[U-Boot] [PATCH] tools: mkimage: Fixed build warnings
uninitialized retval variable warning fixed crc32 api moved to crc.h(new) and build warnings fixed
Signed-off-by: Prafulla Wadaskar prafulla@marvell.com --- include/common.h | 4 +--- include/u-boot/crc.h | 33 +++++++++++++++++++++++++++++++++ tools/mkimage.c | 14 +++++++------- 3 files changed, 41 insertions(+), 10 deletions(-) create mode 100644 include/u-boot/crc.h
diff --git a/include/common.h b/include/common.h index a6922fd..c0db3ff 100644 --- a/include/common.h +++ b/include/common.h @@ -622,9 +622,7 @@ int vsprintf(char *buf, const char *fmt, va_list args); char * strmhz(char *buf, long hz);
/* lib_generic/crc32.c */ -uint32_t crc32 (uint32_t, const unsigned char *, uint); -uint32_t crc32_wd (uint32_t, const unsigned char *, uint, uint); -uint32_t crc32_no_comp (uint32_t, const unsigned char *, uint); +#include <u-boot/crc.h>
/* common/console.c */ int console_init_f(void); /* Before relocation; uses the serial stuff */ diff --git a/include/u-boot/crc.h b/include/u-boot/crc.h new file mode 100644 index 0000000..61bce67 --- /dev/null +++ b/include/u-boot/crc.h @@ -0,0 +1,33 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _UBOOT_CRC_H +#define _UBOOT_CRC_H + +/* lib_generic/crc32.c */ +uint32_t crc32 (uint32_t, const unsigned char *, uint); +uint32_t crc32_wd (uint32_t, const unsigned char *, uint, uint); +uint32_t crc32_no_comp (uint32_t, const unsigned char *, uint); + +#endif /* _UBOOT_CRC_H */ diff --git a/tools/mkimage.c b/tools/mkimage.c index dc42924..33709b1 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -24,8 +24,8 @@
#include "mkimage.h" #include <image.h> +#include <u-boot/crc.h>
-extern unsigned long crc32 (unsigned long crc, const char *buf, unsigned int len); static void copy_file (int, const char *, int); static void usage (void); static int image_verify_header (char *, int); @@ -60,7 +60,7 @@ main (int argc, char **argv) struct stat sbuf; unsigned char *ptr; char *name = ""; - int retval; + int retval = 0;
cmdname = *argv;
@@ -334,7 +334,7 @@ NXTARG: ; hdr = (image_header_t *)ptr;
checksum = crc32 (0, - (const char *)(ptr + image_get_header_size ()), + (const uint8_t *)(ptr + image_get_header_size ()), sbuf.st_size - image_get_header_size () );
@@ -352,7 +352,7 @@ NXTARG: ;
image_set_name (hdr, name);
- checksum = crc32 (0, (const char *)hdr, image_get_header_size ()); + checksum = crc32 (0, (const uint8_t *)hdr, image_get_header_size ());
image_set_hcrc (hdr, checksum);
@@ -485,7 +485,7 @@ static int image_verify_header (char *ptr, int image_size) { int len; - char *data; + uint8_t *data; uint32_t checksum; image_header_t header; image_header_t *hdr = &header; @@ -504,7 +504,7 @@ image_verify_header (char *ptr, int image_size) return -FDT_ERR_BADMAGIC; }
- data = (char *)hdr; + data = (uint8_t *)hdr; len = sizeof(image_header_t);
checksum = be32_to_cpu(hdr->ih_hcrc); @@ -517,7 +517,7 @@ image_verify_header (char *ptr, int image_size) return -FDT_ERR_BADSTATE; }
- data = ptr + sizeof(image_header_t); + data = (uint8_t *)ptr + sizeof(image_header_t); len = image_size - sizeof(image_header_t) ;
if (crc32 (0, data, len) != be32_to_cpu(hdr->ih_dcrc)) {
Dear Prafulla Wadaskar,
Hm... why are you changing the casts to new variable types?
So the prototypes (and the implementation) use "const unsigned char *" for the second argument.
Why are you changing the type here to "uint8_t"? I would expect to see "unsigned char".
- checksum = crc32 (0, (const uint8_t *)hdr, image_get_header_size ());
Ditto.
- char *data;
- uint8_t *data;
Ditto.
- data = (uint8_t *)ptr + sizeof(image_header_t);
And again and again.
This does not look consistent to me.
Prafulla Wadaskar
