[U-Boot] [RFC 0/3] omap3evm: Add support for quick boot
This series is based on the comments received [1] on my earlier submission[2].
Intent of sending as RFC is to thrash out the ideas and then send a formal patch.
More details in individual patch description.
[1] http://marc.info/?l=u-boot&m=128818733126234&w=2 [2] http://marc.info/?l=u-boot&m=128818664024766&w=2
There could be compilation issues as I have not tried building the u-boot with these changes; but will sort them (if any) for final submission.
Sanjeev Premi (3): omap3evm: Move generic config options in common file omap3evm: Update configuration to use common definitions omap3evm: Add support for quick boot
include/configs/omap3_evm_common.h | 269 ++++++++++++++++++++++++++++++++++++ include/configs/omap3_evm_full.h | 160 +++++++++++++++++++++ include/configs/omap3_evm_quick.h | 155 +++++++++++++++++++++ 3 files changed, 584 insertions(+), 0 deletions(-) create mode 100644 include/configs/omap3_evm_common.h create mode 100644 include/configs/omap3_evm_full.h create mode 100644 include/configs/omap3_evm_quick.h
Dear Sanjeev Premi,
Sorry, as you submitted this I see only 3 completely new files without relation to each other nor with any relation to the existing code.
I suggest the following approach:
Patch 1: move common code out of include/configs/omap3_evm.h into a new file include/configs/omap3_evm_common.h; this patch should result in exactly the same code for the board as we have now.
Do not rename omap3_evm.h into omap3_evm_full.h; this makes no sense to me. omap3_evm.h is and remains the default configuration.
Patch 2: Create a new file omap3_evm_quick.h, which contains the speed optimized configuration settings. Get rid of all the
#ifndef FOO #define FOO #endif stuff there. This is a plain simple and fixed configuration, so this is not needed.
You may even consider to splitting this more - into omap3_evm_quick_nand.h and omap3_evm_quick_mmc.h to eliminate even more of the #ifdeffery.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Thursday, October 28, 2010 10:24 PM To: Premi, Sanjeev Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [RFC 0/3] omap3evm: Add support for quick boot
Dear Sanjeev Premi,
[sp] Since I was also moving the related config options next to each other - as against current spread. I couldn't make much sens of patch. Thought it could be confusing to others as well. Appears, I was wrong!
[sp] Sorry, I didn't clean this up considering the focus would be on the first 2 patches.
[sp] That's a good idea. Will have it implemented tomorrow morning.
best regards, Sanjeev
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de A modem is a baudy house.
Dear "Premi, Sanjeev",
In message B85A65D85D7EB246BE421B3FB0FBB593023475E806@dbde02.ent.ti.com you wrote:
Please don't do this in the same patch. Do it as a separate commit either before or after splitting the config files.
Premi, Sanjeev
Sanjeev Premi
