[PATCH v2] pico-pi-imx7d: Unselect CONFIG_CONSOLE_MUX
Unselect CONFIG_CONSOLE_MUX to fix the following error for the input, output and error interfaces:
U-Boot 2023.10 (Oct 03 2023 - 21:23:18 -0300) ... In: No input devices available! Out: No output devices available! Err: No error devices available! Net: eth0: ethernet@30be0000 Hit any key to stop autoboot: 0
Signed-off-by: Fabio Estevam festevam@denx.de --- Changes since v1: - Apply for all pico-imx7 defconfigs.
configs/pico-dwarf-imx7d_defconfig | 1 + configs/pico-hobbit-imx7d_defconfig | 1 + configs/pico-imx7d_bl33_defconfig | 1 + configs/pico-imx7d_defconfig | 1 + configs/pico-nymph-imx7d_defconfig | 1 + configs/pico-pi-imx7d_defconfig | 1 + 6 files changed, 6 insertions(+)
diff --git a/configs/pico-dwarf-imx7d_defconfig b/configs/pico-dwarf-imx7d_defconfig index 2cd906a63da0..8a99b813daee 100644 --- a/configs/pico-dwarf-imx7d_defconfig +++ b/configs/pico-dwarf-imx7d_defconfig @@ -22,6 +22,7 @@ CONFIG_BOARD_SIZE_LIMIT=715776 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx7d-pico-dwarf.dtb" +# CONFIG_CONSOLE_MUX is not set CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000 diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index b63281e53322..9a51a958a686 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -22,6 +22,7 @@ CONFIG_BOARD_SIZE_LIMIT=715776 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx7d-pico-hobbit.dtb" +# CONFIG_CONSOLE_MUX is not set CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000 diff --git a/configs/pico-imx7d_bl33_defconfig b/configs/pico-imx7d_bl33_defconfig index 546e1e6545d3..b5eedec82757 100644 --- a/configs/pico-imx7d_bl33_defconfig +++ b/configs/pico-imx7d_bl33_defconfig @@ -24,6 +24,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run distro_bootcmd" +# CONFIG_CONSOLE_MUX is not set CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000 diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index f11e1f4ef413..02af6533e37a 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -22,6 +22,7 @@ CONFIG_BOARD_SIZE_LIMIT=715776 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="ask" +# CONFIG_CONSOLE_MUX is not set CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000 diff --git a/configs/pico-nymph-imx7d_defconfig b/configs/pico-nymph-imx7d_defconfig index 2cd906a63da0..8a99b813daee 100644 --- a/configs/pico-nymph-imx7d_defconfig +++ b/configs/pico-nymph-imx7d_defconfig @@ -22,6 +22,7 @@ CONFIG_BOARD_SIZE_LIMIT=715776 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx7d-pico-dwarf.dtb" +# CONFIG_CONSOLE_MUX is not set CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000 diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index 3e26aae40053..5b479818d88e 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -22,6 +22,7 @@ CONFIG_BOARD_SIZE_LIMIT=715776 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx7d-pico-pi.dtb" +# CONFIG_CONSOLE_MUX is not set CONFIG_SPL_MAX_SIZE=0xe000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_MAX_SIZE=0x100000
From: Fabio Estevam festevam@denx.de Unselect CONFIG_CONSOLE_MUX to fix the following error for the input, output and error interfaces: U-Boot 2023.10 (Oct 03 2023 - 21:23:18 -0300) ... In: No input devices available! Out: No output devices available! Err: No error devices available! Net: eth0: ethernet@30be0000 Hit any key to stop autoboot: 0 Signed-off-by: Fabio Estevam festevam@denx.de
Best regards, Stefano Babic
Fabio Estevam
sbabic@denx.de
