[U-Boot] [PATCH] ppc4xx: Add command 440epx_r
Adds a command 440epx_r to dump over 140 internal register which define the HW configuration. Command name shortened from 440epx_regdump to 440epx_r to align nicely with the help command.
Handy for documentation and verifying changes.
Signed-off-by: Niklaus Giger niklaus.giger@netstal.com --- cpu/ppc4xx/440epx_regdump.c | 282 +++++++++++++++++++++++++++++++++++++++++++ cpu/ppc4xx/Makefile | 4 + 2 files changed, 286 insertions(+), 0 deletions(-) create mode 100644 cpu/ppc4xx/440epx_regdump.c
diff --git a/cpu/ppc4xx/440epx_regdump.c b/cpu/ppc4xx/440epx_regdump.c new file mode 100644 index 0000000..0e0478d --- /dev/null +++ b/cpu/ppc4xx/440epx_regdump.c @@ -0,0 +1,282 @@ +/* + *(C) Copyright 2005-2009 Netstal Maschinen AG + * Bruno Hars (Bruno.Hars@netstal.com) + * + * This source code is free software; you can redistribute it + * and/or modify it in source code form under the terms of the GNU + * General Public License as published by the Free Software + * Foundation; either version 2 of the License, or (at your option) + * any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA + */ + +/* + * cmd_440epx_regdump.c - CPU Register Dump for HCU5 board with PPC440EPx + */ + +#include <common.h> +#include <command.h> +#include <asm/processor.h> + +enum REGISTER_TYPE { + DCR, /* Directly Accessed DCR's */ + IDCR1, /* Indirectly Accessed DCR via SDRAM0_CFGADDR/SDRAM0_CFGDATA */ + IDCR2, /* Indirectly Accessed DCR via EBC0_CFGADDR/EBC0_CFGDATA */ + IDCR3, /* Indirectly Accessed DCR via EBM0_CFGADDR/EBM0_CFGDATA */ + IDCR4, /* Indirectly Accessed DCR via PPM0_CFGADDR/PPM0_CFGDATA */ + IDCR5, /* Indirectly Accessed DCR via CPR0_CFGADDR/CPR0_CFGDATA */ + IDCR6, /* Indirectly Accessed DCR via SDR0_CFGADDR/SDR0_CFGDATA */ + MM /* Directly Accessed MMIO Register */ +}; + +struct cpu_register { + char *name; + enum REGISTER_TYPE type; + u32 address; +}; + +/* + * PPC440EPx registers ordered for output + * name type addr size + * ------------------------------------------- + */ +const struct cpu_register ppc440epx_reg[] = { + {"EBC0_B0CR", IDCR2, PB0CR}, + {"EBC0_B1CR", IDCR2, PB1CR}, + {"EBC0_B2CR", IDCR2, PB2CR}, + {"EBC0_B3CR", IDCR2, PB3CR}, + {"EBC0_B4CR", IDCR2, PB4CR}, + {"EBC0_B5CR", IDCR2, PB5CR}, + {"EBC0_B0AP", IDCR2, PB0AP}, + {"EBC0_B1AP", IDCR2, PB1AP}, + {"EBC0_B2AP", IDCR2, PB2AP}, + {"EBC0_B3AP", IDCR2, PB3AP}, + {"EBC0_B4AP", IDCR2, PB4AP}, + {"EBC0_B5AP", IDCR2, PB5AP}, + {"EBC0_CFG", IDCR2, 0x23}, + {"SDR0_SDSTP0", IDCR6, SDR0_SDSTP0}, + {"SDR0_SDSTP1", IDCR6, SDR0_SDSTP1}, + {"SDR0_SDSTP2", IDCR6, 0x4001}, + {"SDR0_SDSTP3", IDCR6, 0x4003}, + {"SDR0_CUST0", IDCR6, SDR0_CUST0}, + {"SDR0_CUST1", IDCR6, SDR0_CUST1}, + {"SDR0_EBC0", IDCR6, 0x0100}, + {"SDR0_AMP0", IDCR6, 0x0240}, + {"SDR0_AMP1", IDCR6, 0x0241}, + {"SDR0_CP440", IDCR6, SDR0_CP440}, + {"SDR0_CRYP0", IDCR6, 0x4500}, + {"SDR0_DDRCFG", IDCR6, 0x00E0}, + {"SDR0_EMAC0RXST", IDCR6, 0x4301}, + {"SDR0_EMAC0TXST", IDCR6, 0x4302}, + {"SDR0_MFR", IDCR6, SDR0_MFR}, + {"SDR0_PCI0", IDCR6, SDR0_PCI0}, + {"SDR0_PFC0", IDCR6, SDR0_PFC0}, + {"SDR0_PFC1", IDCR6, SDR0_PFC1}, + {"SDR0_PFC2", IDCR6, SDR0_PFC2}, + {"SDR0_PFC4", IDCR6, SDR0_PFC4}, + {"SDR0_UART0", IDCR6, SDR0_UART0}, + {"SDR0_UART1", IDCR6, SDR0_UART1}, + {"SDR0_UART2", IDCR6, SDR0_UART2}, + {"SDR0_UART3", IDCR6, SDR0_UART3}, + {"DDR0_02", IDCR1, 2}, + {"DDR0_00", IDCR1, 0}, + {"DDR0_01", IDCR1, 1}, + {"DDR0_03", IDCR1, 3}, + {"DDR0_04", IDCR1, 4}, + {"DDR0_05", IDCR1, 5}, + {"DDR0_06", IDCR1, 6}, + {"DDR0_07", IDCR1, 7}, + {"DDR0_08", IDCR1, 8}, + {"DDR0_09", IDCR1, 9}, + {"DDR0_10", IDCR1, 10}, + {"DDR0_11", IDCR1, 11}, + {"DDR0_12", IDCR1, 12}, + {"DDR0_14", IDCR1, 14}, + {"DDR0_17", IDCR1, 17}, + {"DDR0_18", IDCR1, 18}, + {"DDR0_19", IDCR1, 19}, + {"DDR0_20", IDCR1, 20}, + {"DDR0_21", IDCR1, 21}, + {"DDR0_22", IDCR1, 22}, + {"DDR0_23", IDCR1, 23}, + {"DDR0_24", IDCR1, 24}, + {"DDR0_25", IDCR1, 25}, + {"DDR0_26", IDCR1, 26}, + {"DDR0_27", IDCR1, 27}, + {"DDR0_28", IDCR1, 28}, + {"DDR0_31", IDCR1, 31}, + {"DDR0_32", IDCR1, 32}, + {"DDR0_33", IDCR1, 33}, + {"DDR0_34", IDCR1, 34}, + {"DDR0_35", IDCR1, 35}, + {"DDR0_36", IDCR1, 36}, + {"DDR0_37", IDCR1, 37}, + {"DDR0_38", IDCR1, 38}, + {"DDR0_39", IDCR1, 39}, + {"DDR0_40", IDCR1, 40}, + {"DDR0_41", IDCR1, 41}, + {"DDR0_42", IDCR1, 42}, + {"DDR0_43", IDCR1, 43}, + {"DDR0_44", IDCR1, 44}, + {"CPM0_ER", DCR, 0x0B0}, + {"CPM1_ER", DCR, 0x0F0}, + {"CPR0_ICFG", IDCR5, CPR0_ICFG}, + {"CPR0_MALD", IDCR5, CPR0_MALD}, + {"CPR0_OPBD0", IDCR5, 0x00C0}, + {"CPR0_PERD0", IDCR5, 0x00E0}, + {"CPR0_PLLC0", IDCR5, 0x0040}, + {"CPR0_PLLD0", IDCR5, 0x0060}, + {"CPR0_PRIMAD0", IDCR5, 0x0080}, + {"CPR0_PRIMBD0", IDCR5, 0x00A0}, + {"CPR0_SPCID", IDCR5, 0x0120}, + {"SPI0_MODE", MM, 0xEF600900}, + {"IIC0_CLKDIV", MM, 0xEF60070C}, + {"PCIL0_PMM0MA", MM, 0xEF400004}, + {"PCIL0_PMM1MA", MM, 0xEF400014}, + {"PCIL0_PTM1LA", MM, 0xEF400034}, + {"PCIL0_PTM1MS", MM, 0xEF400030}, + {"PCIL0_PTM2LA", MM, 0xEF40003C}, + {"PCIL0_PTM2MS", MM, 0xEF400038}, + {"MAL0_CFG", DCR, MAL0_CFG}, + {"ZMII0_FER", MM, 0xEF600D00}, + {"ZMII0_SSR", MM, 0xEF600D04}, + {"EMAC0_IPGVR", MM, 0xEF600E58}, + {"EMAC0_MR1", MM, 0xEF600E04}, + {"EMAC0_PTR", MM, 0xEF600E2C}, + {"EMAC0_RWMR", MM, 0xEF600E64}, + {"EMAC0_STACR", MM, 0xEF600E5C}, + {"EMAC0_TMR0", MM, 0xEF600E08}, + {"EMAC0_TMR1", MM, 0xEF600E0C}, + {"EMAC0_TRTR", MM, 0xEF600E60}, + {"EMAC1_MR1", MM, 0xEF600F04}, + {"GPIO0_OR", MM, GPIO0_OR}, + {"GPIO1_OR", MM, GPIO1_OR}, + {"GPIO0_TCR", MM, GPIO0_TCR}, + {"GPIO1_TCR", MM, GPIO1_TCR}, + {"GPIO0_ODR", MM, GPIO0_ODR}, + {"GPIO1_ODR", MM, GPIO1_ODR}, + {"GPIO0_OSRL", MM, GPIO0_OSRL}, + {"GPIO0_OSRH", MM, GPIO0_OSRH}, + {"GPIO1_OSRL", MM, GPIO1_OSRL}, + {"GPIO1_OSRH", MM, GPIO1_OSRH}, + {"GPIO0_TSRL", MM, GPIO0_TSRL}, + {"GPIO0_TSRH", MM, GPIO0_TSRH}, + {"GPIO1_TSRL", MM, GPIO1_TSRL}, + {"GPIO1_TSRH", MM, GPIO1_TSRH}, + {"GPIO0_IR", MM, GPIO0_IR}, + {"GPIO1_IR", MM, GPIO1_IR}, + {"GPIO0_ISR1L", MM, GPIO0_ISR1L}, + {"GPIO0_ISR1H", MM, GPIO0_ISR1H}, + {"GPIO1_ISR1L", MM, GPIO1_ISR1L}, + {"GPIO1_ISR1H", MM, GPIO1_ISR1H}, + {"GPIO0_ISR2L", MM, GPIO0_ISR2L}, + {"GPIO0_ISR2H", MM, GPIO0_ISR2H}, + {"GPIO1_ISR2L", MM, GPIO1_ISR2L}, + {"GPIO1_ISR2H", MM, GPIO1_ISR2H}, + {"GPIO0_ISR3L", MM, GPIO0_ISR3L}, + {"GPIO0_ISR3H", MM, GPIO0_ISR3H}, + {"GPIO1_ISR3L", MM, GPIO1_ISR3L}, + {"GPIO1_ISR3H", MM, GPIO1_ISR3H}, + {"SDR0_USB2PHY0CR", IDCR6, SDR0_USB2PHY0CR}, + {"SDR0_USB2H0CR", IDCR6, SDR0_USB2H0CR}, + {"SDR0_USB2D0CR", IDCR6, SDR0_USB2D0CR}, + {"PLB4A0_ACR", DCR, 0x081}, + {"PLB4A1_ACR", DCR, 0x089}, + {"PLB3A0_ACR", DCR, 0x077}, + {"OPB2PLB40_BCTRL", DCR, 0x350}, + {"P4P3BO0_CFG", DCR, 0x026} +}; + +/* + * CPU Register dump of PPC440EPx + * Output in order of struct ppc440epx_reg + */ +int do_440epx_regdump (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) +{ + unsigned int i; + unsigned int n; + u32 value; + enum REGISTER_TYPE type; + + printf + ("\nDump PPC440EPx HW configuration registers\n\n"); + n = sizeof (ppc440epx_reg) / sizeof (ppc440epx_reg[0]); + for (i = 0; i < n; i++) { + value = 0; + type = ppc440epx_reg[i].type; + switch (type) { + case DCR: /* Directly Accessed DCR's */ + switch (ppc440epx_reg[i].address) { + case 0x00b0: + value = mfdcr ( 0x00b0 ); + break; + case 0x00f0: + value = mfdcr ( 0x00f0 ); + break; + case 0x0180: + value = mfdcr ( 0x0180 ); + break; + case 0x0081: + value = mfdcr ( 0x0081 ); + break; + case 0x0089: + value = mfdcr ( 0x0089 ); + break; + case 0x0077: + value = mfdcr ( 0x0077 ); + break; + case 0x0350: + value = mfdcr ( 0x0350 ); + break; + case 0x0026: + value = mfdcr ( 0x0026 ); + break; + default: + printf ("\nERROR: unknown DCR address: 0x%x\n", + ppc440epx_reg[i].address); + break; + } + break; + case IDCR1: /* Indirect via SDRAM0_CFGADDR/DDR0_CFGDATA */ + mtdcr (SDRAM0_CFGADDR, ppc440epx_reg[i].address); + value = mfdcr (SDRAM0_CFGDATA); + break; + case IDCR2: /* Indirect via EBC0_CFGADDR/EBC0_CFGDATA */ + mtdcr (EBC0_CFGADDR, ppc440epx_reg[i].address); + value = mfdcr (EBC0_CFGDATA); + break; + case IDCR5: /* Indirect via CPR0_CFGADDR/CPR0_CFGDATA */ + mtdcr (CPR0_CFGADDR, ppc440epx_reg[i].address); + value = mfdcr (CPR0_CFGDATA); + break; + case IDCR6: /* Indirect via SDR0_CFGADDR/SDR0_CFGDATA */ + mtdcr (SDR0_CFGADDR, ppc440epx_reg[i].address); + value = mfdcr (SDR0_CFGDATA); + break; + case MM: /* Directly Accessed MMIO Register */ + value = *(volatile unsigned long*) ppc440epx_reg[i].address; + break; + default: + printf + ("\nERROR: struct entry %d: unknown register type\n", + i); + break; + } + printf ("0x%08x %-16s: 0x%08x\n", ppc440epx_reg[i].address, + ppc440epx_reg[i].name, value); + } + return 0; +} + +/* define do_440epx_regdump as u-boot command */ +U_BOOT_CMD (440epx_r, 2, 1, do_440epx_regdump, + "print register information for PPC440EPX processor", + ""); diff --git a/cpu/ppc4xx/Makefile b/cpu/ppc4xx/Makefile index 2050b17..2d623a9 100644 --- a/cpu/ppc4xx/Makefile +++ b/cpu/ppc4xx/Makefile @@ -33,6 +33,10 @@ SOBJS += dcr.o SOBJS += kgdb.o
COBJS := 40x_spd_sdram.o +ifdef CONFIG_440EPX +COBJS += 440epx_regdump.o +endif + COBJS += 44x_spd_ddr.o COBJS += 44x_spd_ddr2.o ifdef CONFIG_PPC4xx_DDR_AUTOCALIBRATION
Did you see my last mail about the naming of the command (and its files)? I really thing it makes sense to change this into a more generic name, so that other 4xx variants may use it as well.
More comments below.
- *(C) Copyright 2005-2009 Netstal Maschinen AG
- Bruno Hars (Bruno.Hars@netstal.com)
- This source code is free software; you can redistribute it
- and/or modify it in source code form under the terms of the GNU
- General Public License as published by the Free Software
- Foundation; either version 2 of the License, or (at your option)
- any later version.
- Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
- cmd_440epx_regdump.c - CPU Register Dump for HCU5 board with PPC440EPx
This comment does not fit any more.
- DCR, /* Directly Accessed DCR's */
- IDCR1, /* Indirectly Accessed DCR via SDRAM0_CFGADDR/SDRAM0_CFGDATA */
- IDCR2, /* Indirectly Accessed DCR via EBC0_CFGADDR/EBC0_CFGDATA */
- IDCR3, /* Indirectly Accessed DCR via EBM0_CFGADDR/EBM0_CFGDATA */
- IDCR4, /* Indirectly Accessed DCR via PPM0_CFGADDR/PPM0_CFGDATA */
- IDCR5, /* Indirectly Accessed DCR via CPR0_CFGADDR/CPR0_CFGDATA */
- IDCR6, /* Indirectly Accessed DCR via SDR0_CFGADDR/SDR0_CFGDATA */
- MM /* Directly Accessed MMIO Register */
- char *name;
- enum REGISTER_TYPE type;
- u32 address;
- PPC440EPx registers ordered for output
- name type addr size
- {"EBC0_B0CR", IDCR2, PB0CR},
- {"EBC0_B1CR", IDCR2, PB1CR},
- {"EBC0_B2CR", IDCR2, PB2CR},
- {"EBC0_B3CR", IDCR2, PB3CR},
- {"EBC0_B4CR", IDCR2, PB4CR},
- {"EBC0_B5CR", IDCR2, PB5CR},
- {"EBC0_B0AP", IDCR2, PB0AP},
- {"EBC0_B1AP", IDCR2, PB1AP},
- {"EBC0_B2AP", IDCR2, PB2AP},
- {"EBC0_B3AP", IDCR2, PB3AP},
- {"EBC0_B4AP", IDCR2, PB4AP},
- {"EBC0_B5AP", IDCR2, PB5AP},
- {"EBC0_CFG", IDCR2, 0x23},
EBC0_CFG is defined. Please use it instead of 0x23.
- {"SDR0_SDSTP0", IDCR6, SDR0_SDSTP0},
- {"SDR0_SDSTP1", IDCR6, SDR0_SDSTP1},
- {"SDR0_SDSTP2", IDCR6, 0x4001},
- {"SDR0_SDSTP3", IDCR6, 0x4003},
Those regs should be defines as well. If not please add them to the headers instead.
- {"SDR0_CUST0", IDCR6, SDR0_CUST0},
- {"SDR0_CUST1", IDCR6, SDR0_CUST1},
- {"SDR0_EBC0", IDCR6, 0x0100},
- {"SDR0_AMP0", IDCR6, 0x0240},
- {"SDR0_AMP1", IDCR6, 0x0241},
Again. Please do this for all regs used in this array. Thanks.
<snip>
- CPU Register dump of PPC440EPx
- Output in order of struct ppc440epx_reg
Name change?
- unsigned int i;
- unsigned int n;
- u32 value;
- printf
Is this line split really necessary? Doesn't look too long for me.
- n = sizeof (ppc440epx_reg) / sizeof (ppc440epx_reg[0]);
- for (i = 0; i < n; i++) {
value = 0;
switch (type) {
case 0x00b0:
Please drop the spaces around the braces:
value = mfdcr(0x00b0);
Also in the other cases below.
break;
case 0x00f0:
break;
case 0x0180:
break;
case 0x0081:
break;
case 0x0089:
break;
case 0x0077:
break;
case 0x0350:
break;
case 0x0026:
break;
default:
I would prefer the style func(), without a space before the "(". Most of the code uses this code, so its more consistent.
break;
break;
break;
break;
break;
break;
Please use io accessor function here: in_be32()
break;
default:
printf
i);
I don't like this linesplit. Most likely introduced by lindent. Please use something like:
printf("\nERROR: struct entry %d: unknown " "register type\n", i);
break;
Please don't add this commend unconditionally. We need a config option/switch for this. How about CONFIG_CMD_REGDUMP?
And btw, please keep me always on Cc on ppc4xx related patches.
Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
<snip>
case 0x00b0:
<snip>
case 0x0026:
break;
default:
I have the same preferences, as do most people I would guess. I mentioned this preference to someone else who submitted a patch in the past and they promptly pointed me to http://www.denx.de/wiki/U-Boot/CodingStyle
Anyone care if I change the part about ""Lindent -pcs" (adding spaces before parameters to function calls) is actually used." And adding a reference to Linux's checkpatch.pl script would be nice too.
Best, Peter
Niklaus Giger
Peter Tyser
Stefan Roese
