[U-Boot] [PATCH 1/2] ARM: tegra: Fix mux type for disp1 and disp2 clocks on Tegra210
On Tegra210 the parents for the disp1 and disp2 clocks are slightly different from earlier chips. Only pll_p, pll_d_out0, pll_d2_out0 and clk_m are valid parents (technically pll_d_out is as well, but U-Boot doesn't know anything about it). Fix up the type name and the mux definition.
Signed-off-by: Thierry Reding treding@nvidia.com --- arch/arm/mach-tegra/tegra210/clock.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-tegra/tegra210/clock.c b/arch/arm/mach-tegra/tegra210/clock.c index 06068c4b7b8d..0d7cafea2017 100644 --- a/arch/arm/mach-tegra/tegra210/clock.c +++ b/arch/arm/mach-tegra/tegra210/clock.c @@ -40,7 +40,7 @@ enum clock_type_id { CLOCK_TYPE_PDCT, CLOCK_TYPE_ACPT, CLOCK_TYPE_ASPTE, - CLOCK_TYPE_PMDACD2T, + CLOCK_TYPE_PDD2T, CLOCK_TYPE_PCST, CLOCK_TYPE_DP,
@@ -97,8 +97,8 @@ static enum clock_id clock_source[CLOCK_TYPE_COUNT][CLOCK_MAX_MUX+1] = { { CLK(AUDIO), CLK(SFROM32KHZ), CLK(PERIPH), CLK(OSC), CLK(EPCI), CLK(NONE), CLK(NONE), CLK(NONE), MASK_BITS_31_29}, - { CLK(PERIPH), CLK(MEMORY), CLK(DISPLAY), CLK(AUDIO), - CLK(CGENERAL), CLK(DISPLAY2), CLK(OSC), CLK(NONE), + { CLK(PERIPH), CLK(NONE), CLK(DISPLAY), CLK(NONE), + CLK(NONE), CLK(DISPLAY2), CLK(OSC), CLK(NONE), MASK_BITS_31_29}, { CLK(PERIPH), CLK(CGENERAL), CLK(SFROM32KHZ), CLK(OSC), CLK(NONE), CLK(NONE), CLK(NONE), CLK(NONE), @@ -174,8 +174,8 @@ static enum clock_type_id clock_periph_type[PERIPHC_COUNT] = { TYPE(PERIPHC_0bh, CLOCK_TYPE_NONE), TYPE(PERIPHC_0ch, CLOCK_TYPE_NONE), TYPE(PERIPHC_SBC1, CLOCK_TYPE_PC2CC3M_T), - TYPE(PERIPHC_DISP1, CLOCK_TYPE_PMDACD2T), - TYPE(PERIPHC_DISP2, CLOCK_TYPE_PMDACD2T), + TYPE(PERIPHC_DISP1, CLOCK_TYPE_PDD2T), + TYPE(PERIPHC_DISP2, CLOCK_TYPE_PDD2T),
/* 0x10 */ TYPE(PERIPHC_10h, CLOCK_TYPE_NONE),
pll_c is not a valid parent for the disp1 clock, so trying to set it will fail. Given that display is not used in U-Boot, remove the init table entry so that disp1 will keep its default parent (clk_m).
Signed-off-by: Thierry Reding treding@nvidia.com --- arch/arm/mach-tegra/tegra210/clock.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/mach-tegra/tegra210/clock.c b/arch/arm/mach-tegra/tegra210/clock.c index 0d7cafea2017..b240860f08cf 100644 --- a/arch/arm/mach-tegra/tegra210/clock.c +++ b/arch/arm/mach-tegra/tegra210/clock.c @@ -1265,7 +1265,6 @@ struct periph_clk_init periph_clk_init_table[] = { { PERIPH_ID_SBC5, CLOCK_ID_PERIPH }, { PERIPH_ID_SBC6, CLOCK_ID_PERIPH }, { PERIPH_ID_HOST1X, CLOCK_ID_PERIPH }, - { PERIPH_ID_DISP1, CLOCK_ID_CGENERAL }, { PERIPH_ID_SDMMC1, CLOCK_ID_PERIPH }, { PERIPH_ID_SDMMC2, CLOCK_ID_PERIPH }, { PERIPH_ID_SDMMC3, CLOCK_ID_PERIPH },
Thierry Reding
