* * WLAN_PE_RST - default to deasserted just in case FSP
Enable this option so that the boot-script substitutions of %U works as expected. With this, it can boot into Chrome OS.
configs/chromebook_coral_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/chromebook_coral_defconfig b/configs/chromebook_coral_defconfig index 05e6ce64932..ab73a0a88ce 100644 --- a/configs/chromebook_coral_defconfig +++ b/configs/chromebook_coral_defconfig @@ -29,6 +29,7 @@ CONFIG_BOOTSTAGE_REPORT=y CONFIG_SPL_BOOTSTAGE_RECORD_COUNT=10 CONFIG_BOOTSTAGE_STASH=y CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS_SUBST=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_LOGF_FUNC=y CONFIG_SPL_LOG=y
