[PATCH v3 0/4] mkimage: sunxi_egon: add riscv support
This patchset updates mkimage -T sunxi_egon to be able to generate an eGON.BT0 image for Allwinner RISC-V SoCs (e.g. D1).
In addition, to keep the compatibility, it will still consider the architecture to be ARM when no architecture is specified.
This v3 is a minor update to Icenowy's patch series, which I have also tested. Since the TOC0 patch series touches the same lines in Makefile.spl, it depends on this series.
Changes in v3: - Factor out an egon_get_arch() function as suggested by Andre
Icenowy Zheng (4): mkimage: add a flag to describe whether -A is specified mkimage: sunxi_egon: refactor for multi-architecture support mkimage: sunxi_egon: add support for riscv sunxi: specify architecture when generating SPL boot image
scripts/Makefile.spl | 2 +- tools/imagetool.h | 1 + tools/mkimage.c | 1 + tools/sunxi_egon.c | 73 +++++++++++++++++++++++++++++++++++++++----- 4 files changed, 69 insertions(+), 8 deletions(-)
The sunxi_egon type used to take no -A argument (because we assume sunxi targets are all ARM). However, as Allwinner D1 appears as the first RISC-V sunxi target, we need to support -A; in addition, as external projects rely on U-Boot mkimage to generate sunxi eGON.BT0 header, we need to keep compatibility with command line without -A.
As the default value of arch in mkimage is not proper (IH_ARCH_PPC instead of IH_ARCH_INVALID), to keep more compatibility, add an Aflag field to image parameters to describe whether an architecture is explicitly specified.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Icenowy Zheng icenowy@aosc.io Signed-off-by: Samuel Holland samuel@sholland.org ---
(no changes since v1)
tools/imagetool.h | 1 + tools/mkimage.c | 1 + 2 files changed, 2 insertions(+)
diff --git a/tools/imagetool.h b/tools/imagetool.h index e229a34ffc..5dc28312c2 100644 --- a/tools/imagetool.h +++ b/tools/imagetool.h @@ -51,6 +51,7 @@ struct image_tool_params { int pflag; int vflag; int xflag; + int Aflag; int skipcpy; int os; int arch; diff --git a/tools/mkimage.c b/tools/mkimage.c index fbe883ce36..cfd97b046c 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -171,6 +171,7 @@ static void process_args(int argc, char **argv) show_valid_options(IH_ARCH); usage("Invalid architecture"); } + params.Aflag = 1; break; case 'b': if (add_content(IH_TYPE_FLATDT, optarg)) {
So there was some nitpic^Wdiscussion about the uppercase in the variable name, where Icenowy proposed arch_flag instead. Shall this be changed still? If that's the only thing, I am happy to do it while merging. Btw: Shall this (and the TOC0) series go through the sunxi tree?
Cheers, Andre
- int Aflag; int skipcpy; int os; int arch;
case 'b': if (add_content(IH_TYPE_FLATDT, optarg)) {params.Aflag = 1; break;
My understanding of the discussion was that Aflag made the most sense for consistency, and it was acceptable for that reason, which is why I left it unchanged in v3.
Regards, Samuel
Cheers, Andre
That might have been my suggestion of naming the variable after its meaning rather than the single-character flag.
But I think Tom is happy with it as is, so let's go with it.
- Simon
Regards, Samuel
Cheers, Andre
Refactor some functions in mkimage sunxi_egon type, in order to prepare for adding support for more CPU architectures (e.g. RISC-V). In addition, compatibility for operation w/o specified architecture is kept, in this case the architecture is assumed as ARM.
Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Icenowy Zheng icenowy@aosc.io Signed-off-by: Samuel Holland samuel@sholland.org ---
tools/sunxi_egon.c | 50 +++++++++++++++++++++++++++++++++++++++------- 1 file changed, 43 insertions(+), 7 deletions(-)
diff --git a/tools/sunxi_egon.c b/tools/sunxi_egon.c index a5299eb6a1..e1c945a12f 100644 --- a/tools/sunxi_egon.c +++ b/tools/sunxi_egon.c @@ -14,9 +14,28 @@ */ #define PAD_SIZE 8192
+static int egon_get_arch(struct image_tool_params *params) +{ + if (params->Aflag) + return params->arch; + + /* For compatibility, assume ARM when no architecture specified */ + return IH_ARCH_ARM; +} + static int egon_check_params(struct image_tool_params *params) { - /* We just need a binary image file. */ + /* + * Check whether the architecture is supported. + */ + switch (egon_get_arch(params)) { + case IH_ARCH_ARM: + break; + default: + return EXIT_FAILURE; + } + + /* We need a binary image file. */ return !params->dflag; }
@@ -26,9 +45,18 @@ static int egon_verify_header(unsigned char *ptr, int image_size, const struct boot_file_head *header = (void *)ptr; uint32_t length;
- /* First 4 bytes must be an ARM branch instruction. */ - if ((le32_to_cpu(header->b_instruction) & 0xff000000) != 0xea000000) - return EXIT_FAILURE; + /* + * First 4 bytes must be a branch instruction of the corresponding + * architecture. + */ + switch (egon_get_arch(params)) { + case IH_ARCH_ARM: + if ((le32_to_cpu(header->b_instruction) & 0xff000000) != 0xea000000) + return EXIT_FAILURE; + break; + default: + return EXIT_FAILURE; /* Unknown architecture */ + }
if (memcmp(header->magic, BOOT0_MAGIC, sizeof(header->magic))) return EXIT_FAILURE; @@ -77,9 +105,17 @@ static void egon_set_header(void *buf, struct stat *sbuf, int infd, uint32_t checksum = 0, value; int i;
- /* Generate an ARM branch instruction to jump over the header. */ - value = 0xea000000 | (sizeof(struct boot_file_head) / 4 - 2); - header->b_instruction = cpu_to_le32(value); + /* + * Different architectures need different first instruction to + * branch to the body. + */ + switch (egon_get_arch(params)) { + case IH_ARCH_ARM: + /* Generate an ARM branch instruction to jump over the header. */ + value = 0xea000000 | (sizeof(struct boot_file_head) / 4 - 2); + header->b_instruction = cpu_to_le32(value); + break; + }
memcpy(header->magic, BOOT0_MAGIC, sizeof(header->magic)); header->check_sum = cpu_to_le32(BROM_STAMP_VALUE);
There's now a sun20i family in sunxi, which uses RISC-V CPU.
Add support for making eGON.BT0 image for RISC-V.
tools/sunxi_egon.c | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/tools/sunxi_egon.c b/tools/sunxi_egon.c index e1c945a12f..06e8d67ebc 100644 --- a/tools/sunxi_egon.c +++ b/tools/sunxi_egon.c @@ -30,6 +30,7 @@ static int egon_check_params(struct image_tool_params *params) */ switch (egon_get_arch(params)) { case IH_ARCH_ARM: + case IH_ARCH_RISCV: break; default: return EXIT_FAILURE; @@ -54,6 +55,10 @@ static int egon_verify_header(unsigned char *ptr, int image_size, if ((le32_to_cpu(header->b_instruction) & 0xff000000) != 0xea000000) return EXIT_FAILURE; break; + case IH_ARCH_RISCV: + if ((le32_to_cpu(header->b_instruction) & 0x00000fff) != 0x0000006f) + return EXIT_FAILURE; + break; default: return EXIT_FAILURE; /* Unknown architecture */ } @@ -115,6 +120,24 @@ static void egon_set_header(void *buf, struct stat *sbuf, int infd, value = 0xea000000 | (sizeof(struct boot_file_head) / 4 - 2); header->b_instruction = cpu_to_le32(value); break; + case IH_ARCH_RISCV: + /* + * Generate a RISC-V JAL instruction with rd=x0 + * (pseudo instruction J, jump without side effects). + * + * The following weird bit operation maps imm[20] + * to inst[31], imm[10:1] to inst[30:21], + * imm[11] to inst[20], imm[19:12] to inst[19:12], + * and imm[0] is dropped (because 1-byte RISC-V instruction + * is not allowed). + */ + value = 0x0000006f | + ((sizeof(struct boot_file_head) & 0x00100000) << 11) | + ((sizeof(struct boot_file_head) & 0x000007fe) << 20) | + ((sizeof(struct boot_file_head) & 0x00000800) << 9) | + ((sizeof(struct boot_file_head) & 0x000ff000) << 0); + header->b_instruction = cpu_to_le32(value); + break; }
As mkimage -T sunxi_egon now gains support for -A parameter, specify the architecture when generating SPL boot image for sunxi.
scripts/Makefile.spl | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 6f26eb1fa1..4cc23799db 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -411,7 +411,7 @@ endif $(obj)/$(SPL_BIN).sfp: $(obj)/$(SPL_BIN).bin FORCE $(call if_changed,mkimage)
-MKIMAGEFLAGS_sunxi-spl.bin = -T sunxi_egon \ +MKIMAGEFLAGS_sunxi-spl.bin = -A $(ARCH) -T sunxi_egon \ -n $(CONFIG_DEFAULT_DEVICE_TREE)
OBJCOPYFLAGS_u-boot-spl-dtb.hex := -I binary -O ihex --change-address=$(CONFIG_SPL_TEXT_BASE)
Andre Przywara
Samuel Holland
