[U-Boot] [PATCH 1/1] Adding Configuration option for TQM5200S Board on Goetting
Signed-off-by: Axel Beierlein beierlein@goetting.de --- Makefile | 7 +++++++ board/tqc/tqm5200/tqm5200.c | 9 ++++++++- include/configs/TQM5200.h | 33 ++++++++++++++++++++++++++------- 3 files changed, 41 insertions(+), 8 deletions(-)
diff --git a/Makefile b/Makefile index 2a06440..7f197dd 100644 --- a/Makefile +++ b/Makefile @@ -764,6 +764,7 @@ Total5200_Rev2_lowboot_config: unconfig } @$(MKCONFIG) -a Total5200 ppc mpc5xxx total5200
+HG43630_config \ cam5200_config \ cam5200_niosflash_config \ fo300_config \ @@ -808,6 +809,12 @@ TQM5200_STK100_config: unconfig @[ -z "$(findstring HIGHBOOT,$@)" ] || \ { echo "TEXT_BASE = 0xFFF00000" >$(obj)board/tqm5200/config.tmp ; \ } + @[ -z "$(findstring HG43630,$@)" ] || \ + { echo "#define CONFIG_HG43630" >>$(obj)include/config.h ; \ + echo "#define CONFIG_TQM5200S" >>$(obj)include/config.h ; \ + echo "#define CONFIG_TQM5200_B" >>$(obj)include/config.h ; \ + $(XECHO) "... TQM5200S on Goetting HG43630 Board" ; \ + } @$(MKCONFIG) -n $@ -a TQM5200 ppc mpc5xxx tqm5200 tqc
uc101_config: unconfig diff --git a/board/tqc/tqm5200/tqm5200.c b/board/tqc/tqm5200/tqm5200.c index faa2e02..0d69e86 100644 --- a/board/tqc/tqm5200/tqm5200.c +++ b/board/tqc/tqm5200/tqm5200.c @@ -255,6 +255,10 @@ int checkboard (void) # error "UNKNOWN" #endif
+#ifdef CONFIG_HG43630 +#define CARRIER_NAME "HG43630" +#endif + puts ( "Board: " MODULE_NAME " (TQ-Components GmbH)\n" " on a " CARRIER_NAME " carrier board\n");
@@ -646,7 +650,7 @@ void video_get_info_str (int line_number, char *info) { if (line_number == 1) { strcpy (info, " Board: TQM5200 (TQ-Components GmbH)"); -#if defined (CONFIG_STK52XX) || defined (CONFIG_TB5200) || defined(CONFIG_FO300) +#if defined (CONFIG_STK52XX) || defined (CONFIG_TB5200) || defined(CONFIG_FO300) || defined(CONFIG_HG43630) } else if (line_number == 2) { #if defined (CONFIG_STK52XX) strcpy (info, " on a STK52xx carrier board"); @@ -657,6 +661,9 @@ void video_get_info_str (int line_number, char *info) #if defined (CONFIG_FO300) strcpy (info, " on a FO300 carrier board"); #endif +#if defined (CONFIG_HG43630) + strcpy (info, " on a HG43630 carrier board"); +#endif #endif } else { diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index a4336a7..0f5ff77 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -71,7 +71,7 @@ /* switch is open */ #endif /* CONFIG_FO300 */
-#ifdef CONFIG_STK52XX +#if defined(CONFIG_STK52XX) && !defined(CONFIG_HG43630) #define CONFIG_PS2KBD /* AT-PS/2 Keyboard */ #define CONFIG_PS2MULT /* .. on PS/2 Multiplexer */ #define CONFIG_PS2SERIAL 6 /* .. on PSC6 */ @@ -85,6 +85,7 @@ * 0x50000000 - 0x50ffffff - PCI IO Space */ #ifdef CONFIG_STK52XX +#ifndef CONFIG_HG43630 #define CONFIG_PCI 1 #define CONFIG_PCI_PNP 1 /* #define CONFIG_PCI_SCAN_SHOW 1 */ @@ -96,7 +97,7 @@ #define CONFIG_PCI_IO_BUS 0x50000000 #define CONFIG_PCI_IO_PHYS CONFIG_PCI_IO_BUS #define CONFIG_PCI_IO_SIZE 0x01000000 - +#endif/* ifndef(CONFIG_HG43630)*/ #define CONFIG_NET_MULTI 1 #define CONFIG_EEPRO100 1 #define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */ @@ -132,7 +133,7 @@ #define CONFIG_ISO_PARTITION
/* USB */ -#if defined(CONFIG_STK52XX) || defined(CONFIG_FO300) +#if defined(CONFIG_STK52XX) || defined(CONFIG_FO300) && !defined(CONFIG_HG43630) #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_OHCI_BE_CONTROLLER #define CONFIG_USB_STORAGE @@ -196,7 +197,7 @@ #define CONFIG_PCIAUTO_SKIP_HOST_BRIDGE 1 #endif
-#if defined(CONFIG_MINIFAP) || defined(CONFIG_STK52XX) || defined(CONFIG_FO300) +#if defined(CONFIG_MINIFAP) || defined(CONFIG_STK52XX) || defined(CONFIG_FO300) #define CONFIG_CMD_IDE #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2 @@ -223,6 +224,11 @@ */ #define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */
+#if defined(CONFIG_HG43630) +#define CONFIG_AUTOBOOT_KEYED +#define CONFIG_AUTOBOOT_STOP_STR "HG" +#endif + #define CONFIG_PREBOOT "echo;" \ "echo Type \"run flash_nfs\" to mount root filesystem over NFS;" \ "echo" @@ -262,6 +268,7 @@ "kernel_addr=FC140000\0" \ "ramdisk_addr=FC600000\0" #else /* !CONFIG_TQM5200_B */ + #define ENV_FLASH_LAYOUT \ "fdt_addr=FC0A0000\0" \ "kernel_addr=FC0C0000\0" \ @@ -415,6 +422,15 @@ #ifdef CONFIG_STK52XX # if defined(CONFIG_TQM5200_B) # if defined(CONFIG_SYS_LOWBOOT) +# if defined(CONFIG_HG43630) +# define MTDPARTS_DEFAULT "mtdparts=TQM5200-0:512k(u-boot)," \ + "512k(env)," \ + "2m(kernel)," \ + "16m(ramfs1)," \ + "5m(ramfs2)," \ + "8m(jffs2)" \ + +# else # define MTDPARTS_DEFAULT "mtdparts=TQM5200-0:1m(firmware)," \ "256k(dtb)," \ "2304k(kernel)," \ @@ -422,6 +438,7 @@ "2m(initrd)," \ "8m(misc)," \ "16m(big-fs)" +# endif /* CONFIG_HG43630 */ # else /* highboot */ # define MTDPARTS_DEFAULT "mtdparts=TQM5200-0:2560k(kernel)," \ "3584k(small-fs)," \ @@ -700,13 +717,16 @@
#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ #undef CONFIG_IDE_LED /* LED for ide not supported */ - #define CONFIG_IDE_RESET /* reset for ide supported */ #define CONFIG_IDE_PREINIT
+#ifndef CONFIG_HG43630 #define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ #define CONFIG_SYS_IDE_MAXDEVICE 2 /* max. 2 drives per IDE bus */ - +#else +#define CONFIG_SYS_IDE_MAXBUS 0 +#define CONFIG_SYS_IDE_MAXDEVICE 0 +#endif /* CONFIG_HG43630 */ #define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000
#define CONFIG_SYS_ATA_BASE_ADDR MPC5XXX_ATA @@ -725,7 +745,6 @@
/* Support ATAPI devices */ #define CONFIG_ATAPI 1 - /*----------------------------------------------------------------------- * Open firmware flat tree support *-----------------------------------------------------------------------
Dear Axel Beierlein,
Please use a lower case board name, and keep list sorted.
- @[ -z "$(findstring HG43630,$@)" ] || \
@$(MKCONFIG) -n $@ -a TQM5200 ppc mpc5xxx tqm5200 tqc}
Please don't add board specific configuration to the top level Makefile; do thi sin your board config file instead.
Please add as "#elif" in the "#if" construct above. And move the block out of checkboard(), please.
Line too long.
It's time to get rid of this "#if" here and use something like
strcpy (info, " on a " CARRIER_NAME " carrier board");
instead, as it has been done in checkboard() long ago.
Is CONFIG_STK52XX really defined for CONFIG_HG43630? where?
- 0x50000000 - 0x50ffffff - PCI IO Space
Add blank line here. But - isn;t it sufficient to only not define CONFIG_PCI, while leaving the rest unchanged?
Are you sure this logic is correct, and necessary?
Please do not add trailing white space.
"512k(env)," \
"2m(kernel)," \
"16m(ramfs1)," \
"5m(ramfs2)," \
"8m(jffs2)" \
This #ifdef block is becoming an unreadable mess. Please split up into separate definitions for each board plus a default config, something like
#define MTDPARTS_DEFAULT ... #define MTDPARTS_HG43630 ... #define MTDPARTS_CAM5200 ... #define MTDPARTS_FO300 ... #define MTDPARTS_STK5200 MTDPARTS_DEFAULT
and then use reference the needed version based on the CARRIER_NAME setting.
Don't delete this blank line.
Is it not sufficient to not enable IDE support?
Hi Wolfgang,
Can you explain what you want to see here? The board is based on a tqm5200 module, so he actually does not want to copy his own config file. Personally I think this solution to be ok, can you explain what you don't like about it?
Cheers Detlev
Dear Detlev Zundel,
Board specific configurations (liek #defining CONFIG_TQM5200S and CONFIG_TQM5200_B when CONFIG_HG43630 is set) should not be done in the Makefile, but in the board config file instead.
Actually I want to get rid of most of such longish scripting in the Makefile, and I started rejecting all patches that add such stuff.
An example how to solve this can be found here: http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/65499
Axel Beierlein
Detlev Zundel
