[U-Boot] [PATCH v3 00/10] splash screen on the stm32f769 disco board
Version 1: - Initial commit.
Version 2: - swap patches to avoid compilation issue. - remove panel timings from device tree.
Version 3: - Share same include file mipi_display.h with kernel linux. - Rework ltdc driver with last comments of Anatolij Gustshin. - Check ordering (file dw_mipi_dsi.c). - Rename mipi_display.c to mipi_dsi.c.
This serie contains all patchsets needed for displaying a splash screen on the stm32f769 disco board. A new config has been created configs/stm32f769-disco_defconfig. This is necessary due to the difference of panels between stm32f769-disco & stm32f746-disco boards.
Yannick Fertré (10): video: stm32: stm32_ltdc: add bridge to display controller include: Add new DCS commands in the enum list video: add support of MIPI DSI interface video: add MIPI DSI host controller bridge video: add support of STM32 MIPI DSI controller driver video: add support of panel OTM8009A video: add support of panel RM68200 arm: dts: stm32: add dsi for STM32F746 arm: dts: stm32: add display for STM32F769 disco board board: Add STM32F769 SoC, discovery board support
arch/arm/dts/stm32f746.dtsi | 12 + arch/arm/dts/stm32f769-disco.dts | 41 ++ configs/stm32f769-disco_defconfig | 67 +++ drivers/video/Kconfig | 33 ++ drivers/video/Makefile | 4 + drivers/video/dw_mipi_dsi.c | 827 ++++++++++++++++++++++++++++++++++++ drivers/video/mipi_dsi.c | 828 +++++++++++++++++++++++++++++++++++++ drivers/video/orisetech_otm8009a.c | 367 ++++++++++++++++ drivers/video/raydium-rm68200.c | 339 +++++++++++++++ drivers/video/stm32/Kconfig | 10 + drivers/video/stm32/Makefile | 1 + drivers/video/stm32/stm32_dsi.c | 428 +++++++++++++++++++ drivers/video/stm32/stm32_ltdc.c | 143 ++++--- include/dw_mipi_dsi.h | 33 ++ include/mipi_display.h | 8 + include/mipi_dsi.h | 451 ++++++++++++++++++++ 16 files changed, 3531 insertions(+), 61 deletions(-) create mode 100644 configs/stm32f769-disco_defconfig create mode 100644 drivers/video/dw_mipi_dsi.c create mode 100644 drivers/video/mipi_dsi.c create mode 100644 drivers/video/orisetech_otm8009a.c create mode 100644 drivers/video/raydium-rm68200.c create mode 100644 drivers/video/stm32/stm32_dsi.c create mode 100644 include/dw_mipi_dsi.h create mode 100644 include/mipi_dsi.h
-- 2.7.4
Manage a bridge insert between the display controller & a panel.
Signed-off-by: Yannick Fertré yannick.fertre@st.com --- drivers/video/stm32/stm32_ltdc.c | 143 ++++++++++++++++++++++----------------- 1 file changed, 82 insertions(+), 61 deletions(-)
diff --git a/drivers/video/stm32/stm32_ltdc.c b/drivers/video/stm32/stm32_ltdc.c index dc6c889..6d075e3 100644 --- a/drivers/video/stm32/stm32_ltdc.c +++ b/drivers/video/stm32/stm32_ltdc.c @@ -4,22 +4,20 @@ * Author(s): Philippe Cornu philippe.cornu@st.com for STMicroelectronics. * Yannick Fertre yannick.fertre@st.com for STMicroelectronics. */ - #include <common.h> #include <clk.h> +#include <display.h> #include <dm.h> #include <panel.h> #include <reset.h> #include <video.h> +#include <video_bridge.h> #include <asm/io.h> #include <asm/arch/gpio.h> #include <dm/device-internal.h>
-DECLARE_GLOBAL_DATA_PTR; - struct stm32_ltdc_priv { void __iomem *regs; - struct display_timing timing; enum video_log2_bpp l2bpp; u32 bg_col_argb; u32 crop_x, crop_y, crop_w, crop_h; @@ -174,8 +172,8 @@ static u32 stm32_ltdc_get_pixel_format(enum video_log2_bpp l2bpp) case VIDEO_BPP2: case VIDEO_BPP4: default: - debug("%s: warning %dbpp not supported yet, %dbpp instead\n", - __func__, VNBITS(l2bpp), VNBITS(VIDEO_BPP16)); + pr_warn("%s: warning %dbpp not supported yet, %dbpp instead\n", + __func__, VNBITS(l2bpp), VNBITS(VIDEO_BPP16)); pf = PF_RGB565; break; } @@ -209,23 +207,23 @@ static void stm32_ltdc_enable(struct stm32_ltdc_priv *priv) setbits_le32(priv->regs + LTDC_GCR, GCR_LTDCEN); }
-static void stm32_ltdc_set_mode(struct stm32_ltdc_priv *priv) +static void stm32_ltdc_set_mode(struct stm32_ltdc_priv *priv, + struct display_timing *timings) { void __iomem *regs = priv->regs; - struct display_timing *timing = &priv->timing; u32 hsync, vsync, acc_hbp, acc_vbp, acc_act_w, acc_act_h; u32 total_w, total_h; u32 val;
/* Convert video timings to ltdc timings */ - hsync = timing->hsync_len.typ - 1; - vsync = timing->vsync_len.typ - 1; - acc_hbp = hsync + timing->hback_porch.typ; - acc_vbp = vsync + timing->vback_porch.typ; - acc_act_w = acc_hbp + timing->hactive.typ; - acc_act_h = acc_vbp + timing->vactive.typ; - total_w = acc_act_w + timing->hfront_porch.typ; - total_h = acc_act_h + timing->vfront_porch.typ; + hsync = timings->hsync_len.typ - 1; + vsync = timings->vsync_len.typ - 1; + acc_hbp = hsync + timings->hback_porch.typ; + acc_vbp = vsync + timings->vback_porch.typ; + acc_act_w = acc_hbp + timings->hactive.typ; + acc_act_h = acc_vbp + timings->vactive.typ; + total_w = acc_act_w + timings->hfront_porch.typ; + total_h = acc_act_h + timings->vfront_porch.typ;
/* Synchronization sizes */ val = (hsync << 16) | vsync; @@ -247,14 +245,14 @@ static void stm32_ltdc_set_mode(struct stm32_ltdc_priv *priv)
/* Signal polarities */ val = 0; - debug("%s: timing->flags 0x%08x\n", __func__, timing->flags); - if (timing->flags & DISPLAY_FLAGS_HSYNC_HIGH) + debug("%s: timing->flags 0x%08x\n", __func__, timings->flags); + if (timings->flags & DISPLAY_FLAGS_HSYNC_HIGH) val |= GCR_HSPOL; - if (timing->flags & DISPLAY_FLAGS_VSYNC_HIGH) + if (timings->flags & DISPLAY_FLAGS_VSYNC_HIGH) val |= GCR_VSPOL; - if (timing->flags & DISPLAY_FLAGS_DE_HIGH) + if (timings->flags & DISPLAY_FLAGS_DE_HIGH) val |= GCR_DEPOL; - if (timing->flags & DISPLAY_FLAGS_PIXDATA_NEGEDGE) + if (timings->flags & DISPLAY_FLAGS_PIXDATA_NEGEDGE) val |= GCR_PCPOL; clrsetbits_le32(regs + LTDC_GCR, GCR_HSPOL | GCR_VSPOL | GCR_DEPOL | GCR_PCPOL, val); @@ -330,96 +328,119 @@ static int stm32_ltdc_probe(struct udevice *dev) struct video_uc_platdata *uc_plat = dev_get_uclass_platdata(dev); struct video_priv *uc_priv = dev_get_uclass_priv(dev); struct stm32_ltdc_priv *priv = dev_get_priv(dev); - struct udevice *panel; + struct udevice *bridge = NULL; + struct udevice *panel = NULL; + struct display_timing timings; struct clk pclk; struct reset_ctl rst; - int rate, ret; + int ret;
priv->regs = (void *)dev_read_addr(dev); if ((fdt_addr_t)priv->regs == FDT_ADDR_T_NONE) { - debug("%s: ltdc dt register address error\n", __func__); + dev_err(dev, "ltdc dt register address error\n"); return -EINVAL; }
ret = clk_get_by_index(dev, 0, &pclk); if (ret) { - debug("%s: peripheral clock get error %d\n", __func__, ret); + dev_err(dev, "peripheral clock get error %d\n", ret); return ret; }
ret = clk_enable(&pclk); if (ret) { - debug("%s: peripheral clock enable error %d\n", - __func__, ret); + dev_err(dev, "peripheral clock enable error %d\n", ret); return ret; }
- ret = reset_get_by_index(dev, 0, &rst); + ret = uclass_first_device_err(UCLASS_PANEL, &panel); if (ret) { - debug("%s: missing ltdc hardware reset\n", __func__); - return -ENODEV; + dev_err(dev, "panel device error %d\n", ret); + return ret; }
- /* Reset */ - reset_deassert(&rst); - - ret = uclass_first_device(UCLASS_PANEL, &panel); + ret = panel_get_display_timing(panel, &timings); if (ret) { - debug("%s: panel device error %d\n", __func__, ret); - return ret; + ret = fdtdec_decode_display_timing(gd->fdt_blob, + dev_of_offset(panel), + 0, &timings); + if (ret) { + dev_err(dev, "decode display timing error %d\n", ret); + return ret; + } }
- ret = panel_enable_backlight(panel); + ret = clk_set_rate(&pclk, timings.pixelclock.typ); + if (ret) + dev_warn(dev, "fail to set pixel clock %d hz\n", + timings.pixelclock.typ); + + debug("%s: Set pixel clock req %d hz get %ld hz\n", __func__, + timings.pixelclock.typ, clk_get_rate(&pclk)); + + ret = reset_get_by_index(dev, 0, &rst); if (ret) { - debug("%s: panel %s enable backlight error %d\n", - __func__, panel->name, ret); + dev_err(dev, "missing ltdc hardware reset\n"); return ret; }
- ret = fdtdec_decode_display_timing(gd->fdt_blob, - dev_of_offset(dev), 0, - &priv->timing); - if (ret) { - debug("%s: decode display timing error %d\n", - __func__, ret); - return -EINVAL; - } + /* Reset */ + reset_deassert(&rst);
- rate = clk_set_rate(&pclk, priv->timing.pixelclock.typ); - if (rate < 0) { - debug("%s: fail to set pixel clock %d hz %d hz\n", - __func__, priv->timing.pixelclock.typ, rate); - return rate; + if (IS_ENABLED(CONFIG_VIDEO_BRIDGE)) { + ret = uclass_get_device(UCLASS_VIDEO_BRIDGE, 0, &bridge); + if (ret) + debug("No video bridge, or no backlight on bridge\n"); + + if (bridge) { + ret = video_bridge_attach(bridge); + if (ret) { + dev_err(dev, "fail to attach bridge\n"); + return ret; + } + } }
- debug("%s: Set pixel clock req %d hz get %d hz\n", __func__, - priv->timing.pixelclock.typ, rate); - /* TODO Below parameters are hard-coded for the moment... */ priv->l2bpp = VIDEO_BPP16; priv->bg_col_argb = 0xFFFFFFFF; /* white no transparency */ priv->crop_x = 0; priv->crop_y = 0; - priv->crop_w = priv->timing.hactive.typ; - priv->crop_h = priv->timing.vactive.typ; + priv->crop_w = timings.hactive.typ; + priv->crop_h = timings.vactive.typ; priv->alpha = 0xFF;
debug("%s: %dx%d %dbpp frame buffer at 0x%lx\n", __func__, - priv->timing.hactive.typ, priv->timing.vactive.typ, + timings.hactive.typ, timings.vactive.typ, VNBITS(priv->l2bpp), uc_plat->base); debug("%s: crop %d,%d %dx%d bg 0x%08x alpha %d\n", __func__, priv->crop_x, priv->crop_y, priv->crop_w, priv->crop_h, priv->bg_col_argb, priv->alpha);
/* Configure & start LTDC */ - stm32_ltdc_set_mode(priv); + stm32_ltdc_set_mode(priv, &timings); stm32_ltdc_set_layer1(priv, uc_plat->base); stm32_ltdc_enable(priv);
- uc_priv->xsize = priv->timing.hactive.typ; - uc_priv->ysize = priv->timing.vactive.typ; + uc_priv->xsize = timings.hactive.typ; + uc_priv->ysize = timings.vactive.typ; uc_priv->bpix = priv->l2bpp;
+ if (!bridge) { + ret = panel_enable_backlight(panel); + if (ret) { + dev_err(dev, "panel %s enable backlight error %d\n", + panel->name, ret); + return ret; + } + } else if (IS_ENABLED(CONFIG_VIDEO_BRIDGE)) { + ret = video_bridge_set_backlight(bridge, 80); + if (ret) { + dev_err(dev, "fail to set backlight\n"); + return ret; + } + } + video_set_flush_dcache(dev, true);
Adding new DCS commands which are specified in the DCS 1.3 spec related to CABC.
Signed-off-by: Yannick Fertré yannick.fertre@st.com --- include/mipi_display.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/mipi_display.h b/include/mipi_display.h index ddcc8ca..19aa65a 100644 --- a/include/mipi_display.h +++ b/include/mipi_display.h @@ -115,6 +115,14 @@ enum { MIPI_DCS_READ_MEMORY_CONTINUE = 0x3E, MIPI_DCS_SET_TEAR_SCANLINE = 0x44, MIPI_DCS_GET_SCANLINE = 0x45, + MIPI_DCS_SET_DISPLAY_BRIGHTNESS = 0x51, /* MIPI DCS 1.3 */ + MIPI_DCS_GET_DISPLAY_BRIGHTNESS = 0x52, /* MIPI DCS 1.3 */ + MIPI_DCS_WRITE_CONTROL_DISPLAY = 0x53, /* MIPI DCS 1.3 */ + MIPI_DCS_GET_CONTROL_DISPLAY = 0x54, /* MIPI DCS 1.3 */ + MIPI_DCS_WRITE_POWER_SAVE = 0x55, /* MIPI DCS 1.3 */ + MIPI_DCS_GET_POWER_SAVE = 0x56, /* MIPI DCS 1.3 */ + MIPI_DCS_SET_CABC_MIN_BRIGHTNESS = 0x5E, /* MIPI DCS 1.3 */ + MIPI_DCS_GET_CABC_MIN_BRIGHTNESS = 0x5F, /* MIPI DCS 1.3 */ MIPI_DCS_READ_DDB_START = 0xA1, MIPI_DCS_READ_DDB_CONTINUE = 0xA8, };
Mipi_display.c contains a set of dsi helpers. This file is a copy of file drm_mipi_dsi.c (linux kernel).
Signed-off-by: Yannick Fertré yannick.fertre@st.com --- drivers/video/Kconfig | 8 + drivers/video/Makefile | 1 + drivers/video/mipi_dsi.c | 828 +++++++++++++++++++++++++++++++++++++++++++++++ include/mipi_dsi.h | 451 ++++++++++++++++++++++++++ 4 files changed, 1288 insertions(+) create mode 100644 drivers/video/mipi_dsi.c create mode 100644 include/mipi_dsi.h
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index ecb57d8..6048291 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -73,6 +73,14 @@ config VIDEO_ANSI Enable ANSI escape sequence decoding for a more fully functional console.
+config VIDEO_MIPI_DSI + bool "Support MIPI DSI interface" + depends on DM_VIDEO + help + Support MIPI DSI interface for driving a MIPI compatible device. + The MIPI Display Serial Interface (MIPI DSI) defines a high-speed + serial interface between a host processor and a display module. + config CONSOLE_NORMAL bool "Support a simple text console" depends on DM_VIDEO diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 0f41a23..1e88741 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -47,6 +47,7 @@ obj-$(CONFIG_VIDEO_LCD_ANX9804) += anx9804.o obj-$(CONFIG_VIDEO_LCD_HITACHI_TX18D42VM) += hitachi_tx18d42vm_lcd.o obj-$(CONFIG_VIDEO_LCD_SSD2828) += ssd2828.o obj-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o +obj-${CONFIG_VIDEO_MIPI_DSI} += mipi_dsi.o obj-$(CONFIG_VIDEO_MVEBU) += mvebu_lcd.o obj-$(CONFIG_VIDEO_MX3) += mx3fb.o videomodes.o obj-$(CONFIG_VIDEO_MXS) += mxsfb.o videomodes.o diff --git a/drivers/video/mipi_dsi.c b/drivers/video/mipi_dsi.c new file mode 100644 index 0000000..ccc5794 --- /dev/null +++ b/drivers/video/mipi_dsi.c @@ -0,0 +1,828 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * MIPI DSI Bus + * + * Copyright (C) 2012-2013, Samsung Electronics, Co., Ltd. + * Copyright (C) 2018 STMicroelectronics - All Rights Reserved + * Andrzej Hajda a.hajda@samsung.com + * + * Permission is hereby granted, free of charge, to any person obtaining a + * copy of this software and associated documentation files (the + * "Software"), to deal in the Software without restriction, including + * without limitation the rights to use, copy, modify, merge, publish, + * distribute, sub license, and/or sell copies of the Software, and to + * permit persons to whom the Software is furnished to do so, subject to + * the following conditions: + * + * The above copyright notice and this permission notice (including the + * next paragraph) shall be included in all copies or substantial portions + * of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR + * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, + * FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL + * THE COPYRIGHT HOLDERS, AUTHORS AND/OR ITS SUPPLIERS BE LIABLE FOR ANY CLAIM, + * DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR + * OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE + * USE OR OTHER DEALINGS IN THE SOFTWARE. + * + * Mipi_dsi.c contains a set of dsi helpers. + * This file is inspired from the drm helper file drivers/gpu/drm/drm_mipi_dsi.c + * (kernel linux). + * + */ + +#include <common.h> +#include <clk.h> +#include <display.h> +#include <dm.h> +#include <mipi_display.h> +#include <mipi_dsi.h> + +/** + * DOC: dsi helpers + * + * These functions contain some common logic and helpers to deal with MIPI DSI + * peripherals. + * + * Helpers are provided for a number of standard MIPI DSI command as well as a + * subset of the MIPI DCS command set. + */ + +/** + * mipi_dsi_attach - attach a DSI device to its DSI host + * @dsi: DSI peripheral + */ +int mipi_dsi_attach(struct mipi_dsi_device *dsi) +{ + const struct mipi_dsi_host_ops *ops = dsi->host->ops; + + if (!ops || !ops->attach) + return -ENOSYS; + + return ops->attach(dsi->host, dsi); +} +EXPORT_SYMBOL(mipi_dsi_attach); + +/** + * mipi_dsi_detach - detach a DSI device from its DSI host + * @dsi: DSI peripheral + */ +int mipi_dsi_detach(struct mipi_dsi_device *dsi) +{ + const struct mipi_dsi_host_ops *ops = dsi->host->ops; + + if (!ops || !ops->detach) + return -ENOSYS; + + return ops->detach(dsi->host, dsi); +} +EXPORT_SYMBOL(mipi_dsi_detach); + +/** + * mipi_dsi_device_transfer - transfer message to a DSI device + * @dsi: DSI peripheral + * @msg: message + */ +static ssize_t mipi_dsi_device_transfer(struct mipi_dsi_device *dsi, + struct mipi_dsi_msg *msg) +{ + const struct mipi_dsi_host_ops *ops = dsi->host->ops; + + if (!ops || !ops->transfer) + return -ENOSYS; + + if (dsi->mode_flags & MIPI_DSI_MODE_LPM) + msg->flags |= MIPI_DSI_MSG_USE_LPM; + + return ops->transfer(dsi->host, msg); +} + +/** + * mipi_dsi_packet_format_is_short - check if a packet is of the short format + * @type: MIPI DSI data type of the packet + * + * Return: true if the packet for the given data type is a short packet, false + * otherwise. + */ +bool mipi_dsi_packet_format_is_short(u8 type) +{ + switch (type) { + case MIPI_DSI_V_SYNC_START: + case MIPI_DSI_V_SYNC_END: + case MIPI_DSI_H_SYNC_START: + case MIPI_DSI_H_SYNC_END: + case MIPI_DSI_END_OF_TRANSMISSION: + case MIPI_DSI_COLOR_MODE_OFF: + case MIPI_DSI_COLOR_MODE_ON: + case MIPI_DSI_SHUTDOWN_PERIPHERAL: + case MIPI_DSI_TURN_ON_PERIPHERAL: + case MIPI_DSI_GENERIC_SHORT_WRITE_0_PARAM: + case MIPI_DSI_GENERIC_SHORT_WRITE_1_PARAM: + case MIPI_DSI_GENERIC_SHORT_WRITE_2_PARAM: + case MIPI_DSI_GENERIC_READ_REQUEST_0_PARAM: + case MIPI_DSI_GENERIC_READ_REQUEST_1_PARAM: + case MIPI_DSI_GENERIC_READ_REQUEST_2_PARAM: + case MIPI_DSI_DCS_SHORT_WRITE: + case MIPI_DSI_DCS_SHORT_WRITE_PARAM: + case MIPI_DSI_DCS_READ: + case MIPI_DSI_SET_MAXIMUM_RETURN_PACKET_SIZE: + return true; + } + + return false; +} +EXPORT_SYMBOL(mipi_dsi_packet_format_is_short); + +/** + * mipi_dsi_packet_format_is_long - check if a packet is of the long format + * @type: MIPI DSI data type of the packet + * + * Return: true if the packet for the given data type is a long packet, false + * otherwise. + */ +bool mipi_dsi_packet_format_is_long(u8 type) +{ + switch (type) { + case MIPI_DSI_NULL_PACKET: + case MIPI_DSI_BLANKING_PACKET: + case MIPI_DSI_GENERIC_LONG_WRITE: + case MIPI_DSI_DCS_LONG_WRITE: + case MIPI_DSI_LOOSELY_PACKED_PIXEL_STREAM_YCBCR20: + case MIPI_DSI_PACKED_PIXEL_STREAM_YCBCR24: + case MIPI_DSI_PACKED_PIXEL_STREAM_YCBCR16: + case MIPI_DSI_PACKED_PIXEL_STREAM_30: + case MIPI_DSI_PACKED_PIXEL_STREAM_36: + case MIPI_DSI_PACKED_PIXEL_STREAM_YCBCR12: + case MIPI_DSI_PACKED_PIXEL_STREAM_16: + case MIPI_DSI_PACKED_PIXEL_STREAM_18: + case MIPI_DSI_PIXEL_STREAM_3BYTE_18: + case MIPI_DSI_PACKED_PIXEL_STREAM_24: + return true; + } + + return false; +} +EXPORT_SYMBOL(mipi_dsi_packet_format_is_long); + +/** + * mipi_dsi_create_packet - create a packet from a message according to the + * DSI protocol + * @packet: pointer to a DSI packet structure + * @msg: message to translate into a packet + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_create_packet(struct mipi_dsi_packet *packet, + const struct mipi_dsi_msg *msg) +{ + if (!packet || !msg) + return -EINVAL; + + /* do some minimum sanity checking */ + if (!mipi_dsi_packet_format_is_short(msg->type) && + !mipi_dsi_packet_format_is_long(msg->type)) + return -EINVAL; + + if (msg->channel > 3) + return -EINVAL; + + memset(packet, 0, sizeof(*packet)); + packet->header[0] = ((msg->channel & 0x3) << 6) | (msg->type & 0x3f); + + /* TODO: compute ECC if hardware support is not available */ + + /* + * Long write packets contain the word count in header bytes 1 and 2. + * The payload follows the header and is word count bytes long. + * + * Short write packets encode up to two parameters in header bytes 1 + * and 2. + */ + if (mipi_dsi_packet_format_is_long(msg->type)) { + packet->header[1] = (msg->tx_len >> 0) & 0xff; + packet->header[2] = (msg->tx_len >> 8) & 0xff; + + packet->payload_length = msg->tx_len; + packet->payload = msg->tx_buf; + } else { + const u8 *tx = msg->tx_buf; + + packet->header[1] = (msg->tx_len > 0) ? tx[0] : 0; + packet->header[2] = (msg->tx_len > 1) ? tx[1] : 0; + } + + packet->size = sizeof(packet->header) + packet->payload_length; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_create_packet); + +/** + * mipi_dsi_shutdown_peripheral() - sends a Shutdown Peripheral command + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_shutdown_peripheral(struct mipi_dsi_device *dsi) +{ + struct mipi_dsi_msg msg = { + .channel = dsi->channel, + .type = MIPI_DSI_SHUTDOWN_PERIPHERAL, + .tx_buf = (u8 [2]) { 0, 0 }, + .tx_len = 2, + }; + int ret = mipi_dsi_device_transfer(dsi, &msg); + + return (ret < 0) ? ret : 0; +} +EXPORT_SYMBOL(mipi_dsi_shutdown_peripheral); + +/** + * mipi_dsi_turn_on_peripheral() - sends a Turn On Peripheral command + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_turn_on_peripheral(struct mipi_dsi_device *dsi) +{ + struct mipi_dsi_msg msg = { + .channel = dsi->channel, + .type = MIPI_DSI_TURN_ON_PERIPHERAL, + .tx_buf = (u8 [2]) { 0, 0 }, + .tx_len = 2, + }; + int ret = mipi_dsi_device_transfer(dsi, &msg); + + return (ret < 0) ? ret : 0; +} +EXPORT_SYMBOL(mipi_dsi_turn_on_peripheral); + +/* + * mipi_dsi_set_maximum_return_packet_size() - specify the maximum size of the + * the payload in a long packet transmitted from the peripheral back to the + * host processor + * @dsi: DSI peripheral device + * @value: the maximum size of the payload + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_set_maximum_return_packet_size(struct mipi_dsi_device *dsi, + u16 value) +{ + u8 tx[2] = { value & 0xff, value >> 8 }; + struct mipi_dsi_msg msg = { + .channel = dsi->channel, + .type = MIPI_DSI_SET_MAXIMUM_RETURN_PACKET_SIZE, + .tx_len = sizeof(tx), + .tx_buf = tx, + }; + int ret = mipi_dsi_device_transfer(dsi, &msg); + + return (ret < 0) ? ret : 0; +} +EXPORT_SYMBOL(mipi_dsi_set_maximum_return_packet_size); + +/** + * mipi_dsi_generic_write() - transmit data using a generic write packet + * @dsi: DSI peripheral device + * @payload: buffer containing the payload + * @size: size of payload buffer + * + * This function will automatically choose the right data type depending on + * the payload length. + * + * Return: The number of bytes transmitted on success or a negative error code + * on failure. + */ +ssize_t mipi_dsi_generic_write(struct mipi_dsi_device *dsi, const void *payload, + size_t size) +{ + struct mipi_dsi_msg msg = { + .channel = dsi->channel, + .tx_buf = payload, + .tx_len = size + }; + + switch (size) { + case 0: + msg.type = MIPI_DSI_GENERIC_SHORT_WRITE_0_PARAM; + break; + + case 1: + msg.type = MIPI_DSI_GENERIC_SHORT_WRITE_1_PARAM; + break; + + case 2: + msg.type = MIPI_DSI_GENERIC_SHORT_WRITE_2_PARAM; + break; + + default: + msg.type = MIPI_DSI_GENERIC_LONG_WRITE; + break; + } + + return mipi_dsi_device_transfer(dsi, &msg); +} +EXPORT_SYMBOL(mipi_dsi_generic_write); + +/** + * mipi_dsi_generic_read() - receive data using a generic read packet + * @dsi: DSI peripheral device + * @params: buffer containing the request parameters + * @num_params: number of request parameters + * @data: buffer in which to return the received data + * @size: size of receive buffer + * + * This function will automatically choose the right data type depending on + * the number of parameters passed in. + * + * Return: The number of bytes successfully read or a negative error code on + * failure. + */ +ssize_t mipi_dsi_generic_read(struct mipi_dsi_device *dsi, const void *params, + size_t num_params, void *data, size_t size) +{ + struct mipi_dsi_msg msg = { + .channel = dsi->channel, + .tx_len = num_params, + .tx_buf = params, + .rx_len = size, + .rx_buf = data + }; + + switch (num_params) { + case 0: + msg.type = MIPI_DSI_GENERIC_READ_REQUEST_0_PARAM; + break; + + case 1: + msg.type = MIPI_DSI_GENERIC_READ_REQUEST_1_PARAM; + break; + + case 2: + msg.type = MIPI_DSI_GENERIC_READ_REQUEST_2_PARAM; + break; + + default: + return -EINVAL; + } + + return mipi_dsi_device_transfer(dsi, &msg); +} +EXPORT_SYMBOL(mipi_dsi_generic_read); + +/** + * mipi_dsi_dcs_write_buffer() - transmit a DCS command with payload + * @dsi: DSI peripheral device + * @data: buffer containing data to be transmitted + * @len: size of transmission buffer + * + * This function will automatically choose the right data type depending on + * the command payload length. + * + * Return: The number of bytes successfully transmitted or a negative error + * code on failure. + */ +ssize_t mipi_dsi_dcs_write_buffer(struct mipi_dsi_device *dsi, + const void *data, size_t len) +{ + struct mipi_dsi_msg msg = { + .channel = dsi->channel, + .tx_buf = data, + .tx_len = len + }; + + switch (len) { + case 0: + return -EINVAL; + + case 1: + msg.type = MIPI_DSI_DCS_SHORT_WRITE; + break; + + case 2: + msg.type = MIPI_DSI_DCS_SHORT_WRITE_PARAM; + break; + + default: + msg.type = MIPI_DSI_DCS_LONG_WRITE; + break; + } + + return mipi_dsi_device_transfer(dsi, &msg); +} +EXPORT_SYMBOL(mipi_dsi_dcs_write_buffer); + +/** + * mipi_dsi_dcs_write() - send DCS write command + * @dsi: DSI peripheral device + * @cmd: DCS command + * @data: buffer containing the command payload + * @len: command payload length + * + * This function will automatically choose the right data type depending on + * the command payload length. + * + * Return: The number of bytes successfully transmitted or a negative error + * code on failure. + */ +ssize_t mipi_dsi_dcs_write(struct mipi_dsi_device *dsi, u8 cmd, + const void *data, size_t len) +{ + ssize_t err; + size_t size; + u8 *tx; + + if (len > 0) { + size = 1 + len; + + tx = kmalloc(size, GFP_KERNEL); + if (!tx) + return -ENOMEM; + + /* concatenate the DCS command byte and the payload */ + tx[0] = cmd; + memcpy(&tx[1], data, len); + } else { + tx = &cmd; + size = 1; + } + + err = mipi_dsi_dcs_write_buffer(dsi, tx, size); + + if (len > 0) + kfree(tx); + + return err; +} +EXPORT_SYMBOL(mipi_dsi_dcs_write); + +/** + * mipi_dsi_dcs_read() - send DCS read request command + * @dsi: DSI peripheral device + * @cmd: DCS command + * @data: buffer in which to receive data + * @len: size of receive buffer + * + * Return: The number of bytes read or a negative error code on failure. + */ +ssize_t mipi_dsi_dcs_read(struct mipi_dsi_device *dsi, u8 cmd, void *data, + size_t len) +{ + struct mipi_dsi_msg msg = { + .channel = dsi->channel, + .type = MIPI_DSI_DCS_READ, + .tx_buf = &cmd, + .tx_len = 1, + .rx_buf = data, + .rx_len = len + }; + + return mipi_dsi_device_transfer(dsi, &msg); +} +EXPORT_SYMBOL(mipi_dsi_dcs_read); + +/** + * mipi_dsi_dcs_nop() - send DCS nop packet + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_nop(struct mipi_dsi_device *dsi) +{ + ssize_t err; + + err = mipi_dsi_dcs_write(dsi, MIPI_DCS_NOP, NULL, 0); + if (err < 0) + return err; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_nop); + +/** + * mipi_dsi_dcs_soft_reset() - perform a software reset of the display module + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_soft_reset(struct mipi_dsi_device *dsi) +{ + ssize_t err; + + err = mipi_dsi_dcs_write(dsi, MIPI_DCS_SOFT_RESET, NULL, 0); + if (err < 0) + return err; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_soft_reset); + +/** + * mipi_dsi_dcs_get_power_mode() - query the display module's current power + * mode + * @dsi: DSI peripheral device + * @mode: return location for the current power mode + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_get_power_mode(struct mipi_dsi_device *dsi, u8 *mode) +{ + ssize_t err; + + err = mipi_dsi_dcs_read(dsi, MIPI_DCS_GET_POWER_MODE, mode, + sizeof(*mode)); + if (err <= 0) { + if (err == 0) + err = -ENODATA; + + return err; + } + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_get_power_mode); + +/** + * mipi_dsi_dcs_get_pixel_format() - gets the pixel format for the RGB image + * data used by the interface + * @dsi: DSI peripheral device + * @format: return location for the pixel format + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_get_pixel_format(struct mipi_dsi_device *dsi, u8 *format) +{ + ssize_t err; + + err = mipi_dsi_dcs_read(dsi, MIPI_DCS_GET_PIXEL_FORMAT, format, + sizeof(*format)); + if (err <= 0) { + if (err == 0) + err = -ENODATA; + + return err; + } + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_get_pixel_format); + +/** + * mipi_dsi_dcs_enter_sleep_mode() - disable all unnecessary blocks inside the + * display module except interface communication + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_enter_sleep_mode(struct mipi_dsi_device *dsi) +{ + ssize_t err; + + err = mipi_dsi_dcs_write(dsi, MIPI_DCS_ENTER_SLEEP_MODE, NULL, 0); + if (err < 0) + return err; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_enter_sleep_mode); + +/** + * mipi_dsi_dcs_exit_sleep_mode() - enable all blocks inside the display + * module + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_exit_sleep_mode(struct mipi_dsi_device *dsi) +{ + ssize_t err; + + err = mipi_dsi_dcs_write(dsi, MIPI_DCS_EXIT_SLEEP_MODE, NULL, 0); + if (err < 0) + return err; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_exit_sleep_mode); + +/** + * mipi_dsi_dcs_set_display_off() - stop displaying the image data on the + * display device + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_set_display_off(struct mipi_dsi_device *dsi) +{ + ssize_t err; + + err = mipi_dsi_dcs_write(dsi, MIPI_DCS_SET_DISPLAY_OFF, NULL, 0); + if (err < 0) + return err; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_set_display_off); + +/** + * mipi_dsi_dcs_set_display_on() - start displaying the image data on the + * display device + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure + */ +int mipi_dsi_dcs_set_display_on(struct mipi_dsi_device *dsi) +{ + ssize_t err; + + err = mipi_dsi_dcs_write(dsi, MIPI_DCS_SET_DISPLAY_ON, NULL, 0); + if (err < 0) + return err; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_set_display_on); + +/** + * mipi_dsi_dcs_set_column_address() - define the column extent of the frame + * memory accessed by the host processor + * @dsi: DSI peripheral device + * @start: first column of frame memory + * @end: last column of frame memory + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_set_column_address(struct mipi_dsi_device *dsi, u16 start, + u16 end) +{ + u8 payload[4] = { start >> 8, start & 0xff, end >> 8, end & 0xff }; + ssize_t err; + + err = mipi_dsi_dcs_write(dsi, MIPI_DCS_SET_COLUMN_ADDRESS, payload, + sizeof(payload)); + if (err < 0) + return err; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_set_column_address); + +/** + * mipi_dsi_dcs_set_page_address() - define the page extent of the frame + * memory accessed by the host processor + * @dsi: DSI peripheral device + * @start: first page of frame memory + * @end: last page of frame memory + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_set_page_address(struct mipi_dsi_device *dsi, u16 start, + u16 end) +{ + u8 payload[4] = { start >> 8, start & 0xff, end >> 8, end & 0xff }; + ssize_t err; + + err = mipi_dsi_dcs_write(dsi, MIPI_DCS_SET_PAGE_ADDRESS, payload, + sizeof(payload)); + if (err < 0) + return err; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_set_page_address); + +/** + * mipi_dsi_dcs_set_tear_off() - turn off the display module's Tearing Effect + * output signal on the TE signal line + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure + */ +int mipi_dsi_dcs_set_tear_off(struct mipi_dsi_device *dsi) +{ + ssize_t err; + + err = mipi_dsi_dcs_write(dsi, MIPI_DCS_SET_TEAR_OFF, NULL, 0); + if (err < 0) + return err; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_set_tear_off); + +/** + * mipi_dsi_dcs_set_tear_on() - turn on the display module's Tearing Effect + * output signal on the TE signal line. + * @dsi: DSI peripheral device + * @mode: the Tearing Effect Output Line mode + * + * Return: 0 on success or a negative error code on failure + */ +int mipi_dsi_dcs_set_tear_on(struct mipi_dsi_device *dsi, + enum mipi_dsi_dcs_tear_mode mode) +{ + u8 value = mode; + ssize_t err; + + err = mipi_dsi_dcs_write(dsi, MIPI_DCS_SET_TEAR_ON, &value, + sizeof(value)); + if (err < 0) + return err; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_set_tear_on); + +/** + * mipi_dsi_dcs_set_pixel_format() - sets the pixel format for the RGB image + * data used by the interface + * @dsi: DSI peripheral device + * @format: pixel format + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_set_pixel_format(struct mipi_dsi_device *dsi, u8 format) +{ + ssize_t err; + + err = mipi_dsi_dcs_write(dsi, MIPI_DCS_SET_PIXEL_FORMAT, &format, + sizeof(format)); + if (err < 0) + return err; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_set_pixel_format); + +/** + * mipi_dsi_dcs_set_tear_scanline() - set the scanline to use as trigger for + * the Tearing Effect output signal of the display module + * @dsi: DSI peripheral device + * @scanline: scanline to use as trigger + * + * Return: 0 on success or a negative error code on failure + */ +int mipi_dsi_dcs_set_tear_scanline(struct mipi_dsi_device *dsi, u16 scanline) +{ + u8 payload[3] = { MIPI_DCS_SET_TEAR_SCANLINE, scanline >> 8, + scanline & 0xff }; + ssize_t err; + + err = mipi_dsi_generic_write(dsi, payload, sizeof(payload)); + if (err < 0) + return err; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_set_tear_scanline); + +/** + * mipi_dsi_dcs_set_display_brightness() - sets the brightness value of the + * display + * @dsi: DSI peripheral device + * @brightness: brightness value + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_set_display_brightness(struct mipi_dsi_device *dsi, + u16 brightness) +{ + u8 payload[2] = { brightness & 0xff, brightness >> 8 }; + ssize_t err; + + err = mipi_dsi_dcs_write(dsi, MIPI_DCS_SET_DISPLAY_BRIGHTNESS, + payload, sizeof(payload)); + if (err < 0) + return err; + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_set_display_brightness); + +/** + * mipi_dsi_dcs_get_display_brightness() - gets the current brightness value + * of the display + * @dsi: DSI peripheral device + * @brightness: brightness value + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_get_display_brightness(struct mipi_dsi_device *dsi, + u16 *brightness) +{ + ssize_t err; + + err = mipi_dsi_dcs_read(dsi, MIPI_DCS_GET_DISPLAY_BRIGHTNESS, + brightness, sizeof(*brightness)); + if (err <= 0) { + if (err == 0) + err = -ENODATA; + + return err; + } + + return 0; +} +EXPORT_SYMBOL(mipi_dsi_dcs_get_display_brightness); diff --git a/include/mipi_dsi.h b/include/mipi_dsi.h new file mode 100644 index 0000000..e25753d --- /dev/null +++ b/include/mipi_dsi.h @@ -0,0 +1,451 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * MIPI DSI Bus + * + * Copyright (C) 2012-2013, Samsung Electronics, Co., Ltd. + * Copyright (C) 2018 STMicroelectronics - All Rights Reserved + * Author(s): Andrzej Hajda a.hajda@samsung.com + * Yannick Fertre yannick.fertre@st.com + * Philippe Cornu philippe.cornu@st.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +#ifndef MIPI_DSI_H +#define MIPI_DSI_H + +struct mipi_dsi_host; +struct mipi_dsi_device; + +/* request ACK from peripheral */ +#define MIPI_DSI_MSG_REQ_ACK BIT(0) +/* use Low Power Mode to transmit message */ +#define MIPI_DSI_MSG_USE_LPM BIT(1) + +/** + * struct mipi_dsi_msg - read/write DSI buffer + * @channel: virtual channel id + * @type: payload data type + * @flags: flags controlling this message transmission + * @tx_len: length of @tx_buf + * @tx_buf: data to be written + * @rx_len: length of @rx_buf + * @rx_buf: data to be read, or NULL + */ +struct mipi_dsi_msg { + u8 channel; + u8 type; + u16 flags; + + size_t tx_len; + const void *tx_buf; + + size_t rx_len; + void *rx_buf; +}; + +bool mipi_dsi_packet_format_is_short(u8 type); +bool mipi_dsi_packet_format_is_long(u8 type); + +/** + * struct mipi_dsi_packet - represents a MIPI DSI packet in protocol format + * @size: size (in bytes) of the packet + * @header: the four bytes that make up the header (Data ID, Word Count or + * Packet Data, and ECC) + * @payload_length: number of bytes in the payload + * @payload: a pointer to a buffer containing the payload, if any + */ +struct mipi_dsi_packet { + size_t size; + u8 header[4]; + size_t payload_length; + const u8 *payload; +}; + +int mipi_dsi_create_packet(struct mipi_dsi_packet *packet, + const struct mipi_dsi_msg *msg); + +/** + * struct mipi_dsi_host_ops - DSI bus operations + * @attach: attach DSI device to DSI host + * @detach: detach DSI device from DSI host + * @transfer: transmit a DSI packet + * + * DSI packets transmitted by .transfer() are passed in as mipi_dsi_msg + * structures. This structure contains information about the type of packet + * being transmitted as well as the transmit and receive buffers. When an + * error is encountered during transmission, this function will return a + * negative error code. On success it shall return the number of bytes + * transmitted for write packets or the number of bytes received for read + * packets. + * + * Note that typically DSI packet transmission is atomic, so the .transfer() + * function will seldomly return anything other than the number of bytes + * contained in the transmit buffer on success. + */ +struct mipi_dsi_host_ops { + int (*attach)(struct mipi_dsi_host *host, + struct mipi_dsi_device *dsi); + int (*detach)(struct mipi_dsi_host *host, + struct mipi_dsi_device *dsi); + ssize_t (*transfer)(struct mipi_dsi_host *host, + const struct mipi_dsi_msg *msg); +}; + +/** + * struct mipi_dsi_host - DSI host device + * @dev: driver model device node for this DSI host + * @ops: DSI host operations + * @list: list management + */ +struct mipi_dsi_host { + struct device *dev; + const struct mipi_dsi_host_ops *ops; + struct list_head list; +}; + +/* DSI mode flags */ + +/* video mode */ +#define MIPI_DSI_MODE_VIDEO BIT(0) +/* video burst mode */ +#define MIPI_DSI_MODE_VIDEO_BURST BIT(1) +/* video pulse mode */ +#define MIPI_DSI_MODE_VIDEO_SYNC_PULSE BIT(2) +/* enable auto vertical count mode */ +#define MIPI_DSI_MODE_VIDEO_AUTO_VERT BIT(3) +/* enable hsync-end packets in vsync-pulse and v-porch area */ +#define MIPI_DSI_MODE_VIDEO_HSE BIT(4) +/* disable hfront-porch area */ +#define MIPI_DSI_MODE_VIDEO_HFP BIT(5) +/* disable hback-porch area */ +#define MIPI_DSI_MODE_VIDEO_HBP BIT(6) +/* disable hsync-active area */ +#define MIPI_DSI_MODE_VIDEO_HSA BIT(7) +/* flush display FIFO on vsync pulse */ +#define MIPI_DSI_MODE_VSYNC_FLUSH BIT(8) +/* disable EoT packets in HS mode */ +#define MIPI_DSI_MODE_EOT_PACKET BIT(9) +/* device supports non-continuous clock behavior (DSI spec 5.6.1) */ +#define MIPI_DSI_CLOCK_NON_CONTINUOUS BIT(10) +/* transmit data in low power */ +#define MIPI_DSI_MODE_LPM BIT(11) + +enum mipi_dsi_pixel_format { + MIPI_DSI_FMT_RGB888, + MIPI_DSI_FMT_RGB666, + MIPI_DSI_FMT_RGB666_PACKED, + MIPI_DSI_FMT_RGB565, +}; + +#define DSI_DEV_NAME_SIZE 20 + +/** + * struct mipi_dsi_device_info - template for creating a mipi_dsi_device + * @type: DSI peripheral chip type + * @channel: DSI virtual channel assigned to peripheral + * @node: pointer to OF device node or NULL + * + * This is populated and passed to mipi_dsi_device_new to create a new + * DSI device + */ +struct mipi_dsi_device_info { + char type[DSI_DEV_NAME_SIZE]; + u32 channel; + struct device_node *node; +}; + +/** + * struct mipi_dsi_device - DSI peripheral device + * @host: DSI host for this peripheral + * @dev: driver model device node for this peripheral + * @name: DSI peripheral chip type + * @channel: virtual channel assigned to the peripheral + * @format: pixel format for video mode + * @lanes: number of active data lanes + * @mode_flags: DSI operation mode related flags + */ +struct mipi_dsi_device { + struct mipi_dsi_host *host; + struct udevice *dev; + + char name[DSI_DEV_NAME_SIZE]; + unsigned int channel; + unsigned int lanes; + enum mipi_dsi_pixel_format format; + unsigned long mode_flags; +}; + +/** + * mipi_dsi_pixel_format_to_bpp - obtain the number of bits per pixel for any + * given pixel format defined by the MIPI DSI + * specification + * @fmt: MIPI DSI pixel format + * + * Returns: The number of bits per pixel of the given pixel format. + */ +static inline int mipi_dsi_pixel_format_to_bpp(enum mipi_dsi_pixel_format fmt) +{ + switch (fmt) { + case MIPI_DSI_FMT_RGB888: + case MIPI_DSI_FMT_RGB666: + return 24; + + case MIPI_DSI_FMT_RGB666_PACKED: + return 18; + + case MIPI_DSI_FMT_RGB565: + return 16; + } + + return -EINVAL; +} + +/** + * struct mipi_dsi_panel_plat - DSI panel platform data + * @device: DSI peripheral device + */ +struct mipi_dsi_panel_plat { + struct mipi_dsi_device *device; +}; + +/** + * mipi_dsi_attach - attach a DSI device to its DSI host + * @dsi: DSI peripheral + */ +int mipi_dsi_attach(struct mipi_dsi_device *dsi); + +/** + * mipi_dsi_detach - detach a DSI device from its DSI host + * @dsi: DSI peripheral + */ +int mipi_dsi_detach(struct mipi_dsi_device *dsi); +int mipi_dsi_shutdown_peripheral(struct mipi_dsi_device *dsi); +int mipi_dsi_turn_on_peripheral(struct mipi_dsi_device *dsi); +int mipi_dsi_set_maximum_return_packet_size(struct mipi_dsi_device *dsi, + u16 value); + +ssize_t mipi_dsi_generic_write(struct mipi_dsi_device *dsi, const void *payload, + size_t size); +ssize_t mipi_dsi_generic_read(struct mipi_dsi_device *dsi, const void *params, + size_t num_params, void *data, size_t size); + +/** + * enum mipi_dsi_dcs_tear_mode - Tearing Effect Output Line mode + * @MIPI_DSI_DCS_TEAR_MODE_VBLANK: the TE output line consists of V-Blanking + * information only + * @MIPI_DSI_DCS_TEAR_MODE_VHBLANK : the TE output line consists of both + * V-Blanking and H-Blanking information + */ +enum mipi_dsi_dcs_tear_mode { + MIPI_DSI_DCS_TEAR_MODE_VBLANK, + MIPI_DSI_DCS_TEAR_MODE_VHBLANK, +}; + +#define MIPI_DSI_DCS_POWER_MODE_DISPLAY BIT(2) +#define MIPI_DSI_DCS_POWER_MODE_NORMAL BIT(3) +#define MIPI_DSI_DCS_POWER_MODE_SLEEP BIT(4) +#define MIPI_DSI_DCS_POWER_MODE_PARTIAL BIT(5) +#define MIPI_DSI_DCS_POWER_MODE_IDLE BIT(6) + +/** + * mipi_dsi_dcs_write_buffer() - transmit a DCS command with payload + * @dsi: DSI peripheral device + * @data: buffer containing data to be transmitted + * @len: size of transmission buffer + * + * This function will automatically choose the right data type depending on + * the command payload length. + * + * Return: The number of bytes successfully transmitted or a negative error + * code on failure. + */ +ssize_t mipi_dsi_dcs_write_buffer(struct mipi_dsi_device *dsi, + const void *data, size_t len); + +/** + * mipi_dsi_dcs_write() - send DCS write command + * @dsi: DSI peripheral device + * @cmd: DCS command + * @data: buffer containing the command payload + * @len: command payload length + * + * This function will automatically choose the right data type depending on + * the command payload length. + + * code on failure. + */ +ssize_t mipi_dsi_dcs_write(struct mipi_dsi_device *dsi, u8 cmd, + const void *data, size_t len); + +/** + * mipi_dsi_dcs_read() - send DCS read request command + * @dsi: DSI peripheral device + * @cmd: DCS command + * @data: buffer in which to receive data + * @len: size of receive buffer + * + * Return: The number of bytes read or a negative error code on failure. + */ +ssize_t mipi_dsi_dcs_read(struct mipi_dsi_device *dsi, u8 cmd, void *data, + size_t len); + +/** + * mipi_dsi_dcs_nop() - send DCS nop packet + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_nop(struct mipi_dsi_device *dsi); + +/** + * mipi_dsi_dcs_soft_reset() - perform a software reset of the display module + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_soft_reset(struct mipi_dsi_device *dsi); + +/** + * mipi_dsi_dcs_get_power_mode() - query the display module's current power + * mode + * @dsi: DSI peripheral device + * @mode: return location for the current power mode + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_get_power_mode(struct mipi_dsi_device *dsi, u8 *mode); + +/** + * mipi_dsi_dcs_get_pixel_format() - gets the pixel format for the RGB image + * data used by the interface + * @dsi: DSI peripheral device + * @format: return location for the pixel format + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_get_pixel_format(struct mipi_dsi_device *dsi, u8 *format); + +/** + * mipi_dsi_dcs_enter_sleep_mode() - disable all unnecessary blocks inside the + * display module except interface communication + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_enter_sleep_mode(struct mipi_dsi_device *dsi); + +/** + * mipi_dsi_dcs_exit_sleep_mode() - enable all blocks inside the display + * module + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_exit_sleep_mode(struct mipi_dsi_device *dsi); + +/** + * mipi_dsi_dcs_set_display_off() - stop displaying the image data on the + * display device + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_set_display_off(struct mipi_dsi_device *dsi); + +/** + * mipi_dsi_dcs_set_display_on() - start displaying the image data on the + * display device + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure + */ +int mipi_dsi_dcs_set_display_on(struct mipi_dsi_device *dsi); + +/** + * mipi_dsi_dcs_set_column_address() - define the column extent of the frame + * memory accessed by the host processor + * @dsi: DSI peripheral device + * @start: first column of frame memory + * @end: last column of frame memory + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_set_column_address(struct mipi_dsi_device *dsi, u16 start, + u16 end); +/** + * mipi_dsi_dcs_set_page_address() - define the page extent of the frame + * memory accessed by the host processor + * @dsi: DSI peripheral device + * @start: first page of frame memory + * @end: last page of frame memory + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_set_page_address(struct mipi_dsi_device *dsi, u16 start, + u16 end); + +/** + * mipi_dsi_dcs_set_tear_off() - turn off the display module's Tearing Effect + * output signal on the TE signal line + * @dsi: DSI peripheral device + * + * Return: 0 on success or a negative error code on failure + */ +int mipi_dsi_dcs_set_tear_off(struct mipi_dsi_device *dsi); + +/** + * mipi_dsi_dcs_set_tear_on() - turn on the display module's Tearing Effect + * output signal on the TE signal line. + * @dsi: DSI peripheral device + * @mode: the Tearing Effect Output Line mode + * + * Return: 0 on success or a negative error code on failure + */ +int mipi_dsi_dcs_set_tear_on(struct mipi_dsi_device *dsi, + enum mipi_dsi_dcs_tear_mode mode); + +/** + * mipi_dsi_dcs_set_pixel_format() - sets the pixel format for the RGB image + * data used by the interface + * @dsi: DSI peripheral device + * @format: pixel format + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_set_pixel_format(struct mipi_dsi_device *dsi, u8 format); + +/** + * mipi_dsi_dcs_set_tear_scanline() - set the scanline to use as trigger for + * the Tearing Effect output signal of the display module + * @dsi: DSI peripheral device + * @scanline: scanline to use as trigger + * + * Return: 0 on success or a negative error code on failure + */ +int mipi_dsi_dcs_set_tear_scanline(struct mipi_dsi_device *dsi, u16 scanline); + +/** + * mipi_dsi_dcs_set_display_brightness() - sets the brightness value of the + * display + * @dsi: DSI peripheral device + * @brightness: brightness value + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_set_display_brightness(struct mipi_dsi_device *dsi, + u16 brightness); + +/** + * mipi_dsi_dcs_get_display_brightness() - gets the current brightness value + * of the display + * @dsi: DSI peripheral device + * @brightness: brightness value + * + * Return: 0 on success or a negative error code on failure. + */ +int mipi_dsi_dcs_get_display_brightness(struct mipi_dsi_device *dsi, + u16 *brightness); + +#endif /* MIPI_DSI_H */
Yes I think you need a uclass. However it is probably not applicable for this file, but for the other one, where you have the transfer() method. You should set up a uclass for that.
Ok, I 'll rework driver with a new uclass & driver model.
Best regards
Add a Synopsys Designware MIPI DSI host bridge driver, based on the Rockchip version from rockchip/dw-mipi-dsi.c with phy & bridge APIs.
Signed-off-by: Yannick Fertré yannick.fertre@st.com --- drivers/video/Kconfig | 9 + drivers/video/Makefile | 1 + drivers/video/dw_mipi_dsi.c | 827 ++++++++++++++++++++++++++++++++++++++++++++ include/dw_mipi_dsi.h | 33 ++ 4 files changed, 870 insertions(+) create mode 100644 drivers/video/dw_mipi_dsi.c create mode 100644 include/dw_mipi_dsi.h
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 6048291..ede351d 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -667,6 +667,15 @@ config VIDEO_DW_HDMI rather requires a SoC-specific glue driver to call it), it can not be enabled from the configuration menu.
+config VIDEO_DW_MIPI_DSI + bool + help + Enables the common driver code for the Synopsis Designware + MIPI DSI block found in SoCs from various vendors. + As this does not provide any functionality by itself (but + rather requires a SoC-specific glue driver to call it), it + can not be enabled from the configuration menu. + config VIDEO_SIMPLE bool "Simple display driver for preconfigured display" help diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 1e88741..ae143dc 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -39,6 +39,7 @@ obj-$(CONFIG_VIDEO_BROADWELL_IGD) += broadwell_igd.o obj-$(CONFIG_VIDEO_COREBOOT) += coreboot.o obj-$(CONFIG_VIDEO_DA8XX) += da8xx-fb.o videomodes.o obj-$(CONFIG_VIDEO_DW_HDMI) += dw_hdmi.o +obj-$(CONFIG_VIDEO_DW_MIPI_DSI) += dw_mipi_dsi.o obj-$(CONFIG_VIDEO_EFI) += efi.o obj-$(CONFIG_VIDEO_FSL_DCU_FB) += fsl_dcu_fb.o videomodes.o obj-$(CONFIG_VIDEO_IPUV3) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o diff --git a/drivers/video/dw_mipi_dsi.c b/drivers/video/dw_mipi_dsi.c new file mode 100644 index 0000000..0fd6687 --- /dev/null +++ b/drivers/video/dw_mipi_dsi.c @@ -0,0 +1,827 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016, Fuzhou Rockchip Electronics Co., Ltd + * Copyright (C) 2018, STMicroelectronics - All Rights Reserved + * Author(s): Philippe Cornu philippe.cornu@st.com for STMicroelectronics. + * Yannick Fertre yannick.fertre@st.com for STMicroelectronics. + * + * This generic Synopsys DesignWare MIPI DSI host driver is inspired from + * the Linux Kernel driver drivers/gpu/drm/bridge/synopsys/dw-mipi-dsi.c. + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dw_mipi_dsi.h> +#include <errno.h> +#include <mipi_display.h> +#include <mipi_dsi.h> +#include <panel.h> +#include <video.h> +#include <video_bridge.h> +#include <asm/arch/gpio.h> +#include <asm/io.h> +#include <dm/device-internal.h> +#include <linux/iopoll.h> + +#define HWVER_131 0x31333100 /* IP version 1.31 */ + +#define DSI_VERSION 0x00 +#define VERSION GENMASK(31, 8) + +#define DSI_PWR_UP 0x04 +#define RESET 0 +#define POWERUP BIT(0) + +#define DSI_CLKMGR_CFG 0x08 +#define TO_CLK_DIVISION(div) (((div) & 0xff) << 8) +#define TX_ESC_CLK_DIVISION(div) ((div) & 0xff) + +#define DSI_DPI_VCID 0x0c +#define DPI_VCID(vcid) ((vcid) & 0x3) + +#define DSI_DPI_COLOR_CODING 0x10 +#define LOOSELY18_EN BIT(8) +#define DPI_COLOR_CODING_16BIT_1 0x0 +#define DPI_COLOR_CODING_16BIT_2 0x1 +#define DPI_COLOR_CODING_16BIT_3 0x2 +#define DPI_COLOR_CODING_18BIT_1 0x3 +#define DPI_COLOR_CODING_18BIT_2 0x4 +#define DPI_COLOR_CODING_24BIT 0x5 + +#define DSI_DPI_CFG_POL 0x14 +#define COLORM_ACTIVE_LOW BIT(4) +#define SHUTD_ACTIVE_LOW BIT(3) +#define HSYNC_ACTIVE_LOW BIT(2) +#define VSYNC_ACTIVE_LOW BIT(1) +#define DATAEN_ACTIVE_LOW BIT(0) + +#define DSI_DPI_LP_CMD_TIM 0x18 +#define OUTVACT_LPCMD_TIME(p) (((p) & 0xff) << 16) +#define INVACT_LPCMD_TIME(p) ((p) & 0xff) + +#define DSI_DBI_VCID 0x1c +#define DSI_DBI_CFG 0x20 +#define DSI_DBI_PARTITIONING_EN 0x24 +#define DSI_DBI_CMDSIZE 0x28 + +#define DSI_PCKHDL_CFG 0x2c +#define CRC_RX_EN BIT(4) +#define ECC_RX_EN BIT(3) +#define BTA_EN BIT(2) +#define EOTP_RX_EN BIT(1) +#define EOTP_TX_EN BIT(0) + +#define DSI_GEN_VCID 0x30 + +#define DSI_MODE_CFG 0x34 +#define ENABLE_VIDEO_MODE 0 +#define ENABLE_CMD_MODE BIT(0) + +#define DSI_VID_MODE_CFG 0x38 +#define ENABLE_LOW_POWER (0x3f << 8) +#define ENABLE_LOW_POWER_MASK (0x3f << 8) +#define VID_MODE_TYPE_NON_BURST_SYNC_PULSES 0x0 +#define VID_MODE_TYPE_NON_BURST_SYNC_EVENTS 0x1 +#define VID_MODE_TYPE_BURST 0x2 +#define VID_MODE_TYPE_MASK 0x3 + +#define DSI_VID_PKT_SIZE 0x3c +#define VID_PKT_SIZE(p) ((p) & 0x3fff) + +#define DSI_VID_NUM_CHUNKS 0x40 +#define VID_NUM_CHUNKS(c) ((c) & 0x1fff) + +#define DSI_VID_NULL_SIZE 0x44 +#define VID_NULL_SIZE(b) ((b) & 0x1fff) + +#define DSI_VID_HSA_TIME 0x48 +#define DSI_VID_HBP_TIME 0x4c +#define DSI_VID_HLINE_TIME 0x50 +#define DSI_VID_VSA_LINES 0x54 +#define DSI_VID_VBP_LINES 0x58 +#define DSI_VID_VFP_LINES 0x5c +#define DSI_VID_VACTIVE_LINES 0x60 +#define DSI_EDPI_CMD_SIZE 0x64 + +#define DSI_CMD_MODE_CFG 0x68 +#define MAX_RD_PKT_SIZE_LP BIT(24) +#define DCS_LW_TX_LP BIT(19) +#define DCS_SR_0P_TX_LP BIT(18) +#define DCS_SW_1P_TX_LP BIT(17) +#define DCS_SW_0P_TX_LP BIT(16) +#define GEN_LW_TX_LP BIT(14) +#define GEN_SR_2P_TX_LP BIT(13) +#define GEN_SR_1P_TX_LP BIT(12) +#define GEN_SR_0P_TX_LP BIT(11) +#define GEN_SW_2P_TX_LP BIT(10) +#define GEN_SW_1P_TX_LP BIT(9) +#define GEN_SW_0P_TX_LP BIT(8) +#define ACK_RQST_EN BIT(1) +#define TEAR_FX_EN BIT(0) + +#define CMD_MODE_ALL_LP (MAX_RD_PKT_SIZE_LP | \ + DCS_LW_TX_LP | \ + DCS_SR_0P_TX_LP | \ + DCS_SW_1P_TX_LP | \ + DCS_SW_0P_TX_LP | \ + GEN_LW_TX_LP | \ + GEN_SR_2P_TX_LP | \ + GEN_SR_1P_TX_LP | \ + GEN_SR_0P_TX_LP | \ + GEN_SW_2P_TX_LP | \ + GEN_SW_1P_TX_LP | \ + GEN_SW_0P_TX_LP) + +#define DSI_GEN_HDR 0x6c +#define DSI_GEN_PLD_DATA 0x70 + +#define DSI_CMD_PKT_STATUS 0x74 +#define GEN_RD_CMD_BUSY BIT(6) +#define GEN_PLD_R_FULL BIT(5) +#define GEN_PLD_R_EMPTY BIT(4) +#define GEN_PLD_W_FULL BIT(3) +#define GEN_PLD_W_EMPTY BIT(2) +#define GEN_CMD_FULL BIT(1) +#define GEN_CMD_EMPTY BIT(0) + +#define DSI_TO_CNT_CFG 0x78 +#define HSTX_TO_CNT(p) (((p) & 0xffff) << 16) +#define LPRX_TO_CNT(p) ((p) & 0xffff) + +#define DSI_HS_RD_TO_CNT 0x7c +#define DSI_LP_RD_TO_CNT 0x80 +#define DSI_HS_WR_TO_CNT 0x84 +#define DSI_LP_WR_TO_CNT 0x88 +#define DSI_BTA_TO_CNT 0x8c + +#define DSI_LPCLK_CTRL 0x94 +#define AUTO_CLKLANE_CTRL BIT(1) +#define PHY_TXREQUESTCLKHS BIT(0) + +#define DSI_PHY_TMR_LPCLK_CFG 0x98 +#define PHY_CLKHS2LP_TIME(lbcc) (((lbcc) & 0x3ff) << 16) +#define PHY_CLKLP2HS_TIME(lbcc) ((lbcc) & 0x3ff) + +#define DSI_PHY_TMR_CFG 0x9c +#define PHY_HS2LP_TIME(lbcc) (((lbcc) & 0xff) << 24) +#define PHY_LP2HS_TIME(lbcc) (((lbcc) & 0xff) << 16) +#define MAX_RD_TIME(lbcc) ((lbcc) & 0x7fff) +#define PHY_HS2LP_TIME_V131(lbcc) (((lbcc) & 0x3ff) << 16) +#define PHY_LP2HS_TIME_V131(lbcc) ((lbcc) & 0x3ff) + +#define DSI_PHY_RSTZ 0xa0 +#define PHY_DISFORCEPLL 0 +#define PHY_ENFORCEPLL BIT(3) +#define PHY_DISABLECLK 0 +#define PHY_ENABLECLK BIT(2) +#define PHY_RSTZ 0 +#define PHY_UNRSTZ BIT(1) +#define PHY_SHUTDOWNZ 0 +#define PHY_UNSHUTDOWNZ BIT(0) + +#define DSI_PHY_IF_CFG 0xa4 +#define PHY_STOP_WAIT_TIME(cycle) (((cycle) & 0xff) << 8) +#define N_LANES(n) (((n) - 1) & 0x3) + +#define DSI_PHY_ULPS_CTRL 0xa8 +#define DSI_PHY_TX_TRIGGERS 0xac + +#define DSI_PHY_STATUS 0xb0 +#define PHY_STOP_STATE_CLK_LANE BIT(2) +#define PHY_LOCK BIT(0) + +#define DSI_PHY_TST_CTRL0 0xb4 +#define PHY_TESTCLK BIT(1) +#define PHY_UNTESTCLK 0 +#define PHY_TESTCLR BIT(0) +#define PHY_UNTESTCLR 0 + +#define DSI_PHY_TST_CTRL1 0xb8 +#define PHY_TESTEN BIT(16) +#define PHY_UNTESTEN 0 +#define PHY_TESTDOUT(n) (((n) & 0xff) << 8) +#define PHY_TESTDIN(n) ((n) & 0xff) + +#define DSI_INT_ST0 0xbc +#define DSI_INT_ST1 0xc0 +#define DSI_INT_MSK0 0xc4 +#define DSI_INT_MSK1 0xc8 + +#define DSI_PHY_TMR_RD_CFG 0xf4 +#define MAX_RD_TIME_V131(lbcc) ((lbcc) & 0x7fff) + +#define PHY_STATUS_TIMEOUT_US 10000 +#define CMD_PKT_STATUS_TIMEOUT_US 20000 + +#define MSEC_PER_SEC 1000 + +struct dw_mipi_dsi { + struct mipi_dsi_host dsi_host; + struct mipi_dsi_device *device; + void __iomem *base; + unsigned int lane_mbps; /* per lane */ + u32 channel; + u32 lanes; + u32 format; + unsigned long mode_flags; + unsigned int max_data_lanes; + const struct dw_mipi_dsi_phy_ops *phy_ops; +}; + +static int dsi_mode_vrefresh(struct display_timing *timings) +{ + int refresh = 0; + unsigned int calc_val; + u32 htotal = timings->hactive.typ + timings->hfront_porch.typ + + timings->hback_porch.typ + timings->hsync_len.typ; + u32 vtotal = timings->vactive.typ + timings->vfront_porch.typ + + timings->vback_porch.typ + timings->vsync_len.typ; + + if (htotal > 0 && vtotal > 0) { + calc_val = timings->pixelclock.typ; + calc_val /= htotal; + refresh = (calc_val + vtotal / 2) / vtotal; + } + + return refresh; +} + +/* + * The controller should generate 2 frames before + * preparing the peripheral. + */ +static void dw_mipi_dsi_wait_for_two_frames(struct display_timing *timings) +{ + int refresh, two_frames; + + refresh = dsi_mode_vrefresh(timings); + two_frames = DIV_ROUND_UP(MSEC_PER_SEC, refresh) * 2; + mdelay(two_frames); +} + +static inline struct dw_mipi_dsi *host_to_dsi(struct mipi_dsi_host *host) +{ + return container_of(host, struct dw_mipi_dsi, dsi_host); +} + +static inline void dsi_write(struct dw_mipi_dsi *dsi, u32 reg, u32 val) +{ + writel(val, dsi->base + reg); +} + +static inline u32 dsi_read(struct dw_mipi_dsi *dsi, u32 reg) +{ + return readl(dsi->base + reg); +} + +static int dw_mipi_dsi_host_attach(struct mipi_dsi_host *host, + struct mipi_dsi_device *device) +{ + struct dw_mipi_dsi *dsi = host_to_dsi(host); + + if (device->lanes > dsi->max_data_lanes) { + dev_err(device->dev, + "the number of data lanes(%u) is too many\n", + device->lanes); + return -EINVAL; + } + + dsi->lanes = device->lanes; + dsi->channel = device->channel; + dsi->format = device->format; + dsi->mode_flags = device->mode_flags; + + return 0; +} + +static void dw_mipi_message_config(struct dw_mipi_dsi *dsi, + const struct mipi_dsi_msg *msg) +{ + bool lpm = msg->flags & MIPI_DSI_MSG_USE_LPM; + u32 val = 0; + + if (msg->flags & MIPI_DSI_MSG_REQ_ACK) + val |= ACK_RQST_EN; + if (lpm) + val |= CMD_MODE_ALL_LP; + + dsi_write(dsi, DSI_LPCLK_CTRL, lpm ? 0 : PHY_TXREQUESTCLKHS); + dsi_write(dsi, DSI_CMD_MODE_CFG, val); +} + +static int dw_mipi_dsi_gen_pkt_hdr_write(struct dw_mipi_dsi *dsi, u32 hdr_val) +{ + int ret; + u32 val, mask; + + ret = readl_poll_timeout(dsi->base + DSI_CMD_PKT_STATUS, + val, !(val & GEN_CMD_FULL), + CMD_PKT_STATUS_TIMEOUT_US); + if (ret) { + dev_err(dsi->dev, "failed to get available command FIFO\n"); + return ret; + } + + dsi_write(dsi, DSI_GEN_HDR, hdr_val); + + mask = GEN_CMD_EMPTY | GEN_PLD_W_EMPTY; + ret = readl_poll_timeout(dsi->base + DSI_CMD_PKT_STATUS, + val, (val & mask) == mask, + CMD_PKT_STATUS_TIMEOUT_US); + if (ret) { + dev_err(dsi->dev, "failed to write command FIFO\n"); + return ret; + } + + return 0; +} + +static int dw_mipi_dsi_write(struct dw_mipi_dsi *dsi, + const struct mipi_dsi_packet *packet) +{ + const u8 *tx_buf = packet->payload; + int len = packet->payload_length, pld_data_bytes = sizeof(u32), ret; + __le32 word; + u32 val; + + while (len) { + if (len < pld_data_bytes) { + word = 0; + memcpy(&word, tx_buf, len); + dsi_write(dsi, DSI_GEN_PLD_DATA, le32_to_cpu(word)); + len = 0; + } else { + memcpy(&word, tx_buf, pld_data_bytes); + dsi_write(dsi, DSI_GEN_PLD_DATA, le32_to_cpu(word)); + tx_buf += pld_data_bytes; + len -= pld_data_bytes; + } + + ret = readl_poll_timeout(dsi->base + DSI_CMD_PKT_STATUS, + val, !(val & GEN_PLD_W_FULL), + CMD_PKT_STATUS_TIMEOUT_US); + if (ret) { + dev_err(dsi->dev, + "failed to get available write payload FIFO\n"); + return ret; + } + } + + word = 0; + memcpy(&word, packet->header, sizeof(packet->header)); + return dw_mipi_dsi_gen_pkt_hdr_write(dsi, le32_to_cpu(word)); +} + +static int dw_mipi_dsi_read(struct dw_mipi_dsi *dsi, + const struct mipi_dsi_msg *msg) +{ + int i, j, ret, len = msg->rx_len; + u8 *buf = msg->rx_buf; + u32 val; + + /* Wait end of the read operation */ + ret = readl_poll_timeout(dsi->base + DSI_CMD_PKT_STATUS, + val, !(val & GEN_RD_CMD_BUSY), + CMD_PKT_STATUS_TIMEOUT_US); + if (ret) { + dev_err(dsi->dev, "Timeout during read operation\n"); + return ret; + } + + for (i = 0; i < len; i += 4) { + /* Read fifo must not be empty before all bytes are read */ + ret = readl_poll_timeout(dsi->base + DSI_CMD_PKT_STATUS, + val, !(val & GEN_PLD_R_EMPTY), + CMD_PKT_STATUS_TIMEOUT_US); + if (ret) { + dev_err(dsi->dev, "Read payload FIFO is empty\n"); + return ret; + } + + val = dsi_read(dsi, DSI_GEN_PLD_DATA); + for (j = 0; j < 4 && j + i < len; j++) + buf[i + j] = val >> (8 * j); + } + + return ret; +} + +static ssize_t dw_mipi_dsi_host_transfer(struct mipi_dsi_host *host, + const struct mipi_dsi_msg *msg) +{ + struct dw_mipi_dsi *dsi = host_to_dsi(host); + struct mipi_dsi_packet packet; + int ret, nb_bytes; + + ret = mipi_dsi_create_packet(&packet, msg); + if (ret) { + dev_err(dsi->dev, "failed to create packet: %d\n", ret); + return ret; + } + + dw_mipi_message_config(dsi, msg); + + ret = dw_mipi_dsi_write(dsi, &packet); + if (ret) + return ret; + + if (msg->rx_buf && msg->rx_len) { + ret = dw_mipi_dsi_read(dsi, msg); + if (ret) + return ret; + nb_bytes = msg->rx_len; + } else { + nb_bytes = packet.size; + } + + return nb_bytes; +} + +static const struct mipi_dsi_host_ops dw_mipi_dsi_host_ops = { + .attach = dw_mipi_dsi_host_attach, + .transfer = dw_mipi_dsi_host_transfer, +}; + +static void dw_mipi_dsi_video_mode_config(struct dw_mipi_dsi *dsi) +{ + u32 val; + + /* + * TODO dw drv improvements + * enabling low power is panel-dependent, we should use the + * panel configuration here... + */ + val = ENABLE_LOW_POWER; + + if (dsi->mode_flags & MIPI_DSI_MODE_VIDEO_BURST) + val |= VID_MODE_TYPE_BURST; + else if (dsi->mode_flags & MIPI_DSI_MODE_VIDEO_SYNC_PULSE) + val |= VID_MODE_TYPE_NON_BURST_SYNC_PULSES; + else + val |= VID_MODE_TYPE_NON_BURST_SYNC_EVENTS; + + dsi_write(dsi, DSI_VID_MODE_CFG, val); +} + +static void dw_mipi_dsi_set_mode(struct dw_mipi_dsi *dsi, + unsigned long mode_flags) +{ + dsi_write(dsi, DSI_PWR_UP, RESET); + + if (mode_flags & MIPI_DSI_MODE_VIDEO) { + dsi_write(dsi, DSI_MODE_CFG, ENABLE_VIDEO_MODE); + dw_mipi_dsi_video_mode_config(dsi); + dsi_write(dsi, DSI_LPCLK_CTRL, PHY_TXREQUESTCLKHS); + } else { + dsi_write(dsi, DSI_MODE_CFG, ENABLE_CMD_MODE); + } + + dsi_write(dsi, DSI_PWR_UP, POWERUP); +} + +static void dw_mipi_dsi_init(struct dw_mipi_dsi *dsi) +{ + /* + * The maximum permitted escape clock is 20MHz and it is derived from + * lanebyteclk, which is running at "lane_mbps / 8". Thus we want: + * + * (lane_mbps >> 3) / esc_clk_division < 20 + * which is: + * (lane_mbps >> 3) / 20 > esc_clk_division + */ + u32 esc_clk_division = (dsi->lane_mbps >> 3) / 20 + 1; + + dsi_write(dsi, DSI_PWR_UP, RESET); + + /* + * TODO dw drv improvements + * timeout clock division should be computed with the + * high speed transmission counter timeout and byte lane... + */ + dsi_write(dsi, DSI_CLKMGR_CFG, TO_CLK_DIVISION(10) | + TX_ESC_CLK_DIVISION(esc_clk_division)); +} + +static void dw_mipi_dsi_dpi_config(struct dw_mipi_dsi *dsi, + struct display_timing *timings) +{ + u32 val = 0, color = 0; + + switch (dsi->format) { + case MIPI_DSI_FMT_RGB888: + color = DPI_COLOR_CODING_24BIT; + break; + case MIPI_DSI_FMT_RGB666: + color = DPI_COLOR_CODING_18BIT_2 | LOOSELY18_EN; + break; + case MIPI_DSI_FMT_RGB666_PACKED: + color = DPI_COLOR_CODING_18BIT_1; + break; + case MIPI_DSI_FMT_RGB565: + color = DPI_COLOR_CODING_16BIT_1; + break; + } + + if (dsi->mode_flags & DISPLAY_FLAGS_VSYNC_HIGH) + val |= VSYNC_ACTIVE_LOW; + if (dsi->mode_flags & DISPLAY_FLAGS_HSYNC_HIGH) + val |= HSYNC_ACTIVE_LOW; + + dsi_write(dsi, DSI_DPI_VCID, DPI_VCID(dsi->channel)); + dsi_write(dsi, DSI_DPI_COLOR_CODING, color); + dsi_write(dsi, DSI_DPI_CFG_POL, val); + /* + * TODO dw drv improvements + * largest packet sizes during hfp or during vsa/vpb/vfp + * should be computed according to byte lane, lane number and only + * if sending lp cmds in high speed is enable (PHY_TXREQUESTCLKHS) + */ + dsi_write(dsi, DSI_DPI_LP_CMD_TIM, OUTVACT_LPCMD_TIME(4) + | INVACT_LPCMD_TIME(4)); +} + +static void dw_mipi_dsi_packet_handler_config(struct dw_mipi_dsi *dsi) +{ + dsi_write(dsi, DSI_PCKHDL_CFG, CRC_RX_EN | ECC_RX_EN | BTA_EN); +} + +static void dw_mipi_dsi_video_packet_config(struct dw_mipi_dsi *dsi, + struct display_timing *timings) +{ + /* + * TODO dw drv improvements + * only burst mode is supported here. For non-burst video modes, + * we should compute DSI_VID_PKT_SIZE, DSI_VCCR.NUMC & + * DSI_VNPCR.NPSIZE... especially because this driver supports + * non-burst video modes, see dw_mipi_dsi_video_mode_config()... + */ + dsi_write(dsi, DSI_VID_PKT_SIZE, VID_PKT_SIZE(timings->hactive.typ)); +} + +static void dw_mipi_dsi_command_mode_config(struct dw_mipi_dsi *dsi) +{ + /* + * TODO dw drv improvements + * compute high speed transmission counter timeout according + * to the timeout clock division (TO_CLK_DIVISION) and byte lane... + */ + dsi_write(dsi, DSI_TO_CNT_CFG, HSTX_TO_CNT(1000) | LPRX_TO_CNT(1000)); + /* + * TODO dw drv improvements + * the Bus-Turn-Around Timeout Counter should be computed + * according to byte lane... + */ + dsi_write(dsi, DSI_BTA_TO_CNT, 0xd00); + dsi_write(dsi, DSI_MODE_CFG, ENABLE_CMD_MODE); +} + +/* Get lane byte clock cycles. */ +static u32 dw_mipi_dsi_get_hcomponent_lbcc(struct dw_mipi_dsi *dsi, + struct display_timing *timings, + u32 hcomponent) +{ + u32 frac, lbcc; + + lbcc = hcomponent * dsi->lane_mbps * MSEC_PER_SEC / 8; + + frac = lbcc % (timings->pixelclock.typ / 1000); + lbcc = lbcc / (timings->pixelclock.typ / 1000); + if (frac) + lbcc++; + + return lbcc; +} + +static void dw_mipi_dsi_line_timer_config(struct dw_mipi_dsi *dsi, + struct display_timing *timings) +{ + u32 htotal, hsa, hbp, lbcc; + + htotal = timings->hactive.typ + timings->hfront_porch.typ + + timings->hback_porch.typ + timings->hsync_len.typ; + + hsa = timings->hback_porch.typ; + hbp = timings->hsync_len.typ; + + /* + * TODO dw drv improvements + * computations below may be improved... + */ + lbcc = dw_mipi_dsi_get_hcomponent_lbcc(dsi, timings, htotal); + dsi_write(dsi, DSI_VID_HLINE_TIME, lbcc); + + lbcc = dw_mipi_dsi_get_hcomponent_lbcc(dsi, timings, hsa); + dsi_write(dsi, DSI_VID_HSA_TIME, lbcc); + + lbcc = dw_mipi_dsi_get_hcomponent_lbcc(dsi, timings, hbp); + dsi_write(dsi, DSI_VID_HBP_TIME, lbcc); +} + +static void dw_mipi_dsi_vertical_timing_config(struct dw_mipi_dsi *dsi, + struct display_timing *timings) +{ + u32 vactive, vsa, vfp, vbp; + + vactive = timings->vactive.typ; + vsa = timings->vback_porch.typ; + vfp = timings->vfront_porch.typ; + vbp = timings->vsync_len.typ; + + dsi_write(dsi, DSI_VID_VACTIVE_LINES, vactive); + dsi_write(dsi, DSI_VID_VSA_LINES, vsa); + dsi_write(dsi, DSI_VID_VFP_LINES, vfp); + dsi_write(dsi, DSI_VID_VBP_LINES, vbp); +} + +static void dw_mipi_dsi_dphy_timing_config(struct dw_mipi_dsi *dsi) +{ + u32 hw_version; + + /* + * TODO dw drv improvements + * data & clock lane timers should be computed according to panel + * blankings and to the automatic clock lane control mode... + * note: DSI_PHY_TMR_CFG.MAX_RD_TIME should be in line with + * DSI_CMD_MODE_CFG.MAX_RD_PKT_SIZE_LP (see CMD_MODE_ALL_LP) + */ + + hw_version = dsi_read(dsi, DSI_VERSION) & VERSION; + + if (hw_version >= HWVER_131) { + dsi_write(dsi, DSI_PHY_TMR_CFG, PHY_HS2LP_TIME_V131(0x40) | + PHY_LP2HS_TIME_V131(0x40)); + dsi_write(dsi, DSI_PHY_TMR_RD_CFG, MAX_RD_TIME_V131(10000)); + } else { + dsi_write(dsi, DSI_PHY_TMR_CFG, PHY_HS2LP_TIME(0x40) | + PHY_LP2HS_TIME(0x40) | MAX_RD_TIME(10000)); + } + + dsi_write(dsi, DSI_PHY_TMR_LPCLK_CFG, PHY_CLKHS2LP_TIME(0x40) + | PHY_CLKLP2HS_TIME(0x40)); +} + +static void dw_mipi_dsi_dphy_interface_config(struct dw_mipi_dsi *dsi) +{ + /* + * TODO dw drv improvements + * stop wait time should be the maximum between host dsi + * and panel stop wait times + */ + dsi_write(dsi, DSI_PHY_IF_CFG, PHY_STOP_WAIT_TIME(0x20) | + N_LANES(dsi->lanes)); +} + +static void dw_mipi_dsi_dphy_init(struct dw_mipi_dsi *dsi) +{ + /* Clear PHY state */ + dsi_write(dsi, DSI_PHY_RSTZ, PHY_DISFORCEPLL | PHY_DISABLECLK + | PHY_RSTZ | PHY_SHUTDOWNZ); + dsi_write(dsi, DSI_PHY_TST_CTRL0, PHY_UNTESTCLR); + dsi_write(dsi, DSI_PHY_TST_CTRL0, PHY_TESTCLR); + dsi_write(dsi, DSI_PHY_TST_CTRL0, PHY_UNTESTCLR); +} + +static void dw_mipi_dsi_dphy_enable(struct dw_mipi_dsi *dsi) +{ + u32 val; + int ret; + + dsi_write(dsi, DSI_PHY_RSTZ, PHY_ENFORCEPLL | PHY_ENABLECLK | + PHY_UNRSTZ | PHY_UNSHUTDOWNZ); + + ret = readl_poll_timeout(dsi->base + DSI_PHY_STATUS, val, + val & PHY_LOCK, PHY_STATUS_TIMEOUT_US); + if (ret) + dev_warn(dsi->dev, "failed to wait phy lock state\n"); + + ret = readl_poll_timeout(dsi->base + DSI_PHY_STATUS, + val, val & PHY_STOP_STATE_CLK_LANE, + PHY_STATUS_TIMEOUT_US); + if (ret) + dev_warn(dsi->dev, "failed to wait phy clk lane stop state\n"); +} + +static void dw_mipi_dsi_clear_err(struct dw_mipi_dsi *dsi) +{ + dsi_read(dsi, DSI_INT_ST0); + dsi_read(dsi, DSI_INT_ST1); + dsi_write(dsi, DSI_INT_MSK0, 0); + dsi_write(dsi, DSI_INT_MSK1, 0); +} + +static void dw_mipi_dsi_bridge_set(struct dw_mipi_dsi *dsi, + struct display_timing *timings) +{ + const struct dw_mipi_dsi_phy_ops *phy_ops = dsi->phy_ops; + int ret; + + ret = phy_ops->get_lane_mbps(dsi->device, timings, dsi->lanes, + dsi->format, &dsi->lane_mbps); + if (ret) + dev_warn(dsi->dev, "Phy get_lane_mbps() failed\n"); + + dw_mipi_dsi_init(dsi); + dw_mipi_dsi_dpi_config(dsi, timings); + dw_mipi_dsi_packet_handler_config(dsi); + dw_mipi_dsi_video_mode_config(dsi); + dw_mipi_dsi_video_packet_config(dsi, timings); + dw_mipi_dsi_command_mode_config(dsi); + dw_mipi_dsi_line_timer_config(dsi, timings); + dw_mipi_dsi_vertical_timing_config(dsi, timings); + + dw_mipi_dsi_dphy_init(dsi); + dw_mipi_dsi_dphy_timing_config(dsi); + dw_mipi_dsi_dphy_interface_config(dsi); + + dw_mipi_dsi_clear_err(dsi); + + ret = phy_ops->init(dsi->device); + if (ret) + dev_warn(dsi->dev, "Phy init() failed\n"); + + dw_mipi_dsi_dphy_enable(dsi); + + dw_mipi_dsi_wait_for_two_frames(timings); + + /* Switch to cmd mode for panel-bridge pre_enable & panel prepare */ + dw_mipi_dsi_set_mode(dsi, 0); +} + +void dw_mipi_dsi_bridge_enable(struct mipi_dsi_device *device) +{ + struct mipi_dsi_host *host = device->host; + struct dw_mipi_dsi *dsi = host_to_dsi(host); + + /* Switch to video mode for panel-bridge enable & panel enable */ + dw_mipi_dsi_set_mode(dsi, MIPI_DSI_MODE_VIDEO); +} +EXPORT_SYMBOL_GPL(dw_mipi_dsi_bridge_enable); + +int dw_mipi_dsi_init_bridge(struct mipi_dsi_device *device) +{ + struct dw_mipi_dsi_plat_data *platdata = dev_get_platdata(device->dev); + struct udevice *panel = platdata->panel; + struct display_timing timings; + struct dw_mipi_dsi *dsi; + struct clk clk; + int ret; + + dsi = kzalloc(sizeof(*dsi), GFP_KERNEL); + + dsi->phy_ops = platdata->phy_ops; + dsi->max_data_lanes = platdata->max_data_lanes; + dsi->device = device; + dsi->dsi_host.ops = &dw_mipi_dsi_host_ops; + device->host = &dsi->dsi_host; + + /* TODO Get these settings from panel */ + dsi->lanes = 2; + dsi->format = MIPI_DSI_FMT_RGB888; + dsi->mode_flags = MIPI_DSI_MODE_VIDEO | + MIPI_DSI_MODE_VIDEO_BURST | + MIPI_DSI_MODE_LPM; + + dsi->base = (void *)dev_read_addr(device->dev); + if ((fdt_addr_t)dsi->base == FDT_ADDR_T_NONE) { + dev_err(device->dev, "dsi dt register address error\n"); + return -EINVAL; + } + + ret = panel_get_display_timing(panel, &timings); + if (ret) { + ret = fdtdec_decode_display_timing(gd->fdt_blob, + dev_of_offset(panel), + 0, &timings); + if (ret) { + dev_err(dev, "decode display timing error %d\n", ret); + return ret; + } + } + + if (!dsi->phy_ops->init || !dsi->phy_ops->get_lane_mbps) { + dev_err(device->dev, "Phy not properly configured\n"); + return -ENODEV; + } + + ret = clk_get_by_name(device->dev, "px_clk", &clk); + if (ret) { + dev_err(device->dev, "peripheral clock get error %d\n", ret); + return ret; + } + + /* get the pixel clock set by the clock framework */ + timings.pixelclock.typ = clk_get_rate(&clk); + + dw_mipi_dsi_bridge_set(dsi, &timings); + + return 0; +} +EXPORT_SYMBOL_GPL(dw_mipi_dsi_init_bridge); + +MODULE_AUTHOR("Chris Zhong zyw@rock-chips.com"); +MODULE_AUTHOR("Philippe Cornu philippe.cornu@st.com"); +MODULE_AUTHOR("Yannick Fertré yannick.fertre@st.com"); +MODULE_DESCRIPTION("DW MIPI DSI host controller driver"); +MODULE_LICENSE("GPL"); +MODULE_ALIAS("platform:dw-mipi-dsi"); diff --git a/include/dw_mipi_dsi.h b/include/dw_mipi_dsi.h new file mode 100644 index 0000000..3a649c0 --- /dev/null +++ b/include/dw_mipi_dsi.h @@ -0,0 +1,33 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2017-2018, STMicroelectronics - All Rights Reserved + * + * Authors: Yannick Fertre yannick.fertre@st.com + * Philippe Cornu philippe.cornu@st.com + * + * This generic Synopsys DesignWare MIPI DSI host include is inspired from + * the Linux Kernel include file include/drm/bridge/dw_mipi_dsi.h. + */ + +#ifndef __DW_MIPI_DSI__ +#define __DW_MIPI_DSI__ + +#include <mipi_display.h> +#include <mipi_dsi.h> + +struct dw_mipi_dsi_phy_ops { + int (*init)(void *priv_data); + int (*get_lane_mbps)(void *priv_data, struct display_timing *timings, + u32 lanes, u32 format, unsigned int *lane_mbps); +}; + +struct dw_mipi_dsi_plat_data { + unsigned int max_data_lanes; + const struct dw_mipi_dsi_phy_ops *phy_ops; + struct udevice *panel; +}; + +int dw_mipi_dsi_init_bridge(struct mipi_dsi_device *device); +void dw_mipi_dsi_bridge_enable(struct mipi_dsi_device *device); + +#endif /* __DW_MIPI_DSI__ */
This needs to use driver model. E.g. add your operations as a uclass and go from there.
Add the STM32 DSI controller driver that uses the Synopsys DesignWare MIPI DSI host controller bridge.
Signed-off-by: Yannick Fertré yannick.fertre@st.com --- drivers/video/stm32/Kconfig | 10 + drivers/video/stm32/Makefile | 1 + drivers/video/stm32/stm32_dsi.c | 428 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 439 insertions(+) create mode 100644 drivers/video/stm32/stm32_dsi.c
diff --git a/drivers/video/stm32/Kconfig b/drivers/video/stm32/Kconfig index 78b1fac..5b5e2c4 100644 --- a/drivers/video/stm32/Kconfig +++ b/drivers/video/stm32/Kconfig @@ -13,6 +13,16 @@ menuconfig VIDEO_STM32 DSI. This option enables these supports which can be used on devices which have RGB TFT or DSI display connected.
+config VIDEO_STM32_DSI + bool "Enable STM32 DSI video support" + depends on VIDEO_STM32 + select VIDEO_MIPI_DSI + select VIDEO_BRIDGE + select VIDEO_DW_MIPI_DSI + help + This option enables support DSI internal bridge which can be used on + devices which have DSI devices connected. + config VIDEO_STM32_MAX_XRES int "Maximum horizontal resolution (for memory allocation purposes)" depends on VIDEO_STM32 diff --git a/drivers/video/stm32/Makefile b/drivers/video/stm32/Makefile index 7297e5f..f8b42d1 100644 --- a/drivers/video/stm32/Makefile +++ b/drivers/video/stm32/Makefile @@ -6,3 +6,4 @@ # Yannick Fertre yannick.fertre@st.com
obj-${CONFIG_VIDEO_STM32} = stm32_ltdc.o +obj-${CONFIG_VIDEO_STM32_DSI} += stm32_dsi.o diff --git a/drivers/video/stm32/stm32_dsi.c b/drivers/video/stm32/stm32_dsi.c new file mode 100644 index 0000000..b7feb64 --- /dev/null +++ b/drivers/video/stm32/stm32_dsi.c @@ -0,0 +1,428 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 STMicroelectronics - All Rights Reserved + * Author(s): Philippe Cornu philippe.cornu@st.com for STMicroelectronics. + * Yannick Fertre yannick.fertre@st.com for STMicroelectronics. + * + * This MIPI DSI controller driver is inspired from the Linux Kernel driver + * drivers/gpu/drm/stm/dw_mipi_dsi-stm.c. + */ +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dw_mipi_dsi.h> +#include <mipi_display.h> +#include <mipi_dsi.h> +#include <panel.h> +#include <reset.h> +#include <video.h> +#include <video_bridge.h> +#include <asm/io.h> +#include <asm/arch/gpio.h> +#include <dm/device-internal.h> +#include <linux/iopoll.h> + +#define HWVER_130 0x31333000 /* IP version 1.30 */ +#define HWVER_131 0x31333100 /* IP version 1.31 */ + +/* DSI digital registers & bit definitions */ +#define DSI_VERSION 0x00 +#define VERSION GENMASK(31, 8) + +/* + * DSI wrapper registers & bit definitions + * Note: registers are named as in the Reference Manual + */ +#define DSI_WCFGR 0x0400 /* Wrapper ConFiGuration Reg */ +#define WCFGR_DSIM BIT(0) /* DSI Mode */ +#define WCFGR_COLMUX GENMASK(3, 1) /* COLor MUltipleXing */ + +#define DSI_WCR 0x0404 /* Wrapper Control Reg */ +#define WCR_DSIEN BIT(3) /* DSI ENable */ + +#define DSI_WISR 0x040C /* Wrapper Interrupt and Status Reg */ +#define WISR_PLLLS BIT(8) /* PLL Lock Status */ +#define WISR_RRS BIT(12) /* Regulator Ready Status */ + +#define DSI_WPCR0 0x0418 /* Wrapper Phy Conf Reg 0 */ +#define WPCR0_UIX4 GENMASK(5, 0) /* Unit Interval X 4 */ +#define WPCR0_TDDL BIT(16) /* Turn Disable Data Lanes */ + +#define DSI_WRPCR 0x0430 /* Wrapper Regulator & Pll Ctrl Reg */ +#define WRPCR_PLLEN BIT(0) /* PLL ENable */ +#define WRPCR_NDIV GENMASK(8, 2) /* pll loop DIVision Factor */ +#define WRPCR_IDF GENMASK(14, 11) /* pll Input Division Factor */ +#define WRPCR_ODF GENMASK(17, 16) /* pll Output Division Factor */ +#define WRPCR_REGEN BIT(24) /* REGulator ENable */ +#define WRPCR_BGREN BIT(28) /* BandGap Reference ENable */ +#define IDF_MIN 1 +#define IDF_MAX 7 +#define NDIV_MIN 10 +#define NDIV_MAX 125 +#define ODF_MIN 1 +#define ODF_MAX 8 + +/* dsi color format coding according to the datasheet */ +enum dsi_color { + DSI_RGB565_CONF1, + DSI_RGB565_CONF2, + DSI_RGB565_CONF3, + DSI_RGB666_CONF1, + DSI_RGB666_CONF2, + DSI_RGB888, +}; + +#define LANE_MIN_KBPS 31250 +#define LANE_MAX_KBPS 500000 + +/* Timeout for regulator on/off, pll lock/unlock & fifo empty */ +#define TIMEOUT_US 200000 + +struct stm32_dsi_priv { + struct mipi_dsi_device device; + void __iomem *base; + struct udevice *panel; + u32 pllref_clk; + u32 hw_version; + int lane_min_kbps; + int lane_max_kbps; +}; + +static inline void dsi_write(struct stm32_dsi_priv *dsi, u32 reg, u32 val) +{ + writel(val, dsi->base + reg); +} + +static inline u32 dsi_read(struct stm32_dsi_priv *dsi, u32 reg) +{ + return readl(dsi->base + reg); +} + +static inline void dsi_set(struct stm32_dsi_priv *dsi, u32 reg, u32 mask) +{ + dsi_write(dsi, reg, dsi_read(dsi, reg) | mask); +} + +static inline void dsi_clear(struct stm32_dsi_priv *dsi, u32 reg, u32 mask) +{ + dsi_write(dsi, reg, dsi_read(dsi, reg) & ~mask); +} + +static inline void dsi_update_bits(struct stm32_dsi_priv *dsi, u32 reg, + u32 mask, u32 val) +{ + dsi_write(dsi, reg, (dsi_read(dsi, reg) & ~mask) | val); +} + +static enum dsi_color dsi_color_from_mipi(u32 fmt) +{ + switch (fmt) { + case MIPI_DSI_FMT_RGB888: + return DSI_RGB888; + case MIPI_DSI_FMT_RGB666: + return DSI_RGB666_CONF2; + case MIPI_DSI_FMT_RGB666_PACKED: + return DSI_RGB666_CONF1; + case MIPI_DSI_FMT_RGB565: + return DSI_RGB565_CONF1; + default: + pr_err("MIPI color invalid, so we use rgb888\n"); + } + return DSI_RGB888; +} + +static int dsi_pll_get_clkout_khz(int clkin_khz, int idf, int ndiv, int odf) +{ + int divisor = idf * odf; + + /* prevent from division by 0 */ + if (!divisor) + return 0; + + return DIV_ROUND_CLOSEST(clkin_khz * ndiv, divisor); +} + +static int dsi_pll_get_params(struct stm32_dsi_priv *dsi, + int clkin_khz, int clkout_khz, + int *idf, int *ndiv, int *odf) +{ + int i, o, n, n_min, n_max; + int fvco_min, fvco_max, delta, best_delta; /* all in khz */ + + /* Early checks preventing division by 0 & odd results */ + if (clkin_khz <= 0 || clkout_khz <= 0) + return -EINVAL; + + fvco_min = dsi->lane_min_kbps * 2 * ODF_MAX; + fvco_max = dsi->lane_max_kbps * 2 * ODF_MIN; + + best_delta = 1000000; /* big started value (1000000khz) */ + + for (i = IDF_MIN; i <= IDF_MAX; i++) { + /* Compute ndiv range according to Fvco */ + n_min = ((fvco_min * i) / (2 * clkin_khz)) + 1; + n_max = (fvco_max * i) / (2 * clkin_khz); + + /* No need to continue idf loop if we reach ndiv max */ + if (n_min >= NDIV_MAX) + break; + + /* Clamp ndiv to valid values */ + if (n_min < NDIV_MIN) + n_min = NDIV_MIN; + if (n_max > NDIV_MAX) + n_max = NDIV_MAX; + + for (o = ODF_MIN; o <= ODF_MAX; o *= 2) { + n = DIV_ROUND_CLOSEST(i * o * clkout_khz, clkin_khz); + /* Check ndiv according to vco range */ + if (n < n_min || n > n_max) + continue; + /* Check if new delta is better & saves parameters */ + delta = dsi_pll_get_clkout_khz(clkin_khz, i, n, o) - + clkout_khz; + if (delta < 0) + delta = -delta; + if (delta < best_delta) { + *idf = i; + *ndiv = n; + *odf = o; + best_delta = delta; + } + /* fast return in case of "perfect result" */ + if (!delta) + return 0; + } + } + + return 0; +} + +static int dsi_phy_init(void *priv_data) +{ + struct mipi_dsi_device *device = priv_data; + struct udevice *dev = device->dev; + struct stm32_dsi_priv *dsi = dev_get_priv(dev); + u32 val; + int ret; + + /* Enable the regulator */ + dsi_set(dsi, DSI_WRPCR, WRPCR_REGEN | WRPCR_BGREN); + ret = readl_poll_timeout(dsi->base + DSI_WISR, val, val & WISR_RRS, + TIMEOUT_US); + if (ret) { + dev_err(dev, "!TIMEOUT! waiting REGU\n"); + return ret; + } + + /* Enable the DSI PLL & wait for its lock */ + dsi_set(dsi, DSI_WRPCR, WRPCR_PLLEN); + ret = readl_poll_timeout(dsi->base + DSI_WISR, val, val & WISR_PLLLS, + TIMEOUT_US); + if (ret) { + dev_err(dev, "!TIMEOUT! waiting PLL\n"); + return ret; + } + + /* Enable the DSI wrapper */ + dsi_set(dsi, DSI_WCR, WCR_DSIEN); + + return 0; +} + +static int dsi_get_lane_mbps(void *priv_data, struct display_timing *timings, + u32 lanes, u32 format, unsigned int *lane_mbps) +{ + struct mipi_dsi_device *device = priv_data; + struct udevice *dev = device->dev; + struct stm32_dsi_priv *dsi = dev_get_priv(dev); + int idf, ndiv, odf, pll_in_khz, pll_out_khz; + int ret, bpp; + u32 val; + + /* Update lane capabilities according to hw version */ + dsi->hw_version = dsi_read(dsi, DSI_VERSION) & VERSION; + dsi->lane_min_kbps = LANE_MIN_KBPS; + dsi->lane_max_kbps = LANE_MAX_KBPS; + if (dsi->hw_version == HWVER_131) { + dsi->lane_min_kbps *= 2; + dsi->lane_max_kbps *= 2; + } + + pll_in_khz = dsi->pllref_clk / 1000; + + /* Compute requested pll out */ + bpp = mipi_dsi_pixel_format_to_bpp(format); + pll_out_khz = (timings->pixelclock.typ / 1000) * bpp / lanes; + /* Add 20% to pll out to be higher than pixel bw (burst mode only) */ + pll_out_khz = (pll_out_khz * 12) / 10; + if (pll_out_khz > dsi->lane_max_kbps) { + pll_out_khz = dsi->lane_max_kbps; + dev_warn(dev, "Warning max phy mbps is used\n"); + } + if (pll_out_khz < dsi->lane_min_kbps) { + pll_out_khz = dsi->lane_min_kbps; + dev_warn(dev, "Warning min phy mbps is used\n"); + } + + /* Compute best pll parameters */ + idf = 0; + ndiv = 0; + odf = 0; + ret = dsi_pll_get_params(dsi, pll_in_khz, pll_out_khz, + &idf, &ndiv, &odf); + if (ret) { + dev_err(dev, "Warning dsi_pll_get_params(): bad params\n"); + return ret; + } + + /* Get the adjusted pll out value */ + pll_out_khz = dsi_pll_get_clkout_khz(pll_in_khz, idf, ndiv, odf); + + /* Set the PLL division factors */ + dsi_update_bits(dsi, DSI_WRPCR, WRPCR_NDIV | WRPCR_IDF | WRPCR_ODF, + (ndiv << 2) | (idf << 11) | ((ffs(odf) - 1) << 16)); + + /* Compute uix4 & set the bit period in high-speed mode */ + val = 4000000 / pll_out_khz; + dsi_update_bits(dsi, DSI_WPCR0, WPCR0_UIX4, val); + + /* Select video mode by resetting DSIM bit */ + dsi_clear(dsi, DSI_WCFGR, WCFGR_DSIM); + + /* Select the color coding */ + dsi_update_bits(dsi, DSI_WCFGR, WCFGR_COLMUX, + dsi_color_from_mipi(format) << 1); + + *lane_mbps = pll_out_khz / 1000; + + debug("pll_in %ukHz pll_out %ukHz lane_mbps %uMHz\n", + pll_in_khz, pll_out_khz, *lane_mbps); + + return 0; +} + +static const struct dw_mipi_dsi_phy_ops dsi_stm_phy_ops = { + .init = dsi_phy_init, + .get_lane_mbps = dsi_get_lane_mbps, +}; + +static int stm32_dsi_attach(struct udevice *dev) +{ + struct stm32_dsi_priv *priv = dev_get_priv(dev); + struct dw_mipi_dsi_plat_data *platdata = dev_get_platdata(dev); + struct mipi_dsi_device *device = &priv->device; + int ret; + + platdata->max_data_lanes = 2; + platdata->phy_ops = &dsi_stm_phy_ops; + + ret = uclass_first_device(UCLASS_PANEL, &platdata->panel); + if (ret) { + dev_err(dev, "panel device error %d\n", ret); + return ret; + } + + ret = dw_mipi_dsi_init_bridge(device); + if (ret) { + dev_err(dev, "failed to initialize mipi dsi host\n"); + return ret; + } + + return 0; +} + +static int stm32_dsi_set_backlight(struct udevice *dev, int percent) +{ + struct dw_mipi_dsi_plat_data *dplat = dev_get_platdata(dev); + struct stm32_dsi_priv *priv = dev_get_priv(dev); + struct mipi_dsi_device *device = &priv->device; + struct udevice *panel = dplat->panel; + struct mipi_dsi_panel_plat *mplat; + int ret; + + mplat = dev_get_platdata(panel); + mplat->device = device; + + ret = panel_enable_backlight(panel); + if (ret) { + dev_err(dev, "panel %s enable backlight error %d\n", + panel->name, ret); + return ret; + } + + dw_mipi_dsi_bridge_enable(device); + + return 0; +} + +static int stm32_dsi_probe(struct udevice *dev) +{ + struct stm32_dsi_priv *priv = dev_get_priv(dev); + struct mipi_dsi_device *device = &priv->device; + struct reset_ctl rst; + struct clk clk; + int ret; + + device->dev = dev; + + priv->base = (void *)dev_read_addr(dev); + if ((fdt_addr_t)priv->base == FDT_ADDR_T_NONE) { + dev_err(dev, "dsi dt register address error\n"); + return -EINVAL; + } + + ret = clk_get_by_name(device->dev, "pclk", &clk); + if (ret) { + dev_err(dev, "peripheral clock get error %d\n", ret); + return -ENODEV; + } + + ret = clk_enable(&clk); + if (ret) { + dev_err(dev, "peripheral clock enable error %d\n", ret); + return -ENODEV; + } + + ret = clk_get_by_name(dev, "ref", &clk); + if (ret) { + dev_err(dev, "pll reference clock get error %d\n", ret); + return ret; + } + + priv->pllref_clk = (unsigned int)clk_get_rate(&clk); + + ret = reset_get_by_index(device->dev, 0, &rst); + if (ret) { + dev_err(dev, "missing dsi hardware reset\n"); + return -ENODEV; + } + + /* Reset */ + reset_assert(&rst); + udelay(20); + reset_deassert(&rst); + + return 0; +} + +struct video_bridge_ops stm32_dsi_ops = { + .attach = stm32_dsi_attach, + .set_backlight = stm32_dsi_set_backlight, +}; + +static const struct udevice_id stm32_dsi_ids[] = { + { .compatible = "st,stm32-dsi"}, + { } +}; + +U_BOOT_DRIVER(stm32_dsi) = { + .name = "stm32-display-dsi", + .id = UCLASS_VIDEO_BRIDGE, + .of_match = stm32_dsi_ids, + .bind = dm_scan_fdt_dev, + .probe = stm32_dsi_probe, + .ops = &stm32_dsi_ops, + .priv_auto_alloc_size = sizeof(struct stm32_dsi_priv), + .platdata_auto_alloc_size = sizeof(struct dw_mipi_dsi_plat_data), +};
Support for Orise Tech otm8009a 480p dsi 2dl video mode panel.
Signed-off-by: Yannick Fertré yannick.fertre@st.com --- drivers/video/Kconfig | 8 + drivers/video/Makefile | 1 + drivers/video/orisetech_otm8009a.c | 367 +++++++++++++++++++++++++++++++++++++ 3 files changed, 376 insertions(+) create mode 100644 drivers/video/orisetech_otm8009a.c
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index ede351d..f54f97e 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -328,6 +328,14 @@ config VIDEO_LCD_ANX9804 from a parallel LCD interface and translate it on the fy into a DP interface for driving eDP TFT displays. It uses I2C for configuration.
+config VIDEO_LCD_ORISETECH_OTM8009A + bool "OTM8009A DSI LCD panel support" + depends on DM_VIDEO + select VIDEO_MIPI_DSI + default n + help + Support for Orise Tech otm8009a 480p dsi 2dl video mode panel. + config VIDEO_LCD_SSD2828 bool "SSD2828 bridge chip" default n diff --git a/drivers/video/Makefile b/drivers/video/Makefile index ae143dc..67f5ca7 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -46,6 +46,7 @@ obj-$(CONFIG_VIDEO_IPUV3) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o obj-$(CONFIG_VIDEO_IVYBRIDGE_IGD) += ivybridge_igd.o obj-$(CONFIG_VIDEO_LCD_ANX9804) += anx9804.o obj-$(CONFIG_VIDEO_LCD_HITACHI_TX18D42VM) += hitachi_tx18d42vm_lcd.o +obj-$(CONFIG_VIDEO_LCD_ORISETECH_OTM8009A) += orisetech_otm8009a.o obj-$(CONFIG_VIDEO_LCD_SSD2828) += ssd2828.o obj-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o obj-${CONFIG_VIDEO_MIPI_DSI} += mipi_dsi.o diff --git a/drivers/video/orisetech_otm8009a.c b/drivers/video/orisetech_otm8009a.c new file mode 100644 index 0000000..fd7fc7c --- /dev/null +++ b/drivers/video/orisetech_otm8009a.c @@ -0,0 +1,367 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 STMicroelectronics - All Rights Reserved + * Author(s): Yannick Fertre yannick.fertre@st.com for STMicroelectronics. + * Philippe Cornu philippe.cornu@st.com for STMicroelectronics. + * + * This otm8009a panel driver is inspired from the Linux Kernel driver + * drivers/gpu/drm/panel/panel-orisetech-otm8009a.c. + */ +#include <common.h> +#include <backlight.h> +#include <dm.h> +#include <mipi_display.h> +#include <mipi_dsi.h> +#include <panel.h> +#include <asm/gpio.h> +#include <power/regulator.h> + +#define OTM8009A_BACKLIGHT_DEFAULT 240 +#define OTM8009A_BACKLIGHT_MAX 255 + +/* Manufacturer Command Set */ +#define MCS_ADRSFT 0x0000 /* Address Shift Function */ +#define MCS_PANSET 0xB3A6 /* Panel Type Setting */ +#define MCS_SD_CTRL 0xC0A2 /* Source Driver Timing Setting */ +#define MCS_P_DRV_M 0xC0B4 /* Panel Driving Mode */ +#define MCS_OSC_ADJ 0xC181 /* Oscillator Adjustment for Idle/Normal mode */ +#define MCS_RGB_VID_SET 0xC1A1 /* RGB Video Mode Setting */ +#define MCS_SD_PCH_CTRL 0xC480 /* Source Driver Precharge Control */ +#define MCS_NO_DOC1 0xC48A /* Command not documented */ +#define MCS_PWR_CTRL1 0xC580 /* Power Control Setting 1 */ +#define MCS_PWR_CTRL2 0xC590 /* Power Control Setting 2 for Normal Mode */ +#define MCS_PWR_CTRL4 0xC5B0 /* Power Control Setting 4 for DC Voltage */ +#define MCS_PANCTRLSET1 0xCB80 /* Panel Control Setting 1 */ +#define MCS_PANCTRLSET2 0xCB90 /* Panel Control Setting 2 */ +#define MCS_PANCTRLSET3 0xCBA0 /* Panel Control Setting 3 */ +#define MCS_PANCTRLSET4 0xCBB0 /* Panel Control Setting 4 */ +#define MCS_PANCTRLSET5 0xCBC0 /* Panel Control Setting 5 */ +#define MCS_PANCTRLSET6 0xCBD0 /* Panel Control Setting 6 */ +#define MCS_PANCTRLSET7 0xCBE0 /* Panel Control Setting 7 */ +#define MCS_PANCTRLSET8 0xCBF0 /* Panel Control Setting 8 */ +#define MCS_PANU2D1 0xCC80 /* Panel U2D Setting 1 */ +#define MCS_PANU2D2 0xCC90 /* Panel U2D Setting 2 */ +#define MCS_PANU2D3 0xCCA0 /* Panel U2D Setting 3 */ +#define MCS_PAND2U1 0xCCB0 /* Panel D2U Setting 1 */ +#define MCS_PAND2U2 0xCCC0 /* Panel D2U Setting 2 */ +#define MCS_PAND2U3 0xCCD0 /* Panel D2U Setting 3 */ +#define MCS_GOAVST 0xCE80 /* GOA VST Setting */ +#define MCS_GOACLKA1 0xCEA0 /* GOA CLKA1 Setting */ +#define MCS_GOACLKA3 0xCEB0 /* GOA CLKA3 Setting */ +#define MCS_GOAECLK 0xCFC0 /* GOA ECLK Setting */ +#define MCS_NO_DOC2 0xCFD0 /* Command not documented */ +#define MCS_GVDDSET 0xD800 /* GVDD/NGVDD */ +#define MCS_VCOMDC 0xD900 /* VCOM Voltage Setting */ +#define MCS_GMCT2_2P 0xE100 /* Gamma Correction 2.2+ Setting */ +#define MCS_GMCT2_2N 0xE200 /* Gamma Correction 2.2- Setting */ +#define MCS_NO_DOC3 0xF5B6 /* Command not documented */ +#define MCS_CMD2_ENA1 0xFF00 /* Enable Access Command2 "CMD2" */ +#define MCS_CMD2_ENA2 0xFF80 /* Enable Access Orise Command2 */ + +struct otm8009a_panel_priv { + struct udevice *reg; + struct gpio_desc reset; +}; + +static const struct display_timing default_timing = { + .pixelclock.typ = 32729000, + .hactive.typ = 480, + .hfront_porch.typ = 120, + .hback_porch.typ = 120, + .hsync_len.typ = 63, + .vactive.typ = 800, + .vfront_porch.typ = 12, + .vback_porch.typ = 12, + .vsync_len.typ = 12, +}; + +static void otm8009a_dcs_write_buf(struct udevice *dev, const void *data, + size_t len) +{ + struct mipi_dsi_panel_plat *plat = dev_get_platdata(dev); + struct mipi_dsi_device *device = plat->device; + + if (mipi_dsi_dcs_write_buffer(device, data, len) < 0) + dev_err(dev, "mipi dsi dcs write buffer failed\n"); +} + +static void otm8009a_dcs_write_buf_hs(struct udevice *dev, const void *data, + size_t len) +{ + struct mipi_dsi_panel_plat *plat = dev_get_platdata(dev); + struct mipi_dsi_device *device = plat->device; + + /* data will be sent in dsi hs mode (ie. no lpm) */ + device->mode_flags &= ~MIPI_DSI_MODE_LPM; + + if (mipi_dsi_dcs_write_buffer(device, data, len) < 0) + dev_err(dev, "mipi dsi dcs write buffer failed\n"); + + /* restore back the dsi lpm mode */ + device->mode_flags |= MIPI_DSI_MODE_LPM; +} + +#define dcs_write_seq(dev, seq...) \ +({ \ + static const u8 d[] = { seq }; \ + otm8009a_dcs_write_buf(dev, d, ARRAY_SIZE(d)); \ +}) + +#define dcs_write_seq_hs(dev, seq...) \ +({ \ + static const u8 d[] = { seq }; \ + otm8009a_dcs_write_buf_hs(dev, d, ARRAY_SIZE(d)); \ +}) + +#define dcs_write_cmd_at(dev, cmd, seq...) \ +({ \ + static const u16 c = cmd; \ + struct udevice *device = dev; \ + dcs_write_seq(device, MCS_ADRSFT, (c) & 0xFF); \ + dcs_write_seq(device, (c) >> 8, seq); \ +}) + +static int otm8009a_init_sequence(struct udevice *dev) +{ + struct mipi_dsi_panel_plat *plat = dev_get_platdata(dev); + struct mipi_dsi_device *device = plat->device; + int ret; + + /* Enter CMD2 */ + dcs_write_cmd_at(dev, MCS_CMD2_ENA1, 0x80, 0x09, 0x01); + + /* Enter Orise Command2 */ + dcs_write_cmd_at(dev, MCS_CMD2_ENA2, 0x80, 0x09); + + dcs_write_cmd_at(dev, MCS_SD_PCH_CTRL, 0x30); + mdelay(10); + + dcs_write_cmd_at(dev, MCS_NO_DOC1, 0x40); + mdelay(10); + + dcs_write_cmd_at(dev, MCS_PWR_CTRL4 + 1, 0xA9); + dcs_write_cmd_at(dev, MCS_PWR_CTRL2 + 1, 0x34); + dcs_write_cmd_at(dev, MCS_P_DRV_M, 0x50); + dcs_write_cmd_at(dev, MCS_VCOMDC, 0x4E); + dcs_write_cmd_at(dev, MCS_OSC_ADJ, 0x66); /* 65Hz */ + dcs_write_cmd_at(dev, MCS_PWR_CTRL2 + 2, 0x01); + dcs_write_cmd_at(dev, MCS_PWR_CTRL2 + 5, 0x34); + dcs_write_cmd_at(dev, MCS_PWR_CTRL2 + 4, 0x33); + dcs_write_cmd_at(dev, MCS_GVDDSET, 0x79, 0x79); + dcs_write_cmd_at(dev, MCS_SD_CTRL + 1, 0x1B); + dcs_write_cmd_at(dev, MCS_PWR_CTRL1 + 2, 0x83); + dcs_write_cmd_at(dev, MCS_SD_PCH_CTRL + 1, 0x83); + dcs_write_cmd_at(dev, MCS_RGB_VID_SET, 0x0E); + dcs_write_cmd_at(dev, MCS_PANSET, 0x00, 0x01); + + dcs_write_cmd_at(dev, MCS_GOAVST, 0x85, 0x01, 0x00, 0x84, 0x01, 0x00); + dcs_write_cmd_at(dev, MCS_GOACLKA1, 0x18, 0x04, 0x03, 0x39, 0x00, 0x00, + 0x00, 0x18, 0x03, 0x03, 0x3A, 0x00, 0x00, 0x00); + dcs_write_cmd_at(dev, MCS_GOACLKA3, 0x18, 0x02, 0x03, 0x3B, 0x00, 0x00, + 0x00, 0x18, 0x01, 0x03, 0x3C, 0x00, 0x00, 0x00); + dcs_write_cmd_at(dev, MCS_GOAECLK, 0x01, 0x01, 0x20, 0x20, 0x00, 0x00, + 0x01, 0x02, 0x00, 0x00); + + dcs_write_cmd_at(dev, MCS_NO_DOC2, 0x00); + + dcs_write_cmd_at(dev, MCS_PANCTRLSET1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0); + dcs_write_cmd_at(dev, MCS_PANCTRLSET2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0); + dcs_write_cmd_at(dev, MCS_PANCTRLSET3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0); + dcs_write_cmd_at(dev, MCS_PANCTRLSET4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0); + dcs_write_cmd_at(dev, MCS_PANCTRLSET5, 0, 4, 4, 4, 4, 4, 0, 0, 0, 0, + 0, 0, 0, 0, 0); + dcs_write_cmd_at(dev, MCS_PANCTRLSET6, 0, 0, 0, 0, 0, 0, 4, 4, 4, 4, + 4, 0, 0, 0, 0); + dcs_write_cmd_at(dev, MCS_PANCTRLSET7, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0); + dcs_write_cmd_at(dev, MCS_PANCTRLSET8, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, + 0xFF, 0xFF, 0xFF, 0xFF, 0xFF); + + dcs_write_cmd_at(dev, MCS_PANU2D1, 0x00, 0x26, 0x09, 0x0B, 0x01, 0x25, + 0x00, 0x00, 0x00, 0x00); + dcs_write_cmd_at(dev, MCS_PANU2D2, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x26, 0x0A, 0x0C, 0x02); + dcs_write_cmd_at(dev, MCS_PANU2D3, 0x25, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); + dcs_write_cmd_at(dev, MCS_PAND2U1, 0x00, 0x25, 0x0C, 0x0A, 0x02, 0x26, + 0x00, 0x00, 0x00, 0x00); + dcs_write_cmd_at(dev, MCS_PAND2U2, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x25, 0x0B, 0x09, 0x01); + dcs_write_cmd_at(dev, MCS_PAND2U3, 0x26, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); + + dcs_write_cmd_at(dev, MCS_PWR_CTRL1 + 1, 0x66); + + dcs_write_cmd_at(dev, MCS_NO_DOC3, 0x06); + + dcs_write_cmd_at(dev, MCS_GMCT2_2P, 0x00, 0x09, 0x0F, 0x0E, 0x07, 0x10, + 0x0B, 0x0A, 0x04, 0x07, 0x0B, 0x08, 0x0F, 0x10, 0x0A, + 0x01); + dcs_write_cmd_at(dev, MCS_GMCT2_2N, 0x00, 0x09, 0x0F, 0x0E, 0x07, 0x10, + 0x0B, 0x0A, 0x04, 0x07, 0x0B, 0x08, 0x0F, 0x10, 0x0A, + 0x01); + + /* Exit CMD2 */ + dcs_write_cmd_at(dev, MCS_CMD2_ENA1, 0xFF, 0xFF, 0xFF); + + ret = mipi_dsi_dcs_nop(device); + if (ret) + return ret; + + ret = mipi_dsi_dcs_exit_sleep_mode(device); + if (ret) + return ret; + + /* Wait for sleep out exit */ + mdelay(120); + + /* Default portrait 480x800 rgb24 */ + dcs_write_seq(dev, MIPI_DCS_SET_ADDRESS_MODE, 0x00); + + ret = mipi_dsi_dcs_set_column_address(device, 0, + default_timing.hactive.typ - 1); + if (ret) + return ret; + + ret = mipi_dsi_dcs_set_page_address(device, 0, + default_timing.vactive.typ - 1); + if (ret) + return ret; + + /* See otm8009a driver documentation for pixel format descriptions */ + ret = mipi_dsi_dcs_set_pixel_format(device, MIPI_DCS_PIXEL_FMT_24BIT | + MIPI_DCS_PIXEL_FMT_24BIT << 4); + if (ret) + return ret; + + /* Disable CABC feature */ + dcs_write_seq(dev, MIPI_DCS_WRITE_POWER_SAVE, 0x00); + + ret = mipi_dsi_dcs_set_display_on(device); + if (ret) + return ret; + + ret = mipi_dsi_dcs_nop(device); + if (ret) + return ret; + + /* Send Command GRAM memory write (no parameters) */ + dcs_write_seq(dev, MIPI_DCS_WRITE_MEMORY_START); + + return 0; +} + +static int otm8009a_panel_enable_backlight(struct udevice *dev) +{ + struct mipi_dsi_panel_plat *plat = dev_get_platdata(dev); + struct mipi_dsi_device *device = plat->device; + int ret; + + device->lanes = 2; + device->format = MIPI_DSI_FMT_RGB888; + device->mode_flags = MIPI_DSI_MODE_VIDEO | + MIPI_DSI_MODE_VIDEO_BURST | + MIPI_DSI_MODE_LPM; + + ret = mipi_dsi_attach(device); + if (ret < 0) + return ret; + + ret = otm8009a_init_sequence(dev); + if (ret) + return ret; + + /* + * Power on the backlight with the requested brightness + * Note We can not use mipi_dsi_dcs_set_display_brightness() + * as otm8009a driver support only 8-bit brightness (1 param). + */ + dcs_write_seq(dev, MIPI_DCS_SET_DISPLAY_BRIGHTNESS, + OTM8009A_BACKLIGHT_DEFAULT); + + /* Update Brightness Control & Backlight */ + dcs_write_seq(dev, MIPI_DCS_WRITE_CONTROL_DISPLAY, 0x24); + + /* Update Brightness Control & Backlight */ + dcs_write_seq_hs(dev, MIPI_DCS_WRITE_CONTROL_DISPLAY); + + /* Need to wait a few time before sending the first image */ + mdelay(10); + + return 0; +} + +static int otm8009a_panel_get_display_timing(struct udevice *dev, + struct display_timing *timings) +{ + memcpy(timings, &default_timing, sizeof(*timings)); + return 0; +} + +static int otm8009a_panel_ofdata_to_platdata(struct udevice *dev) +{ + struct otm8009a_panel_priv *priv = dev_get_priv(dev); + int ret; + + if (IS_ENABLED(CONFIG_DM_REGULATOR)) { + ret = device_get_supply_regulator(dev, "power-supply", + &priv->reg); + if (ret && ret != -ENOENT) { + dev_err(dev, "Warning: cannot get power supply\n"); + return ret; + } + } + + ret = gpio_request_by_name(dev, "reset-gpios", 0, &priv->reset, + GPIOD_IS_OUT); + if (ret) { + dev_err(dev, "warning: cannot get reset GPIO\n"); + if (ret != -ENOENT) + return ret; + } + + return 0; +} + +static int otm8009a_panel_probe(struct udevice *dev) +{ + struct otm8009a_panel_priv *priv = dev_get_priv(dev); + int ret; + + if (IS_ENABLED(CONFIG_DM_REGULATOR) && priv->reg) { + dev_dbg(dev, "enable regulator '%s'\n", priv->reg->name); + ret = regulator_set_enable(priv->reg, true); + if (ret) + return ret; + } + + /* reset panel */ + dm_gpio_set_value(&priv->reset, true); + mdelay(1); /* >50us */ + dm_gpio_set_value(&priv->reset, false); + mdelay(10); /* >5ms */ + + return 0; +} + +static const struct panel_ops otm8009a_panel_ops = { + .enable_backlight = otm8009a_panel_enable_backlight, + .get_display_timing = otm8009a_panel_get_display_timing, +}; + +static const struct udevice_id otm8009a_panel_ids[] = { + { .compatible = "orisetech,otm8009a" }, + { } +}; + +U_BOOT_DRIVER(otm8009a_panel) = { + .name = "otm8009a_panel", + .id = UCLASS_PANEL, + .of_match = otm8009a_panel_ids, + .ops = &otm8009a_panel_ops, + .ofdata_to_platdata = otm8009a_panel_ofdata_to_platdata, + .probe = otm8009a_panel_probe, + .platdata_auto_alloc_size = sizeof(struct mipi_dsi_panel_plat), + .priv_auto_alloc_size = sizeof(struct otm8009a_panel_priv), +};
Support for Raydium RM68200 720p dsi 2dl video mode panel. This rm68200 panel driver is based on the Linux Kernel driver from drivers/gpu/drm/panel/panel-raydium-rm68200.c.
Signed-off-by: Yannick Fertré yannick.fertre@st.com --- drivers/video/Kconfig | 8 + drivers/video/Makefile | 1 + drivers/video/raydium-rm68200.c | 339 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 348 insertions(+) create mode 100644 drivers/video/raydium-rm68200.c
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index f54f97e..1aa826d 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -336,6 +336,14 @@ config VIDEO_LCD_ORISETECH_OTM8009A help Support for Orise Tech otm8009a 480p dsi 2dl video mode panel.
+config VIDEO_LCD_RAYDIUM_RM68200 + bool "RM68200 DSI LCD panel support" + depends on DM_VIDEO + select VIDEO_MIPI_DSI + default n + help + Support for Raydium rm68200 720x1280 dsi 2dl video mode panel. + config VIDEO_LCD_SSD2828 bool "SSD2828 bridge chip" default n diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 67f5ca7..d60ff9d 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -47,6 +47,7 @@ obj-$(CONFIG_VIDEO_IVYBRIDGE_IGD) += ivybridge_igd.o obj-$(CONFIG_VIDEO_LCD_ANX9804) += anx9804.o obj-$(CONFIG_VIDEO_LCD_HITACHI_TX18D42VM) += hitachi_tx18d42vm_lcd.o obj-$(CONFIG_VIDEO_LCD_ORISETECH_OTM8009A) += orisetech_otm8009a.o +obj-$(CONFIG_VIDEO_LCD_RAYDIUM_RM68200) += raydium-rm68200.o obj-$(CONFIG_VIDEO_LCD_SSD2828) += ssd2828.o obj-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o obj-${CONFIG_VIDEO_MIPI_DSI} += mipi_dsi.o diff --git a/drivers/video/raydium-rm68200.c b/drivers/video/raydium-rm68200.c new file mode 100644 index 0000000..cf48331 --- /dev/null +++ b/drivers/video/raydium-rm68200.c @@ -0,0 +1,339 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 STMicroelectronics - All Rights Reserved + * Author(s): Yannick Fertre yannick.fertre@st.com for STMicroelectronics. + * Philippe Cornu philippe.cornu@st.com for STMicroelectronics. + * + * This rm68200 panel driver is inspired from the Linux Kernel driver + * drivers/gpu/drm/panel/panel-raydium-rm68200.c. + */ +#include <common.h> +#include <backlight.h> +#include <dm.h> +#include <mipi_display.h> +#include <mipi_dsi.h> +#include <panel.h> +#include <asm/gpio.h> +#include <power/regulator.h> + +/*** Manufacturer Command Set ***/ +#define MCS_CMD_MODE_SW 0xFE /* CMD Mode Switch */ +#define MCS_CMD1_UCS 0x00 /* User Command Set (UCS = CMD1) */ +#define MCS_CMD2_P0 0x01 /* Manufacture Command Set Page0 (CMD2 P0) */ +#define MCS_CMD2_P1 0x02 /* Manufacture Command Set Page1 (CMD2 P1) */ +#define MCS_CMD2_P2 0x03 /* Manufacture Command Set Page2 (CMD2 P2) */ +#define MCS_CMD2_P3 0x04 /* Manufacture Command Set Page3 (CMD2 P3) */ + +/* CMD2 P0 commands (Display Options and Power) */ +#define MCS_STBCTR 0x12 /* TE1 Output Setting Zig-Zag Connection */ +#define MCS_SGOPCTR 0x16 /* Source Bias Current */ +#define MCS_SDCTR 0x1A /* Source Output Delay Time */ +#define MCS_INVCTR 0x1B /* Inversion Type */ +#define MCS_EXT_PWR_IC 0x24 /* External PWR IC Control */ +#define MCS_SETAVDD 0x27 /* PFM Control for AVDD Output */ +#define MCS_SETAVEE 0x29 /* PFM Control for AVEE Output */ +#define MCS_BT2CTR 0x2B /* DDVDL Charge Pump Control */ +#define MCS_BT3CTR 0x2F /* VGH Charge Pump Control */ +#define MCS_BT4CTR 0x34 /* VGL Charge Pump Control */ +#define MCS_VCMCTR 0x46 /* VCOM Output Level Control */ +#define MCS_SETVGN 0x52 /* VG M/S N Control */ +#define MCS_SETVGP 0x54 /* VG M/S P Control */ +#define MCS_SW_CTRL 0x5F /* Interface Control for PFM and MIPI */ + +/* CMD2 P2 commands (GOA Timing Control) - no description in datasheet */ +#define GOA_VSTV1 0x00 +#define GOA_VSTV2 0x07 +#define GOA_VCLK1 0x0E +#define GOA_VCLK2 0x17 +#define GOA_VCLK_OPT1 0x20 +#define GOA_BICLK1 0x2A +#define GOA_BICLK2 0x37 +#define GOA_BICLK3 0x44 +#define GOA_BICLK4 0x4F +#define GOA_BICLK_OPT1 0x5B +#define GOA_BICLK_OPT2 0x60 +#define MCS_GOA_GPO1 0x6D +#define MCS_GOA_GPO2 0x71 +#define MCS_GOA_EQ 0x74 +#define MCS_GOA_CLK_GALLON 0x7C +#define MCS_GOA_FS_SEL0 0x7E +#define MCS_GOA_FS_SEL1 0x87 +#define MCS_GOA_FS_SEL2 0x91 +#define MCS_GOA_FS_SEL3 0x9B +#define MCS_GOA_BS_SEL0 0xAC +#define MCS_GOA_BS_SEL1 0xB5 +#define MCS_GOA_BS_SEL2 0xBF +#define MCS_GOA_BS_SEL3 0xC9 +#define MCS_GOA_BS_SEL4 0xD3 + +/* CMD2 P3 commands (Gamma) */ +#define MCS_GAMMA_VP 0x60 /* Gamma VP1~VP16 */ +#define MCS_GAMMA_VN 0x70 /* Gamma VN1~VN16 */ + +struct rm68200_panel_priv { + struct udevice *reg; + struct udevice *backlight; + struct gpio_desc reset; +}; + +static const struct display_timing default_timing = { + .pixelclock.typ = 52582000, + .hactive.typ = 720, + .hfront_porch.typ = 38, + .hback_porch.typ = 8, + .hsync_len.typ = 38, + .vactive.typ = 1280, + .vfront_porch.typ = 12, + .vback_porch.typ = 4, + .vsync_len.typ = 12, +}; + +static void rm68200_dcs_write_buf(struct udevice *dev, const void *data, + size_t len) +{ + struct mipi_dsi_panel_plat *plat = dev_get_platdata(dev); + struct mipi_dsi_device *device = plat->device; + int err; + + err = mipi_dsi_dcs_write_buffer(device, data, len); + if (err < 0) + dev_err(dev, "MIPI DSI DCS write buffer failed: %d\n", err); +} + +static void rm68200_dcs_write_cmd(struct udevice *dev, u8 cmd, u8 value) +{ + struct mipi_dsi_panel_plat *plat = dev_get_platdata(dev); + struct mipi_dsi_device *device = plat->device; + int err; + + err = mipi_dsi_dcs_write(device, cmd, &value, 1); + if (err < 0) + dev_err(dev, "MIPI DSI DCS write failed: %d\n", err); +} + +#define dcs_write_seq(ctx, seq...) \ +({ \ + static const u8 d[] = { seq }; \ + \ + rm68200_dcs_write_buf(ctx, d, ARRAY_SIZE(d)); \ +}) + +/* + * This panel is not able to auto-increment all cmd addresses so for some of + * them, we need to send them one by one... + */ +#define dcs_write_cmd_seq(ctx, cmd, seq...) \ +({ \ + static const u8 d[] = { seq }; \ + unsigned int i; \ + \ + for (i = 0; i < ARRAY_SIZE(d) ; i++) \ + rm68200_dcs_write_cmd(ctx, cmd + i, d[i]); \ +}) + +static void rm68200_init_sequence(struct udevice *dev) +{ + /* Enter CMD2 with page 0 */ + dcs_write_seq(dev, MCS_CMD_MODE_SW, MCS_CMD2_P0); + dcs_write_cmd_seq(dev, MCS_EXT_PWR_IC, 0xC0, 0x53, 0x00); + dcs_write_seq(dev, MCS_BT2CTR, 0xE5); + dcs_write_seq(dev, MCS_SETAVDD, 0x0A); + dcs_write_seq(dev, MCS_SETAVEE, 0x0A); + dcs_write_seq(dev, MCS_SGOPCTR, 0x52); + dcs_write_seq(dev, MCS_BT3CTR, 0x53); + dcs_write_seq(dev, MCS_BT4CTR, 0x5A); + dcs_write_seq(dev, MCS_INVCTR, 0x00); + dcs_write_seq(dev, MCS_STBCTR, 0x0A); + dcs_write_seq(dev, MCS_SDCTR, 0x06); + dcs_write_seq(dev, MCS_VCMCTR, 0x56); + dcs_write_seq(dev, MCS_SETVGN, 0xA0, 0x00); + dcs_write_seq(dev, MCS_SETVGP, 0xA0, 0x00); + dcs_write_seq(dev, MCS_SW_CTRL, 0x11); /* 2 data lanes, see doc */ + + dcs_write_seq(dev, MCS_CMD_MODE_SW, MCS_CMD2_P2); + dcs_write_seq(dev, GOA_VSTV1, 0x05); + dcs_write_seq(dev, 0x02, 0x0B); + dcs_write_seq(dev, 0x03, 0x0F); + dcs_write_seq(dev, 0x04, 0x7D, 0x00, 0x50); + dcs_write_cmd_seq(dev, GOA_VSTV2, 0x05, 0x16, 0x0D, 0x11, 0x7D, 0x00, + 0x50); + dcs_write_cmd_seq(dev, GOA_VCLK1, 0x07, 0x08, 0x01, 0x02, 0x00, 0x7D, + 0x00, 0x85, 0x08); + dcs_write_cmd_seq(dev, GOA_VCLK2, 0x03, 0x04, 0x05, 0x06, 0x00, 0x7D, + 0x00, 0x85, 0x08); + dcs_write_seq(dev, GOA_VCLK_OPT1, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00); + dcs_write_cmd_seq(dev, GOA_BICLK1, 0x07, 0x08); + dcs_write_seq(dev, 0x2D, 0x01); + dcs_write_seq(dev, 0x2F, 0x02, 0x00, 0x40, 0x05, 0x08, 0x54, 0x7D, + 0x00); + dcs_write_cmd_seq(dev, GOA_BICLK2, 0x03, 0x04, 0x05, 0x06, 0x00); + dcs_write_seq(dev, 0x3D, 0x40); + dcs_write_seq(dev, 0x3F, 0x05, 0x08, 0x54, 0x7D, 0x00); + dcs_write_seq(dev, GOA_BICLK3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00); + dcs_write_seq(dev, GOA_BICLK4, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00); + dcs_write_seq(dev, 0x58, 0x00, 0x00, 0x00); + dcs_write_seq(dev, GOA_BICLK_OPT1, 0x00, 0x00, 0x00, 0x00, 0x00); + dcs_write_seq(dev, GOA_BICLK_OPT2, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00); + dcs_write_seq(dev, MCS_GOA_GPO1, 0x00, 0x00, 0x00, 0x00); + dcs_write_seq(dev, MCS_GOA_GPO2, 0x00, 0x20, 0x00); + dcs_write_seq(dev, MCS_GOA_EQ, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, + 0x00, 0x00); + dcs_write_seq(dev, MCS_GOA_CLK_GALLON, 0x00, 0x00); + dcs_write_cmd_seq(dev, MCS_GOA_FS_SEL0, 0xBF, 0x02, 0x06, 0x14, 0x10, + 0x16, 0x12, 0x08, 0x3F); + dcs_write_cmd_seq(dev, MCS_GOA_FS_SEL1, 0x3F, 0x3F, 0x3F, 0x3F, 0x0C, + 0x0A, 0x0E, 0x3F, 0x3F, 0x00); + dcs_write_cmd_seq(dev, MCS_GOA_FS_SEL2, 0x04, 0x3F, 0x3F, 0x3F, 0x3F, + 0x05, 0x01, 0x3F, 0x3F, 0x0F); + dcs_write_cmd_seq(dev, MCS_GOA_FS_SEL3, 0x0B, 0x0D, 0x3F, 0x3F, 0x3F, + 0x3F); + dcs_write_cmd_seq(dev, 0xA2, 0x3F, 0x09, 0x13, 0x17, 0x11, 0x15); + dcs_write_cmd_seq(dev, 0xA9, 0x07, 0x03, 0x3F); + dcs_write_cmd_seq(dev, MCS_GOA_BS_SEL0, 0x3F, 0x05, 0x01, 0x17, 0x13, + 0x15, 0x11, 0x0F, 0x3F); + dcs_write_cmd_seq(dev, MCS_GOA_BS_SEL1, 0x3F, 0x3F, 0x3F, 0x3F, 0x0B, + 0x0D, 0x09, 0x3F, 0x3F, 0x07); + dcs_write_cmd_seq(dev, MCS_GOA_BS_SEL2, 0x03, 0x3F, 0x3F, 0x3F, 0x3F, + 0x02, 0x06, 0x3F, 0x3F, 0x08); + dcs_write_cmd_seq(dev, MCS_GOA_BS_SEL3, 0x0C, 0x0A, 0x3F, 0x3F, 0x3F, + 0x3F, 0x3F, 0x0E, 0x10, 0x14); + dcs_write_cmd_seq(dev, MCS_GOA_BS_SEL4, 0x12, 0x16, 0x00, 0x04, 0x3F); + dcs_write_seq(dev, 0xDC, 0x02); + dcs_write_seq(dev, 0xDE, 0x12); + + dcs_write_seq(dev, MCS_CMD_MODE_SW, 0x0E); /* No documentation */ + dcs_write_seq(dev, 0x01, 0x75); + + dcs_write_seq(dev, MCS_CMD_MODE_SW, MCS_CMD2_P3); + dcs_write_cmd_seq(dev, MCS_GAMMA_VP, 0x00, 0x0C, 0x12, 0x0E, 0x06, + 0x12, 0x0E, 0x0B, 0x15, 0x0B, 0x10, 0x07, 0x0F, + 0x12, 0x0C, 0x00); + dcs_write_cmd_seq(dev, MCS_GAMMA_VN, 0x00, 0x0C, 0x12, 0x0E, 0x06, + 0x12, 0x0E, 0x0B, 0x15, 0x0B, 0x10, 0x07, 0x0F, + 0x12, 0x0C, 0x00); + + /* Exit CMD2 */ + dcs_write_seq(dev, MCS_CMD_MODE_SW, MCS_CMD1_UCS); +} + +static int rm68200_panel_enable_backlight(struct udevice *dev) +{ + struct mipi_dsi_panel_plat *plat = dev_get_platdata(dev); + struct mipi_dsi_device *device = plat->device; + struct rm68200_panel_priv *priv = dev_get_priv(dev); + int ret; + + device->lanes = 2; + device->format = MIPI_DSI_FMT_RGB888; + device->mode_flags = MIPI_DSI_MODE_VIDEO | + MIPI_DSI_MODE_VIDEO_BURST | + MIPI_DSI_MODE_LPM; + + ret = mipi_dsi_attach(device); + if (ret < 0) + return ret; + + rm68200_init_sequence(dev); + + ret = mipi_dsi_dcs_exit_sleep_mode(device); + if (ret) + return ret; + + mdelay(125); + + ret = mipi_dsi_dcs_set_display_on(device); + if (ret) + return ret; + + mdelay(20); + + ret = backlight_enable(priv->backlight); + if (ret) + return ret; + + return 0; +} + +static int rm68200_panel_get_display_timing(struct udevice *dev, + struct display_timing *timings) +{ + memcpy(timings, &default_timing, sizeof(*timings)); + return 0; +} + +static int rm68200_panel_ofdata_to_platdata(struct udevice *dev) +{ + struct rm68200_panel_priv *priv = dev_get_priv(dev); + int ret; + + if (IS_ENABLED(CONFIG_DM_REGULATOR)) { + ret = device_get_supply_regulator(dev, "power-supply", + &priv->reg); + if (ret && ret != -ENOENT) { + dev_err(dev, "Warning: cannot get power supply\n"); + return ret; + } + } + + ret = gpio_request_by_name(dev, "reset-gpios", 0, &priv->reset, + GPIOD_IS_OUT); + if (ret) { + dev_err(dev, "Warning: cannot get reset GPIO\n"); + if (ret != -ENOENT) + return ret; + } + + ret = uclass_get_device_by_phandle(UCLASS_PANEL_BACKLIGHT, dev, + "backlight", &priv->backlight); + if (ret) { + dev_err(dev, "Cannot get backlight: ret=%d\n", ret); + return ret; + } + + return 0; +} + +static int rm68200_panel_probe(struct udevice *dev) +{ + struct rm68200_panel_priv *priv = dev_get_priv(dev); + int ret; + + if (IS_ENABLED(CONFIG_DM_REGULATOR) && priv->reg) { + ret = regulator_set_enable(priv->reg, true); + if (ret) + return ret; + } + + /* reset panel */ + dm_gpio_set_value(&priv->reset, true); + mdelay(1); + dm_gpio_set_value(&priv->reset, false); + mdelay(10); + + return 0; +} + +static const struct panel_ops rm68200_panel_ops = { + .enable_backlight = rm68200_panel_enable_backlight, + .get_display_timing = rm68200_panel_get_display_timing, +}; + +static const struct udevice_id rm68200_panel_ids[] = { + { .compatible = "raydium,rm68200" }, + { } +}; + +U_BOOT_DRIVER(rm68200_panel) = { + .name = "rm68200_panel", + .id = UCLASS_PANEL, + .of_match = rm68200_panel_ids, + .ops = &rm68200_panel_ops, + .ofdata_to_platdata = rm68200_panel_ofdata_to_platdata, + .probe = rm68200_panel_probe, + .platdata_auto_alloc_size = sizeof(struct mipi_dsi_panel_plat), + .priv_auto_alloc_size = sizeof(struct rm68200_panel_priv), +};
Add mipi dsi bridge node in device-tree.
Signed-off-by: Yannick Fertré yannick.fertre@st.com --- arch/arm/dts/stm32f746.dtsi | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/dts/stm32f746.dtsi b/arch/arm/dts/stm32f746.dtsi index afa7832..005d267 100644 --- a/arch/arm/dts/stm32f746.dtsi +++ b/arch/arm/dts/stm32f746.dtsi @@ -340,6 +340,18 @@ u-boot,dm-pre-reloc; status = "disabled"; }; + + dsi: dsi@40016c00 { + compatible = "st,stm32-dsi"; + reg = <0x40016C00 0x800>; + resets = <&rcc STM32F7_APB2_RESET(DSI)>; + clocks = <&rcc 0 STM32F7_APB2_CLOCK(DSI)>, + <&rcc 0 STM32F7_APB2_CLOCK(LTDC)>, + <&clk_hse>; + clock-names = "pclk", "px_clk", "ref"; + u-boot,dm-pre-reloc; + status = "disabled"; + }; }; };
Enable the display controller, mipi dsi bridge & panel. Set panel display timings.
Signed-off-by: Yannick Fertré yannick.fertre@st.com --- arch/arm/dts/stm32f769-disco.dts | 41 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 41 insertions(+)
diff --git a/arch/arm/dts/stm32f769-disco.dts b/arch/arm/dts/stm32f769-disco.dts index 1e8ef74..6903e66 100644 --- a/arch/arm/dts/stm32f769-disco.dts +++ b/arch/arm/dts/stm32f769-disco.dts @@ -85,6 +85,18 @@ compatible = "st,button1"; button-gpio = <&gpioa 0 0>; }; + + panel: panel { + compatible = "orisetech,otm8009a"; + reset-gpios = <&gpioj 15 1>; + status = "okay"; + + port { + panel_in: endpoint { + remote-endpoint = <&dsi_out>; + }; + }; + }; };
&clk_hse { @@ -264,3 +276,32 @@ bus-width = <4>; max-frequency = <25000000>; }; + +<dc { + status = "okay"; + + ports { + port@0 { + dp_out: endpoint { + remote-endpoint = <&dsi_in>; + }; + }; + }; +}; + +&dsi { + status = "okay"; + + ports { + port@0 { + dsi_out: endpoint { + remote-endpoint = <&panel_in>; + }; + }; + port@1 { + dsi_in: endpoint { + remote-endpoint = <&dp_out>; + }; + }; + }; +};
Signed-off-by: Yannick Fertré yannick.fertre@st.com --- configs/stm32f769-disco_defconfig | 67 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 67 insertions(+) create mode 100644 configs/stm32f769-disco_defconfig
diff --git a/configs/stm32f769-disco_defconfig b/configs/stm32f769-disco_defconfig new file mode 100644 index 0000000..7fe2d3f --- /dev/null +++ b/configs/stm32f769-disco_defconfig @@ -0,0 +1,67 @@ +CONFIG_ARM=y +CONFIG_STM32=y +CONFIG_SYS_TEXT_BASE=0x08008000 +CONFIG_SYS_MALLOC_F_LEN=0xC00 +CONFIG_STM32F7=y +CONFIG_TARGET_STM32F746_DISCO=y +CONFIG_DEFAULT_DEVICE_TREE="stm32f769-disco" +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="U-Boot > " +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y +CONFIG_DM_MMC=y +# CONFIG_SPL_DM_MMC is not set +CONFIG_ARM_PL180_MMCI=y +CONFIG_MTD=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +# CONFIG_PINCTRL_FULL is not set +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_STM32_QSPI=y +CONFIG_DM_VIDEO=y +CONFIG_BACKLIGHT_GPIO=y +CONFIG_VIDEO_LCD_ORISETECH_OTM8009A=y +CONFIG_VIDEO_STM32=y +CONFIG_VIDEO_STM32_DSI=y +CONFIG_VIDEO_STM32_MAX_XRES=480 +CONFIG_VIDEO_STM32_MAX_YRES=800 +CONFIG_VIDEO_BRIDGE=y +CONFIG_OF_LIBFDT_OVERLAY=y +# CONFIG_EFI_LOADER is not set
Yannick FERTRE
Yannick Fertré
